  4. Restore funktioniert nicht
101 Beiträge 19 Kommentatoren 21.4k Aufrufe 7 Beobachtet
  • simatecS simatec
    @r0b1zZle
    Mit welchem User hast du iobroker installiert?
    Hast du mal deine Backups mit 7zip vorher geprüft? Sind die eventuell defekt?
    Füge mal deinen User der Gruppe iobroker hinzu.
    sudo usermod -aG iobroker {Benutzername}
    sudo reboot
    Bitte den Benutzer ohne Klammern
    r0b1zZle
    #61
    @simatec mit "pi"
    sudo usermod -aG iobroker pi
    sudo reboot
    Danach nochmal:
    pi@raspberrypi4-iob:~ $ iobroker stop
    pi@raspberrypi4-iob:~ $ sudo chmod 777 /opt/iobroker/backups/iobroker_2020_03_31-17_31_52_backupiobroker.tar.gz
    pi@raspberrypi4-iob:~ $ iobroker restore iobroker_2020_03_31-17_31_52_backupiobroker.tar.gz
    host.raspberrypi4-iob Cannot extract from file "/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../backups/iobroker_2020_03_31-17_31_52_backupiobroker.tar.gz"
    host.raspberrypi4-iob Cannot find extracted file from file "/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json"
    iobroker controller daemon is not running
    host.raspberrypi4-iob OK.
    (node:1261) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
        at Object.openSync (fs.js:443:3)
        at Object.readFileSync (fs.js:343:35)
        at BackupRestore.restoreAfterStop (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:566:23)
        at Daemon.daemon.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:846:22)
        at Daemon.emit (events.js:203:15)
        at Daemon._kill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:246:14)
        at Daemon.stop (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:185:17)
        at tar.extract.err (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:848:20)
        at process._tickCallback (internal/process/next_tick.js:68:7)
    (node:1261) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
    (node:1261) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    • R r0b1zZle
      @simatec mit "pi"
      sudo reboot
      Danach nochmal:
      simatecS Offline
      simatecS Offline
      simatec
      #62
      @r0b1zZle
      Wie sehen denn die Rechte das Backup Ordners aus?
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      R 1 Antwort Letzte Antwort
      • simatecS simatec
        @r0b1zZle
        r0b1zZle
        #63
        @simatec
        pi@raspberrypi4-iob:~ $ ls -al /opt/iobroker/
        drwxrwxr-x+   2 iobroker iobroker   4096 Mär 31 17:57 backups
        • R r0b1zZle
          @simatec
          simatecS Offline
          simatecS Offline
          simatec
          #64
          @r0b1zZle
          Da ist aber nicht viel drin in dem Ordner /opt/iobroker
          Oder hast du die Ausgabe gekürzt?
          • simatecS simatec
            @r0b1zZle
            r0b1zZle
            #65
            @simatec ja, willst du die ganze Liste?
            • R r0b1zZle
              simatecS Offline
              simatecS Offline
              simatec
              #66
              @r0b1zZle
              Nein das ist ok ... Fangen wir wir mal von vorne an.
              Welche node, nodejs, npm und js-controller Version sind aktuell bei dir installiert?
              • simatecS simatec
                @r0b1zZle
                r0b1zZle
                #67
                @simatec
                node: v10.19.0
                nodejs: v10.19.0
                npm: 6.13.4
                js-controller: 2.2.9
                simatecS 2 Antworten Letzte Antwort
                • R r0b1zZle
                  @simatec
                  node: v10.19.0
                  nodejs: v10.19.0
                  npm: 6.13.4
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #68
                  @r0b1zZle
                  Mit welchen js-controller wurde die Backup-Datei erstellt?
                  Kannst du bitte nochmal den Fixer ausführen und schauen, ob da irgendwelche Fehler kommen?
                  cd /opt/iobroker
                  • R r0b1zZle
                    @simatec
                    node: v10.19.0
                    nodejs: v10.19.0
                    npm: 6.13.4
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #69
                    @r0b1zZle
                    Hier noch ein Tipp aus der Forumsuche.
                    Vielleicht hilft dir dies ja auch weiter ...
                    https://forum.iobroker.net/post/397524
                      paul.honka
                      schrieb am zuletzt editiert von paul.honka
                      #70
                      ich hänge mich mal dran. Auch bei mir läuft nach der Neuinstallation, wie in der Doku unter Linux beschrieben, das Restore nicht. Nach der Installation über curl wurde der Backitup Adapter installiert und das Restore angestossen.Backup ca. / Tage alt. node und nodejs sind 10.19.0 und
                      npm ist 6.14.4 und js ist 2.2.9. Ich komme nach dem Restore nicht mehr auf die Weboberfläche. Der Fixer wurde auch schon gestartet, ohne Erfolg.
                      Im Log stehen alle 30 sek folgende Meldungen:
                      2020-04-01 12:07:22.443 - error: host.Humboldt35 No connection to databases possible, restart
                      2020-04-01 12:07:22.449 - info: host.Humboldt35 iobroker _restart
                      2020-04-01 12:07:23.347 - info: host.Humboldt35 iobroker Starting node restart.js
                      2020-04-01 12:07:25.127 - info: host.Humboldt35 iobroker.js-controller version 2.2.9 js-controller starting
                      2020-04-01 12:07:25.138 - info: host.Humboldt35 Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                      2020-04-01 12:07:25.139 - info: host.Humboldt35 hostname: Humboldt35, node: v10.19.0
                      2020-04-01 12:07:25.142 - info: host.Humboldt35 ip addresses: 192.168.0.60 2a02:8109:1b3f:c414:effe:edd5:8f02:593d fe80::a958:8030:a81b:3e64
                      Was ist denn da verkehrt gelaufen?
                      Beste Grüsse Paul
                      • simatecS simatec
                        @r0b1zZle
                        cd /opt/iobroker
                        r0b1zZle
                        #71
                        @simatec Das Backup wurde auch mit 2.2.9 erstellt.
                        pi@raspberrypi4-iob:/opt/iobroker $ cd /opt/iobroker
                        pi@raspberrypi4-iob:/opt/iobroker $ iobroker stop
                        pi@raspberrypi4-iob:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
                        library: loaded
                        Library version=2020-01-30
                            Welcome to the ioBroker installation fixer!
                            Script version: 2020-01-25
                            You might need to enter your password a couple of times.
                            Installing prerequisites (1/3)
                        Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                        OK:2 http://archive.raspberrypi.org/debian buster InRelease
                        OK:3 https://deb.nodesource.com/node_10.x buster InRelease
                        Holen:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
                        Es wurden 13,0 MB in 6 s geholt (2.158 kB/s).
                        Installed gcc-c++
                            Checking ioBroker user and directory permissions (2/3)
                        Created /etc/sudoers.d/iobroker
                            Checking autostart (3/3)
                        Enabling autostart...
                        Autostart enabled!
                        @simatec Danke, ich werde das mit WinSCP mal testen.
                        • P paul.honka
                          Beste Grüsse Paul
                          simatecS Offline
                          simatecS Offline
                          simatec
                          #72
                          @paul-honka sagte in Restore funktioniert nicht:
                          Da steht es doch ... Wie war der Hostname deines alten Systems?
                          Hattest du redis auf deinem altem System laufen?
                          • R r0b1zZle
                            library: loaded
                            Installed gcc-c++
                            Autostart enabled!
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #73
                            @r0b1zZle
                            Dann tendiere ich eher dazu, das beim kopieren der Backupdatei etwas schief geht ...
                            Was nutzt du für ein FTP Tool?
                              paul.honka
                              #74
                              Hi simatec,
                              ich bin mir sicher, das der auch Humboldt35 hieß.
                              Kann ich das im Backup irgendwo sehen?
                              Beste Grüsse Paul
                              • simatecS simatec
                                @r0b1zZle
                                r0b1zZle
                                #75
                                @simatec Garkeines bisher, habe immer die SD-Karte per Card-Reader an den Windows PC gesteckt, via "Paragon ExtFS for Windows" gemounted und händisch kopiert. Würde dann WinSCP mal testen.
                                • P paul.honka
                                  Beste Grüsse Paul
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #76
                                  Der Restore lief sauber durch ... aber du hast etwas nicht beachtet, dass es zu diesen Fehler kommt
                                  • R r0b1zZle
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #77
                                    @r0b1zZle
                                    ja mach das mal bitte. Wo hast du das hin kopiert???
                                    Auf das Linuxsystem??
                                    • simatecS simatec
                                      @r0b1zZle
                                      r0b1zZle
                                      #78
                                      @simatec Ja, von "/opt/iobroker/backups" auf ein Windows-Verzeichnis und von dem Windows-Verzeichnis wieder in "/opt/iobroker/backups".
                                      • P paul.honka
                                        Hi simatec,
                                        Beste Grüsse Paul
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #79
                                        Humboldt35
                                        Führe mal zur Sicherheit folgendes aus
                                        iobroker host this
                                        und zeige mir mal bitte den Inhalt von:
                                        iobroker status
                                        • R r0b1zZle
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #80
                                          @r0b1zZle sagte in Restore funktioniert nicht:
                                          ohhhhaaa ... das ist sicher keine gute Idee gewesen ... Diese Info hätten wir etwas eher gebrauchen können ;-)
