  3. Einsteigerfragen
  4. Installation
  5. Raspi hängt sich 2x täglich auf
38 Beiträge 7 Kommentatoren 2.9k Aufrufe 5 Beobachtet
  • T Theophilus
    @theophilus Gestern 14.17
    2023-05-30 13:29:30.562 - info: admin.0 (831) ==> Connected system.user.admin from ::ffff:192.168.178.42
    2023-05-30 13:42:55.653 - info: admin.0 (831) <== Disconnect system.user.admin from ::ffff:192.168.178.42 admin
    2023-05-30 14:18:26.657 - info: admin.0 (831) Request actual repository...
    2023-05-30 14:18:28.004 - info: host.raspberrypi Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    2023-05-30 14:17:14.307 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
    2023-05-30 14:17:14.322 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-05-30 14:17:14.325 - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
    2023-05-30 14:17:14.326 - info: host.raspberrypi ip addresses: fe80::4d0d:5036:a3d5:2263
    2023-05-30 14:17:17.489 - info: host.raspberrypi connected to Objects and States
    2023-05-30 14:17:17.566 - info: host.raspberrypi added notifications configuration of host
    2023-05-30 14:17:18.525 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
    2023-05-30 14:17:18.539 - info: host.raspberrypi 8 instances found
    2023-05-30 14:17:18.576 - info: host.raspberrypi starting 8 instances
    2023-05-30 14:17:18.695 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
    2023-05-30 14:17:18.724 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
    2023-05-30 14:17:18.761 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 626
    2023-05-30 14:17:18.847 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
    2023-05-30 14:17:18.920 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
    2023-05-30 14:17:18.994 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
    2023-05-30 14:17:19.066 - info: host.raspberrypi Some obsolete host states deleted.
    2023-05-30 14:17:22.683 - info: host.raspberrypi instance system.adapter.history.0 started with pid 633
    2023-05-30 14:17:23.253 - error: admin.0 (626) admin.0 already running
    2023-05-30 14:17:23.262 - warn: admin.0 (626) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-05-30 14:17:23.907 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-05-30 14:17:23.909 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2023-05-30 14:17:26.052 - error: history.0 (633) history.0 already running
    2023-05-30 14:17:26.061 - warn: history.0 (633) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-05-30 14:17:26.679 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 648
    2023-05-30 14:17:26.725 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-05-30 14:17:26.727 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
    2023-05-30 14:17:30.698 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 655
    2023-05-30 14:17:34.002 - error: javascript.0 (648) javascript.0 already running
    2023-05-30 14:17:34.009 - warn: javascript.0 (648) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-05-30 14:17:34.213 - error: mqtt.0 (655) mqtt.0 already running
    2023-05-30 14:17:34.222 - warn: mqtt.0 (655) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-05-30 14:17:34.669 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-05-30 14:17:34.670 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
    2023-05-30 14:17:34.808 - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 670
    2023-05-30 14:17:34.855 - error: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-05-30 14:17:34.857 - info: host.raspberrypi Restart adapter system.adapter.mqtt.0 because enabled
    arteckA Offline
    arteckA Offline
    arteck
    @theophilus sagte in Raspi hängt sich 2x täglich auf:
    hier wird probiert alles nochmal zu starten...
    machst du da backup vielleicht.. und das geht in die hose..
    • T Theophilus
      @arteck Davor ist erstmal 20 Minuten lang nix passiert:
      2023-05-31 00:00:00.056 - info: sourceanalytix.0 (811) Reset start values for : 0_userdata.0.Stromkasten.Verbrauch_Total
      2023-05-31 00:00:00.097 - info: sourceanalytix.0 (811) Memory values before reset : {"stateDetails":{"consumption":true,"deviceName":"0_userdata__0__Stromkasten__Verbrauch_Total","financialCategory":"earnings","headCategory":"delivered","meter_values":true,"stateType":"ElectricityDelivery","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1},"calcValues":{"cumulativeValue":11694.8968,"start_day":11678,"start_month":11389,"start_quarter":0,"start_week":11678,"start_year":9777,"valueAtDeviceReset":0,"valueAtDeviceInit":null},"prices":{"basicPrice":"15","unitPrice":"0.17"}}
      2023-05-31 00:00:00.149 - info: sourceanalytix.0 (811) Memory values after reset : {"stateDetails":{"consumption":true,"deviceName":"0_userdata__0__Stromkasten__Verbrauch_Total","financialCategory":"earnings","headCategory":"delivered","meter_values":true,"stateType":"ElectricityDelivery","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1},"calcValues":{"start_day":11694.8968,"start_month":11389,"start_quarter":0,"start_week":11678,"start_year":9777,"valueAtDeviceInit":null,"valueAtDeviceReset":0,"cumulativeValue":11694.8968},"prices":{"basicPrice":"15","unitPrice":"0.17"}}
      2023-05-31 00:00:00.150 - info: sourceanalytix.0 (811) Reset start values for : 0_userdata.0.Stromkasten.Einspeisung_Total
      2023-05-31 00:00:00.151 - info: sourceanalytix.0 (811) Memory values before reset : {"stateDetails":{"consumption":true,"deviceName":"0_userdata__0__Stromkasten__Einspeisung_Total","financialCategory":"earnings","headCategory":"delivered","meter_values":true,"stateType":"ElectricityDelivery","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1},"calcValues":{"cumulativeValue":103.0017,"start_day":101,"start_month":53,"start_quarter":16,"start_week":98,"start_year":0,"valueAtDeviceReset":0,"valueAtDeviceInit":null},"prices":{"basicPrice":"15","unitPrice":"0.17"}}
      2023-05-31 00:00:00.175 - info: sourceanalytix.0 (811) Memory values after reset : {"stateDetails":{"consumption":true,"deviceName":"0_userdata__0__Stromkasten__Einspeisung_Total","financialCategory":"earnings","headCategory":"delivered","meter_values":true,"stateType":"ElectricityDelivery","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1},"calcValues":{"start_day":103.0017,"start_month":53,"start_quarter":16,"start_week":98,"start_year":0,"valueAtDeviceInit":null,"valueAtDeviceReset":0,"cumulativeValue":103.0017},"prices":{"basicPrice":"15","unitPrice":"0.17"}}
      2023-05-31 02:02:04.727 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (1): connection timed out
      2023-05-31 02:02:29.769 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (3): connection timed out
      2023-05-31 02:03:14.773 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (5): connection timed out
      2023-05-31 02:04:19.776 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (7): connection timed out
      2023-05-31 02:04:20.689 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Connect locally to device
      2023-05-31 02:04:20.690 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt Init with IP=192.168.178.122, Key=2149e76c6ae6295f, Version=3.3
      2023-05-31 02:04:25.698 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (1): connection timed out
      2023-05-31 02:04:50.700 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (3): connection timed out
      2023-05-31 02:05:35.704 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (5): connection timed out
      2023-05-31 02:06:40.708 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (7): connection timed out
      2023-05-31 02:06:45.642 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Connect locally to device
      2023-05-31 02:06:45.644 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt Init with IP=192.168.178.122, Key=2149e76c6ae6295f, Version=3.3
      2023-05-31 02:06:50.648 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (1): connection timed out
      2023-05-31 02:07:15.651 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (3): connection timed out
      Moin,
      ich ehe einfach mal davon aus, dass Dir der Speicher bei irgendeiner Aktion ausgeht und das System crasht.
      MEMORY:
      Mem:            909M        632M        120M        0.0K        156M        218M
      Swap:            99M         89M         10M
      Total:          1.0G        721M        131M
      Wie viele Adapter hast Du denn installiert und wie viele sind aktiv?
      Zeig doch mal die Langfassung von iob diag und aus dem journal die Einträge zur Zeit der Abstürze, hier mal Beispiele:
      Vor 1 Stunde bis jetzt
      $ journalctl --since "1 hour ago"
      Von vor 2 Tagen bis jetzt
      $ journalctl --since "2 days ago"
      Zwischen zwei Zeiten*
      $ journalctl --since "2015-06-26 23:15:00" --until "2015-06-26 23:20:00"
      Oder schau mal, ob Du oom, kill im Log hast
      $ journalctl | grep -iE 'oom|kill'
      Bernd
      • T Theophilus
        @arteck ich treibe gar nichts ... Das macht der Raspi ganz von alleine!
        		     v.2023-04-16
        Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
        Kernel: 		6.1.21-v8+
        Installation: 		Native
        Timezone: 		Europe/Berlin (CEST, +0200)
        User-ID: 		1000
        X-Server: 		false
        Boot Target: 		multi-user.target
        Pending OS-Updates: 	0
        Pending iob updates: 	0
        Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.0
        			/usr/bin/node 		v18.16.0
        			/usr/bin/npm 		9.5.1
        			/usr/bin/npx 		9.5.1
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Swap:            99M         89M         10M
        Active iob-Instances: 	9
        Active repo(s): stable
        ioBroker Core: 		js-controller 		4.0.24
        			admin 			6.3.5
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects: 		706
        States: 		628
        Size of iob-Database:
        40M	/opt/iobroker/iobroker-data/objects.jsonl
        6.7M	/opt/iobroker/iobroker-data/states.jsonl
        @theophilus
        Gib mal die Langfassung von iob diag
        Und schau zu den Zeiten in das Journal rein.
        Edit: Zu langsam und zu ungenau gewesen... :-)
          Moin,
          MEMORY:
          Swap:            99M         89M         10M
          Bernd
          @dp20eic
          Könnte für 1GB RAM schon zu viel sein.
          ? T 2 Antworten Letzte Antwort
          • arteckA arteck
            von alleine passiert erstmal nix..
            wie hast du den iobroker installiert ? und wir brauchen das LOG vor dem aufhängen nicht danach
            Theophilus
            @arteck sagte in Raspi hängt sich 2x täglich auf:
            Das Log entstand unmittelbar vor dem Aufhängen. Es waren quasi seine letzten Lebenszeichen.
              @dp20eic
              @thomas-braun sagte in Raspi hängt sich 2x täglich auf:
              Moin,
              oh, danke, war wohl zu früh oder ich brauche doch eine Brille, wenn ich am Laptop arbeite :)
              Bernd
              P.S.: also Betriebssystem, nodejs, iobroker, adapter, mir schwebt da eine Aussage vor den Augen, dass da so zwischen 60 - 100 MB pro Adapter zu veranschlagen ist, dann vielleicht noch Backup oder Scripte die da etwas machen, dann kann es eng werden.
                @dp20eic
                Theophilus
                @thomas-braun Erweitern kann man beim Raspi nichts, oder?
                • T Theophilus
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  RAM ? Natürlich nicht
                  Lehrling seit 1975 !!!
                  • DJMarc75D DJMarc75
                    @djmarc75
                    Der McGiver-Ansatz:
                    https://www.pcgameshardware.de/Raspberry-Pi-Hardware-257637/News/4-RAM-Chip-16-GB-Upgrade-1418168/
                      @djmarc75
                      Der McGiver-Ansatz:
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      Der McGiver-Ansatz:
                      ein Streicholz und ein Kaugummipapier 😂
                      konnte damit schon viele LinuxProbleme lösen 😀 👍
                        Der McGiver-Ansatz:
                        @djmarc75
                        Ja, die universell einsetzbaren libmatches und libbubblegum
                          @djmarc75
                          Theophilus
                          Heute nachmittag hat er sich nicht aufgehängt. War wohl Zufall, dass es gestern 2 Uhr und 14 Uhr war.
                          • T Theophilus
                            Theophilus
                            @theophilus Er bleibt bei. Alles läuft super, dann kommt dieser ominöse Neustart und der Raspi hängt sich auf.
                            2023-06-05 07:17:15.426 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                            2023-06-05 07:17:15.439 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                            2023-06-05 07:17:15.441 - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                            2023-06-05 07:17:15.443 - info: host.raspberrypi ip addresses: fe80::4d0d:5036:a3d5:2263
                            2023-06-05 07:17:19.097 - info: host.raspberrypi connected to Objects and States
                            2023-06-05 07:17:19.194 - info: host.raspberrypi added notifications configuration of host
                            2023-06-05 07:17:20.208 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
                            2023-06-05 07:17:20.221 - info: host.raspberrypi 9 instances found
                            2023-06-05 07:17:20.262 - info: host.raspberrypi starting 9 instances
                            2023-06-05 07:17:20.399 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
                            2023-06-05 07:17:20.436 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
                            2023-06-05 07:17:20.475 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 632
                            2023-06-05 07:17:20.509 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
                            2023-06-05 07:17:20.543 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
                            2023-06-05 07:17:20.617 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
                            2023-06-05 07:17:20.646 - info: host.raspberrypi Some obsolete host states deleted.
                            2023-06-05 07:17:24.495 - info: host.raspberrypi instance system.adapter.history.0 started with pid 639
                            2023-06-05 07:17:25.903 - info: admin.0 (632) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
                            2023-06-05 07:17:26.028 - info: admin.0 (632) requesting all states
                            2023-06-05 07:17:26.030 - info: admin.0 (632) requesting all objects
                            2023-06-05 07:17:28.610 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 666
                            2023-06-05 07:17:29.621 - info: admin.0 (632) received all objects
                            2023-06-05 07:17:30.198 - info: history.0 (639) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.history, node: v18.16.0, js-controller: 4.0.24
                            2023-06-05 07:17:30.369 - info: history.0 (639) enabled logging of 0_userdata.0.Solar.Solar_Aktuell (Count=1), Alias=false
                            2023-06-05 07:17:30.372 - info: history.0 (639) enabled logging of 0_userdata.0.Stromkasten.Verbrauch_Aktuell (Count=2), Alias=false
                            2023-06-05 07:17:30.375 - info: history.0 (639) enabled logging of 0_userdata.0.Stromkasten.Verbrauch_Total (Count=3), Alias=false
                            2023-06-05 07:17:30.377 - info: history.0 (639) enabled logging of 0_userdata.0.Stromkasten.Einspeisung_Total (Count=4), Alias=false
                            2023-06-05 07:17:31.502 - info: admin.0 (632) Request actual repository...
                            2023-06-05 07:17:31.655 - info: admin.0 (632) http server listening on port 8081
                            2023-06-05 07:17:31.658 - info: admin.0 (632) Use link "http://localhost:8081" to configure.
                            2023-06-05 07:17:31.703 - info: admin.0 (632) socket.io server listening on port 8081
                            2023-06-05 07:17:33.587 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                            2023-06-05 07:17:33.770 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 681
                            2023-06-05 07:17:35.155 - info: admin.0 (632) failed connection to socket.io from ::ffff:192.168.178.42: Passport was not initialized
                            2023-06-05 07:17:35.438 - info: admin.0 (632) failed connection to socket.io from ::ffff:192.168.178.42: Passport was not initialized
                            2023-06-05 07:17:36.396 - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 688
                            • T Theophilus
                              @theophilus
                              Schau in dein Journal.
                                @theophilus
                                Theophilus
                                @thomas-braun Das Merkwürdige ist, dass die iobroker-Instanz zu dieser Zeit gestoppt war. Da ich in den nächsten Tagen viel unterwegs bin und sich der Raspi immer wieder aufhängt und mir dann über Tage hinweg die Stromdaten fehlen, war mein Plan, den Raspi jeweils um 2:00 Uhr nachts neu zu starten. 1.Versuch: per Cron-Job und wenn das nichts bringt, brutal per Zeitschaltuhr und kappen der Stromzufuhr.
                                Heute nacht also Cronjob. Der hat geklappt (nur beim Reboot habe ich einen Fehler gemacht.) Journal:
                                un 05 02:00:01 raspberrypi CRON[2510]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
                                Jun 05 02:00:01 raspberrypi CRON[2511]: (root) CMD (iobroker stop)
                                Jun 05 02:00:01 raspberrypi sudo[2516]:     root : PWD=/root ; USER=root ; COMMAND=/usr/bin/systemctl stop iobroker
                                Jun 05 02:00:01 raspberrypi sudo[2516]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
                                Jun 05 02:00:01 raspberrypi systemd[1]: Stopping ioBroker Server...
                                Jun 05 02:00:03 raspberrypi bash[488]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
                                Jun 05 02:00:03 raspberrypi bash[488]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                                Jun 05 02:00:03 raspberrypi bash[488]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
                                Jun 05 02:00:03 raspberrypi bash[488]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
                                Jun 05 02:00:06 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                Jun 05 02:00:06 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                Jun 05 02:00:06 raspberrypi systemd[1]: Stopped ioBroker Server.
                                Jun 05 02:00:06 raspberrypi systemd[1]: iobroker.service: Consumed 38min 33.182s CPU time.
                                Jun 05 02:00:06 raspberrypi sudo[2516]: pam_unix(sudo:session): session closed for user root
                                Ju
                                So ganz verstehe ich aber nicht, was die angezeigte Fehlermeldung bedeutet ...
                                crunchipC Thomas BraunT 3 Antworten Letzte Antwort
                                • T Theophilus
                                  Ju
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  das wäre ein dummer und tödlicher Prozess
                                  • T Theophilus
                                    Ju
                                    Welche?
                                    Und mit
                                    meinte ich natürlich den Zeitraum, wenn die Kiste rebootet.
                                    • T Theophilus
                                      Ju
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      dann vllt auf die ein oder andere Instanz für den Zeitraum verzichten, z.b tuya
                                      bzw was läuft da alles?
                                      eine weitere Möglichkeit wäre, falls vorhanden, die backitup Instanz per script starten/stoppen und nur fürs backup laufen lassen
                                      letztendlich, sind aber mittlerweile 1GB Ram einfach zu wenig für die heutige Leistung eines iobroker`s
                                        Theophilus
                                        @crunchip sagte in Raspi hängt sich 2x täglich auf:
                                        Aber wenn der Raspi hängt und nicht mal mehr per ssh ansprechbar ist, bleibt mir eh nichts anderes übrig ...
                                        Deswegen der Gedanke: per cronjob iobroker runterfahren, shutdown für den Raspi, dann den Strom weg. Das ganze in der Nacht, wenn die Daten eh übersichtlich sind.
                                        Wenn alles läuft, dürfte das dem System nicht schaden, wenn er hängt, kann ich sowieso nichts anderes machen.
                                        Oder hast du eine bessere Idee?
                                        • T Theophilus
                                          An die Ursachen herangehen.
                                          Aber da dürfte schlicht und einfach der Arbeitsspeicher ausgehen.
