  4. SMA Energy Meter in Echtzeit auslesen
    6.7k
85 Beiträge 16 Kommentatoren 35.0k Aufrufe 6 Beobachtet
    Marcolotti
    Trigger: Falls WERT von Objekt Netzbezug.
    mach mal aktualisiere "WERT" von Objekt Gesamtverbrauch.
    Den Gesamtverbrauch (Hausverbrauch) ermittelst du aber anders. Anbei mal mein Blockly-Script.
     <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="A_|oG95s;SJyu.E{x%7V" x="-637" y="-587"><mutation items="1"></mutation>
        <value name="OID0"><shadow type="field_oid" id=",XHVS?h[R1:AZAj~(]{I"><field name="oid">modbus.0.inputRegisters.30775_PVLeistung</field></shadow></value>
        <statement name="STATEMENT"><block type="controls_if" id="qHHO|g6/TAQ.).Yo{lH?"><value name="IF0"><block type="logic_compare" id="ReyL(zZ-IFCB!(,SQ7e."><field name="OP">GT</field>
                <value name="A"><block type="get_value" id="8d,ucU}B{Mu_/WoqL*wW"><field name="ATTR">val</field>
                    <field name="OID">modbus.0.inputRegisters.30865_Bezug</field></block></value>
                <value name="B"><block type="math_number" id="7gE)SC`pgjZ,OaJMKO@X"><field name="NUM">1</field></block></value></block></value>
            <statement name="DO0"><block type="update" id="gKGH45oZ.F#AW?GZDqUx"><mutation delay_input="false"></mutation>
                <field name="OID">javascript.0.PV_Anlage.AktHausverbrauch</field>
                <value name="VALUE"><block type="math_arithmetic" id="%%je1MKU.._nRf^9FUk7"><field name="OP">ADD</field>
                    <value name="A"><shadow type="math_number" id="_y%]3cOycFhKAJnHhJi("><field name="NUM">1</field></shadow>
                      <block type="get_value" id="bdETUtBo:uyyeb]WQBO-"><field name="ATTR">val</field>
                    <value name="B"><shadow type="math_number" id="-Z[8!/-igUXos;(vJUVw"><field name="NUM">1</field></shadow>
                      <block type="get_value" id="/.AZOS,oX]g-1|ppFf-q"><field name="ATTR">val</field>
                        <field name="OID">javascript.0.PV_Anlage.Werte.PVLeistung</field></block></value></block></value></block></statement></block></statement>
        <next><block type="on_ext" id="+hCBHdKPoJ07auWNVqF]"><mutation items="1"></mutation>
            <value name="OID0"><shadow type="field_oid" id="*+mSamkO0_PDL=-{%cK7"><field name="oid">modbus.0.inputRegisters.30865_Bezug</field></shadow></value>
            <statement name="STATEMENT"><block type="controls_if" id="0K4{*}3bY@,{E.kwU2iQ"><value name="IF0"><block type="logic_compare" id="ed)^9`y`u5M({wRJ0QK-"><field name="OP">LT</field>
                    <value name="A"><block type="get_value" id="q60LaHAnF9zFFy*t)8kv"><field name="ATTR">val</field>
                        <field name="OID">modbus.0.inputRegisters.30775_PVLeistung</field></block></value>
                    <value name="B"><block type="math_number" id="g`gA;;Igq%#{~XX:lVXG"><field name="NUM">1</field></block></value></block></value>
                <statement name="DO0"><block type="update" id="Zwm;%=MetHz@Z[rTU^k*"><mutation delay_input="false"></mutation>
                    <value name="VALUE"><block type="get_value" id="1K{jq}Q;uUh|#T1Fnml;"><field name="ATTR">val</field>
                        <field name="OID">modbus.0.inputRegisters.30865_Bezug</field></block></value></block></statement></block></statement>
            <next><block type="on_ext" id=").9fLJ-=]~P)cBvbL@N8"><mutation items="1"></mutation>
                <value name="OID0"><shadow type="field_oid" id="K(p8q^h+TEg6`+Tz|zHd"><field name="oid">modbus.0.inputRegisters.30867_Einspeisung</field></shadow></value>
                <statement name="STATEMENT"><block type="controls_if" id="aOwi+@J%Af2z`M]iUntU"><value name="IF0"><block type="logic_compare" id="HUpU+1WgogWAt~g::j1]"><field name="OP">GT</field>
                        <value name="A"><block type="get_value" id="s!Ryj}gQ_Rbb2hT9FOqr"><field name="ATTR">val</field>
                            <field name="OID">modbus.0.inputRegisters.30867_Einspeisung</field></block></value>
                        <value name="B"><block type="math_number" id="`c{;cIl!vvFwx3#M85m."><field name="NUM">1</field></block></value></block></value>
                    <statement name="DO0"><block type="update" id="8#B{9[vq+}.yjz4yt({;"><mutation delay_input="false"></mutation>
                        <value name="VALUE"><block type="math_arithmetic" id="6_p4XZ+.80LPnLU26+Qy"><field name="OP">MINUS</field>
                              <block type="get_value" id="/V5kC~bpl~iB)okjV~Y-"><field name="ATTR">val</field>
                              <block type="get_value" id="R(!t|d+6)8LLtF,vqJrs"><field name="ATTR">val</field>
                                <field name="OID">modbus.0.inputRegisters.30867_Einspeisung</field></block></value></block></value></block></statement></block></statement>
                <next><block type="on_ext" id="?36x-AQU8nD[OmAgz[_]"><mutation items="1"></mutation>
                    <value name="OID0"><shadow type="field_oid" id="tUm]PB6uk2%jJAb}2te:"><field name="oid">javascript.0.PV_Anlage.AktHausverbrauch</field></shadow></value>
                    <statement name="STATEMENT"><block type="controls_if" id="PxZ/oA[33q#/d~xL=!M{"><value name="IF0"><block type="logic_compare" id="oUy-3/+PJeC:uIB9JTkl"><field name="OP">GT</field>
                            <value name="A"><block type="get_value" id="-EfAF.m7|8F2NN7sTPm6"><field name="ATTR">val</field>
                                <field name="OID">javascript.0.PV_Anlage.AktHausverbrauch</field></block></value>
                            <value name="B"><block type="get_value" id="6tvlPvH7#`/c6*0)z}_g"><field name="ATTR">val</field>
                                <field name="OID">javascript.0.PV_Anlage.MaxVerbrauchHeute</field></block></value></block></value>
                        <statement name="DO0"><block type="update" id="7~kniq!7nBj?^0]Ibhk!"><mutation delay_input="false"></mutation>
                            <value name="VALUE"><block type="get_value" id="KqDq?2tl*2wVnB!lu;8Z"><field name="ATTR">val</field>
                                <field name="OID">javascript.0.PV_Anlage.AktHausverbrauch</field></block></value></block></statement></block></statement>
                    <next><block type="schedule" id="5BUMKb@ibWS7o?x2HzV+"><field name="SCHEDULE">59 59 23 * * *</field>
                        <statement name="STATEMENT"><block type="update" id="}%Q^Ta92/;nMH7!^ct|e"><mutation delay_input="false"></mutation>
                            <value name="VALUE"><block type="math_number" id="HnO;1qG,Ylaj*A@P=c(-"><field name="NUM">0</field></block></value>
                            <next><block type="update" id="|qy!pM2Uu~x:1Kreg)Oa"><mutation delay_input="false"></mutation>
                                <field name="OID">javascript.0.PV_Anlage.MaxPVHeute</field>
                                <value name="VALUE"><block type="math_number" id="fxF.%(]-Eo/Q|RkyMhKA"><field name="NUM">0</field></block></value></block></next></block></statement>
                        <next><block type="on_ext" id="n9_GDzS1NxQt2!RfN@Be"><mutation items="1"></mutation>
                            <value name="OID0"><shadow type="field_oid" id="4;_,hSYl5TxrGbMP,[l}"><field name="oid">modbus.0.inputRegisters.30775_PVLeistung</field></shadow></value>
                            <statement name="STATEMENT"><block type="controls_if" id="^Q.6FAXh!F7|qs6Nz/+#"><value name="IF0"><block type="logic_compare" id="y?-W.IqVC)OMg~rZ]t:8"><field name="OP">GT</field>
                                    <value name="A"><block type="get_value" id="NJFvsM[F-qi;W=o`m.ly"><field name="ATTR">val</field>
                                    <value name="B"><block type="get_value" id="Jd`/x7z!1L_[%FltwK[S"><field name="ATTR">val</field>
                                        <field name="OID">javascript.0.PV_Anlage.MaxPVHeute</field></block></value></block></value>
                                <statement name="DO0"><block type="update" id="*HHkx8OmN=E)HkaCdqLz"><mutation delay_input="false"></mutation>
                                    <value name="VALUE"><block type="get_value" id="l]/F%O}Yfn_nRj*I?@RD"><field name="ATTR">val</field>
                                        <field name="OID">javascript.0.PV_Anlage.Werte.PVLeistung</field></block></value></block></statement>
                                <next><block type="controls_if" id="Of|KASl2L#md3Ja5=BtB"><value name="IF0"><block type="logic_compare" id="4CLR;Ws?UfX])eQ8^mw*"><field name="OP">GT</field>
                                        <value name="A"><block type="get_value" id="LG!0Q+G[j(NJ~z:T]cO1"><field name="ATTR">val</field>
                                        <value name="B"><block type="get_value" id="(7I?/+syvHG:S@XcH},C"><field name="ATTR">val</field>
                                            <field name="OID">javascript.0.PV_Anlage.MAXPVever</field></block></value></block></value>
                                    <statement name="DO0"><block type="update" id="CL,.4(Wj5Sm].!4y@?pm"><mutation delay_input="false"></mutation>
                                        <value name="VALUE"><block type="get_value" id="._6z#.CayIYZT.7#c*VG"><field name="ATTR">val</field>
                                            <field name="OID">javascript.0.PV_Anlage.Werte.PVLeistung</field></block></value></block></statement></block></next></block></statement>
                            <next><block type="on_ext" id="m2w.v~KBYw4MNQAZ%4e6"><mutation items="1"></mutation>
                                <value name="OID0"><shadow type="field_oid" id="2^/i*jy?5F[n9W?N|j}j"><field name="oid">javascript.0.PV_Anlage.AktHausverbrauch</field></shadow></value>
                                <statement name="STATEMENT"><block type="controls_if" id="PSIuUZVF2K(,lk{P5b!N"><value name="IF0"><block type="logic_compare" id="Kl(Kt;=?F(Imszqzzi1u"><field name="OP">GT</field>
                                        <value name="A"><block type="get_value" id="aRM%{M?GRx0bPQAmdysW"><field name="ATTR">val</field>
                                        <value name="B"><block type="get_value" id="f!B5KEC)Kek]YHFH8RnY"><field name="ATTR">val</field>
                                            <field name="OID">javascript.0.PV_Anlage.MAXVerbrauchever</field></block></value></block></value>
                                    <statement name="DO0"><block type="update" id="(uh]J)8E9BWJ8HjyC=Hp"><mutation delay_input="false"></mutation>
                                        <value name="VALUE"><block type="get_value" id=":AS43UBCU|d/)vy[`0F_"><field name="ATTR">val</field>
                                    <next><block type="controls_if" id="%b8RpM92~YV2,QS5D?4~"><value name="IF0"><block type="logic_compare" id="NSjOvY#BB,KrdffsFBbU"><field name="OP">LT</field>
                                            <value name="A"><block type="math_arithmetic" id=",J.XLc7i2y1|mMQbNy/f"><field name="OP">ADD</field>
                                                <value name="A"><shadow type="math_number" id="NH32l;.J+J)|Wm@Au~0e"><field name="NUM">1</field></shadow>
                                                  <block type="get_value" id="Eis/z}IaDz4qR/w?{GWl"><field name="ATTR">val</field>
                                                <value name="B"><shadow type="math_number" id="~URDq5C3v{k[VYcx7-I!"><field name="NUM">10</field></shadow></value></block></value>
                                            <value name="B"><block type="get_value" id="lW]UZDSjI7pOgV^?;GDA"><field name="ATTR">val</field>
                                                <field name="OID">javascript.0.PV_Anlage.MinVerbrauchever</field></block></value></block></value>
                                        <statement name="DO0"><block type="update" id="nNr6_]Wghq-]NAkpi:^Q"><mutation delay_input="false"></mutation>
                                            <value name="VALUE"><block type="get_value" id="rGwq^6qZiHx:!0T)5Jx("><field name="ATTR">val</field>
                                                <field name="OID">javascript.0.PV_Anlage.AktHausverbrauch</field></block></value></block></statement></block></next></block></statement></block></next></block></next></block></next></block></next></block></next></block></next></block></xml>
    Gruß Marco
    CCU2-CuxD&Cul868MHz, 44xHM Geräte, 20xMAX Fenstersensoren.Acer Revo mit IoBroker, Tablet Captiva 9,7 SFHD. SMA SB2.5,STP7000TL20,SMA Energy Meter, Echo, Harmony, JeeLink868, Arduino 433MHz, MaxtoxCUL868,MilightEasyLED,Hue
    • Q Offline
      Q Offline
      Qlink
      Meinst du so:
      Funktioniert leider trotzdem nicht :(
      Wie kann ich dein Blockly in Textform importieren und wieder in Blocklys umwandeln ?
        Marcolotti
        Siehe Bild. ;)
        • C Offline
          C1500
          vielen Dank für die Anleitung, es funktioniert bei mir.
          Laut ioBroker werden bei mir jetzt die Werte in Systemvariablen der CCU geschrieben.
          Leider kann ich das auf der CCU nicht nachvollziehen da die CCU seit der Einstellung in ioBroker nicht mehr erreichbar ist.
          Es kommt nur die Meldung "Zuviele gleichzeitige Verbindungen!!"
          Baut ioBroker denn für jede Variable eine eigene Verbindung auf?
          Ist das füllen von 2 Variablen in der CCU schon zu viel für die Verbindung?
          Muss ich die Übertragungsrate irgendwie reduzieren?
          Oder fehlen noch eine Einstellung oder Software in der CCU?
          Sorry für die vielen Fragen aber ich bin absoluter Anfänger mit ioBroker.
          Eines hätte ich dann auch noch:
          Kann ich die Werte in ioBroker irgendwie loggen um mir den Verbrauchsverlauf grafisch anzeigen zu lassen?
          Als Maximum würde ich gerne eine Woche zurück anschauen können
          Könnte mir hier bitte jemand helfen?
          Gruß Peer
          Nachtrag:
          Ich verwende einen RPi3 mit ioBroker und eine CCU2
          Screenshots der ioBroker Einstellung kann ich heute Abend nachreichen.
          Das Steuern z.B. der Lampen an der CCU über die VIS von ioBroker funktioniert.
          Nachtrag 2:
          Ich kam gerade doch wieder auf die CCU Weboberfläche
          Die Systemvariablen werden nicht aktualisiert.
          So sind sie in der CCU eingestellt:
          Und das steht auf der Startseite:
          Nachtrag 3:
          Ich hab nochmal den Namen geändert und alles aktualisiert.
          Leider ohne Erfolg.
          Die Einstellung des Objektes schaut so aus:
          Und so schauts in node.red aus:
          Hoffe ihr könnt mir helfen
          Gruß Peer
            Marcolotti
            Hallo Peer,
            eigentlich sollte das mit der CCU anstandslos klappen. Kontrolliere bitte nochmal, ob du bei NodeRed das richtige eingetragen hast. Unter Verbrauch dieses Value.
            721_verbrauch.jpg <–--
            Alternativ schick mir doch mal deinen Node-Red Flow (exportieren). Da kann ich mir das mal anschauen.
            Laut deiner Bilder hast du ja den History-Adapter bereits in Verwendung. Wenn nicht, installiere ihn mal und tätige mal folgende Einstellungen.
            Unter Objekte, rechts auf das Zahnrad drücken (Objekt deiner Wahl). In der nächsten Maske:
            Gruß Marco
            • C Offline
              C1500
              Servus Marco
              Der Flow ist der aus dem ersten Post.
              Ich hab nur nach dem anlegen die entsprechenden Systemvariablen zugewiesen.
              Unter Objekte tauchen bei hm-rega.0 auch die richtigen Werte auf.
              Die Einstellung in NodeRed schauen so aus:
              Sollten also auch passen.
              RPi und CCU2 sind auch schon mal neu gestartet werden
              Ich schick dir den Flow mal per PN (EDIT: Darf ich leider noch nicht)
              Hast du noch ne Idee?
              Die History schau ich mir nochmal genauer an
              Danke für den Tip
              Gruß Peer
              • C Offline
                C1500
                Servus Zusammen
                hat noch jemand eine Idee warum die Daten nicht an die CCU weiter gegeben werden?
                Oder soll ich lieber einen neuen Threat aufmachen wo es nur um das Thema geht?
                Gruß Peer
                  Marcolotti
                  Was sagt denn deine HM-Rega Konfiguration?
                  Gruß Marco
                  • C Offline
                    C1500
                    Hallo Marco
                    Ja, Variablen sind Aktiv
                    Hast du noch eine Idee?
                    Gruß Peer
                      Marcolotti
                      Hallo Peer,
                      wenn du unter Objekte -> HM-Rega eine deiner Variablen von Hand änderst, wird das synchronisiert?
                      Gruß Marco
                      • C Offline
                        C1500
                        Servus Marco
                        Zunächst hab ich heute alle hr.rega und hm.rpc neu installiert und node.Red neu gestartet.
                        Leider keine Werte in der CUU2.
                        ich hab jetzt mal die Instanz node.Red pausiert und hab dann im Objekt den Wert geändert und mit dem Haken gespeichert.
                        Dieser Wert wird dann auch in die CCU2 übertragen.
                        Irgendwie versteh ich das jetzt nicht.
                        Die Werte werden in das Objekt geschrieben aber nicht übertragen.
                        Wenn ich die gleichen Werte manuell schreibe, werden sie übertragen.
                        Kann es daran liegen, das die Übertragung länger dauert als die Aktualisierung die vom SMA-EM kommt?
                        Mein ioBroker läuft auf einem RPI3, das sollte doch von der Geschwindigkeit reichen, oder?
                        Sollte ja reichen.
                        Kann man die Aktualisierung des SMA-EM reduzieren? Alle 5-10 Sekunden würde ja voll und ganz reichen.
                        Gruß Peer
                          Marcolotti
                          Hast du mal bei Node-Red an den zugehörigen Anschluss ein Debug-Modul angehängt? Ob überhaupt da Daten rauskommen?
                          Stell mal bitte das nochmal um, ich glaube es hängt daran:
                          Statt Value -> Command
                          • C Offline
                            C1500
                            Servus Marco,
                            FU**
                            Warum auch immer es vorher nicht ging (Hatte definitiv auch schon mal "command" drin)
                            Jetzt geht es
                            Herzlichen Dank für deine Bemühungen
                            Gruß Peer
                              Steffi81
                              Hallo zusammen
                              Bräuchte Eure Hilfe in Sachen SMA Energy Meter.
                              Habe bei mir 2 verbaut, am Hauptzähler den 20 und im Schuppen den 10 am WR.
                              Hab versucht nach Marcolotti's Anleitung die Energy Meter aus zulesen, aber es klappt nicht.
                              Bekomme keine Werte. In dem neu angelegtem Flow steht zwar connect bei den 4 Ausgabe Werten, wenn ich dann aber unter Objekte schaue, steht bei dem Node Adatper nur nen leerer Flow, keine Werte nichts.
                              Muss ich noch irgendwo was einstellen oder so?
                              Im Netzwerk sind sie verfügbar, Router hat auch IP Adresse vergeben. Der 20 hat sogar eine Web Oberfläche, auf die komm ich auch drauf, der 10 hat sowas nicht.
                              Beim 20 werden die Werte allerdings mit Minis angezeigt, keine Ahnung warum, SMA weiß aber schon Bescheid und versucht das raus zu finden. Und nein, er ist nicht falsch rum angeschlossen, mehrmals geprüft :-)
                              Über eine IOS App kann ich beide Geräte ohne Problem einsehen.
                              Hoffe Ihr habt eine Idee.
                              Mfg
                              Stephan
                                Marcolotti
                                probiere doch mal den SMA EnergyMeter Adapter.
                                Gruß Marco
                                  Steffi81
                                  Gibt es den denn schon bzw. ist der denn schon ausgereift? Hatte letztens nur gelesen, dass noch Testpersonen dafür gesucht werden :-)
                                  Habe nicht wirklich Lust, was auszuprobieren und hinterher läuft bei mir nix mehr :-)
                                  • DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    @Steffi81:
                                    Habe nicht wirklich Lust, was auszuprobieren und hinterher läuft bei mir nix mehr :-) `
                                    Alles in der latest repository kann man ohne große Gefahr testen/Benutzen
                                    Send from mobile device
                                      Steffi81
                                      Ist der SMA Adapter denn "latest repository"? Was auch immer das heißt :lol:
                                      Bin halt nicht so der intensive IoBroker Freak, hab zwar schon einiges gemacht und auch hin bekommen, aber bei komplizierten Sachen hört es dann auch schon auf :-)
                                      Unter den Adaptern habe ich den SMA noch nicht gefunden, wüsste jetzt auch garnicht, wie ich den hinzufügen soll :oops:
                                      Mfg
                                        also bei mir ist der SMA-Adapter mit v0.5.1 im repo latest enthalten.
                                        hast du admin und controller auf dem neuesten stand?
                                          Steffi81
                                          Also hatte am We IoBroker über Putty upgedatet.
                                          Admin hatte ich auch schon upgedatet. Muss ich nachher noch mal schauen, ob ich den finde unter den ganzen aufgeführten Adaptern, oder muss ich noch wo anders schauen bzw. manuell hinzufügen?
                                          Mfg
