  4. Test Adapter vis 2.0 (Alpha)
    6.8k
780 Beiträge 108 Kommentatoren 352.4k Aufrufe 140 Beobachtet
  • N Nas007
    @feuersturm Ich habe den hier installiert:
    Hier der Webadapter:
    Meinst du das hier aus der Konsole?
    Layout was forced before the page was fully loaded. If stylesheets are not yet loaded this may cause a flash of unstyled content. jquery-1.11.2.min.js:4:29775
    Use of Mutation Events is deprecated. Use MutationObserver instead. analyser.js:485:17
    iobroker.vis-2-beta@2.0.24 using theme "colored" bootstrap.jsx:20:8
    main.7b76ba87.js:658:11
    Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters main.7b76ba87.js:658:26
    Help us to create open source project with reactJS! main.7b76ba87.js:658:186
    See you :) main.7b76ba87.js:658:253
    Einige Cookies verwenden das empfohlene "SameSite"-Attribut inkorrekt. 3
    TypeError: e.field is undefined
        Ns ToolbarItems.jsx:61
        As ToolbarItems.jsx:255
        As ToolbarItems.jsx:247
        An main.7b76ba87.js:1912
        ma main.7b76ba87.js:1914
        _c main.7b76ba87.js:1914
        Uo main.7b76ba87.js:1914
        Fc main.7b76ba87.js:1914
        Ha main.7b76ba87.js:1914
        _o main.7b76ba87.js:1914
        Ma main.7b76ba87.js:1914
        B3 main.7b76ba87.js:1912
        I0 main.7b76ba87.js:1914
    main.7b76ba87.js:1914:177
    TypeError: l.settings is undefined
        Mi View.jsx:206
    Uncaught TypeError: e.field is undefined
    ToolbarItems.jsx:61:16
    Metro version: "1.2.0" edit.html:645:10
    Version Info-Adapter-Widget: 0.0.9 info.js:29:12
    Source-Map-Fehler: Error: request failed with status 404
    Ressourcen-Adresse: http://192.168.100.40:8082/vis-2-beta/widgets/vis-2-widgets-material/static/css/src_Map_jsx-node_modules_leaflet_dist_leaflet_css.11ebe247.chunk.css
    Source-Map-Adresse: src_Map_jsx-node_modules_leaflet_dist_leaflet_css.11ebe247.chunk.css.map
    Ressourcen-Adresse: http://192.168.100.40:8082/vis-2-beta/static/js/main.7b76ba87.js
    Source-Map-Adresse: main.7b76ba87.js.map
    FeuersturmF Offline
    FeuersturmF Offline
    Feuersturm
    #663
    @nas007 aktivieren mal beim web Adapter auf der ersten Seite "reine web-sockets verwenden "
    N 1 Antwort Letzte Antwort
    • FeuersturmF Feuersturm
      N Offline
      N Offline
      Nas007
      #664
      @feuersturm Leider ohne Erfolg. War alles wieder weiß.
      Layout-Darstellung wurde erzwungen, bevor die Seite vollständig geladen war. Falls Stylesheet noch nicht geladen sind, kann dies zu einem kurzzeitigen Darstellung des Inhalts ohne Formatierung führen. jquery-1.11.2.min.js:4:29775
      Mutations-Ereignisse sollten nicht mehr verwendet werden. Verwenden Sie MutationObserver stattdessen. analyser.js:485:17
      [2023-05-04T19:26:32.634Z] Try to connect socket.io.js:66:41
          Mi View.jsx:206
      • N Nas007
            Mi View.jsx:206
        FeuersturmF Offline
        FeuersturmF Offline
        Feuersturm
        #665
        @nas007 Leg mal bitte ein github issue mit deiner Fehlerbeschreibung und dem Log hier an https://github.com/ioBroker/ioBroker.vis/issues
        Ich vermute in deiner VIS1 die bei der Installation übernommen wird ist ein widget enthalten welches Probleme bei vis2 macht.
        Danach kannst du einmal hier im Admin im Datei Menü schauen ob dort dein vis Projekt auftaucht
        Wenn du den entsprechenden Unterordner löscht, dann sollte vis2 mit einem leeren Projekt starten
          N Offline
          N Offline
          Nas007
          #666
          @Feuersturm Ich habe das issue anglegt: https://github.com/ioBroker/ioBroker.vis/issues/712
          Im Dateimenü hat das Löschen der bestehenden Daten den Erfolg gebracht.
          Vielen Dank!
          • FeuersturmF Offline
            FeuersturmF Offline
            Feuersturm
            #667
            Vis-2 version 2.0.27 steht auf npm zur Verfügung.
            Hier https://github.com/ioBroker/ioBroker.vis/commits/master könnt ihr sehen, welche issues seit der Version 2.0.24 bearbeitet worden sind.
              FeuersturmF Offline
              Feuersturm
              #668
              Vis-2 version 2.0.28 steht auf npm zur Verfügung.
              Bluefox hat in den letzten Tagen an vielen vis2 issues gearbeitet. Respekt 😎
              Hier https://github.com/ioBroker/ioBroker.vis/commits/master könnt ihr sehen, welche issues seit der Version 2.0.27 bearbeitet worden sind.
              Issues welche gefixed wurden und nachgetestet werden können haben das "fixed" label bekommen https://github.com/ioBroker/ioBroker.vis/issues?q=is%3Aissue+is%3Aopen+label%3Afixed
              Happy testing :man-surfing:
                ChaotC Offline
                ChaotC Offline
                Chaot
                #669
                @feuersturm
                Danke, ich werde wohl nochmal einen Versuch starten, nachdem ich eine Weile ausgestiegen bin.
                Soweit ich das aber bisher gelesen habe scheint es aktuell immer noch Probleme mit Bindings zu geben. Oder wurde daran auch gearbeitet und ich habe das übersehen?
                • ChaotC Chaot
                  @feuersturm
                  FeuersturmF Offline
                  FeuersturmF Offline
                  Feuersturm
                  #670
                  @chaot sagte in Test Adapter vis 2.0 (Alpha):
                  So wie ich das sehe sind die issues mit den Bindings noch offen.
                    ChaotC Offline
                    ChaotC Offline
                    Chaot
                    #671
                    @feuersturm Na, dann wird das wohl eine Neukonstruktion zum Testen. Meine alte VIS importieren macht dann keinen Sinn, da zu 80% mit Bindings gearbeitet wurde.
                    • ChaotC Chaot
                      ManfredHi
                      #672
                      Verwende auch viele Bindings in meiner VIS. Deshalb hab ich mit Vis2 scheinbar die Probleme, dass die VIS gar nicht in den Editor geladen werden.
                        Sandy
                        schrieb am zuletzt editiert von Sandy
                        #673
                        Hallo
                        Hat schon jemand was mit dem "daswetter.0." Widget gemacht ? wird bei mir in der vis2 nicht mehr angezeigt
                        gruss Sandy
                          Sandy
                          #674
                          Hallo, ich noch mal :-)
                          gibt es eigentlich eine Möglichkeit die Seiten in der Reihenfolge zu verändern ? Bei mir setzt er die neuen immer an die letzte Stelle. Ich hätte sie aber gerne alphabetisch. Wenn ich vorne auf den kleinen Zettel gehe wo ziehen steht, dann ist da nur ein durchgestrichener roter Kreis. :-(
                          gruss Sandy
                          • S Sandy
                            gruss Sandy
                            FeuersturmF Offline
                            FeuersturmF Offline
                            Feuersturm
                            #675
                            @sandy sagte in Test Adapter vis 2.0 (Alpha):
                            Erstelle bitte mal hierzu ein issue. Soweit ich es gerade gesehen habe gibt es dazu noch kein Ticket.
                            Es gibt ein Ticket was in eine ähnliche Richtung geht aber ein anderes Endziel hat https://github.com/ioBroker/ioBroker.vis/issues/631 aber
                            • S Sandy
                              Hallo
                              gruss Sandy
                              FeuersturmF Offline
                              FeuersturmF Offline
                              Feuersturm
                              #676
                              Wie heißt das Widget genau? Ich hab zwar den daswetter Adapter installiert, sehe aber in vis1 oder vis2 kein entsprechendes widget.
                                Sandy
                                #677
                                @feuersturm habe mal ein Screenshot gemacht
                                • S Sandy
                                  #678
                                  Moin,
                                  das ist aber der Adapter daswetter das einzige, VIS Widget, das ich kenne, ist
                                  Bernd
                                    Moin,
                                    Bernd
                                    Sandy
                                    #679
                                    @dp20eic ich weis auch nicht was ich damals genommen habe. Nehme jetzt einfach die "OpenWeatherMap" die funktioniert :-)
                                    LG Sandy
                                    • S Sandy
                                      LG Sandy
                                      Sandy
                                      #680
                                      ich schon wieder. Ich nutze die Vis auf einem MiniPC und habe da einen Touch Monitor angeschlossen. Heute habe ich die Internetseite mal von der Vis auf Vis2 Beta umgestellt und habe folgendes Problem bei den Lampen (Basic Widget - Bulb on/off) ganz normaler Schalter für an/aus. Wenn ich bei Vis2 Beta drauf drücke schaltet die Lampe zwei mal. Bei Vis funktioniert alles. Wenn ich es mit der Maus schalte geht es auch. Nur über Touch schaltet er doppelt.
                                      Musste das Video schneiden
                                      das erste ist mit Vis und das zweite mit Vis2 Beta (2.0.29)
                                      LampenProblem2.mp4
                                      FeuersturmF S 2 Antworten Letzte Antwort
                                      • H Offline
                                        higginsd
                                        #681
                                        Tag Zusammen!
                                        Mir ist gestern Nacht meine ioBroker Installation heftig abgestürzt. Jetzt sehe ich meine Views in Vis2.0 Runtime immer noch vollständig, aber im Edit Mode sind sie weg.
                                        Habe ich eine Möglichkeit, die Views zum Editieren wiederherzustellen?
                                        Viele Grüße
                                        Dirk
                                        • S Sandy
                                          LampenProblem2.mp4
                                          FeuersturmF Offline
                                          FeuersturmF Offline
                                          Feuersturm
                                          #682
                                          Leg mal bitte ein issue dafür an.
