  4. Migration Pi4 > Synology Docker
21 Beiträge 3 Kommentatoren 3.4k Aufrufe 2 Beobachtet
  • B Basti81
    @homoran nach dem restore mit Backitup startet der Container durch. Dann sehe ich im Protokoll folgendes:
    -----                   Step 1 of 5: Preparing container                   -----
    This is not the first run of this container. Skipping first run preparation.
    -----             Step 2 of 5: Detecting ioBroker installation             -----
    Existing installation of ioBroker detected in "/opt/iobroker".
    -----             Step 3 of 5: Checking ioBroker installation              -----
    (Re)setting permissions (This might take a while! Please be patient!)... Done.
    Fixing "sudo-bug" by replacing sudo with gosu... Done.
    Checking Database connection... Failed.
    Please check your configuration and try again.
    For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs).
    This Script will exit now.
    GlasfaserG Offline
    GlasfaserG Offline
    @basti81 sagte in Migration Pi4 > Synology Docker:
    Der Anfang fehlt .
    Zeige mal eine DEBUG Ausgabe :
    Eintrag in Environment Variables ( ENV )
    DEBUG:               true
    und dann das Log hier posten
    • GlasfaserG Glasfaser
      Der Anfang fehlt .
      DEBUG:               true
      Basti81
      schrieb am zuletzt editiert von Basti81
      @glasfaser ah ok, anbei das Log:
      [DEBUG] Checking multihost settings...
      [DEBUG] No multihost settings detected.
      [DEBUG] Done.
      [DEBUG] Checking custom objects db settings...
      [DEBUG] No custom objects db settings detected.
      [DEBUG] Done.
      [DEBUG] Checking custom states db settings...
      [DEBUG] No custom states db settings detected.
      [DEBUG] Done.
      [DEBUG] Error message:
      [DEBUG] No connection to states 0.0.0.0:6379[redis]
      [DEBUG] Debug mode prevents the container from exiting on errors.
      [DEBUG] This enables you to investigate or fix your issue on the command line.
      [DEBUG] If you want to stop or restart your container you have to do it manually.
      [DEBUG] IoBroker is not running!
      • B Basti81
        [DEBUG] Done.
        [DEBUG] Done.
        [DEBUG] Done.
        GlasfaserG Offline
        GlasfaserG Offline
        Redis:
        Hast du das so auf der Pi !?
          Redis:
          Basti81
          @glasfaser auf dem Pi:
          pi@iobrokerpi:~ $ sudo redis-server -v
          Redis server v=5.0.14 sha=00000000:0 malloc=libc bits=32 build=ddd3b1f304a7d4d5
          In dem Container:
          root@iobrokerpi:/opt/iobroker# redis-server -v
          bash: redis-server: command not found
          • B Basti81
            In dem Container:
            GlasfaserG Offline
            GlasfaserG Offline
            @basti81
            https://github.com/buanet/ioBroker.docker/issues/136#issuecomment-710220772
              @basti81
              Basti81
              @glasfaser den Container habe ich über die GUI aktiviert und das gibt es nur diese ENV:
              • B Basti81
                GlasfaserG Offline
                GlasfaserG Offline
                Ja das ist der Standart ,
                extras siehe hier unter :
                Configuration via environment variables
                https://hub.docker.com/r/buanet/iobroker
                  Basti81
                  @glasfaser wir kommen der Sache näher :-)
                  [DEBUG] Done.
                  Configuring custom objects db...
                  IOB_OBJECTSDB_TYPE is available and value meets detected ioBroker installation.
                  IOB_OBJECTSDB_HOST is available and value meets detected ioBroker installation.
                  IOB_OBJECTSDB_PORT is available and value meets detected ioBroker installation.
                  Done.
                  Configuring custom states db...
                  IOB_STATESDB_TYPE is available and value meets detected ioBroker installation.
                  IOB_STATESDB_HOST is available and value meets detected ioBroker installation.
                  IOB_STATESDB_PORT is available but value is different from detected ioBroker installation.
                  Setting port of states db to "9000"... Done.
                  Done.
                  [DEBUG] No connection to objects 127.0.0.1:9001[redis]
                  • B Basti81
                    [DEBUG] Done.
                    Done.
                    Done.
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Warum 9001
                    • B Basti81
                      [DEBUG] Done.
                      Done.
                      Done.
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @basti81
                      zu Redis auch :
                      https://smarthome.buanet.de/2020/12/iobroker-docker-container-mit-redis-db-verbinden/
                        Warum 9001
                        Basti81
                        @glasfaser hab jetzt den 6379 versucht und ich bekomme den gleichen Fehler:
                        [DEBUG] Done.
                        IOB_OBJECTSDB_PORT is available but value is different from detected ioBroker installation.
                        Setting port of objects db to "6379"... Done.
                        Done.
                        Setting port of states db to "6379"... Done.
                        Done.
                        [DEBUG] No connection to objects 127.0.0.1:6379[redis]
                        Soll ich mal:
                        apt-get install redis-sentinel
                        im Container ausführen? Mich wundert das hier im Container:
                        • B Basti81
                          [DEBUG] Done.
                          Done.
                          Done.
                          Soll ich mal:
                          GlasfaserG Offline
                          GlasfaserG Offline
                          kannst du machen ... aber beim nächsten Image wechsel ist er weg !
                          siehe meinen Link , da ist redis seperat als Container !
                            Basti81
                            @glasfaser danke dir. Habe die Container sauber neu aufgesetzt wie hier erläutert:
                            Alles läuft nun wie es soll und der Restore hat geklappt da die redis Verbindung von Anfang an funktionierte. Bridged Network war hier der Schlüssel. Mit Host network hat es nicht geklappt.
                            Danke dir!!!
