  4. Migration Pi4 > Synology Docker
21 Beiträge 3 Kommentatoren 3.4k Aufrufe 2 Beobachtet
  • GlasfaserG Glasfaser
    @basti81 sagte in Migration Pi4 > Synology Docker:
    Das steht im DSM Container Protokoll
    Please check your configuration and try again.
    Zeige mal von Anfang an das Log !
    Basti81
    @glasfaser das ist leider alles was ich im Log sehe nachdem ich den Restore gemacht habe (iobroker restore 0) und anschließen iob start:
    2023-05-07 22:14:16.115  - info: host.iobrokerpi iobroker.js-controller version 4.0.24 js-controller starting
    2023-05-07 22:14:16.117  - info: host.iobrokerpi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-05-07 22:14:16.117  - info: host.iobrokerpi hostname: iobrokerpi, node: v18.16.0
    2023-05-07 22:14:16.118  - info: host.iobrokerpi ip addresses: 192.168.178.100 2003:e5:f749:200:9209:d0ff:fe32:ee4 fe80::9209:d0ff:fe32:ee4 172.18.0.1 fe80::42:61ff:fed4:5012 172.17.0.1 fe80::42:78ff:fe4d:9345 fe80::ccac:35ff:fe52:594a fe80::4819:c2ff:fee1:e247 fe80::301e:e6ff:feec:9aa2
    2023-05-07 22:14:46.125  - error: host.iobrokerpi No connection to databases possible, restart
    2023-05-07 22:14:46.129  - info: host.iobrokerpi iobroker _restart
    2023-05-07 22:14:46.506  - info: host.iobrokerpi iobroker Starting node restart.js
    2023-05-07 22:14:46.979  - info: host.iobrokerpi received SIGTERM
    2023-05-07 22:14:46.992  - warn: host.iobrokerpi get state error: Connection is closed.
    2023-05-07 22:14:46.993  - info: host.iobrokerpi terminated
    2023-05-07 22:14:53.436  - info: host.iobrokerpi iobroker.js-controller version 4.0.24 js-controller starting
    2023-05-07 22:14:53.439  - info: host.iobrokerpi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-05-07 22:14:53.439  - info: host.iobrokerpi hostname: iobrokerpi, node: v18.16.0
    2023-05-07 22:14:53.439  - info: host.iobrokerpi ip addresses: 192.168.178.100 2003:e5:f749:200:9209:d0ff:fe32:ee4 fe80::9209:d0ff:fe32:ee4 172.18.0.1 fe80::42:61ff:fed4:5012 172.17.0.1 fe80::42:78ff:fe4d:9345 fe80::ccac:35ff:fe52:594a fe80::4819:c2ff:fee1:e247 fe80::301e:e6ff:feec:9aa2
    Das wiederholt sich dann...
    Restore war aber erfolgreich lt. shell:
    Reinstalling adapter "admin" from "iobroker.admin@6.3.5"
    added 80 packages in 8s
    20 packages are looking for funding
      run `npm fund` for details
    Reinstalling adapter "backitup" from "iobroker.backitup@2.6.19"
    added 94 packages in 9s
    33 packages are looking for funding
    System successfully restored!
    GlasfaserG HomoranH 2 Antworten Letzte Antwort
    • B Basti81
      GlasfaserG Offline
      GlasfaserG Offline
      iobroker restore 0
      Warum nicht über den Adapter Backitup !?
      • B Basti81
        nein, nur die Konfigurationsdateien wurden erfolgreich wieder hergestellt.
        Anhand derer wird dann das gesamte System neu gebaut, was je nach Hardware und Umfang auch gerne mal 1h dauern jann.
        In dieser Zeit darf nichts am System verändert werden damit es nicht zu einer Störungvder Prozesse und damit ggf. zu einem undefinierten Zustand kommt.
          iobroker restore 0
          Basti81
          @glasfaser hatte ich auch versucht mit dem gleichen Ergebnis nur dann startet das System autom. durch und ich komme gar nicht mehr an den Container ran per ssh da er andauernd von selbst neu startet (wahrscheinlich wegen des Startup bash scripts von buanet.
            GlasfaserG Offline
            GlasfaserG Offline
            @Basti81
            Zeige das DSM Log !
            @glasfaser sagte in Migration Pi4 > Synology Docker:
              Basti81
              @homoran nach dem restore mit Backitup startet der Container durch. Dann sehe ich im Protokoll folgendes:
              -----                   Step 1 of 5: Preparing container                   -----
              This is not the first run of this container. Skipping first run preparation.
              -----             Step 2 of 5: Detecting ioBroker installation             -----
              Existing installation of ioBroker detected in "/opt/iobroker".
              -----             Step 3 of 5: Checking ioBroker installation              -----
              (Re)setting permissions (This might take a while! Please be patient!)... Done.
              Fixing "sudo-bug" by replacing sudo with gosu... Done.
              Checking Database connection... Failed.
              For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs).
              This Script will exit now.
              • B Basti81
                GlasfaserG Offline
                GlasfaserG Offline
                Der Anfang fehlt .
                Zeige mal eine DEBUG Ausgabe :
                Eintrag in Environment Variables ( ENV )
                DEBUG:               true
                und dann das Log hier posten
                  Der Anfang fehlt .
                  DEBUG:               true
                  Basti81
                  schrieb am zuletzt editiert von Basti81
                  @glasfaser ah ok, anbei das Log:
                  [DEBUG] Checking multihost settings...
                  [DEBUG] No multihost settings detected.
                  [DEBUG] Done.
                  [DEBUG] Checking custom objects db settings...
                  [DEBUG] No custom objects db settings detected.
                  [DEBUG] Done.
                  [DEBUG] Checking custom states db settings...
                  [DEBUG] No custom states db settings detected.
                  [DEBUG] Done.
                  [DEBUG] Error message:
                  [DEBUG] No connection to states 0.0.0.0:6379[redis]
                  [DEBUG] Debug mode prevents the container from exiting on errors.
                  [DEBUG] This enables you to investigate or fix your issue on the command line.
                  [DEBUG] If you want to stop or restart your container you have to do it manually.
                  [DEBUG] IoBroker is not running!
                  • B Basti81
                    [DEBUG] Done.
                    [DEBUG] Done.
                    [DEBUG] Done.
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Redis:
                    Hast du das so auf der Pi !?
                      Redis:
                      Basti81
                      @glasfaser auf dem Pi:
                      pi@iobrokerpi:~ $ sudo redis-server -v
                      Redis server v=5.0.14 sha=00000000:0 malloc=libc bits=32 build=ddd3b1f304a7d4d5
                      In dem Container:
                      root@iobrokerpi:/opt/iobroker# redis-server -v
                      bash: redis-server: command not found
                      • B Basti81
                        In dem Container:
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @basti81
                        https://github.com/buanet/ioBroker.docker/issues/136#issuecomment-710220772
                          @basti81
                          Basti81
                          @glasfaser den Container habe ich über die GUI aktiviert und das gibt es nur diese ENV:
                          • B Basti81
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Ja das ist der Standart ,
                            extras siehe hier unter :
                            Configuration via environment variables
                            https://hub.docker.com/r/buanet/iobroker
                              Basti81
                              @glasfaser wir kommen der Sache näher :-)
                              [DEBUG] Done.
                              Configuring custom objects db...
                              IOB_OBJECTSDB_TYPE is available and value meets detected ioBroker installation.
                              IOB_OBJECTSDB_HOST is available and value meets detected ioBroker installation.
                              IOB_OBJECTSDB_PORT is available and value meets detected ioBroker installation.
                              Done.
                              Configuring custom states db...
                              IOB_STATESDB_TYPE is available and value meets detected ioBroker installation.
                              IOB_STATESDB_HOST is available and value meets detected ioBroker installation.
                              IOB_STATESDB_PORT is available but value is different from detected ioBroker installation.
                              Setting port of states db to "9000"... Done.
                              Done.
                              [DEBUG] No connection to objects 127.0.0.1:9001[redis]
                              • B Basti81
                                [DEBUG] Done.
                                Done.
                                Done.
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Warum 9001
                                • B Basti81
                                  [DEBUG] Done.
                                  Done.
                                  Done.
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @basti81
                                  zu Redis auch :
                                  https://smarthome.buanet.de/2020/12/iobroker-docker-container-mit-redis-db-verbinden/
                                    Warum 9001
                                    Basti81
                                    @glasfaser hab jetzt den 6379 versucht und ich bekomme den gleichen Fehler:
                                    [DEBUG] Done.
                                    IOB_OBJECTSDB_PORT is available but value is different from detected ioBroker installation.
                                    Setting port of objects db to "6379"... Done.
                                    Done.
                                    Setting port of states db to "6379"... Done.
                                    Done.
                                    [DEBUG] No connection to objects 127.0.0.1:6379[redis]
                                    Soll ich mal:
                                    apt-get install redis-sentinel
                                    im Container ausführen? Mich wundert das hier im Container:
                                    • B Basti81
                                      [DEBUG] Done.
                                      Done.
                                      Done.
                                      Soll ich mal:
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      kannst du machen ... aber beim nächsten Image wechsel ist er weg !
                                      siehe meinen Link , da ist redis seperat als Container !
                                        Basti81
                                        @glasfaser danke dir. Habe die Container sauber neu aufgesetzt wie hier erläutert:
                                        Alles läuft nun wie es soll und der Restore hat geklappt da die redis Verbindung von Anfang an funktionierte. Bridged Network war hier der Schlüssel. Mit Host network hat es nicht geklappt.
                                        Danke dir!!!
