  4. Migration Pi4 > Synology Docker
21 Beiträge 3 Kommentatoren 3.4k Aufrufe 2 Beobachtet
  • GlasfaserG Glasfaser
    @basti81 sagte in Migration Pi4 > Synology Docker:
    [DEBUG] No connection to states 0.0.0.0:6379[redis]
    Redis:
    Hast du das so auf der Pi !?
    Basti81
    @glasfaser auf dem Pi:
    pi@iobrokerpi:~ $ sudo redis-server -v
    Redis server v=5.0.14 sha=00000000:0 malloc=libc bits=32 build=ddd3b1f304a7d4d5
    In dem Container:
    root@iobrokerpi:/opt/iobroker# redis-server -v
    bash: redis-server: command not found
    • B Basti81
      In dem Container:
      GlasfaserG Offline
      GlasfaserG Offline
      @basti81
      https://github.com/buanet/ioBroker.docker/issues/136#issuecomment-710220772
        @basti81
        Basti81
        @glasfaser den Container habe ich über die GUI aktiviert und das gibt es nur diese ENV:
        • B Basti81
          GlasfaserG Offline
          GlasfaserG Offline
          Ja das ist der Standart ,
          extras siehe hier unter :
          Configuration via environment variables
          https://hub.docker.com/r/buanet/iobroker
            Basti81
            @glasfaser wir kommen der Sache näher :-)
            -----             Step 3 of 5: Checking ioBroker installation              -----
            (Re)setting permissions (This might take a while! Please be patient!)... Done.
            Fixing "sudo-bug" by replacing sudo with gosu... Done.
            [DEBUG] Checking multihost settings...
            [DEBUG] No multihost settings detected.
            [DEBUG] Done.
            Configuring custom objects db...
            IOB_OBJECTSDB_TYPE is available and value meets detected ioBroker installation.
            IOB_OBJECTSDB_HOST is available and value meets detected ioBroker installation.
            IOB_OBJECTSDB_PORT is available and value meets detected ioBroker installation.
            Done.
            Configuring custom states db...
            IOB_STATESDB_TYPE is available and value meets detected ioBroker installation.
            IOB_STATESDB_HOST is available and value meets detected ioBroker installation.
            IOB_STATESDB_PORT is available but value is different from detected ioBroker installation.
            Setting port of states db to "9000"... Done.
            Done.
            Checking Database connection... Failed.
            [DEBUG] Error message:
            [DEBUG] No connection to objects 127.0.0.1:9001[redis]
            Please check your configuration and try again.
            For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs).
            [DEBUG] Debug mode prevents the container from exiting on errors.
            [DEBUG] This enables you to investigate or fix your issue on the command line.
            [DEBUG] If you want to stop or restart your container you have to do it manually.
            [DEBUG] IoBroker is not running!
            • B Basti81
              [DEBUG] Done.
              Done.
              Done.
              GlasfaserG Offline
              GlasfaserG Offline
              Warum 9001
              • B Basti81
                [DEBUG] Done.
                Done.
                Done.
                GlasfaserG Offline
                GlasfaserG Offline
                @basti81
                zu Redis auch :
                https://smarthome.buanet.de/2020/12/iobroker-docker-container-mit-redis-db-verbinden/
                  Warum 9001
                  Basti81
                  @glasfaser hab jetzt den 6379 versucht und ich bekomme den gleichen Fehler:
                  [DEBUG] Done.
                  IOB_OBJECTSDB_PORT is available but value is different from detected ioBroker installation.
                  Setting port of objects db to "6379"... Done.
                  Done.
                  Setting port of states db to "6379"... Done.
                  Done.
                  [DEBUG] No connection to objects 127.0.0.1:6379[redis]
                  Soll ich mal:
                  apt-get install redis-sentinel
                  im Container ausführen? Mich wundert das hier im Container:
                  • B Basti81
                    [DEBUG] Done.
                    Done.
                    Done.
                    Soll ich mal:
                    GlasfaserG Offline
                    GlasfaserG Offline
                    kannst du machen ... aber beim nächsten Image wechsel ist er weg !
                    siehe meinen Link , da ist redis seperat als Container !
                      Basti81
                      @glasfaser danke dir. Habe die Container sauber neu aufgesetzt wie hier erläutert:
                      Alles läuft nun wie es soll und der Restore hat geklappt da die redis Verbindung von Anfang an funktionierte. Bridged Network war hier der Schlüssel. Mit Host network hat es nicht geklappt.
                      Danke dir!!!
