  4. Adapter smartgarden Fehler 403
    6.3k
33 Beiträge 11 Kommentatoren 7.4k Aufrufe 12 Beobachtet
  • R reutli
    erhalte seit heute Fehler im Adapter/Instanz.
    Habe soeben nochmals credentials gecheckt, die er ja wohl auch mit
    smartgarden.0
    	2023-05-03 14:17:14.242	info	1/ Connection: successful: response.statusCode / statusMessage=200 / OK
    akzeptiert, oder?
    Rest sieht dann so aus:
    smartgarden.0
    	2023-05-03 14:17:14.446	info	1/ getConnection: trying to connect again in 300 seconds
    smartgarden.0
    	2023-05-03 14:17:14.445	info	1/ getConnection: returned connection error: request returned 403 Forbidden
    smartgarden.0
    	2023-05-03 14:17:14.444	error	Error: request returned 403 Forbidden
    smartgarden.0
    	2023-05-03 14:17:14.444	info	1/ get_locations failure:..return with error
    smartgarden.0
    	2023-05-03 14:17:14.443	info	1/ get_locations failure: response.statusCode/Message=403/Forbidden
    smartgarden.0
    	2023-05-03 14:17:14.244	info	1/ get_locations ...
    smartgarden.0
    	2023-05-03 14:17:14.244	info	1/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    smartgarden.0
    	2023-05-03 14:17:14.243	info	1/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
    smartgarden.0
    smartgarden.0
    	2023-05-03 14:17:13.976	info	1/ connect ... using client credentials grant
    smartgarden.0
    	2023-05-03 14:17:13.975	info	1/ connect ... empty password
    smartgarden.0
    	2023-05-03 14:17:13.973	info	1/ connect ... empty username
    smartgarden.0
    	2023-05-03 14:17:13.973	info	1/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
    smartgarden.0
    	2023-05-03 14:17:13.972	info	1/ connecting to Gardena Smart System Service ...
    smartgarden.0
    	2023-05-03 14:17:13.971	info	1/ connectToGardena...
    smartgarden.0
    	2023-05-03 14:17:13.970	info	1/ getConnection...
    smartgarden.0
    	2023-05-03 14:17:13.932	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v18.16.0, js-controller: 4.0.24
    Hat API einen Hänger?
    sambaoleS Offline
    sambaoleS Offline
    sambaole
    @reutli Habe das gleiche Problem. Lief bis gestern problemlos. API bei Husqvarna geändert?
    R 1 Antwort Letzte Antwort
    • sambaoleS sambaole
      R Online
      R Online
      reutli
      @sambaole
      Habe keine Ahnung. Ich mach mal noch einen GitHub Issue auf....
      Edit: gibt's schon : https://github.com/jpgorganizer/ioBroker.smartgarden/issues/56
      iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
      *Wer freundlich ist, dem wird freundlich geholfen *
      • R Online
        R Online
        reutli
        Hallo Leute,
        für alle die in den issue rennen:
        Ich habe einen neuen Account (APP-Key und - Secret) erstellt und damit hat es funktioniert.
        Es scheint, dass Accounts/API-connects gesperrt wurde.
        Könnt' Ihr das bestätigen?
        • R reutli
          Hallo Leute,
          Dominic151617
          @reutli Danke für den Tipp und ja, mit einer ganz neuen Application läuft es auch bei mir wieder.
          • D Dominic151617
            R Online
            R Online
            reutli
            @jpgorganizer kannst Du da mal schauen, was Sache ist. Die scheinen die accounts gesperrt zu haben...
            D P 3 Antworten Letzte Antwort
            • R reutli
              Dominic151617
              @reutli @jpgorganizer Also nicht die Accounts in dem Sinne, sondern die Applications. Habe in dem vorhanden Account die Application entsprechend der Anleitung neu angelegt.
              O G 2 Antworten Letzte Antwort
              • R reutli
                Pino72
                Hab auch nen neue Application erstellt und wollte die neuen keys einsetzen aber ich kann im IOBroker kein application secret mehr reinschreiben...Feld ist ausgegraut und lässt sich nicht editieren?
                • P Pino72
                  Dominic151617
                  @pino72 sagte in Adapter smartgarden Fehler 403:
                  Benutzernamen und Passwort löschen
                  P 1 Antwort Letzte Antwort
                  • D Dominic151617
                    Pino72
                    @dominic151617 DAnke! Das wars :-)
                    • R reutli
                      Dominic151617
                      @reutli @jpgorganizer Zur Info: bis heute lief der Adapter bei mir mit Benutzernamen und Passwort. Das hat ja wohl schon voher Probleme bereitet. Aber Key und Scret aus der vorhanden Application funktionierten nicht.
                      • D Dominic151617
                        Pino72
                        Läuft jetzt wieder ohne Benutzername und PAsswort aber mit neuen Keys.
                        • D Dominic151617
                          O Abwesend
                          O Abwesend
                          oFbEQnpoLKKl6mbY5e13
                          @dominic151617 sagte in Adapter smartgarden Fehler 403:
                          Das war auch bei mir die Lösung.
                          • O oFbEQnpoLKKl6mbY5e13
                            R Online
                            R Online
                            reutli
                            @ofbeqnpolkkl6mby5e13
                            Na wenigstens haben wir eine Lösung, auch wenn ich gerne den "root cause" wüsste...
                            • R reutli
                              smartgarden.0
                              akzeptiert, oder?
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              smartgarden.0
                              Rene LausenhammerR Offline
                              Rene Lausenhammer
                              schrieb am zuletzt editiert von Rene Lausenhammer
                              API Neuanlegen dann läufts wieder
                              N 1 Antwort Letzte Antwort
                              • Rene LausenhammerR Rene Lausenhammer
                                N Offline
                                N Offline
                                netfriend
                                Ja stimmt, damit geht's wieder. 👍
                                War ja letztes Jahr die gleiche Freakshow...irgendwie nervt das. Bei Gardena/Husqvarna spielt man gerne am laufenden System rum. Danach geht irgendwie nix mehr, man merkt es auch nicht sofort. Und im ersten Moment vermutet man, es liegt am eigenen System. Man könnte die registrierten Kunden ja auch mal per eMail informieren, dass es ein Problem gibt oder was geändert wurde und man ne neue Application anlegen muss.
                                • D Dominic151617
                                  G Online
                                  G Online
                                  Gonzokalle
                                  @dominic151617
                                  Hast du einen Link zur Anleitung? Ist schon lange her, wo ich das gemacht habe. 😊
                                  O 1 Antwort Letzte Antwort
                                  • G Gonzokalle
                                    @dominic151617
                                    O Abwesend
                                    O Abwesend
                                    @gonzokalle
                                    G 1 Antwort Letzte Antwort
                                      @gonzokalle
                                      G Online
                                      G Online
                                      Gonzokalle
                                      Hat funktioniert. Dankeschön 👍
                                      • HiltexH Offline
                                        HiltexH Offline
                                        Hiltex
                                        Das Löschen und neu Anlegen der Application im Developer Portal von Husqvarna hat bei mir auch geholfen.
                                        Ich hatte zeitgleich das Problem, dass der Mähroboter (Smart SILENO City) sich komisch verhalten hat. Jedes mal zu Beginn eines Zeitplanes hat sich der Mäher selbst deaktiviert und die Play-Taste hat nicht richtig funktioniert (als wäre sie kaputt). Löschen und neu Anlegen des Zeitplanes hat nicht geholfen, Ab- und Anlernen an die App/das System auch nicht.
                                        Die Lösung war dann, den Akku zu entfernen und mindestens 13 Stunden (ich hatte 24 Stunden) nicht wieder einzusetzen. Danach schnurrte der Robi wieder, wie es ganz zu Anfang der Fall war.
                                        Beides hatte nichts miteinander zu tun, aber vielleicht hat ja jemand mal den Fall und kann sich dann an diese Vorgehensweise erinnern.
                                        Blog: indibit.de
                                        • HiltexH Hiltex
                                          O Abwesend
                                          O Abwesend
                                          @hiltex
                                          Hast du die Firmware von Ende letzten Jahres installiert? Gardena hat die wegen Problemen zurückgezogen und nennt das Wartungsarbeiten. Wenn ich mich richtig erinnere, dann passt das zu den berichteten Problemen mit der Firmware.
                                          HiltexH 1 Antwort Letzte Antwort
