  4. Adapter smartgarden Fehler 403
    5.4k
33 Beiträge 11 Kommentatoren 7.3k Aufrufe 12 Beobachtet
  • R Online
    R Online
    reutli
    erhalte seit heute Fehler im Adapter/Instanz.
    Habe soeben nochmals credentials gecheckt, die er ja wohl auch mit
    smartgarden.0
    	2023-05-03 14:17:14.242	info	1/ Connection: successful: response.statusCode / statusMessage=200 / OK
    akzeptiert, oder?
    Rest sieht dann so aus:
    smartgarden.0
    	2023-05-03 14:17:14.446	info	1/ getConnection: trying to connect again in 300 seconds
    smartgarden.0
    	2023-05-03 14:17:14.445	info	1/ getConnection: returned connection error: request returned 403 Forbidden
    smartgarden.0
    	2023-05-03 14:17:14.444	error	Error: request returned 403 Forbidden
    smartgarden.0
    	2023-05-03 14:17:14.444	info	1/ get_locations failure:..return with error
    smartgarden.0
    	2023-05-03 14:17:14.443	info	1/ get_locations failure: response.statusCode/Message=403/Forbidden
    smartgarden.0
    	2023-05-03 14:17:14.244	info	1/ get_locations ...
    smartgarden.0
    	2023-05-03 14:17:14.244	info	1/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    smartgarden.0
    	2023-05-03 14:17:14.243	info	1/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
    smartgarden.0
    smartgarden.0
    	2023-05-03 14:17:13.976	info	1/ connect ... using client credentials grant
    smartgarden.0
    	2023-05-03 14:17:13.975	info	1/ connect ... empty password
    smartgarden.0
    	2023-05-03 14:17:13.973	info	1/ connect ... empty username
    smartgarden.0
    	2023-05-03 14:17:13.973	info	1/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
    smartgarden.0
    	2023-05-03 14:17:13.972	info	1/ connecting to Gardena Smart System Service ...
    smartgarden.0
    	2023-05-03 14:17:13.971	info	1/ connectToGardena...
    smartgarden.0
    	2023-05-03 14:17:13.970	info	1/ getConnection...
    smartgarden.0
    	2023-05-03 14:17:13.932	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v18.16.0, js-controller: 4.0.24
    Hat API einen Hänger?
    iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
    *Wer freundlich ist, dem wird freundlich geholfen *
    O sambaoleS Rene LausenhammerR K 4 Antworten Letzte Antwort
    • R reutli
      smartgarden.0
      akzeptiert, oder?
      smartgarden.0
      smartgarden.0
      smartgarden.0
      smartgarden.0
      smartgarden.0
      smartgarden.0
      smartgarden.0
      smartgarden.0
      smartgarden.0
      smartgarden.0
      smartgarden.0
      smartgarden.0
      smartgarden.0
      smartgarden.0
      smartgarden.0
      smartgarden.0
      smartgarden.0
      O Offline
      O Offline
      oFbEQnpoLKKl6mbY5e13
      @reutli
      Ist bei mir auch so.
      R 1 Antwort Letzte Antwort
      • O oFbEQnpoLKKl6mbY5e13
        @reutli
        R Online
        R Online
        reutli
        schrieb am zuletzt editiert von reutli
        @ofbeqnpolkkl6mby5e13
        ok, danke, also API?
        O 1 Antwort Letzte Antwort
        • R reutli
          O Offline
          O Offline
          @reutli
          Schätze, ja, mal abwarten...
          • R reutli
            smartgarden.0
            akzeptiert, oder?
            smartgarden.0
            smartgarden.0
            smartgarden.0
            smartgarden.0
            smartgarden.0
            smartgarden.0
            smartgarden.0
            smartgarden.0
            smartgarden.0
            smartgarden.0
            smartgarden.0
            smartgarden.0
            smartgarden.0
            smartgarden.0
            smartgarden.0
            smartgarden.0
            smartgarden.0
            sambaoleS Offline
            sambaoleS Offline
            sambaole
            @reutli Habe das gleiche Problem. Lief bis gestern problemlos. API bei Husqvarna geändert?
            • sambaoleS sambaole
              R Online
              R Online
              reutli
              @sambaole
              Habe keine Ahnung. Ich mach mal noch einen GitHub Issue auf....
              Edit: gibt's schon : https://github.com/jpgorganizer/ioBroker.smartgarden/issues/56
              • R Online
                R Online
                reutli
                Hallo Leute,
                für alle die in den issue rennen:
                Ich habe einen neuen Account (APP-Key und - Secret) erstellt und damit hat es funktioniert.
                Es scheint, dass Accounts/API-connects gesperrt wurde.
                Könnt' Ihr das bestätigen?
                • R reutli
                  Hallo Leute,
                  Dominic151617
                  @reutli Danke für den Tipp und ja, mit einer ganz neuen Application läuft es auch bei mir wieder.
                  • D Dominic151617
                    R Online
                    R Online
                    reutli
                    @jpgorganizer kannst Du da mal schauen, was Sache ist. Die scheinen die accounts gesperrt zu haben...
                    D P 3 Antworten Letzte Antwort
                    • R reutli
                      Dominic151617
                      @reutli @jpgorganizer Also nicht die Accounts in dem Sinne, sondern die Applications. Habe in dem vorhanden Account die Application entsprechend der Anleitung neu angelegt.
                      O G 2 Antworten Letzte Antwort
                      • R reutli
                        Pino72
                        Hab auch nen neue Application erstellt und wollte die neuen keys einsetzen aber ich kann im IOBroker kein application secret mehr reinschreiben...Feld ist ausgegraut und lässt sich nicht editieren?
                        • P Pino72
                          Dominic151617
                          @pino72 sagte in Adapter smartgarden Fehler 403:
                          Benutzernamen und Passwort löschen
                          P 1 Antwort Letzte Antwort
                          • D Dominic151617
                            Pino72
                            @dominic151617 DAnke! Das wars :-)
                            • R reutli
                              Dominic151617
                              @reutli @jpgorganizer Zur Info: bis heute lief der Adapter bei mir mit Benutzernamen und Passwort. Das hat ja wohl schon voher Probleme bereitet. Aber Key und Scret aus der vorhanden Application funktionierten nicht.
                              • D Dominic151617
                                Pino72
                                Läuft jetzt wieder ohne Benutzername und PAsswort aber mit neuen Keys.
                                • D Dominic151617
                                  O Offline
                                  O Offline
                                  @dominic151617 sagte in Adapter smartgarden Fehler 403:
                                  Das war auch bei mir die Lösung.
                                    R Online
                                    R Online
                                    reutli
                                    Na wenigstens haben wir eine Lösung, auch wenn ich gerne den "root cause" wüsste...
                                    • R reutli
                                      smartgarden.0
                                      akzeptiert, oder?
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      smartgarden.0
                                      Rene LausenhammerR Offline
                                      Rene Lausenhammer
                                      schrieb am zuletzt editiert von Rene Lausenhammer
                                      API Neuanlegen dann läufts wieder
                                      N 1 Antwort Letzte Antwort
                                      • Rene LausenhammerR Rene Lausenhammer
                                        N Offline
                                        N Offline
                                        netfriend
                                        Ja stimmt, damit geht's wieder. 👍
                                        War ja letztes Jahr die gleiche Freakshow...irgendwie nervt das. Bei Gardena/Husqvarna spielt man gerne am laufenden System rum. Danach geht irgendwie nix mehr, man merkt es auch nicht sofort. Und im ersten Moment vermutet man, es liegt am eigenen System. Man könnte die registrierten Kunden ja auch mal per eMail informieren, dass es ein Problem gibt oder was geändert wurde und man ne neue Application anlegen muss.
                                        • D Dominic151617
                                          G Online
                                          G Online
                                          Gonzokalle
                                          @dominic151617
                                          Hast du einen Link zur Anleitung? Ist schon lange her, wo ich das gemacht habe. 😊
