  4. Adapter smartgarden Fehler 403
    6.3k
33 Beiträge 11 Kommentatoren 7.4k Aufrufe 12 Beobachtet
  • O oFbEQnpoLKKl6mbY5e13
    @reutli
    Ist bei mir auch so.
    R Online
    R Online
    reutli
    schrieb am zuletzt editiert von reutli
    @ofbeqnpolkkl6mby5e13
    ok, danke, also API?
    iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
    *Wer freundlich ist, dem wird freundlich geholfen *
    O 1 Antwort Letzte Antwort
    • R reutli
      O Abwesend
      O Abwesend
      @reutli
      Schätze, ja, mal abwarten...
      • R reutli
        erhalte seit heute Fehler im Adapter/Instanz.
        Habe soeben nochmals credentials gecheckt, die er ja wohl auch mit
        smartgarden.0
        	2023-05-03 14:17:14.242	info	1/ Connection: successful: response.statusCode / statusMessage=200 / OK
        akzeptiert, oder?
        Rest sieht dann so aus:
        smartgarden.0
        	2023-05-03 14:17:14.446	info	1/ getConnection: trying to connect again in 300 seconds
        smartgarden.0
        	2023-05-03 14:17:14.445	info	1/ getConnection: returned connection error: request returned 403 Forbidden
        smartgarden.0
        	2023-05-03 14:17:14.444	error	Error: request returned 403 Forbidden
        smartgarden.0
        	2023-05-03 14:17:14.444	info	1/ get_locations failure:..return with error
        smartgarden.0
        	2023-05-03 14:17:14.443	info	1/ get_locations failure: response.statusCode/Message=403/Forbidden
        smartgarden.0
        	2023-05-03 14:17:14.244	info	1/ get_locations ...
        smartgarden.0
        	2023-05-03 14:17:14.244	info	1/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        smartgarden.0
        	2023-05-03 14:17:14.243	info	1/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
        smartgarden.0
        smartgarden.0
        	2023-05-03 14:17:13.976	info	1/ connect ... using client credentials grant
        smartgarden.0
        	2023-05-03 14:17:13.975	info	1/ connect ... empty password
        smartgarden.0
        	2023-05-03 14:17:13.973	info	1/ connect ... empty username
        smartgarden.0
        	2023-05-03 14:17:13.973	info	1/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
        smartgarden.0
        	2023-05-03 14:17:13.972	info	1/ connecting to Gardena Smart System Service ...
        smartgarden.0
        	2023-05-03 14:17:13.971	info	1/ connectToGardena...
        smartgarden.0
        	2023-05-03 14:17:13.970	info	1/ getConnection...
        smartgarden.0
        	2023-05-03 14:17:13.932	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v18.16.0, js-controller: 4.0.24
        Hat API einen Hänger?
        sambaoleS Offline
        sambaoleS Offline
        sambaole
        @reutli Habe das gleiche Problem. Lief bis gestern problemlos. API bei Husqvarna geändert?
        R 1 Antwort Letzte Antwort
        • sambaoleS sambaole
          R Online
          R Online
          reutli
          @sambaole
          Habe keine Ahnung. Ich mach mal noch einen GitHub Issue auf....
          Edit: gibt's schon : https://github.com/jpgorganizer/ioBroker.smartgarden/issues/56
          • R Online
            R Online
            reutli
            Hallo Leute,
            für alle die in den issue rennen:
            Ich habe einen neuen Account (APP-Key und - Secret) erstellt und damit hat es funktioniert.
            Es scheint, dass Accounts/API-connects gesperrt wurde.
            Könnt' Ihr das bestätigen?
            • R reutli
              Hallo Leute,
              Dominic151617
              @reutli Danke für den Tipp und ja, mit einer ganz neuen Application läuft es auch bei mir wieder.
              • D Dominic151617
                R Online
                R Online
                reutli
                @jpgorganizer kannst Du da mal schauen, was Sache ist. Die scheinen die accounts gesperrt zu haben...
                D P 3 Antworten Letzte Antwort
                • R reutli
                  Dominic151617
                  @reutli @jpgorganizer Also nicht die Accounts in dem Sinne, sondern die Applications. Habe in dem vorhanden Account die Application entsprechend der Anleitung neu angelegt.
                  O G 2 Antworten Letzte Antwort
                  • R reutli
                    Pino72
                    Hab auch nen neue Application erstellt und wollte die neuen keys einsetzen aber ich kann im IOBroker kein application secret mehr reinschreiben...Feld ist ausgegraut und lässt sich nicht editieren?
                    • P Pino72
                      Dominic151617
                      @pino72 sagte in Adapter smartgarden Fehler 403:
                      Benutzernamen und Passwort löschen
                      P 1 Antwort Letzte Antwort
                      • D Dominic151617
                        Pino72
                        @dominic151617 DAnke! Das wars :-)
                        • R reutli
                          Dominic151617
                          @reutli @jpgorganizer Zur Info: bis heute lief der Adapter bei mir mit Benutzernamen und Passwort. Das hat ja wohl schon voher Probleme bereitet. Aber Key und Scret aus der vorhanden Application funktionierten nicht.
                          • D Dominic151617
                            Pino72
                            Läuft jetzt wieder ohne Benutzername und PAsswort aber mit neuen Keys.
                            • D Dominic151617
                              O Abwesend
                              O Abwesend
                              @dominic151617 sagte in Adapter smartgarden Fehler 403:
                              Das war auch bei mir die Lösung.
                                R Online
                                R Online
                                reutli
                                Na wenigstens haben wir eine Lösung, auch wenn ich gerne den "root cause" wüsste...
                                • R reutli
                                  smartgarden.0
                                  akzeptiert, oder?
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  smartgarden.0
                                  Rene LausenhammerR Offline
                                  Rene Lausenhammer
                                  schrieb am zuletzt editiert von Rene Lausenhammer
                                  API Neuanlegen dann läufts wieder
                                  N 1 Antwort Letzte Antwort
                                  • Rene LausenhammerR Rene Lausenhammer
                                    N Offline
                                    N Offline
                                    netfriend
                                    Ja stimmt, damit geht's wieder. 👍
                                    War ja letztes Jahr die gleiche Freakshow...irgendwie nervt das. Bei Gardena/Husqvarna spielt man gerne am laufenden System rum. Danach geht irgendwie nix mehr, man merkt es auch nicht sofort. Und im ersten Moment vermutet man, es liegt am eigenen System. Man könnte die registrierten Kunden ja auch mal per eMail informieren, dass es ein Problem gibt oder was geändert wurde und man ne neue Application anlegen muss.
                                    • D Dominic151617
                                      G Online
                                      G Online
                                      Gonzokalle
                                      @dominic151617
                                      Hast du einen Link zur Anleitung? Ist schon lange her, wo ich das gemacht habe. 😊
                                      • G Gonzokalle
                                        @dominic151617
                                        O Abwesend
                                        O Abwesend
                                        @gonzokalle
                                        G 1 Antwort Letzte Antwort
                                          @gonzokalle
                                          G Online
                                          G Online
                                          Gonzokalle
                                          Hat funktioniert. Dankeschön 👍
