  3. Off Topic
  4. Proxmox
  5. Proxmox / Influxdb V1 zu V2... wie?
    1.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
221 Beiträge 20 Kommentatoren 56.3k Aufrufe 24 Beobachtet
  • Chris76eC Chris76e
    Jetzt bin ich weiter gekommen, kann aber influx nicht mehr starten
    Failed to start influxdb.service: Unit influxdb.service is masked
    chris@influxdbtest:~$ sudo apt install influxdb2
    Reading package lists... Done
    The following additional packages will be installed:
      influxdb2-cli
    The following packages will be REMOVED:
      influxdb
    The following NEW packages will be installed:
      influxdb2 influxdb2-cli
    0 upgraded, 2 newly installed, 1 to remove and 1 not upgraded.
    Need to get 57.3 MB of archives.
    After this operation, 112 MB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Get:1 https://repos.influxdata.com/debian stable/main amd64 influxdb2 amd64 2.7.1-1 [45.9 MB]
    Get:2 https://repos.influxdata.com/debian stable/main amd64 influxdb2-cli amd64 2.7.3-1 [11.5 MB]
    Fetched 57.3 MB in 1s (51.1 MB/s)
    (Reading database ... 20833 files and directories currently installed.)
    Removing influxdb (1.6.7~rc0-1ubuntu0.22.04.1) ...
    Selecting previously unselected package influxdb2.
    (Reading database ... 20826 files and directories currently installed.)
    Preparing to unpack .../influxdb2_2.7.1-1_amd64.deb ...
    Unpacking influxdb2 (2.7.1-1) ...
    Selecting previously unselected package influxdb2-cli.
    Preparing to unpack .../influxdb2-cli_2.7.3-1_amd64.deb ...
    Unpacking influxdb2-cli (2.7.3-1) ...
    Setting up influxdb2 (2.7.1-1) ...
    Synchronizing state of influxdb.service with SysV service script with /lib/systemd/systemd-sysv-install.
    Executing: /lib/systemd/systemd-sysv-install enable influxdb
    Failed to enable unit: Unit file /etc/systemd/system/influxdb.service is masked.
    ! Important 1.x to 2.x Upgrade Notice !
    Thank you for installing InfluxDB v2.  Due to significant changes between
    the v1 and v2 versions, upgrading to v2 requires additional steps.  If
    upgrading to v2 was not intended, simply re-install the v1 package now.
    An upgrade helper script is available that should be reviewed and executed
    prior to starting the influxdb systemd service.  In order to start the v2
    upgrade, execute the following:
    sudo /usr/share/influxdb/influxdb2-upgrade.sh
    Visit our website for complete details on the v1 to v2 upgrade process:
    https://docs.influxdata.com/influxdb/latest/upgrade/v1-to-v2/
    For new or upgrade installations, please review the getting started guide:
    https://docs.influxdata.com/influxdb/latest/get-started/
    Setting up influxdb2-cli (2.7.3-1) ...
    Processing triggers for man-db (2.10.2-1) ...
    chris@influxdbtest:~$ sudo -u influxdb influxd upgrade
    {"level":"info","ts":1683120477.123403,"caller":"upgrade/upgrade.go:401","msg":"Starting InfluxDB 1.x upgrade"}
    {"level":"info","ts":1683120477.123551,"caller":"upgrade/upgrade.go:404","msg":"Upgrading config file","file":"/etc/influxdb/influxdb.conf"}
    {"level":"info","ts":1683120477.1238437,"caller":"upgrade/upgrade.go:408","msg":"Config file upgraded.","1.x config":"/etc/influxdb/influxdb.conf","2.x config":"/var/lib/influxdb/.influxdbv2/config.toml"}
    {"level":"info","ts":1683120477.1238594,"caller":"upgrade/upgrade.go:418","msg":"Upgrade source paths","meta":"/var/lib/influxdb/meta","data":"/var/lib/influxdb/data"}
    {"level":"info","ts":1683120477.1239064,"caller":"upgrade/upgrade.go:419","msg":"Upgrade target paths","bolt":"/var/lib/influxdb/.influxdbv2/influxd.bolt","engine":"/var/lib/influxdb/.influxdbv2/engine"}
    {"level":"info","ts":1683120477.147437,"caller":"bolt/bbolt.go:83","msg":"Resources opened","service":"bolt","path":"/var/lib/influxdb/.influxdbv2/influxd.bolt"}
    {"level":"info","ts":1683120477.1527815,"caller":"migration/migration.go:175","msg":"Bringing up metadata migrations","service":"migrations","migration_count":20}
    > Welcome to InfluxDB 2.0!
    ? Please type your primary username admin
    ? Please type your password ******
    X Sorry, your reply was invalid: value is too short. Min length is 8
    ? Please type your password **********
    ? Please type your password again **********
    ? Please type your primary organization name iob
    ? Please type your primary bucket name iobroker3
    ? Please type your retention period in hours, or 0 for infinite 0
    ? Setup with these parameters?
      Username:          admin
      Organization:      iob
      Bucket:            iobroker3
      Retention Period:  infinite
     Yes
    {"level":"info","ts":1683120634.533276,"caller":"upgrade/setup.go:73","msg":"CLI config has been stored.","path":"/var/lib/influxdb/.influxdbv2/configs"}
    {"level":"info","ts":1683120634.533326,"caller":"upgrade/database.go:202","msg":"Checking available disk space"}
    {"level":"info","ts":1683120634.5367415,"caller":"upgrade/database.go:223","msg":"Computed disk space","free":"17 GB","required":"595 MB"}
    ? Proceeding will copy all V1 data to "/var/lib/influxdb/.influxdbv2"
      Space available: 17 GB
      Space required:  595 MB
     Yes
    {"level":"info","ts":1683120639.156735,"caller":"upgrade/database.go:51","msg":"Upgrading databases"}
    {"level":"info","ts":1683120639.1700745,"caller":"upgrade/database.go:101","msg":"Creating mapping","database":"iobroker","retention policy":"autogen","orgID":"e285f69fcf72fc03","bucketID":"f93ed287dd616025"}
    {"level":"info","ts":1683120641.8099163,"caller":"upgrade/database.go:195","msg":"Database upgrade complete","upgraded_count":1}
    {"level":"info","ts":1683120641.8100085,"caller":"upgrade/security.go:45","msg":"Upgrading 1.x users"}
    {"level":"warn","ts":1683120641.8101015,"caller":"upgrade/security.go:50","msg":"User is admin and will not be upgraded","username":"admin"}
    {"level":"info","ts":1683120641.8379087,"caller":"upgrade/security.go:115","msg":"User upgrade complete","upgraded_count":2}
    {"level":"info","ts":1683120641.838016,"caller":"upgrade/upgrade.go:488","msg":"Upgrade successfully completed. Start the influxd service now, then log in","login_url":"http://localhost:8086"}
    chris@influxdbtest:~$ sudo systemctl start influxdb
    Failed to start influxdb.service: Unit influxdb.service is masked.
    chris@influxdbtest:~$ service influxdb start
    Failed to start influxdb.service: Access denied
    See system logs and 'systemctl status influxdb.service' for details.
    chris@influxdbtest:~$ sudo systemctl status influxdb
    * influxdb.service
         Loaded: masked (Reason: Unit influxdb.service is masked.)
         Active: inactive (dead) since Wed 2023-05-03 13:25:29 UTC; 7min ago
       Main PID: 912 (code=exited, status=0/SUCCESS)
            CPU: 2.201s
    May 03 13:25:29 influxdbtest influxd[912]: ts=2023-05-03T13:25:29.439535Z lvl=info msg="Shutting down monitor service" log_id=0h_S6k~0000 service=monitor
    May 03 13:25:29 influxdbtest influxd[912]: ts=2023-05-03T13:25:29.439539Z lvl=info msg="Terminating storage of statistics" log_id=0h_S6k~0000 service=monitor
    May 03 13:25:29 influxdbtest influxd[912]: ts=2023-05-03T13:25:29.439547Z lvl=info msg="Terminating precreation service" log_id=0h_S6k~0000 service=shard-precr>
    May 03 13:25:29 influxdbtest influxd[912]: ts=2023-05-03T13:25:29.439552Z lvl=info msg="Terminating continuous query service" log_id=0h_S6k~0000 service=contin>
    May 03 13:25:29 influxdbtest influxd[912]: ts=2023-05-03T13:25:29.439572Z lvl=info msg="Closing retention policy enforcement service" log_id=0h_S6k~0000 servic>
    May 03 13:25:29 influxdbtest influxd[912]: ts=2023-05-03T13:25:29.446068Z lvl=info msg="Closed service" log_id=0h_S6k~0000 service=subscriber
    May 03 13:25:29 influxdbtest influxd[912]: ts=2023-05-03T13:25:29.446118Z lvl=info msg="Server shutdown completed" log_id=0h_S6k~0000
    May 03 13:25:29 influxdbtest systemd[1]: influxdb.service: Deactivated successfully.
    May 03 13:25:29 influxdbtest systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
    May 03 13:25:29 influxdbtest systemd[1]: influxdb.service: Consumed 2.201s CPU time.
    #173
    @chris76e sagte in Proxmox / Influxdb V1 zu V2... wie?:
    Moin,
    hast Du das gelesen?
    sudo /usr/share/influxdb/influxdb2-upgrade.sh                                <-----------------
    Dann macht der das von alleine
    [dp20eic@influxDB ~]$ sudo apt install influxdb2
      influxdb2-cli
      influxdb
    0 upgraded, 2 newly installed, 1 to remove and 0 not upgraded.
    After this operation, 24.4 MB disk space will be freed.
    Fetched 57.3 MB in 2s (24.7 MB/s)
    (Reading database ... 23066 files and directories currently installed.)
    Removing influxdb (1.8.10-1) ...
    (Reading database ... 23046 files and directories currently installed.)
    [dp20eic@influxDB ~]$ sudo /usr/share/influxdb/influxdb2-upgrade.sh
    {"level":"info","ts":1683120863.4011807,"caller":"upgrade/upgrade.go:401","msg":"Starting InfluxDB 1.x upgrade"}
    {"level":"info","ts":1683120863.4013894,"caller":"upgrade/upgrade.go:404","msg":"Upgrading config file","file":"/etc/influxdb/influxdb.conf"}
    {"level":"info","ts":1683120863.4016256,"caller":"upgrade/upgrade.go:408","msg":"Config file upgraded.","1.x config":"/etc/influxdb/influxdb.conf","2.x config":"/etc/influxdb/config.toml"}
    {"level":"info","ts":1683120863.401655,"caller":"upgrade/upgrade.go:418","msg":"Upgrade source paths","meta":"/var/lib/influxdb/meta","data":"/var/lib/influxdb/data"}
    {"level":"info","ts":1683120863.4016862,"caller":"upgrade/upgrade.go:419","msg":"Upgrade target paths","bolt":"/var/lib/influxdb/influxd.bolt","engine":"/var/lib/influxdb/engine"}
    {"level":"info","ts":1683120863.4033222,"caller":"bolt/bbolt.go:83","msg":"Resources opened","service":"bolt","path":"/var/lib/influxdb/influxd.bolt"}
    {"level":"info","ts":1683120863.4036214,"caller":"migration/migration.go:175","msg":"Bringing up metadata migrations","service":"migrations","migration_count":20}
    ? Please type your primary username dp20eic
    ? Please type your password ***********
    ? Please type your password again ***********
    ? Please type your primary organization name iobroker
      Username:          dp20eic
      Organization:      iobroker
      Bucket:            iobroker
     Yes
    {"level":"info","ts":1683121542.855478,"caller":"upgrade/setup.go:73","msg":"CLI config has been stored.","path":"/root/.influxdbv2/configs"}
    {"level":"info","ts":1683121542.8555653,"caller":"upgrade/database.go:202","msg":"Checking available disk space"}
    {"level":"info","ts":1683121542.8631513,"caller":"upgrade/database.go:223","msg":"Computed disk space","free":"17 GB","required":"2.9 GB"}
    ? Proceeding will copy all V1 data to "/var/lib/influxdb"
      Space required:  2.9 GB
     Yes
    {"level":"info","ts":1683121556.5976517,"caller":"upgrade/database.go:51","msg":"Upgrading databases"}
    {"level":"info","ts":1683121556.5980585,"caller":"upgrade/database.go:101","msg":"Creating mapping","database":"iobroker","retention policy":"global","orgID":"e252c40981d69d16","bucketID":"26e75b81215f75de"}
    {"level":"info","ts":1683121568.78221,"caller":"upgrade/database.go:101","msg":"Creating mapping","database":"telegraf","retention policy":"autogen","orgID":"e252c40981d69d16","bucketID":"b98918d0b4c6d11b"}
    {"level":"info","ts":1683121577.072777,"caller":"upgrade/database.go:195","msg":"Database upgrade complete","upgraded_count":2}
    {"level":"info","ts":1683121577.0735512,"caller":"upgrade/security.go:45","msg":"Upgrading 1.x users"}
    {"level":"warn","ts":1683121577.0737543,"caller":"upgrade/security.go:50","msg":"User is admin and will not be upgraded","username":"influxDb"}
    {"level":"info","ts":1683121577.0737848,"caller":"upgrade/security.go:115","msg":"User upgrade complete","upgraded_count":0}
    {"level":"info","ts":1683121577.0738018,"caller":"upgrade/upgrade.go:488","msg":"Upgrade successfully completed. Start the influxd service now, then log in","login_url":"http://localhost:8086"}
    The upgrade completed successfully.  Execute the following to start InfluxDB:
    A complete copy of v1 data was created as part of the upgrade process.
    After confirming v2 is functioning as intended, removal of v1 data can be
    performed by executing:
    sudo /var/tmp/influxdbv1-remove.sh
    NOTE: This script will erase all previous v1 data and config files!
    Ich bin jetzt mal für ne Stunde weg.
    Bernd
      @dp20eic sagte in Proxmox / Influxdb V1 zu V2... wie?:
      ich erstelle gerade eine Kopie meiner 1.8 influxDB Instanz. Dann kann ich das alles einmal durchgehen.
      Danke, warte dann auf dich.
      Habe zwar jetzt was hinbekommen, aber keine Ahnung ob es richtig ist.
      #174
      Moin,
      dann zeig doch mal was jetzt so angezeigt wird
      # apt policy influxdb*
      # systemctl status influxd.service
      # systemctl status influxdb.service
      Und wenn alles up and running
      http://ip.influx.db:8086
      dann sollte das kommen
      Das erste Bucket im letzten Bild ist das, welches ich bei der Migration angelegt habe, das zweite iobroker/global ist das, welches aus der V1.8 migriert wurde. Das Telegraf Bucket ist eine DB die ich auch noch in der V 1.8 hatte.
      Dann ist das aber alles umgestellt auf die neue Abfragesprache FLUX, wenn Du weiter in influxQL unter Grafana werkeln willst, muss man noch etwas umstellen, suche ich gleich mal.
      Bernd
      Chris76eC 1 Antwort Letzte Antwort
        Moin,
        Bernd
        Chris76eC Offline
        Chris76eC Offline
        Chris76e
        #175
        @dp20eic
        scheint zulaufen 😊
        Oder muss ich nochwas machen?
        chris@influxdb3test:~$ apt policy influxdb*
        influxdb2-cli:
          Installed: (none)
          Candidate: 2.7.3-1
          Version table:
             2.7.3-1 500
                500 https://repos.influxdata.com/debian stable/main amd64 Packages
             2.7.1-2 500
             2.6.1 500
             2.6.0 500
             2.5.0 500
             2.4.0 500
             2.3.0 500
        influxdb-client:
          Installed: (none)
          Candidate: 1.6.7~rc0-1ubuntu0.22.04.2
          Version table:
             1.6.7~rc0-1ubuntu0.22.04.2 500
                500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
             1.6.7~rc0-1 500
                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        influxdb-dev:
          Installed: (none)
          Candidate: (none)
          Version table:
        influxdb2-client:
          Installed: (none)
          Candidate: 2.7.1-1
          Version table:
             2.7.1-1 500
        influxdb:
          Installed: (none)
          Candidate: 1.8.10-1
          Version table:
             1.8.10-1 500
             1.6.7~rc0-1ubuntu0.22.04.1 -1
             1.6.7~rc0-1 500
        influxdb2:
          Installed: 2.7.1-1
          Candidate: 2.7.1-1
          Version table:
         *** 2.7.1-1 500
             2.7.0-1 500
             2.6.1-1 500
             2.6.0-1 500
             2.5.1-1 500
             2.4.0-1 500
             2.3.0-1 500
             2.2.0 500
        Thomas BraunT ? 2 Antworten Letzte Antwort
          @dp20eic
          scheint zulaufen 😊
          influxdb2-cli:
            Installed: (none)
            Candidate: 2.7.3-1
            Version table:
               2.7.3-1 500
               2.7.1-2 500
               2.6.1 500
               2.6.0 500
               2.5.0 500
               2.4.0 500
               2.3.0 500
          influxdb-client:
            Installed: (none)
            Version table:
               1.6.7~rc0-1 500
          influxdb-dev:
            Installed: (none)
            Candidate: (none)
            Version table:
          influxdb2-client:
            Installed: (none)
            Candidate: 2.7.1-1
            Version table:
               2.7.1-1 500
          influxdb:
            Installed: (none)
            Candidate: 1.8.10-1
            Version table:
               1.8.10-1 500
               1.6.7~rc0-1 500
          influxdb2:
            Installed: 2.7.1-1
            Candidate: 2.7.1-1
            Version table:
           *** 2.7.1-1 500
               2.7.0-1 500
               2.6.1-1 500
               2.6.0-1 500
               2.5.1-1 500
               2.4.0-1 500
               2.3.0-1 500
               2.2.0 500
          #176
          @chris76e
          Für (unter anderem) Backups wird noch der
          influxdb2-client
          benötigt.
            @dp20eic
            scheint zulaufen 😊
            influxdb2-cli:
              Installed: (none)
              Candidate: 2.7.3-1
              Version table:
                 2.7.3-1 500
                 2.7.1-2 500
                 2.6.1 500
                 2.6.0 500
                 2.5.0 500
                 2.4.0 500
                 2.3.0 500
            influxdb-client:
              Installed: (none)
              Version table:
                 1.6.7~rc0-1 500
            influxdb-dev:
              Installed: (none)
              Candidate: (none)
              Version table:
            influxdb2-client:
              Installed: (none)
              Candidate: 2.7.1-1
              Version table:
                 2.7.1-1 500
            influxdb:
              Installed: (none)
              Candidate: 1.8.10-1
              Version table:
                 1.8.10-1 500
                 1.6.7~rc0-1 500
            influxdb2:
              Installed: 2.7.1-1
              Candidate: 2.7.1-1
              Version table:
             *** 2.7.1-1 500
                 2.7.0-1 500
                 2.6.1-1 500
                 2.6.0-1 500
                 2.5.1-1 500
                 2.4.0-1 500
                 2.3.0-1 500
                 2.2.0 500
            #177
            Moin,
            na, wenn das jetzt Deine Daten im Bucket sind und nicht die vom Nachbarn, dann schaut das ja mal gut aus :)
            Wenn Du Grafana nutzt, musst Du Dich entscheiden, ob Du vorhandene Panels/Dashboards auf die neue FLUX Abfragesprache umstellen möchtest oder ob Du da weiter mit influxQL Handtieren möchtest.
            Ich bin komplett umgestiegen auf FLUX und kann Dir nicht sagen wie Du das Einstellen musst, vielleicht steht ja hier was https://docs.influxdata.com/influxdb/v2.7/upgrade/v1-to-v2/manual-upgrade/
            Es gibt aber schon einige Posts hier im Forum, die das Thema behandeln.
            Und wie @Thomas-Braun sagte, wenn Du den ioBroker - Backitup Adapter nutzt, musst Du den influxdb2-cli auf dem ioBroker installieren, ansonsten kannst Du keine Backups der influxDB machen.
            @Thomas-Braun müsste das nicht influxdb2-cli sein?
            Bernd
              Moin,
              Bernd
              #178
              @dp20eic
              Ich weiß es nicht genau. Ich hab jetzt die Versionsnummer genommen die zur Hauptversion passt.
              Man müsste man in influxdb2-cli und influxdb2-client hineinschauen und checken was da drin ist
                @chris76e
                influxdb2-client
                benötigt.
                Chris76eC Offline
                Chris76eC Offline
                Chris76e
                #179
                @thomas-braun sagte in Proxmox / Influxdb V1 zu V2... wie?:
                influxdb2-client
                Bin nach der offiziellen Anleitung gegangen
                Download from the command line
                # amd64
                wget https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.7.1-linux-amd64.tar.gz
                # arm
                wget https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.7.1-linux-arm64.tar.gz
                Unpackage the downloaded package.
                Note: The following commands are examples. Adjust the filenames, paths, and utilities if necessary.
                # amd64
                tar xvzf path/to/influxdb2-client-2.7.1-linux-amd64.tar.gz
                # arm
                tar xvzf path/to/influxdb2-client-2.7.1-linux-arm64.tar.gz
                Aber scheint nicht zufunktionieren
                chris@influxdb3test:~$ wget https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.7.1-linux-amd64.tar.gz
                --2023-05-03 16:02:32--  https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.7.1-linux-amd64.tar.gz
                Resolving dl.influxdata.com (dl.influxdata.com)... 18.154.63.120, 18.154.63.100, 18.154.63.19, ...
                Connecting to dl.influxdata.com (dl.influxdata.com)|18.154.63.120|:443... connected.
                HTTP request sent, awaiting response... 200 OK
                Length: 11265848 (11M) [application/x-tar]
                Saving to: 'influxdb2-client-2.7.1-linux-amd64.tar.gz'
                influxdb2-client-2.7.1-linux-amd64.tar. 100%[===============================================================================>]  10.74M  --.-KB/s    in 0.1s
                2023-05-03 16:02:33 (82.0 MB/s) - 'influxdb2-client-2.7.1-linux-amd64.tar.gz' saved [11265848/11265848]
                chris@influxdb3test:~$ tar xvzf ./influxdb2-client-2.7.1-linux-amd64.tar.gz
                ./LICENSE
                ./README.md
                ./influx
                influxdb2-cli:
                  Installed: (none)
                  Candidate: 2.7.3-1
                  Version table:
                     2.7.3-1 500
                     2.7.1-2 500
                     2.6.1 500
                     2.6.0 500
                     2.5.0 500
                     2.4.0 500
                     2.3.0 500
                influxdb-client:
                  Installed: (none)
                  Version table:
                     1.6.7~rc0-1 500
                influxdb-dev:
                  Installed: (none)
                  Candidate: (none)
                  Version table:
                influxdb2-client:
                  Installed: (none)
                  Candidate: 2.7.1-1
                  Version table:
                     2.7.1-1 500
                influxdb:
                  Installed: (none)
                  Candidate: 1.8.10-1
                  Version table:
                     1.8.10-1 500
                     1.6.7~rc0-1 500
                influxdb2:
                  Installed: 2.7.1-1
                  Candidate: 2.7.1-1
                  Version table:
                 *** 2.7.1-1 500
                     2.7.0-1 500
                     2.6.1-1 500
                     2.6.0-1 500
                     2.5.1-1 500
                     2.4.0-1 500
                     2.3.0-1 500
                     2.2.0 500
                ? Thomas BraunT 2 Antworten Letzte Antwort
                  influxdb2-client
                  # amd64
                  # arm
                  # amd64
                  # arm
                  ./LICENSE
                  ./README.md
                  ./influx
                  influxdb2-cli:
                    Installed: (none)
                    Candidate: 2.7.3-1
                    Version table:
                       2.7.3-1 500
                       2.7.1-2 500
                       2.6.1 500
                       2.6.0 500
                       2.5.0 500
                       2.4.0 500
                       2.3.0 500
                  influxdb-client:
                    Installed: (none)
                    Version table:
                       1.6.7~rc0-1 500
                  influxdb-dev:
                    Installed: (none)
                    Candidate: (none)
                    Version table:
                  influxdb2-client:
                    Installed: (none)
                    Candidate: 2.7.1-1
                    Version table:
                       2.7.1-1 500
                  influxdb:
                    Installed: (none)
                    Candidate: 1.8.10-1
                    Version table:
                       1.8.10-1 500
                       1.6.7~rc0-1 500
                  influxdb2:
                    Installed: 2.7.1-1
                    Candidate: 2.7.1-1
                    Version table:
                   *** 2.7.1-1 500
                       2.7.0-1 500
                       2.6.1-1 500
                       2.6.0-1 500
                       2.5.1-1 500
                       2.4.0-1 500
                       2.3.0-1 500
                       2.2.0 500
                  #180
                  Moin,
                  was versuchst Du gerade?
                  Die erste Frage ist, nutzt Du den ioBrober Backitup Adapter?
                  Wenn, ja, dann musst Du auf dem ioBroker den Client installieren, damit der ioBroker das Bucket, in welches Du schreibst, mit sichern kann, fehlt der Client, kann man nicht remote auf die influxDB zugreifen.
                  Wenn alles ioBroker u. influxDB auf demselben Server läuft, dann ist das nicht nötig.
                  Sollte der ioBroker im eigenen Container laufen, dann musst Du da auch das korrekten Repository anlegen und dann mit
                  # sudo apt install influxdb2-client
                  installieren
                  Bernd
                    Moin,
                    installieren
                    Bernd
                    Chris76eC Offline
                    Chris76eC Offline
                    Chris76e
                    #181
                    @dp20eic
                    InfluxDB läuft auf einem eigene LXC, Backups werden mit Proxmox gemacht
                      influxdb2-client
                      # amd64
                      # arm
                      # amd64
                      # arm
                      ./LICENSE
                      ./README.md
                      ./influx
                      influxdb2-cli:
                        Installed: (none)
                        Candidate: 2.7.3-1
                        Version table:
                           2.7.3-1 500
                           2.7.1-2 500
                           2.6.1 500
                           2.6.0 500
                           2.5.0 500
                           2.4.0 500
                           2.3.0 500
                      influxdb-client:
                        Installed: (none)
                        Version table:
                           1.6.7~rc0-1 500
                      influxdb-dev:
                        Installed: (none)
                        Candidate: (none)
                        Version table:
                      influxdb2-client:
                        Installed: (none)
                        Candidate: 2.7.1-1
                        Version table:
                           2.7.1-1 500
                      influxdb:
                        Installed: (none)
                        Candidate: 1.8.10-1
                        Version table:
                           1.8.10-1 500
                           1.6.7~rc0-1 500
                      influxdb2:
                        Installed: 2.7.1-1
                        Candidate: 2.7.1-1
                        Version table:
                       *** 2.7.1-1 500
                           2.7.0-1 500
                           2.6.1-1 500
                           2.6.0-1 500
                           2.5.1-1 500
                           2.4.0-1 500
                           2.3.0-1 500
                           2.2.0 500
                      #182
                      @chris76e
                      Hatten wir nicht oben bereits gesagt, dass man keine tar.gz wildherunterlädt, sondern seinen PAKETTMANAGER benutzt? Dafür ist der nämlich da.
                      Lösch den Mist wieder.
                        @chris76e
                        Chris76eC Offline
                        Chris76eC Offline
                        Chris76e
                        #183
                        was soll man denn machen wenn man nicht viel Ahnung von Linux hat? Das ist doch die offizielle Anleitung von influx. https://docs.influxdata.com/influxdb/v2.7/tools/influx-cli/?t=Linux
                        Du schreibst:
                        influxdb2-client
                        benötigt.
                        dann habe ich nach influxdb2-client gesucht.....
                          Du schreibst:
                          influxdb2-client
                          benötigt.
                          #184
                          @chris76e
                          So installiert man Software unter Debian:
                          sudo apt install PAKETNAME
                          Entsprechende Quelle muss u.U. noch angelegt werden.
                          Andere Linux-Geschmacksrichtungen haben andere Paketmanager.
                            @chris76e
                            Chris76eC Offline
                            Chris76eC Offline
                            Chris76e
                            #185
                            So sieht es jetzt aus
                            influxdb2-cli:
                              Installed: (none)
                              Candidate: 2.7.3-1
                              Version table:
                                 2.7.3-1 500
                                 2.7.1-2 500
                                 2.6.1 500
                                 2.6.0 500
                                 2.5.0 500
                                 2.4.0 500
                                 2.3.0 500
                            influxdb-client:
                              Installed: (none)
                              Version table:
                                 1.6.7~rc0-1 500
                            influxdb-dev:
                              Installed: (none)
                              Candidate: (none)
                              Version table:
                            influxdb2-client:
                              Installed: 2.7.1-1
                              Candidate: 2.7.1-1
                              Version table:
                             *** 2.7.1-1 500
                            influxdb:
                              Installed: (none)
                              Candidate: 1.8.10-1
                              Version table:
                                 1.8.10-1 500
                                 1.6.7~rc0-1 500
                            influxdb2:
                              Installed: 2.7.1-1
                              Candidate: 2.7.1-1
                              Version table:
                             *** 2.7.1-1 500
                                 2.7.0-1 500
                                 2.6.1-1 500
                                 2.6.0-1 500
                                 2.5.1-1 500
                                 2.4.0-1 500
                                 2.3.0-1 500
                                 2.2.0 500
                              @dp20eic
                              #186
                              @dp20eic
                              Moin,
                              dann bist Du erst einmal fertig, denn nur wenn Du den ioBroker Adapter 3fb67c71-a435-42a7-b174-424ed437d40c-grafik.png nutzt, brauchst Du den Client auf dem ioBroker Server.
                              Solange Du die Backups mit Proxmox machst, ist das dann nicht nötig.
                              Bernd
                              P.S.: und wie @Thomas-Braun schon sagte, lösche das, was Du da heruntergeladen hast.
                              Chris76eC Thomas BraunT 2 Antworten Letzte Antwort
                                @dp20eic
                                Moin,
                                Bernd
                                Chris76eC Offline
                                Chris76eC Offline
                                Chris76e
                                #187
                                @dp20eic
                                Danke 👍
                                  @dp20eic
                                  Moin,
                                  Bernd
                                  #188
                                  @dp20eic
                                  Wobei ich vermutlich bei den Backups zweigleisig fahren würde. Falls entsprechend ausreichend Speicherplatz vorhanden ist jedenfalls.
                                    influxdb2-cli:
                                      Installed: (none)
                                      Candidate: 2.7.3-1
                                      Version table:
                                         2.7.3-1 500
                                         2.7.1-2 500
                                         2.6.1 500
                                         2.6.0 500
                                         2.5.0 500
                                         2.4.0 500
                                         2.3.0 500
                                    influxdb-client:
                                      Installed: (none)
                                      Version table:
                                         1.6.7~rc0-1 500
                                    influxdb-dev:
                                      Installed: (none)
                                      Candidate: (none)
                                      Version table:
                                    influxdb2-client:
                                      Installed: 2.7.1-1
                                      Candidate: 2.7.1-1
                                      Version table:
                                     *** 2.7.1-1 500
                                    influxdb:
                                      Installed: (none)
                                      Candidate: 1.8.10-1
                                      Version table:
                                         1.8.10-1 500
                                         1.6.7~rc0-1 500
                                    influxdb2:
                                      Installed: 2.7.1-1
                                      Candidate: 2.7.1-1
                                      Version table:
                                     *** 2.7.1-1 500
                                         2.7.0-1 500
                                         2.6.1-1 500
                                         2.6.0-1 500
                                         2.5.1-1 500
                                         2.4.0-1 500
                                         2.3.0-1 500
                                         2.2.0 500
                                    #189
                                    Moin,
                                    das ist für den aktuellen Betrieb erst einmal ausreichend.
                                    Du kannst bei der 2er-Version viel mittels der WEB-UI einstellen und administrieren, aber manches geht nur auf der Kommandozeile, dafür brauchst Du dann das influxDB2-cli, das kann entweder auf dem influxDB Server mit installiert sein oder auf irgendeinem anderen.
                                    Mach aber erst mal weiter und wenn alles erst mal läuft eine Sicherung nicht vergessen :)
                                    Bernd
                                      @dp20eic
                                      #190
                                      @dp20eic
                                      Moin,
                                      ja, ist mit Sicherheit ein wichtiger Hinweis, aber wieso schon wieder Rennen, wenn man erst einmal Laufen lernen sollte :)
                                      Bernd
                                        Moin,
                                        Bernd
                                        Chris76eC Offline
                                        Chris76eC Offline
                                        Chris76e
                                        #191
                                        @dp20eic noch läuft es auf dem test lxc, daten werden jetzt mit flux übernommen
                                          #192
                                          Moin,
                                          sieht doch gut aus.
                                          Dann viel Spaß beim ioBrokern und influxen :)
                                          Bernd
