  3. Einsteigerfragen
  4. Installation
  5. IOBroker backup auf neue Rasperry übertragen
65 Beiträge 5 Kommentatoren 5.0k Aufrufe 3 Beobachtet
  • M Metzid
    @crunchip nach dem restore startet der iobroker leider nicht mehr. Soll ich iobroker fix ausführen
    @crunchip hier der log iobroker ist dann wieder problemlos gestartet
    login as: pi
    pi@192.168.178.172's password:
    Linux piiobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
    permitted by applicable law.
    Last login: Wed Apr 26 11:31:28 2023
    Wi-Fi is currently blocked by rfkill.
    Use raspi-config to set the country before use.
    pi@piiobroker:~ $ cd /opt/iobroker
    pi@piiobroker:/opt/iobroker $ iobroker stop
    pi@piiobroker:/opt/iobroker $ iobroker setup custom
    Current configuration:
    - Objects database:
      - Type: jsonl
      - Host/Unix Socket: 127.0.0.1
      - Port: 9001
    - States database:
      - Type: jsonl
      - Port: 9000
    - Data Directory: ../../iobroker-data/
    Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: f
    Host / Unix Socket of objects DB(file), default[127.0.0.1]:
    Port of objects DB(file), default[9001]:
    Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [file]: f
    Host / Unix Socket of states DB (file), default[127.0.0.1]:
    Port of states DB (file), default[9000]:
    Data directory (file), default[../../iobroker-data/]:
    Host name of this machine [piiobroker]: piiobroker
    This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y
    Do you want to migrate objects and states from "jsonl/jsonl" to "file/file" [y/N]: y
    Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y
    Connecting to previous DB "jsonl"...
    Creating backup ...
    This can take some time ... please be patient!
    host.piiobroker 102 states saved
    host.piiobroker 143 objects saved
    Backup created: /opt/iobroker/backups/2023_04_27-09_30_42_backupiobroker-migration.tar.gz
    updating conf/iobroker.json
    Connecting to new DB "file" (can take up to 20s) ...
    Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
    Server Cannot load /opt/iobroker/iobroker-data/states.json: Database file /opt/iobroker/iobroker-data/states.json does not exists.. We try last Backup!
    Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
    Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
    Server Cannot load /opt/iobroker/iobroker-data/states.json.bak: Database file /opt/iobroker/iobroker-data/states.json.bak does not exists.. Continue with empty dataset!
     Cannot read system.config: null (OK when migrating or restoring)
    Restore backup ...
    iobroker controller daemon is not running
    host.piiobroker OK.
    host.piiobroker Clear all objects and states...
    clean 2 objects...
    clean 2 states...
    host.piiobroker done.
    host.piiobroker Processed 0/143 objects
    143 objects restored.
    host.piiobroker Processed 0/102 states
    102 states restored.
    upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
    upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
    upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
    upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
    upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
    upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
    upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
    upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
    upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
    upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
    upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
    upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
    Reinstalling adapter "admin" from "iobroker.admin@6.3.5"
    removed 1 package, and changed 4 packages in 45s
    45 packages are looking for funding
      run `npm fund` for details
    Reinstalling adapter "backitup" from "iobroker.backitup@2.6.19"
    up to date in 6s
    Could not migrate objects to corresponding sets: Cannot read properties of undefined (reading 'getObjectList')
    Backup restored - Migration successful
    Important: If your system consists of multiple hosts please execute
    "iobroker upload all" on the master AFTER all other hosts/slaves have
    also been updated to this states/objects database configuration AND are
    running!
    crunchipC Abwesend
    crunchipC Abwesend
    @metzid sagte in IOBroker backup auf neue Rasperry übertragen:
    ein restore dauert auch eine Weile, wie lange hast du gewartet?
    und generell, auf welchem Stand ist deine alte Installation bzw das backup?
      Metzid
      @crunchip Altsystem Raspberry 3B
      • Plattform: linux
      • Die Architektur: arm
      • CPUs: 4
      • Geschwindigkeit: 1200 MHz
      • Modell: ARMv7 Processor rev 4 (v7l)
      • RAM: 923.3 MB
      • System-Betriebszeit: 00:45:28
      • Node.js: v10.18.0
      • NPM: 6.13.4
      • Datenträgergröße: 12.9 GiB
      • Datenträger verfügbar: 7.5 GiB
      • Adapter-Anzahl: 471
      • Betriebszeit: 23:32:45
      • Aktive Instanzen: 8
      Betriebsystem Jessie
      Der Js-controller hat die Version ist 2.1.1 Jetzt wollte ich das System updaten leider scheint die installierte Raspbain GUN linux8 Jessie nicht mehr mit den neuen JS-controllern unterstützt zu werden. Wenn ich da einen update durchführen verhagelt er mir das ganze system. Leider konnte ich beim Altsystem kein Backup mit dem Backit
      Hier die Übersicht zum neuen System
      Neue System Raspberry 3B
      • Plattform: linux
      • Betriebssystem: linux
      • Architektur: arm64
      • CPUs: 4
      • Modell: Cortex-A53
      • RAM: 909.6 MB
      • System-Betriebszeit: 00:23:54
      • Node.js: v18.16.0
      • time: 1682502790750
      • timeOffset: -60
      • NPM: v9.5.1
      • Datenträgergröße: 14.3 GB
      • Freier Festplattenspeicher: 9.5 GB
      • Betriebszeit: 00:04:51
      • Aktive Instanzen: 3
      • Pfad: /opt/iobroker/
      • aktiv:
      • Der Js-controller hat die Version ist 4.0.24
      Betriebsystem bullseye
      Leider ließ sich auf dem Altsystem auch der Backitup Adapter nicht installieren.
      Somit habe ich über putty manuell über den command das Backup angestoßen.
      iobroker Backup erstellt.
      Das Backup habe ich dann auf das Neusystem kopiert und nach Stop des iobrokers das System versucht zurückzuspielen
      Welche Option habe ich jetzt noch
      • M Metzid
        • Plattform: linux
        • CPUs: 4
        • RAM: 923.3 MB
        • Node.js: v10.18.0
        • NPM: 6.13.4
        • Plattform: linux
        • CPUs: 4
        • RAM: 909.6 MB
        • Node.js: v18.16.0
        • timeOffset: -60
        • NPM: v9.5.1
        • aktiv:
        @metzid
        Jag mal iob diag über das System.
        Musst du direkt aufrufen, siehe in meiner Signatur.
        • crunchipC Abwesend
          crunchipC Abwesend
          @metzid ok also immer noch auf deinem alten System der gleiche Stand wie zu Beginn im Thread.
          ich würde mal versuchen den controller auf die V3.3(beinhaltet jsonl) zu bringen, den admin entsprechen auf 4.1 oder größer, also bewusst bestimmte versionen installieren, müsste ja mit deiner node10 uns jessi noch funktionieren
          somit müsste auch der backitup adapter( auch eventuell in einer älteren version) funktionieren um ein passende backup zu erstellen, was auf einem neuen system dann eingespielt werden kann
            Metzid
            @crunchip danke für die Info gibt es eine Beschreibung wie man den controller auf die besagte Version bringt.
            • M Metzid
              crunchipC Abwesend
              crunchipC Abwesend
              @metzid dazu musst du ins entsprechende Verzeichnis
              /opt/iobroker
              Von da via npm install
              Z.b. admin
              npm install admin @4.0
              npm install iobroker.js-controller@version
                @metzid
                Metzid
                pi@raspberrypi:/opt/iobroker $ iob diag
                Commands:
                iobroker setup [--objects <host>] [--states <host>] [custom]
                iobroker start
                iobroker stop
                iobroker start <adapter>
                iobroker stop <adapter>
                iobroker start all
                iobroker restart
                iobroker restart <adapter>
                iobroker info
                iobroker logs [adapter] [--watch] [--lines=1000]
                iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
                iobroker install <adapter>
                iobroker url <url> [<name>]
                iobroker del <adapter>
                iobroker del <adapter>.<instance>
                iobroker update [repository url] [--updatable/--u] [--installed/--i]
                iobroker upgrade [repository url]
                iobroker upgrade self [repository url]
                iobroker upgrade <adapter> [repository url]
                iobroker upload <pathToLocalFile> <pathIniobroker>
                iobroker upload all
                iobroker upload <adapter>
                iobroker object get <id>
                iobroker object set <id> <json-value>
                iobroker object set <id> propertyname=value
                iobroker object del <id|pattern> [--yes]
                iobroker object chmod <object-mode> [state-mode] <id>
                iobroker object chown <user> <group> <id>
                iobroker object list <id>
                iobroker state get <id>
                iobroker state getplain <id> [--pretty]
                iobroker state getvalue <id>
                iobroker state set <id> <value> [ack]
                iobroker state del <id>
                iobroker message <adapter>[.instanceid] <command> [<message>]
                iobroker list <type> [filter]
                iobroker chmod <mode> <file>
                iobroker chown <user> <group> <file>
                iobroker touch <file>
                iobroker rm <file>
                iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
                iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
                iobroker file sync
                iobroker user add <user> [--ingroup group] [--password pass]
                iobroker user del <user>
                iobroker user passwd <user> [--password pass]
                iobroker user enable <user>
                iobroker user disable <user>
                iobroker user get <user>
                iobroker user check <user> [--password pass]
                iobroker group add <group>
                iobroker group del <group>
                iobroker group list <group>
                iobroker group enable <group>
                iobroker group disable <group>
                iobroker group get <group>
                iobroker group adduser <group> <user>
                iobroker group deluser <group> <user>
                iobroker host this
                iobroker host <hostname>
                iobroker host set <hostname>
                iobroker host remove <hostname>
                iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
                iobroker license <license.file or license.text>
                iobroker cert create
                iobroker cert view [<certificate name>]
                iobroker clean
                iobroker backup
                iobroker restore <backup name or path>
                iobroker <command> --timeout 5000
                iobroker status [all]
                iobroker repo [name]
                iobroker repo add <name> <path or url>
                iobroker repo set <name>
                iobroker repo del <name>
                iobroker uuid
                iobroker unsetup
                iobroker multihost <enable|disable> [--secure true|false]
                iobroker multihost browse
                iobroker multihost connect
                iobroker compact status
                iobroker compact <enable|on|disable|off>
                iobroker compact <adapter>.<instance> status
                iobroker compact <adapter>.<instance> group <group-id>
                iobroker compact <adapter>.<instance> <disable|off>
                iobroker compact <adapter>.<instance> <enable|on> [group-id]
                iobroker version [adapter]
                iobroker [adapter] -v
                Optionen:
                  --help     Hilfe anzeigen  [boolean]
                  --version  Version anzeigen  [boolean]
                crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                • M Metzid
                  Commands:
                  iobroker start
                  iobroker stop
                  iobroker start all
                  iobroker restart
                  iobroker info
                  iobroker upload all
                  iobroker rm <file>
                  iobroker file sync
                  iobroker host this
                  iobroker clean
                  iobroker backup
                  iobroker uuid
                  iobroker unsetup
                  Optionen:
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @metzid setz das in code tags </>
                    /opt/iobroker
                    Z.b. admin
                    Metzid
                    @crunchip muss ich für die Prozedur den iobroker beenden. Muss mir erst noch eine neue sd erstellen. Gibt es eine Anleitung wie die code tags hesetzt werden. Bin nicht oft in Foren unterwegs
                    crunchipC HomoranH 2 Antworten Letzte Antwort
                    • M Metzid
                      Commands:
                      iobroker start
                      iobroker stop
                      iobroker start all
                      iobroker restart
                      iobroker info
                      iobroker upload all
                      iobroker rm <file>
                      iobroker file sync
                      iobroker host this
                      iobroker clean
                      iobroker backup
                      iobroker uuid
                      iobroker unsetup
                      Optionen:
                      @metzid
                      Du musst es mit dem vollen Pfad aus meiner Signatur aufrufen. Die Kurzform iob diag funktioniert nur mit aktuellen Versionen.
                      • M Metzid
                        crunchipC Abwesend
                        crunchipC Abwesend
                        Du klickst das zeichen über deinen editor an und kopierst deinen text da rein
                          Metzid
                          Ich habe jetzt doch mal über die Neuinstallation das iobroker fix laufen gelassen und dann iobroker start. Plötzlich war die Webseite wieder da und fie konfiguration zurückgespielt. Klasse!!!!!
                          Wie gehe ich jetzt weiter vor die Adapter und der iobroker haben ja jetzt das alte Treiberversionen und die Datenbank ist auf file file.
                          Einfach das Betriebssystem updaten und dann auch den iobroker und die prozedur spielt die neuen Versionen ein und stellt fann auch in dem Zug die die Datenbank auf das mormale Format um
                          • M Metzid
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @metzid jetzt komm ich grad nicht ganz mit, der neue mit dem backup läuft jetzt?
                              Metzid
                              @crunchip ja der neue läuft jetzt. Alle adapter haben jetzt die alte Release Version drauf. Nur der js controller ist stat der alten version 2.1... die neue version 3.3.... Drauf
                              • M Metzid
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @metzid und was klappt jetzt nicht bzw was ist nun das Problem?
                                  Metzid
                                  @crunchip ia ich wollte halt fragen wie ich am besten jetzt auf die neusten adapterversionen und Betriebsysteme update. Ich würde es so machen im iobroker die Adapter über das ui updaten dann das Betriebsystem über putty updaten zum Schluss den iobroker über putti updaten dann Backup von der sd karte dann bachup über das ui von iobroker. Wäre das so ok
                                  • M Metzid
                                      crunchipC Abwesend
                                      @metzid was möchtest du jetzt im neuen updaten, ich dachte es geht um den alten hochziehen so weit es geht, damit ein funktionierendes backup erstellt werden kann.
                                        Metzid
                                        @crunchip Hallo anbei möchte ich zusammenfassen wie ich mit eurer Hilfe die alte Raspberry Jessi Version auf das neue Bullseye Version gebracht habe.
                                        Anzumerken sei:
                                        Altsystem ist ein Raspberry 3B mit Jessie
                                        Neusystem ist auch ein Raspberry 3B mit Bullseye
                                        Hier nochmal die Versionsstände der beiden Systeme
                                        • Plattform: linux
                                        • CPUs: 4
                                        • RAM: 923.3 MB
                                        • Node.js: v10.18.0
                                        • NPM: 6.13.4
                                        • Plattform: linux
                                        • CPUs: 4
                                        • RAM: 909.6 MB
                                        • Node.js: v18.16.0
                                        • timeOffset: -60
                                        • NPM: v9.5.1
                                        • aktiv:
                                        Leider konnte das Altsystem nicht mehr auf den neusten Stand gebracht werden. Unabhängig ob ich versucht habe am Betriebssystem ein update durchzuführen oder am Iobroker das führte immer dazu das der Iobroker nicht mehr gestartet ist.
                                        Hier will ich stichpunktartig aufzeigen die ich mit eurer Hilfe doch noch zu Erfolg kam.
                                        Hier die Übersicht was ausgeführt wurde
                                        Backitup Adapter konnte auf dem alten System nicht installiert werden Fehlermeldung JS-Controller Note-JS veraltet
                                        Das Backup auf der Betriebsystemebene (iobroker backup) hatte jedoch funktioniert
                                        Kopieren des Backupfiles auf das Neusystem über filezilla. Auf dem Neusystem hatte ich schon mal nach der Installation über den dort laufenden Backitup Adapter eine backup erstellt. Die beiden Backup Files konnte man leicht unterscheiden weil das iobroker backup und das Backitup backup File unterschiedlich Namenskonventionen hatte
                                        Der Restore des iobrokers dauerte recht lange es wurde jedoch recht schnell eine erfolgreich Meldung gebracht jedoch habe ich gemerkt das das System jetzt die Adapterversionen vom Altsystem wohl über das internet downgegradet hat. Somit stand ich schon wieder im Grunde vor einem Altsystem zwar jetzt mit bullseye aber vor eine alte iobroker Gesamtversion
                                        Dann habe ich den Vorschlag crunchip ausgeführt die Datenbank über den Befehl (iobrover setup custom) auf file/file umzustellen laut Aussage von crunchip jsonl in früheren Versionen noch nicht gab.
                                        Leider ließ sich danach der iobroker noch immer nicht starten erst der Vorschlag iobroker fix auf der Konsole auszuführen führte dazu das der js-controller auf Version 3.xxx oder 4.xxx umgestellt wurde genaue Version weiß ich leider nicht mehr.
                                        Jetzt ließ sich der iobroker wieder starten und nach dem manuellen update aller Adapter über die iobroker Admin web Oberfläche konnte der Iobroker auf den neusten Stand gebracht werden.
                                        Mit dem neunen Szenen Adapter hatte ich zwar durch die neue Oberfläche und wohl gegenüber dir alten Versionen einige Fehlfunktionen aber das konnte ich dann auch wieder auf die Reihe bringen.
                                        Vielen Dank an alle für eure kompetente Hilfe
                                        Der Request kann als gelöst geschlossen werden nochmal danke!!!!
                                        • M Metzid
                                          Anzumerken sei:
                                          • Plattform: linux
                                          • CPUs: 4
                                          • RAM: 923.3 MB
                                          • Node.js: v10.18.0
                                          • NPM: 6.13.4
                                          • Plattform: linux
                                          • CPUs: 4
                                          • RAM: 909.6 MB
                                          • Node.js: v18.16.0
                                          • timeOffset: -60
                                          • NPM: v9.5.1
                                          • aktiv:
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          Das musst du selbst, indem du deinen ersten Beitrag editierst und ein [gelöst] davor setzt.
                                          Schön das es wieder läuft.
                                          Für die Zukunft merken...mit Updates, System auf Stand halten und ebenfalls regelmäßig backups...nicht geizen, spart ne Menge Kummer und Zeit.
