  4. ESPHome: Reinstallation aber wie?
esp32esphomem5stack
137 Beiträge 8 Kommentatoren 23.1k Aufrufe 7 Beobachtet
  • S smarthome2020
    Folgendes wird mir da dann ausgegeben:
    total 2656
    drwxrwxr-x+ 3 iobroker iobroker    4096 Apr 22 12:38 .
    drwxrwxr-x+ 4 iobroker iobroker    4096 Apr 22 12:38 ..
    -rwxrwxr-x+ 1 iobroker iobroker    7536 Apr 22 12:38 api.js
    -rwxrwxr-x+ 1 iobroker iobroker 2680354 Apr 22 12:39 get-pip.py
    -rwxrwxr-x+ 1 iobroker iobroker     530 Apr 22 12:38 nopenv.js
    -rwxrwxr-x+ 1 iobroker iobroker     397 Apr 22 12:38 nopy.js
    -rwxrwxr-x+ 1 iobroker iobroker    3091 Apr 22 12:38 npip.js
    drwxrwxr-x+ 2 iobroker iobroker    4096 Apr 22 12:39 test
    -rwxrwxr-x+ 1 iobroker iobroker     822 Apr 22 12:38 utils.js
    #111
    @smarthome2020
    Installier den Adapter nochmal neu.
    • S smarthome2020
      total 2656
      #112
      @smarthome2020
      Und dann zeig mal einen Start des Adapters. Schaut bei mir so aus:
      2023-04-23 14:57:21.204  - info: host.chet instance system.adapter.esphome.0 started with pid 1244918
      2023-04-23 14:57:24.024  - info: esphome.0 (1244918) starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.esphome, node: v18.16.0, js-controller: 5.0.1-alpha.0-20230418-efa3e809
      2023-04-23 14:57:24.135  - info: esphome.0 (1244918) Auto Discovery startet, new devices (or IP changes) will be detected automatically
      2023-04-23 14:57:24.144  - info: esphome.0 (1244918) Native Integration of ESPHome Dashboard enabled
      2023-04-23 14:57:26.512  - info: esphome.0 (1244918) [ESPHome - Console] 2023-04-23 14:57:26,511 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir /opt/iobroker/iobroker-data/esphome.0...
        @smarthome2020
        smarthome2020
        #113
        Ich kann ihn nun gar nicht mehr installieren:
        $ iobroker add esphome --host raspberrypi
        NPM version: 9.5.1
        Installing iobroker.esphome@0.2.4... (System call)
        host.raspberrypi Cannot install iobroker.esphome@0.2.4: 1
        ERROR: Process exited with code 25
        • S smarthome2020
          NPM version: 9.5.1
          #114
          @smarthome2020 sagte in ESPHome: Reinstallation aber wie?:
          iobroker add esphome --host raspberrypi --debug
            smarthome2020
            #115
            npm ERR! code 1
            npm ERR! path /opt/iobroker/node_modules/iobroker.esphome
            npm ERR! command failed
            npm ERR! command sh -c npip install
            npm ERR! No python_modules directory; installing pip locally if needed.
            npm ERR! Successfully completed pip check.
            npm ERR! Collecting esphome>=2021.8
            npm ERR!   Using cached esphome-2023.4.0-py2.py3-none-any.whl (2.6 MB)
            npm ERR! Collecting tornado>=3.2
            npm ERR!   Using cached tornado-6.3.1.tar.gz (508 kB)
            npm ERR!   Installing build dependencies: started
            npm ERR!   Installing build dependencies: finished with status 'done'
            npm ERR!   Getting requirements to build wheel: started
            npm ERR!   Getting requirements to build wheel: finished with status 'done'
            npm ERR!   Preparing metadata (pyproject.toml): started
            npm ERR!   Preparing metadata (pyproject.toml): finished with status 'done'
            npm ERR! Collecting voluptuous==0.13.1 (from esphome>=2021.8)
            npm ERR!   Using cached voluptuous-0.13.1-py3-none-any.whl (29 kB)
            npm ERR! Collecting PyYAML==6.0 (from esphome>=2021.8)
            npm ERR!   Using cached PyYAML-6.0.tar.gz (124 kB)
            npm ERR! Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)
            npm ERR!   Using cached paho-mqtt-1.6.1.tar.gz (99 kB)
            npm ERR!   Preparing metadata (setup.py): started
            npm ERR!   Preparing metadata (setup.py): finished with status 'done'
            npm ERR! Collecting colorama==0.4.6 (from esphome>=2021.8)
            npm ERR!   Using cached colorama-0.4.6-py2.py3-none-any.whl (25 kB)
            npm ERR!   Using cached tornado-6.2.tar.gz (504 kB)
            npm ERR! Collecting tzlocal==4.2 (from esphome>=2021.8)
            npm ERR!   Using cached tzlocal-4.2-py3-none-any.whl (19 kB)
            npm ERR! Collecting tzdata>=2021.1 (from esphome>=2021.8)
            npm ERR!   Using cached tzdata-2023.3-py2.py3-none-any.whl (341 kB)
            npm ERR! Collecting pyserial==3.5 (from esphome>=2021.8)
            npm ERR!   Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
            npm ERR! Collecting platformio==6.1.6 (from esphome>=2021.8)
            npm ERR!   Using cached platformio-6.1.6.tar.gz (236 kB)
            npm ERR! Collecting esptool==4.5.1 (from esphome>=2021.8)
            npm ERR!   Using cached esptool-4.5.1.tar.gz (252 kB)
            npm ERR! Collecting click==8.1.3 (from esphome>=2021.8)
            npm ERR!   Using cached click-8.1.3-py3-none-any.whl (96 kB)
            npm ERR! Collecting esphome-dashboard==20230214.0 (from esphome>=2021.8)
            npm ERR!   Using cached esphome_dashboard-20230214.0-py3-none-any.whl (1.6 MB)
            npm ERR! Collecting aioesphomeapi==13.5.1 (from esphome>=2021.8)
            npm ERR!   Using cached aioesphomeapi-13.5.1-py2.py3-none-any.whl (54 kB)
            npm ERR! Collecting zeroconf==0.56.0 (from esphome>=2021.8)
            npm ERR!   Using cached zeroconf-0.56.0.tar.gz (140 kB)
            npm ERR! Collecting kconfiglib==13.7.1 (from esphome>=2021.8)
            npm ERR!   Using cached kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
            npm ERR! Collecting protobuf>=3.19.0 (from aioesphomeapi==13.5.1->esphome>=2021.8)
            npm ERR!   Using cached protobuf-4.22.3-py3-none-any.whl (172 kB)
            npm ERR! Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==13.5.1->esphome>=2021.8)
            npm ERR!   Using cached noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
            npm ERR! Collecting async-timeout>=4.0 (from aioesphomeapi==13.5.1->esphome>=2021.8)
            npm ERR!   Using cached async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
            npm ERR! Collecting bitstring>=3.1.6 (from esptool==4.5.1->esphome>=2021.8)
            npm ERR!   Using cached bitstring-4.0.2-py3-none-any.whl (46 kB)
            npm ERR! Collecting cryptography>=2.1.4 (from esptool==4.5.1->esphome>=2021.8)
            npm ERR!   Using cached cryptography-40.0.2.tar.gz (625 kB)
            npm ERR!   Installing build dependencies: finished with status 'error'
            npm ERR! /usr/bin/python3: No module named pip
            npm ERR! /usr/bin/python3: No module named ensurepip
            npm ERR!   error: subprocess-exited-with-error
            npm ERR!
            npm ERR!   × pip subprocess to install build dependencies did not run successfully.
            npm ERR!   │ exit code: 1
            npm ERR!   ╰─> [81 lines of output]
            npm ERR!       Collecting setuptools!=60.9.0,>=40.6.0
            npm ERR!         Using cached setuptools-67.7.1-py3-none-any.whl (1.1 MB)
            npm ERR!       Collecting wheel
            npm ERR!         Using cached wheel-0.40.0-py3-none-any.whl (64 kB)
            npm ERR!       Collecting cffi>=1.12
            npm ERR!         Using cached cffi-1.15.1.tar.gz (508 kB)
            npm ERR!       Collecting setuptools-rust>=0.11.4
            npm ERR!         Using cached setuptools_rust-1.5.2-py3-none-any.whl (23 kB)
            npm ERR!       Collecting pycparser (from cffi>=1.12)
            npm ERR!         Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
            npm ERR!       Collecting semantic-version<3,>=2.8.2 (from setuptools-rust>=0.11.4)
            npm ERR!         Using cached semantic_version-2.10.0-py2.py3-none-any.whl (15 kB)
            npm ERR!       Collecting typing-extensions>=3.7.4.3 (from setuptools-rust>=0.11.4)
            npm ERR!         Using cached typing_extensions-4.5.0-py3-none-any.whl (27 kB)
            npm ERR!       Building wheels for collected packages: cffi
            npm ERR!         Building wheel for cffi (setup.py): started
            npm ERR!         Building wheel for cffi (setup.py): finished with status 'error'
            npm ERR!
            npm ERR!         × python setup.py bdist_wheel did not run successfully.
            npm ERR!         ╰─> [50 lines of output]
            npm ERR!             /opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.9/site-packages/setuptools/config/setupcfg.py:293: _DeprecatedConfig: Deprecated config in `setup.cfg`
            npm ERR!             !!
            npm ERR!
            npm ERR!                     ********************************************************************************
            npm ERR!                     The license_file parameter is deprecated, use license_files instead.
            npm ERR!
            npm ERR!                     By 2023-Oct-30, you need to update your project and remove deprecated calls
            npm ERR!                     or your builds will no longer be supported.
            npm ERR!
            npm ERR!                     See https://setuptools.pypa.io/en/latest/https://setuptools.pypa.io/en/latest/userguide/declarative_config.html for details.
            npm ERR!
            npm ERR!             !!
            npm ERR!               parsed = self.parsers.get(option_name, lambda x: x)(value)
            npm ERR!             running bdist_wheel
            npm ERR!             running build
            npm ERR!             running build_py
            npm ERR!             creating build
            npm ERR!             creating build/lib.linux-aarch64-cpython-39
            npm ERR!             creating build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/lock.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/cparser.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/verifier.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/vengine_gen.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/backend_ctypes.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/vengine_cpy.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/setuptools_ext.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/error.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/cffi_opcode.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/__init__.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/model.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/pkgconfig.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/recompiler.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/api.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/ffiplatform.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/commontypes.py -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/_cffi_include.h -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/parse_c_type.h -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/_embedding.h -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             copying cffi/_cffi_errors.h -> build/lib.linux-aarch64-cpython-39/cffi
            npm ERR!             running build_ext
            npm ERR!             building '_cffi_backend' extension
            npm ERR!             creating build/temp.linux-aarch64-cpython-39
            npm ERR!             creating build/temp.linux-aarch64-cpython-39/c
            npm ERR!             arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -DFFI_BUILDING=1 -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-aarch64-cpython-39/c/_cffi_backend.o
            npm ERR!             c/_cffi_backend.c:2:10: fatal error: Python.h: No such file or directory
            npm ERR!                 2 | #include <Python.h>
            npm ERR!                   |          ^~~~~~~~~~
            npm ERR!             compilation terminated.
            npm ERR!             error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
            npm ERR!             [end of output]
            npm ERR!
            npm ERR!         note: This error originates from a subprocess, and is likely not a problem with pip.
            npm ERR!         ERROR: Failed building wheel for cffi
            npm ERR!         Running setup.py clean for cffi
            npm ERR!       Failed to build cffi
            npm ERR!       ERROR: Could not build wheels for cffi, which is required to install pyproject.toml-based projects
            npm ERR!
            npm ERR!
            npm ERR! ╰─> See above for output.
            npm ERR!
            npm ERR!     /home/iobroker/.npm/_logs/2023-04-23T13_12_46_529Z-debug-0.log
            • S smarthome2020
              npm ERR! code 1
              npm ERR!
              npm ERR!
              npm ERR!             !!
              npm ERR!
              npm ERR!
              npm ERR!
              npm ERR!
              npm ERR!             !!
              npm ERR!
              npm ERR!
              npm ERR!
              npm ERR!
              #116
              @smarthome2020
              Da stimmt was mit der python-Installation noch nicht.
              find "/usr/lib" -name "EXTERNALLY-MANAGED"
                @smarthome2020
                smarthome2020
                #117
                auf den Befehl folgt bei mir gar nichts
                HomoranH Thomas BraunT 3 Antworten Letzte Antwort
                • S smarthome2020
                  HomoranH Offline
                  HomoranH Offline
                  #118
                  immer alles zeigen!
                  • S smarthome2020
                    #119
                    @smarthome2020
                    python --version
                    apt policy python3 build-essential python-is-python3
                      @smarthome2020
                      python --version
                      smarthome2020
                      #120
                      Ich kann dir die Ausgabe heute Abend zeigen. Muss nun zur Schwiegermutter . Nur Probleme heute 😂
                      • S smarthome2020
                        #121
                        @smarthome2020
                        cd /opt/iobroker
                        npm i nopy
                        sudo -u iobroker chmod ug+x /opt/iobroker/node_modules/nopy/src/n*
                        Dann nochmal eine übliche Installation des esphome versuchen.
                        Wenn der installiert wurde:
                        cd /opt/iobroker
                        npm uninstall nopy
                          @smarthome2020
                          cd /opt/iobroker
                          npm i nopy
                          cd /opt/iobroker
                          npm uninstall nopy
                          smarthome2020
                          #122
                          Ging leider auch nicht . Endet wieder mit einer Error 25.
                          Vielleicht muss ich auch den Weg über ein neu aufgesetztes linux gehen und das Backup ohne ESPHome einspielen.
                          • S smarthome2020
                            #123
                            Ich brauch immer die Langfassung. Error 25 sagt gar nix.
                              smarthome2020
                              #124
                              • S smarthome2020
                                #125
                                  smarthome2020
                                  #126
                                  pi@raspberrypi:~ $ iobroker add esphome --host raspberrypi --debug
                                  NPM version: 9.5.1
                                  npm ERR! code 1
                                  npm ERR!   Using cached esphome-2023.4.1-py2.py3-none-any.whl (2.6 MB)
                                  npm ERR!
                                  npm ERR!         Using cached setuptools-67.7.2-py3-none-any.whl (1.1 MB)
                                  npm ERR!
                                  npm ERR!             !!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!                     See https://setuptools.pypa.io/en/latest/userguide/declarative_config.html for details.
                                  npm ERR!
                                  npm ERR!             !!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!     /home/iobroker/.npm/_logs/2023-04-24T21_18_47_600Z-debug-0.log
                                  • S smarthome2020
                                    NPM version: 9.5.1
                                    npm ERR! code 1
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!             !!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!             !!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    #127
                                    Hast du python-3.9-dev installiert?
                                    python --version
                                    sudo apt update
                                    sudo apt install python3.9-dev
                                      python --version
                                      sudo apt update
                                      smarthome2020
                                      #128
                                      pi@raspberrypi:~ $ sudo apt update
                                      Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
                                      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                      Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                                      Fetched 15.0 kB in 1s (13.2 kB/s)
                                      Reading package lists... Done
                                      All packages are up to date.
                                      pi@raspberrypi:~ $ sudo apt install python3.9-dev
                                      The following additional packages will be installed:
                                        libpython3.9-dev
                                      The following NEW packages will be installed:
                                        libpython3.9-dev python3.9-dev
                                      0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                                      Need to get 3,556 kB of archives.
                                      After this operation, 14.5 MB of additional disk space will be used.
                                      Do you want to continue? [Y/n] y
                                      Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libpython3.9-dev armhf 3.9.2-1+rpi1 [3,055 kB]
                                      Get:2 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python3.9-dev armhf 3.9.2-1+rpi1 [501 kB]
                                      Fetched 3,556 kB in 1s (3,592 kB/s)
                                      Selecting previously unselected package libpython3.9-dev:armhf.
                                      (Reading database ... 56419 files and directories currently installed.)
                                      Preparing to unpack .../libpython3.9-dev_3.9.2-1+rpi1_armhf.deb ...
                                      Unpacking libpython3.9-dev:armhf (3.9.2-1+rpi1) ...
                                      Selecting previously unselected package python3.9-dev.
                                      Preparing to unpack .../python3.9-dev_3.9.2-1+rpi1_armhf.deb ...
                                      Unpacking python3.9-dev (3.9.2-1+rpi1) ...
                                      Setting up libpython3.9-dev:armhf (3.9.2-1+rpi1) ...
                                      Setting up python3.9-dev (3.9.2-1+rpi1) ...
                                      Processing triggers for man-db (2.9.4-2) ...
                                      NPM version: 9.5.1
                                      npm ERR! code 1
                                      npm ERR! Collecting ecdsa>=0.16.0 (from esptool==4.5.1->esphome>=2021.8)
                                      npm ERR!   Downloading ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
                                      npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 142.9/142.9 kB 427.0 kB/s eta 0:00:00
                                      npm ERR! Collecting reedsolo<=1.6.0,>=1.5.3 (from esptool==4.5.1->esphome>=2021.8)
                                      npm ERR!   Downloading reedsolo-1.6.0.tar.gz (278 kB)
                                      npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 278.6/278.6 kB 5.2 MB/s eta 0:00:00
                                      npm ERR! Collecting bottle==0.12.* (from platformio==6.1.6->esphome>=2021.8)
                                      npm ERR!   Downloading bottle-0.12.25-py3-none-any.whl (90 kB)
                                      npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 90.2/90.2 kB 3.7 MB/s eta 0:00:00
                                      npm ERR! Collecting marshmallow==3.* (from platformio==6.1.6->esphome>=2021.8)
                                      npm ERR!   Downloading marshmallow-3.19.0-py3-none-any.whl (49 kB)
                                      npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 49.1/49.1 kB 2.1 MB/s eta 0:00:00
                                      npm ERR! Collecting pyelftools<1,>=0.27 (from platformio==6.1.6->esphome>=2021.8)
                                      npm ERR!   Downloading pyelftools-0.29-py2.py3-none-any.whl (174 kB)
                                      npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 174.3/174.3 kB 5.1 MB/s eta 0:00:00
                                      npm ERR! Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==6.1.6->esphome>=2021.8) (2.25.1)
                                      npm ERR! Collecting semantic_version==2.10.* (from platformio==6.1.6->esphome>=2021.8)
                                      npm ERR! Collecting tabulate==0.9.* (from platformio==6.1.6->esphome>=2021.8)
                                      npm ERR!   Downloading tabulate-0.9.0-py3-none-any.whl (35 kB)
                                      npm ERR! Collecting aiofiles==22.1.* (from platformio==6.1.6->esphome>=2021.8)
                                      npm ERR!   Downloading aiofiles-22.1.0-py3-none-any.whl (14 kB)
                                      npm ERR! Collecting ajsonrpc==1.* (from platformio==6.1.6->esphome>=2021.8)
                                      npm ERR!   Downloading ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
                                      npm ERR! Collecting starlette==0.23.* (from platformio==6.1.6->esphome>=2021.8)
                                      npm ERR!   Downloading starlette-0.23.1-py3-none-any.whl (64 kB)
                                      npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 64.5/64.5 kB 3.6 MB/s eta 0:00:00
                                      npm ERR! Collecting uvicorn==0.20.* (from platformio==6.1.6->esphome>=2021.8)
                                      npm ERR!   Downloading uvicorn-0.20.0-py3-none-any.whl (56 kB)
                                      npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 56.9/56.9 kB 2.3 MB/s eta 0:00:00
                                      npm ERR! Collecting wsproto==1.2.* (from platformio==6.1.6->esphome>=2021.8)
                                      npm ERR!   Downloading wsproto-1.2.0-py3-none-any.whl (24 kB)
                                      npm ERR! Collecting pytz-deprecation-shim (from tzlocal==4.2->esphome>=2021.8)
                                      npm ERR!   Downloading pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
                                      npm ERR! Collecting ifaddr>=0.1.7 (from zeroconf==0.56.0->esphome>=2021.8)
                                      npm ERR!   Downloading ifaddr-0.2.0-py3-none-any.whl (12 kB)
                                      npm ERR! Collecting packaging>=17.0 (from marshmallow==3.*->platformio==6.1.6->esphome>=2021.8)
                                      npm ERR!   Downloading packaging-23.1-py3-none-any.whl (48 kB)
                                      npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 48.9/48.9 kB 2.9 MB/s eta 0:00:00
                                      npm ERR! Collecting anyio<5,>=3.4.0 (from starlette==0.23.*->platformio==6.1.6->esphome>=2021.8)
                                      npm ERR!   Downloading anyio-3.6.2-py3-none-any.whl (80 kB)
                                      npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 80.6/80.6 kB 4.2 MB/s eta 0:00:00
                                      npm ERR! Collecting typing-extensions>=3.10.0 (from starlette==0.23.*->platformio==6.1.6->esphome>=2021.8)
                                      npm ERR! Collecting h11>=0.8 (from uvicorn==0.20.*->platformio==6.1.6->esphome>=2021.8)
                                      npm ERR!   Downloading h11-0.14.0-py3-none-any.whl (58 kB)
                                      npm ERR!      ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 58.3/58.3 kB 3.1 MB/s eta 0:00:00
                                      npm ERR! Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==4.5.1->esphome>=2021.8)
                                      npm ERR! Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==4.5.1->esphome>=2021.8) (1.16.0)
                                      npm ERR! Requirement already satisfied: idna>=2.8 in /usr/lib/python3/dist-packages (from anyio<5,>=3.4.0->starlette==0.23.*->platformio==6.1.6->esphome>=2021.8) (2.10)
                                      npm ERR! Collecting sniffio>=1.1 (from anyio<5,>=3.4.0->starlette==0.23.*->platformio==6.1.6->esphome>=2021.8)
                                      npm ERR!   Downloading sniffio-1.3.0-py3-none-any.whl (10 kB)
                                      npm ERR! Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==4.5.1->esphome>=2021.8)
                                      npm ERR! Building wheels for collected packages: tornado, esptool, paho-mqtt, platformio, PyYAML, zeroconf, cryptography, reedsolo, cffi
                                      npm ERR!   Building wheel for tornado (pyproject.toml): started
                                      npm ERR!   Building wheel for tornado (pyproject.toml): finished with status 'done'
                                      npm ERR!   Created wheel for tornado: filename=tornado-6.2-cp37-abi3-linux_aarch64.whl size=422461 sha256=aeb1d1960da0fb3afc4c4c1ebfeeef00387f601ca5fd7dc2842c213ab5a20aae
                                      npm ERR!   Stored in directory: /home/iobroker/.cache/pip/wheels/90/7b/73/1df52e0a3fb1604361eb56c578af8de175b5f5262c626762f7
                                      npm ERR!   Building wheel for esptool (setup.py): started
                                      npm ERR!   Building wheel for esptool (setup.py): finished with status 'done'
                                      npm ERR!   Created wheel for esptool: filename=esptool-4.5.1-py3-none-any.whl size=320921 sha256=6a88b547e2ae0117edbd299c3d8cde05f65def500fd1165f0225f9907bc9d038
                                      npm ERR!   Stored in directory: /home/iobroker/.cache/pip/wheels/78/54/f8/0507bb484d688824cea726ae932d3f8339a1ccd039612d3b7e
                                      npm ERR!   Building wheel for paho-mqtt (setup.py): started
                                      npm ERR!   Building wheel for paho-mqtt (setup.py): finished with status 'done'
                                      npm ERR!   Created wheel for paho-mqtt: filename=paho_mqtt-1.6.1-py3-none-any.whl size=62118 sha256=f80ab02eaea54f89a42c38014b49c4d0b7f55043a8d9da7cae59be86305aeda8
                                      npm ERR!   Stored in directory: /home/iobroker/.cache/pip/wheels/0f/90/29/db29bb8ddc98ec5f2363b959130c9ddbcf5cfdb4a00b6184dd
                                      npm ERR!   Building wheel for platformio (setup.py): started
                                      npm ERR!   Building wheel for platformio (setup.py): finished with status 'done'
                                      npm ERR!   Created wheel for platformio: filename=platformio-6.1.6-py3-none-any.whl size=416715 sha256=32ecef86ff72e883a3c38d0dc71d415a8869dc115435ca42fe722616d265f948
                                      npm ERR!   Stored in directory: /home/iobroker/.cache/pip/wheels/1e/91/74/6e84ce10899b29c1c504acc5399a1f0828f531c069fa4914cc
                                      npm ERR!   Building wheel for PyYAML (pyproject.toml): started
                                      npm ERR!   Building wheel for PyYAML (pyproject.toml): finished with status 'done'
                                      npm ERR!   Created wheel for PyYAML: filename=PyYAML-6.0-cp39-cp39-linux_aarch64.whl size=45333 sha256=65d75f3e2112561ab7fc09cab32a98719197464e8c673d3550f97544bdeff626
                                      npm ERR!   Stored in directory: /home/iobroker/.cache/pip/wheels/b4/0f/9a/d6af48581dda678920fccfb734f5d9f827c6ed5b4074c7eda8
                                      npm ERR!   Building wheel for zeroconf (pyproject.toml): started
                                      npm ERR!   Building wheel for zeroconf (pyproject.toml): still running...
                                      npm ERR!   Building wheel for zeroconf (pyproject.toml): finished with status 'done'
                                      npm ERR!   Created wheel for zeroconf: filename=zeroconf-0.56.0-cp39-cp39-manylinux_2_31_armv7l.whl size=2101325 sha256=118fd225fe23a463591d45c4775dad4fbd6da8c11da62b506e675b358ceb1572
                                      npm ERR!   Stored in directory: /home/iobroker/.cache/pip/wheels/72/ac/bd/e36f8455a390cd9cbb284caf9f3ae3b8048c75380a37f4945e
                                      npm ERR!   Building wheel for cryptography (pyproject.toml): started
                                      npm ERR!   Building wheel for cryptography (pyproject.toml): finished with status 'error'
                                      npm ERR!   Building wheel for reedsolo (setup.py): started
                                      npm ERR!   Building wheel for reedsolo (setup.py): finished with status 'done'
                                      npm ERR!   Created wheel for reedsolo: filename=reedsolo-1.6.0-py3-none-any.whl size=31053 sha256=8f5d7a542cb368189268c4dc92c3137fd09bbda4857fe35f059090ee1170e5a4
                                      npm ERR!   Stored in directory: /home/iobroker/.cache/pip/wheels/0a/69/f4/ff4c4b80781195a115015f14b39ba1e708ef6a77a0fd5187fb
                                      npm ERR!   Building wheel for cffi (setup.py): finished with status 'done'
                                      npm ERR!   Created wheel for cffi: filename=cffi-1.15.1-cp39-cp39-linux_aarch64.whl size=364680 sha256=491068733de3ca0619733c0a2d64f46ee760a8cb7c235f0ebdcfbd219b839024
                                      npm ERR!   Stored in directory: /home/iobroker/.cache/pip/wheels/d0/6e/69/346a0fb73c6a05221ee65cf8d51e67742e36c57aa5b8c7c5ed
                                      npm ERR! Successfully built tornado esptool paho-mqtt platformio PyYAML zeroconf reedsolo cffi
                                      npm ERR! Failed to build cryptography
                                      npm ERR!
                                      npm ERR!   × Building wheel for cryptography (pyproject.toml) did not run successfully.
                                      npm ERR!   ╰─> [247 lines of output]
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography
                                      npm ERR!       copying src/cryptography/exceptions.py -> build/lib.linux-aarch64-cpython-39/cryptography
                                      npm ERR!       copying src/cryptography/__init__.py -> build/lib.linux-aarch64-cpython-39/cryptography
                                      npm ERR!       copying src/cryptography/fernet.py -> build/lib.linux-aarch64-cpython-39/cryptography
                                      npm ERR!       copying src/cryptography/__about__.py -> build/lib.linux-aarch64-cpython-39/cryptography
                                      npm ERR!       copying src/cryptography/utils.py -> build/lib.linux-aarch64-cpython-39/cryptography
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography/hazmat
                                      npm ERR!       copying src/cryptography/hazmat/__init__.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat
                                      npm ERR!       copying src/cryptography/hazmat/_oid.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography/x509
                                      npm ERR!       copying src/cryptography/x509/extensions.py -> build/lib.linux-aarch64-cpython-39/cryptography/x509
                                      npm ERR!       copying src/cryptography/x509/ocsp.py -> build/lib.linux-aarch64-cpython-39/cryptography/x509
                                      npm ERR!       copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-aarch64-cpython-39/cryptography/x509
                                      npm ERR!       copying src/cryptography/x509/general_name.py -> build/lib.linux-aarch64-cpython-39/cryptography/x509
                                      npm ERR!       copying src/cryptography/x509/__init__.py -> build/lib.linux-aarch64-cpython-39/cryptography/x509
                                      npm ERR!       copying src/cryptography/x509/base.py -> build/lib.linux-aarch64-cpython-39/cryptography/x509
                                      npm ERR!       copying src/cryptography/x509/oid.py -> build/lib.linux-aarch64-cpython-39/cryptography/x509
                                      npm ERR!       copying src/cryptography/x509/name.py -> build/lib.linux-aarch64-cpython-39/cryptography/x509
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends
                                      npm ERR!       copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives
                                      npm ERR!       copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives
                                      npm ERR!       copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives
                                      npm ERR!       copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives
                                      npm ERR!       copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives
                                      npm ERR!       copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives
                                      npm ERR!       copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives
                                      npm ERR!       copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives
                                      npm ERR!       copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives
                                      npm ERR!       copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives
                                      npm ERR!       copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives
                                      npm ERR!       copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings
                                      npm ERR!       copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/backends/openssl
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/asymmetric
                                      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/asymmetric
                                      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/asymmetric
                                      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/asymmetric
                                      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/asymmetric
                                      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/asymmetric
                                      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/asymmetric
                                      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/asymmetric
                                      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/asymmetric
                                      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/asymmetric
                                      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/asymmetric
                                      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/asymmetric
                                      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/asymmetric
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/twofactor
                                      npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/twofactor
                                      npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/twofactor
                                      npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/twofactor
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/serialization
                                      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/serialization
                                      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/serialization
                                      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/serialization
                                      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/serialization
                                      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/serialization
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/ciphers
                                      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/ciphers
                                      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/ciphers
                                      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/ciphers
                                      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/ciphers
                                      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/ciphers
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/kdf
                                      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/kdf
                                      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/kdf
                                      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/kdf
                                      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/kdf
                                      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/kdf
                                      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/kdf
                                      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/primitives/kdf
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings/openssl
                                      npm ERR!       copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings/openssl
                                      npm ERR!       copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings/openssl
                                      npm ERR!       copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings/openssl
                                      npm ERR!       running egg_info
                                      npm ERR!       writing src/cryptography.egg-info/PKG-INFO
                                      npm ERR!       writing dependency_links to src/cryptography.egg-info/dependency_links.txt
                                      npm ERR!       writing requirements to src/cryptography.egg-info/requires.txt
                                      npm ERR!       writing top-level names to src/cryptography.egg-info/top_level.txt
                                      npm ERR!       reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
                                      npm ERR!       reading manifest template 'MANIFEST.in'
                                      npm ERR!       no previously-included directories found matching 'docs/_build'
                                      npm ERR!       warning: no previously-included files found matching 'vectors'
                                      npm ERR!       warning: no previously-included files matching '*' found under directory 'vectors'
                                      npm ERR!       warning: no previously-included files matching '*' found under directory '.github'
                                      npm ERR!       warning: no previously-included files found matching 'release.py'
                                      npm ERR!       warning: no previously-included files found matching '.readthedocs.yml'
                                      npm ERR!       warning: no previously-included files found matching 'ci-constraints-requirements.txt'
                                      npm ERR!       warning: no previously-included files found matching 'mypy.ini'
                                      npm ERR!       adding license file 'LICENSE'
                                      npm ERR!       adding license file 'LICENSE.APACHE'
                                      npm ERR!       adding license file 'LICENSE.BSD'
                                      npm ERR!       adding license file 'LICENSE.PSF'
                                      npm ERR!       writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
                                      npm ERR!       /tmp/pip-build-env-vl9y10zd/overlay/lib/python3.9/site-packages/setuptools/command/build_py.py:201: _Warning: Package 'cryptography.hazmat.bindings._rust' is absent from the `packages` configuration.
                                      npm ERR!       !!
                                      npm ERR!
                                      npm ERR!               ############################
                                      npm ERR!               # Package would be ignored #
                                      npm ERR!               Python recognizes 'cryptography.hazmat.bindings._rust' as an importable package[^1],
                                      npm ERR!               but it is absent from setuptools' `packages` configuration.
                                      npm ERR!
                                      npm ERR!               This leads to an ambiguous overall configuration. If you want to distribute this
                                      npm ERR!               package, please make sure that 'cryptography.hazmat.bindings._rust' is explicitly added
                                      npm ERR!               to the `packages` configuration field.
                                      npm ERR!
                                      npm ERR!               Alternatively, you can also rely on setuptools' discovery methods
                                      npm ERR!               (for example by using `find_namespace_packages(...)`/`find_namespace:`
                                      npm ERR!               instead of `find_packages(...)`/`find:`).
                                      npm ERR!
                                      npm ERR!               You can read more about "package discovery" on setuptools documentation page:
                                      npm ERR!
                                      npm ERR!               - https://setuptools.pypa.io/en/latest/userguide/package_discovery.html
                                      npm ERR!
                                      npm ERR!               If you don't want 'cryptography.hazmat.bindings._rust' to be distributed and are
                                      npm ERR!               already explicitly excluding 'cryptography.hazmat.bindings._rust' via
                                      npm ERR!               `find_namespace_packages(...)/find_namespace` or `find_packages(...)/find`,
                                      npm ERR!               you can try to use `exclude_package_data`, or `include-package-data=False` in
                                      npm ERR!               combination with a more fine grained `package-data` configuration.
                                      npm ERR!
                                      npm ERR!               You can read more about "package data files" on setuptools documentation page:
                                      npm ERR!
                                      npm ERR!               - https://setuptools.pypa.io/en/latest/userguide/datafiles.html
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!               [^1]: For Python, any directory (with suitable naming) can be imported,
                                      npm ERR!                     even if it does not contain any `.py` files.
                                      npm ERR!                     On the other hand, currently there is no concept of package data
                                      npm ERR!                     directory, all directories are treated like packages.
                                      npm ERR!
                                      npm ERR!       !!
                                      npm ERR!         check.warn(importable)
                                      npm ERR!       /tmp/pip-build-env-vl9y10zd/overlay/lib/python3.9/site-packages/setuptools/command/build_py.py:201: _Warning: Package 'cryptography.hazmat.bindings._rust.openssl' is absent from the `packages` configuration.
                                      npm ERR!       !!
                                      npm ERR!
                                      npm ERR!               Python recognizes 'cryptography.hazmat.bindings._rust.openssl' as an importable package[^1],
                                      npm ERR!
                                      npm ERR!               package, please make sure that 'cryptography.hazmat.bindings._rust.openssl' is explicitly added
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!               If you don't want 'cryptography.hazmat.bindings._rust.openssl' to be distributed and are
                                      npm ERR!               already explicitly excluding 'cryptography.hazmat.bindings._rust.openssl' via
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!       !!
                                      npm ERR!       copying src/cryptography/py.typed -> build/lib.linux-aarch64-cpython-39/cryptography
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings/_rust
                                      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings/_rust
                                      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/_openssl.pyi -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings/_rust
                                      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings/_rust
                                      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings/_rust
                                      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings/_rust
                                      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings/_rust
                                      npm ERR!       creating build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/__init__.pyi -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x25519.pyi -> build/lib.linux-aarch64-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                      npm ERR!       running build_rust
                                      npm ERR!
                                      npm ERR!           =============================DEBUG ASSISTANCE=============================
                                      npm ERR!           If you are seeing a compilation error please try the following steps to
                                      npm ERR!           successfully install cryptography:
                                      npm ERR!           1) Upgrade to the latest pip and try again. This will fix errors for most
                                      npm ERR!              users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
                                      npm ERR!           2) Read https://cryptography.io/en/latest/installation/ for specific
                                      npm ERR!              instructions for your platform.
                                      npm ERR!           3) Check our frequently asked questions for more information:
                                      npm ERR!              https://cryptography.io/en/latest/faq/
                                      npm ERR!           4) Ensure you have a recent Rust toolchain installed:
                                      npm ERR!              https://cryptography.io/en/latest/installation/#rust
                                      npm ERR!
                                      npm ERR!           Python: 3.9.2
                                      npm ERR!           platform: Linux-6.1.21-v8+-aarch64-with-glibc2.31
                                      npm ERR!           pip: n/a
                                      npm ERR!           setuptools: 67.7.2
                                      npm ERR!           setuptools_rust: 1.5.2
                                      npm ERR!           rustc: n/a
                                      npm ERR!
                                      npm ERR!       error: can't find Rust compiler
                                      npm ERR!
                                      npm ERR!       If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
                                      npm ERR!
                                      npm ERR!       To update pip, run:
                                      npm ERR!
                                      npm ERR!           pip install --upgrade pip
                                      npm ERR!
                                      npm ERR!       and then retry package installation.
                                      npm ERR!
                                      npm ERR!       If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
                                      npm ERR!
                                      npm ERR!       This package requires Rust >=1.48.0.
                                      npm ERR!
                                      npm ERR!   ERROR: Failed building wheel for cryptography
                                      npm ERR! ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
                                      npm ERR!     /home/iobroker/.npm/_logs/2023-04-24T21_30_35_350Z-debug-0.log
                                      • S smarthome2020
                                          libpython3.9-dev
                                        NPM version: 9.5.1
                                        npm ERR! code 1
                                        npm ERR!
                                        npm ERR!       !!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!       !!
                                        npm ERR!       !!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!       !!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!           pip: n/a
                                        npm ERR!           rustc: n/a
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!
                                        #129
                                        sudo apt install build-essential libssl-dev libffi-dev python3-dev cargo pkg-config
                                        If you are on RHEL/CentOS/Fedora/Debian/Ubuntu or another distribution derived from the preceding list, then you should upgrade pip and attempt to install cryptography again before following the instructions to compile it below. These platforms will receive a binary wheel and require no compiler if you have an updated pip!
                                        The Rust available in most Debian versions is older than the minimum supported version. Debian Bookworm is sufficiently new
                                        Möglich das dein pip bzw. Rust zu alt ist. Bei mir läuft Debian Unstable / Bookworm, das ist aktuell.
                                          smarthome2020
                                          #130
                                          pi@raspberrypi:~ $ sudo apt install build-essential libssl-dev libffi-dev python3-dev cargo pkg-config
                                          build-essential is already the newest version (12.9).
                                          libffi-dev is already the newest version (3.3-6).
                                          libffi-dev set to manually installed.
                                          pkg-config is already the newest version (0.29.2-1).
                                            javascript-common libgit2-1.1 libhttp-parser2.9 libjs-jquery
                                            libjs-sphinxdoc libjs-underscore libllvm11 libmbedcrypto3 libmbedtls12
                                            libmbedx509-0 libpython3-dev libstd-rust-1.48 libstd-rust-dev libz3-4
                                            rust-gdb rustc
                                          Suggested packages:
                                            cargo-doc apache2 | lighttpd | httpd libssl-doc gdb-doc rust-doc rust-src
                                            lld-11
                                          Recommended packages:
                                            cargo
                                            cargo javascript-common libgit2-1.1 libhttp-parser2.9 libjs-jquery
                                            libmbedx509-0 libpython3-dev libssl-dev libstd-rust-1.48 libstd-rust-dev
                                            libz3-4 python3-dev rust-gdb rustc
                                          0 upgraded, 19 newly installed, 0 to remove and 0 not upgraded.
                                          Need to get 73.3 MB of archives.
                                          After this operation, 312 MB of additional disk space will be used.
                                          Err:1 http://archive.raspberrypi.org/debian bullseye/main armhf libssl-dev armhf 1.1.1n-0+deb11u4+rpt1
                                            Temporary failure resolving 'archive.raspberrypi.org'
                                          Err:2 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libhttp-parser2.9 armhf 2.9.4-4+deb11u1
                                            Temporary failure resolving 'raspbian.raspberrypi.org'
                                          Err:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libmbedcrypto3 armhf 2.16.9-0.1
                                          Err:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libmbedx509-0 armhf 2.16.9-0.1
                                          Err:5 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libmbedtls12 armhf 2.16.9-0.1
                                          Err:6 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libgit2-1.1 armhf 1.1.0+dfsg.1-4
                                          Err:7 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libz3-4 armhf 4.8.10-1
                                          Err:8 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libllvm11 armhf 1:11.0.1-2+rpi1
                                          Err:9 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libstd-rust-1.48 armhf 1.48.0+dfsg1-1+rpi1
                                          Err:10 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libstd-rust-dev armhf 1.48.0+dfsg1-1+rpi1
                                          Err:11 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf rustc armhf 1.48.0+dfsg1-1+rpi1
                                          Err:12 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf cargo armhf 0.47.0-3
                                          Err:13 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf javascript-common all 11+nmu1
                                          Err:14 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libjs-jquery all 3.5.1+dfsg+~3.5.5-7
                                          Err:15 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libjs-underscore all 1.9.1~dfsg-3
                                          Err:16 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libjs-sphinxdoc all 3.4.3-2
                                          Err:17 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libpython3-dev armhf 3.9.2-3
                                          Err:18 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python3-dev armhf 3.9.2-3
                                          Err:19 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf rust-gdb all 1.48.0+dfsg1-1+rpi1
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/h/http-parser/libhttp-parser2.9_2.9.4-4%2bdeb11u1_armhf.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/m/mbedtls/libmbedcrypto3_2.16.9-0.1_armhf.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/m/mbedtls/libmbedx509-0_2.16.9-0.1_armhf.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/m/mbedtls/libmbedtls12_2.16.9-0.1_armhf.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/libg/libgit2/libgit2-1.1_1.1.0%2bdfsg.1-4_armhf.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/z/z3/libz3-4_4.8.10-1_armhf.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/l/llvm-toolchain-11/libllvm11_11.0.1-2%2brpi1_armhf.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/r/rustc/libstd-rust-1.48_1.48.0%2bdfsg1-1%2brpi1_armhf.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/r/rustc/libstd-rust-dev_1.48.0%2bdfsg1-1%2brpi1_armhf.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/r/rustc/rustc_1.48.0%2bdfsg1-1%2brpi1_armhf.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/c/cargo/cargo_0.47.0-3_armhf.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/j/javascript-common/javascript-common_11%2bnmu1_all.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/node-jquery/libjs-jquery_3.5.1%2bdfsg%2b%7e3.5.5-7_all.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/u/underscore/libjs-underscore_1.9.1%7edfsg-3_all.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/s/sphinx/libjs-sphinxdoc_3.4.3-2_all.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/python3-defaults/libpython3-dev_3.9.2-3_armhf.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/o/openssl/libssl-dev_1.1.1n-0%2bdeb11u4%2brpt1_armhf.deb  Temporary failure resolving 'archive.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/python3-defaults/python3-dev_3.9.2-3_armhf.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/r/rustc/rust-gdb_1.48.0%2bdfsg1-1%2brpi1_all.deb  Temporary failure resolving 'raspbian.raspberrypi.org'
                                          E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
