  4. Einstellungen von Shuttercontrol
    5.4k
43 Beiträge 5 Kommentatoren 4.9k Aufrufe 7 Beobachtet
  • S StealthAngel
    @simatec said in Einstellungen von Shuttercontrol:
    @stealthangel was sagt der Debuglog?
    2023-04-12 14:50:00.010 - debug: shuttercontrol.0 (179737) calculate astrodata ...
    2023-04-12 14:50:00.010 - debug: shuttercontrol.0 (179737) Sun Azimut: 209.5°
    2023-04-12 14:50:00.011 - debug: shuttercontrol.0 (179737) Sun Elevation: 43.3°
    2023-04-12 14:50:09.334 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
    2023-04-12 14:52:53.560 - debug: shuttercontrol.0 (179737) Brightness sensor value: 4125
    2023-04-12 14:52:53.608 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: up
    2023-04-12 14:53:03.561 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
    2023-04-12 14:55:00.007 - debug: shuttercontrol.0 (179737) calculate astrodata ...
    2023-04-12 14:55:00.008 - debug: shuttercontrol.0 (179737) Sun Azimut: 211.1°
    2023-04-12 14:55:00.008 - debug: shuttercontrol.0 (179737) Sun Elevation: 42.9°
    2023-04-12 14:55:02.018 - debug: shuttercontrol.0 (179737) Buero: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
    2023-04-12 14:55:02.019 - info: shuttercontrol.0 (179737) Sunprotect #416 Set ID: Buero value: 30%
    2023-04-12 14:55:02.070 - debug: shuttercontrol.0 (179737) #0 wait for shutter check started
    2023-04-12 14:55:02.069 - info: mqtt.0 (955) send2Server mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos[shellies/Buero/Rolladen/roller/0/command/pos]
    2023-04-12 14:55:02.099 - debug: shuttercontrol.0 (179737) Sunprotect for Buero is active
    2023-04-12 14:55:02.100 - debug: shuttercontrol.0 (179737) RangeMinus: 210 < 211.1RangePlus: 320 > 211.1
    2023-04-12 14:55:02.100 - debug: shuttercontrol.0 (179737) last automatic Action for Buero: down_Sunprotect
    2023-04-12 14:55:02.101 - debug: shuttercontrol.0 (179737) Sunprotect Buero old height: 100% new height: 30%
    2023-04-12 14:55:22.072 - debug: shuttercontrol.0 (179737) #0 wait for shutter check end
    2023-04-12 14:55:22.074 - debug: shuttercontrol.0 (179737) Shutter state changed: Buero old value = 100 new value = 30
    2023-04-12 14:55:22.074 - debug: shuttercontrol.0 (179737) #1 shutterName: Buero
    2023-04-12 14:55:22.074 - debug: shuttercontrol.0 (179737) #1 shutterState: 30 %
    2023-04-12 14:55:22.074 - debug: shuttercontrol.0 (179737) #1 currentAction: Manu_Mode
    2023-04-12 14:55:22.075 - debug: shuttercontrol.0 (179737) #1 triggerAction: Manu_Mode
    2023-04-12 14:55:22.075 - debug: shuttercontrol.0 (179737) #1 currentHeight: 30 %
    2023-04-12 14:55:22.075 - debug: shuttercontrol.0 (179737) #1 oldHeight: 100 %
    2023-04-12 14:55:22.075 - debug: shuttercontrol.0 (179737) #1 currentShutterState: activated
    2023-04-12 14:55:22.076 - debug: shuttercontrol.0 (179737) #1 currentShutterStateTime: 20 seconds
    2023-04-12 14:55:22.127 - debug: shuttercontrol.0 (179737) Buero drived manually to 30. Old value = 100. New value = 30
    2023-04-12 14:55:22.127 - debug: shuttercontrol.0 (179737) Buero Updated trigger action to Manu_Mode to prevent moving after window close
    2023-04-12 14:55:33.323 - debug: shuttercontrol.0 (179737) Brightness sensor value: 4104
    2023-04-12 14:55:33.354 - info: shuttercontrol.0 (179737) Lightsensor #5 Set ID: Buero value: 100%
    2023-04-12 14:55:33.361 - info: mqtt.0 (955) send2Server mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos[shellies/Buero/Rolladen/roller/0/command/pos]
    2023-04-12 14:55:33.362 - debug: shuttercontrol.0 (179737) #0 wait for shutter check started
    2023-04-12 14:55:33.419 - debug: shuttercontrol.0 (179737) last automatic Action for Buero: up_Brightness
    2023-04-12 14:55:33.420 - debug: shuttercontrol.0 (179737) save current height: 100% from Buero
    2023-04-12 14:55:43.325 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
    2023-04-12 14:55:53.364 - debug: shuttercontrol.0 (179737) #0 wait for shutter check end
    2023-04-12 14:55:53.365 - debug: shuttercontrol.0 (179737) Buero Old value = 100. New value = 100. automatic is active
    2023-04-12 14:57:58.575 - debug: shuttercontrol.0 (179737) Brightness sensor value: 3967
    2023-04-12 14:57:58.629 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: up
    2023-04-12 14:58:08.577 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
    2023-04-12 15:00:00.008 - debug: shuttercontrol.0 (179737) calculate astrodata ...
    2023-04-12 15:00:00.008 - debug: shuttercontrol.0 (179737) Sun Azimut: 212.7°
    2023-04-12 15:00:00.009 - debug: shuttercontrol.0 (179737) Sun Elevation: 42.5°
    2023-04-12 15:00:02.020 - debug: shuttercontrol.0 (179737) Buero: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
    2023-04-12 15:00:02.020 - info: shuttercontrol.0 (179737) Sunprotect #416 Set ID: Buero value: 30%
    2023-04-12 15:00:02.065 - info: mqtt.0 (955) send2Server mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos[shellies/Buero/Rolladen/roller/0/command/pos]
    2023-04-12 15:00:02.066 - debug: shuttercontrol.0 (179737) #0 wait for shutter check started
    2023-04-12 15:00:02.121 - debug: shuttercontrol.0 (179737) Sunprotect for Buero is active
    2023-04-12 15:00:02.121 - debug: shuttercontrol.0 (179737) RangeMinus: 210 < 212.7RangePlus: 320 > 212.7
    2023-04-12 15:00:02.121 - debug: shuttercontrol.0 (179737) last automatic Action for Buero: down_Sunprotect
    2023-04-12 15:00:02.121 - debug: shuttercontrol.0 (179737) Sunprotect Buero old height: 100% new height: 30%
    2023-04-12 15:00:09.576 - debug: shuttercontrol.0 (179737) Brightness sensor value: 3856
    2023-04-12 15:00:09.606 - debug: shuttercontrol.0 (179737) outsidetemperature changed: hm-rpc.1.00181D89B4E7B4.1.ACTUAL_TEMPERATURE Value: 10.6
    2023-04-12 15:00:09.672 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
    2023-04-12 15:00:19.577 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
    2023-04-12 15:00:22.067 - debug: shuttercontrol.0 (179737) #0 wait for shutter check end
    2023-04-12 15:00:22.068 - debug: shuttercontrol.0 (179737) Shutter state changed: Buero old value = 100 new value = 30
    2023-04-12 15:00:22.069 - debug: shuttercontrol.0 (179737) Buero Old value = 100. New value = 30. automatic is active
    2023-04-12 15:03:10.046 - debug: shuttercontrol.0 (179737) Brightness sensor value: 4257
    2023-04-12 15:03:10.068 - debug: shuttercontrol.0 (179737) outsidetemperature changed: hm-rpc.1.00181D89B4E7B4.1.ACTUAL_TEMPERATURE Value: 10.5
    2023-04-12 15:03:10.130 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
    2023-04-12 15:03:20.047 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
    2023-04-12 15:05:00.008 - debug: shuttercontrol.0 (179737) calculate astrodata ...
    2023-04-12 15:05:00.009 - debug: shuttercontrol.0 (179737) Sun Azimut: 214.3°
    2023-04-12 15:05:00.009 - debug: shuttercontrol.0 (179737) Sun Elevation: 42.1°
    2023-04-12 15:05:56.040 - debug: shuttercontrol.0 (179737) Brightness sensor value: 4471
    2023-04-12 15:05:56.083 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
    2023-04-12 15:06:06.041 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
    2023-04-12 15:08:27.812 - debug: shuttercontrol.0 (179737) Brightness sensor value: 4399
    2023-04-12 15:08:27.839 - debug: shuttercontrol.0 (179737) outsidetemperature changed: hm-rpc.1.00181D89B4E7B4.1.ACTUAL_TEMPERATURE Value: 10.6
    2023-04-12 15:08:27.898 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
    2023-04-12 15:08:37.813 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
    2023-04-12 15:10:00.014 - debug: shuttercontrol.0 (179737) calculate astrodata ...
    2023-04-12 15:10:00.014 - debug: shuttercontrol.0 (179737) Sun Azimut: 215.8°
    2023-04-12 15:10:00.015 - debug: shuttercontrol.0 (179737) Sun Elevation: 41.6°
    2023-04-12 15:10:45.049 - debug: shuttercontrol.0 (179737) Brightness sensor value: 4524
    2023-04-12 15:10:45.135 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
    2023-04-12 15:10:55.050 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
    2023-04-12 15:12:47.794 - debug: shuttercontrol.0 (179737) Brightness sensor value: 4369
    2023-04-12 15:12:47.834 - debug: shuttercontrol.0 (179737) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
    2023-04-12 15:12:57.795 - debug: shuttercontrol.0 (179737) Brightness State Down is: false
    Danke für Deine Hilfe...
    simatecS Offline
    simatecS Offline
    simatec
    @stealthangel Deine Überprüfung der Rollläden nach 20 Sekunden löst hier die Aktion aus.
    Entweder deine Rollläden liefern einen sauberen State, dann schalte die Überprüfung aus oder setze der Wert höher.
    Z.B. auf 60 oder 100 Sekunden
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    S 2 Antworten Letzte Antwort
    • simatecS simatec
      StealthAngel
      Hallo, die Überprüfung ist auf 60 Sekunden eingestellt
      Jetzt war ich zwar nicht zuhause, aber als ich nach Hause kam war der Rollladen hochgefahren (und nicht auf 30%).
      2023-04-13 14:50:00.007 - debug: shuttercontrol.0 (184934) calculate astrodata ...
      2023-04-13 14:50:00.008 - debug: shuttercontrol.0 (184934) Sun Azimut: 209.7°
      2023-04-13 14:50:00.008 - debug: shuttercontrol.0 (184934) Sun Elevation: 43.6°
      2023-04-13 14:50:04.184 - debug: shuttercontrol.0 (184934) Brightness sensor value: 7487
      2023-04-13 14:50:04.208 - debug: shuttercontrol.0 (184934) outsidetemperature changed: hm-rpc.1.00181D89B4E7B4.1.ACTUAL_TEMPERATURE Value: 12
      2023-04-13 14:50:04.274 - debug: shuttercontrol.0 (184934) Lightsensor up Buero already up at: 100% - setting current action: up
      2023-04-13 14:50:14.184 - debug: shuttercontrol.0 (184934) Brightness State Down is: false
      2023-04-13 14:52:53.676 - debug: shuttercontrol.0 (184934) Brightness sensor value: 7333
      2023-04-13 14:52:53.718 - debug: shuttercontrol.0 (184934) Lightsensor up Buero already up at: 100% - setting current action: up
      2023-04-13 14:53:03.677 - debug: shuttercontrol.0 (184934) Brightness State Down is: false
      2023-04-13 14:55:00.009 - debug: shuttercontrol.0 (184934) calculate astrodata ...
      2023-04-13 14:55:00.009 - debug: shuttercontrol.0 (184934) Sun Azimut: 211.4°
      2023-04-13 14:55:00.010 - debug: shuttercontrol.0 (184934) Sun Elevation: 43.2°
      2023-04-13 14:55:02.023 - debug: shuttercontrol.0 (184934) Buero: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
      2023-04-13 14:55:02.024 - info: shuttercontrol.0 (184934) Sunprotect #416 Set ID: Buero value: 30%
      2023-04-13 14:55:02.075 - debug: shuttercontrol.0 (184934) #0 wait for shutter check started
      2023-04-13 14:55:02.073 - info: mqtt.0 (955) send2Server mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos[shellies/Buero/Rolladen/roller/0/command/pos]
      2023-04-13 14:55:02.126 - debug: shuttercontrol.0 (184934) Sunprotect for Buero is active
      2023-04-13 14:55:02.127 - debug: shuttercontrol.0 (184934) RangeMinus: 210 < 211.4RangePlus: 320 > 211.4
      2023-04-13 14:55:02.127 - debug: shuttercontrol.0 (184934) last automatic Action for Buero: down_Sunprotect
      2023-04-13 14:55:02.127 - debug: shuttercontrol.0 (184934) Sunprotect Buero old height: 100% new height: 30%
      2023-04-13 14:55:28.929 - debug: shuttercontrol.0 (184934) Brightness sensor value: 7345
      2023-04-13 14:55:28.952 - debug: shuttercontrol.0 (184934) outsidetemperature changed: hm-rpc.1.00181D89B4E7B4.1.ACTUAL_TEMPERATURE Value: 12.1
      2023-04-13 14:55:29.030 - debug: shuttercontrol.0 (184934) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
      2023-04-13 14:55:38.930 - debug: shuttercontrol.0 (184934) Brightness State Down is: false
      2023-04-13 14:56:02.076 - debug: shuttercontrol.0 (184934) #0 wait for shutter check end
      2023-04-13 14:56:02.078 - debug: shuttercontrol.0 (184934) Shutter state changed: Buero old value = 100 new value = 30
      2023-04-13 14:56:02.078 - debug: shuttercontrol.0 (184934) Buero Old value = 100. New value = 30. automatic is active
      2023-04-13 14:57:49.676 - debug: shuttercontrol.0 (184934) Brightness sensor value: 7125
      2023-04-13 14:57:49.724 - debug: shuttercontrol.0 (184934) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
      2023-04-13 14:57:59.677 - debug: shuttercontrol.0 (184934) Brightness State Down is: false
      2023-04-13 14:59:55.972 - debug: shuttercontrol.0 (184934) Brightness sensor value: 6848
      2023-04-13 14:59:56.003 - debug: shuttercontrol.0 (184934) outsidetemperature changed: hm-rpc.1.00181D89B4E7B4.1.ACTUAL_TEMPERATURE Value: 12.2
      2023-04-13 14:59:56.029 - debug: shuttercontrol.0 (184934) Lightsensor up Buero already up at: 100% - setting current action: sunProtect
      Die Objects sind der Meinung, dass der Rollladen auf 30% steht
      In Wirklichkeit ist der Rollladen aber auf 100%
      Also ist er scheinbar runter und gleich wieder hochgefahren.
      Kast Du bitte nochmal schauen, was hier schief gegangen ist?.....
      • simatecS simatec
        StealthAngel
        @simatec
        Halt Stop, ich habe noch einen Fehler bei mir gefunden. Wenn ich die "Objekt-ID Rollladen" einstelle wird vermutlich die Sollposition dort hin gesendet und die Position davon auch abgefragt, oder?
        Bei meinen Shellys muss ich aber auf
        schreiben und von
        mqtt.0.shellies.Buero.Rolladen.roller.0.pos
        lesen. Ich hatte als Object-ID "mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos". Das könnte der Fehler sein. Ich arbeite jetzt mit einen Alias.
            "alias": {
              "id": {
                "read": "mqtt.0.shellies.Buero.Rolladen.roller.0.pos",
                "write": "mqtt.0.shellies.Buero.Rolladen.roller.0.command.pos"
        Ich hoffe, dass es jetzt morgen funktioniert.
        Erstmal Sorry und vielen Dank....
        • S StealthAngel
          simatecS Offline
          simatecS Offline
          simatec
          @stealthangel Laut dem Log hat Shuttercontrol mit dem Überprüfen nach 60 Sekunden alles richtig gemacht.
          Automatik wurde erkannt und er wurde in den Sonnenschutz gefahren.
          Ich gehe mal davon aus, dass da bei deinen States der Rollläden was krum ist.
          Hast du da noch irgendwelche Scripte laufen?
          Wann wurde denn der State des Rollladens geändert?
          • S StealthAngel
            @simatec
            schreiben und von
                "alias": {
                  "id": {
            simatecS Offline
            simatecS Offline
            simatec
            @stealthangel Warum nutzt du nicht den Shelly Adapter??? Würde sicher einiges erleichtern
            • simatecS simatec
              StealthAngel
              Ich habe jetzt auch auf den Shelly Adapter umgestellt. Das Problem ist aber immer noch das Gleiche :(
              Der Rollladen ist wieder 3 mal runter und rauf gefahren. So langsam verzweifele ich ....
              2023-04-17 14:45:00.014 - debug: shuttercontrol.0 (207218) calculate astrodata ...
              2023-04-17 14:45:00.014 - debug: shuttercontrol.0 (207218) Sun Azimut: 209°
              2023-04-17 14:45:00.015 - debug: shuttercontrol.0 (207218) Sun Elevation: 45.3°
              2023-04-17 14:46:12.976 - debug: shuttercontrol.0 (207218) Brightness sensor value: 5032
              2023-04-17 14:46:14.052 - debug: shuttercontrol.0 (207218) Lightsensor up BueroRollladen already up at: 100% - setting current action: up
              2023-04-17 14:46:22.978 - debug: shuttercontrol.0 (207218) Brightness State Down is: false
              2023-04-17 14:48:53.703 - debug: shuttercontrol.0 (207218) Brightness sensor value: 4799
              2023-04-17 14:48:54.799 - debug: shuttercontrol.0 (207218) Lightsensor up BueroRollladen already up at: 100% - setting current action: up
              2023-04-17 14:49:03.703 - debug: shuttercontrol.0 (207218) Brightness State Down is: false
              2023-04-17 14:50:00.019 - debug: shuttercontrol.0 (207218) calculate astrodata ...
              2023-04-17 14:50:00.020 - debug: shuttercontrol.0 (207218) Sun Azimut: 210.7°
              2023-04-17 14:50:00.021 - debug: shuttercontrol.0 (207218) Sun Elevation: 44.9°
              2023-04-17 14:50:02.035 - debug: shuttercontrol.0 (207218) BueroRollladen: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
              2023-04-17 14:50:02.036 - info: shuttercontrol.0 (207218) Sunprotect #416 Set ID: BueroRollladen value: 30%
              2023-04-17 14:50:02.048 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 14:50:02.059 - debug: shuttercontrol.0 (207218) Sunprotect for BueroRollladen is active
              2023-04-17 14:50:02.060 - debug: shuttercontrol.0 (207218) RangeMinus: 210 < 210.7RangePlus: 320 > 210.7
              2023-04-17 14:50:02.060 - debug: shuttercontrol.0 (207218) last automatic Action for BueroRollladen: down_Sunprotect
              2023-04-17 14:50:02.060 - debug: shuttercontrol.0 (207218) Sunprotect BueroRollladen old height: % new height: 30%
              2023-04-17 14:50:02.083 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 14:50:14.335 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 14:51:02.049 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 14:51:02.051 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = new value = 30
              2023-04-17 14:51:02.051 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
              2023-04-17 14:51:02.052 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
              2023-04-17 14:51:02.052 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
              2023-04-17 14:51:02.052 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
              2023-04-17 14:51:02.053 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
              2023-04-17 14:51:02.053 - debug: shuttercontrol.0 (207218) #1 oldHeight: %
              2023-04-17 14:51:02.053 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
              2023-04-17 14:51:02.053 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
              2023-04-17 14:51:02.084 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 14:51:02.085 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = new value = 30
              2023-04-17 14:51:02.086 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
              2023-04-17 14:51:02.087 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
              2023-04-17 14:51:02.087 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
              2023-04-17 14:51:02.087 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
              2023-04-17 14:51:02.088 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
              2023-04-17 14:51:02.088 - debug: shuttercontrol.0 (207218) #1 oldHeight: %
              2023-04-17 14:51:02.089 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
              2023-04-17 14:51:02.089 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
              2023-04-17 14:51:02.091 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = . New value = 30
              2023-04-17 14:51:02.092 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
              2023-04-17 14:51:02.142 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = . New value = 30
              2023-04-17 14:51:02.143 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
              2023-04-17 14:51:14.336 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 14:51:14.338 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = new value = 30
              2023-04-17 14:51:14.338 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
              2023-04-17 14:51:14.339 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
              2023-04-17 14:51:14.339 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
              2023-04-17 14:51:14.339 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
              2023-04-17 14:51:14.339 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
              2023-04-17 14:51:14.340 - debug: shuttercontrol.0 (207218) #1 oldHeight: %
              2023-04-17 14:51:14.340 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
              2023-04-17 14:51:14.340 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
              2023-04-17 14:51:14.390 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = . New value = 30
              2023-04-17 14:51:14.391 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
              2023-04-17 14:51:19.961 - debug: shuttercontrol.0 (207218) Brightness sensor value: 4622
              2023-04-17 14:51:19.995 - info: shuttercontrol.0 (207218) Lightsensor #5 Set ID: BueroRollladen value: 100%
              2023-04-17 14:51:20.003 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 14:51:20.013 - debug: shuttercontrol.0 (207218) last automatic Action for BueroRollladen: up_Brightness
              2023-04-17 14:51:20.013 - debug: shuttercontrol.0 (207218) save current height: 100% from BueroRollladen
              2023-04-17 14:51:20.035 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 14:51:29.963 - debug: shuttercontrol.0 (207218) Brightness State Down is: false
              2023-04-17 14:51:33.042 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 14:52:20.004 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 14:52:20.005 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = new value = 100
              2023-04-17 14:52:20.006 - debug: shuttercontrol.0 (207218) BueroRollladen Old value = . New value = 100. automatic is active
              2023-04-17 14:52:20.035 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 14:52:20.037 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = new value = 100
              2023-04-17 14:52:20.038 - debug: shuttercontrol.0 (207218) BueroRollladen Old value = . New value = 100. automatic is active
              2023-04-17 14:52:33.043 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 14:52:33.044 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = new value = 100
              2023-04-17 14:52:33.045 - debug: shuttercontrol.0 (207218) BueroRollladen Old value = . New value = 100. automatic is active
              2023-04-17 14:53:31.713 - debug: shuttercontrol.0 (207218) Brightness sensor value: 4502
              2023-04-17 14:53:31.770 - debug: shuttercontrol.0 (207218) Lightsensor up BueroRollladen already up at: 100% - setting current action: up
              2023-04-17 14:53:41.714 - debug: shuttercontrol.0 (207218) Brightness State Down is: false
              2023-04-17 14:55:00.017 - debug: shuttercontrol.0 (207218) calculate astrodata ...
              2023-04-17 14:55:00.018 - debug: shuttercontrol.0 (207218) Sun Azimut: 212.3°
              2023-04-17 14:55:00.018 - debug: shuttercontrol.0 (207218) Sun Elevation: 44.5°
              2023-04-17 14:55:02.040 - debug: shuttercontrol.0 (207218) BueroRollladen: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
              2023-04-17 14:55:02.041 - info: shuttercontrol.0 (207218) Sunprotect #416 Set ID: BueroRollladen value: 30%
              2023-04-17 14:55:02.093 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 14:55:02.111 - debug: shuttercontrol.0 (207218) Sunprotect for BueroRollladen is active
              2023-04-17 14:55:02.112 - debug: shuttercontrol.0 (207218) RangeMinus: 210 < 212.3RangePlus: 320 > 212.3
              2023-04-17 14:55:02.113 - debug: shuttercontrol.0 (207218) last automatic Action for BueroRollladen: down_Sunprotect
              2023-04-17 14:55:02.113 - debug: shuttercontrol.0 (207218) Sunprotect BueroRollladen old height: 100% new height: 30%
              2023-04-17 14:55:02.136 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 14:55:14.373 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 14:56:02.095 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 14:56:02.097 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = 100 new value = 30
              2023-04-17 14:56:02.098 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
              2023-04-17 14:56:02.099 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
              2023-04-17 14:56:02.099 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
              2023-04-17 14:56:02.100 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
              2023-04-17 14:56:02.100 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
              2023-04-17 14:56:02.101 - debug: shuttercontrol.0 (207218) #1 oldHeight: 100 %
              2023-04-17 14:56:02.101 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
              2023-04-17 14:56:02.101 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
              2023-04-17 14:56:02.137 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 14:56:02.143 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = 100 new value = 30
              2023-04-17 14:56:02.144 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
              2023-04-17 14:56:02.144 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
              2023-04-17 14:56:02.145 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
              2023-04-17 14:56:02.146 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
              2023-04-17 14:56:02.146 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
              2023-04-17 14:56:02.147 - debug: shuttercontrol.0 (207218) #1 oldHeight: 100 %
              2023-04-17 14:56:02.147 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
              2023-04-17 14:56:02.148 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
              2023-04-17 14:56:02.152 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = 100. New value = 30
              2023-04-17 14:56:02.153 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
              2023-04-17 14:56:02.208 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = 100. New value = 30
              2023-04-17 14:56:02.209 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
              2023-04-17 14:56:14.374 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 14:56:14.377 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = 100 new value = 30
              2023-04-17 14:56:14.377 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
              2023-04-17 14:56:14.378 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
              2023-04-17 14:56:14.378 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
              2023-04-17 14:56:14.378 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
              2023-04-17 14:56:14.378 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
              2023-04-17 14:56:14.379 - debug: shuttercontrol.0 (207218) #1 oldHeight: 100 %
              2023-04-17 14:56:14.379 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
              2023-04-17 14:56:14.379 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
              2023-04-17 14:56:14.432 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = 100. New value = 30
              2023-04-17 14:56:14.432 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
              2023-04-17 14:56:32.952 - debug: shuttercontrol.0 (207218) Brightness sensor value: 4650
              2023-04-17 14:56:32.992 - info: shuttercontrol.0 (207218) Lightsensor #5 Set ID: BueroRollladen value: 100%
              2023-04-17 14:56:33.000 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 14:56:33.010 - debug: shuttercontrol.0 (207218) last automatic Action for BueroRollladen: up_Brightness
              2023-04-17 14:56:33.011 - debug: shuttercontrol.0 (207218) save current height: 100% from BueroRollladen
              2023-04-17 14:56:33.032 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 14:56:42.953 - debug: shuttercontrol.0 (207218) Brightness State Down is: false
              2023-04-17 14:56:46.052 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 14:57:26.778 - info: admin.0 (831) ==> Connected system.user.admin from ::ffff:192.168.2.21
              2023-04-17 14:57:33.002 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 14:57:33.003 - debug: shuttercontrol.0 (207218) BueroRollladen Old value = 100. New value = 100. automatic is active
              2023-04-17 14:57:33.032 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 14:57:33.034 - debug: shuttercontrol.0 (207218) BueroRollladen Old value = 100. New value = 100. automatic is active
              2023-04-17 14:57:38.475 - info: admin.0 (831) ==> Connected system.user.admin from ::ffff:192.168.2.21
              2023-04-17 14:57:46.054 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 14:57:46.055 - debug: shuttercontrol.0 (207218) BueroRollladen Old value = 100. New value = 100. automatic is active
              2023-04-17 14:59:19.969 - debug: shuttercontrol.0 (207218) Brightness sensor value: 4804
              2023-04-17 14:59:20.020 - debug: shuttercontrol.0 (207218) Lightsensor up BueroRollladen already up at: 100% - setting current action: up
              2023-04-17 14:59:29.971 - debug: shuttercontrol.0 (207218) Brightness State Down is: false
              2023-04-17 15:00:00.012 - debug: shuttercontrol.0 (207218) calculate astrodata ...
              2023-04-17 15:00:00.013 - debug: shuttercontrol.0 (207218) Sun Azimut: 213.9°
              2023-04-17 15:00:00.013 - debug: shuttercontrol.0 (207218) Sun Elevation: 44.1°
              2023-04-17 15:00:02.026 - debug: shuttercontrol.0 (207218) BueroRollladen: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
              2023-04-17 15:00:02.026 - info: shuttercontrol.0 (207218) Sunprotect #416 Set ID: BueroRollladen value: 30%
              2023-04-17 15:00:02.075 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 15:00:02.086 - debug: shuttercontrol.0 (207218) Sunprotect for BueroRollladen is active
              2023-04-17 15:00:02.086 - debug: shuttercontrol.0 (207218) RangeMinus: 210 < 213.9RangePlus: 320 > 213.9
              2023-04-17 15:00:02.086 - debug: shuttercontrol.0 (207218) last automatic Action for BueroRollladen: down_Sunprotect
              2023-04-17 15:00:02.087 - debug: shuttercontrol.0 (207218) Sunprotect BueroRollladen old height: 100% new height: 30%
              2023-04-17 15:00:02.105 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 15:00:14.359 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 15:01:02.077 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 15:01:02.078 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = 100 new value = 30
              2023-04-17 15:01:02.079 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
              2023-04-17 15:01:02.079 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
              2023-04-17 15:01:02.080 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
              2023-04-17 15:01:02.080 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
              2023-04-17 15:01:02.080 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
              2023-04-17 15:01:02.080 - debug: shuttercontrol.0 (207218) #1 oldHeight: 100 %
              2023-04-17 15:01:02.081 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
              2023-04-17 15:01:02.081 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
              2023-04-17 15:01:02.106 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 15:01:02.128 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = 100 new value = 30
              2023-04-17 15:01:02.128 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
              2023-04-17 15:01:02.129 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
              2023-04-17 15:01:02.130 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
              2023-04-17 15:01:02.130 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
              2023-04-17 15:01:02.132 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
              2023-04-17 15:01:02.132 - debug: shuttercontrol.0 (207218) #1 oldHeight: 100 %
              2023-04-17 15:01:02.132 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
              2023-04-17 15:01:02.133 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
              2023-04-17 15:01:02.140 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = 100. New value = 30
              2023-04-17 15:01:02.140 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
              2023-04-17 15:01:02.188 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = 100. New value = 30
              2023-04-17 15:01:02.188 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
              2023-04-17 15:01:14.360 - debug: shuttercontrol.0 (207218) #0 wait for shutter check end
              2023-04-17 15:01:14.361 - debug: shuttercontrol.0 (207218) Shutter state changed: BueroRollladen old value = 100 new value = 30
              2023-04-17 15:01:14.362 - debug: shuttercontrol.0 (207218) #1 shutterName: BueroRollladen
              2023-04-17 15:01:14.362 - debug: shuttercontrol.0 (207218) #1 shutterState: 30 %
              2023-04-17 15:01:14.362 - debug: shuttercontrol.0 (207218) #1 currentAction: Manu_Mode
              2023-04-17 15:01:14.363 - debug: shuttercontrol.0 (207218) #1 triggerAction: Manu_Mode
              2023-04-17 15:01:14.363 - debug: shuttercontrol.0 (207218) #1 currentHeight: 30 %
              2023-04-17 15:01:14.363 - debug: shuttercontrol.0 (207218) #1 oldHeight: 100 %
              2023-04-17 15:01:14.363 - debug: shuttercontrol.0 (207218) #1 currentShutterState: activated
              2023-04-17 15:01:14.364 - debug: shuttercontrol.0 (207218) #1 currentShutterStateTime: 60 seconds
              2023-04-17 15:01:14.415 - debug: shuttercontrol.0 (207218) BueroRollladen drived manually to 30. Old value = 100. New value = 30
              2023-04-17 15:01:14.415 - debug: shuttercontrol.0 (207218) BueroRollladen Updated trigger action to Manu_Mode to prevent moving after window close
              2023-04-17 15:01:52.457 - debug: shuttercontrol.0 (207218) Brightness sensor value: 4873
              2023-04-17 15:01:52.494 - info: shuttercontrol.0 (207218) Lightsensor #5 Set ID: BueroRollladen value: 100%
              2023-04-17 15:01:52.506 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 15:01:52.520 - debug: shuttercontrol.0 (207218) last automatic Action for BueroRollladen: up_Brightness
              2023-04-17 15:01:52.520 - debug: shuttercontrol.0 (207218) save current height: 100% from BueroRollladen
              2023-04-17 15:01:52.537 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              2023-04-17 15:02:02.459 - debug: shuttercontrol.0 (207218) Brightness State Down is: false
              2023-04-17 15:02:05.565 - debug: shuttercontrol.0 (207218) #0 wait for shutter check started
              Also irgendwas läuft noch falsch.
              Mich wundert, dass sich der Status ändert. Ist das so richtig?
              Screenshot ist von einem etwas späteren Zeitpunkt, war aber sonst auch so, allerdings nicht geloggt....
              Jetzt wo ich hier schreibe, fährt der Rollladen munter weiter rauf und runter.
              Es ist mit dem Shelly-Adapter also massiv schlechter geworden :(
              • S StealthAngel
                simatecS Offline
                simatecS Offline
                simatec
                @stealthangel Bitte teste die aktuelle v1.4.28
                • simatecS simatec
                  StealthAngel
                  schrieb am zuletzt editiert von StealthAngel
                  Funktioniert auch nicht richtig :(
                  Das einzige was sich jetzt geändert hat ist, dass der Rollladen nicht mehr komplett rauf und runter fährt, sondern nur ca. 5% und das jetzt fast im Sekunden Takt.
                  Am besten sieht man das an der Shelly Shutter.Position Objekt:
                  Hier auch noch das Debug:
                  2023-04-18 15:34:50.700 - debug: shuttercontrol.0 (208390) Brightness sensor value: 8371
                  2023-04-18 15:34:50.742 - debug: shuttercontrol.0 (208390) Lightsensor up BueroRollladen already up at: 100% - setting current action: up
                  2023-04-18 15:35:00.016 - debug: shuttercontrol.0 (208390) calculate astrodata ...
                  2023-04-18 15:35:00.017 - debug: shuttercontrol.0 (208390) Sun Azimut: 224.9°
                  2023-04-18 15:35:00.018 - debug: shuttercontrol.0 (208390) Sun Elevation: 41°
                  2023-04-18 15:35:00.700 - debug: shuttercontrol.0 (208390) Brightness State Down is: false
                  2023-04-18 15:35:02.073 - debug: shuttercontrol.0 (208390) BueroRollladen: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                  2023-04-18 15:35:02.074 - info: shuttercontrol.0 (208390) Sunprotect #416 Set ID: BueroRollladen value: 30%
                  2023-04-18 15:35:02.122 - debug: shuttercontrol.0 (208390) #0 wait for shutter check started
                  2023-04-18 15:35:02.141 - debug: shuttercontrol.0 (208390) Sunprotect for BueroRollladen is active
                  2023-04-18 15:35:02.142 - debug: shuttercontrol.0 (208390) RangeMinus: 210 < 224.9RangePlus: 320 > 224.9
                  2023-04-18 15:35:02.144 - debug: shuttercontrol.0 (208390) last automatic Action for BueroRollladen: down_Sunprotect
                  2023-04-18 15:35:02.144 - debug: shuttercontrol.0 (208390) Sunprotect BueroRollladen old height: 100% new height: 30%
                  2023-04-18 15:35:02.166 - debug: shuttercontrol.0 (208390) #0 wait for shutter check started
                  2023-04-18 15:35:03.157 - debug: shuttercontrol.0 (208390) #0 wait for shutter check started
                  2023-04-18 15:35:05.773 - debug: shuttercontrol.0 (208390) #0 wait for shutter check started
                  2023-04-18 15:36:02.124 - debug: shuttercontrol.0 (208390) #0 wait for shutter check end
                  2023-04-18 15:36:02.167 - debug: shuttercontrol.0 (208390) #0 wait for shutter check end
                  2023-04-18 15:36:03.158 - debug: shuttercontrol.0 (208390) #0 wait for shutter check end
                  2023-04-18 15:36:05.775 - debug: shuttercontrol.0 (208390) #0 wait for shutter check end
                  2023-04-18 15:37:08.708 - debug: shuttercontrol.0 (208390) Brightness sensor value: 8611
                  2023-04-18 15:37:08.784 - info: shuttercontrol.0 (208390) Lightsensor #5 Set ID: BueroRollladen value: 30%
                  2023-04-18 15:37:08.793 - debug: shuttercontrol.0 (208390) #0 wait for shutter check started
                  2023-04-18 15:37:08.806 - debug: shuttercontrol.0 (208390) last automatic Action for BueroRollladen: up_Brightness
                  2023-04-18 15:37:08.807 - debug: shuttercontrol.0 (208390) save current height: 30% from BueroRollladen
                  2023-04-18 15:37:08.824 - debug: shuttercontrol.0 (208390) #0 wait for shutter check started
                  2023-04-18 15:37:09.861 - debug: shuttercontrol.0 (208390) #0 wait for shutter check started
                  2023-04-18 15:37:10.839 - debug: shuttercontrol.0 (208390) #0 wait for shutter check started
                  2023-04-18 15:37:11.852 - debug: shuttercontrol.0 (208390) #0 wait for shutter check started
                  2023-04-18 15:37:12.863 - debug: shuttercontrol.0 (208390) #0 wait for shutter check started
                  2023-04-18 15:37:13.883 - debug: shuttercontrol.0 (208390) #0 wait for shutter check started
                  2023-04-18 15:37:16.495 - debug: shuttercontrol.0 (208390) #0 wait for shutter check started
                  2023-04-18 15:37:18.709 - debug: shuttercontrol.0 (208390) Brightness State Down is: false
                  2023-04-18 15:38:08.794 - debug: shuttercontrol.0 (208390) #0 wait for shutter check end
                  2023-04-18 15:38:08.825 - debug: shuttercontrol.0 (208390) #0 wait for shutter check end
                  2023-04-18 15:38:09.860 - debug: shuttercontrol.0 (208390) #0 wait for shutter check end
                  2023-04-18 15:38:10.840 - debug: shuttercontrol.0 (208390) #0 wait for shutter check end
                  2023-04-18 15:38:11.853 - debug: shuttercontrol.0 (208390) #0 wait for shutter check end
                  2023-04-18 15:38:12.863 - debug: shuttercontrol.0 (208390) #0 wait for shutter check end
                  2023-04-18 15:38:13.884 - debug: shuttercontrol.0 (208390) #0 wait for shutter check end
                  2023-04-18 15:38:16.496 - debug: shuttercontrol.0 (208390) #0 wait for shutter check end
                  2023-04-18 15:39:12.143 - debug: shuttercontrol.0 (208390) Brightness sensor value: 8592
                  2023-04-18 15:39:22.144 - debug: shuttercontrol.0 (208390) Brightness State Down is: false
                  2023-04-18 15:40:00.010 - debug: shuttercontrol.0 (208390) calculate astrodata ...
                  2023-04-18 15:40:00.010 - debug: shuttercontrol.0 (208390) Sun Azimut: 226.4°
                  2023-04-18 15:40:00.011 - debug: shuttercontrol.0 (208390) Sun Elevation: 40.4°
                  2023-04-18 15:42:05.421 - debug: shuttercontrol.0 (208390) Brightness sensor value: 8634
                  2023-04-18 15:42:15.421 - debug: shuttercontrol.0 (208390) Brightness State Down is: false
                  2023-04-18 15:44:44.194 - debug: shuttercontrol.0 (208390) Brightness sensor value: 8423
                  2023-04-18 15:44:54.195 - debug: shuttercontrol.0 (208390) Brightness State Down is: false
                  2023-04-18 15:45:00.011 - debug: shuttercontrol.0 (208390) calculate astrodata ...
                  2023-04-18 15:45:00.011 - debug: shuttercontrol.0 (208390) Sun Azimut: 227.8°
                  2023-04-18 15:45:00.012 - debug: shuttercontrol.0 (208390) Sun Elevation: 39.8°
                  Auch die Position in den Objekten passt nicht.
                  shutters.autoLevel.BueroRollladen steht auf 30%
                  Shelly.Shutter.Position sagt aber 100% (und das ist auch richtig)
                    StealthAngel
                    @simatec Wenn Du mir mit einigen Worten erklärst wie das Ganze funktionieren soll, würde ich mich bereit erklären und etwas in den Source-Code abzutauchen und Debug-Hilfe zugeben....
                    • S StealthAngel
                      @stealthangel sagte in Einstellungen von Shuttercontrol:
                      das sieht für mich aus als ob der Shelly die Position unsauber durchgibt (flattert)
                      im Millisekundenbereich von 92 auf 98 u.ä.
                      • S StealthAngel
                        simatecS Offline
                        simatecS Offline
                        simatec
                        @stealthangel Poste mal deine Config hier als JSON.
                        Da ist bei dir völlig was krumm… Shuttercontrol gibt nur einen Fahrbefehl an deinen Rollladen.
                        Schalte alle Scripte und sonstige Routinen ab
                          StealthAngel
                          Hier ist die Config: system.adapter.shuttercontrol.0 (2).json
                          Es gibt keine anderen Skripte oder Routinen
                          Das Flattern habe ich auch nur mit dem Shelly-Adapter gesehen. Als ich das noch über MQTT gemacht habe war der Positionswert sauber, aber der Shuttercontrol hat trotzdem nicht richtig funktioniert...
                            StealthAngel
                            @simatec
                            Noch zwei Fragen:
                            1.) Wenn ich in den Objekten "autoSun" auf "false" stelle während der Sonnenschutz aktiv ist, müsste dann sunProtect nicht beendet werden und die Rollläden wieder hoch fahren?
                            2.) Wenn der Rollladen bei "autoDown" runter fährt und das Fenster offen ist würde ich erwarten das der Rollladen nur bis auf den Wert runter fährt der bei "Rollladenhöhe bei öffnen des Fensters oder Tür" definiert ist. Bei mir fährt der Rollladen jedoch komplett runter und erst wenn ich das Fenster zu und wieder auf mache, wird die "richtige" Rollladenhöhe gefahren.
                            Oder verstehe ich da irgendwas falsch?
                            • S StealthAngel
                              @simatec
                              Noch zwei Fragen:
                              simatecS Offline
                              simatecS Offline
                              simatec
                              @stealthangel
                              1. Nein ist nicht so angedacht ...
                              2. Aussperrschutz falsch konfiguriert
