4.8k Beiträge 4 Kommentatoren 2.9m Aufrufe 4 Beobachtet
  • mickymM mickym
    @mickym Ja, das geht
    Nee - da ist noch ein Logikfehler drin. Besser eine delay Node - ich überlege noch,
    mickymM Offline
    mickymM Offline
    mickym
    #4729
    So ich würde es nun so umschreiben . die trigger Node am Anfang wieder raus machen:
           "id": "3066ee94f24c9d6e",
           "type": "switch",
           "z": "289f539dcc33814e",
           "name": "",
           "property": "payload",
           "propertyType": "msg",
           "rules": [
                   "t": "true"
                   "t": "false"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 810,
           "y": 4920,
           "wires": [
                   "285dd3b342fbf577"
                   "4b8d91d2070cccd5",
                   "285dd3b342fbf577"
           "id": "4b8d91d2070cccd5",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "reset",
                   "pt": "msg",
                   "to": "true",
                   "tot": "bool"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1000,
           "y": 4940,
           "wires": [
                   "9629200a08cd9231"
           "id": "9629200a08cd9231",
           "type": "delay",
           "name": "",
           "pauseType": "rate",
           "timeout": "5",
           "timeoutUnits": "seconds",
           "rate": "1",
           "nbRateUnits": "1",
           "rateUnits": "minute",
           "randomFirst": "1",
           "randomLast": "5",
           "randomUnits": "seconds",
           "drop": true,
           "allowrate": false,
           "outputs": 1,
           "x": 1280,
           "y": 4920,
           "wires": [
                   "e8a1d2bd62d35a63"
           "id": "285dd3b342fbf577",
           "type": "trigger",
           "name": "",
           "op1": "{\"tab\":\"\"}",
           "op2": "",
           "op1type": "json",
           "op2type": "nul",
           "duration": "-1",
           "extend": false,
           "overrideDelay": false,
           "units": "min",
           "reset": "false",
           "bytopic": "all",
           "topic": "topic",
           "outputs": 1,
           "x": 1010,
           "y": 4880,
           "wires": [
                   "9629200a08cd9231"
    • mickymM mickym
             "type": "switch",
             "name": "",
             "rules": [
                     "t": "true"
                     "t": "false"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 810,
             "y": 4920,
             "wires": [
                     "285dd3b342fbf577"
                     "4b8d91d2070cccd5",
                     "285dd3b342fbf577"
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "reset",
                     "pt": "msg",
                     "to": "true",
                     "tot": "bool"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1000,
             "y": 4940,
             "wires": [
                     "9629200a08cd9231"
             "type": "delay",
             "name": "",
             "timeout": "5",
             "rate": "1",
             "nbRateUnits": "1",
             "randomFirst": "1",
             "randomLast": "5",
             "drop": true,
             "allowrate": false,
             "outputs": 1,
             "x": 1280,
             "y": 4920,
             "wires": [
                     "e8a1d2bd62d35a63"
             "type": "trigger",
             "name": "",
             "op2": "",
             "op1type": "json",
             "op2type": "nul",
             "duration": "-1",
             "extend": false,
             "units": "min",
             "reset": "false",
             "bytopic": "all",
             "topic": "topic",
             "outputs": 1,
             "x": 1010,
             "y": 4880,
             "wires": [
                     "9629200a08cd9231"
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      #4730
      @mickym Habe das jetzt so eingebaut und die Karte aktualisiert sich jede Minute.
      Mit besten Grüßen
      Andy
      • Damrak2022D Damrak2022
        mickymM Offline
        mickymM Offline
        mickym
        #4731
        @damrak2022 Nun und das sollte sie nur tun - wenn der Staubi aktiv ist. Dann wäre das Ziel ja erreicht.
        • mickymM mickym
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          #4732
          @mickym Ja, ich habe per inject ein true gesendet zum testen
          Mit besten Grüßen
          Andy
          • mickymM mickym
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            #4733
            @mickym Hallo Micky, mein Staubsauger läuft gerade und ich stelle folgendes fest:
            Die Karte wird zwar alle 1 Minute refresht, wie im Trigger vorgegeben, aber der Staubsauger wird weiterhin an dr Ladestation angezeigt.
            Der Roborock Tab ist geöffnet und auch das Dashboard.
            Nur wenn ich die Karte im Bowser selbst refreshe, als neu lade, wird mir die veränderte Position des Roboters angezeigt.
            Mit besten Grüßen
            Andy
              mickymM Offline
              mickymM Offline
              mickym
              #4734
              @damrak2022 Dann tuts mir leid - dann musst Du wohl doch über VIS gehen oder Du benutzt entweder die Node-Rode Roborock Nodes oder dieses Valetudo
              https://valetudo.cloud/pages/general/supported-robots.html
              Das kann anscheinend herstellerübergreifend die MAP anzeigen lassen: https://flows.nodered.org/node/node-red-contrib-valetudo
              • mickymM mickym
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                #4735
                @mickym Ich muss hier doch nochmal was fragen. Warum steht bei diesem Flow bei manchen nodes "connected", während bei den anderen Nodes der Datenpunkt, als 0.userdate.0 etc angezeigt wird?
                Mit besten Grüßen
                Andy
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #4736
                  @damrak2022 Weil in diese Datenpunkte (nur connected) noch nichts geschrieben wurde.
                  • mickymM mickym
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    #4737
                    @mickym Kugelleuchte, Stehlampe und iMac waren aber in den letzten Tagen an, seit ich das protokolliere. Eventuell muss ich die Datenpunkte nochmal erneut zuordnen?
                    Mit besten Grüßen
                    Andy
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #4738
                      @damrak2022 Na Du siehst doch an den Nodes - ob sie zuletzt ein- oder ausgeschaltet wurden. Nicht gleich neu zuordnen, sondern systemmatisch vorgehen.
                      Wenn Du sowas siehst, dann siehst Du doch, dass keine Startzeit geschrieben wurde und nur eine Einschaltzeit.
                      In so einem Fall macht eine Neuzuordnung KEINEN Sinn.
                      • mickymM mickym
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        #4739
                        @mickym Ja ich ordne die Datenpunkt nochmal erneut zu. Eventuell hakt es da.
                        Meintest Du nicht auch, das ich die Umrechnung anpassen sollte, da mir das ganze ja letztendlich Grafana in angezeigt werden soll
                        Als nicht "payload/60000" sondern ?
                        Mit besten Grüßen
                        Andy
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #4740
                          @damrak2022 Ich würde ggf. gar nicht umrechnen. Du musst ja nur wissen, was es für eine Einheit ist. Die ganze Umrechnerei kannst du doch in Grafana oder Influx machen. Wenn Du gar nichts umrechnest dann ist das die Zeit in Millisekunden (ms).
                          Und ansonsten - machst Du debug Nodes dran und prüfst wo die Nachrichten verschluckt werden, wenn Du einschaltest. ;) - So wie Du es gelernt haben solltest. 😀
                          Aber wenn wie im Beispiel unten keine Startzeit aber eine Einschaltzeit berechnet wurden, macht eine Neuzuordnung keinen Sinn, da der Flow ja von einem Datenpunkt getriggert wird.
                          • mickymM mickym
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            #4741
                            @mickym Guten Morgen, ich will Dich nicht ärgern, aber das verstehe ich nicht.
                            Ich habe meine Lampe im Flur eben exakt 5 Minuten angehabt.
                            Dann wird mir folgender Wert in den Datenpunkt geschrieben:
                            Wenn ich das nun aber wie in unserem Flow durch 60000 teile ist das Ergebnis 0,00009 Minuten - Das kann doch nicht sein.
                            Ich verstehe es beim besten Willen nicht.
                            Mit besten Grüßen
                            Andy
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #4742
                              @damrak2022 du hast doch schon durch 60000 geteilt, deswegen kommen ja 5,3 Minuten raus. Siehst du doch in deinem Screenshot Deiner Change-Node.
                              • mickymM mickym
                                Damrak2022D Offline
                                Damrak2022D Offline
                                Damrak2022
                                #4743
                                @mickym Ja, ich lag gerade im Bett und da ist mir bewusst geworden, das ich totalen Müll geschrieben hatte.
                                Mit besten Grüßen
                                Andy
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #4744
                                  Na ist ja nicht so schlimm und es waren halt auch keine 5 Minuten sondern 5 Minuten und 21 Sekunden. ;). Aber auf Minuten gerundet, hast Du natürlich Recht. ;) Also auf exakt gerundete 5 Minuten. 🤣
                                  • mickymM mickym
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    #4745
                                    @mickym
                                    Ich lese gerade das hier nochmal
                                    https://forum.iobroker.net/post/979135
                                    Vielleicht löst sich mein Problem wirklich wenn ich die Umrechnung direkt in Grafana oder Influx mache. Dann würde der ganze Flow so bleiben wie er ist, nur die Change node mit der Berechnung müsste weg, richtig?
                                    Mit besten Grüßen
                                    Andy
                                      @mickym
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #4746
                                      @damrak2022 Ja und????
                                      • mickymM mickym
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #4747
                                        @mickym Nein nicht die ChangeNode - die Differenz musst Du doch berechnen? Hast Du eigentlich gar nicht verstanden was der Flow macht?
                                        • mickymM mickym
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          #4748
                                          @mickym Doch, Achso ich muss aus der Change Node die Division entfernen.
                                          Mit besten Grüßen
                                          Andy
