  4. Alpha Test js-controller 5.0
    6.6k
140 Beiträge 25 Kommentatoren 31.9k Aufrufe 31 Beobachtet
  • foxriver76F foxriver76
    @crunchip ja neuer Controller validiert die patterns
    Marty56
    #75
    Besteht mit der Version 5.0 eigentlich die Hoffnung, dass diese "Alias Error Bursts", die mich alle 2-3 Tage heimsuchen, aufhören.
    Das Error Log zeigt nur einen kleinen Ausschnitt. Es sind alle meine ca. 400 Aliases betroffen.
    Auswirkung auf die Funktion scheinen diese Fehlermeldung nicht zu haben. Sie nerven nur.
    2023-04-10 03:48:35.417 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.KEQ0971413.2.ENERGY_COUNTER, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","name":"K1_Waschen_Messen.ENERGY_COUNTER","role":"value.power.consumption"},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089040406,"_id":"hm-rpc.0.KEQ0971413.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2023-04-10 03:48:35.424 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.OEQ0125847.0.UNREACH, sourceObj={"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"role":"indicator.unreach","name":"Deckenlampe im Wohnzimmer:0.UNREACH"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089035775,"_id":"hm-rpc.0.OEQ0125847.0.UNREACH","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2023-04-10 03:48:35.425 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.OEQ0125847.2.STATE, sourceObj={"type":"state","common":{"def":false,"type":"boolean","read":true,"write":true,"role":"switch","name":"WZ_Deckenlampe.STATE"},"native":{"CONTROL":"SWITCH.STATE","DEFAULT":false,"FLAGS":1,"ID":"STATE","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089035853,"_id":"hm-rpc.0.OEQ0125847.2.STATE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2023-04-10 03:48:35.425 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.OEQ0125847.0.UNREACH, sourceObj={"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"role":"indicator.unreach","name":"Deckenlampe im Wohnzimmer:0.UNREACH"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089035775,"_id":"hm-rpc.0.OEQ0125847.0.UNREACH","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2023-04-10 03:48:35.425 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.LEQ0413828.1.LEVEL, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":true,"min":0,"max":100,"unit":"%","role":"level.blind","workingID":"WORKING","name":"K3_Fensteroeffner.LEVEL"},"native":{"CONTROL":"BLIND.LEVEL","DEFAULT":0,"FLAGS":1,"ID":"LEVEL","MAX":1,"MIN":0,"OPERATIONS":7,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"100%"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089036364,"_id":"hm-rpc.0.LEQ0413828.1.LEVEL","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2023-04-10 03:48:35.425 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.LEQ0413828.1.STOP, sourceObj={"type":"state","common":{"def":false,"type":"boolean","read":false,"write":true,"role":"button.stop","name":"K3_Fensteroeffner.STOP"},"native":{"CONTROL":"BLIND.STOP","DEFAULT":false,"FLAGS":1,"ID":"STOP","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":1,"TYPE":"ACTION","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089036367,"_id":"hm-rpc.0.LEQ0413828.1.STOP","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    HW:NUC (16 GB Ram)
    OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
    • crunchipC Offline
      crunchipC Offline
      #76
      @marty56 reine Vermutung von mir, da ich dieses Problem auch hatte.
      Es wurden immer unterschiedliche alias angemeckert, nicht immer die selben,
      daher die Frage, wie hast du die alias angelegt, per alias manager oder mit dem device Adapter? Letzterer hat sowieso ein Problem in der Version 1.1.2
      https://github.com/ioBroker/ioBroker.devices/issues/217
      zu Beginn hatte ich auch alias mit dem device adapter angelegt, aber dann zum alias manager gewechselt und somit auch alle bestehenden alias, die mit dem device adapter erstellt wurden, gelöscht und neu mit dem alias manager erstellt.
      Seit dem ist Ruhe.
      Vllt hat es auch Einfluss, wenn alias mit unterschiedlichen Adapter Versionen angelegt wurden.
      Kann Zufall sein oder ein möglicher Ansatz.
        Seit dem ist Ruhe.
        Marty56
        #77
        @crunchip Ich habe alle Aliases mit einem eigenenJavascript angelegt.
        HW:NUC (16 GB Ram)
        • M Marty56
          foxriver76F Offline
          foxriver76F Offline
          foxriver76
          #78
          @marty56 Heißt das, du hast die 5.0 Alpha laufen und bekommst die Meldungen weiterhin?
          Videotutorials & mehr
          • wendy2702W Online
            wendy2702W Online
            #79
            gerade den Master auf 5.0.1 angehoben:
            Web adapter crasht wegen Trashschedule fehler. Ich vermute das "ü" als Übeltäter wobei ich auch ein "ä" verwende was nicht angemeckert wird:
            2023-04-11 12:21:46.870  - error: web.0 (8220) uncaught exception: The pattern "trashschedule.0.type.Restmüll.daysleft" is not a valid ID pattern
            2023-04-11 12:21:46.873  - error: web.0 (8220) Error: The pattern "trashschedule.0.type.Restmüll.daysleft" is not a valid ID pattern
                at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2161:15)
                at pattern2RegEx (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/adapter-core/build/controllerTools.js:94:44)
                at SocketCommands.subscribe (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:267:13)
                at SocketCommands._subscribeStates (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:489:26)
                at commands.subscribe (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1356:25)
                at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1556:43)
                at Socket.emit (node:events:513:28)
                at /opt/iobroker/node_modules/socket.io/lib/socket.js:531:14
                at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
            2023-04-11 12:21:46.874  - error: web.0 (8220) The pattern "trashschedule.0.type.Restmüll.daysleft" is not a valid ID pattern
            Linux Control läuft nicht mehr zum steuern meiner Wandtablets
            mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker.current.log |grep linux
            2023-04-11 12:30:02.872  - info: host.iobroker instance system.adapter.linux-control.0 started with pid 8596
            2023-04-11 12:30:07.502  - warn: linux-control.0 (8596) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
            2023-04-11 12:30:07.503  - warn: linux-control.0 (8596) This object will not be created in future versions. Please report this to the developer.
            2023-04-11 12:30:07.544  - info: linux-control.0 (8596) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.linux-control, node: v18.14.2, js-controller: 5.0.1-alpha.0-20230406-4552d569
            2023-04-11 12:30:07.872  - warn: linux-control.0 (8596) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
            2023-04-11 12:30:07.893  - warn: linux-control.0 (8596) This object will not be created in future versions. Please report this to the developer.
            2023-04-11 12:30:07.990  - info: linux-control.0 (8596) getting data from VIS-OG (192.168.178.215:22, Adapter start)
            2023-04-11 12:30:08.000  - info: linux-control.0 (8596) getting data from VIS-EG (192.168.178.216:22, Adapter start)
            2023-04-11 12:30:24.355  - warn: host.iobroker-Server States 127.0.0.1:33208 Error from InMemDB: Error: The pattern "linux-control.0.VIS-OG.services.●.restart" is not a valid ID pattern
            2023-04-11 12:30:24.359  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-04-11 12:30:24.360  - error: linux-control.0 (8596) unhandled promise rejection: Error The pattern "linux-control.0.VIS-OG.services.●.restart" is not a valid ID pattern
            2023-04-11 12:30:24.361  - error: linux-control.0 (8596) ReplyError: Error The pattern "linux-control.0.VIS-OG.services.●.restart" is not a valid ID pattern
            2023-04-11 12:30:24.361  - error: linux-control.0 (8596) Error The pattern "linux-control.0.VIS-OG.services.●.restart" is not a valid ID pattern
            2023-04-11 12:30:24.380  - info: linux-control.0 (8596) cleaned everything up...
            2023-04-11 12:30:24.381  - info: linux-control.0 (8596) terminating
            2023-04-11 12:30:24.381  - warn: linux-control.0 (8596) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2023-04-11 12:30:24.385  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-04-11 12:30:24.386  - error: linux-control.0 (8596) unhandled promise rejection: The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
            2023-04-11 12:30:24.387  - error: linux-control.0 (8596) Error: The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
            2023-04-11 12:30:24.387  - error: linux-control.0 (8596) The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
            2023-04-11 12:30:24.401  - warn: host.iobroker-Server States 127.0.0.1:33208 Error from InMemDB: Error: The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
            2023-04-11 12:30:24.404  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-04-11 12:30:24.404  - error: linux-control.0 (8596) unhandled promise rejection: Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
            2023-04-11 12:30:24.405  - error: linux-control.0 (8596) ReplyError: Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
            2023-04-11 12:30:24.405  - error: linux-control.0 (8596) Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
            2023-04-11 12:30:24.736  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-04-11 12:30:24.737  - error: linux-control.0 (8596) unhandled promise rejection: The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
            2023-04-11 12:30:24.737  - error: linux-control.0 (8596) Error: The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
            2023-04-11 12:30:24.737  - error: linux-control.0 (8596) The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
            2023-04-11 12:30:24.783  - warn: host.iobroker-Server States 127.0.0.1:33208 Error from InMemDB: Error: The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
            2023-04-11 12:30:24.792  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-04-11 12:30:24.792  - error: linux-control.0 (8596) unhandled promise rejection: Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
            2023-04-11 12:30:24.793  - error: linux-control.0 (8596) ReplyError: Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
            2023-04-11 12:30:24.793  - error: linux-control.0 (8596) Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
            2023-04-11 12:30:24.888  - info: linux-control.0 (8596) terminating
            2023-04-11 12:30:24.900  - warn: linux-control.0 (8596) get state error: Connection is closed.
            2023-04-11 12:30:24.907  - error: linux-control.0 (8596) [servicesInfo] VIS-OG (192.168.178.215:22): error: DB closed, stack: Error: DB closed
            2023-04-11 12:30:25.038  - error: linux-control.0 (8596) [userCommandExecute] VIS-OG (192.168.178.215:22): datapoint-id: VIS_OG_ScreenOff, description: ViS-OG_ScreenOff
            2023-04-11 12:30:25.039  - error: linux-control.0 (8596) [userCommandExecute] VIS-OG (192.168.178.215:22): error: DB closed, stack: Error: DB closed
            2023-04-11 12:30:25.041  - error: linux-control.0 (8596) [userCommandExecute] VIS-OG (192.168.178.215:22): datapoint-id: VIS_OG_ScreenOn, description: VIS-OG_ScreenOn
            2023-04-11 12:30:25.042  - error: linux-control.0 (8596) [userCommandExecute] VIS-OG (192.168.178.215:22): error: DB closed, stack: Error: DB closed
            2023-04-11 12:30:25.494  - error: host.iobroker instance system.adapter.linux-control.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2023-04-11 12:30:25.502  - info: host.iobroker Restart adapter system.adapter.linux-control.0 because enabled
            Nehme an es liegt an dem "dicken" Punkt im Namen und ist ein Adapter issue, oder?
            Enigma 2 Adapter läuft nicht mehr:
            mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker.current.log |grep enigma
            2023-04-11 12:36:12.099  - info: host.iobroker instance system.adapter.enigma2.0 started with pid 8762
            2023-04-11 12:36:12.802  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js
            2023-04-11 12:36:12.802  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js
            2023-04-11 12:36:12.802  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25)
            2023-04-11 12:36:12.805  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js',
            2023-04-11 12:36:12.805  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/main.js'
            2023-04-11 12:36:12.805  - error: host.iobroker instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2023-04-11 12:36:12.812  - info: host.iobroker Rebuild for adapter system.adapter.enigma2.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
            2023-04-11 12:36:28.124  - info: host.iobroker "system.adapter.enigma2.0" disabled
            2023-04-11 12:36:34.443  - info: host.iobroker "system.adapter.enigma2.0" enabled
            2023-04-11 12:36:34.613  - info: host.iobroker instance system.adapter.enigma2.0 started with pid 8775
            2023-04-11 12:36:36.424  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js
            2023-04-11 12:36:36.425  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js
            2023-04-11 12:36:36.425  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25)
            2023-04-11 12:36:36.426  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js',
            2023-04-11 12:36:36.426  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/main.js'
            2023-04-11 12:36:36.426  - error: host.iobroker instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2023-04-11 12:36:36.426  - info: host.iobroker Rebuild for adapter system.adapter.enigma2.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
            EDIT: Ergänzung zum Enigma2 Adapter:
            2023-04-11 12:48:29.329  - info: trashschedule.0 (10113) [ical] configurured ical preview is 34 days - increase this value to find more events in the future
            2023-04-11 12:48:46.571  - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
            2023-04-11 12:48:46.776  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
            2023-04-11 12:48:47.781  - info: host.iobroker iobroker npm-rebuild: exit 0
            2023-04-11 12:48:47.972  - info: host.iobroker instance system.adapter.enigma2.0 started with pid 10173
            2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1078
            2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]:   throw err;
            2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]:   ^
            2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
            2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]: Require stack:
            2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js
            2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js
            2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
            2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:920:27)
            2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1141:19)
            2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:110:18)
            2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25)
            2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1254:14)
            2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
            2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1117:32)
            2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:958:12)
            2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1141:19) {
            2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
            2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]:   requireStack: [
            2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js',
            2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/main.js'
            2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]:   ]
            2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]: }
            2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]: Node.js v18.14.2
            2023-04-11 12:48:49.186  - error: host.iobroker instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2023-04-11 12:48:49.186  - info: host.iobroker Adapter system.adapter.enigma2.0 needs rebuild and will be restarted afterwards.
            2023-04-11 12:48:49.186  - info: host.iobroker system.adapter.enigma2.0 will be rebuilt
            2023-04-11 12:48:49.186  - warn: host.iobroker adapter "enigma2" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
            2023-04-11 12:48:49.187  - info: host.iobroker iobroker rebuild
            2023-04-11 12:48:52.129  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
            • wendy2702W wendy2702
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              #80
              @wendy2702 Legt Trashschedule wirklich States mit Umlauten an? Sollte eigentlich nicht möglich sein und entsprechend sollte der Adapter auch den subscribe entsprechend anpassen.
              Die anderen beiden sind sicher Adapter Issues.
                wendy2702W Online
                wendy2702W Online
                #81
                @foxriver76 Ja, legt der Adapter an:
                Zum Enigma2 Adapter: habe den zum testen mal komplett gelöscht, also Instanz und Adapter. Jetzt kann ich ihn nicht mehr installieren:
                2023-04-11 12:54:08.072  - info: host.iobroker iobroker add enigma2 auto --host iobroker --debug
                2023-04-11 12:54:11.281  - error: host.iobroker iobroker host.iobroker Unknown packetName enigma2. Please install packages from outside the repository using npm!
                2023-04-11 12:54:12.335  - info: host.iobroker iobroker exit 12
                EDIT: OK, der hing wohl noch im Cache in der Anzeige der verfügbaren Adapter.
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  #82
                  @wendy2702 enigma2 ist nicht im offiziellen Repo
                    wendy2702W Online
                    wendy2702W Online
                    #83
                    @foxriver76 Ja, ist mir dann auch wieder auf/eingefallen.
                    Komplette neu installation leider auch erfolglos. Da, der Adapter wenn ich das richtig sehe nicht mehr gepflegt wird, es hier doch einige User gibt sollte man eventuell einen Hinweis geben oder bin ich der einzige bei dem er mit Controller V5 nicht mehr läuft ?
                      #84
                      @wendy2702
                      Arbeit am Adapter enigma2 abgebrochen. Projekt Übernehmer gesucht!
                      Sieht sehr eindeutig nach verwaist aus.
                      • foxriver76F Offline
                        foxriver76F Offline
                        foxriver76
                        #85
                        @wendy2702 Wird bei keinem laufen, lässt sich relativ einfach fixen. Habe gesehen dass nicht gepflegt, wäre gut wenn der damalige Entwickler den Adapter wie vorgeschlagen in community-adapters übergibt.
                        Ok, Umlaute sind tatsächlich nicht verboten, entsprechend sollte Pattern auch nicht meckern bei einem richtigen ü. Allerdings scheint der Adapter dein ü als ü zu speichern, evtl Encoding-Problem beim Speichern der Daten vom Frontend. Damit auch Adapter Fehler.
                        Enigma 2 kann ich vorbereiten, allerdings muss der Dev mergen.
                          wendy2702W Online
                          wendy2702W Online
                          #86
                          @foxriver76 OK.
                          Und was genau heisst das jetzt für den Trashschedule Adapter?
                          foxriver76F 3 Antworten Letzte Antwort
                            @foxriver76 OK.
                            foxriver76F Offline
                            foxriver76F Offline
                            foxriver76
                            #87
                            @wendy2702 Issue anlegen bitte
                              @foxriver76 OK.
                              foxriver76F Offline
                              foxriver76F Offline
                              foxriver76
                              #88
                              @wendy2702 Probier gerne mal Enigma von folgender URL: https://github.com/foxriver76/ioBroker.enigma2
                              PR ist gestellt: https://github.com/Matten-Matten/ioBroker.enigma2/pull/63
                                @foxriver76 OK.
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                schrieb am zuletzt editiert von foxriver76
                                #89
                                Edit: ne doch issue erstellen ;-)
                                • wendy2702W Online
                                  wendy2702W Online
                                  #90
                                  @foxriver76 sagte in Alpha Test js-controller 5.0:
                                  Dein PR ist gemerged und der Adapter läuft mit JS 5.0.1
                                  Bin gestern zurück auf JS 4.0.24 und jetzt wieder auf 5.0.1.
                                  EDIT: Trashschedule Fehler ist noch vorhanden, zeigt sich aber heute Hartnäckig.
                                  Nachdem das entfernen der Umlaute nicht geholfen hat, habe ich die Trashschedule Instanz gestoppt.
                                  Alle Objekte gelöscht
                                  aber der WEB Adapter meckert immer noch:
                                  2023-04-12 09:53:28.585  - error: web.0 (32727) uncaught exception: The pattern "trashschedule.0.type.Restmüll.daysleft" is not a valid ID pattern
                                  2023-04-12 09:53:28.586  - error: web.0 (32727) Error: The pattern "trashschedule.0.type.Restmüll.daysleft" is not a valid ID pattern
                                  2023-04-12 09:53:28.587  - error: web.0 (32727) The pattern "trashschedule.0.type.Restmüll.daysleft" is not a valid ID pattern
                                    foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    #91
                                    @wendy2702 ah das war ja nicht von trashschedule selbst sondern von web. Dann kommts vermutlich von vis oder web direkt.
                                    Bitte bei web Issue anlegen.
                                      wendy2702W Online
                                      wendy2702W Online
                                      #92
                                      @foxriver76 Das Problem lag am Ende scheinbar daran das in VIS Widgets nach dem Upgrade auf JS5.0.1 das hier z.B. drin steht bzw. er das anmeckert.
                                      Zeile  87403:           "color": "{wert:trashschedule.0.type.Restmüll.daysleft; wert<2 ? \"#ff0000\" :: wert == 2 ? \"#f3f60e\" :: \"#ffffff\"}",
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        #93
                                        @wendy2702 ah perfekt dass du es gefunden hast. Funktioniert es mit einem ü nicht oder warum der Escape?
                                          wendy2702W Online
                                          wendy2702W Online
                                          #94
                                          @foxriver76 Da stand eigentlich bis zu irgendeinem Upgrade ein "ü" welches dann nach Upgrade von was auch immer von alleine in das "ü" geändert.
                                          Habe jetzt in Trashschedule und in den Widgets erstmal das "ü" und das "ü" mit "ue" ersetzt.
                                          Muss mal testen ob es auch funktioniert wenn überall wieder das "ü" steht.
