    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • draexlerD draexler
    @armilar
    export const config = <Config> {
        panelRecvTopic: 'mqtt.0.tasmota.NSPanel_Buero.tele.RESULT',       // Bitte anpassen
        panelSendTopic: 'mqtt.0.tasmota.NSPanel_Buero.cmnd.CustomSend',   // Bitte anpassen
    Bildschirmfoto 2023-04-08 um 18.13.36.pngBildschirmfoto 2023-04-08 um 18.14.16.png
      "common": {
        "name": "CustomSend",
        "desc": "Manuell erzeugt",
        "role": "state",
        "type": "string",
        "read": true,
        "write": true,
        "def": ""
      "type": "state",
      "native": {},
      "user": "system.user.admin",
      "ts": 1680882985700,
      "_id": "mqtt.0.tasmota.NSPanel_Buero.cmnd.CustomSend",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
    Beim Starten des Skripts:
    javascript.0
    2023-04-08 18:14:43.893	info	script.js.common.NSPanels.NSPanel_Buero: Installed TFT Firmware: 50 / v4.0.5
    javascript.0
    2023-04-08 18:14:43.893	info	script.js.common.NSPanels.NSPanel_Buero: Desired TFT Firmware: 50 / v4.0.5
    javascript.0
    2023-04-08 18:14:43.567	info	script.js.common.NSPanels.NSPanel_Buero: registered 28 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
    javascript.0
    2023-04-08 18:14:43.525	info	script.js.common.NSPanels.NSPanel_Buero: weather alias for accuweather.0. already exists
    javascript.0
    2023-04-08 18:14:43.503	info	script.js.common.NSPanels.NSPanel_Buero: setObjects enabled - create Alias Channels possible
    javascript.0
    2023-04-08 18:14:43.407	info	script.js.common.NSPanels.NSPanel_Buero: source code did not change, using cached compilation result...
    javascript.0
    2023-04-08 18:14:42.967	info	script.js.common.NSPanels.NSPanel_Buero: compiling TypeScript source...
    javascript.0
    2023-04-08 18:14:41.343	info	Stop script script.js.common.NSPanels.NSPanel_Buero
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #2789
    @draexler
    Das Script arbeitet. Nimm mal den haken in der MQTT-Instanz raus:
    Ggfs. danach noch mal den MQTT durchstarten
    draexlerD 1 Antwort Letzte Antwort
    • ArmilarA Armilar
      @draexler
      draexlerD Offline
      draexlerD Offline
      draexler
      #2790
      @armilar Tja, was soll man sagen... Das wars. Bist einfach super :-) Genau deswegen gefällt mir der ioBroker so gut. Wegen der SUPER Community.
      Nochmal DANKE :-)
        Nochmal DANKE :-)
        draexlerD Offline
        draexlerD Offline
        draexler
        #2791
        Aber für Dummies. Wie sendet denn der MQTT dann jetzt?
        Die Einstellung war -> Nur bei Änderungen publizieren, was ja bedeutet nur wenn sich der Datenpunkt ändert... und jetzt? Jede Sekunde, alle 10 Minuten?!?
        ArmilarA J 2 Antworten Letzte Antwort
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          #2792
          @draexler
          Habe den Sinn hinter der Programmierung dieses Hakens nie verstanden ;-)
          Nur das er irgendwie nicht das tut was er beschreibt 😕
          • A australien
            @tt-tom
            Das klingt nach einem Plan, zeitlich kein Stress!
            Die Richtung als Unterschrift ist auch gut.
            TT-Tom
            #2793
            @australien
            so es gibt die erste Version von der Einbindung des Adapter Fahrplan.
            benötigt wird dieses externe Script, welches die Daten aus dem Ordner "DepatureTimetableX.JSON" ausliest und für das Panel aufbereitet. Das Script liest maximal 6 Abfahrten pro Abfahrtstafel aus. Das Icon und die Farbe wird aus den Daten ermittelt. Grün alles okay / Rot Verspätung. Zur Zeit wird die Anzeige noch über die CradEntities realisiert und dadurch nur die ersten 4 Abfahrten dargestellt.
            Die PageConfig für die erste Abfahrttafel sieht wie folgt aus:
            let FahrplanEntities0 = <PageEntities>
                    'type': 'cardEntities',
                    'heading': 'Eisenstadt ',
                    'useColor': true,
                    'items': [
                        <PageItem>{ id: AliasUserPath + 'FahrplanAnzeiger.Haltestelle0.Abfahrt0', name: "getState('alias.0.FahrplanAnzeiger.Haltestelle0.Abfahrt0.Richtung').val"},
                        <PageItem>{ id: AliasUserPath + 'FahrplanAnzeiger.Haltestelle0.Abfahrt1', name: "getState('alias.0.FahrplanAnzeiger.Haltestelle0.Abfahrt1.Richtung').val"},
                        <PageItem>{ id: AliasUserPath + 'FahrplanAnzeiger.Haltestelle0.Abfahrt2', name: "getState('alias.0.FahrplanAnzeiger.Haltestelle0.Abfahrt2.Richtung').val"},
                        <PageItem>{ id: AliasUserPath + 'FahrplanAnzeiger.Haltestelle0.Abfahrt3', name: "getState('alias.0.FahrplanAnzeiger.Haltestelle0.Abfahrt3.Richtung').val"},
                        <PageItem>{ id: AliasUserPath + 'FahrplanAnzeiger.Haltestelle0.Abfahrt4', name: "getState('alias.0.FahrplanAnzeiger.Haltestelle0.Abfahrt4.Richtung').val"},
                        <PageItem>{ id: AliasUserPath + 'FahrplanAnzeiger.Haltestelle0.Abfahrt5', name: "getState('alias.0.FahrplanAnzeiger.Haltestelle0.Abfahrt5.Richtung').val"}
            Das Script kann mehrere Abfahrtstafeln überwachen, einzustellen im Script unter
            const AnzahlHaltestellen: number = 3;               // Anzahl der Haltestellen / Anzeigetafeln
            einzige Bedingung -> sie müssen am Anfang in der Adapterconfig stehen und fortlaufend sein.
            weitere Einstellungen sind
            const DP_NSPanel: string = '0_userdata.0.NSPanel.1.';        // Standard 0_userdata.0.NSPanel.1.
            const DP_userdata: string = '0_userdata.0.';        // Pafad unter 0_userdata.0    Automatisch wird "FahrplanAnzeiger.HaltestelleX.AbfahrtX" durch das Script erzeugt
            const DP_AliasNSPanel: string = 'alias.0.';         // Pfad unter alias.0    Automatisch wird "FahrplanAnzeiger.HaltestelleX.AbfahrtX" durch das Script erzeugt
            const VerspätungPopup: boolean = true;              // Bei Verspätung soll PopupNotifypage auf dem Panel angezeigt werden
            Das Script kann auf Wunsch auch eine PopupNotifyPage bei einer Verspätung erzeugen.
            Das ist lauffähig ab NSPanel Script Version 4.0.5.5 kommt die Tage
            weitere Erläuterungen folgen im Wiki unter FAQ & Anleitungen
            Gruß Tom
            Public Transport
            NSPanel Adapter Wiki
            • eierfeileE Offline
              eierfeileE Offline
              eierfeile
              schrieb am zuletzt editiert von eierfeile
              #2794
              Hi, bin neu im NSPanel Thema. Hab Tasmota und Lovelace installiert. Es soll mein bestehendes Wandthermostat ersetzen. Würde daher auch das Relais1 vom NSPanel zum automatischen ein- und ausschalten der Heizung nutzen. Dachte das müsste einfach gehen. Ist aber bis jetzt nicht wirklich trivial ;-). Aber wird schon!
              Also Alias für Thermostat hab ich erstellt.
              Code sieht aktuell so aus:
              let Kueche_Themostat = <PageThermo>
                  'type': 'cardThermo',
                  'heading': 'Thermostat Kueche',
                  'useColor': true,
                  'subPage': false,
                  'parent': undefined,
                  'items': [<PageItem>{
                              minValue: 50,
                              maxValue: 300,
                              stepValue: 5,
                            //  setThermoDestTemp2: 'ACTUAL1'
              Aber ich sehe nicht mal die Karte im Panel? Was mach ich denn falsch?
              • eierfeileE eierfeile
                    'useColor': true,
                    'subPage': false,
                                minValue: 50,
                                maxValue: 300,
                                stepValue: 5,
                ArmilarA Offline
                ArmilarA Offline
                Armilar
                #2795
                @eierfeile sagte in SONOFF NSPanel mit Lovelace UI:
                Kueche_Themostat
                Gibt es denn Kueche_Themostat als Page in der Config-Auflistung?
                eierfeileE 1 Antwort Letzte Antwort
                • ArmilarA Armilar
                  Kueche_Themostat
                  eierfeileE Offline
                  eierfeileE Offline
                  eierfeile
                  #2796
                  @armilar jap ist drin...hab erst mal alles nur auskommentiert was ich nicht brauche. Wird später gelöscht. b0009a68-f57f-4e9d-a78e-0c00e5d0cf56-image.png
                    ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    #2797
                    @eierfeile
                    Sieht aber soweit erstmal okay aus...
                    Der Setpoint ist erreichbar und enthält einen numerischen Wert?
                    Gibt es Warnungen oder Fehler im Log?
                    • ArmilarA Armilar
                      @eierfeile
                      eierfeileE Offline
                      eierfeileE Offline
                      eierfeile
                      #2798
                      @armilar paar Warnungen hab ich noch drin. Die kann ich aber nicht deuten.
                      Mit Setpoint meinst du vermutlich das hier:
                      Der ist "0". Den Wert wollte ich künftig über das cardThermo pflegen....falls das geht?
                        ArmilarA Offline
                        ArmilarA Offline
                        Armilar
                        #2799
                        @eierfeile
                        Da ist in den Chart-Pages ein Fehler
                        Kommentier mal alle Seiten bis auf die cardThermo aus
                        Ja der Setpoint wird auch über die cardThermo gesteuert...
                          joBr99
                          #2800
                          @draexler
                          Nein, ohne "Nur Änderungen publizieren" sendet er die MQTT Nachrichten so wie sie tatsächlich kommen, also bei jedem Event.
                          Stell dir nen Button vor, immer wenn er gedrückt wird kommt nen Event, die Nachricht ist aber immer die gleiche. Bei nem Schalter würdest du auch bei jedem Schalten eine Event haben, aber die Nachricht ändert sich von an auf aus.
                            Bhenyamin
                            schrieb am zuletzt editiert von Bhenyamin
                            #2801
                            Tach zusammen,
                            nachdem ich mein Panel jetzt vor gut einer Woche mal in den Feldversuch (in die Wand) genommen habe zeigen sich die ersten kleinen Schwächen - auch wenn ich insg. sehr zufrieden bin.
                            Ich habe aktuell nur 2 Hauptseiten + die NSPanel_Einstellungen Seite - alles weitere als Subpages darunter geordnet.
                            pages: [
                                        FavKitchen
                                        KitchenTopMenu
                                        NSPanel_Service                            	//Auto-Alias Service Page
                                subPages: [
                                            NSPanel_Infos,                          //Auto-Alias Service Page
                                                NSPanel_Wifi_Info_1,                //Auto-Alias Service Page
                                                NSPanel_Wifi_Info_2,                //Auto-Alias Service Page
                                                NSPanel_Sensoren,                   //Auto-Alias Service Page
                                                NSPanel_Hardware,                   //Auto-Alias Service Page
                                            NSPanel_Einstellungen,                  //Auto-Alias Service Page
                                                NSPanel_Screensaver,                //Auto-Alias Service Page
                                                    NSPanel_ScreensaverDimmode,     //Auto-Alias Service Page
                                                    NSPanel_ScreensaverBrightness,  //Auto-Alias Service Page
                                                    NSPanel_ScreensaverLayout,      //Auto-Alias Service Page
                                                    NSPanel_ScreensaverWeather,     //Auto-Alias Service Page
                                                    NSPanel_ScreensaverDateformat,  //Auto-Alias Service Page
                                                    NSPanel_ScreensaverIndicators,  //Auto-Alias Service Page
                                                NSPanel_Relays,                     //Auto-Alias Service Page
                                            NSPanel_Firmware,                       //Auto-Alias Service Page
                                                NSPanel_FirmwareTasmota,            //Auto-Alias Service Page
                                                NSPanel_FirmwareBerry,              //Auto-Alias Service Page
                                                NSPanel_FirmwareNextion,            //Auto-Alias Service Page
                                            FavLichtWzEzK                           //Favoitenmenü Lichtszenen Wohnbereich
                                                FavLichtWzEzKSingle,                    //NUR aus Favoritenmenü heraus: Einzelsteuerung Licht Wohnbereich
                                            FavKinder
                                        Haus                                        //Top-Menü Haus Strg.
                                            OG,                                     //Obergeschoss Mainpage
                                                Bad,                                //Bad
                                                    BadRadiator,                    //Heizkörper Bad
                                                    BadFBH,                         // Fußbodenheizung Bad
                                                Schlafzimmer,                       //Schlafzimmer
        EG,                                     //Erdgeschoss Mainpage
                                                Wohnbereich,                        //Wohnbereich Wohnzimmer / Esszimmer / Küche Sublevel 1
                                                    LichtWzEzK,                     //Einzelsteuerung Licht Wohnzimmer / Esszimmer / Küche
                                                    RollosWzEzK,                    //Rollosteuerung WZ
                                                Hausflur,                           //Gesamter Hausflur
                                                Büro,                               //Büro
                                                Gästebad,                           //Gäste Bad (WC) Erdgeschoss
                                            Garage,                                 //Garage
                                            Aussen,                                 //Außenbereich
                                            Photovoltaik,                           //Übersicht PV
                                            Abfall                                  //Abfallkalender
                            Wenn ich nun per Doppeltippen aus dem Screensaver raus komme, lande ich auf der Favoritenseite "FavKitchen".
                            Pfeil rechts bringt mich auch (meist) zur 2. Hauptseite "KitchenTopMenu" von wo aus ich alles weitere verzweige.
                            Leider nur meistens: Oft springt er beim 2. Druck auf den Rechtspfeil auch direkt auf die NSPanel Einstellungen, sodass ich dann noch 2 x nach rechts drücken muss um auf die gewünscht KitchenTopMenu Seite zu kommen. Ich komme nur nicht dahinter, woran es liegen kann. Auch habe ich immer mal Hänger, bei denen ich bis zum nächsten Screensaver einfach einen Blankscreen bekomme.
                            Noch habe ich meine bessere Hälfte nicht umfassend in die Bedienung eingeführt - dafür muss es erst reibungslos laufen um die Akzeptanz nicht unnötig zu kompromittieren 😬
                            Vielleicht habt ihr 'ne Idee?
                            • B Bhenyamin
                              Tach zusammen,
                              pages: [
                                          FavKitchen
                                          KitchenTopMenu
                                  subPages: [
                                              FavKinder
                                                  Bad,                                //Bad
                                                  Büro,                               //Büro
                                              Garage,                                 //Garage
                              TT-Tom
                              #2802
                              @bhenyamin
                              mir ist auf gefallen, das bei deinen Hauptseiten das Komma fehlt. zeige mal bitte auch die Config der beiden Seiten.
                              Gruß Tom
                              Public Transport
                              ArmilarA B 2 Antworten Letzte Antwort
                              • T TT-Tom
                                @bhenyamin
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                #2803
                                @tt-tom
                                @Bhenyamin
                                Bei den Subpages fehlen zum Teil auch die Kommas, z.B. bei:
                                • FavLichtWzEzK
                                • FavKinder
                                • Haus
                                Der Blankscreen ist oft eine schlechte WLAN-Verbindung. Alternativ, wenn zu viele Seiten auf einmal aufgerufen werden.
                                • madingM Offline
                                  madingM Offline
                                  mading
                                  schrieb am zuletzt editiert von mading
                                  #2804
                                  Moin zusammen,
                                  ich habe erfolgreich das Skript auf 4.0.5.2 gehoben. Das Panel zeigt auch alles im Advanced Screensaver an. Echt tolle Arbeit, Armilar! Habe dir einen Obulus per Paypal geschickt.
                                  Zwei Fragen: Gerne würde ich für die aktuelle Temperatur meinen Datenpunkt nehmen, statt dem von daswetter. Kann ich das anpassen?
                                  Ich passe für mich den DP 0_userdata.0.NSPanel.1.ScreensaverInfo.activeDimmodeBrightness an, so dass im Screensaver das Display nicht zu dunkel ist. Sobald ich das ts Skript anpasse, zieht er den Parameter aber nicht mehr und das Display ist viel dunkler. Erst wenn ich den Wert im DP wieder anpasse, ist das Display wieder im Screensaver heller. Ist das schon einmal aufgefallen?
                                  Eine weitere Frage habe ich: bei Waschmaschine und Trockner funktioniert es, dass wenn sie aus sind, die "Off-Icons" angezeigt werden. Beim Plug Stat (mqtt.0.openWB.lp.1.boolPlugStat) nicht. Kann es daran liegen, dass es kein true/ false ist sondern 0/1? Der Datenpunkt ist definitiv 0, zeigt aber das Icon power-plug-outline an.
                                  indicatorScreensaverEntity:
                                              //icons mitte unter Uhr
                                              // indicatorScreensaverEntity 1 (only Advanced Screensaver)
                                                  ScreensaverEntity: 'viessmannapi.0.64851.0.features.heating.compressors.0.properties.active.value',
                                                  ScreensaverEntityFactor: 1,
                                                  ScreensaverEntityDecimalPlaces: 0,
                                                  ScreensaverEntityIconOn: 'heat-pump-outline',
                                                  ScreensaverEntityIconOff: 'heat-pump',
                                                  ScreensaverEntityText: 'Heizung',
                                                  ScreensaverEntityUnitText: null,
                                                  ScreensaverEntityIconColor: { 'val_min': 0, 'val_max': 1 }
                                              // indicatorScreensaverEntity 2 (only Advanced Screensaver)
                                                  ScreensaverEntity: 'hm-rpc.0.000F1D898C4EA9.1.MOTION',
                                                  ScreensaverEntityIconOn: 'garage-open',
                                                  ScreensaverEntityIconOff: 'garage-variant',
                                                  ScreensaverEntityText: 'Garage',
                                                  ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 1}
                                              // indicatorScreensaverEntity 3 (only Advanced Screensaver)
                                                  ScreensaverEntity: 'mqtt.0.openWB.lp.1.boolPlugStat',
                                                  ScreensaverEntityIconOn: 'power-plug-outline',
                                                  ScreensaverEntityIconOff: 'power-plug-off-outline',
                                                  ScreensaverEntityText: 'verbunden',
                                                  //ScreensaverEntityIconColor: { 'val_min': 0, 'val_max': 1 }
                                              // indicatorScreensaverEntity 4 (only Advanced Screensaver)
                                                  ScreensaverEntity: '0_userdata.0.EigeneDatenpunkte.Tasmota.WaschmaschineLaeuft',
                                                  ScreensaverEntityIconOn: 'washing-machine',
                                                  ScreensaverEntityIconOff: 'washing-machine-off',
                                                  ScreensaverEntityText: 'Wama',
                                                  ScreensaverEntityIconColor: { 'val_min': 1, 'val_max': 0 }
                                              // indicatorScreensaverEntity 5 (only Advanced Screensaver)
                                                  ScreensaverEntity: '0_userdata.0.EigeneDatenpunkte.Tasmota.TrocknerLaeuft',
                                                  ScreensaverEntityIconOn: 'tumble-dryer',
                                                  ScreensaverEntityIconOff: 'tumble-dryer-off',
                                                  ScreensaverEntityText: 'Trockner',
                                                  ScreensaverEntityUnitText: '%',
                                  • T TT-Tom
                                    @australien
                                            'useColor': true,
                                            'items': [
                                    australien
                                    schrieb am zuletzt editiert von australien
                                    #2805
                                    @tt-tom
                                    Super! Danke, schaut sehr gut aus.
                                    Leider wird bei mir nichts angezeigt, ausser Warnungen beim Compilieren.
                                    Das Display am NSPanel beleibt leer, obwohl die aliase mit dem Script befühlt werden.
                                    Egal ob ich es mit der Version aus den FAQ oder denen hier versuche.
                                    Nachsatz, bei einer Verspätung kommt die Subpage.
                                    • madingM mading
                                      Moin zusammen,
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      #2806
                                      @mading
                                      Jederzeit. Einfach den Datenpunkt mit der Temperatur austauschen
                                      Ich denke du meinst den Neustart des Scriptes. Der Datenpunkt 0_userdata.0.NSPanel.1.ScreensaverInfo.activeDimmodeBrightness wird aktuell im Zuge eines Scriptstarts nicht berücksichtigt, sondern nur wenn der Trigger Änderungen erfasst --> Wird kurzfristig in die nächste Version kommen...
                                      Muss ein Boolean, d.h. true/false sein.
                                      Zwei Möglichkeiten:
                                      • du machst aus dem mqtt.0 Datenpunkt ein einen boolschen DP oder
                                      • du legst einen Alias an und konvertierst die 0 und 1 über die Funktion zu true und false.
                                      madingM 1 Antwort Letzte Antwort
                                      • ArmilarA Armilar
                                        @mading
                                        Zwei Möglichkeiten:
                                        madingM Offline
                                        madingM Offline
                                        mading
                                        #2807
                                        @armilar danke dir. das mit der Brightness wäre super, wenns rein käme. Alias habe ich angelegt und funktioniert, danke. Das mit dem eigenen Alias für das Wetter hatte ich bei der Skript Migration vergessen und generell nicht mehr daran gedacht. Nun ist es perfekt, danke!
                                        • A australien
                                          @tt-tom
                                          TT-Tom
                                          #2808
                                          @australien
                                          Welche Version von meinem Script hast du aktuell??
                                          Und welche Version vom Panel??
                                          Gruß Tom
                                          Public Transport
