  4. Test Adapter vis 2.0 (Alpha)
    6.7k
780 Beiträge 108 Kommentatoren 352.2k Aufrufe 140 Beobachtet
  • sigi234S sigi234
    @manfredhi sagte in Test Adapter vis 2.0 (Alpha):
    Was muss ich tun damit es funktioniert?
    Welche Version vom WEB Adapter hast du?
    ManfredHi
    #587
    @sigi234 sagte in Test Adapter vis 2.0 (Alpha):
    Version 5.4.1
    • M ManfredHi
      Version 5.4.1
      sigi234S Online
      sigi234S Online
      #588
      Version 5.4.1
      Ok, was sagt F12 ?
      • sigi234S sigi234
        Version 5.4.1
        Ok, was sagt F12 ?
        ManfredHi
        #589
        @sigi234
        iobroker.vis-2-beta@2.0.24 using theme "colored"
        main.9e02fddc.js:658
        main.9e02fddc.js:658 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
        main.9e02fddc.js:658 Help us to create open source project with reactJS!
        main.9e02fddc.js:658 See you :)
        socket.io.js:66 [2023-04-05T14:54:59.516Z] Try to connect
        socket.io.js:67
               [2023-04-05T14:55:02.540Z] No READY flag received in 3 seconds. Re-init
        warn @ socket.io.js:67
        (anonym) @ socket.io.js:148
        socket.io.js:397
               WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706499516&name=vis-2-beta' failed: WebSocket is closed before the connection is established.
        SocketClient.close @ socket.io.js:397
        (anonym) @ socket.io.js:149
        socket.io.js:66 [2023-04-05T14:55:02.540Z] Start reconnect 0
        socket.io.js:68
               [2023-04-05T14:55:02.541Z] ws connection error: CLOSE_ABNORMAL
        error @ socket.io.js:68
        socket.onclose @ socket.io.js:177
        socket.io.js:66 [2023-04-05T14:55:02.541Z] Reconnect is already running 0
        socket.io.js:66 [2023-04-05T14:55:02.542Z] Try to connect
        socket.io.js:67
               [2023-04-05T14:55:05.543Z] No READY flag received in 3 seconds. Re-init
        setTimeout (asynchron)
        SocketClient.connect @ socket.io.js:146
        (anonym) @ socket.io.js:432
        SocketClient._reconnect @ socket.io.js:427
        SocketClient.close @ socket.io.js:411
        socket.onerror @ socket.io.js:189
        socket.io.js:397
               WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706502542&name=vis-2-beta' failed: WebSocket is closed before the connection is established.
        socket.io.js:66 [2023-04-05T14:55:05.543Z] Start reconnect 1
        socket.io.js:68
               [2023-04-05T14:55:05.543Z] ws connection error: CLOSE_ABNORMAL
        socket.io.js:66 [2023-04-05T14:55:05.543Z] Reconnect is already running 1
        socket.io.js:66 [2023-04-05T14:55:06.544Z] Try to connect
        socket.io.js:140
               WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706506544&name=vis-2-beta' failed:
        SocketClient.connect @ socket.io.js:140
        socket.io.js:66 [2023-04-05T14:55:08.839Z] Start reconnect 2
        socket.io.js:68
               [2023-04-05T14:55:08.839Z] ws connection error: CLOSE_ABNORMAL
        socket.io.js:66 [2023-04-05T14:55:08.839Z] Reconnect is already running 2
        socket.io.js:66 [2023-04-05T14:55:10.841Z] Try to connect
        socket.io.js:140
               WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706510841&name=vis-2-beta' failed:
        socket.io.js:66 [2023-04-05T14:55:13.286Z] Start reconnect 3
        socket.io.js:68
               [2023-04-05T14:55:13.287Z] ws connection error: CLOSE_ABNORMAL
        socket.io.js:66 [2023-04-05T14:55:13.287Z] Reconnect is already running 3
        socket.io.js:66 [2023-04-05T14:55:16.289Z] Try to connect
        socket.io.js:140
               WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706516289&name=vis-2-beta' failed:
        socket.io.js:66 [2023-04-05T14:55:18.584Z] Start reconnect 4
        socket.io.js:68
               [2023-04-05T14:55:18.584Z] ws connection error: CLOSE_ABNORMAL
        socket.io.js:66 [2023-04-05T14:55:18.584Z] Reconnect is already running 4
        socket.io.js:66 [2023-04-05T14:55:22.586Z] Try to connect
        socket.io.js:67
               [2023-04-05T14:55:25.587Z] No READY flag received in 3 seconds. Re-init
        error (asynchron)
        SocketClient.connect @ socket.io.js:182
        error (asynchron)
        error (asynchron)
        error (asynchron)
        socket.io.js:397
               WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706522586&name=vis-2-beta' failed: WebSocket is closed before the connection is established.
        error (asynchron)
        error (asynchron)
        error (asynchron)
        error (asynchron)
        socket.io.js:66 [2023-04-05T14:55:25.587Z] Start reconnect 5
        socket.io.js:68
               [2023-04-05T14:55:25.587Z] ws connection error: CLOSE_ABNORMAL
        error (asynchron)
        error (asynchron)
        error (asynchron)
        error (asynchron)
        socket.io.js:66 [2023-04-05T14:55:25.587Z] Reconnect is already running 5
        socket.io.js:66 [2023-04-05T14:55:30.588Z] Try to connect
        socket.io.js:140
               WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706530588&name=vis-2-beta' failed:
        socket.io.js:66 [2023-04-05T14:55:32.871Z] Start reconnect 5
        socket.io.js:68
               [2023-04-05T14:55:32.871Z] ws connection error: CLOSE_ABNORMAL
        socket.io.js:66 [2023-04-05T14:55:32.871Z] Reconnect is already running 5
        socket.io.js:66 [2023-04-05T14:55:37.872Z] Try to connect
        socket.io.js:140
               WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706537872&name=vis-2-beta' failed:
        socket.io.js:66 [2023-04-05T14:55:40.154Z] Start reconnect 5
        socket.io.js:68
               [2023-04-05T14:55:40.154Z] ws connection error: CLOSE_ABNORMAL
        socket.io.js:66 [2023-04-05T14:55:40.155Z] Reconnect is already running 5
        • M ManfredHi
          @sigi234
          socket.io.js:67
          socket.io.js:397
          socket.io.js:68
          socket.io.js:67
          socket.io.js:397
          socket.io.js:68
          socket.io.js:140
          socket.io.js:68
          socket.io.js:140
          socket.io.js:68
          socket.io.js:140
          socket.io.js:68
          socket.io.js:67
          error (asynchron)
          error (asynchron)
          error (asynchron)
          error (asynchron)
          socket.io.js:397
          error (asynchron)
          error (asynchron)
          error (asynchron)
          error (asynchron)
          socket.io.js:68
          error (asynchron)
          error (asynchron)
          error (asynchron)
          error (asynchron)
          socket.io.js:140
          socket.io.js:68
          socket.io.js:140
          socket.io.js:68
          sigi234S Online
          sigi234S Online
          #590
          @manfredhi
          Zeig mal die Einstellungen vom WEB Adapter
          • sigi234S sigi234
            @manfredhi
            ManfredHi
            #591
            @sigi234
            • M ManfredHi
              @sigi234
              sigi234S Online
              sigi234S Online
              #592
              @manfredhi
              • sigi234S sigi234
                @manfredhi
                ManfredHi
                #593
                @sigi234
                Hab eine zweite web-Instanz mit den gleichen Einstellungen wie du über Port 9082.
                Da kommt folgendes:
                main.7b76ba87.js:658
                main.7b76ba87.js:658 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
                main.7b76ba87.js:658 Help us to create open source project with reactJS!
                main.7b76ba87.js:658 See you :)
                socket.io.js:66 [2023-04-05T15:19:38.123Z] Try to connect
                main.7b76ba87.js:658 Translate: background
                VM1641:402 Version eventlist: 1.0.1
                visEngine.jsx:1283
                       WTF?? in tplMaListDoor: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                (anonym) @ visEngine.jsx:1283
                visEngine.jsx:1283
                       WTF?? in tplMaListWindow: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListWindow3: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListTemp: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListHumid: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListPressure: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListTempHumid: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListPresence: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListOccupancy: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListLight: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListLightDim: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListLightKelvin: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListThermostat: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListWindowShutter: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListVolume: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListBoolean: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListNumber: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListText: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListValve: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                visEngine.jsx:1283
                       WTF?? in tplMaListGarage: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
                metro-bootstrap.css:1
                       Failed to load resource: the server responded with a status of 404 (Not Found)
                iconFont.min.css:1
                fritzdect.js:46 Version fritzdect: 0.0.2
                kodi.js:48 Version kodi: 2.0.0
                trashschedule.js:163 Version trashschedule: 2.2.0
                info.js:21 Version Info-Adapter-Widget: 0.0.9
                :9082/vis-2-beta/widgets/metro/js/metro.js:1
                :9082/vis-2-beta/adapter/template/words.js:1
                vis-material-advanced.js:184 Version vis-material-advanced: 1.6.0
                :9082/vis-2-beta/edi…r_hourly_Preise:410
                       Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
                    at JSON.parse (<anonymous>)
                    at getTranslation (info.js:13:47)
                iconFont.min.css:1
                sigi234S 2 Antworten Letzte Antwort
                • M ManfredHi
                  @sigi234
                  Da kommt folgendes:
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  visEngine.jsx:1283
                  iconFont.min.css:1
                  iconFont.min.css:1
                  sigi234S Online
                  sigi234S Online
                  #594
                  Port 9082.
                  • M ManfredHi
                    @sigi234
                    Da kommt folgendes:
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    visEngine.jsx:1283
                    iconFont.min.css:1
                    iconFont.min.css:1
                    sigi234S Online
                    sigi234S Online
                    #595
                    @manfredhi
                    Funktioniert es jetzt?
                    • sigi234S sigi234
                      Port 9082.
                      ManfredHi
                      #596
                      @sigi234
                      Ich habe zwei Web-Instanzen (einmal auf Port 8082 und einmal auf Port 9082) wegen dem Energieflussadapter.
                      Port 8082 ist mit ws.io.
                      Das brauch ich weil sonst der Energieflussadapter nicht funktioniert (geht nicht über ws.io). Und ohne ws.io habe ich die Probleme mit dem VIS-Editor (Verbindungsabbruch ....)
                      • sigi234S sigi234
                        @manfredhi
                        ManfredHi
                        #597
                        nein, hab den Web-Adapter nun auf Version 5.5.3 aktualisiert, aber ebenfalls ohne erfolg.
                        • M ManfredHi
                          Digi-Bit
                          #598
                          Abend.........
                          Den Schmarren hatte ich heute auch und hat mich 3 Stunden gekostet.....
                          Bei mir stand Kurz da, wo ich die VIS aufgerufen habe stand sowas wie " Updating VIS " oder sowas in dem dreh da was mich wunderte da ich schon einige Tage auf v .23 bin....
                          Und danach 3 stunden Schnecke egal was ich machte....
                          bei F12 war was mit Socket.io oder sowas was ich nun gar nicht wusste was das ist aber da steht viel was ich nicht weiß....
                          Ich bin noch auf Vis .24 gegangen, ist doch dass was grade Aktuell ist oder ?
                          auch 0 Effeckt.....
                          Der Knaller ist das die .16 funktioniert......
                          Keine Ahnung wieso ich immer wieder bei der Version landen muss.........
                          Vielleicht Hilft es ja den einen oder anderen........
                          Ich bin für heute satt von IOB.....
                          Schönen Abend noch......
                          P.s. ich weiss das es eine Beta ist und das man mit sowas leben muss dann also nicht meckern ;)
                          Leider ist die Beta für mich immer noch Besser wie Vis1.... das ist schlimmer wie Vis 2 Beta bei mir !
                          mfg
                          Digi-Bit .
                          Router: Ubiquiti UniFi Dream Machine Pro|Iobroker I.NUCi5/Debian, 6 x Switche, 3 x APs, 3 x Cam, 2 x Nas(Qnap 4 & 8 Bay's)
                          7 x Echos, 76 x Tasmota, 58 x ZigBee, Homatic Ip, 2 x USV
                          • apollon77A apollon77
                            @sandy Na dann melde doch bitte mal das was nicht geht oder was in deinen augen komisch ist ... :-)
                            Sandy
                            schrieb am zuletzt editiert von Sandy
                            #599
                            @apollon77 habe mal ein Screenshot von der Bearbeitungsoberfläche gemacht und eins vom Vorschaufenster.
                            Alle Buttons verschoben.
                            Und dann geht noch das Wetter nicht von dieser Seite (https://weatherwidget.io/)
                            Habe es schon bei github.com gemeldet. Wenn einer was wissen will denke ich mal wird es dort als erstes stehen :-)
                            https://github.com/ioBroker/ioBroker.vis/issues/695
                            • S Sandy
                              Hallo Leute,
                              habe jetzt mal eine ganze Weile rum gespielt und man merkt das die Vis2 noch in der Testphase ist. Manche Sachen gehen gar nicht (wie z.B. meine Wetter App) Und viele Buttons sind einfach an einer anderen Stelle als vorher. Also wenn man in die Bearbeitenoberfläche geht sind sie an der richtigen Stelle aber wenn man dann auf das Vorschaufenster geht dann nicht mehr. Aber ich denke diese Fehler werden noch behoben.
                              Ansonsten lässt es sich gut mit arbeiten :-)
                              FeuersturmF Offline
                              FeuersturmF Offline
                              Feuersturm
                              #600
                              @sandy sagte in Test Adapter vis 2.0 (Alpha):
                              Die Fehler können nur behoben werden, wenn sie einzeln auf github als issue eingestellt werden. Bluefox arbeitet dort die Tickets ab und stellt dort bei Bedarf Rückfragen oder markiert sie als fixed.
                              Der thread hier dient als Austausch, um zu schauen ob andere auch das Problem haben oder ob der Fehler z.b. bereits bekannt ist. In deinem Fall mit den verschoben Grafiken kenne ich noch kein entsprechendes issue was dazu passt. Daher bitte ein issue auf github einstellen :-)
                              sigi234S S 2 Antworten Letzte Antwort
                              • FeuersturmF Feuersturm
                                sigi234S Online
                                sigi234S Online
                                #601
                                @feuersturm sagte in Test Adapter vis 2.0 (Alpha):
                                Jupp, da haben wir eines: Einheiten werden nicht angezeigt bei Energy Widgets Verbrauch und ein paar Übersetzungsfehler.
                                @Feuersturm bei dir auch?
                                FeuersturmF 2 Antworten Letzte Antwort
                                  Sandy
                                  #602
                                  @feuersturm said in Test Adapter vis 2.0 (Alpha):
                                  kannst du mr vielleicht erklären wie ich das machen muss.
                                  L FeuersturmF 2 Antworten Letzte Antwort
                                  • S Sandy
                                    lustig29
                                    #603
                                    Bei mir startet der Vis Editor nicht. Da einzige was ich sehe, ist das drehende Iobrokersymbol. Weiter komme ich nicht. Womit kann das zusammenhängen?
                                    • L lustig29
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      #604
                                      @lustig29
                                      Sorry ... aber lesen in diesem Thread ist nicht deine stärke .. bzw. es mal zu versuchen
                                      das ist Käse :
                                      https://forum.iobroker.net/topic/64458/vis-2-0-öffnet-sich-nicht
                                      und mit den Infos von dir kann man nicht viel hier anfangen !
                                      • S Sandy
                                        FeuersturmF Offline
                                        FeuersturmF Offline
                                        Feuersturm
                                        #605
                                        Klar. Du brauchst einen Account auf der Seite github.com
                                        Über diesen link kommst du zum Repository vom vis Adapter https://github.com/ioBroker/ioBroker.vis
                                        Dort gehst du auf zweiten Tab "issue". Dort findest du einen Button "New".
                                        Wenn du einen Fehler melden möchtest wählst du "Bug" aus, bei einem Verbesserungsvorschlag "Feature request".
                                        Im neuen Fenster füllst du dann die entsprechenden Abschnitte aus, welche durch das Template schon vorgegeben sind.
                                          Thomas b
                                          #606
                                          Hatte in der falschen Gruppe gepostet - daher hier nochmal neu
                                          Hallo Leute,
                                          ich wollte über die Ostertage die neue "vis-2" ausprobieren und habe mir "https://forum.iobroker.net/topic/60398/test-adapter-vis-2-0-alpha" die Testversion installiert.
                                          Der Adapter scheint zwar grundsätzlich zu laufen:
                                          9ae76bda-144f-4272-85ba-3c539e4b9ed6-grafik.png 01cf2b00-504b-4601-a5fd-fedf49c9cd2e-grafik.png
                                          eine erste Testview ließ sich zwar anlegen, nach erneutem Aufruf läuft aber alles ins Leere. Es kommt dann nur noch die nicht vollständige Startseite
                                          ... der blaue Laufbalken läuft bis zum St-Nimmerleinstag durch
                                          ... switch zwischen Edit-Ansicht und Runtime-Ansicht funktioniert nicht
                                          ... "Runtime in neuem Fenster öffnen" hat die leere Seite "http://IP-iobroker-Maschine:8082/vis-2-beta/?Test#dd" zur Folge
                                          InstallationsPfad ist "/opt/iobroker/"
                                          Es laufen:
                                          Node.js v18.15.0
                                          NPM 9.5.0
                                          "iob list adapters" liefert:
                                          system.adapter.admin: admin - v6.3.5
                                          system.adapter.socketio: socketio - v4.2.0
                                          system.adapter.vis: vis - v1.4.16
                                          system.adapter.vis-2-beta: vis-2-beta - v2.0.24
                                          system.adapter.web: web - v5.5.0
                                          system.adapter.ws: ws - v1.3.0
                                          "web-v5.5.0" habe ich aus der beta-Repo genommen, weil nach der Installation von "vis-2-beta-v2.0.24" eine entsprechende Meldung in der log aufgeschlagen ist.
                                          An welcher Stelle könnte ich mit der Fehlersuche anfangen?
                                          Danke & Gruß
                                          Thomas
                                          sigi gab mir den Tip mit der Konsole. Dann kommt folgendes:
