  4. Test Adapter vis 2.0 (Alpha)
    6.7k
780 Beiträge 108 Kommentatoren 352.2k Aufrufe 140 Beobachtet
  • sigi234S sigi234
    @manfredhi sagte in Test Adapter vis 2.0 (Alpha):
    @sigi234 sagte in Test Adapter vis 2.0 (Alpha):
    Welche Version vom WEB Adapter hast du?
    Version 5.4.1
    Ok, was sagt F12 ?
    ManfredHi
    #589
    @sigi234
    iobroker.vis-2-beta@2.0.24 using theme "colored"
    main.9e02fddc.js:658
    main.9e02fddc.js:658 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
    main.9e02fddc.js:658 Help us to create open source project with reactJS!
    main.9e02fddc.js:658 See you :)
    socket.io.js:66 [2023-04-05T14:54:59.516Z] Try to connect
    socket.io.js:67
           [2023-04-05T14:55:02.540Z] No READY flag received in 3 seconds. Re-init
    warn @ socket.io.js:67
    (anonym) @ socket.io.js:148
    socket.io.js:397
           WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706499516&name=vis-2-beta' failed: WebSocket is closed before the connection is established.
    SocketClient.close @ socket.io.js:397
    (anonym) @ socket.io.js:149
    socket.io.js:66 [2023-04-05T14:55:02.540Z] Start reconnect 0
    socket.io.js:68
           [2023-04-05T14:55:02.541Z] ws connection error: CLOSE_ABNORMAL
    error @ socket.io.js:68
    socket.onclose @ socket.io.js:177
    socket.io.js:66 [2023-04-05T14:55:02.541Z] Reconnect is already running 0
    socket.io.js:66 [2023-04-05T14:55:02.542Z] Try to connect
    socket.io.js:67
           [2023-04-05T14:55:05.543Z] No READY flag received in 3 seconds. Re-init
    setTimeout (asynchron)
    SocketClient.connect @ socket.io.js:146
    (anonym) @ socket.io.js:432
    SocketClient._reconnect @ socket.io.js:427
    SocketClient.close @ socket.io.js:411
    socket.onerror @ socket.io.js:189
    socket.io.js:397
           WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706502542&name=vis-2-beta' failed: WebSocket is closed before the connection is established.
    socket.io.js:66 [2023-04-05T14:55:05.543Z] Start reconnect 1
    socket.io.js:68
           [2023-04-05T14:55:05.543Z] ws connection error: CLOSE_ABNORMAL
    socket.io.js:66 [2023-04-05T14:55:05.543Z] Reconnect is already running 1
    socket.io.js:66 [2023-04-05T14:55:06.544Z] Try to connect
    socket.io.js:140
           WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706506544&name=vis-2-beta' failed:
    SocketClient.connect @ socket.io.js:140
    socket.io.js:66 [2023-04-05T14:55:08.839Z] Start reconnect 2
    socket.io.js:68
           [2023-04-05T14:55:08.839Z] ws connection error: CLOSE_ABNORMAL
    socket.io.js:66 [2023-04-05T14:55:08.839Z] Reconnect is already running 2
    socket.io.js:66 [2023-04-05T14:55:10.841Z] Try to connect
    socket.io.js:140
           WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706510841&name=vis-2-beta' failed:
    socket.io.js:66 [2023-04-05T14:55:13.286Z] Start reconnect 3
    socket.io.js:68
           [2023-04-05T14:55:13.287Z] ws connection error: CLOSE_ABNORMAL
    socket.io.js:66 [2023-04-05T14:55:13.287Z] Reconnect is already running 3
    socket.io.js:66 [2023-04-05T14:55:16.289Z] Try to connect
    socket.io.js:140
           WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706516289&name=vis-2-beta' failed:
    socket.io.js:66 [2023-04-05T14:55:18.584Z] Start reconnect 4
    socket.io.js:68
           [2023-04-05T14:55:18.584Z] ws connection error: CLOSE_ABNORMAL
    socket.io.js:66 [2023-04-05T14:55:18.584Z] Reconnect is already running 4
    socket.io.js:66 [2023-04-05T14:55:22.586Z] Try to connect
    socket.io.js:67
           [2023-04-05T14:55:25.587Z] No READY flag received in 3 seconds. Re-init
    error (asynchron)
    SocketClient.connect @ socket.io.js:182
    error (asynchron)
    error (asynchron)
    error (asynchron)
    socket.io.js:397
           WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706522586&name=vis-2-beta' failed: WebSocket is closed before the connection is established.
    error (asynchron)
    error (asynchron)
    error (asynchron)
    error (asynchron)
    socket.io.js:66 [2023-04-05T14:55:25.587Z] Start reconnect 5
    socket.io.js:68
           [2023-04-05T14:55:25.587Z] ws connection error: CLOSE_ABNORMAL
    error (asynchron)
    error (asynchron)
    error (asynchron)
    error (asynchron)
    socket.io.js:66 [2023-04-05T14:55:25.587Z] Reconnect is already running 5
    socket.io.js:66 [2023-04-05T14:55:30.588Z] Try to connect
    socket.io.js:140
           WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706530588&name=vis-2-beta' failed:
    socket.io.js:66 [2023-04-05T14:55:32.871Z] Start reconnect 5
    socket.io.js:68
           [2023-04-05T14:55:32.871Z] ws connection error: CLOSE_ABNORMAL
    socket.io.js:66 [2023-04-05T14:55:32.871Z] Reconnect is already running 5
    socket.io.js:66 [2023-04-05T14:55:37.872Z] Try to connect
    socket.io.js:140
           WebSocket connection to 'ws://http//192.168.0.30/?sid=1680706537872&name=vis-2-beta' failed:
    socket.io.js:66 [2023-04-05T14:55:40.154Z] Start reconnect 5
    socket.io.js:68
           [2023-04-05T14:55:40.154Z] ws connection error: CLOSE_ABNORMAL
    socket.io.js:66 [2023-04-05T14:55:40.155Z] Reconnect is already running 5
    • M ManfredHi
      @sigi234
      socket.io.js:67
      socket.io.js:397
      socket.io.js:68
      socket.io.js:67
      socket.io.js:397
      socket.io.js:68
      socket.io.js:140
      socket.io.js:68
      socket.io.js:140
      socket.io.js:68
      socket.io.js:140
      socket.io.js:68
      socket.io.js:67
      error (asynchron)
      error (asynchron)
      error (asynchron)
      error (asynchron)
      socket.io.js:397
      error (asynchron)
      error (asynchron)
      error (asynchron)
      error (asynchron)
      socket.io.js:68
      error (asynchron)
      error (asynchron)
      error (asynchron)
      error (asynchron)
      socket.io.js:140
      socket.io.js:68
      socket.io.js:140
      socket.io.js:68
      sigi234S Online
      sigi234S Online
      #590
      @manfredhi
      Zeig mal die Einstellungen vom WEB Adapter
      • sigi234S sigi234
        @manfredhi
        ManfredHi
        #591
        @sigi234
        • M ManfredHi
          @sigi234
          sigi234S Online
          sigi234S Online
          #592
          @manfredhi
          • sigi234S sigi234
            @manfredhi
            ManfredHi
            #593
            @sigi234
            Hab eine zweite web-Instanz mit den gleichen Einstellungen wie du über Port 9082.
            Da kommt folgendes:
            main.7b76ba87.js:658
            main.7b76ba87.js:658 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
            main.7b76ba87.js:658 Help us to create open source project with reactJS!
            main.7b76ba87.js:658 See you :)
            socket.io.js:66 [2023-04-05T15:19:38.123Z] Try to connect
            main.7b76ba87.js:658 Translate: background
            VM1641:402 Version eventlist: 1.0.1
            visEngine.jsx:1283
                   WTF?? in tplMaListDoor: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            (anonym) @ visEngine.jsx:1283
            visEngine.jsx:1283
                   WTF?? in tplMaListWindow: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListWindow3: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListTemp: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListHumid: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListPressure: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListTempHumid: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListPresence: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListOccupancy: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListLight: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListLightDim: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListLightKelvin: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListThermostat: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListWindowShutter: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListVolume: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListBoolean: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListNumber: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListText: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListValve: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            visEngine.jsx:1283
                   WTF?? in tplMaListGarage: InvalidCharacterError: Failed to execute 'setAttribute' on 'Element': ';' is not a valid attribute name.
            metro-bootstrap.css:1
                   Failed to load resource: the server responded with a status of 404 (Not Found)
            iconFont.min.css:1
            fritzdect.js:46 Version fritzdect: 0.0.2
            kodi.js:48 Version kodi: 2.0.0
            trashschedule.js:163 Version trashschedule: 2.2.0
            info.js:21 Version Info-Adapter-Widget: 0.0.9
            :9082/vis-2-beta/widgets/metro/js/metro.js:1
            :9082/vis-2-beta/adapter/template/words.js:1
            vis-material-advanced.js:184 Version vis-material-advanced: 1.6.0
            :9082/vis-2-beta/edi…r_hourly_Preise:410
                   Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
                at JSON.parse (<anonymous>)
                at getTranslation (info.js:13:47)
            iconFont.min.css:1
            sigi234S 2 Antworten Letzte Antwort
            • M ManfredHi
              @sigi234
              Da kommt folgendes:
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              visEngine.jsx:1283
              iconFont.min.css:1
              iconFont.min.css:1
              sigi234S Online
              sigi234S Online
              #594
              Port 9082.
              • M ManfredHi
                @sigi234
                Da kommt folgendes:
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                visEngine.jsx:1283
                iconFont.min.css:1
                iconFont.min.css:1
                sigi234S Online
                sigi234S Online
                #595
                @manfredhi
                Funktioniert es jetzt?
                • sigi234S sigi234
                  Port 9082.
                  ManfredHi
                  #596
                  @sigi234
                  Ich habe zwei Web-Instanzen (einmal auf Port 8082 und einmal auf Port 9082) wegen dem Energieflussadapter.
                  Port 8082 ist mit ws.io.
                  Das brauch ich weil sonst der Energieflussadapter nicht funktioniert (geht nicht über ws.io). Und ohne ws.io habe ich die Probleme mit dem VIS-Editor (Verbindungsabbruch ....)
                  • sigi234S sigi234
                    @manfredhi
                    ManfredHi
                    #597
                    nein, hab den Web-Adapter nun auf Version 5.5.3 aktualisiert, aber ebenfalls ohne erfolg.
                    • M ManfredHi
                      Digi-Bit
                      #598
                      Abend.........
                      Den Schmarren hatte ich heute auch und hat mich 3 Stunden gekostet.....
                      Bei mir stand Kurz da, wo ich die VIS aufgerufen habe stand sowas wie " Updating VIS " oder sowas in dem dreh da was mich wunderte da ich schon einige Tage auf v .23 bin....
                      Und danach 3 stunden Schnecke egal was ich machte....
                      bei F12 war was mit Socket.io oder sowas was ich nun gar nicht wusste was das ist aber da steht viel was ich nicht weiß....
                      Ich bin noch auf Vis .24 gegangen, ist doch dass was grade Aktuell ist oder ?
                      auch 0 Effeckt.....
                      Der Knaller ist das die .16 funktioniert......
                      Keine Ahnung wieso ich immer wieder bei der Version landen muss.........
                      Vielleicht Hilft es ja den einen oder anderen........
                      Ich bin für heute satt von IOB.....
                      Schönen Abend noch......
                      P.s. ich weiss das es eine Beta ist und das man mit sowas leben muss dann also nicht meckern ;)
                      Leider ist die Beta für mich immer noch Besser wie Vis1.... das ist schlimmer wie Vis 2 Beta bei mir !
                      mfg
                      Digi-Bit .
                      Router: Ubiquiti UniFi Dream Machine Pro|Iobroker I.NUCi5/Debian, 6 x Switche, 3 x APs, 3 x Cam, 2 x Nas(Qnap 4 & 8 Bay's)
                      7 x Echos, 76 x Tasmota, 58 x ZigBee, Homatic Ip, 2 x USV
                      • apollon77A apollon77
                        @sandy Na dann melde doch bitte mal das was nicht geht oder was in deinen augen komisch ist ... :-)
                        Sandy
                        schrieb am zuletzt editiert von Sandy
                        #599
                        @apollon77 habe mal ein Screenshot von der Bearbeitungsoberfläche gemacht und eins vom Vorschaufenster.
                        Alle Buttons verschoben.
                        Und dann geht noch das Wetter nicht von dieser Seite (https://weatherwidget.io/)
                        Habe es schon bei github.com gemeldet. Wenn einer was wissen will denke ich mal wird es dort als erstes stehen :-)
                        https://github.com/ioBroker/ioBroker.vis/issues/695
                        • S Sandy
                          Hallo Leute,
                          habe jetzt mal eine ganze Weile rum gespielt und man merkt das die Vis2 noch in der Testphase ist. Manche Sachen gehen gar nicht (wie z.B. meine Wetter App) Und viele Buttons sind einfach an einer anderen Stelle als vorher. Also wenn man in die Bearbeitenoberfläche geht sind sie an der richtigen Stelle aber wenn man dann auf das Vorschaufenster geht dann nicht mehr. Aber ich denke diese Fehler werden noch behoben.
                          Ansonsten lässt es sich gut mit arbeiten :-)
                          FeuersturmF Offline
                          FeuersturmF Offline
                          Feuersturm
                          #600
                          @sandy sagte in Test Adapter vis 2.0 (Alpha):
                          Die Fehler können nur behoben werden, wenn sie einzeln auf github als issue eingestellt werden. Bluefox arbeitet dort die Tickets ab und stellt dort bei Bedarf Rückfragen oder markiert sie als fixed.
                          Der thread hier dient als Austausch, um zu schauen ob andere auch das Problem haben oder ob der Fehler z.b. bereits bekannt ist. In deinem Fall mit den verschoben Grafiken kenne ich noch kein entsprechendes issue was dazu passt. Daher bitte ein issue auf github einstellen :-)
                          sigi234S S 2 Antworten Letzte Antwort
                          • FeuersturmF Feuersturm
                            sigi234S Online
                            sigi234S Online
                            #601
                            @feuersturm sagte in Test Adapter vis 2.0 (Alpha):
                            Jupp, da haben wir eines: Einheiten werden nicht angezeigt bei Energy Widgets Verbrauch und ein paar Übersetzungsfehler.
                            @Feuersturm bei dir auch?
                            FeuersturmF 2 Antworten Letzte Antwort
                              Sandy
                              #602
                              @feuersturm said in Test Adapter vis 2.0 (Alpha):
                              kannst du mr vielleicht erklären wie ich das machen muss.
                              L FeuersturmF 2 Antworten Letzte Antwort
                              • S Sandy
                                lustig29
                                #603
                                Bei mir startet der Vis Editor nicht. Da einzige was ich sehe, ist das drehende Iobrokersymbol. Weiter komme ich nicht. Womit kann das zusammenhängen?
                                • L lustig29
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #604
                                  @lustig29
                                  Sorry ... aber lesen in diesem Thread ist nicht deine stärke .. bzw. es mal zu versuchen
                                  das ist Käse :
                                  https://forum.iobroker.net/topic/64458/vis-2-0-öffnet-sich-nicht
                                  und mit den Infos von dir kann man nicht viel hier anfangen !
                                  • S Sandy
                                    FeuersturmF Offline
                                    FeuersturmF Offline
                                    Feuersturm
                                    #605
                                    Klar. Du brauchst einen Account auf der Seite github.com
                                    Über diesen link kommst du zum Repository vom vis Adapter https://github.com/ioBroker/ioBroker.vis
                                    Dort gehst du auf zweiten Tab "issue". Dort findest du einen Button "New".
                                    Wenn du einen Fehler melden möchtest wählst du "Bug" aus, bei einem Verbesserungsvorschlag "Feature request".
                                    Im neuen Fenster füllst du dann die entsprechenden Abschnitte aus, welche durch das Template schon vorgegeben sind.
                                      Thomas b
                                      #606
                                      Hatte in der falschen Gruppe gepostet - daher hier nochmal neu
                                      Hallo Leute,
                                      ich wollte über die Ostertage die neue "vis-2" ausprobieren und habe mir "https://forum.iobroker.net/topic/60398/test-adapter-vis-2-0-alpha" die Testversion installiert.
                                      Der Adapter scheint zwar grundsätzlich zu laufen:
                                      9ae76bda-144f-4272-85ba-3c539e4b9ed6-grafik.png 01cf2b00-504b-4601-a5fd-fedf49c9cd2e-grafik.png
                                      eine erste Testview ließ sich zwar anlegen, nach erneutem Aufruf läuft aber alles ins Leere. Es kommt dann nur noch die nicht vollständige Startseite
                                      ... der blaue Laufbalken läuft bis zum St-Nimmerleinstag durch
                                      ... switch zwischen Edit-Ansicht und Runtime-Ansicht funktioniert nicht
                                      ... "Runtime in neuem Fenster öffnen" hat die leere Seite "http://IP-iobroker-Maschine:8082/vis-2-beta/?Test#dd" zur Folge
                                      InstallationsPfad ist "/opt/iobroker/"
                                      Es laufen:
                                      Node.js v18.15.0
                                      NPM 9.5.0
                                      "iob list adapters" liefert:
                                      system.adapter.admin: admin - v6.3.5
                                      system.adapter.socketio: socketio - v4.2.0
                                      system.adapter.vis: vis - v1.4.16
                                      system.adapter.vis-2-beta: vis-2-beta - v2.0.24
                                      system.adapter.web: web - v5.5.0
                                      system.adapter.ws: ws - v1.3.0
                                      "web-v5.5.0" habe ich aus der beta-Repo genommen, weil nach der Installation von "vis-2-beta-v2.0.24" eine entsprechende Meldung in der log aufgeschlagen ist.
                                      An welcher Stelle könnte ich mit der Fehlersuche anfangen?
                                      Danke & Gruß
                                      Thomas
                                      sigi gab mir den Tip mit der Konsole. Dann kommt folgendes:
                                      • T Thomas b
                                        Hallo Leute,
                                        Es laufen:
                                        Node.js v18.15.0
                                        NPM 9.5.0
                                        Danke & Gruß
                                        Thomas
                                        FeuersturmF Offline
                                        FeuersturmF Offline
                                        Feuersturm
                                        #607
                                        @thomas-b sagte in Test Adapter vis 2.0 (Alpha):
                                        Wie bist du denn an Web version 5.5.0 gekommen? 5.5.3 ist die aktuelle beta Version. Installiere die mal. Lösch bitte auch einmal deinen Browser Cache.
                                        • sigi234S sigi234
                                          FeuersturmF Offline
                                          FeuersturmF Offline
                                          Feuersturm
                                          #608
                                          Ich bin aktuell unterwegs, kann es Sonntag abend testen.
