  4. Test Adapter vodafone-speedtest v0.0.x GitHub/Latest
vodafone speedtest
208 Beiträge 43 Kommentatoren 52.4k Aufrufe 33 Beobachtet
  • SKBS Offline
    SKBS Offline
    SKB
    #157
    ... oder direkt als Link :)
    https://www.kreyenborg.koeln/speedtest-fuer-iobroker/
    Gruß,
    Stephan
    • JohGreJ JohGre
      Bei mir funktioniert der Adapter seit gestern Nachmittag nicht mehr. Auch aus dem Log ist nicht wirklich was ersichtlich. Ist da was bekannt.
      2022-03-30 09:48:00.435 - debug: vofo-speedtest.0 (5218) Redis Objects: Use Redis connection: 10.0.0.227:9001
      2022-03-30 09:48:00.462 - debug: vofo-speedtest.0 (5218) Objects client ready ... initialize now
      2022-03-30 09:48:00.464 - debug: vofo-speedtest.0 (5218) Objects create System PubSub Client
      2022-03-30 09:48:00.465 - debug: vofo-speedtest.0 (5218) Objects create User PubSub Client
      2022-03-30 09:48:00.499 - debug: vofo-speedtest.0 (5218) Objects client initialize lua scripts
      2022-03-30 09:48:00.504 - debug: vofo-speedtest.0 (5218) Objects connected to redis: 10.0.0.227:9001
      2022-03-30 09:48:00.505 - silly: vofo-speedtest.0 (5218) redis psubscribe cfg.o.system.user.*
      2022-03-30 09:48:00.525 - silly: vofo-speedtest.0 (5218) redis psubscribe cfg.o.enum.*
      2022-03-30 09:48:00.527 - silly: vofo-speedtest.0 (5218) objectDB connected
      2022-03-30 09:48:00.528 - debug: vofo-speedtest.0 (5218) Redis States: Use Redis connection: 10.0.0.227:9000
      2022-03-30 09:48:00.543 - debug: vofo-speedtest.0 (5218) States create System PubSub Client
      2022-03-30 09:48:00.544 - debug: vofo-speedtest.0 (5218) States create User PubSub Client
      2022-03-30 09:48:00.570 - debug: vofo-speedtest.0 (5218) States connected to redis: 10.0.0.227:9000
      2022-03-30 09:48:00.571 - silly: vofo-speedtest.0 (5218) statesDB connected
      2022-03-30 09:48:00.664 - debug: vofo-speedtest.0 (5218) Plugin sentry Initialize Plugin (enabled=true)
      2022-03-30 09:48:00.941 - info: vofo-speedtest.0 (5218) starting. Version 0.0.10 in /opt/iobroker/node_modules/iobroker.vofo-speedtest, node: v14.19.1, js-controller: 4.0.21
      2022-03-30 09:48:00.998 - silly: vofo-speedtest.0 (5218) States system redis pmessage system.adapter.vofo-speedtest.0.logLevel/system.adapter.vofo-speedtest.0.logLevel:{"val":"silly","ack":true,"ts":1648626480968,"q":0,"from":"system.adapter.vofo-speedtest.0","lc":1648626480968}
      2022-03-30 10:03:00.003 - warn: host.VM-Slave instance system.adapter.vofo-speedtest.0 already running with pid 5218
      RK62R Offline
      RK62R Offline
      RK62
      #158
      @johgre Ich hatte diesen Docker-Container mal getestet, der arbeitet recht zuverlässig und ist optisch auch nett aufgemacht: https://github.com/henrywhitaker3/Speedtest-Tracker
      Mittlerweile habe ich den ookla-Speedtest in eine eigene Docker-Maschine gelegt, die dann regelmäßig ein Testergebnis für den ioBroker bereit stellt und dort dann visualisiert wird.
      • JohGreJ Offline
        JohGreJ Offline
        JohGre
        #159
        Danke an alle und @SKB für das Script werde es nun mal etwas testen
        nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
        • JohGreJ JohGre
          #160
          @johgre
          Hier hab ich noch ein paar Ergänzungen zum Skript aufgeschrieben:
          https://forum.iobroker.net/topic/48700/speedtest-skript-von-kreyenborg-koeln-für-kabel-gigabit
          Da wird u. a. die speedtest binairy sauberer im System installiert.
          JohGreJ 1 Antwort Letzte Antwort
            @johgre
            JohGreJ Offline
            JohGreJ Offline
            JohGre
            #161
            @thomas-braun Super, danke für den Link und läuft schon. Ich musste aber noch in die sudoers.d von iobroker den Pfad zu speedtest eintragen damits dann wirklich lief.
            sudo nano /etc/sudoers.d/iobroker
            iobroker ALL=(ALL) NOPASSWD: /usr/bin/speedtest
            • JohGreJ JohGre
              #162
              @johgre sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
              Musste ich nicht. Warum auch?
              echad@chet:~ $ which speedtest
              /usr/bin/speedtest
              echad@chet:~ $ ls -l /usr/bin/speedtest
              -rwxr-xr-x 1 root root 2471896 Nov 17 23:26 /usr/bin/speedtest
              echad@chet:~ $
                Bongo
                #163
                Habe ich nun auch installiert. Funktioniert! Danke.
                Was ist der Unterschied zu den Datenpunkten download_Mb und download_Mb_calc?
                Bongo
                Script - Die sprechende Kaffeemaschine – Home Connect
                Script - JUDO Wasserenthärtung - Connectivity-Modul API
                  mx-driver
                  #164
                  Im Moment bekomme ich den Fehler:
                  instance system.adapter.vofo-speedtest.0 already running with pid 21677
                  Immer wenn er einen Speedtest machen sollte.
                  Hat das sonst noch jemand?
                  • KnallochseK Offline
                    KnallochseK Offline
                    Knallochse
                    #165
                    Installation unter Node Version 18.15.0 nicht mehr möglich
                    $ iobroker add vofo-speedtest auto --host buanet-iobroker1 --debug
                    NPM version: 9.5.0
                    Installing iobroker.vofo-speedtest@0.0.13... (System call)
                    npm ERR! code 1
                    npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-libcurl/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/.cache/node-gyp/18.15.0/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/18.15.0',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/18.15.0/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-libcurl',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Could not run curl-config, please make sure libcurl dev package is installed.
                    npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2023-04-04T09_56_47_982Z-debug-0.log
                    host.buanet-iobroker1 Cannot install iobroker.vofo-speedtest@0.0.13: 1
                    ERROR: Process exited with code 25
                    Github Issues dazu
                    • KnallochseK Knallochse
                      NPM version: 9.5.0
                      npm ERR! code 1
                      Github Issues dazu
                      wendy2702W Online
                      wendy2702W Online
                      #166
                      @knallochse sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                      Mal hier gschaut: https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/2
                      • wendy2702W wendy2702
                        #167
                        @wendy2702
                        Du bist zu spät. Wurde schon gelöst:
                        Kein Issue mit nodejs, da fehlen dev-packages.
                        sudo apt update
                        apt policy libcurl4-gnutls-dev libcurl4-nss-dev libcurl4-openssl-dev
                          @wendy2702
                          sudo apt update
                          wendy2702W Online
                          wendy2702W Online
                          #168
                          @thomas-braun Ups...
                          OK.
                          • P Offline
                            PatrickFro
                            #169
                            Moin,
                            ich habe den Adapter gerade erst gefunden und installiert. So wie es scheint wird er ja nun doch weiterentwickelt, zumindest gab es einige Änderungen im letzten Monat.
                            Ich verstehe die Ergebnisse jedoch noch nicht:
                            9b7898b3-a51f-4574-92ba-4dd798486539-image.png im Vergleich zu baeddd3f-17c8-40c9-8d9c-148a2baf8fc2-image.png
                            Schaue ich mir die Downloadraten an, sehe ich über die Webseite vom Speedtest 269 Mbit/s, über den Adapter eine Minute vor der Messung per Webseite 55,842 MB/s.
                            Wenn ich die verschiedenen Werte richtig zuordnete, müsste ich bei MB/s x 8,25 rechnen um auf Mbit/s zu kommen. Das aber ergäbe 470 Mbit/s. Wo ist hier mein Denkfehler?
                            • wollerosekaufeW Offline
                              wollerosekaufe
                              schrieb am zuletzt editiert von wollerosekaufe
                              #170
                              verstehe es auch nicht so ganz.
                              auf npm ist version 1.0.1, aber nur dependencies aktualisiert und kein release.
                              haben wir noch chancen dass der adapter gefixt wird? @Bluefox @peterbaumert :)
                              anyway, der adapter läuft bei mir nicht. habe ebenso das problem von @PatrickFro mit VIEL zu niedrigen DL rates.
                              dazu klappt der UL test erst gar nicht, der adapter stoppt einfach "ohne fehlermeldung", vofo-speedtest.0.Results.upload_MB etc. bleibt alles leer.
                              host.iobroker
                              	2023-11-17 22:57:39.204	info	instance system.adapter.vofo-speedtest.0 terminated with code 0 (NO_ERROR)
                              vofo-speedtest.0
                              	2023-11-17 22:57:38.631	info	Terminated (NO_ERROR): Without reason
                              vofo-speedtest.0
                              	2023-11-17 22:57:38.577	info	cleaned everything up...
                              vofo-speedtest.0
                              	2023-11-17 22:57:38.576	info	starting cleanup...
                              vofo-speedtest.0
                              	2023-11-17 22:57:38.563	info	Vofo-Speedtest finished with 184.013mbit download speed and 0mbit upload speed.
                              vofo-speedtest.0
                              	2023-11-17 22:57:04.317	info	starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.vofo-speedtest, node: v18.18.2, js-controller: 5.0.16
                              host.iobroker
                              	2023-11-17 22:57:00.080	info	instance system.adapter.vofo-speedtest.0 started with pid 509363
                              mit CURL ist das ganze noch schlimmer, da crasht der adapter mit UNCAUGHT_EXCEPTION:
                              host.iobroker
                              	2023-11-17 23:01:44.523	error	instance system.adapter.vofo-speedtest.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              vofo-speedtest.0
                              	2023-11-17 23:01:43.944	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              vofo-speedtest.0
                              	2023-11-17 23:01:43.941	info	terminating
                              vofo-speedtest.0
                              	2023-11-17 23:01:43.938	info	cleaned everything up...
                              vofo-speedtest.0
                              	2023-11-17 23:01:43.937	info	starting cleanup...
                              vofo-speedtest.0
                              	2023-11-17 23:01:43.799	error	Curl handle is closed.
                              vofo-speedtest.0
                              	2023-11-17 23:01:43.798	error	Error: Curl handle is closed. at Curl.close (/opt/iobroker/node_modules/node-libcurl/dist/Curl.js:588:21) at VofoSpeedtest.stopDownloadTest (/opt/iobroker/node_modules/iobroker.vofo-speedtest/main.js:824:29) at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.vofo-speedtest/main.js:540:39) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
                              vofo-speedtest.0
                              	2023-11-17 23:01:43.787	error	uncaught exception: Curl handle is closed.
                              vofo-speedtest.0
                              	2023-11-17 23:00:03.861	info	starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.vofo-speedtest, node: v18.18.2, js-controller: 5.0.16
                              host.iobroker
                              	2023-11-17 23:00:00.125	info	instance system.adapter.vofo-speedtest.0 started with pid 509581
                              iobroker läuft auf buanet/docker mit libcurl4-openssl-dev package
                              btw: bei mir wird die config nicht richtig aktualisiert, daher meldet npm permanent die alte version. alle anderen dateien werden sauber von 1.0.1 geladen, code auf dem iobroker entspricht den neuen github files - das update klappt also. adapter mehrmals de- und neu installiert, hilft nichts. hab die config nun manuell angepasst damit die update-meldung nicht nervt.
                                Bongo
                                #171
                                @wollerosekaufe
                                Ich hatte meinen buanet/Docker Container upgegradet. Dabei wurde auch ein Upgrade von node 16 auf 18 gemacht. Darauf hin kam unter anderem JS_CONTROLLER_STOPPED.
                                Ich habe dann die Version v0.0.13 über Github auf v1.0.1 gebracht. Jetzt gibt es keine Fehlermeldung mehr. Download passt aber Upload war immer 0.
                                Dann habe ich CURL aktiviert. Dann war der Upload wieder korrekt.
                                Hilft dir vermutlich nicht weiter aber bei mir funktioniert wieder alles.
                                Von welcher Config sprichst du?
                                Bongo
                                wollerosekaufeW 1 Antwort Letzte Antwort
                                • B Bongo
                                  @wollerosekaufe
                                  wollerosekaufe
                                  #172
                                  @bongo said in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                                  bei mir wird die io-package.json scheinbar nicht geladen, alles andere wie gesagt schon. aus der datei holt sich iobroker/npm dann wohl die version zum update-abgleich. hab da manuell 1.0.1 hinterlegt:
                                  cat io-package.json
                                    "common": {
                                      "name": "vofo-speedtest",
                                      "version": "1.0.1",
                                      "news": {
                                        "0.0.13": {
                                          "en": "some more \"already running\" fixes",
                                  über github bekomme ich auch nur die alte version, die 1.0.1 ist da nicht released.
                                  • wollerosekaufeW wollerosekaufe
                                    cat io-package.json
                                      "common": {
                                        "version": "1.0.1",
                                        "news": {
                                          "0.0.13": {
                                    Bongo
                                    #173
                                    @wollerosekaufe sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                                    Ich habe die 1.0.1 über die Katze installiert. In der Instanz wird zwar die alte Version angezeigt aber wenn das Programm startet sieht man im Protokoll die 1.0.1.
                                    Bongo
                                    • B Bongo
                                      wollerosekaufe
                                      #174
                                      @bongo
                                      jau, in den logs und in den dateien (bis auf o.g.) war bei mir auch alles korrekt. nur im admin wurde weiter die alte version angezeigt.
                                      aber habe es nun im vierten anlauf löschen-und-neu aus npm mal "vollständig" installiert bekommen. probleme bleiben dieselben :/
                                        mhuber
                                        #175
                                        was ist eigentlich der Unterschied zw. "download_Mb" und "download_Mb_calc"?
                                          @bongo
                                          mhuber
                                          #176
                                          @wollerosekaufe habe ähnliche Probleme. es läuft 0.0.13 bzw. 1.0.1, aber eigentlich keine Fehlermeldungen im Log.
                                          Nur mit CURL bekomm ich falsche DL rates, Upload passt. Ohne CURL passt die DL rate aber ich bekomme keine UL rates....
                                          @Bluefox @peterbaumert wäre super wenn Ihr Euch das mal ansehen könnt. Das mit den DL rates ist übrigens erst seit kurzem
