  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.0k Aufrufe 40 Beobachtet
  • GlasfaserG Glasfaser
    @thomas-braun sagte in iob diag - Skript:
    Kannst nochmal nach dem journalctl schauen? Sollte jetzt raus sein.
    Upps
    /var:
    sudo: unable to resolve host iobrokerv6: Name or service not known
    32M     /var/
    30M     /var/lib
    18M     /var/lib/apt/lists
    18M     /var/lib/apt
    13M     /var/lib/dpkg
    ./iob_diag: line 303: syntax error: unexpected end of file
    root@iobrokerv6:/opt/iobroker#
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    #335
    @glasfaser sagte in iob diag - Skript:
    Upps
    auch gerade gehabt
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       20G   15G  4.0G  79% /
    10.0.1.21:/volume1/Backups       nfs4       14T  9.5T  4.6T  68% /opt/iobroker/backups
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     1.6G  136K  1.6G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1001
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET                           SOURCE                                FSTYPE     OPTIONS
    /                                /dev/mapper/pve-vm--100--disk--0      ext4       rw,relatime,stripe=16
    |-/opt/iobroker/backups          10.0.1.21:/volume1/Backups            nfs4       rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=10.0.1.201,local_lock=none,addr=10.0.1.21
    |-/proc/cpuinfo                  lxcfs[/proc/cpuinfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/diskstats                lxcfs[/proc/diskstats]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/loadavg                  lxcfs[/proc/loadavg]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/meminfo                  lxcfs[/proc/meminfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/stat                     lxcfs[/proc/stat]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/swaps                    lxcfs[/proc/swaps]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/uptime                   lxcfs[/proc/uptime]                   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys/devices/system/cpu/online lxcfs[/sys/devices/system/cpu/online] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    2.5G    /var/
    2.0G    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
    2.0G    /var/log
    307M    /var/lib
    ° Fixer ---> iob fix
      @glasfaser
      Ja, musste ich für Debian 'Bookworm' umstellen. Da wird die Zeit anders angepackt. Aber ich hab wohl da nicht dran gedacht, dass der Docker halt nicht per systemd gestartet wird.
      Muss ich da wohl auch den Code verzweigen.
      GlasfaserG Offline
      GlasfaserG Offline
      #336
      Geht :
      /var:
      32M     /var/
      30M     /var/lib
      18M     /var/lib/apt
      13M     /var/lib/dpkg
      Orrrrrrrrrr... Docker doesn't read journals!
      /opt/iobroker/backups:
      582M    /opt/iobroker/backups/
        Upps
        /var:
        32M     /var/
        30M     /var/lib
        18M     /var/lib/apt
        13M     /var/lib/dpkg
        #337
        @glasfaser
        Jaja, wenn man seinen eigenen Code nicht mal laufen lässt... ;-)
        Probier jetzt nochmal.
          @glasfaser
          GlasfaserG Offline
          GlasfaserG Offline
          #338
          siehe oben
            siehe oben
            #339
            @glasfaser
            Okay, dann blanke ich die Meldung jetzt.
              @glasfaser
              #340
              Also bei der Zeit und beim Terminaltype tickt der Docker anders, stimmt's?
                GlasfaserG Offline
                GlasfaserG Offline
                #341
                Ja , die Befehle gibt es nicht
                z.b:
                root@iobrokerv6:/opt/iobroker# timedatectl
                bash: timedatectl: command not found
                  z.b:
                  #342
                  @glasfaser
                  Klar, das sind alles systemd-Kommandos.
                  Muss ich wohl leider den Code splitten und 'Sonderstrick' machen.
                  (Und/oder den root-Verboten-Code scharf schalten!)
                  • GlasfaserG Offline
                    GlasfaserG Offline
                    #343
                    Jein . kann gut gehen ...
                    , bzw.
                    Das Thema wurde schon mehrmals durchgekaut .. beim Thema " Docker "
                    bzw. auch hier Zusammengefasst :
                    https://forum.iobroker.net/topic/53193/root-user-im-container-docker-ja-nein-warum
                      , bzw.
                      #344
                      @glasfaser
                      Jaja, ich weiß...
                        , bzw.
                        #345
                        @glasfaser
                        Ziehst du nochmal?
                          @glasfaser
                          Ziehst du nochmal?
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #346
                          *** Time and Time Zones ***
                          Tue Apr  4 17:56:58 UTC 2023
                          Tue Apr  4 19:56:58 CEST 2023
                          CEST +0200
                          Etc/UTC
                          *** X-Server-Setup ***
                          X-Server:       false
                          Desktop:
                          Terminal:
                          Run Level:
                          EDIT :
                          sieht auch gut aus
                          /var:
                          33M     /var/
                          30M     /var/lib
                          18M     /var/lib/apt
                          13M     /var/lib/dpkg
                          /opt/iobroker/iobroker-data:
                            CEST +0200
                            Etc/UTC
                            X-Server:       false
                            Desktop:
                            Terminal:
                            Run Level:
                            EDIT :
                            sieht auch gut aus
                            /var:
                            33M     /var/
                            30M     /var/lib
                            18M     /var/lib/apt
                            13M     /var/lib/dpkg
                            #347
                            @glasfaser
                            Okay, zumindest die Fehlermeldungen sind weg. RunLevel gibt es im Docker halt auch nicht im klassischen Sinne.
                            Ich seh gerade, im SUMMARY muss ich das auch umstellen.
                              CEST +0200
                              Etc/UTC
                              X-Server:       false
                              Desktop:
                              Terminal:
                              Run Level:
                              EDIT :
                              sieht auch gut aus
                              /var:
                              33M     /var/
                              30M     /var/lib
                              18M     /var/lib/apt
                              13M     /var/lib/dpkg
                              #348
                              @glasfaser
                              Ziehst du das nochmal?
                              Und kannst du auch mal die Langfassung wie auch die Summary posten?
                                GlasfaserG Offline
                                #349
                                EDIT
                                EDIT
                                  EDIT
                                  EDIT
                                  #350
                                  @glasfaser
                                  Passt also.
                                  Was ich aber immer noch nicht verstanden habe: Wenn es einen user mit der uid=1000 gibt (wird der 'iobroker' sein), warum kann es keinen user 'glasfaser' mit uid=1001 im docker geben?
                                    @glasfaser
                                    Passt also.
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    #351
                                    ist doch schon ein non-root-user
                                    https://medium.com/redbubble/running-a-docker-container-as-a-non-root-user-7d2e00f8ee15
                                      #352
                                      @glasfaser
                                      Ja mir wird immer erzählt das ginge nicht mit einem standard user und man müsse da immer als root herumgeistern.
                                        @glasfaser
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        #353
                                        Das Docker Image ist im Default auf 1000 SETGID und SETUID
                                        siehe auch hier :
                                        https://hub.docker.com/r/buanet/iobroker/dockerfile
                                          siehe auch hier :
                                          #354
                                          @glasfaser
                                          Und einen weiteren user gibt der host nicht her?
