  4. Shellys ("Alt und Plus") über MQTT Adapter
512 Beiträge 5 Kommentatoren 150.9k Aufrufe 6 Beobachtet
  • hotspot_2H hotspot_2
    @mickym So, hab mal etwas gearbeitet ;-).
    Bei dem Shelly Button bin ich mir nicht ganz so sicher wie man das richtig auswertet. Wenn man den Button drückt dann kommt da (richtiger Pfad zum Objekt ist drin) ein JSON mit event und event_cnt. event ist dann z.B. S für einen kurzen Druck, SS für zwei kurze Drücker und L für einen langen Druck auf den Button. event_cnt zählt immer hoch.
           "id": "86408d5662226c61",
           "type": "mqtt in",
           "z": "692f3cf44001c136",
           "name": "",
           "topic": "shellies/sonstiges/bwm_keller/status",
           "qos": "2",
           "datatype": "auto-detect",
           "broker": "b22fc4d3e3f172bb",
           "nl": false,
           "rap": true,
           "rh": 0,
           "inputs": 0,
           "x": 220,
           "y": 340,
           "wires": [
                   "e74cb961cfd52dca"
           "id": "218e611097615166",
           "type": "mqtt in",
           "name": "",
           "topic": "shellies/sonstiges/bwm_unten/status",
           "qos": "2",
           "nl": false,
           "rap": true,
           "rh": 0,
           "inputs": 0,
           "x": 220,
           "y": 400,
           "wires": [
                   "e74cb961cfd52dca"
           "id": "d4bdac625b4b90f5",
           "type": "mqtt in",
           "name": "",
           "topic": "shellies/sonstiges/bwm_oben/status",
           "qos": "2",
           "nl": false,
           "rap": true,
           "rh": 0,
           "inputs": 0,
           "x": 220,
           "y": 460,
           "wires": [
                   "e74cb961cfd52dca"
           "id": "e74cb961cfd52dca",
           "type": "switch",
           "name": "",
           "property": "payload.motion",
           "propertyType": "msg",
           "rules": [
                   "t": "true"
           "checkall": "true",
           "repair": false,
           "outputs": 1,
           "x": 870,
           "y": 520,
           "wires": [
           "id": "411794847503e83f",
           "type": "mqtt in",
           "name": "",
           "topic": "shellies/licht/treppenhaus/unten/status/switch:0",
           "qos": "2",
           "nl": false,
           "rap": true,
           "rh": 0,
           "inputs": 0,
           "x": 260,
           "y": 540,
           "wires": [
                   "d1c3e09e7243a899"
           "id": "d1c3e09e7243a899",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload.output",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 550,
           "y": 540,
           "wires": [
                   "e74cb961cfd52dca"
           "id": "0a50ecf858e5f5fd",
           "type": "mqtt in",
           "name": "",
           "topic": "shellies/licht/treppenhaus/oben/status/switch:0",
           "qos": "2",
           "nl": false,
           "rap": true,
           "rh": 0,
           "inputs": 0,
           "x": 250,
           "y": 600,
           "wires": [
                   "b59a624bcc1d2dde"
           "id": "b59a624bcc1d2dde",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 550,
           "y": 600,
           "wires": [
                   "e74cb961cfd52dca"
           "id": "0fedf4e255e04e63",
           "type": "mqtt in",
           "name": "",
           "topic": "shellies/sonstiges/button_keller/input_event/0",
           "qos": "2",
           "nl": false,
           "rap": true,
           "rh": 0,
           "inputs": 0,
           "x": 250,
           "y": 660,
           "wires": [
           "id": "b22fc4d3e3f172bb",
           "type": "mqtt-broker",
           "name": "iobroker mqtt adapter",
           "broker": "localhost",
           "port": "1883",
           "clientid": "mqttin_nodered",
           "autoConnect": true,
           "usetls": false,
           "protocolVersion": "4",
           "keepalive": "60",
           "cleansession": true,
           "birthTopic": "",
           "birthQos": "0",
           "birthPayload": "",
           "birthMsg": {},
           "closeTopic": "",
           "closeQos": "0",
           "closePayload": "",
           "closeMsg": {},
           "willTopic": "",
           "willQos": "0",
           "willPayload": "",
           "willMsg": {},
           "userProps": "",
           "sessionExpiry": ""
    Hab gerade nochmal was korrigiert.
    mickymM
    mickymM
    mickym
    #217
    @hotspot_2 sagte in Shellys ("Alt und Plus") über MQTT Adapter:
           "type": "mqtt in",
           "name": "",
           "qos": "2",
           "nl": false,
           "rap": true,
           "rh": 0,
           "inputs": 0,
           "x": 220,
           "y": 340,
           "wires": [
                   "e74cb961cfd52dca"
           "type": "mqtt in",
           "name": "",
           "qos": "2",
           "nl": false,
           "rap": true,
           "rh": 0,
           "inputs": 0,
           "x": 220,
           "y": 400,
           "wires": [
                   "e74cb961cfd52dca"
           "type": "mqtt in",
           "name": "",
           "qos": "2",
           "nl": false,
           "rap": true,
           "rh": 0,
           "inputs": 0,
           "x": 220,
           "y": 460,
           "wires": [
                   "e74cb961cfd52dca"
           "type": "switch",
           "name": "",
           "rules": [
                   "t": "true"
           "checkall": "true",
           "repair": false,
           "outputs": 1,
           "x": 870,
           "y": 520,
           "wires": [
           "type": "mqtt in",
           "name": "",
           "qos": "2",
           "nl": false,
           "rap": true,
           "rh": 0,
           "inputs": 0,
           "x": 260,
           "y": 540,
           "wires": [
                   "d1c3e09e7243a899"
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 550,
           "y": 540,
           "wires": [
                   "e74cb961cfd52dca"
           "type": "mqtt in",
           "name": "",
           "qos": "2",
           "nl": false,
           "rap": true,
           "rh": 0,
           "inputs": 0,
           "x": 250,
           "y": 600,
           "wires": [
                   "b59a624bcc1d2dde"
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 550,
           "y": 600,
           "wires": [
                   "e74cb961cfd52dca"
           "type": "mqtt in",
           "name": "",
           "qos": "2",
           "nl": false,
           "rap": true,
           "rh": 0,
           "inputs": 0,
           "x": 250,
           "y": 660,
           "wires": [
           "port": "1883",
           "usetls": false,
           "keepalive": "60",
           "birthTopic": "",
           "birthQos": "0",
           "birthPayload": "",
           "birthMsg": {},
           "closeTopic": "",
           "closeQos": "0",
           "closePayload": "",
           "closeMsg": {},
           "willTopic": "",
           "willQos": "0",
           "willPayload": "",
           "willMsg": {},
           "userProps": "",
           "sessionExpiry": ""
    Ich hab Dir einen Flow geschickt - nimm einfach den. Bei den Bewegungsmelder musst Du motion true ausfiltern, bei den Schaltern und Button interessiert der Inhalt nicht, da sollen die ja nur triggern - egal was da geschaltet wird.
    hotspot_2H 1 Antwort Letzte Antwort
    • mickymM mickym
             "type": "mqtt in",
             "name": "",
             "qos": "2",
             "nl": false,
             "rap": true,
             "rh": 0,
             "inputs": 0,
             "x": 220,
             "y": 340,
             "wires": [
                     "e74cb961cfd52dca"
             "type": "mqtt in",
             "name": "",
             "qos": "2",
             "nl": false,
             "rap": true,
             "rh": 0,
             "inputs": 0,
             "x": 220,
             "y": 400,
             "wires": [
                     "e74cb961cfd52dca"
             "type": "mqtt in",
             "name": "",
             "qos": "2",
             "nl": false,
             "rap": true,
             "rh": 0,
             "inputs": 0,
             "x": 220,
             "y": 460,
             "wires": [
                     "e74cb961cfd52dca"
             "type": "switch",
             "name": "",
             "rules": [
                     "t": "true"
             "checkall": "true",
             "repair": false,
             "outputs": 1,
             "x": 870,
             "y": 520,
             "wires": [
             "type": "mqtt in",
             "name": "",
             "qos": "2",
             "nl": false,
             "rap": true,
             "rh": 0,
             "inputs": 0,
             "x": 260,
             "y": 540,
             "wires": [
                     "d1c3e09e7243a899"
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 550,
             "y": 540,
             "wires": [
                     "e74cb961cfd52dca"
             "type": "mqtt in",
             "name": "",
             "qos": "2",
             "nl": false,
             "rap": true,
             "rh": 0,
             "inputs": 0,
             "x": 250,
             "y": 600,
             "wires": [
                     "b59a624bcc1d2dde"
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 550,
             "y": 600,
             "wires": [
                     "e74cb961cfd52dca"
             "type": "mqtt in",
             "name": "",
             "qos": "2",
             "nl": false,
             "rap": true,
             "rh": 0,
             "inputs": 0,
             "x": 250,
             "y": 660,
             "wires": [
             "port": "1883",
             "usetls": false,
             "keepalive": "60",
             "birthTopic": "",
             "birthQos": "0",
             "birthPayload": "",
             "birthMsg": {},
             "closeTopic": "",
             "closeQos": "0",
             "closePayload": "",
             "closeMsg": {},
             "willTopic": "",
             "willQos": "0",
             "willPayload": "",
             "willMsg": {},
             "userProps": "",
             "sessionExpiry": ""
      hotspot_2H
      hotspot_2H
      hotspot_2
      schrieb am zuletzt editiert von hotspot_2
      #218
      @mickym Alles klar, verstanden. Das mit den Inhalten und filtern bei BWM.
      Ich seh schon das wird deutlich einfacher wie mit Blockly. Und vor allem irgendwie auch viel logischer.
      Welche Möglichkeit habe ich den die Zeit des Triggers nun über einen Wert in einem ioBroker Objekt zu ändern?
        mickymM
        mickymM
        mickym
        #219
        @hotspot_2 Gleich ich pass das nur gerade an - gib mir einfach eine iobroker In Node - wo der Wert drin steht, wie lange das Licht brennen soll und sind das ms oder s ?
        • mickymM mickym
          hotspot_2H
          hotspot_2H
          hotspot_2
          #220
          @mickym
          Der Wert steht in "0_userdata.0.hausautomation.zeitdauer_licht_treppenhaus" und die Zeitdauer in Minuten (number) ist da drin. Aktuell steht der Wert z.B. auf 3.
            @mickym
            mickymM
            mickymM
            mickym
            #221
            So der Flow ist fertig ;)
            Ich hab mal alle Topics der Buttons, Schalter und BWM angepasst. Kernpunkt ist wieder die trigger Node - schau Dir auch immer die Hilfe zu den Nodes an:
            Das alles was triggert den Zeitraum verlängert hatten wir ja schon - neu ist nun das wir mit msg.delay die Verzögerung in der Node überschreiben. ;)
            Da dein Datenpunkt in Minuten angibt - muss die msg.delay Eigenschaft auf eine umgerechnete payload gesetzt werden.
            Beim Setzen der delay rechnen wir also von Minuten noch in ms um:
            und fertig ist der Flow . Hier zum Import:
                   "id": "397e721c8443f53e",
                   "type": "mqtt in",
                   "z": "2e7d4cac81c671e3",
                   "d": true,
                   "name": "",
                   "qos": "2",
                   "nl": false,
                   "rap": true,
                   "rh": 0,
                   "inputs": 0,
                   "x": 460,
                   "y": 1600,
                   "wires": [
                           "f37773770cc10a69"
                   "id": "4e9de718a2e77470",
                   "type": "mqtt in",
                   "d": true,
                   "name": "",
                   "qos": "2",
                   "nl": false,
                   "rap": true,
                   "rh": 0,
                   "inputs": 0,
                   "x": 460,
                   "y": 1640,
                   "wires": [
                           "f37773770cc10a69"
                   "id": "800abea06f19a103",
                   "type": "trigger",
                   "name": "",
                   "op1": "{\"id\":123,\"src\":\"hotspot_2\",\"method\":\"Switch.Set\",\"params\":{\"id\":0,\"on\":true}}",
                   "op2": "{\"id\":123,\"src\":\"hotspot_2\",\"method\":\"Switch.Set\",\"params\":{\"id\":0,\"on\":false}}",
                   "op1type": "json",
                   "op2type": "json",
                   "duration": "2",
                   "extend": true,
                   "overrideDelay": true,
                   "units": "min",
                   "reset": "",
                   "bytopic": "all",
                   "topic": "topic",
                   "outputs": 1,
                   "x": 1130,
                   "y": 1540,
                   "wires": [
                           "b122e2e77c6da325"
                   "id": "c7a2538582f26f99",
                   "type": "switch",
                   "name": "active = true?",
                   "property": "active",
                   "propertyType": "global",
                   "rules": [
                           "t": "true"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 1,
                   "x": 940,
                   "y": 1540,
                   "wires": [
                           "800abea06f19a103"
                   "id": "85adc04bab696758",
                   "type": "mqtt in",
                   "d": true,
                   "name": "",
                   "qos": "2",
                   "nl": false,
                   "rap": true,
                   "rh": 0,
                   "inputs": 0,
                   "x": 460,
                   "y": 1680,
                   "wires": [
                           "f37773770cc10a69"
                   "id": "8e92ad87f1753886",
                   "type": "mqtt in",
                   "d": true,
                   "name": "",
                   "qos": "2",
                   "nl": false,
                   "rap": true,
                   "rh": 0,
                   "inputs": 0,
                   "x": 450,
                   "y": 1420,
                   "wires": [
                           "fc6fb44b1d1d608a"
                   "id": "f37773770cc10a69",
                   "type": "switch",
                   "name": "",
                   "rules": [
                           "t": "true"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 1,
                   "x": 690,
                   "y": 1640,
                   "wires": [
                           "77e70e12f14594fe"
                   "id": "9cbbb699f5a355ef",
                   "type": "mqtt in",
                   "d": true,
                   "name": "",
                   "qos": "2",
                   "nl": false,
                   "rap": true,
                   "rh": 0,
                   "inputs": 0,
                   "x": 440,
                   "y": 1460,
                   "wires": [
                           "fc6fb44b1d1d608a"
                   "id": "8f34eb2c75697e59",
                   "type": "mqtt in",
                   "d": true,
                   "name": "",
                   "qos": "2",
                   "nl": false,
                   "rap": true,
                   "rh": 0,
                   "inputs": 0,
                   "x": 450,
                   "y": 1500,
                   "wires": [
                           "fc6fb44b1d1d608a"
                   "id": "b122e2e77c6da325",
                   "type": "debug",
                   "name": "Schalten",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "complete": "payload",
                   "targetType": "msg",
                   "statusVal": "",
                   "statusType": "auto",
                   "x": 1320,
                   "y": 1540,
                   "wires": []
                   "id": "3f983bcf654e4ce8",
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "delay",
                           "pt": "msg",
                           "to": "payload * 60 *1000",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 920,
                   "y": 1360,
                   "wires": [
                           "800abea06f19a103"
                   "id": "c8a98f98d67408e0",
                   "type": "ioBroker in",
                   "name": "",
                   "topic": "0_userdata.0.hausautomation.zeitdauer_licht_treppenhaus",
                   "payloadType": "value",
                   "onlyack": "",
                   "func": "all",
                   "gap": "",
                   "fireOnStart": "true",
                   "outFormat": "MQTT",
                   "x": 530,
                   "y": 1360,
                   "wires": [
                           "3f983bcf654e4ce8"
                   "id": "77e70e12f14594fe",
                   "type": "junction",
                   "x": 820,
                   "y": 1540,
                   "wires": [
                           "c7a2538582f26f99"
                   "id": "fc6fb44b1d1d608a",
                   "type": "junction",
                   "x": 720,
                   "y": 1460,
                   "wires": [
                           "77e70e12f14594fe"
                   "port": "1883",
                   "usetls": false,
                   "keepalive": "60",
                   "birthTopic": "",
                   "birthQos": "0",
                   "birthPayload": "",
                   "birthMsg": {},
                   "closeTopic": "",
                   "closeQos": "0",
                   "closePayload": "",
                   "closeMsg": {},
                   "willTopic": "",
                   "willQos": "0",
                   "willPayload": "",
                   "willMsg": {},
                   "userProps": "",
                   "sessionExpiry": ""
            Eigentlich easy, wenn man es logisch durchdacht hat. Nun gut das mit dem detached Mode - konnten wir uns ja das wiedereinschalten sparen. ;)
            Achso ist noch das Abprüfen auf die globale Variable drin - musst halt ggf. wieder raus nehmen.
            • mickymM mickym
                     "type": "mqtt in",
                     "d": true,
                     "name": "",
                     "qos": "2",
                     "nl": false,
                     "rap": true,
                     "rh": 0,
                     "inputs": 0,
                     "x": 460,
                     "y": 1600,
                     "wires": [
                             "f37773770cc10a69"
                     "type": "mqtt in",
                     "d": true,
                     "name": "",
                     "qos": "2",
                     "nl": false,
                     "rap": true,
                     "rh": 0,
                     "inputs": 0,
                     "x": 460,
                     "y": 1640,
                     "wires": [
                             "f37773770cc10a69"
                     "type": "trigger",
                     "name": "",
                     "op1type": "json",
                     "op2type": "json",
                     "duration": "2",
                     "extend": true,
                     "units": "min",
                     "reset": "",
                     "bytopic": "all",
                     "topic": "topic",
                     "outputs": 1,
                     "x": 1130,
                     "y": 1540,
                     "wires": [
                             "b122e2e77c6da325"
                     "type": "switch",
                     "rules": [
                             "t": "true"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 1,
                     "x": 940,
                     "y": 1540,
                     "wires": [
                             "800abea06f19a103"
                     "type": "mqtt in",
                     "d": true,
                     "name": "",
                     "qos": "2",
                     "nl": false,
                     "rap": true,
                     "rh": 0,
                     "inputs": 0,
                     "x": 460,
                     "y": 1680,
                     "wires": [
                             "f37773770cc10a69"
                     "type": "mqtt in",
                     "d": true,
                     "name": "",
                     "qos": "2",
                     "nl": false,
                     "rap": true,
                     "rh": 0,
                     "inputs": 0,
                     "x": 450,
                     "y": 1420,
                     "wires": [
                             "fc6fb44b1d1d608a"
                     "type": "switch",
                     "name": "",
                     "rules": [
                             "t": "true"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 1,
                     "x": 690,
                     "y": 1640,
                     "wires": [
                             "77e70e12f14594fe"
                     "type": "mqtt in",
                     "d": true,
                     "name": "",
                     "qos": "2",
                     "nl": false,
                     "rap": true,
                     "rh": 0,
                     "inputs": 0,
                     "x": 440,
                     "y": 1460,
                     "wires": [
                             "fc6fb44b1d1d608a"
                     "type": "mqtt in",
                     "d": true,
                     "name": "",
                     "qos": "2",
                     "nl": false,
                     "rap": true,
                     "rh": 0,
                     "inputs": 0,
                     "x": 450,
                     "y": 1500,
                     "wires": [
                             "fc6fb44b1d1d608a"
                     "type": "debug",
                     "name": "Schalten",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1320,
                     "y": 1540,
                     "wires": []
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "delay",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 920,
                     "y": 1360,
                     "wires": [
                             "800abea06f19a103"
                     "name": "",
                     "onlyack": "",
                     "func": "all",
                     "gap": "",
                     "x": 530,
                     "y": 1360,
                     "wires": [
                             "3f983bcf654e4ce8"
                     "type": "junction",
                     "x": 820,
                     "y": 1540,
                     "wires": [
                             "c7a2538582f26f99"
                     "type": "junction",
                     "x": 720,
                     "y": 1460,
                     "wires": [
                             "77e70e12f14594fe"
                     "port": "1883",
                     "usetls": false,
                     "keepalive": "60",
                     "birthTopic": "",
                     "birthQos": "0",
                     "birthPayload": "",
                     "birthMsg": {},
                     "closeTopic": "",
                     "closeQos": "0",
                     "closePayload": "",
                     "closeMsg": {},
                     "willTopic": "",
                     "willQos": "0",
                     "willPayload": "",
                     "willMsg": {},
                     "userProps": "",
                     "sessionExpiry": ""
              hotspot_2H
              hotspot_2H
              hotspot_2
              #222
              @mickym Super!
              Kurze Frage noch: Der Switch "active=true" ist der der die globale Variable prüft (ob Treppenhauslicht aktiv oder nicht) ? Oder wird der für die Zusammenführung der ganzen Nodes gebraucht?
                @mickym Super!
                mickymM
                mickymM
                mickym
                #223
                @hotspot_2
                @mickym Super!
                Habs gerade geschrieben - ja das war mit dem Abprüfen der globalen Variable - das kannst rausnehmen oder muss halt setzen. Du kannst sowas ja auch über einen scheduler setzen - zum Beispiel dass es automatisch aktiv wird wenn es dunkel wird oder nicht. Du kannst auch beides nehmen. Dass Du über Dein Jarvis die Automatik einschaltest - gleichzeitig wenn die Automatik ein ist, aber nur bei Dunkelheit einschaltet. Wie auch immer. Für solche Tageszeiten empfehle ich den Lightscheduler - aber das machen wir erst, wenn Du sowas brauchst.
                • mickymM mickym
                  @hotspot_2
                  @mickym Super!
                  hotspot_2H
                  hotspot_2H
                  hotspot_2
                  #224
                  @mickym
                  So, hab mal noch die Bewegungsmelder zum abschalten reingemacht.
                         "id": "d61506de1954395b",
                         "type": "trigger",
                         "name": "",
                         "op1type": "json",
                         "op2type": "json",
                         "duration": "2",
                         "extend": true,
                         "overrideDelay": false,
                         "units": "min",
                         "reset": "",
                         "bytopic": "all",
                         "topic": "topic",
                         "outputs": 1,
                         "x": 1130,
                         "y": 420,
                         "wires": [
                                 "aea976760342a7ca",
                                 "b31a1ad723458b20",
                                 "cdde801771054bfd"
                         "id": "13f2741ac766c270",
                         "type": "switch",
                         "name": "",
                         "rules": [
                                 "t": "true"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 1,
                         "x": 590,
                         "y": 600,
                         "wires": [
                                 "cb40f947f82f67aa"
                         "id": "cb40f947f82f67aa",
                         "type": "ioBroker get",
                         "name": "Schalter",
                         "topic": "0_userdata.0.hausautomation.bewegungsmelder_treppenhaus",
                         "attrname": "payload",
                         "errOnInvalidState": "nothing",
                         "x": 720,
                         "y": 600,
                         "wires": [
                                 "a7f6db04440edd6b"
                         "id": "a7f6db04440edd6b",
                         "type": "switch",
                         "name": "Schalter = true?",
                         "property": "payload",
                         "rules": [
                                 "t": "true"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 1,
                         "x": 880,
                         "y": 600,
                         "wires": [
                                 "d61506de1954395b"
                         "id": "dc7cb1f29dd48123",
                         "type": "mqtt in",
                         "name": "",
                         "qos": "2",
                         "nl": false,
                         "rap": true,
                         "rh": 0,
                         "inputs": 0,
                         "x": 290,
                         "y": 360,
                         "wires": [
                                 "6a2f9b58c826dbf9"
                         "id": "d6a73f6b14cae279",
                         "type": "mqtt in",
                         "name": "",
                         "topic": "shellies/licht/treppenhaus/oben/command/switch:0",
                         "qos": "2",
                         "nl": false,
                         "rap": true,
                         "rh": 0,
                         "inputs": 0,
                         "x": 270,
                         "y": 420,
                         "wires": [
                                 "6a2f9b58c826dbf9"
                         "id": "e520634c4d127742",
                         "type": "mqtt in",
                         "name": "",
                         "topic": "shellies/licht/treppenhaus/unten/command/switch:0",
                         "qos": "2",
                         "nl": false,
                         "rap": true,
                         "rh": 0,
                         "inputs": 0,
                         "x": 270,
                         "y": 480,
                         "wires": [
                                 "6a2f9b58c826dbf9"
                         "id": "453d4b0e34fa74da",
                         "type": "mqtt in",
                         "name": "",
                         "qos": "2",
                         "nl": false,
                         "rap": true,
                         "rh": 0,
                         "inputs": 0,
                         "x": 320,
                         "y": 540,
                         "wires": [
                                 "13f2741ac766c270"
                         "id": "cb8976790deb4942",
                         "type": "mqtt in",
                         "name": "",
                         "qos": "2",
                         "nl": false,
                         "rap": true,
                         "rh": 0,
                         "inputs": 0,
                         "x": 320,
                         "y": 600,
                         "wires": [
                                 "13f2741ac766c270"
                         "id": "4f5732168c07a0ab",
                         "type": "mqtt in",
                         "name": "",
                         "qos": "2",
                         "nl": false,
                         "rap": true,
                         "rh": 0,
                         "inputs": 0,
                         "x": 320,
                         "y": 660,
                         "wires": [
                                 "13f2741ac766c270"
                         "id": "cdde801771054bfd",
                         "type": "mqtt out",
                         "name": "",
                         "topic": "shellies/licht/treppenhaus/keller/rpc",
                         "qos": "",
                         "retain": "",
                         "respTopic": "",
                         "contentType": "",
                         "userProps": "",
                         "correl": "",
                         "expiry": "",
                         "x": 1420,
                         "y": 480,
                         "wires": []
                         "id": "b31a1ad723458b20",
                         "type": "mqtt out",
                         "name": "",
                         "topic": "shellies/licht/treppenhaus/oben/rpc",
                         "qos": "",
                         "retain": "",
                         "respTopic": "",
                         "contentType": "",
                         "userProps": "",
                         "correl": "",
                         "expiry": "",
                         "x": 1420,
                         "y": 420,
                         "wires": []
                         "id": "aea976760342a7ca",
                         "type": "mqtt out",
                         "name": "",
                         "topic": "shellies/licht/treppenhaus/unten/rpc",
                         "qos": "",
                         "retain": "",
                         "respTopic": "",
                         "contentType": "",
                         "userProps": "",
                         "correl": "",
                         "expiry": "",
                         "x": 1420,
                         "y": 360,
                         "wires": []
                         "id": "ce80c62e18617a11",
                         "name": "",
                         "onlyack": "",
                         "func": "all",
                         "gap": "",
                         "x": 250,
                         "y": 300,
                         "wires": [
                                 "7489466fabc808bb"
                         "id": "7489466fabc808bb",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "delay",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 920,
                         "y": 300,
                         "wires": [
                                 "d61506de1954395b"
                         "id": "6a2f9b58c826dbf9",
                         "type": "junction",
                         "x": 540,
                         "y": 420,
                         "wires": [
                                 "d61506de1954395b"
                         "port": "1883",
                         "usetls": false,
                         "keepalive": "60",
                         "birthTopic": "",
                         "birthQos": "0",
                         "birthPayload": "",
                         "birthMsg": {},
                         "closeTopic": "",
                         "closeQos": "0",
                         "closePayload": "",
                         "closeMsg": {},
                         "willTopic": "",
                         "willQos": "0",
                         "willPayload": "",
                         "willMsg": {},
                         "userProps": "",
                         "sessionExpiry": ""
                  Super Sache. Wenn ich mir jetzt das Blockly anschaue wäre ich auch definitiv bei "grottig".
                  Danke!
                    @mickym
                           "type": "trigger",
                           "name": "",
                           "op1type": "json",
                           "op2type": "json",
                           "duration": "2",
                           "extend": true,
                           "units": "min",
                           "reset": "",
                           "bytopic": "all",
                           "topic": "topic",
                           "outputs": 1,
                           "x": 1130,
                           "y": 420,
                           "wires": [
                                   "aea976760342a7ca",
                                   "b31a1ad723458b20",
                                   "cdde801771054bfd"
                           "type": "switch",
                           "name": "",
                           "rules": [
                                   "t": "true"
                           "checkall": "true",
                           "repair": false,
                           "outputs": 1,
                           "x": 590,
                           "y": 600,
                           "wires": [
                                   "cb40f947f82f67aa"
                           "name": "Schalter",
                           "x": 720,
                           "y": 600,
                           "wires": [
                                   "a7f6db04440edd6b"
                           "type": "switch",
                           "rules": [
                                   "t": "true"
                           "checkall": "true",
                           "repair": false,
                           "outputs": 1,
                           "x": 880,
                           "y": 600,
                           "wires": [
                                   "d61506de1954395b"
                           "type": "mqtt in",
                           "name": "",
                           "qos": "2",
                           "nl": false,
                           "rap": true,
                           "rh": 0,
                           "inputs": 0,
                           "x": 290,
                           "y": 360,
                           "wires": [
                                   "6a2f9b58c826dbf9"
                           "type": "mqtt in",
                           "name": "",
                           "qos": "2",
                           "nl": false,
                           "rap": true,
                           "rh": 0,
                           "inputs": 0,
                           "x": 270,
                           "y": 420,
                           "wires": [
                                   "6a2f9b58c826dbf9"
                           "type": "mqtt in",
                           "name": "",
                           "qos": "2",
                           "nl": false,
                           "rap": true,
                           "rh": 0,
                           "inputs": 0,
                           "x": 270,
                           "y": 480,
                           "wires": [
                                   "6a2f9b58c826dbf9"
                           "type": "mqtt in",
                           "name": "",
                           "qos": "2",
                           "nl": false,
                           "rap": true,
                           "rh": 0,
                           "inputs": 0,
                           "x": 320,
                           "y": 540,
                           "wires": [
                                   "13f2741ac766c270"
                           "type": "mqtt in",
                           "name": "",
                           "qos": "2",
                           "nl": false,
                           "rap": true,
                           "rh": 0,
                           "inputs": 0,
                           "x": 320,
                           "y": 600,
                           "wires": [
                                   "13f2741ac766c270"
                           "type": "mqtt in",
                           "name": "",
                           "qos": "2",
                           "nl": false,
                           "rap": true,
                           "rh": 0,
                           "inputs": 0,
                           "x": 320,
                           "y": 660,
                           "wires": [
                                   "13f2741ac766c270"
                           "type": "mqtt out",
                           "name": "",
                           "qos": "",
                           "retain": "",
                           "respTopic": "",
                           "contentType": "",
                           "userProps": "",
                           "correl": "",
                           "expiry": "",
                           "x": 1420,
                           "y": 480,
                           "wires": []
                           "type": "mqtt out",
                           "name": "",
                           "qos": "",
                           "retain": "",
                           "respTopic": "",
                           "contentType": "",
                           "userProps": "",
                           "correl": "",
                           "expiry": "",
                           "x": 1420,
                           "y": 420,
                           "wires": []
                           "type": "mqtt out",
                           "name": "",
                           "qos": "",
                           "retain": "",
                           "respTopic": "",
                           "contentType": "",
                           "userProps": "",
                           "correl": "",
                           "expiry": "",
                           "x": 1420,
                           "y": 360,
                           "wires": []
                           "name": "",
                           "onlyack": "",
                           "func": "all",
                           "gap": "",
                           "x": 250,
                           "y": 300,
                           "wires": [
                                   "7489466fabc808bb"
                           "type": "change",
                           "name": "",
                           "rules": [
                                   "t": "set",
                                   "p": "delay",
                                   "pt": "msg",
                                   "tot": "jsonata"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 920,
                           "y": 300,
                           "wires": [
                                   "d61506de1954395b"
                           "type": "junction",
                           "x": 540,
                           "y": 420,
                           "wires": [
                                   "d61506de1954395b"
                           "port": "1883",
                           "usetls": false,
                           "keepalive": "60",
                           "birthTopic": "",
                           "birthQos": "0",
                           "birthPayload": "",
                           "birthMsg": {},
                           "closeTopic": "",
                           "closeQos": "0",
                           "closePayload": "",
                           "closeMsg": {},
                           "willTopic": "",
                           "willQos": "0",
                           "willPayload": "",
                           "willMsg": {},
                           "userProps": "",
                           "sessionExpiry": ""
                    Danke!
                    mickymM
                    mickymM
                    mickym
                    #225
                    es glaubt mir nur niemand, der es nicht ausprobiert. Das schöne ist halt dass Du mit Deiner Logik relativ schnell verstehst an welcher Stelle man eingreifen muss und kann und nicht Spaghetticode entwickelt. ;)
                    Ehrlich gesagt finde ich es immer noch schlimm:
                    Gut manches hätte man sicher auch mit Blockly einfacher machen können - vor allem wenn detached eingeschaltet gewesen wäre. Ich hoffe es funktioniert alles - sonst musst mit debug nodes arbeiten.
                    • mickymM mickym
                      hotspot_2H
                      hotspot_2H
                      hotspot_2
                      #226
                      @mickym Definitiv! Es ist einfach schlecht.
                      Funktioniert alles bestens. Das Licht funktioniert wie gewünscht.
                      Freu mich.
                      Würde morgen gerne noch ein paar andere Blocklys anschauen.
                      Gibt es denn ein Node um zu eine bestimmten Zeitpunkt MQTT ins zu prüfen (Switch an oder aus) um dann z.B. Switch ein- oder auszuschalten?
                      Würde dann morgen noch weitere Blocklys umziehen.
                        Freu mich.
                        mickymM
                        mickymM
                        mickym
                        #227
                        Theoretisch ja - insbesondere bei mqtt-Version 5. Aber machs einfach nicht, das ist nicht state of the art und wiederspricht dem mqtt-Konzept. Mqtt gibt immer aktuelle Trigger aus - für die Speicherung von Zuständen ist die Anwendung verantwortlich. Genau für diesen Zweck lass mqtt triggern und speichere den Zustand in einer Node-Red Variablen ab. Diese kannst Du dann zu beliebigen Zeitpunkten abfragen und darauf reagieren. Du kannst auch Datenpunkte im mqtt-Adapter abfragen. ;) Den hast Du bis jetzt ja gar nicht genutzt. Dafür könntest Du ihn nutzen. Im Prinzip ist das auch in Verbindung mit Node-Red die größte Stärke desiobrokers. ;)
                        Grundsätzlich sollte man aber nicht pollen - ganz allgemein.
                        Wenn ich beispielsweise die Wohnung verlasse, dann werden einfach alle Lichter ausgeschaltet - da interessiert es mich nicht, ob das Licht vorher eingeschaltet war oder nicht. Also überprüfe hier erst mal Deine Logik, ob solche Abfragen erforderlich sind. Ein eingeschaltetes Licht nochmal einzuschalten - belastet gar nichts - weder ein Relais noch sonst was - und ein ausgeschaltetes Licht auszuschalten tut auch niemand weh und ist definitiv einfacher - als Abfragen. Dann ist es sinnvoller abzufragen ob jemand daheim ist.
                        Ich habe meine Shellies alle so geschaltet, dass wenn ich sie einschalte (also über den Schalter) dann sind die Bewegungsmelder inaktiv. Wenn ich die Shellies am Schalter ausschalte werden die Bewegungsmelder aktiv, aber nur wenn es dunkel ist. Der Vorteil ist, dass ich damit ein Logik implementiert habe, wenn ich mal keine GUI oder App zur Hand habe. Aber wie gesagt - jeder überlegt sich, was er für sinnvoll erachtet.
                        • mickymM mickym
                          hotspot_2H
                          hotspot_2H
                          hotspot_2
                          #228
                          @mickym
                          Ok.
                          Hab gerade noch diesen Fehler entdeckt im Protokoll:
                          Client [mqttin_nodered] Message 9588 deleted after 11 retries
                          Kann man da mehr Infos dazu irgendwo finden?
                            @mickym
                            Ok.
                            mickymM
                            mickymM
                            mickym
                            #229
                            @mickym
                            Ok.
                            Das ist leider ein Mist des mqtt-Adapters als Broker. Deswegen nutze ich diesen Adapter nur als client und nicht als Broker. Wenn das öfters auftritt empfehle ich Dir mosquitto als Mqtt-Broker. Das sind leider Inkompatibilitäten des Adapters.
                            Siehe hier: https://forum.iobroker.net/post/441763
                            • mickymM mickym
                              @mickym
                              Ok.
                              hotspot_2H
                              hotspot_2H
                              hotspot_2
                              #230
                              @mickym
                              Ok. Mosquito aber nicht als Adapter dann, oder? Sondern neben iobroker dann auf der Maschine installiert.
                                @mickym
                                mickymM
                                mickymM
                                mickym
                                #231
                                @hotspot_2 Genau - ich habe mosquitto als Service laufen und den mqtt-Adapter als Client zum mosquitto
                                Ist eigentlich super einfach zu installieren.
                                In dem Fall ist das nicht viel Umstellungsaufwand für Dich, weil wenn Du die gleichen Credentials nimmst nur ein MQTT-Broker auf einer Maschine betreiben kannst. Am Besten ist dann dass Du alle Haken rausmachst:
                                Empfehle ich Dir auch für den Broker übrigens.
                                Falls Du mosquitto installierst - die Client Tools brauchst Du nicht.
                                Also nur
                                sudo apt install mosquitto
                                • mickymM mickym
                                  Also nur
                                  hotspot_2H
                                  hotspot_2H
                                  hotspot_2
                                  #232
                                  @mickym Dem Thema Mosquito usw. nehme ich mich heute auch noch an. Es laufen doch einige Fehlermeldungen (wie oben) an. Werde dann den mosquitto als broker installieren und ich greife dann mit dem mqtt Adapter als Client auf den mosquitto zu und habe dann alle mqtts wieder in iobroker. So ist das Konzept, oder? Stelle ich dann aber alles bei mir auf den mosquitto um also z.B. auch meine ESPs?
                                  Habe noch eine zweite Frage: Bastele gerade an einer Erweiterung des Treppenhaus Licht Flows. Würde ich Dir dann nachher mal zeigen wollen (ist nicht viel, aber interessant ob ich es richtig mache für mich). Frage ist noch: Wenn ich einen Switch-Node habe der true und false als Ausgänge hat (Ergebnis) wie lasse ich den den Flow korrekt enden wenn es nach false dann nicht mehr weiter geht (also keine weitere Aktion folgt). Lässt man dann die Verbindung einfach weg oder sollte man das anders lösen?
                                    mickymM
                                    mickymM
                                    mickym
                                    #233
                                    Nein auf den Shellies oder Clients musst Du gar nichts ändern, wenn Du in mosquitto die gleichen Credentials (Benutzer und Passwort) falls Du vergeben hast. Die Clients merken ja eigentlich nicht, dass da ein anderer Broker dahinter hängt, da IP-Adresse und Port ja gleich bleiben. Im mqtt-Adapter subscribest Du alles - wie in meinem Screenshot gezeigt - also #.
                                    Damit hast Du quasi den gesamten mosquitto im mqtt-Adapter und du erkennst keinen Unterschied. Im Gegenteil kannst Du nun auch direkt in die Datenpunkte schreiben - da machte der Broker auch oft Probleme. Du nutzt ja den gleichen Adapter nur eben als Client:
                                    Du kannst doch die Ausgänge die nicht nutzt einfach löschen:
                                    Standard ist eh erst mal ein Ausgang und Du kannst beliebig viele Ausgange hinzufügen oder löschen:
                                    Du kannst aber auch die Verbindung einfach weglassen. Es gibt auch Nodes die haben 2 oder mehrere Ausgänge, die Du nicht nutzen musst. Beispiel ist die exec Node - da musst Du nicht alle 3 Ausgänge nutzen. ;)
                                    • mickymM mickym
                                      hotspot_2H
                                      hotspot_2H
                                      hotspot_2
                                      #234
                                      @mickym So, ich habe jetzt mal was eingebaut in den Flow. Idee ist das ich einen zusätzlichen Schalter habe der bei true die Bewegungsmelder nur einschalten soll wenn es dunkel ist und bei false immer. Davor gibt es noch einen Schalter der dafür sorgen soll ob die Bewegungsmelder überhaupt aktiviert worden sind.
                                             "type": "trigger",
                                             "name": "",
                                             "op1type": "json",
                                             "op2type": "json",
                                             "duration": "2",
                                             "extend": true,
                                             "units": "min",
                                             "reset": "",
                                             "bytopic": "all",
                                             "topic": "topic",
                                             "outputs": 1,
                                             "x": 1130,
                                             "y": 420,
                                             "wires": [
                                                     "aea976760342a7ca",
                                                     "b31a1ad723458b20",
                                                     "cdde801771054bfd"
                                             "type": "switch",
                                             "name": "",
                                             "rules": [
                                                     "t": "true"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 1,
                                             "x": 590,
                                             "y": 600,
                                             "wires": [
                                                     "cb40f947f82f67aa"
                                             "name": "Schalter",
                                             "x": 740,
                                             "y": 600,
                                             "wires": [
                                                     "a7f6db04440edd6b"
                                             "type": "switch",
                                             "rules": [
                                                     "t": "true"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 1,
                                             "x": 920,
                                             "y": 600,
                                             "wires": [
                                                     "1c6a8158f2b8126a"
                                             "type": "mqtt in",
                                             "name": "",
                                             "qos": "2",
                                             "nl": false,
                                             "rap": true,
                                             "rh": 0,
                                             "inputs": 0,
                                             "x": 290,
                                             "y": 360,
                                             "wires": [
                                                     "6a2f9b58c826dbf9"
                                             "type": "mqtt in",
                                             "name": "",
                                             "qos": "2",
                                             "nl": false,
                                             "rap": true,
                                             "rh": 0,
                                             "inputs": 0,
                                             "x": 270,
                                             "y": 420,
                                             "wires": [
                                                     "6a2f9b58c826dbf9"
                                             "type": "mqtt in",
                                             "name": "",
                                             "qos": "2",
                                             "nl": false,
                                             "rap": true,
                                             "rh": 0,
                                             "inputs": 0,
                                             "x": 270,
                                             "y": 480,
                                             "wires": [
                                                     "6a2f9b58c826dbf9"
                                             "type": "mqtt in",
                                             "name": "",
                                             "qos": "2",
                                             "nl": false,
                                             "rap": true,
                                             "rh": 0,
                                             "inputs": 0,
                                             "x": 320,
                                             "y": 540,
                                             "wires": [
                                                     "13f2741ac766c270"
                                             "type": "mqtt in",
                                             "name": "",
                                             "qos": "2",
                                             "nl": false,
                                             "rap": true,
                                             "rh": 0,
                                             "inputs": 0,
                                             "x": 320,
                                             "y": 600,
                                             "wires": [
                                                     "13f2741ac766c270"
                                             "type": "mqtt in",
                                             "name": "",
                                             "qos": "2",
                                             "nl": false,
                                             "rap": true,
                                             "rh": 0,
                                             "inputs": 0,
                                             "x": 320,
                                             "y": 660,
                                             "wires": [
                                                     "13f2741ac766c270"
                                             "type": "mqtt out",
                                             "name": "",
                                             "qos": "",
                                             "retain": "",
                                             "respTopic": "",
                                             "contentType": "",
                                             "userProps": "",
                                             "correl": "",
                                             "expiry": "",
                                             "x": 1420,
                                             "y": 480,
                                             "wires": []
                                             "type": "mqtt out",
                                             "name": "",
                                             "qos": "",
                                             "retain": "",
                                             "respTopic": "",
                                             "contentType": "",
                                             "userProps": "",
                                             "correl": "",
                                             "expiry": "",
                                             "x": 1420,
                                             "y": 420,
                                             "wires": []
                                             "type": "mqtt out",
                                             "name": "",
                                             "qos": "",
                                             "retain": "",
                                             "respTopic": "",
                                             "contentType": "",
                                             "userProps": "",
                                             "correl": "",
                                             "expiry": "",
                                             "x": 1420,
                                             "y": 360,
                                             "wires": []
                                             "name": "",
                                             "onlyack": "",
                                             "func": "all",
                                             "gap": "",
                                             "x": 250,
                                             "y": 300,
                                             "wires": [
                                                     "7489466fabc808bb"
                                             "type": "change",
                                             "name": "",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "delay",
                                                     "pt": "msg",
                                                     "tot": "jsonata"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 920,
                                             "y": 300,
                                             "wires": [
                                                     "d61506de1954395b"
                                             "id": "4de2c4fe8b51e654",
                                             "type": "light-scheduler",
                                             "settings": "4b848ab17ecfd60b",
                                             "events": "[{\"start\":{\"dow\":0,\"mod\":595},\"end\":{\"dow\":0,\"mod\":605}}]",
                                             "topic": "",
                                             "name": "",
                                             "onPayload": "true",
                                             "onPayloadType": "bool",
                                             "offPayload": "false",
                                             "offPayloadType": "bool",
                                             "onlyWhenDark": true,
                                             "scheduleRndMax": 0,
                                             "sunElevationThreshold": "3",
                                             "sunShowElevationInStatus": false,
                                             "outputfreq": "output.statechange.startup",
                                             "x": 980,
                                             "y": 680,
                                             "wires": [
                                                     "2002136e01a05254"
                                             "id": "814349e7d60ec173",
                                             "type": "switch",
                                             "rules": [
                                                     "t": "true"
                                                     "t": "false"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 2,
                                             "x": 760,
                                             "y": 720,
                                             "wires": [
                                                     "4de2c4fe8b51e654"
                                                     "2002136e01a05254"
                                             "id": "1c6a8158f2b8126a",
                                             "name": "Schalter",
                                             "topic": "0_userdata.0.hausautomation.bewegungsmelder_aktiv_nachts",
                                             "x": 600,
                                             "y": 720,
                                             "wires": [
                                                     "814349e7d60ec173"
                                             "type": "junction",
                                             "x": 540,
                                             "y": 420,
                                             "wires": [
                                                     "d61506de1954395b"
                                             "id": "2002136e01a05254",
                                             "type": "junction",
                                             "x": 1100,
                                             "y": 760,
                                             "wires": [
                                                     "d61506de1954395b"
                                             "port": "1883",
                                             "usetls": false,
                                             "keepalive": "60",
                                             "birthTopic": "",
                                             "birthQos": "0",
                                             "birthPayload": "",
                                             "birthMsg": {},
                                             "closeTopic": "",
                                             "closeQos": "0",
                                             "closePayload": "",
                                             "closeMsg": {},
                                             "willTopic": "",
                                             "willQos": "0",
                                             "willPayload": "",
                                             "willMsg": {},
                                             "userProps": "",
                                             "sessionExpiry": ""
                                             "id": "4b848ab17ecfd60b",
                                             "type": "light-scheduler-settings",
                                             "name": "my settings",
                                             "latitude": "48.8924",
                                             "longitude": "9.1876"
                                      Nun würde ich noch gerne das Licht, wenn es dunkel ist, aktivieren wenn jemand an einer der beiden Türklingeln (unten und oben) klingelt. Da stellt sich mir noch die Frage ob ich irgendwie die vorhandene Node Light Scheduler ebenfalls nutzen kann und keine zweite Flow einfügen muss. Das wird aber dann vermutlich über das Thema global Payload passieren, oder?
                                               "type": "trigger",
                                               "name": "",
                                               "op1type": "json",
                                               "op2type": "json",
                                               "duration": "2",
                                               "extend": true,
                                               "units": "min",
                                               "reset": "",
                                               "bytopic": "all",
                                               "topic": "topic",
                                               "outputs": 1,
                                               "x": 1130,
                                               "y": 420,
                                               "wires": [
                                                       "aea976760342a7ca",
                                                       "b31a1ad723458b20",
                                                       "cdde801771054bfd"
                                               "type": "switch",
                                               "name": "",
                                               "rules": [
                                                       "t": "true"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 1,
                                               "x": 590,
                                               "y": 600,
                                               "wires": [
                                                       "cb40f947f82f67aa"
                                               "name": "Schalter",
                                               "x": 740,
                                               "y": 600,
                                               "wires": [
                                                       "a7f6db04440edd6b"
                                               "type": "switch",
                                               "rules": [
                                                       "t": "true"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 1,
                                               "x": 920,
                                               "y": 600,
                                               "wires": [
                                                       "1c6a8158f2b8126a"
                                               "type": "mqtt in",
                                               "name": "",
                                               "qos": "2",
                                               "nl": false,
                                               "rap": true,
                                               "rh": 0,
                                               "inputs": 0,
                                               "x": 290,
                                               "y": 360,
                                               "wires": [
                                                       "6a2f9b58c826dbf9"
                                               "type": "mqtt in",
                                               "name": "",
                                               "qos": "2",
                                               "nl": false,
                                               "rap": true,
                                               "rh": 0,
                                               "inputs": 0,
                                               "x": 270,
                                               "y": 420,
                                               "wires": [
                                                       "6a2f9b58c826dbf9"
                                               "type": "mqtt in",
                                               "name": "",
                                               "qos": "2",
                                               "nl": false,
                                               "rap": true,
                                               "rh": 0,
                                               "inputs": 0,
                                               "x": 270,
                                               "y": 480,
                                               "wires": [
                                                       "6a2f9b58c826dbf9"
                                               "type": "mqtt in",
                                               "name": "",
                                               "qos": "2",
                                               "nl": false,
                                               "rap": true,
                                               "rh": 0,
                                               "inputs": 0,
                                               "x": 320,
                                               "y": 540,
                                               "wires": [
                                                       "13f2741ac766c270"
                                               "type": "mqtt in",
                                               "name": "",
                                               "qos": "2",
                                               "nl": false,
                                               "rap": true,
                                               "rh": 0,
                                               "inputs": 0,
                                               "x": 320,
                                               "y": 600,
                                               "wires": [
                                                       "13f2741ac766c270"
                                               "type": "mqtt in",
                                               "name": "",
                                               "qos": "2",
                                               "nl": false,
                                               "rap": true,
                                               "rh": 0,
                                               "inputs": 0,
                                               "x": 320,
                                               "y": 660,
                                               "wires": [
                                                       "13f2741ac766c270"
                                               "type": "mqtt out",
                                               "name": "",
                                               "qos": "",
                                               "retain": "",
                                               "respTopic": "",
                                               "contentType": "",
                                               "userProps": "",
                                               "correl": "",
                                               "expiry": "",
                                               "x": 1420,
                                               "y": 480,
                                               "wires": []
                                               "type": "mqtt out",
                                               "name": "",
                                               "qos": "",
                                               "retain": "",
                                               "respTopic": "",
                                               "contentType": "",
                                               "userProps": "",
                                               "correl": "",
                                               "expiry": "",
                                               "x": 1420,
                                               "y": 420,
                                               "wires": []
                                               "type": "mqtt out",
                                               "name": "",
                                               "qos": "",
                                               "retain": "",
                                               "respTopic": "",
                                               "contentType": "",
                                               "userProps": "",
                                               "correl": "",
                                               "expiry": "",
                                               "x": 1420,
                                               "y": 360,
                                               "wires": []
                                               "name": "",
                                               "onlyack": "",
                                               "func": "all",
                                               "gap": "",
                                               "x": 250,
                                               "y": 300,
                                               "wires": [
                                                       "7489466fabc808bb"
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "delay",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 920,
                                               "y": 300,
                                               "wires": [
                                                       "d61506de1954395b"
                                               "topic": "",
                                               "name": "",
                                               "x": 980,
                                               "y": 680,
                                               "wires": [
                                                       "2002136e01a05254"
                                               "type": "switch",
                                               "rules": [
                                                       "t": "true"
                                                       "t": "false"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 2,
                                               "x": 760,
                                               "y": 720,
                                               "wires": [
                                                       "4de2c4fe8b51e654"
                                                       "2002136e01a05254"
                                               "name": "Schalter",
                                               "x": 600,
                                               "y": 720,
                                               "wires": [
                                                       "814349e7d60ec173"
                                               "type": "junction",
                                               "x": 540,
                                               "y": 420,
                                               "wires": [
                                                       "d61506de1954395b"
                                               "type": "junction",
                                               "x": 1100,
                                               "y": 760,
                                               "wires": [
                                                       "d61506de1954395b"
                                               "port": "1883",
                                               "usetls": false,
                                               "keepalive": "60",
                                               "birthTopic": "",
                                               "birthQos": "0",
                                               "birthPayload": "",
                                               "birthMsg": {},
                                               "closeTopic": "",
                                               "closeQos": "0",
                                               "closePayload": "",
                                               "closeMsg": {},
                                               "willTopic": "",
                                               "willQos": "0",
                                               "willPayload": "",
                                               "willMsg": {},
                                               "userProps": "",
                                               "sessionExpiry": ""
                                        mickymM
                                        mickymM
                                        mickym
                                        #235
                                        @hotspot_2 Also Du hast den falschen Node genutzt beim LightScheduler. Den Du genutzt hast, der triggert.
                                        Du brauchst aber die Filter node. Ich finde es zwar mit deinen Schalter langsam übertrieben. Du musst ein bisschen auf Ästhetik achten - und das ganze etwas auseinander ziehen - dann kannst Du oben auch noch Deinen anderen Geräte in den Filter laufen lassen:
                                               "id": "175f30df96275374",
                                               "type": "trigger",
                                               "name": "",
                                               "op1type": "json",
                                               "op2type": "json",
                                               "duration": "2",
                                               "extend": true,
                                               "units": "min",
                                               "reset": "",
                                               "bytopic": "all",
                                               "topic": "topic",
                                               "outputs": 1,
                                               "x": 1710,
                                               "y": 2580,
                                               "wires": [
                                                       "433430a1daf7bfcf",
                                                       "f8e58410f9532511",
                                                       "3d427bcbd9d3748a"
                                               "id": "0e94e2277ef2e2c9",
                                               "type": "switch",
                                               "name": "",
                                               "rules": [
                                                       "t": "true"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 1,
                                               "x": 550,
                                               "y": 2740,
                                               "wires": [
                                                       "2d80433bb10dac6b"
                                               "id": "2d80433bb10dac6b",
                                               "name": "Schalter",
                                               "x": 700,
                                               "y": 2740,
                                               "wires": [
                                                       "4f70dc2ebd50bed3"
                                               "id": "4f70dc2ebd50bed3",
                                               "type": "switch",
                                               "rules": [
                                                       "t": "true"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 1,
                                               "x": 880,
                                               "y": 2740,
                                               "wires": [
                                                       "3f5134f664a1560b"
                                               "id": "f51133ee161cc15a",
                                               "type": "mqtt in",
                                               "name": "",
                                               "qos": "2",
                                               "nl": false,
                                               "rap": true,
                                               "rh": 0,
                                               "inputs": 0,
                                               "x": 250,
                                               "y": 2500,
                                               "wires": [
                                                       "7988a035aa866cc7"
                                               "id": "7039b340f9031c6c",
                                               "type": "mqtt in",
                                               "name": "",
                                               "qos": "2",
                                               "nl": false,
                                               "rap": true,
                                               "rh": 0,
                                               "inputs": 0,
                                               "x": 230,
                                               "y": 2560,
                                               "wires": [
                                                       "7988a035aa866cc7",
                                                       "2451e8e5eec3974f"
                                               "id": "363c3739240f060e",
                                               "type": "mqtt in",
                                               "name": "",
                                               "qos": "2",
                                               "nl": false,
                                               "rap": true,
                                               "rh": 0,
                                               "inputs": 0,
                                               "x": 230,
                                               "y": 2620,
                                               "wires": [
                                                       "7988a035aa866cc7"
                                               "id": "3097c993fb9ba0ab",
                                               "type": "mqtt in",
                                               "name": "",
                                               "qos": "2",
                                               "nl": false,
                                               "rap": true,
                                               "rh": 0,
                                               "inputs": 0,
                                               "x": 280,
                                               "y": 2680,
                                               "wires": [
                                                       "0e94e2277ef2e2c9"
                                               "id": "3f99ccd3c170d98f",
                                               "type": "mqtt in",
                                               "name": "",
                                               "qos": "2",
                                               "nl": false,
                                               "rap": true,
                                               "rh": 0,
                                               "inputs": 0,
                                               "x": 280,
                                               "y": 2740,
                                               "wires": [
                                                       "0e94e2277ef2e2c9"
                                               "id": "d6acc88db262e895",
                                               "type": "mqtt in",
                                               "name": "",
                                               "qos": "2",
                                               "nl": false,
                                               "rap": true,
                                               "rh": 0,
                                               "inputs": 0,
                                               "x": 280,
                                               "y": 2800,
                                               "wires": [
                                                       "0e94e2277ef2e2c9"
                                               "id": "3d427bcbd9d3748a",
                                               "type": "mqtt out",
                                               "name": "",
                                               "qos": "",
                                               "retain": "",
                                               "respTopic": "",
                                               "contentType": "",
                                               "userProps": "",
                                               "correl": "",
                                               "expiry": "",
                                               "x": 2000,
                                               "y": 2640,
                                               "wires": []
                                               "id": "f8e58410f9532511",
                                               "type": "mqtt out",
                                               "name": "",
                                               "qos": "",
                                               "retain": "",
                                               "respTopic": "",
                                               "contentType": "",
                                               "userProps": "",
                                               "correl": "",
                                               "expiry": "",
                                               "x": 2000,
                                               "y": 2580,
                                               "wires": []
                                               "id": "433430a1daf7bfcf",
                                               "type": "mqtt out",
                                               "name": "",
                                               "qos": "",
                                               "retain": "",
                                               "respTopic": "",
                                               "contentType": "",
                                               "userProps": "",
                                               "correl": "",
                                               "expiry": "",
                                               "x": 2000,
                                               "y": 2520,
                                               "wires": []
                                               "id": "c937f514cee2bae6",
                                               "name": "",
                                               "onlyack": "",
                                               "func": "all",
                                               "gap": "",
                                               "x": 210,
                                               "y": 2440,
                                               "wires": [
                                                       "aefab38101674dfc"
                                               "id": "aefab38101674dfc",
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "delay",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 880,
                                               "y": 2440,
                                               "wires": [
                                                       "175f30df96275374"
                                               "id": "e4b6c617ddedb818",
                                               "type": "switch",
                                               "rules": [
                                                       "t": "true"
                                                       "t": "false"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 2,
                                               "x": 1240,
                                               "y": 2740,
                                               "wires": [
                                                       "2451e8e5eec3974f"
                                                       "b74937efbbbc0c04"
                                               "id": "3f5134f664a1560b",
                                               "name": "Schalter",
                                               "x": 1060,
                                               "y": 2740,
                                               "wires": [
                                                       "e4b6c617ddedb818"
                                               "id": "2451e8e5eec3974f",
                                               "type": "light-scheduler-filter",
                                               "settings": "",
                                               "events": "[]",
                                               "name": "",
                                               "sunElevationThreshold": 6,
                                               "x": 1480,
                                               "y": 2660,
                                               "wires": [
                                                       "b74937efbbbc0c04"
                                               "id": "7988a035aa866cc7",
                                               "type": "junction",
                                               "x": 500,
                                               "y": 2560,
                                               "wires": [
                                                       "175f30df96275374"
                                               "id": "b74937efbbbc0c04",
                                               "type": "junction",
                                               "x": 1680,
                                               "y": 2680,
                                               "wires": [
                                                       "175f30df96275374"
                                               "port": "1883",
                                               "usetls": false,
                                               "keepalive": "60",
                                               "birthTopic": "",
                                               "birthQos": "0",
                                               "birthPayload": "",
                                               "birthMsg": {},
                                               "closeTopic": "",
                                               "closeQos": "0",
                                               "closePayload": "",
                                               "closeMsg": {},
                                               "willTopic": "",
                                               "willQos": "0",
                                               "willPayload": "",
                                               "willMsg": {},
                                               "userProps": "",
                                               "sessionExpiry": ""
                                        • mickymM mickym
                                                 "type": "trigger",
                                                 "name": "",
                                                 "op1type": "json",
                                                 "op2type": "json",
                                                 "duration": "2",
                                                 "extend": true,
                                                 "units": "min",
                                                 "reset": "",
                                                 "bytopic": "all",
                                                 "topic": "topic",
                                                 "outputs": 1,
                                                 "x": 1710,
                                                 "y": 2580,
                                                 "wires": [
                                                         "433430a1daf7bfcf",
                                                         "f8e58410f9532511",
                                                         "3d427bcbd9d3748a"
                                                 "type": "switch",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "true"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 1,
                                                 "x": 550,
                                                 "y": 2740,
                                                 "wires": [
                                                         "2d80433bb10dac6b"
                                                 "name": "Schalter",
                                                 "x": 700,
                                                 "y": 2740,
                                                 "wires": [
                                                         "4f70dc2ebd50bed3"
                                                 "type": "switch",
                                                 "rules": [
                                                         "t": "true"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 1,
                                                 "x": 880,
                                                 "y": 2740,
                                                 "wires": [
                                                         "3f5134f664a1560b"
                                                 "type": "mqtt in",
                                                 "name": "",
                                                 "qos": "2",
                                                 "nl": false,
                                                 "rap": true,
                                                 "rh": 0,
                                                 "inputs": 0,
                                                 "x": 250,
                                                 "y": 2500,
                                                 "wires": [
                                                         "7988a035aa866cc7"
                                                 "type": "mqtt in",
                                                 "name": "",
                                                 "qos": "2",
                                                 "nl": false,
                                                 "rap": true,
                                                 "rh": 0,
                                                 "inputs": 0,
                                                 "x": 230,
                                                 "y": 2560,
                                                 "wires": [
                                                         "7988a035aa866cc7",
                                                         "2451e8e5eec3974f"
                                                 "type": "mqtt in",
                                                 "name": "",
                                                 "qos": "2",
                                                 "nl": false,
                                                 "rap": true,
                                                 "rh": 0,
                                                 "inputs": 0,
                                                 "x": 230,
                                                 "y": 2620,
                                                 "wires": [
                                                         "7988a035aa866cc7"
                                                 "type": "mqtt in",
                                                 "name": "",
                                                 "qos": "2",
                                                 "nl": false,
                                                 "rap": true,
                                                 "rh": 0,
                                                 "inputs": 0,
                                                 "x": 280,
                                                 "y": 2680,
                                                 "wires": [
                                                         "0e94e2277ef2e2c9"
                                                 "type": "mqtt in",
                                                 "name": "",
                                                 "qos": "2",
                                                 "nl": false,
                                                 "rap": true,
                                                 "rh": 0,
                                                 "inputs": 0,
                                                 "x": 280,
                                                 "y": 2740,
                                                 "wires": [
                                                         "0e94e2277ef2e2c9"
                                                 "type": "mqtt in",
                                                 "name": "",
                                                 "qos": "2",
                                                 "nl": false,
                                                 "rap": true,
                                                 "rh": 0,
                                                 "inputs": 0,
                                                 "x": 280,
                                                 "y": 2800,
                                                 "wires": [
                                                         "0e94e2277ef2e2c9"
                                                 "type": "mqtt out",
                                                 "name": "",
                                                 "qos": "",
                                                 "retain": "",
                                                 "respTopic": "",
                                                 "contentType": "",
                                                 "userProps": "",
                                                 "correl": "",
                                                 "expiry": "",
                                                 "x": 2000,
                                                 "y": 2640,
                                                 "wires": []
                                                 "type": "mqtt out",
                                                 "name": "",
                                                 "qos": "",
                                                 "retain": "",
                                                 "respTopic": "",
                                                 "contentType": "",
                                                 "userProps": "",
                                                 "correl": "",
                                                 "expiry": "",
                                                 "x": 2000,
                                                 "y": 2580,
                                                 "wires": []
                                                 "type": "mqtt out",
                                                 "name": "",
                                                 "qos": "",
                                                 "retain": "",
                                                 "respTopic": "",
                                                 "contentType": "",
                                                 "userProps": "",
                                                 "correl": "",
                                                 "expiry": "",
                                                 "x": 2000,
                                                 "y": 2520,
                                                 "wires": []
                                                 "name": "",
                                                 "onlyack": "",
                                                 "func": "all",
                                                 "gap": "",
                                                 "x": 210,
                                                 "y": 2440,
                                                 "wires": [
                                                         "aefab38101674dfc"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "delay",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 880,
                                                 "y": 2440,
                                                 "wires": [
                                                         "175f30df96275374"
                                                 "type": "switch",
                                                 "rules": [
                                                         "t": "true"
                                                         "t": "false"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 2,
                                                 "x": 1240,
                                                 "y": 2740,
                                                 "wires": [
                                                         "2451e8e5eec3974f"
                                                         "b74937efbbbc0c04"
                                                 "name": "Schalter",
                                                 "x": 1060,
                                                 "y": 2740,
                                                 "wires": [
                                                         "e4b6c617ddedb818"
                                                 "settings": "",
                                                 "events": "[]",
                                                 "name": "",
                                                 "x": 1480,
                                                 "y": 2660,
                                                 "wires": [
                                                         "b74937efbbbc0c04"
                                                 "type": "junction",
                                                 "x": 500,
                                                 "y": 2560,
                                                 "wires": [
                                                         "175f30df96275374"
                                                 "type": "junction",
                                                 "x": 1680,
                                                 "y": 2680,
                                                 "wires": [
                                                         "175f30df96275374"
                                                 "port": "1883",
                                                 "usetls": false,
                                                 "keepalive": "60",
                                                 "birthTopic": "",
                                                 "birthQos": "0",
                                                 "birthPayload": "",
                                                 "birthMsg": {},
                                                 "closeTopic": "",
                                                 "closeQos": "0",
                                                 "closePayload": "",
                                                 "closeMsg": {},
                                                 "willTopic": "",
                                                 "willQos": "0",
                                                 "willPayload": "",
                                                 "willMsg": {},
                                                 "userProps": "",
                                                 "sessionExpiry": ""
                                          hotspot_2H
                                          hotspot_2H
                                          hotspot_2
                                          #236
                                          @mickym Ich mag mein VIS (jarvis) und meine Schalter da drin. Nutze sie nicht sehr oft, das stimmt, aber einfach "nice to have" für mich ;-).
                                          So, jetzt sollte es passen. Funktioniert echt sehr gut mit Node RED. Bin total begeistert.
                                                 "type": "trigger",
                                                 "name": "",
                                                 "op1type": "json",
                                                 "op2type": "json",
                                                 "duration": "2",
                                                 "extend": true,
                                                 "units": "min",
                                                 "reset": "",
                                                 "bytopic": "all",
                                                 "topic": "topic",
                                                 "outputs": 1,
                                                 "x": 1410,
                                                 "y": 420,
                                                 "wires": [
                                                         "aea976760342a7ca",
                                                         "b31a1ad723458b20",
                                                         "cdde801771054bfd"
                                                 "type": "switch",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "true"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 1,
                                                 "x": 590,
                                                 "y": 600,
                                                 "wires": [
                                                         "cb40f947f82f67aa"
                                                 "name": "Schalter",
                                                 "x": 740,
                                                 "y": 600,
                                                 "wires": [
                                                         "a7f6db04440edd6b"
                                                 "type": "switch",
                                                 "rules": [
                                                         "t": "true"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 1,
                                                 "x": 920,
                                                 "y": 600,
                                                 "wires": [
                                                         "1c6a8158f2b8126a"
                                                 "type": "mqtt in",
                                                 "name": "",
                                                 "qos": "2",
                                                 "nl": false,
                                                 "rap": true,
                                                 "rh": 0,
                                                 "inputs": 0,
                                                 "x": 290,
                                                 "y": 360,
                                                 "wires": [
                                                         "6a2f9b58c826dbf9"
                                                 "type": "mqtt in",
                                                 "name": "",
                                                 "qos": "2",
                                                 "nl": false,
                                                 "rap": true,
                                                 "rh": 0,
                                                 "inputs": 0,
                                                 "x": 270,
                                                 "y": 420,
                                                 "wires": [
                                                         "6a2f9b58c826dbf9"
                                                 "type": "mqtt in",
                                                 "name": "",
                                                 "qos": "2",
                                                 "nl": false,
                                                 "rap": true,
                                                 "rh": 0,
                                                 "inputs": 0,
                                                 "x": 270,
                                                 "y": 480,
                                                 "wires": [
                                                         "6a2f9b58c826dbf9"
                                                 "type": "mqtt in",
                                                 "name": "",
                                                 "qos": "2",
                                                 "nl": false,
                                                 "rap": true,
                                                 "rh": 0,
                                                 "inputs": 0,
                                                 "x": 320,
                                                 "y": 540,
                                                 "wires": [
                                                         "13f2741ac766c270"
                                                 "type": "mqtt in",
                                                 "name": "",
                                                 "qos": "2",
                                                 "nl": false,
                                                 "rap": true,
                                                 "rh": 0,
                                                 "inputs": 0,
                                                 "x": 320,
                                                 "y": 600,
                                                 "wires": [
                                                         "13f2741ac766c270"
                                                 "type": "mqtt in",
                                                 "name": "",
                                                 "qos": "2",
                                                 "nl": false,
                                                 "rap": true,
                                                 "rh": 0,
                                                 "inputs": 0,
                                                 "x": 320,
                                                 "y": 660,
                                                 "wires": [
                                                         "13f2741ac766c270"
                                                 "type": "mqtt out",
                                                 "name": "",
                                                 "qos": "",
                                                 "retain": "",
                                                 "respTopic": "",
                                                 "contentType": "",
                                                 "userProps": "",
                                                 "correl": "",
                                                 "expiry": "",
                                                 "x": 1680,
                                                 "y": 480,
                                                 "wires": []
                                                 "type": "mqtt out",
                                                 "name": "",
                                                 "qos": "",
                                                 "retain": "",
                                                 "respTopic": "",
                                                 "contentType": "",
                                                 "userProps": "",
                                                 "correl": "",
                                                 "expiry": "",
                                                 "x": 1680,
                                                 "y": 420,
                                                 "wires": []
                                                 "type": "mqtt out",
                                                 "name": "",
                                                 "qos": "",
                                                 "retain": "",
                                                 "respTopic": "",
                                                 "contentType": "",
                                                 "userProps": "",
                                                 "correl": "",
                                                 "expiry": "",
                                                 "x": 1680,
                                                 "y": 360,
                                                 "wires": []
                                                 "name": "",
                                                 "onlyack": "",
                                                 "func": "all",
                                                 "gap": "",
                                                 "x": 250,
                                                 "y": 300,
                                                 "wires": [
                                                         "7489466fabc808bb"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "delay",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1180,
                                                 "y": 300,
                                                 "wires": [
                                                         "d61506de1954395b"
                                                 "type": "switch",
                                                 "rules": [
                                                         "t": "true"
                                                         "t": "false"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 2,
                                                 "x": 920,
                                                 "y": 480,
                                                 "wires": [
                                                         "f85c9f2e9c8f2c44"
                                                 "name": "Schalter",
                                                 "x": 760,
                                                 "y": 480,
                                                 "wires": [
                                                         "814349e7d60ec173"
                                                 "id": "f85c9f2e9c8f2c44",
                                                 "settings": "0235e1e58e1f63fb",
                                                 "events": "[]",
                                                 "name": "Dunkel?",
                                                 "x": 1220,
                                                 "y": 600,
                                                 "wires": [
                                                         "d61506de1954395b"
                                                 "id": "77905b7b0ada129c",
                                                 "type": "mqtt in",
                                                 "name": "",
                                                 "topic": "shellies/sonstiges/klingel_oben/command/switch:0",
                                                 "qos": "2",
                                                 "nl": false,
                                                 "rap": true,
                                                 "rh": 0,
                                                 "inputs": 0,
                                                 "x": 270,
                                                 "y": 720,
                                                 "wires": [
                                                         "f1cab755275289c6"
                                                 "id": "83b0d265a7f475aa",
                                                 "type": "mqtt in",
                                                 "name": "",
                                                 "topic": "shellies/sonstiges/klingel_unten/command/switch:0",
                                                 "qos": "2",
                                                 "nl": false,
                                                 "rap": true,
                                                 "rh": 0,
                                                 "inputs": 0,
                                                 "x": 270,
                                                 "y": 780,
                                                 "wires": [
                                                         "f1cab755275289c6"
                                                 "id": "f1cab755275289c6",
                                                 "name": "Schalter",
                                                 "topic": "0_userdata.0.hausautomation.licht_an_klingel_treppenhaus",
                                                 "x": 580,
                                                 "y": 740,
                                                 "wires": [
                                                         "b74ff5a798e07ecc"
                                                 "id": "b74ff5a798e07ecc",
                                                 "type": "switch",
                                                 "rules": [
                                                         "t": "true"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 1,
                                                 "x": 760,
                                                 "y": 740,
                                                 "wires": [
                                                         "f85c9f2e9c8f2c44"
                                                 "type": "junction",
                                                 "x": 540,
                                                 "y": 420,
                                                 "wires": [
                                                         "d61506de1954395b"
                                                 "port": "1883",
                                                 "usetls": false,
                                                 "keepalive": "60",
                                                 "birthTopic": "",
                                                 "birthQos": "0",
                                                 "birthPayload": "",
                                                 "birthMsg": {},
                                                 "closeTopic": "",
                                                 "closeQos": "0",
                                                 "closePayload": "",
                                                 "closeMsg": {},
                                                 "willTopic": "",
                                                 "willQos": "0",
                                                 "willPayload": "",
                                                 "willMsg": {},
                                                 "userProps": "",
                                                 "sessionExpiry": ""
                                                 "id": "0235e1e58e1f63fb",
                                          Nachher noch das Mosquito Thema erledigen und dann ist das ne runde Sache insgesamt.
                                          Gibt es eine Möglichkeit nach dem Ende des Triggers noch ein paar Aktionen zu machen? z.B. einen Wert in ein iobroker out zu schreiben?
                                          33.2k
                                          84.3k
