    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • T tklein
    @armilar thx, mit ACTUAL klappt es.
    heir die Ausgabe wegen des Datums:
    14:57:06.965	info	javascript.0 (18424) Stop script script.js.common.Sonoff_Panel.test
    14:57:08.269	info	javascript.0 (18424) Start javascript script.js.common.Sonoff_Panel.test
    14:57:08.291	info	javascript.0 (18424) script.js.common.Sonoff_Panel.test: 06.04.2023
    14:57:08.292	info	javascript.0 (18424) script.js.common.Sonoff_Panel.test: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #2732
    @tklein
    Interessant und merkwürdig, denn das Script macht eigentlich nichts anderes als den Inhalt eines DP zu visualisieren (ohne Konvertierung). Hätte ich adhoc auch keinen Ansatz...
    • T tklein
      @armilar vielleicht hat es auch mit diesen warnungen zu tun?
      14:53:37.800	info	javascript.0 (18424) script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01: Installed TFT Firmware: 50 / v4.0.4
      14:53:50.394	warn	javascript.0 (18424) at HandleScreensaverUpdate (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8563:35)
      14:53:50.394	warn	javascript.0 (18424) at HandleScreensaver (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8272:5)
      14:53:50.394	warn	javascript.0 (18424) at HandleMessage (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4235:21)
      14:53:50.394	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4164:25)
      14:53:50.395	warn	javascript.0 (18424) at step (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:33:23)
      14:53:50.395	warn	javascript.0 (18424) at Object.next (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:14:53)
      14:53:50.395	warn	javascript.0 (18424) at script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8:71
      14:53:50.395	warn	javascript.0 (18424) at __awaiter (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4:12)
      14:53:50.395	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4156:12)
      14:53:50.398	warn	javascript.0 (18424) at HandleScreensaverUpdate (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8573:37)
      14:53:50.398	warn	javascript.0 (18424) at HandleScreensaver (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8272:5)
      14:53:50.398	warn	javascript.0 (18424) at HandleMessage (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4235:21)
      14:53:50.398	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4164:25)
      14:53:50.398	warn	javascript.0 (18424) at step (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:33:23)
      14:53:50.399	warn	javascript.0 (18424) at Object.next (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:14:53)
      14:53:50.399	warn	javascript.0 (18424) at script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8:71
      14:53:50.399	warn	javascript.0 (18424) at __awaiter (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4:12)
      14:53:50.399	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4156:12)
      14:53:50.401	warn	javascript.0 (18424) at HandleScreensaverUpdate (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8577:37)
      14:53:50.401	warn	javascript.0 (18424) at HandleScreensaver (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8272:5)
      14:53:50.402	warn	javascript.0 (18424) at HandleMessage (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4235:21)
      14:53:50.402	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4164:25)
      14:53:50.402	warn	javascript.0 (18424) at step (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:33:23)
      14:53:50.402	warn	javascript.0 (18424) at Object.next (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:14:53)
      14:53:50.402	warn	javascript.0 (18424) at script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8:71
      14:53:50.403	warn	javascript.0 (18424) at __awaiter (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4:12)
      14:53:50.403	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4156:12)
      14:53:52.281	warn	javascript.0 (18424) at HandleScreensaverUpdate (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8563:35)
      14:53:52.281	warn	javascript.0 (18424) at HandleScreensaver (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8272:5)
      14:53:52.282	warn	javascript.0 (18424) at HandleMessage (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4235:21)
      14:53:52.282	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4164:25)
      14:53:52.282	warn	javascript.0 (18424) at step (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:33:23)
      14:53:52.283	warn	javascript.0 (18424) at Object.next (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:14:53)
      14:53:52.283	warn	javascript.0 (18424) at script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8:71
      14:53:52.284	warn	javascript.0 (18424) at __awaiter (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4:12)
      14:53:52.284	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4156:12)
      14:53:52.287	warn	javascript.0 (18424) at HandleScreensaverUpdate (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8573:37)
      14:53:52.287	warn	javascript.0 (18424) at HandleScreensaver (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8272:5)
      14:53:52.287	warn	javascript.0 (18424) at HandleMessage (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4235:21)
      14:53:52.288	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4164:25)
      14:53:52.288	warn	javascript.0 (18424) at step (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:33:23)
      14:53:52.288	warn	javascript.0 (18424) at Object.next (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:14:53)
      14:53:52.289	warn	javascript.0 (18424) at script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8:71
      14:53:52.289	warn	javascript.0 (18424) at __awaiter (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4:12)
      14:53:52.293	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4156:12)
      14:53:52.296	warn	javascript.0 (18424) at HandleScreensaverUpdate (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8577:37)
      14:53:52.296	warn	javascript.0 (18424) at HandleScreensaver (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8272:5)
      14:53:52.297	warn	javascript.0 (18424) at HandleMessage (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4235:21)
      14:53:52.297	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4164:25)
      14:53:52.297	warn	javascript.0 (18424) at step (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:33:23)
      14:53:52.298	warn	javascript.0 (18424) at Object.next (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:14:53)
      14:53:52.298	warn	javascript.0 (18424) at script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8:71
      14:53:52.299	warn	javascript.0 (18424) at __awaiter (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4:12)
      14:53:52.299	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:4156:12)
      14:54:00.132	warn	javascript.0 (18424) at HandleScreensaverUpdate (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8563:35)
      14:54:00.133	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:3174:9)
      14:54:00.135	warn	javascript.0 (18424) at HandleScreensaverUpdate (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8573:37)
      14:54:00.135	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:3174:9)
      14:54:00.139	warn	javascript.0 (18424) at HandleScreensaverUpdate (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:8577:37)
      14:54:00.139	warn	javascript.0 (18424) at Object.<anonymous> (script.js.common.Sonoff_Panel.Panel_1.Panel_1_2023_04_01:3174:9)
      Kann man da irgendwie die entsprechende Zeilennr heruasbekommen, welche als erstes probleme bereitet?
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      #2733
      @tklein
      Nee, die sagen nur, dass du auf Objekte (DP's) zugreifst, die nicht existieren...
      Nach den Zeilennummer kannst du dich nicht orientieren. Die passen nicht zur Zeile im Script (irgendwie noch nie)
      T 2 Antworten Letzte Antwort
      • ArmilarA Armilar
        @tklein
        tklein
        #2734
        @armilar thx, kann man anhand der logs sehen, welche das sind?
        • T tklein
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          #2735
          @tklein
          Du kannst jeden Block so auskommentieren. Wenn die Warnung verschwunden ist, hast du den Übeltäter...
                          ScreensaverEntity: 'alias.0.Haus.Erdgeschoss.Buero.Sensoren.Temperatur.ACTUAL',
                          ScreensaverEntityFactor: 1,
                          ScreensaverEntityDecimalPlaces: 1,
                          ScreensaverEntityIconOn: 'thermometer',
                          ScreensaverEntityIconOff: null,
                          ScreensaverEntityText: 'Temperatur',
                          ScreensaverEntityUnitText: '°C',
                          ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 35, 'val_best': 22}
          • ArmilarA Armilar
            @tklein
            tklein
            #2736
            @armilar wenn dass kurz nach dem start des skriptes ist und ich nur die screensaver im display sehe, kann es nur davon sein, oder werden alle views etc aufgerufen und können somit fehler von anderen views auftreten?
            • T tklein
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #2737
              @tklein
              Die anderen Cards durchlaufen nicht die Screensaver-Funktionen
              • ArmilarA Armilar
                @tklein
                tklein
                #2738
                @armilar ja das hatte ich mir schon gedacht. meine frage geht dahin, ob nach dem start alles views intern "gecached" etc werden und somit alles views durchlaufen werden und deren fehler entsprechend ausgegeben, ode halt erst beim direkten aufruf? dann wären die fehler bei mir im screensaver, immer beim wechsel.
                • ArmilarA Armilar
                  @tklein
                  tklein
                  #2739
                  @armilar sehe gerade, das beim wechsel vom forcecast weg, die werte wieder "null" für wohnzimmertemp und stromverbrauch sind.
                  • T tklein
                    ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    #2740
                    @tklein
                    Jede Seite wird dann aufgerufen, wenn sie zu sehen ist. Immer zur aktuellen Seite aufgebaut. Also zunächst wird Seite 0 nach dem Start aufgebaut, wenn dann keine Aktion mehr passiert, dann kommt der Screensaver und die Seite 0 existiert nicht mehr.
                    Da Deine Fehler aber in der HandleScreensaverUpdate passieren, wird es auch nur in den Definitionen für den Screensaver die Fehler geben
                    • T tklein
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #2741
                      @tklein
                      irgendetwas nicht gespeichert an den Änderungen mit dem .ACTUAL?
                      Alternativ mal die JS-Instanz neu starten. Nicht das im Hintergrund noch eine Schattenkopie läuft...
                      • ArmilarA Armilar
                        @tklein
                        tklein
                        #2742
                        @armilar fehlermeldungen sind jetzt alle weg. javascript neugestartet. dennoch manchmal "null" werte
                        • A australien
                          @tt-tom
                          JSON wird geliefert, ich hab hier mal ein Beispiel anschaulich gemacht.
                          [{"tripId":"2|#VN#1#ST#1680243542#PI#0#ZI#473130#TA#2#DA#310323#1S#8103000#1T#1715#LS#8100361#LT#1840#PU#81#RT#1#CA#REX#ZE#64#ZB#REX 64  #PC#4#FR#8103000#FT#1715#TO#8100361#TT#1840#","stop":{"type":"stop","id":"8100219","name":"Donnerskirchen Bahnhof","location":{"type":"location","id":"8100219","latitude":47.888477,"longitude":16.660418},"products":{"nationalExpress":false,"national":false,"interregional":false,"regional":true,"suburban":false,"bus":false,"ferry":false,"subway":false,"tram":false,"onCall":false}},"when":"2023-03-31T18:15:00+02:00","plannedWhen":"2023-03-31T18:15:00+02:00","delay":0,"platform":"1","plannedPlatform":"1","prognosisType":"prognosed","direction":"Wulkaprodersdorf Bahnhof","provenance":null,"line":{"type":"line","id":"rex-64-zug-nr-2655","fahrtNr":"2655","name":"REX 64 (Zug-Nr. 2655)","public":true,"adminCode":"81____","productName":"REX","mode":"train","product":"regional","operator":{"type":"operator","id":"nahreisezug","name":"Nahreisezug"}},"remarks":[{"type":"hint","code":"OB","text":"Niederflurfahrzeug"},
                          {"type":"hint","code":"RO","text":"Rollstuhlstellplatz"},
                          {"type":"hint","code":"OA","text":"Rollstuhlstellplatz - Voranmeldung unter +43 5 1717"},
                          {"type":"hint","code":"OG","text":"bedingt rollstuhltaugliches WC"},
                          {"type":"hint","code":"FK","text":"Fahrradmitnahme begrenzt möglich"},{
                          "type":"hint","code":"BH","text":"Halt nur bei Bedarf (Donnerskirchen Bahnhof)"},
                          {"type":"hint","code":"K2","text":"nur 2. Klasse"},
                          {"type":"hint","code":"SB","text":"Zustieg im Nahverkehr (REX, R, CJX, S-Bahn) nur mit gültiger Fahrkarte"},
                          {"type":"hint","code":"WV","text":"<b>WLAN verfügbar</b>"},
                          {"type":"status","code":"text.realtime.journey.attribute.change","text":"Bei Ihrer Verbindung hat sich die Zugausstattung geändert."}],"origin":null,"destination":{"type":"stop","id":"8100361","name":"Wulkaprodersdorf Bahnhof","location":{"type":"location","id":"8100361","latitude":47.788939,"longitude":16.490594},"products":{"nationalExpress":false,"national":false,"interregional":false,"regional":true,"suburban":false,"bus":false,"ferry":false,"subway":false,"tram":false,"onCall":false}},"currentTripPosition":{"type":"location","latitude":47.883128,"longitude":16.659466}},
                          {"tripId":"2|#VN#1#ST#1680243542#PI#0#ZI#473129#TA#3#DA#310323#1S#8100361#1T#1820#LS#8103000#LT#1943#PU#81#RT#1#CA#REX#ZE#64#ZB#REX 64  #PC#4#FR#8100361#FT#1820#TO#8103000#TT#1943#","stop":{"type":"stop","id":"8100219","name":"Donnerskirchen Bahnhof","location":{"type":"location","id":"8100219","latitude":47.888477,"longitude":16.660418},"products":{"nationalExpress":false,"national":false,"interregional":false,"regional":true,"suburban":false,"bus":false,"ferry":false,"subway":false,"tram":false,"onCall":false}},"when":"2023-03-31T18:39:00+02:00","plannedWhen":"2023-03-31T18:39:00+02:00","delay":0,"platform":"1","plannedPlatform":"1","prognosisType":"prognosed","direction":"Wien Hbf","provenance":null,"line":{"type":"line","id":"rex-64-zug-nr-2658","fahrtNr":"2658","name":"REX 64 (Zug-Nr. 2658)","public":true,"adminCode":"81____","productName":"REX","mode":"train","product":"regional","operator":{"type":"operator","id":"nahreisezug","name":"Nahreisezug"}},"remarks":[{"type":"hint","code":"OB","text":"Niederflurfahrzeug"},
                          {"type":"hint","code":"BH","text":"Halt nur bei Bedarf (Donnerskirchen Bahnhof)"},
                          {"type":"status","code":"text.realtime.journey.attribute.change","text":"Bei Ihrer Verbindung hat sich die Zugausstattung geändert."}],"origin":null,"destination":{"type":"stop","id":"8103000","name":"Wien Hbf","location":{"type":"location","id":"8103000","latitude":48.184564,"longitude":16.378526},"products":{"nationalExpress":true,"national":true,"interregional":true,"regional":true,"suburban":true,"bus":false,"ferry":false,"subway":false,"tram":false,"onCall":false}}},
                          {"tripId":"2|#VN#1#ST#1680243542#PI#0#ZI#473128#TA#3#DA#310323#1S#8103000#1T#1748#LS#8100361#LT#1914#PU#81#RT#1#CA#REX#ZE#64#ZB#REX 64  #PC#4#FR#8103000#FT#1748#TO#8100361#TT#1914#","stop":{"type":"stop","id":"8100219","name":"Donnerskirchen Bahnhof","location":{"type":"location","id":"8100219","latitude":47.888477,"longitude":16.660418},"products":{"nationalExpress":false,"national":false,"interregional":false,"regional":true,"suburban":false,"bus":false,"ferry":false,"subway":false,"tram":false,"onCall":false}},"when":"2023-03-31T18:47:00+02:00","plannedWhen":"2023-03-31T18:47:00+02:00","delay":0,"platform":"1","plannedPlatform":"1","prognosisType":"prognosed","direction":"Wulkaprodersdorf Bahnhof","provenance":null,"line":{"type":"line","id":"rex-64-zug-nr-2657","fahrtNr":"2657","name":"REX 64 (Zug-Nr. 2657)","public":true,"adminCode":"81____","productName":"REX","mode":"train","product":"regional","operator":{"type":"operator","id":"nahreisezug","name":"Nahreisezug"}},"remarks":[{"type":"hint","code":"OB","text":"Niederflurfahrzeug"},
                          {"type":"hint","code":"SB","text":"Zustieg im Nahverkehr (REX, R, CJX, S-Bahn) nur mit gültiger Fahrkarte"}],"origin":null,"destination":{"type":"stop","id":"8100361","name":"Wulkaprodersdorf Bahnhof","location":{"type":"location","id":"8100361","latitude":47.788939,"longitude":16.490594},"products":{"nationalExpress":false,"national":false,"interregional":false,"regional":true,"suburban":false,"bus":false,"ferry":false,"subway":false,"tram":false,"onCall":false}},"currentTripPosition":{"type":"location","latitude":48.022398,"longitude":16.706488}},
                          {"tripId":"2|#VN#1#ST#1680243542#PI#0#ZI#494129#TA#0#DA#310323#1S#197045#1T#1828#LS#191002#LT#1909#PU#81#RT#1#CA#Bus#ZE#280#ZB#Bus 280 #PC#6#FR#197045#FT#1828#TO#191002#TT#1909#","stop":{"type":"stop","id":"193021","name":"Donnerskirchen Bundesstraße (Eisenstädter Straße)","location":{"type":"location","id":"193021","latitude":47.893403,"longitude":16.647213},"products":{"nationalExpress":false,"national":true,"interregional":false,"regional":false,"suburban":false,"bus":true,"ferry":false,"subway":false,"tram":false,"onCall":false}},"when":"2023-03-31T18:54:00+02:00","plannedWhen":"2023-03-31T18:54:00+02:00","delay":null,"platform":null,"plannedPlatform":null,"prognosisType":null,"direction":"Eisenstadt Busbahnhof (Domplatz)","provenance":null,"line":{"type":"line","id":"bus-280","fahrtNr":"14026","name":"Bus 280","public":true,"adminCode":"v12Pos","productName":"Bus","mode":"bus","product":"bus","operator":{"type":"operator","id":"osterreichische-postbus-aktiengesellschaft","name":"Österreichische Postbus Aktiengesellschaft"}},"remarks":[{"type":"hint","code":"OB","text":"Niederflurfahrzeug"},
                          {"type":"hint","code":"RO","text":"Rollstuhlstellplatz"}],"origin":null,"destination":{"type":"stop","id":"191002","name":"Eisenstadt Busbahnhof (Domplatz)","location":{"type":"location","id":"191002","latitude":47.845922,"longitude":16.525616},"products":{"nationalExpress":false,"national":false,"interregional":false,"regional":false,"suburban":false,"bus":true,"ferry":false,"subway":false,"tram":false,"onCall":false}}}]
                          kann man mit dem was anfangen?
                          oder doch die Datenpunkte verwenden und damit die Zeilen erzeugen?
                          Angezeigt sollen Abfahrtzeit, Richtung, Verspätung und Verkehrsmittel (Zug-Bus) werden.
                          Die Verspätung kann auch in einer anderen Farbe (grün/rot) der Abfahrtszeit eingestellt werden, dann würde noch etwas Platz bleiben für die Richung.
                          TT-Tom
                          #2743
                          @australien
                          Man könnte bis zu 6 Abfahrzeiten als Wert auf einer cardGrid darstellen und als Unterschrift die Richtung.
                          Ich denke da in Richtung monobutton. Sein Toggeln löst dann eine notifyPage aus mit allen wichtigen Infos, die über ein externes Script zur Verfügung gestellt werden. Muss mich mit @Armilar mal kurzschließen, für eventuelle Anpassung am Script.
                          Werde zeitlich nächste Woche, dazu kommen.
                          Passt das ungefähr deinen Vorstellungen??
                          Gruß Tom
                          Public Transport
                          NSPanel Adapter Wiki
                          GregorSG A 2 Antworten Letzte Antwort
                          • T TT-Tom
                            @australien
                            GregorSG Offline
                            GregorSG Offline
                            GregorS
                            #2744
                            Kann ich das Objekt
                            "0_userdata.0.NSPanel.1.ScreensaverInfo.popupNotifyHeading"
                            in rot und blinkend anzeigen lassen?
                            Leider geht der weiße Text ein wenig in der Masse der Informationen verloren.
                            Wie kann man die Temperaturanzeige (Wettervorhersage) unter dem Symbol (links) mit der eigenen richtigen Temperatur
                            überschreiben?
                            INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
                              TT-Tom
                              #2745
                              @gregors sagte in SONOFF NSPanel mit Lovelace UI:
                              Kann ich das Objekt
                              Farbe sollte funktionieren über popupNotifyHeadingColor. Laut Wiki wird es im Layout 2 unterstützt.
                              überschreiben?
                              Meinst du diese Einstellung
                              Gruß Tom
                              Public Transport
                              GregorSG 1 Antwort Letzte Antwort
                              • T TT-Tom
                                Kann ich das Objekt
                                überschreiben?
                                GregorSG Offline
                                GregorSG Offline
                                GregorS
                                #2746
                                @tt-tom
                                Ja. Habe jetzt den Dreh gefunden - werde die entsprechende Variable anpassen
                                Allerdings mit der Farbe ändern und dem blinken komme ich nicht mit.
                                • GregorSG GregorS
                                  @tt-tom
                                  TT-Tom
                                  #2747
                                  @gregors
                                  Ich glaube wir haben bei der Farbe aneinander vorbei gedacht. Du meinst den Text auf dem Screensaver und ich die Seite popupNotify. Ob die Farbe dort auch greift, kann ich nicht 100% beantworten.
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    @gregors
                                    GregorSG Offline
                                    GregorSG Offline
                                    GregorS
                                    #2748
                                    @tt-tom
                                    ok danke
                                    • L Online
                                      L Online
                                      lesiflo
                                      schrieb am zuletzt editiert von lesiflo
                                      #2749
                                      besteht die Möglichkeit die Farbe des Icons und des Wertes zu wechseln je nachdem ob Strom eingespeist
                                      oder entnommen wird? Bei Einspeisung soll es grün sein, bei Entnahme rot. Aktuell sieht es bei mit so aus. Der Wert kann negativ (Einspeisung) oder oder positiv (Entnahme) werden. Mit val_min, val_max und val_best habe ich es schon versucht.
                                                      //ScreensaverEntity: 'alias.0.PV_Anlage.PV_Leistung.ACTUAL',
                                                      ScreensaverEntity: 'mqtt.0.openWB.evu.W',
                                                      ScreensaverEntityDecimalPlaces: 0,
                                                      //ScreensaverEntityIconOn: 'solar-power-variant',
                                                      ScreensaverEntityIconOn: 'power-meter',
                                                      ScreensaverEntityText: 'L1-L3',
                                                      ScreensaverEntityUnitText: ' W',
                                                      ScreensaverEntityIconColor: {'val_min': -11000, 'val_max': 11000, 'val_best': 0}
                                      • L lesiflo
                                        TT-Tom
                                        #2750
                                        @lesiflo wenn du val_best nutzt dann ist der Wert dein grün siehe Wiki , dort ist es beschrieben wie du die Farben definieren kannst.
                                        Es reicht dann auch als Werte +/-1 anzugeben, sonst kommt rot und grün erst bei +/- 1100
                                        Gruß Tom
                                        Public Transport
                                        L 1 Antwort Letzte Antwort
                                        • T TT-Tom
                                          L Online
                                          L Online
                                          lesiflo
                                          #2751
                                          @tt-tom Klappt leider nicht. Wenn ich es z.B: so eingebe
                                                          ScreensaverEntityIconColor: {'val_min': -1, 'val_max': 1, 'val_best': 0}
                                          wird kein Icon angezeigt.
                                          Bei
                                          ist das Icon grün obwohl gerade Strom entnommen wird. Die Frage ist, ob das überhaupt möglich ist.
                                          @Armilar: Geht das überhaupt?
