  4. Restore läuft nicht weiter
    5.5k
27 Beiträge 5 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • wendy2702W wendy2702
    @adamantium Im log sehe ich nichts auffälliges.
    Und wenn du mit Browser auf die IP:8081 gehst kommt nichts?
    Steht denn was im iobroker log:
    cat /opt/iobroker/log/iobroker.current.log
    Adamantium
    @wendy2702 said in Restore läuft nicht weiter:
    Das passiert:
    [Marcel@Marcel ~]$ docker exec -i -t iobroker bash
    root@edfa9db59fd4:/opt/iobroker# cat /opt/iobroker/log/iobroker.current.log
    2023-03-31 14:14:58.367  - info: host.edfa9db59fd4 iobroker.js-controller versio        n 4.0.24 js-controller starting
    2023-03-31 14:14:58.373  - info: host.edfa9db59fd4 Copyright (c) 2014-2022 bluef        ox, 2014 hobbyquaker
    2023-03-31 14:14:58.374  - info: host.edfa9db59fd4 hostname: edfa9db59fd4, node:        v18.15.0
    2023-03-31 14:14:58.375  - info: host.edfa9db59fd4 ip addresses: 192.168.1.49
    2023-03-31 14:14:58.791  - info: host.edfa9db59fd4 connected to Objects and Stat        es
    2023-03-31 14:14:58.826  - info: host.edfa9db59fd4 Node.js version has changed f        rom unknown to 18.15.0
    2023-03-31 14:14:58.899  - info: host.edfa9db59fd4 added notifications configura        tion of host
    2023-03-31 14:14:59.182  - info: host.edfa9db59fd4 3 instances found
    2023-03-31 14:14:59.191  - info: host.edfa9db59fd4 starting 3 instances
    2023-03-31 14:14:59.243  - info: host.edfa9db59fd4 instance system.adapter.admin        .0 started with pid 588
    2023-03-31 14:14:59.530  - info: host.edfa9db59fd4 Successfully updated capabili        ties "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2023-03-31 14:15:01.350  - info: admin.0 (588) starting. Version 6.3.5 in /opt/i        obroker/node_modules/iobroker.admin, node: v18.15.0, js-controller: 4.0.24
    2023-03-31 14:15:01.398  - info: admin.0 (588) requesting all states
    2023-03-31 14:15:01.399  - info: admin.0 (588) requesting all objects
    2023-03-31 14:15:01.596  - info: admin.0 (588) received all objects
    2023-03-31 14:15:01.631  - info: admin.0 (588) Request actual repository...
    2023-03-31 14:15:01.644  - info: host.edfa9db59fd4 Updating repository "stable"        under "http://download.iobroker.net/sources-dist.json"
    2023-03-31 14:15:01.651  - info: admin.0 (588) http server listening on port 808        1
    2023-03-31 14:15:01.652  - info: admin.0 (588) Use link "http://localhost:8081"        to configure.
    2023-03-31 14:15:01.661  - info: admin.0 (588) socket.io server listening on por        t 8081
    2023-03-31 14:15:01.804  - warn: admin.0 (588) Repository cannot be read: Active        repo - stable
    2023-03-31 14:15:01.805  - warn: admin.0 (588) Active repository "stable" cannot        be read
    2023-03-31 14:15:03.215  - info: host.edfa9db59fd4 instance system.adapter.disco        very.0 started with pid 603
    2023-03-31 14:15:05.010  - info: discovery.0 (603) starting. Version 3.1.0 in /o        pt/iobroker/node_modules/iobroker.discovery, node: v18.15.0, js-controller: 4.0.        24
    2023-03-31 14:15:07.401  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 started with pid 630
    2023-03-31 14:15:07.481  - info: admin.0 (588) Repository received successfully.
    2023-03-31 14:15:09.494  - info: backitup.0 (630) starting. Version 2.5.12 in /o        pt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.2        4
    2023-03-31 14:15:09.690  - info: backitup.0 (630) [iobroker] backup was activate        d at 02:40 every 1 day(s)
    2023-03-31 15:07:54.305  - info: admin.0 (588) ==> Connected system.user.admin f        rom ::ffff:192.168.1.51
    2023-03-31 15:08:51.640  - info: admin.0 (588) ==> Connected system.user.admin f        rom ::ffff:192.168.1.51
    2023-03-31 15:09:04.966  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 (force=false, process=true)
    2023-03-31 15:09:04.975  - info: backitup.0 (630) Got terminate signal TERMINATE        _YOURSELF
    2023-03-31 15:09:04.977  - info: backitup.0 (630) cleaned everything up...
    2023-03-31 15:09:04.978  - info: backitup.0 (630) terminating
    2023-03-31 15:09:04.980  - info: backitup.0 (630) Terminated (ADAPTER_REQUESTED_        TERMINATION): Without reason
    2023-03-31 15:09:05.015  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 send kill signal
    2023-03-31 15:09:05.524  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-03-31 15:09:08.047  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 started with pid 3338
    2023-03-31 15:09:09.778  - info: backitup.0 (3338) starting. Version 2.5.12 in /        opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.        24
    2023-03-31 15:09:09.846  - info: backitup.0 (3338) Restarting Adapter because of        changed Sentry settings
    2023-03-31 15:09:09.847  - warn: backitup.0 (3338) Restart initiated
    2023-03-31 15:09:09.849  - info: backitup.0 (3338) cleaned everything up...
    2023-03-31 15:09:09.897  - info: backitup.0 (3338) terminating
    2023-03-31 15:09:09.898  - info: backitup.0 (3338) Terminated (NO_ERROR): Withou        t reason
    2023-03-31 15:09:10.450  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 terminated with code 0 (NO_ERROR)
    2023-03-31 15:09:10.450  - info: host.edfa9db59fd4 Restart adapter system.adapte        r.backitup.0 because enabled
    2023-03-31 15:09:27.084  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 started with pid 3365
    2023-03-31 15:09:28.707  - info: backitup.0 (3365) starting. Version 2.5.12 in /        opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.        24
    2023-03-31 15:09:28.854  - info: backitup.0 (3365) [iobroker] backup was activat        ed at 02:40 every 1 day(s)
    2023-03-31 15:09:30.646  - info: admin.0 (588) <== Disconnect system.user.admin        from ::ffff:192.168.1.51
    2023-03-31 15:09:34.037  - info: admin.0 (588) ==> Connected system.user.admin f        rom ::ffff:192.168.1.51
    2023-03-31 15:09:36.718  - error: backitup.0 (3365) FTP: Error: /backupDir: No s        uch file or directory
    2023-03-31 15:09:37.330  - error: backitup.0 (3365) FTP: Error: /backupDir: No s        uch file or directory
    2023-03-31 15:09:49.414  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 (force=false, process=true)
    2023-03-31 15:09:49.419  - info: backitup.0 (3365) Got terminate signal TERMINAT        E_YOURSELF
    2023-03-31 15:09:49.421  - info: backitup.0 (3365) cleaned everything up...
    2023-03-31 15:09:49.422  - info: backitup.0 (3365) terminating
    2023-03-31 15:09:49.423  - info: backitup.0 (3365) Terminated (ADAPTER_REQUESTED        _TERMINATION): Without reason
    2023-03-31 15:09:49.458  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 send kill signal
    2023-03-31 15:09:49.964  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-03-31 15:09:52.481  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 started with pid 3405
    2023-03-31 15:09:54.063  - info: backitup.0 (3405) starting. Version 2.5.12 in /        opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.        24
    2023-03-31 15:09:54.199  - info: backitup.0 (3405) [iobroker] backup was activat        ed at 02:40 every 1 day(s)
    2023-03-31 15:09:54.924  - error: backitup.0 (3405) FTP: Error: /backup_iobroker        : No such file or directory
    2023-03-31 15:10:10.325  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 (force=false, process=true)
    2023-03-31 15:10:10.330  - info: backitup.0 (3405) Got terminate signal TERMINAT        E_YOURSELF
    2023-03-31 15:10:10.332  - info: backitup.0 (3405) cleaned everything up...
    2023-03-31 15:10:10.333  - info: backitup.0 (3405) terminating
    2023-03-31 15:10:10.334  - info: backitup.0 (3405) Terminated (ADAPTER_REQUESTED        _TERMINATION): Without reason
    2023-03-31 15:10:10.369  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 send kill signal
    2023-03-31 15:10:10.876  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-03-31 15:10:13.002  - info: admin.0 (588) <== Disconnect system.user.admin        from ::ffff:192.168.1.51
    2023-03-31 15:10:13.393  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 started with pid 3433
    2023-03-31 15:10:14.908  - info: backitup.0 (3433) starting. Version 2.5.12 in /        opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.        24
    2023-03-31 15:10:15.028  - info: backitup.0 (3433) [iobroker] backup was activat        ed at 02:40 every 1 day(s)
    2023-03-31 15:10:15.743  - error: backitup.0 (3433) FTP: Error: /backup_iobroker        /: No such file or directory
    2023-03-31 15:10:17.465  - info: admin.0 (588) ==> Connected system.user.admin f        rom ::ffff:192.168.1.51
    2023-03-31 15:10:19.529  - error: backitup.0 (3433) FTP: Error: /backup_iobroker        /: No such file or directory
    2023-03-31 15:10:39.043  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 (force=false, process=true)
    2023-03-31 15:10:39.047  - info: backitup.0 (3433) Got terminate signal TERMINAT        E_YOURSELF
    2023-03-31 15:10:39.048  - info: backitup.0 (3433) cleaned everything up...
    2023-03-31 15:10:39.049  - info: backitup.0 (3433) terminating
    2023-03-31 15:10:39.050  - info: backitup.0 (3433) Terminated (ADAPTER_REQUESTED        _TERMINATION): Without reason
    2023-03-31 15:10:39.086  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 send kill signal
    2023-03-31 15:10:39.586  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-03-31 15:10:42.109  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 started with pid 3472
    2023-03-31 15:10:43.835  - info: backitup.0 (3472) starting. Version 2.5.12 in /        opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.        24
    2023-03-31 15:10:43.983  - info: backitup.0 (3472) [iobroker] backup was activat        ed at 02:40 every 1 day(s)
    2023-03-31 15:11:29.524  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 (force=false, process=true)
    2023-03-31 15:11:29.529  - info: backitup.0 (3472) Got terminate signal TERMINAT        E_YOURSELF
    2023-03-31 15:11:29.531  - info: backitup.0 (3472) cleaned everything up...
    2023-03-31 15:11:29.531  - info: backitup.0 (3472) terminating
    2023-03-31 15:11:29.533  - info: backitup.0 (3472) Terminated (ADAPTER_REQUESTED        _TERMINATION): Without reason
    2023-03-31 15:11:29.568  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 send kill signal
    2023-03-31 15:11:30.067  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-03-31 15:11:31.686  - info: admin.0 (588) <== Disconnect system.user.admin        from ::ffff:192.168.1.51
    2023-03-31 15:11:32.594  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 started with pid 3523
    2023-03-31 15:11:34.107  - info: backitup.0 (3523) starting. Version 2.5.12 in /        opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.        24
    2023-03-31 15:11:34.249  - info: backitup.0 (3523) [iobroker] backup was activat        ed at 02:40 every 1 day(s)
    2023-03-31 15:11:38.465  - info: admin.0 (588) ==> Connected system.user.admin f        rom ::ffff:192.168.1.51
    2023-03-31 15:12:20.313  - info: host.edfa9db59fd4 received SIGTERM
    2023-03-31 15:12:20.315  - info: host.edfa9db59fd4 stopInstance system.adapter.a        dmin.0 (force=false, process=true)
    2023-03-31 15:12:20.315  - info: host.edfa9db59fd4 stopInstance system.adapter.d        iscovery.0 (force=false, process=true)
    2023-03-31 15:12:20.316  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 (force=false, process=true)
    2023-03-31 15:12:20.322  - info: host.edfa9db59fd4 stopInstance system.adapter.a        dmin.0 send kill signal
    2023-03-31 15:12:20.322  - info: backitup.0 (3523) Got terminate signal TERMINAT        E_YOURSELF
    2023-03-31 15:12:20.323  - info: discovery.0 (603) Got terminate signal TERMINAT        E_YOURSELF
    2023-03-31 15:12:20.324  - info: host.edfa9db59fd4 stopInstance system.adapter.d        iscovery.0 send kill signal
    2023-03-31 15:12:20.325  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 send kill signal
    2023-03-31 15:12:20.325  - info: admin.0 (588) Got terminate signal TERMINATE_YO        URSELF
    2023-03-31 15:12:20.325  - info: backitup.0 (3523) cleaned everything up...
    2023-03-31 15:12:20.326  - info: backitup.0 (3523) terminating
    2023-03-31 15:12:20.328  - info: backitup.0 (3523) Terminated (ADAPTER_REQUESTED        _TERMINATION): Without reason
    2023-03-31 15:12:20.328  - info: discovery.0 (603) terminating
    2023-03-31 15:12:20.330  - info: discovery.0 (603) Terminated (ADAPTER_REQUESTED        _TERMINATION): Without reason
    2023-03-31 15:12:20.328  - info: admin.0 (588) terminating http server on port 8        081
    2023-03-31 15:12:20.338  - info: admin.0 (588) terminating
    2023-03-31 15:12:20.339  - info: admin.0 (588) Terminated (ADAPTER_REQUESTED_TER        MINATION): Without reason
    2023-03-31 15:12:20.873  - info: host.edfa9db59fd4 instance system.adapter.disco        very.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-03-31 15:12:20.881  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-03-31 15:12:20.923  - info: host.edfa9db59fd4 instance system.adapter.admin        .0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-03-31 15:12:20.925  - info: host.edfa9db59fd4 All instances are stopped.
    2023-03-31 15:12:21.141  - info: host.edfa9db59fd4 terminated
    2023-03-31 15:26:48.156  - info: host.dd14ecbc30a9 iobroker.js-controller versio        n 4.0.24 js-controller starting
    2023-03-31 15:26:48.162  - info: host.dd14ecbc30a9 Copyright (c) 2014-2022 bluef        ox, 2014 hobbyquaker
    2023-03-31 15:26:48.163  - info: host.dd14ecbc30a9 hostname: dd14ecbc30a9, node:        v18.15.0
    2023-03-31 15:26:48.164  - info: host.dd14ecbc30a9 ip addresses: 192.168.1.49
    2023-03-31 15:26:48.817  - info: host.dd14ecbc30a9 connected to Objects and Stat        es
    2023-03-31 15:26:48.842  - info: host.dd14ecbc30a9 added notifications configura        tion of host
    2023-03-31 15:26:49.199  - info: host.dd14ecbc30a9 Delete host system.host.edfa9        db59fd4
    2023-03-31 15:26:49.249  - info: host.dd14ecbc30a9 Delete state "system.host.dd1        4ecbc30a9.versions.nodeCurrent"
    2023-03-31 15:26:49.251  - info: host.dd14ecbc30a9 15 instances found
    2023-03-31 15:26:49.266  - warn: host.dd14ecbc30a9 does not start any instances        on this host
    2023-03-31 15:26:49.343  - info: host.dd14ecbc30a9 Delete state "system.host.dd1        4ecbc30a9.versions.nodeNewest"
    2023-03-31 15:26:49.396  - info: host.dd14ecbc30a9 Delete state "system.host.dd1        4ecbc30a9.versions.nodeNewestNext"
    2023-03-31 15:26:49.449  - info: host.dd14ecbc30a9 Delete state "system.host.dd1        4ecbc30a9.versions.npmCurrent"
    2023-03-31 15:26:49.500  - info: host.dd14ecbc30a9 Delete state "system.host.dd1        4ecbc30a9.versions.npmNewest"
    2023-03-31 15:26:49.552  - info: host.dd14ecbc30a9 Delete state "system.host.dd1        4ecbc30a9.versions.npmNewestNext"
    2023-03-31 15:26:49.603  - info: host.dd14ecbc30a9 Some obsolete host states del        eted.
    2023-03-31 15:48:40.806  - info: host.dd14ecbc30a9 received SIGINT
    2023-03-31 15:48:40.860  - info: host.dd14ecbc30a9 terminated
    2023-03-31 16:01:12.692  - info: host.dd14ecbc30a9 iobroker.js-controller versio        n 4.0.24 js-controller starting
    2023-03-31 16:01:12.697  - info: host.dd14ecbc30a9 Copyright (c) 2014-2022 bluef        ox, 2014 hobbyquaker
    2023-03-31 16:01:12.698  - info: host.dd14ecbc30a9 hostname: dd14ecbc30a9, node:        v18.15.0
    2023-03-31 16:01:12.699  - info: host.dd14ecbc30a9 ip addresses: 192.168.1.49
    2023-03-31 16:01:13.348  - info: host.dd14ecbc30a9 connected to Objects and Stat        es
    2023-03-31 16:01:13.385  - info: host.dd14ecbc30a9 added notifications configura        tion of host
    2023-03-31 16:01:13.746  - info: host.dd14ecbc30a9 15 instances found
    2023-03-31 16:01:13.758  - warn: host.dd14ecbc30a9 does not start any instances        on this host
    2023-03-31 16:59:01.051  - info: host.dd14ecbc30a9 iobroker.js-controller versio        n 4.0.24 js-controller starting
    2023-03-31 16:59:01.057  - info: host.dd14ecbc30a9 Copyright (c) 2014-2022 bluef        ox, 2014 hobbyquaker
    2023-03-31 16:59:01.057  - info: host.dd14ecbc30a9 hostname: dd14ecbc30a9, node:        v18.15.0
    2023-03-31 16:59:01.058  - info: host.dd14ecbc30a9 ip addresses: 192.168.1.49
    2023-03-31 16:59:03.147  - error: host.dd14ecbc30a9-Server Cannot start inMem-ob        jects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.        jsonl"!
    2023-03-31 16:59:49.955  - info: host.dd14ecbc30a9 received SIGTERM
    2023-03-31 16:59:49.996  - info: host.dd14ecbc30a9 terminated
    2023-03-31 17:00:38.736  - info: host.dd14ecbc30a9 iobroker.js-controller versio        n 4.0.24 js-controller starting
    2023-03-31 17:00:38.743  - info: host.dd14ecbc30a9 Copyright (c) 2014-2022 bluef        ox, 2014 hobbyquaker
    2023-03-31 17:00:38.744  - info: host.dd14ecbc30a9 hostname: dd14ecbc30a9, node:        v18.15.0
    2023-03-31 17:00:38.744  - info: host.dd14ecbc30a9 ip addresses: 192.168.1.49
    2023-03-31 17:00:39.460  - info: host.dd14ecbc30a9 connected to Objects and Stat        es
    2023-03-31 17:00:39.485  - info: host.dd14ecbc30a9 added notifications configura        tion of host
    2023-03-31 17:00:39.902  - info: host.dd14ecbc30a9 15 instances found
    2023-03-31 17:00:39.914  - warn: host.dd14ecbc30a9 does not start any instances        on this host
    • A Adamantium
      Das passiert:
      GlasfaserG Offline
      GlasfaserG Offline
      @adamantium sagte in Restore läuft nicht weiter:
      • GlasfaserG Glasfaser
        Docker: v8.0.0
        host.dd14ecbc30a9 check instance "system.adapter.admin.0" for host "edfa9db59fd4"
        Habe das schon zweimal mit dem Restore
        pkill -u iobroker
        iobroker host this
        danach den Container neu starten
        Adamantium
        @glasfaser said in Restore läuft nicht weiter:
        Docker: v8.0.0
        pkill -u iobroker
        iobroker host this
        Die beiden Befehle per SSH?
        • A Adamantium
          Docker: v8.0.0
          pkill -u iobroker
          iobroker host this
          GlasfaserG Offline
          GlasfaserG Offline
          @adamantium
          Ja im Container bei ioBroker
          • A Adamantium
            @adamantium Das ist aber nicht der lange text.
            was kommt bei
            iob start admin
            Der rattert schnell durch und dann kommt nur die Summary.
            Was ich schnell kopieren konnte:
            Skript v.2023-01-02
            *** BASE SYSTEM ***
            Architecture:   x86_64
            Docker:         v8.0.0
            Virtualization: Unknown (buanet/Synology?)
            Distributor ID: Debian
            Description:    Debian GNU/Linux 11 (bullseye)
            Release:        11
            Codename:       bullseye
            PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
            NAME="Debian GNU/Linux"
            VERSION_ID="11"
            VERSION="11 (bullseye)"
            VERSION_CODENAME=bullseye
            ID=debian
            HOME_URL="https://www.debian.org/"
            SUPPORT_URL="https://www.debian.org/support"
            BUG_REPORT_URL="https://bugs.debian.org/"
            Systemuptime and Load:
             16:14:39 up 2 days, 15:19,  0 users,  load average: 1.62, 1.66, 1.75
            CPU threads: 4
            *** Time and Time Zones ***
            Fri Mar 31 14:14:39 UTC 2023
            Fri Mar 31 16:14:39 CEST 2023
            CEST +0200
            Etc/UTC
            *** User and Groups ***
            root
            /root
            root
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:
            /home/iobroker/.diag.sh: line 95: systemctl: command not found
            Boot Target:
            *** MEMORY ***
            Mem:             15G        1.8G        9.8G        314M        4.3G         13G
            Swap:           7.6G        0.0K        7.6G
            Total:           23G        1.8G         17G
                    15926 M total memory
                     1836 M used memory
                     2439 M active memory
                     2552 M inactive memory
                     9810 M free memory
                      677 M buffer memory
                     3602 M swap cache
                     7583 M total swap
                        0 M used swap
                     7582 M free swap
            *** FILESYSTEM ***
            Filesystem            Type     Size  Used Avail Use% Mounted on
            overlay               overlay  5.0T  406G  4.6T   8% /
            tmpfs                 tmpfs     64M     0   64M   0% /dev
            tmpfs                 tmpfs    7.8G     0  7.8G   0% /sys/fs/cgroup
            shm                   tmpfs     64M     0   64M   0% /dev/shm
            /dev/mapper/cachedev1 ext4     5.0T  406G  4.6T   8% /opt/iobroker
            tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/asound
            tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/acpi
            tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/scsi
            tmpfs                 tmpfs    7.8G     0  7.8G   0% /sys/firmware
            Messages in dmesg:
            dmesg: read kernel buffer failed: Operation not permitted
            TARGET           SOURCE        FSTYPE OPTIONS
            /opt/iobroker    /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/volumes/81067777c9c7fa38318a1880e7b0ef7213b9be8715bb9352d426074b4b77d050/_data]          ext4   rw,relatime,lazytime,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv0,usrjquota=aquota.user
            /etc/resolv.conf /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/edfa9db59fd46e4df32568df7051548c50058e2ef7cacec51939801b6ed54bed/resolv.conf] ext4   rw,relatime,lazytime,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv0,usrjquota=aquota.user
            /etc/hostname    /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/edfa9db59fd46e4df32568df7051548c50058e2ef7cacec51939801b6ed54bed/hostname]    ext4   rw,relatime,lazytime,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv0,usrjquota=aquota.user
            /etc/hosts       /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/edfa9db59fd46e4df32568df7051548c50058e2ef7cacec51939801b6ed54bed/hosts]       ext4   rw,relatime,lazytime,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv0,usrjquota=aquota.user
            /var:
            33M     /var/
            31M     /var/lib
            18M     /var/lib/apt/lists
            18M     /var/lib/apt
            13M     /var/lib/dpkg
            /opt/iobroker/backups:
            2.5M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            26M     /opt/iobroker/iobroker-data/
            15M     /opt/iobroker/iobroker-data/files
            13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
            11M     /opt/iobroker/iobroker-data/objects.jsonl
            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
            1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
            788K    /opt/iobroker/iobroker-data/states.jsonl
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.15.0
            /usr/bin/node           v18.15.0
            /usr/bin/npm            9.5.0
            /usr/bin/npx            9.5.0
            nodejs:
              Installed: 18.15.0-deb-1nodesource1
              Candidate: 18.15.0-deb-1nodesource1
              Version table:
             *** 18.15.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                 12.22.12~dfsg-1~deb11u3 500
                    500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                 12.22.5~dfsg-2~11u1 500
                    500 http://deb.debian.org/debian bullseye/main amd64 Packages
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            ^Aadmin:                6.3.5
            ^C
            Bei "iob start admin" passiert nichts.
            Im Terminal kann man auf der ersten Seite nach oben scrollen und zusätzlich liegt ein Log von iob diag im Home des iobrokers.
              @adamantium
              Adamantium
              @adamantium
              Da macht er gar nichts...als wenn es nicht beachtet wird.
              • A Adamantium
                @adamantium
                GlasfaserG Offline
                GlasfaserG Offline
                @adamantium
                Hier rein .. oder was machst du da
                  Adamantium
                  Theorie:
                  Bei jeder neuen Installation muss ich eine andere IP Adresse für den Container vergeben, da er sagt die alte wäre bereits belegt.
                  Heißt die Installation wo das Backup erstellt wurde hatte die 192.168.1.47...nun bin ich aber hinten bei der 1.49!
                  Kann es damit etwas zu tun haben?
                  • A Adamantium
                    Theorie:
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Nein, Kurzfassung :
                    der Container HOST hat beim erstellen einen Namen X und dein Restore hat den Namen Y .
                    das passt nicht
                    daher :
                    iobroker host this
                      @adamantium
                      Adamantium
                      @adamantium
                      Bin in dem root:
                      • A Adamantium
                        @adamantium
                        Bin in dem root:
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @adamantium
                        Ja , er hat doch schon alles gemacht ( changed ) !!
                        Jetzt den Container neu starten
                          @adamantium
                          Adamantium
                          @adamantium
                          Habe ich gemacht, hängt aber an der gleichen Stell.
                          Nun steht im Log:
                          2023-03-31 17:16:20.646  - info: host.edfa9db59fd4 iobroker.js-controller version 4.0.24 js-controller starting
                          2023-03-31 17:16:20.651  - info: host.edfa9db59fd4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                          2023-03-31 17:16:20.652  - info: host.edfa9db59fd4 hostname: edfa9db59fd4, node: v18.15.0
                          2023-03-31 17:16:20.653  - info: host.edfa9db59fd4 ip addresses: 192.168.1.49
                          2023-03-31 17:16:21.375  - info: host.edfa9db59fd4 connected to Objects and States
                          2023-03-31 17:16:21.413  - info: host.edfa9db59fd4 added notifications configuration of host
                          2023-03-31 17:16:21.418  - info: host.edfa9db59fd4 Node.js version has changed from unknown to 18.15.0
                          2023-03-31 17:16:21.479  - info: host.edfa9db59fd4 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                          2023-03-31 17:16:21.744  - info: host.edfa9db59fd4 Delete host system.host.edfa9db59fd4
                          2023-03-31 17:16:21.790  - info: host.edfa9db59fd4 15 instances found
                          2023-03-31 17:16:21.818  - info: host.edfa9db59fd4 starting 2 instances
                          2023-03-31 17:16:21.824  - warn: host.edfa9db59fd4 startInstance cannot find adapter "javascript@6.1.4". Try to install it... 1 attempt
                          2023-03-31 17:16:21.826  - info: host.edfa9db59fd4 iobroker install javascript@6.1.4 using installedFrom
                          2023-03-31 17:16:21.932  - info: host.edfa9db59fd4 instance system.adapter.admin.0 started with pid 174
                          2023-03-31 17:16:24.091  - info: admin.0 (174) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.15.0, js-controller: 4.0.24
                          2023-03-31 17:16:24.145  - info: admin.0 (174) requesting all states
                          2023-03-31 17:16:24.146  - info: admin.0 (174) requesting all objects
                          2023-03-31 17:16:24.648  - info: admin.0 (174) received all objects
                          2023-03-31 17:16:24.855  - info: admin.0 (174) http server listening on port 8081
                          2023-03-31 17:16:24.856  - info: admin.0 (174) Use link "http://localhost:8081" to configure.
                          2023-03-31 17:16:24.865  - info: admin.0 (174) socket.io server listening on port 8081
                          2023-03-31 17:16:25.071  - info: host.edfa9db59fd4 iobroker npm-install: NPM version: 9.5.0
                          2023-03-31 17:16:25.073  - info: host.edfa9db59fd4 iobroker npm-install: Installing iobroker.javascript@6.1.4... (System call)
                          2023-03-31 17:16:25.888  - info: host.edfa9db59fd4 instance system.adapter.backitup.0 started with pid 225
                          2023-03-31 17:16:27.713  - info: backitup.0 (225) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.24
                          2023-03-31 17:16:27.932  - info: backitup.0 (225) [iobroker] backup was activated at 3:00 every 2 day(s)
                          2023-03-31 17:16:39.920  - warn: admin.0 (174) Cannot update rating: timeout of 15000ms exceeded
                          2023-03-31 17:17:25.230  - error: backitup.0 (225) Error: read ECONNRESET
                          2023-03-31 17:17:30.369  - warn: admin.0 (174) Cannot check node.js versions: Error: read ECONNRESET
                          • A Adamantium
                            @adamantium
                            Nun steht im Log:
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @adamantium
                            Wenn du ein Restore einspielst ... mußt du warten , denn die Adapter werden alle nachinstalliert
                              @adamantium
                              Adamantium
                              @glasfaser
                              Aber er bleibt an gleicher Stelle stehen bzw. ist ein Error von backitup.
                              Lohnt es das System nochmal neu zu machen, dann das Backup zu restoren, die Befehle von dir und dann warten?
                              • GlasfaserG Offline
                                GlasfaserG Offline
                                so weit hab ich nicht runter gescrollt
                                ECONNRESET
                                sehr merkwürdig
                                Ja lohnt sich , ist ja noch nicht viel passiert !
                                  ECONNRESET
                                  sehr merkwürdig
                                  Adamantium
                                  @glasfaser
                                  Habe das System nochmal aufgesetzt und nun ging es :)
                                  Nervig ist jetzt nur, dass die IP wieder eine andere ist. Muss eine Einstellung im Virtual Switch des QNAP sein.
                                  Vielen Dank für die Hilfe
