  4. Restore läuft nicht weiter
    5.4k
27 Beiträge 5 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • A Adamantium
    @wendy2702 said in Restore läuft nicht weiter:
    @adamantium Das ist aber nicht der lange text.
    was kommt bei
    iob start admin
    Der rattert schnell durch und dann kommt nur die Summary.
    Was ich schnell kopieren konnte:
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Architecture:   x86_64
    Docker:         v8.0.0
    Virtualization: Unknown (buanet/Synology?)
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     16:14:39 up 2 days, 15:19,  0 users,  load average: 1.62, 1.66, 1.75
    CPU threads: 4
    *** Time and Time Zones ***
    Fri Mar 31 14:14:39 UTC 2023
    Fri Mar 31 16:14:39 CEST 2023
    CEST +0200
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    /home/iobroker/.diag.sh: line 95: systemctl: command not found
    Boot Target:
    *** MEMORY ***
    Mem:             15G        1.8G        9.8G        314M        4.3G         13G
    Swap:           7.6G        0.0K        7.6G
    Total:           23G        1.8G         17G
            15926 M total memory
             1836 M used memory
             2439 M active memory
             2552 M inactive memory
             9810 M free memory
              677 M buffer memory
             3602 M swap cache
             7583 M total swap
                0 M used swap
             7582 M free swap
    *** FILESYSTEM ***
    Filesystem            Type     Size  Used Avail Use% Mounted on
    overlay               overlay  5.0T  406G  4.6T   8% /
    tmpfs                 tmpfs     64M     0   64M   0% /dev
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /sys/fs/cgroup
    shm                   tmpfs     64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev1 ext4     5.0T  406G  4.6T   8% /opt/iobroker
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/asound
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/acpi
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/scsi
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /sys/firmware
    Messages in dmesg:
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET           SOURCE        FSTYPE OPTIONS
    /opt/iobroker    /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/volumes/81067777c9c7fa38318a1880e7b0ef7213b9be8715bb9352d426074b4b77d050/_data]          ext4   rw,relatime,lazytime,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv0,usrjquota=aquota.user
    /etc/resolv.conf /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/edfa9db59fd46e4df32568df7051548c50058e2ef7cacec51939801b6ed54bed/resolv.conf] ext4   rw,relatime,lazytime,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv0,usrjquota=aquota.user
    /etc/hostname    /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/edfa9db59fd46e4df32568df7051548c50058e2ef7cacec51939801b6ed54bed/hostname]    ext4   rw,relatime,lazytime,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv0,usrjquota=aquota.user
    /etc/hosts       /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/edfa9db59fd46e4df32568df7051548c50058e2ef7cacec51939801b6ed54bed/hosts]       ext4   rw,relatime,lazytime,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv0,usrjquota=aquota.user
    /var:
    33M     /var/
    31M     /var/lib
    18M     /var/lib/apt/lists
    18M     /var/lib/apt
    13M     /var/lib/dpkg
    /opt/iobroker/backups:
    2.5M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    26M     /opt/iobroker/iobroker-data/
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    11M     /opt/iobroker/iobroker-data/objects.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    788K    /opt/iobroker/iobroker-data/states.jsonl
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.15.0
    /usr/bin/node           v18.15.0
    /usr/bin/npm            9.5.0
    /usr/bin/npx            9.5.0
    nodejs:
      Installed: 18.15.0-deb-1nodesource1
      Candidate: 18.15.0-deb-1nodesource1
      Version table:
     *** 18.15.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    ^Aadmin:                6.3.5
    ^C
    Bei "iob start admin" passiert nichts.
    @adamantium sagte in Restore läuft nicht weiter:
    nur wenn du das Summary startest.
    • A Adamantium
      was kommt bei
      iob start admin
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Docker:         v8.0.0
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      CEST +0200
      Etc/UTC
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      Boot Target:
      *** MEMORY ***
      Total:           23G        1.8G         17G
               1836 M used memory
               9810 M free memory
                677 M buffer memory
               3602 M swap cache
               7583 M total swap
                  0 M used swap
               7582 M free swap
      *** FILESYSTEM ***
      Messages in dmesg:
      /var:
      33M     /var/
      31M     /var/lib
      18M     /var/lib/apt
      13M     /var/lib/dpkg
      /usr/bin/npm            9.5.0
      /usr/bin/npx            9.5.0
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      ^Aadmin:                6.3.5
      ^C
      GlasfaserG Offline
      GlasfaserG Offline
      Docker: v8.0.0
      host.dd14ecbc30a9 check instance "system.adapter.admin.0" for host "edfa9db59fd4"
      Habe das schon zweimal mit dem Restore
      pkill -u iobroker
      iobroker host this
      danach den Container neu starten
      • wendy2702W wendy2702
        @adamantium Im log sehe ich nichts auffälliges.
        Und wenn du mit Browser auf die IP:8081 gehst kommt nichts?
        Steht denn was im iobroker log:
        cat /opt/iobroker/log/iobroker.current.log
        Adamantium
        Das passiert:
        [Marcel@Marcel ~]$ docker exec -i -t iobroker bash
        root@edfa9db59fd4:/opt/iobroker# cat /opt/iobroker/log/iobroker.current.log
        2023-03-31 14:14:58.367  - info: host.edfa9db59fd4 iobroker.js-controller versio        n 4.0.24 js-controller starting
        2023-03-31 14:14:58.373  - info: host.edfa9db59fd4 Copyright (c) 2014-2022 bluef        ox, 2014 hobbyquaker
        2023-03-31 14:14:58.374  - info: host.edfa9db59fd4 hostname: edfa9db59fd4, node:        v18.15.0
        2023-03-31 14:14:58.375  - info: host.edfa9db59fd4 ip addresses: 192.168.1.49
        2023-03-31 14:14:58.791  - info: host.edfa9db59fd4 connected to Objects and Stat        es
        2023-03-31 14:14:58.826  - info: host.edfa9db59fd4 Node.js version has changed f        rom unknown to 18.15.0
        2023-03-31 14:14:58.899  - info: host.edfa9db59fd4 added notifications configura        tion of host
        2023-03-31 14:14:59.182  - info: host.edfa9db59fd4 3 instances found
        2023-03-31 14:14:59.191  - info: host.edfa9db59fd4 starting 3 instances
        2023-03-31 14:14:59.243  - info: host.edfa9db59fd4 instance system.adapter.admin        .0 started with pid 588
        2023-03-31 14:14:59.530  - info: host.edfa9db59fd4 Successfully updated capabili        ties "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
        2023-03-31 14:15:01.350  - info: admin.0 (588) starting. Version 6.3.5 in /opt/i        obroker/node_modules/iobroker.admin, node: v18.15.0, js-controller: 4.0.24
        2023-03-31 14:15:01.398  - info: admin.0 (588) requesting all states
        2023-03-31 14:15:01.399  - info: admin.0 (588) requesting all objects
        2023-03-31 14:15:01.596  - info: admin.0 (588) received all objects
        2023-03-31 14:15:01.631  - info: admin.0 (588) Request actual repository...
        2023-03-31 14:15:01.644  - info: host.edfa9db59fd4 Updating repository "stable"        under "http://download.iobroker.net/sources-dist.json"
        2023-03-31 14:15:01.651  - info: admin.0 (588) http server listening on port 808        1
        2023-03-31 14:15:01.652  - info: admin.0 (588) Use link "http://localhost:8081"        to configure.
        2023-03-31 14:15:01.661  - info: admin.0 (588) socket.io server listening on por        t 8081
        2023-03-31 14:15:01.804  - warn: admin.0 (588) Repository cannot be read: Active        repo - stable
        2023-03-31 14:15:01.805  - warn: admin.0 (588) Active repository "stable" cannot        be read
        2023-03-31 14:15:03.215  - info: host.edfa9db59fd4 instance system.adapter.disco        very.0 started with pid 603
        2023-03-31 14:15:05.010  - info: discovery.0 (603) starting. Version 3.1.0 in /o        pt/iobroker/node_modules/iobroker.discovery, node: v18.15.0, js-controller: 4.0.        24
        2023-03-31 14:15:07.401  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 started with pid 630
        2023-03-31 14:15:07.481  - info: admin.0 (588) Repository received successfully.
        2023-03-31 14:15:09.494  - info: backitup.0 (630) starting. Version 2.5.12 in /o        pt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.2        4
        2023-03-31 14:15:09.690  - info: backitup.0 (630) [iobroker] backup was activate        d at 02:40 every 1 day(s)
        2023-03-31 15:07:54.305  - info: admin.0 (588) ==> Connected system.user.admin f        rom ::ffff:192.168.1.51
        2023-03-31 15:08:51.640  - info: admin.0 (588) ==> Connected system.user.admin f        rom ::ffff:192.168.1.51
        2023-03-31 15:09:04.966  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 (force=false, process=true)
        2023-03-31 15:09:04.975  - info: backitup.0 (630) Got terminate signal TERMINATE        _YOURSELF
        2023-03-31 15:09:04.977  - info: backitup.0 (630) cleaned everything up...
        2023-03-31 15:09:04.978  - info: backitup.0 (630) terminating
        2023-03-31 15:09:04.980  - info: backitup.0 (630) Terminated (ADAPTER_REQUESTED_        TERMINATION): Without reason
        2023-03-31 15:09:05.015  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 send kill signal
        2023-03-31 15:09:05.524  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-03-31 15:09:08.047  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 started with pid 3338
        2023-03-31 15:09:09.778  - info: backitup.0 (3338) starting. Version 2.5.12 in /        opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.        24
        2023-03-31 15:09:09.846  - info: backitup.0 (3338) Restarting Adapter because of        changed Sentry settings
        2023-03-31 15:09:09.847  - warn: backitup.0 (3338) Restart initiated
        2023-03-31 15:09:09.849  - info: backitup.0 (3338) cleaned everything up...
        2023-03-31 15:09:09.897  - info: backitup.0 (3338) terminating
        2023-03-31 15:09:09.898  - info: backitup.0 (3338) Terminated (NO_ERROR): Withou        t reason
        2023-03-31 15:09:10.450  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 terminated with code 0 (NO_ERROR)
        2023-03-31 15:09:10.450  - info: host.edfa9db59fd4 Restart adapter system.adapte        r.backitup.0 because enabled
        2023-03-31 15:09:27.084  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 started with pid 3365
        2023-03-31 15:09:28.707  - info: backitup.0 (3365) starting. Version 2.5.12 in /        opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.        24
        2023-03-31 15:09:28.854  - info: backitup.0 (3365) [iobroker] backup was activat        ed at 02:40 every 1 day(s)
        2023-03-31 15:09:30.646  - info: admin.0 (588) <== Disconnect system.user.admin        from ::ffff:192.168.1.51
        2023-03-31 15:09:34.037  - info: admin.0 (588) ==> Connected system.user.admin f        rom ::ffff:192.168.1.51
        2023-03-31 15:09:36.718  - error: backitup.0 (3365) FTP: Error: /backupDir: No s        uch file or directory
        2023-03-31 15:09:37.330  - error: backitup.0 (3365) FTP: Error: /backupDir: No s        uch file or directory
        2023-03-31 15:09:49.414  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 (force=false, process=true)
        2023-03-31 15:09:49.419  - info: backitup.0 (3365) Got terminate signal TERMINAT        E_YOURSELF
        2023-03-31 15:09:49.421  - info: backitup.0 (3365) cleaned everything up...
        2023-03-31 15:09:49.422  - info: backitup.0 (3365) terminating
        2023-03-31 15:09:49.423  - info: backitup.0 (3365) Terminated (ADAPTER_REQUESTED        _TERMINATION): Without reason
        2023-03-31 15:09:49.458  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 send kill signal
        2023-03-31 15:09:49.964  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-03-31 15:09:52.481  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 started with pid 3405
        2023-03-31 15:09:54.063  - info: backitup.0 (3405) starting. Version 2.5.12 in /        opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.        24
        2023-03-31 15:09:54.199  - info: backitup.0 (3405) [iobroker] backup was activat        ed at 02:40 every 1 day(s)
        2023-03-31 15:09:54.924  - error: backitup.0 (3405) FTP: Error: /backup_iobroker        : No such file or directory
        2023-03-31 15:10:10.325  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 (force=false, process=true)
        2023-03-31 15:10:10.330  - info: backitup.0 (3405) Got terminate signal TERMINAT        E_YOURSELF
        2023-03-31 15:10:10.332  - info: backitup.0 (3405) cleaned everything up...
        2023-03-31 15:10:10.333  - info: backitup.0 (3405) terminating
        2023-03-31 15:10:10.334  - info: backitup.0 (3405) Terminated (ADAPTER_REQUESTED        _TERMINATION): Without reason
        2023-03-31 15:10:10.369  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 send kill signal
        2023-03-31 15:10:10.876  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-03-31 15:10:13.002  - info: admin.0 (588) <== Disconnect system.user.admin        from ::ffff:192.168.1.51
        2023-03-31 15:10:13.393  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 started with pid 3433
        2023-03-31 15:10:14.908  - info: backitup.0 (3433) starting. Version 2.5.12 in /        opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.        24
        2023-03-31 15:10:15.028  - info: backitup.0 (3433) [iobroker] backup was activat        ed at 02:40 every 1 day(s)
        2023-03-31 15:10:15.743  - error: backitup.0 (3433) FTP: Error: /backup_iobroker        /: No such file or directory
        2023-03-31 15:10:17.465  - info: admin.0 (588) ==> Connected system.user.admin f        rom ::ffff:192.168.1.51
        2023-03-31 15:10:19.529  - error: backitup.0 (3433) FTP: Error: /backup_iobroker        /: No such file or directory
        2023-03-31 15:10:39.043  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 (force=false, process=true)
        2023-03-31 15:10:39.047  - info: backitup.0 (3433) Got terminate signal TERMINAT        E_YOURSELF
        2023-03-31 15:10:39.048  - info: backitup.0 (3433) cleaned everything up...
        2023-03-31 15:10:39.049  - info: backitup.0 (3433) terminating
        2023-03-31 15:10:39.050  - info: backitup.0 (3433) Terminated (ADAPTER_REQUESTED        _TERMINATION): Without reason
        2023-03-31 15:10:39.086  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 send kill signal
        2023-03-31 15:10:39.586  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-03-31 15:10:42.109  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 started with pid 3472
        2023-03-31 15:10:43.835  - info: backitup.0 (3472) starting. Version 2.5.12 in /        opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.        24
        2023-03-31 15:10:43.983  - info: backitup.0 (3472) [iobroker] backup was activat        ed at 02:40 every 1 day(s)
        2023-03-31 15:11:29.524  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 (force=false, process=true)
        2023-03-31 15:11:29.529  - info: backitup.0 (3472) Got terminate signal TERMINAT        E_YOURSELF
        2023-03-31 15:11:29.531  - info: backitup.0 (3472) cleaned everything up...
        2023-03-31 15:11:29.531  - info: backitup.0 (3472) terminating
        2023-03-31 15:11:29.533  - info: backitup.0 (3472) Terminated (ADAPTER_REQUESTED        _TERMINATION): Without reason
        2023-03-31 15:11:29.568  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 send kill signal
        2023-03-31 15:11:30.067  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-03-31 15:11:31.686  - info: admin.0 (588) <== Disconnect system.user.admin        from ::ffff:192.168.1.51
        2023-03-31 15:11:32.594  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 started with pid 3523
        2023-03-31 15:11:34.107  - info: backitup.0 (3523) starting. Version 2.5.12 in /        opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.        24
        2023-03-31 15:11:34.249  - info: backitup.0 (3523) [iobroker] backup was activat        ed at 02:40 every 1 day(s)
        2023-03-31 15:11:38.465  - info: admin.0 (588) ==> Connected system.user.admin f        rom ::ffff:192.168.1.51
        2023-03-31 15:12:20.313  - info: host.edfa9db59fd4 received SIGTERM
        2023-03-31 15:12:20.315  - info: host.edfa9db59fd4 stopInstance system.adapter.a        dmin.0 (force=false, process=true)
        2023-03-31 15:12:20.315  - info: host.edfa9db59fd4 stopInstance system.adapter.d        iscovery.0 (force=false, process=true)
        2023-03-31 15:12:20.316  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 (force=false, process=true)
        2023-03-31 15:12:20.322  - info: host.edfa9db59fd4 stopInstance system.adapter.a        dmin.0 send kill signal
        2023-03-31 15:12:20.322  - info: backitup.0 (3523) Got terminate signal TERMINAT        E_YOURSELF
        2023-03-31 15:12:20.323  - info: discovery.0 (603) Got terminate signal TERMINAT        E_YOURSELF
        2023-03-31 15:12:20.324  - info: host.edfa9db59fd4 stopInstance system.adapter.d        iscovery.0 send kill signal
        2023-03-31 15:12:20.325  - info: host.edfa9db59fd4 stopInstance system.adapter.b        ackitup.0 send kill signal
        2023-03-31 15:12:20.325  - info: admin.0 (588) Got terminate signal TERMINATE_YO        URSELF
        2023-03-31 15:12:20.325  - info: backitup.0 (3523) cleaned everything up...
        2023-03-31 15:12:20.326  - info: backitup.0 (3523) terminating
        2023-03-31 15:12:20.328  - info: backitup.0 (3523) Terminated (ADAPTER_REQUESTED        _TERMINATION): Without reason
        2023-03-31 15:12:20.328  - info: discovery.0 (603) terminating
        2023-03-31 15:12:20.330  - info: discovery.0 (603) Terminated (ADAPTER_REQUESTED        _TERMINATION): Without reason
        2023-03-31 15:12:20.328  - info: admin.0 (588) terminating http server on port 8        081
        2023-03-31 15:12:20.338  - info: admin.0 (588) terminating
        2023-03-31 15:12:20.339  - info: admin.0 (588) Terminated (ADAPTER_REQUESTED_TER        MINATION): Without reason
        2023-03-31 15:12:20.873  - info: host.edfa9db59fd4 instance system.adapter.disco        very.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-03-31 15:12:20.881  - info: host.edfa9db59fd4 instance system.adapter.backi        tup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-03-31 15:12:20.923  - info: host.edfa9db59fd4 instance system.adapter.admin        .0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-03-31 15:12:20.925  - info: host.edfa9db59fd4 All instances are stopped.
        2023-03-31 15:12:21.141  - info: host.edfa9db59fd4 terminated
        2023-03-31 15:26:48.156  - info: host.dd14ecbc30a9 iobroker.js-controller versio        n 4.0.24 js-controller starting
        2023-03-31 15:26:48.162  - info: host.dd14ecbc30a9 Copyright (c) 2014-2022 bluef        ox, 2014 hobbyquaker
        2023-03-31 15:26:48.163  - info: host.dd14ecbc30a9 hostname: dd14ecbc30a9, node:        v18.15.0
        2023-03-31 15:26:48.164  - info: host.dd14ecbc30a9 ip addresses: 192.168.1.49
        2023-03-31 15:26:48.817  - info: host.dd14ecbc30a9 connected to Objects and Stat        es
        2023-03-31 15:26:48.842  - info: host.dd14ecbc30a9 added notifications configura        tion of host
        2023-03-31 15:26:49.199  - info: host.dd14ecbc30a9 Delete host system.host.edfa9        db59fd4
        2023-03-31 15:26:49.249  - info: host.dd14ecbc30a9 Delete state "system.host.dd1        4ecbc30a9.versions.nodeCurrent"
        2023-03-31 15:26:49.251  - info: host.dd14ecbc30a9 15 instances found
        2023-03-31 15:26:49.266  - warn: host.dd14ecbc30a9 does not start any instances        on this host
        2023-03-31 15:26:49.343  - info: host.dd14ecbc30a9 Delete state "system.host.dd1        4ecbc30a9.versions.nodeNewest"
        2023-03-31 15:26:49.396  - info: host.dd14ecbc30a9 Delete state "system.host.dd1        4ecbc30a9.versions.nodeNewestNext"
        2023-03-31 15:26:49.449  - info: host.dd14ecbc30a9 Delete state "system.host.dd1        4ecbc30a9.versions.npmCurrent"
        2023-03-31 15:26:49.500  - info: host.dd14ecbc30a9 Delete state "system.host.dd1        4ecbc30a9.versions.npmNewest"
        2023-03-31 15:26:49.552  - info: host.dd14ecbc30a9 Delete state "system.host.dd1        4ecbc30a9.versions.npmNewestNext"
        2023-03-31 15:26:49.603  - info: host.dd14ecbc30a9 Some obsolete host states del        eted.
        2023-03-31 15:48:40.806  - info: host.dd14ecbc30a9 received SIGINT
        2023-03-31 15:48:40.860  - info: host.dd14ecbc30a9 terminated
        2023-03-31 16:01:12.692  - info: host.dd14ecbc30a9 iobroker.js-controller versio        n 4.0.24 js-controller starting
        2023-03-31 16:01:12.697  - info: host.dd14ecbc30a9 Copyright (c) 2014-2022 bluef        ox, 2014 hobbyquaker
        2023-03-31 16:01:12.698  - info: host.dd14ecbc30a9 hostname: dd14ecbc30a9, node:        v18.15.0
        2023-03-31 16:01:12.699  - info: host.dd14ecbc30a9 ip addresses: 192.168.1.49
        2023-03-31 16:01:13.348  - info: host.dd14ecbc30a9 connected to Objects and Stat        es
        2023-03-31 16:01:13.385  - info: host.dd14ecbc30a9 added notifications configura        tion of host
        2023-03-31 16:01:13.746  - info: host.dd14ecbc30a9 15 instances found
        2023-03-31 16:01:13.758  - warn: host.dd14ecbc30a9 does not start any instances        on this host
        2023-03-31 16:59:01.051  - info: host.dd14ecbc30a9 iobroker.js-controller versio        n 4.0.24 js-controller starting
        2023-03-31 16:59:01.057  - info: host.dd14ecbc30a9 Copyright (c) 2014-2022 bluef        ox, 2014 hobbyquaker
        2023-03-31 16:59:01.057  - info: host.dd14ecbc30a9 hostname: dd14ecbc30a9, node:        v18.15.0
        2023-03-31 16:59:01.058  - info: host.dd14ecbc30a9 ip addresses: 192.168.1.49
        2023-03-31 16:59:03.147  - error: host.dd14ecbc30a9-Server Cannot start inMem-ob        jects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.        jsonl"!
        2023-03-31 16:59:49.955  - info: host.dd14ecbc30a9 received SIGTERM
        2023-03-31 16:59:49.996  - info: host.dd14ecbc30a9 terminated
        2023-03-31 17:00:38.736  - info: host.dd14ecbc30a9 iobroker.js-controller versio        n 4.0.24 js-controller starting
        2023-03-31 17:00:38.743  - info: host.dd14ecbc30a9 Copyright (c) 2014-2022 bluef        ox, 2014 hobbyquaker
        2023-03-31 17:00:38.744  - info: host.dd14ecbc30a9 hostname: dd14ecbc30a9, node:        v18.15.0
        2023-03-31 17:00:38.744  - info: host.dd14ecbc30a9 ip addresses: 192.168.1.49
        2023-03-31 17:00:39.460  - info: host.dd14ecbc30a9 connected to Objects and Stat        es
        2023-03-31 17:00:39.485  - info: host.dd14ecbc30a9 added notifications configura        tion of host
        2023-03-31 17:00:39.902  - info: host.dd14ecbc30a9 15 instances found
        2023-03-31 17:00:39.914  - warn: host.dd14ecbc30a9 does not start any instances        on this host
        • A Adamantium
          Das passiert:
          GlasfaserG Offline
          GlasfaserG Offline
          • GlasfaserG Glasfaser
            Docker: v8.0.0
            pkill -u iobroker
            iobroker host this
            Adamantium
            @glasfaser said in Restore läuft nicht weiter:
            Docker: v8.0.0
            pkill -u iobroker
            iobroker host this
            Die beiden Befehle per SSH?
            • A Adamantium
              Docker: v8.0.0
              pkill -u iobroker
              iobroker host this
              GlasfaserG Offline
              GlasfaserG Offline
              @adamantium
              Ja im Container bei ioBroker
              • A Adamantium
                was kommt bei
                iob start admin
                Skript v.2023-01-02
                *** BASE SYSTEM ***
                Docker:         v8.0.0
                Release:        11
                Codename:       bullseye
                VERSION_ID="11"
                ID=debian
                CPU threads: 4
                CEST +0200
                Etc/UTC
                root
                /root
                root
                X-Server:       false
                Desktop:
                Terminal:
                Boot Target:
                *** MEMORY ***
                Total:           23G        1.8G         17G
                         1836 M used memory
                         9810 M free memory
                          677 M buffer memory
                         3602 M swap cache
                         7583 M total swap
                            0 M used swap
                         7582 M free swap
                *** FILESYSTEM ***
                Messages in dmesg:
                /var:
                33M     /var/
                31M     /var/lib
                18M     /var/lib/apt
                13M     /var/lib/dpkg
                /usr/bin/npm            9.5.0
                /usr/bin/npx            9.5.0
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                ^Aadmin:                6.3.5
                ^C
                Im Terminal kann man auf der ersten Seite nach oben scrollen und zusätzlich liegt ein Log von iob diag im Home des iobrokers.
                  @adamantium
                  Adamantium
                  @adamantium
                  Da macht er gar nichts...als wenn es nicht beachtet wird.
                  • A Adamantium
                    @adamantium
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @adamantium
                    Hier rein .. oder was machst du da
                      Adamantium
                      Theorie:
                      Bei jeder neuen Installation muss ich eine andere IP Adresse für den Container vergeben, da er sagt die alte wäre bereits belegt.
                      Heißt die Installation wo das Backup erstellt wurde hatte die 192.168.1.47...nun bin ich aber hinten bei der 1.49!
                      Kann es damit etwas zu tun haben?
                      • A Adamantium
                        Theorie:
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Nein, Kurzfassung :
                        der Container HOST hat beim erstellen einen Namen X und dein Restore hat den Namen Y .
                        das passt nicht
                        daher :
                        iobroker host this
                          @adamantium
                          Adamantium
                          @adamantium
                          Bin in dem root:
                          • A Adamantium
                            @adamantium
                            Bin in dem root:
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @adamantium
                            Ja , er hat doch schon alles gemacht ( changed ) !!
                            Jetzt den Container neu starten
                              @adamantium
                              Adamantium
                              @adamantium
                              Habe ich gemacht, hängt aber an der gleichen Stell.
                              Nun steht im Log:
                              2023-03-31 17:16:20.646  - info: host.edfa9db59fd4 iobroker.js-controller version 4.0.24 js-controller starting
                              2023-03-31 17:16:20.651  - info: host.edfa9db59fd4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                              2023-03-31 17:16:20.652  - info: host.edfa9db59fd4 hostname: edfa9db59fd4, node: v18.15.0
                              2023-03-31 17:16:20.653  - info: host.edfa9db59fd4 ip addresses: 192.168.1.49
                              2023-03-31 17:16:21.375  - info: host.edfa9db59fd4 connected to Objects and States
                              2023-03-31 17:16:21.413  - info: host.edfa9db59fd4 added notifications configuration of host
                              2023-03-31 17:16:21.418  - info: host.edfa9db59fd4 Node.js version has changed from unknown to 18.15.0
                              2023-03-31 17:16:21.479  - info: host.edfa9db59fd4 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                              2023-03-31 17:16:21.744  - info: host.edfa9db59fd4 Delete host system.host.edfa9db59fd4
                              2023-03-31 17:16:21.790  - info: host.edfa9db59fd4 15 instances found
                              2023-03-31 17:16:21.818  - info: host.edfa9db59fd4 starting 2 instances
                              2023-03-31 17:16:21.824  - warn: host.edfa9db59fd4 startInstance cannot find adapter "javascript@6.1.4". Try to install it... 1 attempt
                              2023-03-31 17:16:21.826  - info: host.edfa9db59fd4 iobroker install javascript@6.1.4 using installedFrom
                              2023-03-31 17:16:21.932  - info: host.edfa9db59fd4 instance system.adapter.admin.0 started with pid 174
                              2023-03-31 17:16:24.091  - info: admin.0 (174) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.15.0, js-controller: 4.0.24
                              2023-03-31 17:16:24.145  - info: admin.0 (174) requesting all states
                              2023-03-31 17:16:24.146  - info: admin.0 (174) requesting all objects
                              2023-03-31 17:16:24.648  - info: admin.0 (174) received all objects
                              2023-03-31 17:16:24.855  - info: admin.0 (174) http server listening on port 8081
                              2023-03-31 17:16:24.856  - info: admin.0 (174) Use link "http://localhost:8081" to configure.
                              2023-03-31 17:16:24.865  - info: admin.0 (174) socket.io server listening on port 8081
                              2023-03-31 17:16:25.071  - info: host.edfa9db59fd4 iobroker npm-install: NPM version: 9.5.0
                              2023-03-31 17:16:25.073  - info: host.edfa9db59fd4 iobroker npm-install: Installing iobroker.javascript@6.1.4... (System call)
                              2023-03-31 17:16:25.888  - info: host.edfa9db59fd4 instance system.adapter.backitup.0 started with pid 225
                              2023-03-31 17:16:27.713  - info: backitup.0 (225) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.24
                              2023-03-31 17:16:27.932  - info: backitup.0 (225) [iobroker] backup was activated at 3:00 every 2 day(s)
                              2023-03-31 17:16:39.920  - warn: admin.0 (174) Cannot update rating: timeout of 15000ms exceeded
                              2023-03-31 17:17:25.230  - error: backitup.0 (225) Error: read ECONNRESET
                              2023-03-31 17:17:30.369  - warn: admin.0 (174) Cannot check node.js versions: Error: read ECONNRESET
                              • A Adamantium
                                @adamantium
                                Nun steht im Log:
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @adamantium
                                Wenn du ein Restore einspielst ... mußt du warten , denn die Adapter werden alle nachinstalliert
                                  @adamantium
                                  Adamantium
                                  @glasfaser
                                  Aber er bleibt an gleicher Stelle stehen bzw. ist ein Error von backitup.
                                  Lohnt es das System nochmal neu zu machen, dann das Backup zu restoren, die Befehle von dir und dann warten?
                                  • GlasfaserG Offline
                                    GlasfaserG Offline
                                    so weit hab ich nicht runter gescrollt
                                    ECONNRESET
                                    sehr merkwürdig
                                    Ja lohnt sich , ist ja noch nicht viel passiert !
                                      ECONNRESET
                                      sehr merkwürdig
                                      Adamantium
                                      @glasfaser
                                      Habe das System nochmal aufgesetzt und nun ging es :)
                                      Nervig ist jetzt nur, dass die IP wieder eine andere ist. Muss eine Einstellung im Virtual Switch des QNAP sein.
                                      Vielen Dank für die Hilfe
