  4. Restore läuft nicht weiter
    5.5k
27 Beiträge 5 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • A Adamantium
    @wendy2702 said in Restore läuft nicht weiter:
    @adamantium Das ist aber nicht der lange text.
    was kommt bei
    iob start admin
    Der rattert schnell durch und dann kommt nur die Summary.
    Was ich schnell kopieren konnte:
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Architecture:   x86_64
    Docker:         v8.0.0
    Virtualization: Unknown (buanet/Synology?)
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     16:14:39 up 2 days, 15:19,  0 users,  load average: 1.62, 1.66, 1.75
    CPU threads: 4
    *** Time and Time Zones ***
    Fri Mar 31 14:14:39 UTC 2023
    Fri Mar 31 16:14:39 CEST 2023
    CEST +0200
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    /home/iobroker/.diag.sh: line 95: systemctl: command not found
    Boot Target:
    *** MEMORY ***
    Mem:             15G        1.8G        9.8G        314M        4.3G         13G
    Swap:           7.6G        0.0K        7.6G
    Total:           23G        1.8G         17G
            15926 M total memory
             1836 M used memory
             2439 M active memory
             2552 M inactive memory
             9810 M free memory
              677 M buffer memory
             3602 M swap cache
             7583 M total swap
                0 M used swap
             7582 M free swap
    *** FILESYSTEM ***
    Filesystem            Type     Size  Used Avail Use% Mounted on
    overlay               overlay  5.0T  406G  4.6T   8% /
    tmpfs                 tmpfs     64M     0   64M   0% /dev
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /sys/fs/cgroup
    shm                   tmpfs     64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev1 ext4     5.0T  406G  4.6T   8% /opt/iobroker
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/asound
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/acpi
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/scsi
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /sys/firmware
    Messages in dmesg:
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET           SOURCE        FSTYPE OPTIONS
    /opt/iobroker    /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/volumes/81067777c9c7fa38318a1880e7b0ef7213b9be8715bb9352d426074b4b77d050/_data]          ext4   rw,relatime,lazytime,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv0,usrjquota=aquota.user
    /etc/resolv.conf /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/edfa9db59fd46e4df32568df7051548c50058e2ef7cacec51939801b6ed54bed/resolv.conf] ext4   rw,relatime,lazytime,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv0,usrjquota=aquota.user
    /etc/hostname    /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/edfa9db59fd46e4df32568df7051548c50058e2ef7cacec51939801b6ed54bed/hostname]    ext4   rw,relatime,lazytime,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv0,usrjquota=aquota.user
    /etc/hosts       /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/edfa9db59fd46e4df32568df7051548c50058e2ef7cacec51939801b6ed54bed/hosts]       ext4   rw,relatime,lazytime,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv0,usrjquota=aquota.user
    /var:
    33M     /var/
    31M     /var/lib
    18M     /var/lib/apt/lists
    18M     /var/lib/apt
    13M     /var/lib/dpkg
    /opt/iobroker/backups:
    2.5M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    26M     /opt/iobroker/iobroker-data/
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    11M     /opt/iobroker/iobroker-data/objects.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    788K    /opt/iobroker/iobroker-data/states.jsonl
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.15.0
    /usr/bin/node           v18.15.0
    /usr/bin/npm            9.5.0
    /usr/bin/npx            9.5.0
    nodejs:
      Installed: 18.15.0-deb-1nodesource1
      Candidate: 18.15.0-deb-1nodesource1
      Version table:
     *** 18.15.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    ^Aadmin:                6.3.5
    ^C
    Bei "iob start admin" passiert nichts.
    @adamantium sagte in Restore läuft nicht weiter:
    Im Terminal kann man auf der ersten Seite nach oben scrollen und zusätzlich liegt ein Log von iob diag im Home des iobrokers.
    • GlasfaserG Glasfaser
      @adamantium
      Ja im Container bei ioBroker
      Adamantium
      @glasfaser said in Restore läuft nicht weiter:
      @adamantium
      Da macht er gar nichts...als wenn es nicht beachtet wird.
      • A Adamantium
        @adamantium
        GlasfaserG Offline
        GlasfaserG Offline
        @adamantium
        Hier rein .. oder was machst du da
        [Marcel@Marcel ~]$ docker exec -i -t iobroker bash
        root@edfa9db59fd4:/opt/iobroker#
          Adamantium
          Theorie:
          Bei jeder neuen Installation muss ich eine andere IP Adresse für den Container vergeben, da er sagt die alte wäre bereits belegt.
          Heißt die Installation wo das Backup erstellt wurde hatte die 192.168.1.47...nun bin ich aber hinten bei der 1.49!
          Kann es damit etwas zu tun haben?
          • A Adamantium
            Theorie:
            GlasfaserG Offline
            GlasfaserG Offline
            Nein, Kurzfassung :
            der Container HOST hat beim erstellen einen Namen X und dein Restore hat den Namen Y .
            das passt nicht
            daher :
            iobroker host this
              @adamantium
              Adamantium
              @adamantium
              Bin in dem root:
              • A Adamantium
                @adamantium
                Bin in dem root:
                GlasfaserG Offline
                GlasfaserG Offline
                @adamantium
                Ja , er hat doch schon alles gemacht ( changed ) !!
                Jetzt den Container neu starten
                  @adamantium
                  Adamantium
                  @adamantium
                  Habe ich gemacht, hängt aber an der gleichen Stell.
                  Nun steht im Log:
                  2023-03-31 17:16:20.646  - info: host.edfa9db59fd4 iobroker.js-controller version 4.0.24 js-controller starting
                  2023-03-31 17:16:20.651  - info: host.edfa9db59fd4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                  2023-03-31 17:16:20.652  - info: host.edfa9db59fd4 hostname: edfa9db59fd4, node: v18.15.0
                  2023-03-31 17:16:20.653  - info: host.edfa9db59fd4 ip addresses: 192.168.1.49
                  2023-03-31 17:16:21.375  - info: host.edfa9db59fd4 connected to Objects and States
                  2023-03-31 17:16:21.413  - info: host.edfa9db59fd4 added notifications configuration of host
                  2023-03-31 17:16:21.418  - info: host.edfa9db59fd4 Node.js version has changed from unknown to 18.15.0
                  2023-03-31 17:16:21.479  - info: host.edfa9db59fd4 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                  2023-03-31 17:16:21.744  - info: host.edfa9db59fd4 Delete host system.host.edfa9db59fd4
                  2023-03-31 17:16:21.790  - info: host.edfa9db59fd4 15 instances found
                  2023-03-31 17:16:21.818  - info: host.edfa9db59fd4 starting 2 instances
                  2023-03-31 17:16:21.824  - warn: host.edfa9db59fd4 startInstance cannot find adapter "javascript@6.1.4". Try to install it... 1 attempt
                  2023-03-31 17:16:21.826  - info: host.edfa9db59fd4 iobroker install javascript@6.1.4 using installedFrom
                  2023-03-31 17:16:21.932  - info: host.edfa9db59fd4 instance system.adapter.admin.0 started with pid 174
                  2023-03-31 17:16:24.091  - info: admin.0 (174) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.15.0, js-controller: 4.0.24
                  2023-03-31 17:16:24.145  - info: admin.0 (174) requesting all states
                  2023-03-31 17:16:24.146  - info: admin.0 (174) requesting all objects
                  2023-03-31 17:16:24.648  - info: admin.0 (174) received all objects
                  2023-03-31 17:16:24.855  - info: admin.0 (174) http server listening on port 8081
                  2023-03-31 17:16:24.856  - info: admin.0 (174) Use link "http://localhost:8081" to configure.
                  2023-03-31 17:16:24.865  - info: admin.0 (174) socket.io server listening on port 8081
                  2023-03-31 17:16:25.071  - info: host.edfa9db59fd4 iobroker npm-install: NPM version: 9.5.0
                  2023-03-31 17:16:25.073  - info: host.edfa9db59fd4 iobroker npm-install: Installing iobroker.javascript@6.1.4... (System call)
                  2023-03-31 17:16:25.888  - info: host.edfa9db59fd4 instance system.adapter.backitup.0 started with pid 225
                  2023-03-31 17:16:27.713  - info: backitup.0 (225) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.15.0, js-controller: 4.0.24
                  2023-03-31 17:16:27.932  - info: backitup.0 (225) [iobroker] backup was activated at 3:00 every 2 day(s)
                  2023-03-31 17:16:39.920  - warn: admin.0 (174) Cannot update rating: timeout of 15000ms exceeded
                  2023-03-31 17:17:25.230  - error: backitup.0 (225) Error: read ECONNRESET
                  2023-03-31 17:17:30.369  - warn: admin.0 (174) Cannot check node.js versions: Error: read ECONNRESET
                  • A Adamantium
                    @adamantium
                    Nun steht im Log:
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @adamantium
                    Wenn du ein Restore einspielst ... mußt du warten , denn die Adapter werden alle nachinstalliert
                      @adamantium
                      Adamantium
                      @glasfaser
                      Aber er bleibt an gleicher Stelle stehen bzw. ist ein Error von backitup.
                      Lohnt es das System nochmal neu zu machen, dann das Backup zu restoren, die Befehle von dir und dann warten?
                      • GlasfaserG Offline
                        GlasfaserG Offline
                        so weit hab ich nicht runter gescrollt
                        ECONNRESET
                        sehr merkwürdig
                        Ja lohnt sich , ist ja noch nicht viel passiert !
                          ECONNRESET
                          sehr merkwürdig
                          Adamantium
                          @glasfaser
                          Habe das System nochmal aufgesetzt und nun ging es :)
                          Nervig ist jetzt nur, dass die IP wieder eine andere ist. Muss eine Einstellung im Virtual Switch des QNAP sein.
                          Vielen Dank für die Hilfe
