  4. Backitup findet Dateien nicht auf NAS-Stick wird gesucht
    5.4k
100 Beiträge 6 Kommentatoren 4.4k Aufrufe 5 Beobachtet
    @olli63
    Wie sehen die Einstellungen im Backitup-Adapter aus?
    Das log kann man u.U. so im Terminal beobachten:
    iob logs --watch | uniq
    Am besten mal einen Backup-Vorgang dort anschauen.
    O Offline
    O Offline
    Olli63
    @thomas-braun said in Backitup findet Dateien nicht auf NAS-Stick wird gesucht:
    Started iobroker ...
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=admin,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.178.23/TV_Aufnahmen /opt/iobroker/backups"
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=admin,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.23/TV_Aufnahmen /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.phoscon 1848 states saved
    [DEBUG] [iobroker] - host.phoscon 2544 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_03_30-12_37_40_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [yahka] - found yahka database: yahka.0
    [DEBUG] [yahka] - done
    [DEBUG] [cifs] - used copy path: /TV_Aufnahmen
    [DEBUG] [cifs] - done
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    MOD EDIT: LOG IN CODE TAGS </> GESETZT
    O 1 Antwort Letzte Antwort
    • O Olli63
      [EXIT] 0
      O Offline
      O Offline
      Olli63
      unter Putty erfolgt gar kein Eintrag weder beim Backup erstellen noch beim Versuch es widerherzustellen
      O wendy2702W 2 Antworten Letzte Antwort
      • O Olli63
        O Offline
        O Offline
        Olli63
        53854d2f-9e39-4c6c-8730-9061c048589d-image.png @olli63
        • O Olli63
          wendy2702W Offline
          wendy2702W Offline
          @olli63 sagte in Backitup findet Dateien nicht auf NAS-Stick wird gesucht:
          Woher stammt denn das Log das du oben gepostet hast?
          Was genau hast du in Putty eingegeben?
          Komplette ein Ausgabe hier posten als Text. In Putty einfach den Text markieren, dann ist der schon im Speicher. Dann hier, wie oben erklärt in Code Tags </> einfügen.
          • O Olli63
            @olli63
            Stell mal den SMB-Dialekt auf 3.1.1 um. Oder was auch immer dein NAS spricht, aber mit v1 sollte da eigentlich nichts mehr laufen.
            O HomoranH 2 Antworten Letzte Antwort
              @olli63
              O Offline
              O Offline
              Olli63
              @thomas-braun SMB 3.1.1 hat auch nicht geholfen
              Ich lass es einfach...
              In Putty ist defintiv kein Log wenn ich Backitup wiederherstellung anstosse
              Danke für Eure Hilfsversuche
              • O Olli63
                @olli63
                Loglevel für den Adapter mal auf debug gesetzt?
                • O Olli63
                  Blödsinn ;-)
                  das bekommen wir schon hin.
                  Wenn du in ioBroker das Backup startest wirst du in putty au h nichts anderes sehen, wenn du dort mit iob logs --watch nachsiehst.
                  "Einfach so" komm nichts in putty.
                  jetzt mal strukturiert!
                  bevor wir weitermachen erst mal die Grundlagen
                  Wo hast du Probleme mit Screenshot und logs zu posten?
                  das bekommen wir alles hin
                    Blödsinn ;-)
                    O Offline
                    O Offline
                    Olli63
                    @homoran Genau das habe ich in putty gemachcht iob logs -- watch
                    Dann im IO Broker das Backup gestartet
                    und es erfolgte kein Log :-(
                    Das Log das ich gepostet habe ist das Log aus dem Webinterface wenn ich ein Backup starte und nicht im Hintergrund laufen lasse.
                    Das alles ist aber nicht mein Problem! Das Backup wird ja erstellt und genau dort im NAS gespeichert wo es hin soll.
                    Das Problem ist das ich , wenn ich ein Backup widerherstellen möchte der IO Broker kein Backup zur wiederherstellung anbietet - er scheint es nicht auf dem NAS zu finden oder hat sonst irgend welche Probleme.
                    Ich lebe jetzt schon einige Zeit damit und sichere mir meinen Stick immer auf einem 2. Stick mit Win32 Diskimager. Das ist zwar umständlicher funktioniert aber wenigstens.
                    • O Olli63
                      @olli63
                      Mir ist auch die Konstruktion mit dem USB-Stick nicht klar. Läuft auf dem ein CIFS-Server?
                        @olli63
                        O Offline
                        O Offline
                        Olli63
                        @thomas-braun ? Wie oder was ist da zu tun?
                        Thomas BraunT O 2 Antworten Letzte Antwort
                          @olli63
                          O Offline
                          O Offline
                          Olli63
                          @thomas-braun mein Rasberry läuft auf einem Stick (nicht SD) der Server hat damit nichts zu tun . Der ist im Netz (MyCloud)
                          • O Olli63
                            @olli63
                            Du musst uns sagen was das da für ein System mit welchen Einstellungen da auf der IP ist.
                            USB-Sticks werden üblicherweise nicht per IP eingebunden und da läuft auch kein SMB/CIFS-Server drauf.
                            • O Olli63
                              das ist mir schon klar!
                              Aber wir können nicht helfen, wenn wir nichts sehen.
                              Das musst du uns liefern.
                              Wenn du schon keine logs bekommst, können wir keine Informationen bekommen, die du vielleicht nicht erkennst.
                              Aus putty kopieren geht ganz einfach:
                              @wendy2702 sagte in Backitup findet Dateien nicht auf NAS-Stick wird gesucht:
                              bitte mit Eingabezeile.
                              • O Olli63
                                O Offline
                                O Offline
                                Olli63
                                @olli63 said in Backitup findet Dateien nicht auf NAS-Stick wird gesucht:
                                um auf Debug zu setzen?
                                  O Offline
                                  O Offline
                                  Olli63
                                  @homoran said in Backitup findet Dateien nicht auf NAS-Stick wird gesucht:
                                  Wenn in putty etwas zu sehen wäre würde ich es posten....
                                  Lasst es jetzt einfach gut sein - ich bin zu blöd dafür
                                  • O Olli63
                                    O Offline
                                    O Offline
                                    Olli63
                                    @olli63 Danke für die Hilfsversuche, aber ihr setzt wahrscheinlich zu viel voraus
                                    • O Olli63
                                      @olli63 wenn du da drauf klickst
                                      was kommt dann?
                                      eher nicht!
                                      Vielleicht ist etwas defekt/verstellt, das wollen wir fixen.
                                      auch keine Eingabezeile, dass man sehen kann wo du gerade im System hängst?
                                        was kommt dann?
                                        eher nicht!
                                        O Offline
                                        O Offline
                                        Olli63
                                        was kommt dann?
                                        eher nicht!
                                        Genau da liegt das Problem. Wenn ich an der Stelle klicke beginnt die Suche nach den Backups und nichts wird gefunden :-(
                                        • O Olli63
                                          was kommt dann?
                                          eher nicht!
                                          das sollte aber angesagt werden
                                          geh mal auf die Seite Instanzen
                                          schalte den Expertenmodus ein
                                          gehe bei Logstufe auf den Bleistift
                                          stelle von info auf debug um
                                          Dann klick nochmal den Button an.
                                          Jetzt muss was im log stehen
