4.8k Beiträge 4 Kommentatoren 2.9m Aufrufe 4 Beobachtet
  • mickymM mickym
    @damrak2022 Na nur die Ioboker-in node die Probleme macht - der Rest macht ja keine Probleme
    Damrak2022D
    Damrak2022D
    Damrak2022
    #4659
    @mickym Mache ich - bitte Geduld😧
    Mit besten Grüßen
    Andy
    • Damrak2022D Damrak2022
      mickymM
      mickymM
      mickym
      #4660
      @damrak2022 Na keine Eile.
      • mickymM mickym
        Damrak2022D
        Damrak2022D
        Damrak2022
        #4661
        @mickym Ist gelöscht
        Mit besten Grüßen
        Andy
          mickymM
          mickymM
          mickym
          #4662
          @damrak2022 So dann probier halt mal mit einer get-Node den Datenpunkt auszulesen:
                  "id": "be4f312afb9e4c3b",
                  "type": "ui_template",
                  "z": "289f539dcc33814e",
                  "group": "5b02a0802660a23d",
                  "name": "",
                  "order": 0,
                  "width": "12",
                  "height": "12",
                  "format": "<img src={{msg.payload}}>",
                  "storeOutMessages": true,
                  "fwdInMessages": true,
                  "resendOnRefresh": true,
                  "templateScope": "local",
                  "className": "",
                  "x": 780,
                  "y": 4860,
                  "wires": [
                  "id": "d7a7cba9a481811d",
                  "type": "ioBroker get",
                  "name": "",
                  "topic": "0_userdata.0.Test.Bild",
                  "attrname": "payload",
                  "payloadType": "value",
                  "errOnInvalidState": "nothing",
                  "x": 560,
                  "y": 4860,
                  "wires": [
                          "be4f312afb9e4c3b"
                  "id": "84bdc0f2f51c9803",
                  "type": "inject",
                  "name": "",
                  "props": [
                          "p": "payload"
                  "repeat": "",
                  "crontab": "",
                  "once": false,
                  "onceDelay": 0.1,
                  "topic": "",
                  "payload": "true",
                  "payloadType": "bool",
                  "x": 370,
                  "y": 4860,
                  "wires": [
                          "d7a7cba9a481811d"
                  "id": "5b02a0802660a23d",
                  "type": "ui_group",
                  "name": "Bild",
                  "tab": "2ce144dc.d7472c",
                  "order": 2,
                  "disp": true,
                  "width": "12",
                  "collapse": false,
                  "className": ""
                  "id": "2ce144dc.d7472c",
                  "type": "ui_tab",
                  "name": "test",
                  "icon": "dashboard",
                  "order": 23,
                  "disabled": false,
                  "hidden": false
          • mickymM mickym
                    "name": "",
                    "order": 0,
                    "width": "12",
                    "height": "12",
                    "className": "",
                    "x": 780,
                    "y": 4860,
                    "wires": [
                    "name": "",
                    "x": 560,
                    "y": 4860,
                    "wires": [
                            "be4f312afb9e4c3b"
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "true",
                    "x": 370,
                    "y": 4860,
                    "wires": [
                            "d7a7cba9a481811d"
                    "type": "ui_group",
                    "name": "Bild",
                    "order": 2,
                    "disp": true,
                    "width": "12",
                    "collapse": false,
                    "className": ""
                    "type": "ui_tab",
                    "name": "test",
                    "order": 23,
                    "disabled": false,
                    "hidden": false
            Damrak2022D
            Damrak2022D
            Damrak2022
            #4663
            @mickym Da hängt es auch. Wenn ich von einem anderen Tab zurück will zum Staubsauger. Dann tauch auch einmal kurz der Ladekreis in (orange) auf, dann kann ich einmal was machen, dann wieder warten. Ich versteh es halt nicht, weil man es ja auch in der Vis einbinden kann. Da kann ja kein besonderer Unterschied sein.
            Bildschirm­foto 2023-03-27 um 19.31.39.png Bildschirm­foto 2023-03-27 um 19.31.31.png
            Und so sieht das aus, wenn ich im Browser zurück auf iobroker wechseln will:
            Mit besten Grüßen
            Andy
              mickymM
              mickymM
              mickym
              #4664
              @damrak2022 Nur mal zum Test kopiere mal den Inhalt des Datenpunktes nun in einen selbstestellten Datenpunkt unter 0_userdata und schau ob Du damit Probleme hast. datentyp ist string.
              • mickymM mickym
                Damrak2022D
                Damrak2022D
                Damrak2022
                #4665
                @mickym Moment
                Mit besten Grüßen
                Andy
                • mickymM mickym
                  Damrak2022D
                  Damrak2022D
                  Damrak2022
                  #4666
                  @mickym Wie kopiere ich da was rein?
                  Mit besten Grüßen
                  Andy
                    @mickym Moment
                    mickymM
                    mickymM
                    mickym
                    #4667
                    @damrak2022 Kopieren bitte über die Schaltfläche und nicht mit der Maus ziehen:
                    und dann in einen Datenpunkt mit typ String kopieren:
                    • mickymM mickym
                      Damrak2022D
                      Damrak2022D
                      Damrak2022
                      #4668
                      @mickym Okay, habe ich direkt nach dem einsetzen hat sich der Ladekreis für 2 Sekunden gezeigt, ist jetzt aber drin
                      Mit besten Grüßen
                      Andy
                      • mickymM mickym
                        Damrak2022D
                        Damrak2022D
                        Damrak2022
                        #4669
                        @mickym Jetzt dauert es wieder einen Moment bis ich den Datenpunkt in der Get Node anpassen kann.
                        Mit besten Grüßen
                        Andy
                          mickymM
                          mickymM
                          mickym
                          #4670
                          @damrak2022 So dann schau mal wenn Du die get Node nun auf den Userdaten punkt setzt ob es geht.
                            mickymM
                            mickymM
                            mickym
                            #4671
                            Wir haben viel Zeit.
                            • mickymM mickym
                              Damrak2022D
                              Damrak2022D
                              Damrak2022
                              #4672
                              @mickym Musste neu importieren, denn öffnen lässt sich eine Node bei mir nicht mehr, wenn sie mit dem orginal Datenpunkt bestückt ist.
                              Momentan schaut es so aus:
                              Bildschirm­foto 2023-03-27 um 19.49.29.png Bildschirm­foto 2023-03-27 um 19.49.23.png
                              Oh warte mal, der hat die Daten in eigenen Datenpunkt garnicht übernommen - also nochmal
                              Mit besten Grüßen
                              Andy
                                mickymM
                                mickymM
                                mickym
                                #4673
                                @damrak2022 Du musst dann auf die Schaltfläche Wert setzen klicken
                                Ob das Bild drin ist siehst doch ob der Anfang des Strings drin ist:
                                • mickymM mickym
                                  Damrak2022D
                                  Damrak2022D
                                  Damrak2022
                                  #4674
                                  @mickym Das habe ich mittlerweile 3 mal gemacht, nur erfolglos
                                  Mit besten Grüßen
                                  Andy
                                    mickymM
                                    mickymM
                                    mickym
                                    #4675
                                    @damrak2022 Du musst Geduld haben. Ansonsten mach mal folgendes - geh auf Kopieren und kopier halt die Daten in einen Editor und dann kopierst Du von dort in den Datenpunkt.
                                    • mickymM mickym
                                      Damrak2022D
                                      Damrak2022D
                                      Damrak2022
                                      #4676
                                      @mickym Auch der Umweg über den Editor geht nicht. Sobald ich auf das Feld klicke kann ich das einsetzen und wenn ich dann Wett schreiben anklicke und danach nachschaue wieder das gleiche. Es ist nichts drin.
                                      Mit besten Grüßen
                                      Andy
                                        mickymM
                                        mickymM
                                        mickym
                                        #4677
                                        @damrak2022 Na vielleicht ist es nur ein Anzeigeproblem - ansonsten ist Dein mac vielleicht überfordert. Mach mal den Browser komplett zu udn wieder auf.
                                        • mickymM mickym
                                          Damrak2022D
                                          Damrak2022D
                                          Damrak2022
                                          #4678
                                          @mickym Jetzt ist da glaube ich ein anderes Fenster:
                                          Soll ich da was bestimmtes reinschreiben?
                                          Mit besten Grüßen
                                          Andy
