  4. Iobroker Absturz
    5.5k
Iobroker Absturz
43 Beiträge 4 Kommentatoren 5.0k Aufrufe 2 Beobachtet
  • VanduraV Vandura
    pi@raspberrypi:/var $ tail -n 100 /var/log/kern.log
    Mar 27 11:28:16 raspberrypi kernel: [    3.253047]     HOME=/
    Mar 27 11:28:16 raspberrypi kernel: [    3.253061]     TERM=linux
    Mar 27 11:28:16 raspberrypi kernel: [    3.376336] usb 1-1.4: USB disconnect, device number 3
    Mar 27 11:28:16 raspberrypi kernel: [    3.674376] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
    Mar 27 11:28:16 raspberrypi kernel: [    3.812994] usb 1-1.4: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
    Mar 27 11:28:16 raspberrypi kernel: [    3.813042] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    Mar 27 11:28:16 raspberrypi kernel: [    3.813078] usb 1-1.4: Product: ConBee II
    Mar 27 11:28:16 raspberrypi kernel: [    3.813108] usb 1-1.4: Manufacturer: dresden elektronik ingenieurtechnik GmbH
    Mar 27 11:28:16 raspberrypi kernel: [    3.813140] usb 1-1.4: SerialNumber: DE2218695
    Mar 27 11:28:16 raspberrypi kernel: [    4.676546] NET: Registered protocol family 10
    Mar 27 11:28:16 raspberrypi kernel: [    4.677949] Segment Routing with IPv6
    Mar 27 11:28:16 raspberrypi kernel: [    6.562991] random: systemd: uninitialized urandom read (16 bytes read)
    Mar 27 11:28:16 raspberrypi kernel: [    6.590967] random: systemd: uninitialized urandom read (16 bytes read)
    Mar 27 11:28:16 raspberrypi kernel: [    6.592359] random: systemd: uninitialized urandom read (16 bytes read)
    Mar 27 11:28:16 raspberrypi kernel: [    7.216983] usb 1-1.4: USB disconnect, device number 4
    Mar 27 11:28:16 raspberrypi kernel: [    7.524380] usb 1-1.4: new full-speed USB device number 5 using xhci_hcd
    Mar 27 11:28:16 raspberrypi kernel: [    7.663063] usb 1-1.4: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
    Mar 27 11:28:16 raspberrypi kernel: [    7.663087] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    Mar 27 11:28:16 raspberrypi kernel: [    7.663105] usb 1-1.4: Product: ConBee II
    Mar 27 11:28:16 raspberrypi kernel: [    7.663122] usb 1-1.4: Manufacturer: dresden elektronik ingenieurtechnik GmbH
    Mar 27 11:28:16 raspberrypi kernel: [    7.663139] usb 1-1.4: SerialNumber: DE2218695
    Mar 27 11:28:16 raspberrypi kernel: [    8.694377] EXT4-fs (sda2): re-mounted. Opts: (null)
    Mar 27 11:28:16 raspberrypi kernel: [   10.113741] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
    Mar 27 11:28:16 raspberrypi kernel: [   10.116142] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
    Mar 27 11:28:16 raspberrypi kernel: [   10.116775] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
    Mar 27 11:28:16 raspberrypi kernel: [   10.117383] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
    Mar 27 11:28:16 raspberrypi kernel: [   10.258105] mc: Linux media interface: v0.10
    Mar 27 11:28:16 raspberrypi kernel: [   10.273992] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    Mar 27 11:28:16 raspberrypi kernel: [   10.358164] videodev: Linux video capture interface: v2.00
    Mar 27 11:28:16 raspberrypi kernel: [   10.435146] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    Mar 27 11:28:16 raspberrypi kernel: [   10.437435] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    Mar 27 11:28:16 raspberrypi kernel: [   10.437459] [vc_sm_connected_init]: start
    Mar 27 11:28:16 raspberrypi kernel: [   10.438512] [vc_sm_connected_init]: installed successfully
    Mar 27 11:28:16 raspberrypi kernel: [   10.438883] bcm2835_audio bcm2835_audio: card created with 8 channels
    Mar 27 11:28:16 raspberrypi kernel: [   10.609786] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
    Mar 27 11:28:16 raspberrypi kernel: [   10.611221] usbcore: registered new interface driver cdc_acm
    Mar 27 11:28:16 raspberrypi kernel: [   10.611239] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    Mar 27 11:28:16 raspberrypi kernel: [   10.741564] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    Mar 27 11:28:16 raspberrypi kernel: [   10.741600] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    Mar 27 11:28:16 raspberrypi kernel: [   10.755577] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    Mar 27 11:28:16 raspberrypi kernel: [   10.962973] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    Mar 27 11:28:16 raspberrypi kernel: [   11.055770] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    Mar 27 11:28:16 raspberrypi kernel: [   11.068646] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    Mar 27 11:28:16 raspberrypi kernel: [   11.071775] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    Mar 27 11:28:16 raspberrypi kernel: [   11.071782] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    Mar 27 11:28:16 raspberrypi kernel: [   11.072744] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    Mar 27 11:28:16 raspberrypi kernel: [   11.073083] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    Mar 27 11:28:16 raspberrypi kernel: [   11.073112] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    Mar 27 11:28:16 raspberrypi kernel: [   11.073137] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    Mar 27 11:28:16 raspberrypi kernel: [   11.073160] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    Mar 27 11:28:16 raspberrypi kernel: [   11.073183] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    Mar 27 11:28:16 raspberrypi kernel: [   11.073425] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    Mar 27 11:28:16 raspberrypi kernel: [   11.083601] [drm] No displays found. Consider forcing hotplug if HDMI is attached
    Mar 27 11:28:16 raspberrypi kernel: [   11.083726] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    Mar 27 11:28:16 raspberrypi kernel: [   11.095958] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
    Mar 27 11:28:16 raspberrypi kernel: [   11.096494] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    Mar 27 11:28:16 raspberrypi kernel: [   11.096538] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    Mar 27 11:28:16 raspberrypi kernel: [   11.098385] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    Mar 27 11:28:16 raspberrypi kernel: [   11.103345] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    Mar 27 11:28:16 raspberrypi kernel: [   11.103390] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    Mar 27 11:28:16 raspberrypi kernel: [   11.108197] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    Mar 27 11:28:16 raspberrypi kernel: [   11.108259] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    Mar 27 11:28:16 raspberrypi kernel: [   11.126548] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
    Mar 27 11:28:16 raspberrypi kernel: [   11.126596] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
    Mar 27 11:28:16 raspberrypi kernel: [   11.157030] random: crng init done
    Mar 27 11:28:16 raspberrypi kernel: [   11.157058] random: 7 urandom warning(s) missed due to ratelimiting
    Mar 27 11:28:16 raspberrypi kernel: [   11.168321] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    Mar 27 11:28:16 raspberrypi kernel: [   11.314650] sd 0:0:0:0: Attached scsi generic sg0 type 0
    Mar 27 11:28:16 raspberrypi kernel: [   11.410389] brcmfmac: F1 signature read @0x18000000=0x15264345
    Mar 27 11:28:16 raspberrypi kernel: [   11.418858] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    Mar 27 11:28:16 raspberrypi kernel: [   11.419550] usbcore: registered new interface driver brcmfmac
    Mar 27 11:28:16 raspberrypi kernel: [   12.993487] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    Mar 27 11:28:16 raspberrypi kernel: [   12.993606] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    Mar 27 11:28:16 raspberrypi kernel: [   13.043682] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
    Mar 27 11:28:16 raspberrypi kernel: [   16.685590] uart-pl011 fe201000.serial: no DMA platform data
    Mar 27 11:28:17 raspberrypi kernel: [   17.934114] 8021q: 802.1Q VLAN Support v1.8
    Mar 27 11:28:20 raspberrypi kernel: [   21.187493] exfat: Deprecated parameter 'utf8'
    Mar 27 11:28:20 raspberrypi kernel: [   21.187540] /dev/sda1: Can't open blockdev
    Mar 27 11:28:24 raspberrypi kernel: [   25.312183] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
    Mar 27 11:28:25 raspberrypi kernel: [   25.665358] Bluetooth: Core ver 2.22
    Mar 27 11:28:25 raspberrypi kernel: [   25.665455] NET: Registered protocol family 31
    Mar 27 11:28:25 raspberrypi kernel: [   25.665470] Bluetooth: HCI device and connection manager initialized
    Mar 27 11:28:25 raspberrypi kernel: [   25.665974] Bluetooth: HCI socket layer initialized
    Mar 27 11:28:25 raspberrypi kernel: [   25.665995] Bluetooth: L2CAP socket layer initialized
    Mar 27 11:28:25 raspberrypi kernel: [   25.666027] Bluetooth: SCO socket layer initialized
    Mar 27 11:28:25 raspberrypi kernel: [   25.792451] Bluetooth: HCI UART driver ver 2.3
    Mar 27 11:28:25 raspberrypi kernel: [   25.792469] Bluetooth: HCI UART protocol H4 registered
    Mar 27 11:28:25 raspberrypi kernel: [   25.792546] Bluetooth: HCI UART protocol Three-wire (H5) registered
    Mar 27 11:28:25 raspberrypi kernel: [   25.792788] Bluetooth: HCI UART protocol Broadcom registered
    Mar 27 11:28:25 raspberrypi kernel: [   26.024737] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
    Mar 27 11:28:25 raspberrypi kernel: [   26.025106] bcmgenet fd580000.ethernet eth0: Link is Down
    Mar 27 11:28:26 raspberrypi kernel: [   26.844353] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
    Mar 27 11:28:27 raspberrypi kernel: [   27.465190] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    Mar 27 11:28:27 raspberrypi kernel: [   27.465206] Bluetooth: BNEP filters: protocol multicast
    Mar 27 11:28:27 raspberrypi kernel: [   27.465230] Bluetooth: BNEP socket layer initialized
    Mar 27 11:28:28 raspberrypi kernel: [   29.124495] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    Mar 27 11:28:28 raspberrypi kernel: [   29.124525] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    Mar 27 11:28:30 raspberrypi kernel: [   31.036764] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
    Mar 27 11:28:30 raspberrypi kernel: [   31.159329] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    Mar 27 11:28:31 raspberrypi kernel: [   31.834348] vcc-sd: disabling
    @vandura sagte in Iobroker Absturz:
    Um 11:28 gab es offenbar einen Reboot.
    VanduraV 1 Antwort Letzte Antwort
      Und ein vncserver-x11.log darf da auch nicht existieren, ganz einfach weil man kein X11 und auch kein VNC auf einem Server laufen lässt.
      VanduraV Offline
      VanduraV Offline
      Vandura
      @thomas-braun sagte in Iobroker Absturz:
      Weiß noch nicht mal was das ist......
      Raspberry 4 - 8GB / 500 GB Festplatte mit IoBroker! 1xConbee 2, 15xAQARA Door Sensoren,2xSonoff Door Sensor, 2xSonoff Pov2, 2xAQARA Watersensoren, 3xIKEA TRÅDFRI Bewegungsmelder, 5xIKEA TRÅDFRI Repeater, 1x IKEA TRÅDFRI Treiber 10w, 10xTeckin Steckdosen mit Tasmota-Flash, 1xShelly SHSW-1, 2xAQARA Taster, 4xAlexa...usw.
      • VanduraV Vandura
        @vandura
        Ich würde mir mein Backup vom iobroker schnappen und die Kiste neu und gescheit (d. h. OHNE Desktop und VNC und so 'nem Kram) aufsetzen.
          VanduraV Offline
          VanduraV Offline
          Vandura
          das war ich selbst
          • VanduraV Vandura
            das war ich selbst
            VanduraV Offline
            VanduraV Offline
            Vandura
            @vandura
            -rw-r----- 1 root adm  206G Mar 27 11:28 kern.log
            -rw-r----- 1 root adm  4.2G Mar  8 17:47 kern.log.3.gz
            -rw-r----- 1 root adm  3.4G Mar  7 09:53 kern.log.4.gz
            -rw-r----- 1 root adm   47G Mar 27 14:39 syslog
            -rw-r----- 1 root adm  160G Mar 27 00:00 syslog.1
            kann man die Teile löschen?
            • VanduraV Vandura
              @vandura
              @vandura
              sudo > /var/log/syslog.1
              sudo > /var/log/kern.log.3.gz
              sudo > /var/log/kern.log.4.gz
              Nutzt dir aber nix, wenn du die Ursache nicht anpackst, das aktuelle log wird dir dann wieder um die Ohren fliegen.
              • VanduraV Offline
                VanduraV Offline
                Vandura
                @vandura
                Ich tippe mal liegt am mihome-vacuum......der kackt immer ab
                Thomas BraunT VanduraV 2 Antworten Letzte Antwort
                • VanduraV Vandura
                  @vandura
                  Ich tippe
                  Schau ins Log, tippen nutzt dir nix.
                  • VanduraV Vandura
                    @vandura
                    VanduraV Offline
                    VanduraV Offline
                    Vandura
                    @vandura
                    kommt nur Permission denied.....?
                    • VanduraV Vandura
                      @vandura
                      Möglich.
                      Man kann auch files mit Attributen versehen, das selbst der root die nicht (ohne weiteres) löschen kann. Ich weiß aber nicht ob das bei den logs gemacht wird.
                      Versuch mal
                      sudo su
                      echo "" > /var/log/syslog.1
                      echo "" > /var/log/kern.log.3.gz
                      echo "" > /var/log/kern.log.4.gz
                      exit
                      • VanduraV Vandura
                        @vandura
                        VanduraV Offline
                        VanduraV Offline
                        Vandura
                        @vandura
                        Hat geklappt jetzt....ich beobachte es mal weiter, mihome-vacuum habe ich erst mal gelöscht....Danke für die Hilfe
                        • VanduraV Vandura
                          @vandura
                          Installier da ein noch lebendes Betriebssytem!
                          Dein 'buster' ist tot.
                            VanduraV Offline
                            VanduraV Offline
                            Vandura
                            wie mache ich das ohne das alles weg ist......die Ahnung hab ich nicht....leider
                            • VanduraV Vandura
                              @vandura
                              Hier hat das mal jemand festgehalten:
                              https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                @vandura
                                VanduraV Offline
                                VanduraV Offline
                                Vandura
                                @thomas-braun ok, schau ich mir an....Danke
                                  @vandura
                                  VanduraV Offline
                                  VanduraV Offline
                                  Vandura
                                  @vandura
                                                       v.2023-01-02
                                  Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                                  Installation:           Native
                                  Timezone:               Europe/Berlin
                                  User-ID:                1000
                                  X-Server:               false
                                  Pending OS-Updates:     0
                                  Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                                          /usr/bin/node           v16.19.1
                                                          /usr/bin/npm            8.19.3
                                                          /usr/bin/npx            8.19.3
                                  ioBroker Core:          js-controller           4.0.24
                                                          admin                   6.3.5
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Status admin:
                                  Pending iob updates:    0
                                  Objects:                8860
                                  States:                 7736
                                  Size of iob-Database:
                                  17M     /opt/iobroker/iobroker-data/objects.json.migrated
                                  17M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                  15M     /opt/iobroker/iobroker-data/objects.jsonl
                                  16K     /opt/iobroker/iobroker-data/objects.json.old
                                  66M     /opt/iobroker/iobroker-data/states.jsonl
                                  11M     /opt/iobroker/iobroker-data/states.json.migrated
                                  11M     /opt/iobroker/iobroker-data/states.json.bak.migrated
                                  7.3M    /opt/iobroker/iobroker-data/states.json.old
                                  • VanduraV Vandura
                                    @vandura
                                                         v.2023-01-02
                                    User-ID:                1000
                                    X-Server:               false
                                                            /usr/bin/npm            8.19.3
                                                            /usr/bin/npx            8.19.3
                                                            admin                   6.3.5
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Status admin:
                                    Objects:                8860
                                    States:                 7736
                                    @vandura
                                    Stell das Boot Target auf Multiuser und bring nodejs auf die derzeitig empfohlene Version 18.
                                    • VanduraV Offline
                                      VanduraV Offline
                                      Vandura
                                      @vandura
                                      wie stelle ich das Boot Target um?
                                      • VanduraV Vandura
                                        @vandura
                                        @vandura
                                        sudo systemctl set-default multi-user.target
                                        Alternativ kann man beim Raspberry auch über
                                        sudo raspi-config
                                        einstellen.
                                          @vandura
                                          sudo raspi-config
                                          einstellen.
                                          VanduraV Offline
                                          VanduraV Offline
                                          Vandura
                                          @vandura
                                          sudo raspi-config
                                          einstellen.
                                          Alles erledigt incl. Upgrade Node.js v18.15.0.
                                          Danke nochmal für deine Hilfe.....👍
