  4. Iobroker Absturz
    5.5k
Iobroker Absturz
43 Beiträge 4 Kommentatoren 5.0k Aufrufe 2 Beobachtet
  • VanduraV Vandura
    code_text
    ``` pi@raspberrypi:~ $ df -h
    Filesystem      Size  Used Avail Use% Mounted on
    /dev/root       458G  428G  6.6G  99% /
    devtmpfs        3.7G     0  3.7G   0% /dev
    tmpfs           3.9G     0  3.9G   0% /dev/shm
    tmpfs           3.9G   17M  3.9G   1% /run
    tmpfs           5.0M  4.0K  5.0M   1% /run/lock
    tmpfs           3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/sda1       253M   49M  204M  20% /boot
    tmpfs           785M     0  785M   0% /run/user/1000
    arteckA Offline
    arteckA Offline
    arteck
    @vandura installier dir mal ncdu
    apt install ncdu
    und schau was da so vollgemüllt hat
    aufruff aus dem Wurzelverzeichniss ncdu
      @vandura sagte in Iobroker Absturz:
      voll!
      VanduraV Offline
      VanduraV Offline
      Vandura
      schrieb am zuletzt editiert von Vandura
      ncdu arbeitet gerade....
      220.9 MiB [##########] /.npm
        69.0 MiB [###       ] /.cache
         5.6 MiB [          ]  deconz-latest-beta.deb
       396.0 KiB [          ] /iobroker-data
       360.0 KiB [          ] /rpi-clone
       304.0 KiB [          ] /.local
       276.0 KiB [          ]  pi_stretch_motion_4.1.1-1_armhf.deb.1
       228.0 KiB [          ]  package-lock.json
       160.0 KiB [          ]  deCONZ_RaspBeeII_0x26610700_many2one.bin.GCF
       160.0 KiB [          ]  deCONZ_ConBeeII_0x26580700.bin.GCF
        24.0 KiB [          ]  .bash_history
        16.0 KiB [          ] /.config
        12.0 KiB [          ] /.iobroker
         8.0 KiB [          ] /.gnupg
         8.0 KiB [          ]  reinstall.js
      e   4.0 KiB [          ] /log
         4.0 KiB [          ]  .bashrc
         4.0 KiB [          ]  .profile
         4.0 KiB [          ]  .bash_logout
         4.0 KiB [          ]  .wget-hsts
         4.0 KiB [          ]  package.json
         4.0 KiB [          ]  iobroker
         4.0 KiB [          ]  iob
         4.0 KiB [          ]  .npmrc
      code_text
      Raspberry 4 - 8GB / 500 GB Festplatte mit IoBroker! 1xConbee 2, 15xAQARA Door Sensoren,2xSonoff Door Sensor, 2xSonoff Pov2, 2xAQARA Watersensoren, 3xIKEA TRÅDFRI Bewegungsmelder, 5xIKEA TRÅDFRI Repeater, 1x IKEA TRÅDFRI Treiber 10w, 10xTeckin Steckdosen mit Tasmota-Flash, 1xShelly SHSW-1, 2xAQARA Taster, 4xAlexa...usw.
      Thomas BraunT HomoranH 3 Antworten Letzte Antwort
      • VanduraV Vandura
           8.0 KiB [          ] /.gnupg
        e   4.0 KiB [          ] /log
           4.0 KiB [          ]  .bashrc
           4.0 KiB [          ]  iob
           4.0 KiB [          ]  .npmrc
        code_text
        @vandura
        Vom akuten Problem abgesehn:
        Schau dir per
        iob diag
        auch den Rest der Installation an.
        VanduraV 1 Antwort Letzte Antwort
        • VanduraV Vandura
             8.0 KiB [          ] /.gnupg
          e   4.0 KiB [          ] /log
             4.0 KiB [          ]  .bashrc
             4.0 KiB [          ]  iob
             4.0 KiB [          ]  .npmrc
          code_text
          das nutzt nichts.
          erst wenn er fertig ist
          • VanduraV Vandura
               8.0 KiB [          ] /.gnupg
            e   4.0 KiB [          ] /log
               4.0 KiB [          ]  .bashrc
               4.0 KiB [          ]  iob
               4.0 KiB [          ]  .npmrc
            code_text
            Du steht (hoffentlich) im falschen Verzeichnis.
            Aufruf von
            cd /
            sudo ncdu
            cd ~
            Die ganzen .deb-Files da lassen mich schon erahnen, das da mal wieder 'wild irgendwas von irgendwoher' in das System geknüppelt wurde.
              @vandura
              Schau dir per
              iob diag
              VanduraV Offline
              VanduraV Offline
              Vandura
                                   v.2023-01-02
              Operatingsystem:        Raspbian GNU/Linux 10 (buster)
              Installation:           Native
              Timezone:               Europe/Berlin
              User-ID:                1000
              X-Server:               false
              Pending OS-Updates:     19
              Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                      /usr/bin/node           v16.19.1
                                      /usr/bin/npm            8.19.3
                                      /usr/bin/npx            8.19.3
              ioBroker Core:          js-controller           4.0.24
                                      admin                   6.3.5
              Objects type: jsonl
              States  type: jsonl
              Status admin:
              Pending iob updates:    0
              Objects:                9122
              States:                 7884
              Size of iob-Database:
              17M     /opt/iobroker/iobroker-data/objects.json.migrated
              17M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
              15M     /opt/iobroker/iobroker-data/objects.jsonl
              16K     /opt/iobroker/iobroker-data/objects.json.old
              11M     /opt/iobroker/iobroker-data/states.jsonl
              11M     /opt/iobroker/iobroker-data/states.json.migrated
              11M     /opt/iobroker/iobroker-data/states.json.bak.migrated
              7.3M    /opt/iobroker/iobroker-data/states.json.old
              pi@raspberrypi:~ $
              • VanduraV Vandura
                                     v.2023-01-02
                User-ID:                1000
                X-Server:               false
                                        /usr/bin/npm            8.19.3
                                        /usr/bin/npx            8.19.3
                                        admin                   6.3.5
                Objects type: jsonl
                States  type: jsonl
                Status admin:
                Objects:                9122
                States:                 7884
                pi@raspberrypi:~ $
                (buster)
                ist tod, installier da das 'Bullsyeye'-Release.
                Und bitte die Langfassung von iob diag.
                  Aufruf von
                  cd /
                  sudo ncdu
                  cd ~
                  VanduraV Offline
                  VanduraV Offline
                  Vandura
                  pi@raspberrypi:~ $ ^C
                  pi@raspberrypi:~ $ cd /
                  pi@raspberrypi:/ $ sudo ncdu
                  ncdu 1.13 ~ Use the arrow keys to navigate, press ? for help
                    418.7 GiB [##########] /var
                      3.4 GiB [          ] /opt
                      3.3 GiB [          ] /home
                      1.4 GiB [          ] /usr
                    381.2 MiB [          ] /lib
                     48.2 MiB [          ] /boot
                     23.7 MiB [          ] /root
                     16.5 MiB [          ] /run
                      9.3 MiB [          ] /bin
                      8.7 MiB [          ] /sbin
                      4.3 MiB [          ] /etc
                     52.0 KiB [          ] /tmp
                  e  16.0 KiB [          ] /lost+found
                     12.0 KiB [          ] /mnt
                      8.0 KiB [          ] /media
                  e   4.0 KiB [          ] /srv
                  e   4.0 KiB [          ] /History
                      0.0   B [          ] /sys
                  .   0.0   B [          ] /proc
                      0.0   B [          ] /dev
                  code_text
                  • VanduraV Vandura
                        3.4 GiB [          ] /opt
                        3.3 GiB [          ] /home
                        1.4 GiB [          ] /usr
                      381.2 MiB [          ] /lib
                       48.2 MiB [          ] /boot
                       23.7 MiB [          ] /root
                       16.5 MiB [          ] /run
                        9.3 MiB [          ] /bin
                        8.7 MiB [          ] /sbin
                        4.3 MiB [          ] /etc
                       52.0 KiB [          ] /tmp
                       12.0 KiB [          ] /mnt
                        8.0 KiB [          ] /media
                    e   4.0 KiB [          ] /srv
                        0.0   B [          ] /sys
                    .   0.0   B [          ] /proc
                        0.0   B [          ] /dev
                    code_text
                    @vandura
                    Dann schau in /var was da so drin liegt.
                    Ich vermute dir ist ein log um die Ohren geflogen.
                      (buster)
                      VanduraV Offline
                      VanduraV Offline
                      Vandura
                      Skript v.2023-01-02
                      *** BASE SYSTEM ***
                      Model           : Raspberry Pi 4 Model B Rev 1.4
                      Architecture:   armv7l
                      Docker:         false
                      Virtualization: none
                      Distributor ID: Raspbian
                      Description:    Raspbian GNU/Linux 10 (buster)
                      Release:        10
                      Codename:       buster
                      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                      NAME="Raspbian GNU/Linux"
                      VERSION_ID="10"
                      VERSION="10 (buster)"
                      VERSION_CODENAME=buster
                      ID=raspbian
                      ID_LIKE=debian
                      HOME_URL="http://www.raspbian.org/"
                      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                      Systemuptime and Load:
                       14:22:59 up  2:54,  1 user,  load average: 0.66, 1.04, 1.03
                      CPU threads: 4
                      *** Time and Time Zones ***
                      Mon Mar 27 12:22:59 UTC 2023
                      Mon Mar 27 14:22:59 CEST 2023
                      CEST +0200
                      Europe/Berlin
                      *** User and Groups ***
                      pi
                      /home/pi
                      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                      *** X-Server-Setup ***
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:           7.8G        1.9G        3.8G         16M        2.1G        6.1G
                      Swap:           99M          0B         99M
                      Total:         7.9G        1.9G        3.9G
                               7846 M total memory
                               1934 M used memory
                                502 M active memory
                               3269 M inactive memory
                               3836 M free memory
                                326 M buffer memory
                               1748 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      *** FILESYSTEM ***
                      /dev/root      ext4      458G  428G  6.8G  99% /
                      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                      tmpfs          tmpfs     3.9G   17M  3.9G   1% /run
                      tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                      /dev/sda1      vfat      253M   49M  204M  20% /boot
                      tmpfs          tmpfs     785M     0  785M   0% /run/user/1000
                      Messages in dmesg:
                      [Mon Mar 27 11:28:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:E2:12:0E vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=316bf5fd-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                      [Mon Mar 27 11:28:30 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                      [Mon Mar 27 11:28:30 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                      [Mon Mar 27 11:28:35 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
                      TARGET                      SOURCE    FSTYPE  OPTIONS
                      /                           /dev/sda2 ext4    rw,noatime
                      |-/sys/fs/bpf               none      bpf     rw,nosuid,nodev,noexec,relatime,mode=700
                      |-/sys/kernel/debug/tracing tracefs   tracefs rw,relatime
                      `-/boot                     /dev/sda1 vfat    rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      419G    /var/log
                      419G    /var/
                      196M    /var/cache
                      190M    /var/cache/apt
                      131M    /var/cache/apt/archives
                      /opt/iobroker/backups:
                      1.2G    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      1.1G    /opt/iobroker/iobroker-data/
                      591M    /opt/iobroker/iobroker-data/files
                      222M    /opt/iobroker/iobroker-data/backup-objects
                      134M    /opt/iobroker/iobroker-data/history
                      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
                      27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
                      23M     /opt/iobroker/iobroker-data/history/20201011/history.mihome-vacuum.0.history.allTableHTML.json
                      19M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.90ec613a.js.map
                      19M     /opt/iobroker/iobroker-data/files/eventlist.admin/static/js/main.90ec613a.js.map
                      *** NodeJS-Installation ***
                      /usr/bin/npm            8.19.3
                      /usr/bin/npx            8.19.3
                      nodejs:
                        Installed: 16.19.1-deb-1nodesource1
                        Candidate: 16.19.1-deb-1nodesource1
                        Version table:
                       *** 16.19.1-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                           10.24.0~dfsg-1~deb10u3 500
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Core adapters versions
                      js-controller:  4.0.24
                      admin:          6.3.5
                      javascript:     6.1.4
                      Adapters from github:   2
                      Adapter State
                      + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
                        system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                      + system.adapter.eventlist.0              : eventlist             : raspberrypi                              -  enabled
                      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                      + system.adapter.hs100.0                  : hs100                 : raspberrypi                              -  enabled
                        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
                        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
                        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
                        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
                        system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              -  enabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
                        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
                        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
                      + system.adapter.km200.0                  : km200                 : raspberrypi                              -  enabled
                        system.adapter.kodi.0                   : kodi                  : raspberrypi                              - disabled, port: 9999
                        system.adapter.material.0               : material              : raspberrypi                              -  enabled
                        system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
                      + system.adapter.mihome.0                 : mihome                : raspberrypi                              -  enabled, port: 9898, bind: 0.0.0.0
                        system.adapter.mobile.0                 : mobile                : raspberrypi                              -  enabled
                      + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
                      + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
                        system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                      + system.adapter.parcel.0                 : parcel                : raspberrypi                              -  enabled
                        system.adapter.parcel.1                 : parcel                : raspberrypi                              - disabled
                      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
                      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 0
                      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                      + system.adapter.tr-064.2                 : tr-064                : raspberrypi                              -  enabled
                      + system.adapter.tr-064.3                 : tr-064                : raspberrypi                              -  enabled
                      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
                        system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
                        system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
                        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
                        system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              -  enabled
                        system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              -  enabled
                        system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
                        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
                        system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
                        system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
                        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              -  enabled
                        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              -  enabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
                        system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
                      + system.adapter.yamaha.0                 : yamaha                : raspberrypi                              -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      Stable (default): http://download.iobroker.net/sources-dist.json
                      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                      Installed ioBroker-Instances
                      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                      Adapter    "backitup"     : 2.5.12   , installed 2.5.12
                      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                      Adapter    "devices"      : 1.1.2    , installed 1.1.2
                      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                      Adapter    "history"      : 2.2.4    , installed 2.2.4
                      Adapter    "hs100"        : 2.1.2    , installed 2.1.2
                      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                      Adapter    "info"         : 1.9.19   , installed 1.9.19
                      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                      Adapter    "km200"        : 2.0.3    , installed 2.0.3
                      Adapter    "kodi"         : 2.0.9    , installed 2.0.9
                      Adapter    "material"     : 1.1.2    , installed 1.1.2
                      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                      Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
                      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                      Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                      Adapter    "musiccast"    : 0.1.5    , installed 0.1.5
                      Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
                      Adapter    "openweathermap": 0.3.3   , installed 0.3.3
                      Adapter    "parcel"       : 0.0.25   , installed 0.0.25
                      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                      Adapter    "tuya"         : 3.13.1   , installed 3.13.1
                      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                      Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
                      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                      Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
                      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                      Adapter    "worx"         : 2.0.3    , installed 2.0.3
                      Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
                      Objects and States
                      Objects:        9122
                      States:         7883
                      Hit:1 http://phoscon.de/apt/deconz buster InRelease
                      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                      Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
                      Reading package lists...
                      Pending Updates: 19
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       16023      360/deCONZ
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18049      793/sshd
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18680      368/cupsd
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       256704     16918/io.sonoff.0
                      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       19671      360/deCONZ
                      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       259235     17105/io.shelly.0
                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       255025     16085/iobroker.js-c
                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       253257     16085/iobroker.js-c
                      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          18102      782/vncserver-x11-c
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       253367     16153/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       258612     17400/io.web.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          18051      793/sshd
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18679      368/cupsd
                      tcp6       0      0 :::5900                 :::*                    LISTEN      0          18101      782/vncserver-x11-c
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19595      765/dhcpcd
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17575      524/cups-browsed
                      udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       264790     18509/io.musiccast.
                      udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       259101     16988/io.mihome.0
                      udp        0      0 192.168.178.200:5353    0.0.0.0:*                           1001       259649     16555/io.tr-064.2
                      udp        0      0 192.168.178.181:5353    0.0.0.0:*                           1001       259648     16555/io.tr-064.2
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17069      371/avahi-daemon: r
                      udp        0      0 0.0.0.0:56633           0.0.0.0:*                           108        17071      371/avahi-daemon: r
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       264550     18439/io.deconz.0
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       264547     18439/io.deconz.0
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       19676      360/deCONZ
                      udp6       0      0 :::546                  :::*                                0          19615      765/dhcpcd
                      udp6       0      0 :::49757                :::*                                108        17072      371/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                108        17070      371/avahi-daemon: r
                      udp6       0      0 :::1900                 :::*                                1001       264552     18439/io.deconz.0
                      udp6       0      0 :::1900                 :::*                                1001       264551     18439/io.deconz.0
                      udp6       0      0 :::1900                 :::*                                1001       264549     18439/io.deconz.0
                      udp6       0      0 :::1900                 :::*                                1001       264548     18439/io.deconz.0
                      2023-03-27 12:31:41.512  - info: sql.0 (10244) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.500  - info: parcel.0 (12913) Got terminate signal TERMINATE_YOURSELF
                      2023-03-27 12:31:41.517  - info: shelly.0 (11439) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.517  - info: eventlist.0 (12907) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.522  - info: vis-inventwo.0 (11855) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.523  - info: octoprint.0 (12721) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.491  - info: discovery.0 (11502) Got terminate signal TERMINATE_YOURSELF
                      2023-03-27 12:31:41.521  - info: tr-064.3 (11475) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.524  - info: parcel.0 (12913) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.530  - info: km200.0 (12347) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.532  - info: mihome.0 (11178) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.534  - info: discovery.0 (11502) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.535  - info: deconz.0 (12614) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.535  - info: tankerkoenig.0 (12872) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.542  - info: info.0 (11523) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.551  - info: trashschedule.0 (12637) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.552  - info: admin.0 (9979) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.551  - info: tr-064.2 (10531) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.554  - info: mihome-vacuum.0 (10545) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.557  - info: backitup.0 (12728) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.639  - info: web.0 (11598) terminated http server on port 8082
                      2023-03-27 12:31:41.642  - info: history.0 (10119) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.673  - info: web.0 (11598) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.753  - info: ping.0 (10398) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2023-03-27 12:31:41.773  - info: telegram.0 (9631) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        @vandura
                        VanduraV Offline
                        VanduraV Offline
                        Vandura
                        • VanduraV Vandura
                          @vandura
                          Keine Bildchens...
                          ls -lAh /var/log
                          • VanduraV Offline
                            VanduraV Offline
                            Vandura
                            @thomas-braun sagte in Iobroker Absturz:
                            @vandura
                            Keine Bildchens...
                            ls -lAh /var/log
                            pi@raspberrypi:/var $ ls -lAh /var/log
                            total 419G
                            -rw-r--r-- 1 root root    0 Dec 27 00:00 alternatives.log
                            -rw-r--r-- 1 root root 3.3K Dec 26 12:28 alternatives.log.1
                            -rw-r--r-- 1 root root  108 Sep 24  2022 alternatives.log.2.gz
                            -rw-r--r-- 1 root root  682 Jun 22  2022 alternatives.log.3.gz
                            -rw-r--r-- 1 root root  108 Nov 18  2021 alternatives.log.4.gz
                            -rw-r--r-- 1 root root  168 Apr 25  2021 alternatives.log.5.gz
                            -rw-r--r-- 1 root root  214 Mar  5  2021 alternatives.log.6.gz
                            -rw-r--r-- 1 root root  232 Aug 17  2020 alternatives.log.7.gz
                            drwxr-xr-x 2 root root 4.0K Feb 19 00:00 apt
                            -rw-r----- 1 root adm   76K Mar 27 14:25 auth.log
                            -rw-r----- 1 root adm   34K Mar 25 23:17 auth.log.1
                            -rw-r----- 1 root adm  2.0K Mar 19 00:17 auth.log.2.gz
                            -rw-r----- 1 root adm  2.1K Mar 12 00:17 auth.log.3.gz
                            -rw-r----- 1 root adm  2.5K Mar  4 23:17 auth.log.4.gz
                            -rw-r--r-- 1 root root    0 May 27  2020 bootstrap.log
                            -rw-rw---- 1 root utmp    0 Mar  1 00:00 btmp
                            -rw-rw---- 1 root utmp    0 Feb  1 00:00 btmp.1
                            drwxr-xr-x 2 root root 4.0K Mar 27 00:00 cups
                            -rw-r----- 1 root adm  3.9M Mar 27 14:39 daemon.log
                            -rw-r----- 1 root adm   28M Mar 26 00:00 daemon.log.1
                            -rw-r----- 1 root adm  1.3M Mar 19 01:10 daemon.log.2.gz
                            -rw-r----- 1 root adm  1.1M Mar 12 00:55 daemon.log.3.gz
                            -rw-r----- 1 root adm  1.3M Mar  5 00:00 daemon.log.4.gz
                            -rw-r----- 1 root adm   13K Mar 27 11:28 debug
                            -rw-r----- 1 root adm  1.9K Mar 26 17:43 debug.1
                            -rw-r----- 1 root adm   615 Mar  8 17:47 debug.2.gz
                            -rw-r----- 1 root adm   611 Feb 22 16:20 debug.3.gz
                            -rw-r----- 1 root adm    87 Feb 18 13:33 debug.4.gz
                            -rw-r--r-- 1 root root    0 Feb 19 00:00 dpkg.log
                            -rw-r--r-- 1 root root  13K Feb 18 13:33 dpkg.log.1
                            -rw-r--r-- 1 root root  508 Sep 18  2021 dpkg.log.10.gz
                            -rw-r--r-- 1 root root 2.9K Apr 25  2021 dpkg.log.11.gz
                            -rw-r--r-- 1 root root 6.0K Mar  5  2021 dpkg.log.12.gz
                            -rw-r--r-- 1 root root 4.5K Dec 26 12:28 dpkg.log.2.gz
                            -rw-r--r-- 1 root root 4.0K Sep 24  2022 dpkg.log.3.gz
                            -rw-r--r-- 1 root root 5.0K Jun 22  2022 dpkg.log.4.gz
                            -rw-r--r-- 1 root root 1023 Feb 21  2022 dpkg.log.5.gz
                            -rw-r--r-- 1 root root 1.6K Jan  1  2022 dpkg.log.6.gz
                            -rw-r--r-- 1 root root 8.6K Nov 18  2021 dpkg.log.7.gz
                            -rw-r--r-- 1 root root 2.0K Oct 13  2021 dpkg.log.8.gz
                            -rw-r--r-- 1 root root  211 Oct 10  2021 dpkg.log.9.gz
                            -rw-r--r-- 1 root root  24K Nov 18  2021 faillog
                            -rw-r--r-- 1 root root 2.2K Nov 18  2021 fontconfig.log
                            -rw-r----- 1 root adm  206G Mar 27 11:28 kern.log
                            -rw-r----- 1 root adm   465 Mar 25 16:42 kern.log.1
                            -rw-r----- 1 root adm   135 Mar 16 10:54 kern.log.2.gz
                            -rw-r----- 1 root adm  4.2G Mar  8 17:47 kern.log.3.gz
                            -rw-r----- 1 root adm  3.4G Mar  7 09:53 kern.log.4.gz
                            -rw-rw-r-- 1 root utmp 286K Mar 27 14:12 lastlog
                            -rw-r----- 1 root adm  375K Mar 27 11:28 messages
                            -rw-r----- 1 root adm  4.3K Mar 26 00:00 messages.1
                            -rw-r----- 1 root adm   299 Mar 19 00:00 messages.2.gz
                            -rw-r----- 1 root adm   28K Mar 12 00:00 messages.3.gz
                            -rw-r----- 1 root adm   304 Mar  5 00:00 messages.4.gz
                            drwx------ 2 root root 4.0K May 27  2020 private
                            -rw-r--r-- 1 root root   66 Aug 16  2020 rpi-clone.log
                            -rw-r----- 1 root adm   47G Mar 27 14:39 syslog
                            -rw-r----- 1 root adm  160G Mar 27 00:00 syslog.1
                            -rw-r----- 1 root adm  178K Mar 26 00:00 syslog.2.gz
                            -rw-r----- 1 root adm  175K Mar 25 00:00 syslog.3.gz
                            -rw-r----- 1 root adm  178K Mar 24 00:00 syslog.4.gz
                            -rw-r----- 1 root adm  177K Mar 23 00:01 syslog.5.gz
                            -rw-r----- 1 root adm  177K Mar 22 00:00 syslog.6.gz
                            -rw-r----- 1 root adm  178K Mar 21 00:00 syslog.7.gz
                            -rw-r----- 1 root adm   42K Mar 27 11:28 user.log
                            -rw-r----- 1 root adm  3.1K Mar 26 00:00 user.log.1
                            -rw-r----- 1 root adm   173 Mar 19 00:00 user.log.2.gz
                            -rw-r----- 1 root adm  2.9K Mar 12 00:00 user.log.3.gz
                            -rw-r----- 1 root adm   177 Mar  5 00:00 user.log.4.gz
                            -rw------- 1 root root  12K Mar 27 11:28 vncserver-x11.log
                            -rw------- 1 root root  12K Mar 27 11:28 vncserver-x11.log.bak
                            -rw-rw-r-- 1 root utmp 584K Mar 27 14:12 wtmp
                            • VanduraV Vandura
                              @vandura
                              Keine Bildchens...
                              ls -lAh /var/log
                              total 419G
                              Da hast du deine dicken Dinger:
                              Musste halt mal reinschauen, was da gerade los ist.
                              tail -n 100 /var/log/kern.log
                              • VanduraV Vandura
                                @vandura
                                Keine Bildchens...
                                ls -lAh /var/log
                                total 419G
                                Und ein vncserver-x11.log darf da auch nicht existieren, ganz einfach weil man kein X11 und auch kein VNC auf einem Server laufen lässt.
                                VanduraV 2 Antworten Letzte Antwort
                                  VanduraV Offline
                                  VanduraV Offline
                                  Vandura
                                  pi@raspberrypi:/var $ tail -n 100 /var/log/kern.log
                                  Mar 27 11:28:16 raspberrypi kernel: [    3.253047]     HOME=/
                                  Mar 27 11:28:16 raspberrypi kernel: [    3.253061]     TERM=linux
                                  Mar 27 11:28:16 raspberrypi kernel: [    3.376336] usb 1-1.4: USB disconnect, device number 3
                                  Mar 27 11:28:16 raspberrypi kernel: [    3.674376] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
                                  Mar 27 11:28:16 raspberrypi kernel: [    3.812994] usb 1-1.4: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
                                  Mar 27 11:28:16 raspberrypi kernel: [    3.813042] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                  Mar 27 11:28:16 raspberrypi kernel: [    3.813078] usb 1-1.4: Product: ConBee II
                                  Mar 27 11:28:16 raspberrypi kernel: [    3.813108] usb 1-1.4: Manufacturer: dresden elektronik ingenieurtechnik GmbH
                                  Mar 27 11:28:16 raspberrypi kernel: [    3.813140] usb 1-1.4: SerialNumber: DE2218695
                                  Mar 27 11:28:16 raspberrypi kernel: [    4.676546] NET: Registered protocol family 10
                                  Mar 27 11:28:16 raspberrypi kernel: [    4.677949] Segment Routing with IPv6
                                  Mar 27 11:28:16 raspberrypi kernel: [    6.562991] random: systemd: uninitialized urandom read (16 bytes read)
                                  Mar 27 11:28:16 raspberrypi kernel: [    6.590967] random: systemd: uninitialized urandom read (16 bytes read)
                                  Mar 27 11:28:16 raspberrypi kernel: [    6.592359] random: systemd: uninitialized urandom read (16 bytes read)
                                  Mar 27 11:28:16 raspberrypi kernel: [    7.216983] usb 1-1.4: USB disconnect, device number 4
                                  Mar 27 11:28:16 raspberrypi kernel: [    7.524380] usb 1-1.4: new full-speed USB device number 5 using xhci_hcd
                                  Mar 27 11:28:16 raspberrypi kernel: [    7.663063] usb 1-1.4: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
                                  Mar 27 11:28:16 raspberrypi kernel: [    7.663087] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                  Mar 27 11:28:16 raspberrypi kernel: [    7.663105] usb 1-1.4: Product: ConBee II
                                  Mar 27 11:28:16 raspberrypi kernel: [    7.663122] usb 1-1.4: Manufacturer: dresden elektronik ingenieurtechnik GmbH
                                  Mar 27 11:28:16 raspberrypi kernel: [    7.663139] usb 1-1.4: SerialNumber: DE2218695
                                  Mar 27 11:28:16 raspberrypi kernel: [    8.694377] EXT4-fs (sda2): re-mounted. Opts: (null)
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.113741] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.116142] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.116775] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.117383] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.258105] mc: Linux media interface: v0.10
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.273992] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.358164] videodev: Linux video capture interface: v2.00
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.435146] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.437435] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.437459] [vc_sm_connected_init]: start
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.438512] [vc_sm_connected_init]: installed successfully
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.438883] bcm2835_audio bcm2835_audio: card created with 8 channels
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.609786] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.611221] usbcore: registered new interface driver cdc_acm
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.611239] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.741564] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.741600] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.755577] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                                  Mar 27 11:28:16 raspberrypi kernel: [   10.962973] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.055770] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.068646] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.071775] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.071782] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.072744] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.073083] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.073112] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.073137] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.073160] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.073183] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.073425] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.083601] [drm] No displays found. Consider forcing hotplug if HDMI is attached
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.083726] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.095958] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.096494] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.096538] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.098385] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.103345] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.103390] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.108197] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.108259] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.126548] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.126596] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.157030] random: crng init done
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.157058] random: 7 urandom warning(s) missed due to ratelimiting
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.168321] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.314650] sd 0:0:0:0: Attached scsi generic sg0 type 0
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.410389] brcmfmac: F1 signature read @0x18000000=0x15264345
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.418858] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                  Mar 27 11:28:16 raspberrypi kernel: [   11.419550] usbcore: registered new interface driver brcmfmac
                                  Mar 27 11:28:16 raspberrypi kernel: [   12.993487] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                  Mar 27 11:28:16 raspberrypi kernel: [   12.993606] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                  Mar 27 11:28:16 raspberrypi kernel: [   13.043682] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                                  Mar 27 11:28:16 raspberrypi kernel: [   16.685590] uart-pl011 fe201000.serial: no DMA platform data
                                  Mar 27 11:28:17 raspberrypi kernel: [   17.934114] 8021q: 802.1Q VLAN Support v1.8
                                  Mar 27 11:28:20 raspberrypi kernel: [   21.187493] exfat: Deprecated parameter 'utf8'
                                  Mar 27 11:28:20 raspberrypi kernel: [   21.187540] /dev/sda1: Can't open blockdev
                                  Mar 27 11:28:24 raspberrypi kernel: [   25.312183] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                                  Mar 27 11:28:25 raspberrypi kernel: [   25.665358] Bluetooth: Core ver 2.22
                                  Mar 27 11:28:25 raspberrypi kernel: [   25.665455] NET: Registered protocol family 31
                                  Mar 27 11:28:25 raspberrypi kernel: [   25.665470] Bluetooth: HCI device and connection manager initialized
                                  Mar 27 11:28:25 raspberrypi kernel: [   25.665974] Bluetooth: HCI socket layer initialized
                                  Mar 27 11:28:25 raspberrypi kernel: [   25.665995] Bluetooth: L2CAP socket layer initialized
                                  Mar 27 11:28:25 raspberrypi kernel: [   25.666027] Bluetooth: SCO socket layer initialized
                                  Mar 27 11:28:25 raspberrypi kernel: [   25.792451] Bluetooth: HCI UART driver ver 2.3
                                  Mar 27 11:28:25 raspberrypi kernel: [   25.792469] Bluetooth: HCI UART protocol H4 registered
                                  Mar 27 11:28:25 raspberrypi kernel: [   25.792546] Bluetooth: HCI UART protocol Three-wire (H5) registered
                                  Mar 27 11:28:25 raspberrypi kernel: [   25.792788] Bluetooth: HCI UART protocol Broadcom registered
                                  Mar 27 11:28:25 raspberrypi kernel: [   26.024737] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                                  Mar 27 11:28:25 raspberrypi kernel: [   26.025106] bcmgenet fd580000.ethernet eth0: Link is Down
                                  Mar 27 11:28:26 raspberrypi kernel: [   26.844353] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
                                  Mar 27 11:28:27 raspberrypi kernel: [   27.465190] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                  Mar 27 11:28:27 raspberrypi kernel: [   27.465206] Bluetooth: BNEP filters: protocol multicast
                                  Mar 27 11:28:27 raspberrypi kernel: [   27.465230] Bluetooth: BNEP socket layer initialized
                                  Mar 27 11:28:28 raspberrypi kernel: [   29.124495] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                                  Mar 27 11:28:28 raspberrypi kernel: [   29.124525] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                                  Mar 27 11:28:30 raspberrypi kernel: [   31.036764] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                                  Mar 27 11:28:30 raspberrypi kernel: [   31.159329] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                                  Mar 27 11:28:31 raspberrypi kernel: [   31.834348] vcc-sd: disabling
                                  • VanduraV Vandura
                                    Um 11:28 gab es offenbar einen Reboot.
                                      VanduraV Offline
                                      VanduraV Offline
                                      Vandura
                                      Weiß noch nicht mal was das ist......
                                      • VanduraV Vandura
                                        @vandura
                                        Ich würde mir mein Backup vom iobroker schnappen und die Kiste neu und gescheit (d. h. OHNE Desktop und VNC und so 'nem Kram) aufsetzen.
                                          VanduraV Offline
                                          VanduraV Offline
                                          Vandura
                                          das war ich selbst
