  3. Entwicklung
  4. [Neuer Adapter] Reolink Kamera
reolinkneuer adaptertestenkamera
1.1k Beiträge 166 Kommentatoren 679.5k Aufrufe 146 Beobachtet
  • M michihorn
    Hallo habe heute im ferienhaus eine E1 Outdoor installiert. Leider klappt es zu Hause nicht mit dem Adapter. Folgendes steht im Log:
    reolink.0
    2023-03-21 22:02:59.100	error	Error: connect EHOSTUNREACH 192.168.xxx.249:443: EHOSTUNREACH
    reolink.0
    2023-03-21 22:02:53.771	silly	States system redis pmessage system.adapter.reolink.0.logLevel/system.adapter.reolink.0.logLevel:{"val":"silly","ack":true,"ts":1679432573639,"q":0,"from":"system.adapter.reolink.0","lc":1679432506968}
    reolink.0
    2023-03-21 22:02:53.631	info	Current IP: 192.168.xxx.249
    reolink.0
    2023-03-21 22:02:53.626	info	Reolink adapter has started
    reolink.0
    2023-03-21 22:02:53.540	info	starting. Version 0.1.1 (non-npm: aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1) in /opt/iobroker/node_modules/iobroker.reolink, node: v18.12.0, js-controller: 4.0.24
    reolink.0
    2023-03-21 22:02:49.183	silly	statesDB connected
    reolink.0
    2023-03-21 22:02:49.181	debug	States connected to redis: 127.0.0.1:9000
    reolink.0
    2023-03-21 22:02:49.006	debug	States create User PubSub Client
    reolink.0
    2023-03-21 22:02:49.005	debug	States create System PubSub Client
    reolink.0
    2023-03-21 22:02:48.940	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    reolink.0
    2023-03-21 22:02:48.937	silly	objectDB connected
    reolink.0
    2023-03-21 22:02:48.931	silly	redis psubscribe cfg.o.enum.*
    reolink.0
    2023-03-21 22:02:48.842	silly	redis psubscribe cfg.o.system.user.*
    reolink.0
    2023-03-21 22:02:48.839	debug	Objects connected to redis: 127.0.0.1:9001
    reolink.0
    2023-03-21 22:02:48.830	debug	Objects client initialize lua scripts
    reolink.0
    2023-03-21 22:02:48.556	debug	Objects create User PubSub Client
    reolink.0
    2023-03-21 22:02:48.554	debug	Objects create System PubSub Client
    reolink.0
    2023-03-21 22:02:48.552	debug	Objects client ready ... initialize now
    reolink.0
    2023-03-21 22:02:48.427	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    Wo bin ich falsch abgebogen?
    Was muss ich bei Kanal eintragen?
    Gruß Michael
    skvarelS Online
    skvarelS Online
    skvarel
    schrieb am zuletzt editiert von skvarel
    #412
    @michihorn sagte in [Neuer Adapter] Reolink Kamera:
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    reolink.0
    Gruß Michael
    .. alle Ports in der Browseransicht aktiviert?
    Die E1 Outdoor läuft auf jeden Fall mit dem Adapter
    #TeamInventwo
    Unsere Adapter:
    Michael SchumannM 1 Antwort Letzte Antwort
    • T Tobi68
      @skvarel sagte in [Neuer Adapter] Reolink Kamera:
      Ich bin jetzt zu dem Entschluss gekommen, auf motionEye verzichten zu wollen.
      Ich habe aber jetzt auch das Problem, dass sich das Image Widget nicht aktualisiert. Standbild klappt, mehr aber auch nicht.
      @spanier .. hattest du eine Lösung gefunden? Ich habe genau das selbe Problem.
      EDIT: Jetzt läuft es! Kürzer als 300ms geht halt nicht. Damit kann ich aber leben.
      Wenn man jetzt noch die Bewegungserkennung bzw. den Upload über den Adapter stoppen könnte, wäre es super :)
      Sag mal wie und bei welcher cam!
      Ich musste mit einer Cam auch über Motioneye gehen und möchte davon weg.
      skvarelS Online
      skvarelS Online
      skvarel
      #413
      @tobi68 sagte in [Neuer Adapter] Reolink Kamera:
      Zur Zeit habe ich die E1 Outdoor und die RLC-410W im Reolink Adapter. Weitere Kameras kommen im Laufe des Jahres.
      Mit der IP über einen Browser einloggen und dann in den Network Settings alle Ports aktivieren.
      #TeamInventwo
      Unsere Adapter:
      • T Tobi68
        @skvarel
        Zeig mal bitte!
        Ich finde eure Widgets wirklich sehr toll, sind aber durch die Universalität recht komplex geworden
        Ich mache es jetzt so.. würde es aber eigentlich besser finden wenn ich direkt wenn ich das Ikon gedrückt habe schon ein feedback bekomme das es auch wirklich geschaltet ist, die Kamera/Adapter haben 1-2 sec. Verzögerung bis sich was bewegt..
        skvarelS Online
        skvarelS Online
        skvarel
        #414
        @skvarel
        Zeig mal bitte!
        Ich nutze unsere Radio-Buttons. Die Presets werden über die ID angesteuert. 1 = erstes Preset, 2 = zweites Preset usw.
        Feedback können unsrer Widgets aber auch. Einfach hier 500 (oder mehr) eintragen
        #TeamInventwo
        Unsere Adapter:
        • T Tobi68
          skvarelS Online
          skvarelS Online
          skvarel
          #415
          ... Image Widget mit 300ms Aktualisierung
          #TeamInventwo
          Unsere Adapter:
          H 1 Antwort Letzte Antwort
          • skvarelS Online
            skvarelS Online
            skvarel
            #416
            Die Aufnahmen kann ich jetzt auch per VIS, Script und Sprache steuern ;)
            Ich de- und aktiviere einfach den ftp-User über einer Userliste. Dazu überschreibe ich die User einfach per Ll8inux-Control Adapter.
            Jede Kamera hat einen eigen ftp Zugang. Durch ein Hinzufügen oder Löschen eines Useres in der vsftpd.user_list kann die Kamera entweder speichern oder eben nicht ;)
            #TeamInventwo
            Unsere Adapter:
            • skvarelS skvarel
              hansmeier
              #417
              Im Edit VIS Fenster habe sehe ich meine RLC-811A auch noch wunderbar. Jedoch in der View auf Tablett oder Browser sehe ich nur noch ein kleines blinkendes Grafik-Symbol.
              was mache ich falsch mit dem Image - Widget ?
              T skvarelS 2 Antworten Letzte Antwort
              • H hansmeier
                Tobi68
                #418
                @hansmeier
                Das Problem kenne ich, aber auch manchmal umgekehrt!
                Ist immer sehr mühselig mit den Streams, von Kamera zu Kamera verschieden.
                Manchmal muss ich auch über den Stream meiner Synology gehen..
                Motioneye habe ich mal abgeschaltet, darüber gehts auch. Ist aber noch komplexer in der Einrichtung.. hab mir diese 40Watt jetzt mal gespart..
                • T Tobi68
                  @hansmeier
                  hansmeier
                  #419
                  @tobi68 Normalerweise mache ich das auch über MotionEye, jedoch max. der Substream kommt da ohne viel Verzögerung in der VIS an.
                  ich habe gehofft, mit diesem Widget auf den Main-Stream zugreifen zu können.
                    Tobi68
                    #420
                    @hansmeier
                    @skvarel
                    Ihr seit wohl etwas fitter mit Cams in der Vis als ich..
                    Jetzt habe ich mir irgenwie was verfummelt was mal ging..
                    Was steuere ich mit dieser updatezeit 500ms?
                    Ich bekomme derzeit zwar in der Vis ein Bild angezeigt wenn ich aber über ein Button den anderen PTZ Punkt anfahre, macht die Kamera das zwar, zeigt es aber nicht in der Vis an, auch nicht nach nach zwei Minuten, nur wenn ich nen Browser refresh mache..
                    • T Tobi68
                      @hansmeier
                      @skvarel
                      BananaJoeB Offline
                      BananaJoeB Offline
                      BananaJoe
                      #421
                      Wie oft du ein neues Bild holst.
                      500ms ist etwas viel, teste mal mit 3 Sekunden / 3.000ms und dann kannst du langsam runter gehen und schauen was er schafft
                      • BananaJoeB BananaJoe
                        Tobi68
                        #422
                        @bananajoe
                        das ist ja Problem..
                        da passiert in der VIS nichts.. nur beim Browser refresh..
                        Die Kamera schwenkt das sehe ich in der app..
                        • T Tobi68
                          @bananajoe
                          BananaJoeB Offline
                          BananaJoeB Offline
                          BananaJoe
                          #423
                          @tobi68 also, ich hole mir als Hintergrundbild mit folgender URL von meiner RLC-510A ein Bild:
                          http://192.168.1.225/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=admin&password=test1234
                          rs war meine ich ein zufälliger Wert.
                          Und das aktualisiere ich alle 60.000ms und das funktioniert (sehe ich am Zeitstempel im Bild)
                          • skvarelS skvarel
                            nik82N Offline
                            nik82N Offline
                            nik82
                            #424
                            Bei mir läufts super mit 500ms.
                            Bei 300ms habe ich zwar auch noch ein Bild, aber dann sieht man das immer mal wieder eine Sekunde übersprungen wird, es werden also Bilder verschluckt, bei mir ist es mit 500ms flüssiger wie mit 300ms und hatte noch keinerlei Bildausfälle.
                            P.S. Habe eine Trackmix und Unifi 6 Pro Accesspoints.
                              Tobi68
                              #425
                              @bananajoe
                              Ich verstehe es einfach nicht.. bei mir wird hier gar nichts aktualisiert..
                              Ist eine 823, hängt am Lan, genau die der IOBroker
                              Denke eher wir Reden irgendwie aneinander vorbei:
                              Basic - Image:
                              http://192.168.178.131/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=123456789&user=NAS&password=Pass4NAS
                              nik82N skvarelS 2 Antworten Letzte Antwort
                              • T Tobi68
                                @bananajoe
                                Basic - Image:
                                nik82N Offline
                                nik82N Offline
                                nik82
                                #426
                                @tobi68
                                Häng hinten mal die breite und höhe an:
                                http://192.168.1.2/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=952700014VWK6CKG&user=admin&password=xxx&width=1920&height=1080
                                • nik82N nik82
                                  @tobi68
                                  Tobi68
                                  #427
                                  @nik82
                                  Habe ich gemacht, ändert aber nichts.
                                  Bild wird nur nach Browser Refresh aktualisiert
                                  nik82N 1 Antwort Letzte Antwort
                                  • T Tobi68
                                    @nik82
                                    nik82N Offline
                                    nik82N Offline
                                    nik82
                                    #428
                                    @tobi68
                                    Ja dann passts doch, mach doch mal die Update zeit oben auf 1000ms.
                                    So wie du es eingestellt hast wird ja nur alle paar minuten aktualisiert.
                                    • nik82N nik82
                                      @tobi68
                                      Tobi68
                                      schrieb am zuletzt editiert von Tobi68
                                      #429
                                      @nik82 sagte in [Neuer Adapter] Reolink Kamera:
                                      @tobi68
                                      Nein passt nicht, auch bei 1000ms kommt nichts..
                                      Ich sehe aber gerade das ich bei einer Foscam, die ich über die Synology reinholen musste, es Tip Top funzt.
                                      Dort habe ich ein anders Wiget benutzt..
                                      Das wird halt im editor nicht angezeigt aber nach in der visu schon..🙃
                                      <img src={synology.0.SurveillanceStation.cameras.Foscam.linkMjpegHttpPath} width="100%" height="100%">
                                      wie würde das HTML hier für meine Reo aussehen?
                                      • skvarelS Online
                                        skvarelS Online
                                        skvarel
                                        #430
                                        ACHTUNG ...., dieser Haken MUSS raus!
                                        Es wird ein Token an die URL gehängt. Wenn man das mit dem Haken unterbindet gibt es keinen Refresh!
                                        #TeamInventwo
                                        Unsere Adapter:
                                        • H hansmeier
                                          skvarelS Online
                                          skvarelS Online
                                          skvarel
                                          #431
                                          @hansmeier sagte in [Neuer Adapter] Reolink Kamera:
                                          ... die Update-Zeit zu kurz gewählt? Unter 350ms klappt es bei mir nicht!
                                          #TeamInventwo
                                          Unsere Adapter:
