  4. IoBroker auf Raspberry Pi 1B?
20 Beiträge 6 Kommentatoren 10.5k Aufrufe 1 Beobachtet
  • X Offline
    X Offline
    xelarep
    Irgendwie klappt es nicht :( Ich hab heute nochmal ein frisches Raspbian Jessie Lite aufgesetzt (inkl. root per SSH, alt-get update&upgrade) und dann erst mal ein Image gezogen.
    1. Versuch node 6.10.0 installiert, iobroker Installation gestartet - nach knapp 1h Abbruch mit
    ! root@flexo:/opt/iobroker# npm install iobroker
    ! > iobroker@0.7.1 install /opt/iobroker/node_modules/iobroker
    ! > node lib/setup.js
    ! npm install iobroker.js-controller –production --prefix /opt/iobroker
    ! npm WARN deprecated letsencrypt@2.1.8: letsencrypt has been renamed to greenlock. Please find it at npm greenlock
    ! npm WARN deprecated localhost.daplie.com-certificates@1.2.5: Moved to localhost.daplie.me-certificates
    ! module.js:96
    ! throw e;
    ! SyntaxError: Error parsing /opt/iobroker/node_modules/load-json-file/package.json: Unexpected token
    ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
    ! npm WARN iobroker No description
    ! npm WARN iobroker No repository field.
    ! npm WARN iobroker No README data
    ! npm WARN iobroker No license field.
    ! npm ERR! Linux 4.4.38+
    ! npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production" "--prefix" "/opt/iobroker"
    ! npm ERR! node v6.10.0
    ! npm ERR! npm v3.10.10
    ! npm ERR! code ELIFECYCLE
    ! npm ERR! iobroker.js-controller@0.15.3 install: node lib/setup.js setup first
    ! npm ERR! Exit status 1
    ! npm ERR!
    ! npm ERR! Failed at the iobroker.js-controller@0.15.3 install script 'node lib/setup.js setup first'.
    ! npm ERR! Make sure you have the latest version of node.js and npm installed.
    ! npm ERR! If you do, this is most likely a problem with the iobroker.js-controller package,
    ! npm ERR! not with npm itself.
    ! npm ERR! Tell the author that this fails on your system:
    ! npm ERR! node lib/setup.js setup first
    ! npm ERR! You can get information on how to open an issue for this project with:
    ! npm ERR! npm bugs iobroker.js-controller
    ! npm ERR! Or if that isn't available, you can get their info via:
    ! npm ERR! npm owner ls iobroker.js-controller
    ! npm ERR! There is likely additional logging output above.
    ! npm ERR! Please include the following file with any support request:
    ! npm ERR! /opt/iobroker/node_modules/iobroker/npm-debug.log
    ! npm ERR! code 1
    ! Cannot install as normal user. Try sudo...
    ! sudo npm install iobroker.js-controller --production --prefix /opt/iobroker
    ! /opt/iobroker/node_modules/nan/include_dirs.js:2
    ! SyntaxError: Invalid or unexpected token
    ! at Object.exports.runInThisContext (vm.js:76:16)
    ! at Module._compile (module.js:542:28)
    ! at Object.Module._extensions..js (module.js:579:10)
    ! at Module.load (module.js:487:32)
    ! at tryModuleLoad (module.js:446:12)
    ! at Function.Module._load (module.js:438:3)
    ! at Module.require (module.js:497:17)
    ! at require (internal/module.js:20:19)
    ! at [eval]:1:1
    ! at ContextifyScript.Script.runInThisContext (vm.js:25:33)
    ! gyp: Call to 'node -e "require('nan')"' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    ! gyp ERR! configure error
    ! gyp ERR! stack Error: gyp failed with exit code: 1
    ! gyp ERR! stack at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:305:16)
    ! gyp ERR! stack at emitTwo (events.js:106:13)
    ! gyp ERR! stack at ChildProcess.emit (events.js:191:7)
    ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
    ! gyp ERR! System Linux 4.4.38+
    ! gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! gyp ERR! cwd /opt/iobroker/node_modules/ursa
    ! gyp ERR! node -v v6.10.0
    ! gyp ERR! node-gyp -v v3.4.0
    ! gyp ERR! not ok
    ! /opt/iobroker/node_modules/engine.io-parser/index.js:3
    ! Takes the same argu
    ! SyntaxError: Unexpected identifier
    ! at Object. <anonymous>(/opt/iobroker/node_modules/engine.io-client/lib/transport.js:5:14)
    ! at Module._compile (module.js:570:32)
    ! npm WARN Failed to parse json
    ! npm WARN Unexpected token ' ' at 22:27
    ! npm WARN "host": "pacegistry')
    ! npm WARN ^
    ! npm WARN File: /opt/iobroker/node_modules/graceful-fs/package.json
    ! npm WARN Unexpected control character at 22:21
    ! npm WARN "name": "sindresP�5 ! npm WARN ^ ! npm WARN File: /opt/iobroker/node_modules/load-json-file/package.json ! npm WARN iobroker No description ! npm WARN iobroker No repository field. ! npm WARN iobroker No README data ! npm WARN iobroker No license field. ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa@0.9.4 (node_modules/ursa): ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa@0.9.4 install: node-gyp rebuild! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1 ! npm ERR! Linux 4.4.38+ ! npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "–production" "--prefix" "/opt/iobroker" ! npm ERR! node v6.10.0 ! npm ERR! npm v3.10.10 ! npm ERR! code ELIFECYCLE ! npm ERR! iobroker.js-controller@0.15.3 install:node lib/setup.js setup first ! npm ERR! Exit status 1 ! npm ERR! ! npm ERR! Failed at the iobroker.js-controller@0.15.3 install script 'node lib/setup.js setup first'. ! npm ERR! Make sure you have the latest version of node.js and npm installed. ! npm ERR! If you do, this is most likely a problem with the iobroker.js-controller package, ! npm ERR! not with npm itself. ! npm ERR! Tell the author that this fails on your system: ! npm ERR! node lib/setup.js setup first ! npm ERR! You can get information on how to open an issue for this project with: ! npm ERR! npm bugs iobroker.js-controller ! npm ERR! Or if that isn't available, you can get their info via: ! npm ERR! npm owner ls iobroker.js-controller ! npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request: ! npm ERR! /opt/iobroker/node_modules/iobroker/npm-debug.log ! npm install iobroker.admin --production --prefix /opt/iobroker ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json' ! npm WARN Failed to parse json ! npm WARN Unexpected token ' ' at 22:27 ! npm WARN "host": "pacegistry') ! npm WARN ^ ! npm WARN File: /opt/iobroker/node_modules/graceful-fs/package.json ! npm WARN Failed to parse json ! npm WARN Unexpected control character at 22:21 ! npm WARN "name": "sindresP�5
    ! npm WARN ^
    ! Write "./iobroker start" to start the ioBroker
    ! Cannot set permissions of /opt/iobroker/node_modules/iobroker.js-controller/iobroker
    ! You can still manually copy
    ! /opt/iobroker/node_modules/iobroker/lib/../install/linux/install.sh: line 65: cd: /opt/iobroker/node_modules/iobroker.js-controller/: No such file or directory
    ! /opt/iobroker/node_modules/iobroker/lib/../install/linux/install.sh: line 67: ./iobroker: No such file or directory
    ! Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
    ! iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
    ! /opt/iobroker
    ! └─┬ iobroker@0.7.1
    ! └─┬ yargs@4.8.1
    ! ├─┬ cliui@3.2.0
    ! │ ├─┬ strip-ansi@3.0.1
    ! │ │ └── ansi-regex@2.1.1
    ! │ └── wrap-ansi@2.1.0
    ! ├── decamelize@1.2.0
    ! ├── get-caller-file@1.0.2
    ! ├── lodash.assign@4.2.0
    ! ├─┬ os-locale@1.4.0
    ! │ └─┬ lcid@1.0.0
    ! │ └── invert-kv@1.0.0
    ! ├─┬ read-pkg-up@1.0.1
    ! │ ├─┬ find-up@1.1.2
    ! │ │ ├── path-exists@2.1.0
    ! │ │ └─┬ pinkie-promise@2.0.1
    ! │ │ └── pinkie@2.0.4
    ! │ └─┬ read-pkg@1.1.0
    ! │ ├─┬ load-json-file@1.1.0
    ! │ │ ├── graceful-fs@4.1.11
    ! │ │ ├─┬ parse-json@2.2.0
    ! │ │ │ └─┬ error-ex@1.3.0
    ! │ │ │ └── is-arrayish@0.2.1
    ! │ │ ├── pify@2.3.0
    ! │ │ └─┬ strip-bom@2.0.0
    ! │ │ └── is-utf8@0.2.1
    ! │ ├─┬ normalize-package-data@2.3.5
    ! │ │ ├── hosted-git-info@2.2.0
    ! │ │ ├─┬ is-builtin-module@1.0.0
    ! │ │ │ └── builtin-modules@1.1.1
    ! │ │ ├── semver@5.3.0
    ! │ │ └─┬ validate-npm-package-license@3.0.1
    ! │ │ ├─┬ spdx-correct@1.0.2
    ! │ │ │ └── spdx-license-ids@1.2.2
    ! │ │ └── spdx-expression-parse@1.0.4
    ! │ └── path-type@1.1.0
    ! ├── require-directory@2.1.1
    ! ├── require-main-filename@1.0.1
    ! ├── set-blocking@2.0.0
    ! ├─┬ string-width@1.0.2
    ! │ ├── code-point-at@1.1.0
    ! │ └─┬ is-fullwidth-code-point@1.0.0
    ! │ └── number-is-nan@1.0.1
    ! ├── which-module@1.0.0
    ! ├── window-size@0.2.0
    ! ├── y18n@3.2.1
    ! └─┬ yargs-parser@2.4.1
    ! └── camelcase@3.0.0
    ! root@flexo:/opt/iobroker# iobroker restart
    ! module.js:471
    ! throw err;
    ! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    ! at Function.Module._resolveFilename (module.js:469:15)
    ! at Function.Module._load (module.js:417:25)
    ! at Module.runMain (module.js:604:10)
    ! at run (bootstrap_node.js:394:7)
    ! at startup (bootstrap_node.js:149:9)
    ! at bootstrap_node.js:509:3
    ! root@flexo:/opt/iobroker# poweroff</anonymous>
    2. Versuch. Zurück auf Image, node 4.8.0 installiert - Installation Biobroker gestartet - hier schon nach knapp 5 min Abbruch mit
    ! npm WARN cannot run in wd iobroker@0.7.1 node lib/setup.js (wd=/opt/iobroker/node_modules/iobroker)
    ! iobroker@0.7.1 node_modules/iobroker
    ! └── yargs@4.8.1 (get-caller-file@1.0.2, lodash.assign@4.2.0, decamelize@1.2.0, y18n@3.2.1, which-module@1.0.0, set-blocking@2.0.0, window-size@0.2.0, require-main-filename@1.0.1, require-directory@2.1.1, yargs-parser@2.4.1, cliui@3.2.0, string-width@1.0.2, os-locale@1.4.0, read-pkg-up@1.0.1)
    Was mach ich falsch?
    Ich installierte node als root wie folgt:
    wget https://nodejs.org/dist/v6.10.0/node-v6.10.0-linux-armv6l.tar.xz  (bzw. wget https://nodejs.org/download/release/v4.8.0/node-v4.8.0-linux-armv6l.tar.xz...)
    tar -xvf  node-v6.10.0-linux-armv6l.tar.xz
    cd node-v6.10.0-linux-armv6l
    cp -R * /usr/local/
    Ein node -v liefert die jeweils installierte Version.
    Danach erzeuge ich den iobroker Ordner und rufe per npm die Installation auf, also
    mkdir /opt/iobroker
    chmod 777 /opt/iobroker
    cd /opt/iobroker
    Alexander, etwas ratlos
      Jetzt liege ich schon im Bett. Werde das morgen aber testen.
      Hast du nodejs für Arm v6?
      • X Offline
        X Offline
        xelarep
        @Homoran:
        Hast du nodejs für Arm v6? `
        Ja, siehe oben ;-)
        • G Offline
          gst666
          Hatte auch das Problem. Habe mich dann für fertiges Image entschieden. Ist zwar keine Lösung aber Umgehung des Problems.
            @gst666:
            Hatte auch das Problem. Habe mich dann für fertiges Image entschieden. Ist zwar keine Lösung aber Umgehung des Problems. `
            Auf den Images ist aber node 0.1x.xx
            Ich habe es gerade nachvollzogen und es hat auf Anhieb geklappt ;-)
            ganz ehrlich - ich habe ein oder zwei Modifikationen eingebaut.
            Nicht dass ich wüsste was ich tue aber….
            Raspbian vom 11.01.2017 auf SD-Karte mit Win32Diskimager
            lokal am Pi in die Konsole eingeloggt und über sudo raspi-config
            • change user passwort (security issue)
            • Resize filesystem, auch wenn er das automatisch gemacht haben sollte
            • Internationalization alles bis auf WiFi geändert
            • advanced
              • Hostname geändert auf ioBroker-Pi1
              • SSH freigegeben.
            Raspi-config beendet, Raspi rebootet automatisch
            Jetzt über putty als user pi eingeloggt
            • sudo su
            Betriebssystem aktualisiert
            • apt-get update
            • apt-get upgrade
            • apt-get dist-upgrade
            • apt-get autoremove (da gab's nichts zu removen)
            node 6.10 installiert indem ich die verlinkte Anleitung nach Sichtung der Dateien bei http://nodejs.org/dist/latest-v6.x/ hierauf angepasst hatte:
            wget http://nodejs.org/dist/latest-v6.x/node-v6.10.0-linux-armv6l.tar.gz
            tar -xvf node-v6.10.0-linux-armv6l.tar.gz
            sudo cp -R * /usr/local/
            test mit node -v und npm -v ok!
            test mit nodejs -v jedoch negativ!
            Ob das jetzt notwendig war??? Ich weiß wie gesagt nicht was ich tue.
            der in der Anleitung angegebene Befehl zum Anlegen des symlinks
            sudo ln -s /usr/local/bin/nodejs /usr/bin/node
            brachte keine Besserung - also todesmutig den Link umgedreht:
            sudo ln -s /usr/local/bin/node /usr/bin/nodejs
            jetzt kam auch bei nodejs-v die richtige Version raus.
            Wie gesagt habe ich von Linux so wenig Ahnung, dass das alles unnötig sein könnte.
            Dann die übliche ioBroker Installation
            sudo mkdir /opt/iobroker
            sudo chmod 777 /opt/iobroker
            cd /opt/iobroker
            sudo npm install iobroker --unsafe-perm
            und voila unter <ip>:8081 ist der admin zu sehen:
            werde jetzt mal die wichtigsten Adapter installieren und dann versuchen daraus ein Image zu machen.
            Ist leider eine 16GB Karte, werde es daher erstmalig mit USB Image Tool versuchen, sonst muss ich auf dem üblichen Weg nochmal alles durchziehen.
            Rainer</ip>
            • X Offline
              X Offline
              xelarep
              Wahnsinn, man lernt doch jeden Tag was neues :shock:
              Ich hab's ausgehend von meinem bisherigen "up2date"-Raspian Image heute nochmal probiert, und mal die abweichenden Dinge beherzigt (speziell ln für nodejs setzen, –unsafe-perm). Dasselbe Spiel, über eine Stunde nix passiert - Abbruch. Während des Wartens hab ich noch ne zweite SD Karte aus meinem Foto mit dem o.g. Image betankt. Danach nochmal genau dasselbe mit dieser anderen SD Karte gemacht.
              Ne knappe halbe Stunde später war das Ding durch und - TADAA - ich bekomme die Konfigurationsseite!
              Sollte der ganze Zirkus an einer defekten SD Karte gelegen haben??? Wahnsinn!
              Jedenfalls nochmal herzlichen Dank an Homoran für den Parallelflug! Bin doch nicht zu blöd nen Raspberry aufzusetzen :lol:
              Ich geh jetzt ein Image ziehen und dann spielen :-)
              Alexander
                @xelarep:
                Ne knappe halbe Stunde später war das Ding durch und - TADAA - ich bekomme die Konfigurationsseite! `
                Glückwunsch!
                ich sitze jetzt seit 17:07 an dem zweiten Anlauf. Der erste war für ein Image zu groß.
                Da war ein Kernel Update das hat schon fast eine Stunde gedauert.
                Bin jetzt bei den letzten Adaptern.
                Dann kommt das Image auf die Website.
                • X Offline
                  X Offline
                  xelarep
                  Danke,
                  @Homoran:
                  @xelarep:
                  Ne knappe halbe Stunde später war das Ding durch und - TADAA - ich bekomme die Konfigurationsseite! Da war ein Kernel Update das hat schon fast eine Stunde gedauert.
                  Das Kernelupdate hatte ich glücklicherweise gestern schon erledigt - aber die Stunde kommt hin ;-)
                  Alexander
                    @all
                    Habe es jetzt endlich geschafft das Image auf die Downloadseite zu bringen.
                    Damit liegt da jetzt auch ein fertiges Image für den Pi1 mit nodejs 6.xx vor!
                    ich musste die Installation noch mal durchführen, dadurch hat es leider etwas länger gedauert.
                    • R Offline
                      RS_Tobi
                      Hallo Rainer,
                      es ist zwar etwas umständlich, da man die aktuelle Version immer von dem Link anpassen muss,
                      aber denkst du nicht auch, dass man deine aktuelle node Version mit auf die Anleitung auf der
                      IObroker Seite hinzufügen sollte?
                      Aber ich habe mich auch TODESMUTIG (so wie du) gewagt und habe bei meinem (schon konfigurierten) System
                      die node geupdated.
                      ich habe erst iobroker gestopt
                      (bei mir alles im root)
                      iobroker stop
                      dann die aktuelle node gelöscht
                      apt-get --purge remove node
                      apt-get --purge remove nodejs
                      apt-get autoremove
                      reboot
                      und danach habe ich wie du beschrieben hast
                      ! @Homoran:
                      jetzt kam auch bei nodejs-v die richtige Version raus. `
                      RESULTAT FUNKTIONIERT EINWANDFREI
                      grüße Tobi
                        Hast du auch den symlink anpassen müssen?
                        Wenn ja, hast du direkt den zweiten Versuch gemacht?
                        • R Offline
                          RS_Tobi
                          hi,
                          ich habe deinen link zu den Versionen geöffnet und die aktuelle 6.11.3 in den Befehlen abgeändert.
                          Funktionierte auf Anhieb.
                          Was meinst du mir zweiten Versuch?
                          mfg
                          • W Offline
                            W Offline
                            WowaDriver
                            Hallo Leute, habe versucht beide Versionen zum PI1 Image aus der Downloaddatenbank zu laden. Der link führt immer ins Nirvana... sprich Links sind tot. Wäre ein Reup möglich? Oder kann mir einer hier die Daten zur verfügung stellen?
                            Möchte für paar kleine Test auf einem alten PI das noch rumliegt eine ioBroker Instanz unabhängig von meiner Produktiv Lösung aufsetzen...
                            Besten Gruß und Danke!
