  4. IoBroker Stürt aus dem Nix ab
    5.5k
28 Beiträge 6 Kommentatoren 920 Aufrufe 4 Beobachtet
  • Horst BöttcherH Horst Böttcher
    @glasfaser sagte in IoBroker Stürt aus dem Nix ab:
    iob diag
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Architecture:   aarch64
    Docker:         false
    Virtualization: none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     21:00:36 up 3 days,  7:42,  3 users,  load average: 1.30, 0.77, 0.78
    CPU threads: 4
    *** Time and Time Zones ***
    Sat Mar  4 20:00:36 UTC 2023
    Sat Mar  4 21:00:36 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        2.9G        262M         35M        644M        796M
    Swap:            99M         99M        0.0K
    Total:          3.9G        3.0G        262M
             3793 M total memory
             2886 M used memory
              342 M active memory
             2990 M inactive memory
              261 M free memory
               73 M buffer memory
              571 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       59G  7.2G   49G  13% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/sda1      vfat      255M   31M  225M  12% /boot
    tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
    Messages in dmesg:
    [Wed Mar  1 13:17:53 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Wed Mar  1 13:17:53 2023] EXT4-fs (sda2): write access will be enabled during recovery
    [Wed Mar  1 13:17:53 2023] EXT4-fs (sda2): recovery complete
    [Wed Mar  1 13:17:53 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Wed Mar  1 13:17:53 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed Mar  1 13:17:55 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.1G    /var/
    545M    /var/lib
    366M    /var/lib/influxdb/engine
    336M    /var/lib/influxdb/engine/data/3ad9bb32cbdeed46/autogen/1
    /opt/iobroker/backups:
    320M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    509M    /opt/iobroker/iobroker-data/
    396M    /opt/iobroker/iobroker-data/files
    98M     /opt/iobroker/iobroker-data/files/vis.0
    83M     /opt/iobroker/iobroker-data/backup-objects
    55M     /opt/iobroker/iobroker-data/files/vis.0/ios
    52M     /opt/iobroker/iobroker-data/files/vis.0/ios/videoplayback_Eg1j6TSN.mp4
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/2.c870507c.chunk.js.map
    19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.806bf48a.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.fe83292c.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.1
    /usr/bin/node           v16.19.1
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    GlasfaserG Offline
    GlasfaserG Offline
    @horst-böttcher sagte in IoBroker Stürt aus dem Nix ab:
    Der Rest von der Ausgabe fehlt noch !
    Eventuell ein Script was Amok läuft ... mehr kann ich gerade nicht sagen !
    3793 M total memory
    2886 M used memory
    Was steht im ioBroker Log vor/nach dem Absturz !?
      iob diag
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Docker:         false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      CET +0100
      Europe/Berlin
      pi
      /home/pi
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M         99M        0.0K
               3793 M total memory
               2886 M used memory
                342 M active memory
                261 M free memory
                 73 M buffer memory
                571 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      Messages in dmesg:
      /var:
      1.1G    /var/
      545M    /var/lib
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      GlasfaserG Offline
      GlasfaserG Offline
      @horst-böttcher
      Wenn ich in deinem Log dsmeg die Instanzen zähle , bin ich über 40 Instanzen ..
      dann passt dieses dazu :
      https://forum.iobroker.net/post/855735
      • Horst BöttcherH Offline
        Horst Böttcher
        schrieb am zuletzt editiert von Horst Böttcher
        @glasfaser
        das heißt mein 4b ist zu klein ???
        die frage ob sich das Problem mit einem Multi host lösen last oder was man da machen kann
        oder kann man den swap vergösseern da ist ein 64gb Stick dran
        ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
          @glasfaser
          CodierknechtC Online
          Codierknecht
          Für 40 Instanzen? Ja!
          Das wird Dir nicht helfen.
          Das wäre eine Möglichkeit. Du musst halt dafür sorgen, dass der arme Raspi nicht so viele Adapter-Instanzen betreiben muss.
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
          Horst BöttcherH HomoranH 2 Antworten Letzte Antwort
          • CodierknechtC Codierknecht
            Horst Böttcher
            @codierknecht sagte in IoBroker Stürt aus dem Nix ab:
            alle pi ausverkauft also bleibt nur https://forum.iobroker.net/topic/63600/hp-elitedesk-g3-800g-für-iobroker-co/5
              das wundert mich jetzt. 40 Instanzen per se sollten bei 4GB nicht alleine ein Problem sein.
                Codierknecht
                alle pi ausverkauft
                Das ist schon seit einiger Zeit so. Und wenn es welche gibt, sind sie völlig überteuert.
                https://rpilocator.com/
                Horst BöttcherH 1 Antwort Letzte Antwort
                  alle pi ausverkauft
                  Horst Böttcher
                  @codierknecht Ja leider deshalb ist man mit einem mini pc glaub ich besser bedient
                    Codierknecht
                    @homoran sagte in IoBroker Stürt aus dem Nix ab:
                    40 Instanzen x ~ 100 MB ... zack - Speicher weg.
                    Natürlich benötigen viele Adapter einiges weniger als 100 MB. Aber der Raspi braucht ja noch etwas Luft zum Atmen. Und die eine oder andere Instanz braucht ja auch gerne mal deutlich mehr.
                    Die 40 Instanzen alleine sind vielleicht nicht unbedingt das Problem. Möglicherweise aber noch das eine oder andere Zusatztool wie Grafana, Influx usw.
                    Du weißt doch, was die Leute da so alles betreiben ;-)
                      Codierknecht
                      Wäre mit Sicherheit einfacher zu beschaffen.
                      Aber ggf. etwas teurer und weniger sparsam im Verbrauch.
                        so passts!
                        nee, 100 brauchen nur ganz wenige, der Rest braucht +/- 50 (40-60)
                        und controller, admin und js-Adapter laufen nur einmal
                        Horst BöttcherH CodierknechtC 2 Antworten Letzte Antwort
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @codierknecht
                          Mit der Auslastung stimme ich Dir zu.
                          Die 4GB sind bei 40 Adapter + diverse Abhängigkeiten weg.
                          Eine ähnliche Auslastung habe ich bei der Syno.
                          Nun stellt sich die Frage , braucht man alle 40 oder sind da auch ein paar Probier Adapter bei.
                          Das kann nur der TE entscheiden.
                            so passts!
                            Horst Böttcher
                            @homoran ja ich werde morgen versuchen erst mal alles frisch aufzusetzen ohne gafan und influx für leicht geht es dann hab ja zigbee auch wieder in Phillips hue um Ressourcen zu Sparren
                              so passts!
                              Codierknecht
                              Ich komme mit meinen 28 aktiven Instanzen auf 2,4 GB.
                              Ergibt hochgerechnet ca. 3,4 GB für 40 Instanzen.
                              Viel Luft bleibt da nicht mehr ;-)
                                die kannst du so linear nicht hochrechnen, weil die größten RAM Fresser schon in der Grundinstallation dabei sind und nicht nochmal dazu kommen
                                Dass da nicht mehr vieel Luft ist, ist unstrittig.
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  @horst-böttcher
                                  Großartig wäre es , wenn Du Deine Texte nochmal querliest, bevor Du auf senden drückst.
                                  Ich finde sowas gehört auch zu einer Netiquette gegenüber Helfenden.
                                  Was bringt es Dir es wegzulassen, wenn Du es sowieso haben willst oder wieder installieren wirst ?
                                  • haselchenH haselchen
                                    @horst-böttcher
                                    Horst Böttcher
                                    @haselchen sagte in IoBroker Stürt aus dem Nix ab:
                                    @horst-böttcher
                                    Also erst mal weg lassen um ein Stabiles System zu haben
                                    dann nach einer lösung suchen wie z.b neuer Pi oder multihost oder ähnliches ich muss wenn ich alles neu installiere sehn ob alle adapter gebraucht werden
                                      @horst-böttcher
                                      Horst Böttcher
                                      habe jetzt nur das nötigste installiert mal sehn ob es gut geht
                                      96c95fbf-9d0e-4a8b-9540-b60eb8d312b6-image.png @horst-böttcher
                                        @horst-böttcher bitte die Ausgabe von top oder iob diag zeigen!
                                        die Werte im Screenshot passen irgendwie nicht zu 4GB RAM
                                          Horst Böttcher
                                          top
                                          pi@raspberrypi:~ $ top
                                          top - 13:10:40 up  3:57,  1 user,  load average: 0.63, 0.44, 0.39
                                          Tasks: 179 total,   1 running, 178 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s):  5.7 us,  1.8 sy,  0.0 ni, 92.0 id,  0.0 wa,  0.0 hi,  0.5 si,  0.0 st
                                          MiB Mem :   3837.9 total,    523.3 free,   1877.1 used,   1437.5 buff/cache
                                          MiB Swap:    100.0 total,     98.7 free,      1.3 used.   2317.4 avail Mem
                                            PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                                           9456 iobroker  20   0  406048 297280  35616 S  14.2   7.6  17:16.99 iobroker.js-con
                                           9588 iobroker  20   0  193932  82200  30908 S   4.6   2.1   1:41.31 io.hue.0
                                           9683 iobroker  20   0  220044 103344  32064 S   3.3   2.6   2:59.85 io.zigbee.0
                                          10678 iobroker  20   0  206984  92704  30976 S   3.0   2.4   2:50.45 io.web.0
                                           9513 iobroker  20   0  257500 146044  35604 S   2.6   3.7   3:20.76 io.javascript.0
                                          10431 iobroker  20   0  194212  79844  30696 S   1.0   2.0   1:55.38 io.sourceanalyt
                                           9562 iobroker  20   0  221144 105500  31768 S   0.7   2.7   1:23.15 io.tuya.0
                                           9955 iobroker  20   0  196712  74612  31480 S   0.7   1.9   0:14.94 io.openligadb.0
                                          10570 iobroker  20   0  192052  73968  31936 S   0.7   1.9   0:14.98 io.webuntis.0
                                          11611 pi        20   0   11244   2936   2464 R   0.7   0.1   0:00.22 top
                                             14 root      20   0       0      0      0 I   0.3   0.0   0:09.71 rcu_sched
                                             95 root     -51   0       0      0      0 S   0.3   0.0   0:33.96 irq/62-mmc0
                                            385 avahi     20   0    6916   3112   2720 S   0.3   0.1   0:14.68 avahi-daemon
                                           9474 iobroker  20   0  227636 118832  36136 S   0.3   3.0   0:59.75 io.admin.0
                                           9520 iobroker  20   0  188420  72044  30852 S   0.3   1.8   0:10.42 io.whatsapp-cmb
                                           9648 iobroker  20   0  185604  65712  30764 S   0.3   1.7   0:13.47 io.ping.0
                                           9668 iobroker  20   0  197256  84136  35676 S   0.3   2.1   0:45.23 io.tr-064.0
                                           9690 iobroker  20   0  198332  83560  36332 S   0.3   2.1   0:11.98 io.backitup.0
                                           9740 iobroker  20   0  186660  71896  31804 S   0.3   1.8   0:22.65 io.chromecast.0
                                          10525 iobroker  20   0  183508  62196  30720 S   0.3   1.6   0:10.29 io.vis-inventwo
                                          11333 root      20   0       0      0      0 I   0.3   0.0   0:04.54 kworker/2:0-events
                                          11594 pi        20   0   14716   5012   3980 S   0.3   0.1   0:00.04 sshd
                                              1 root      20   0   33844   8780   7020 S   0.0   0.2   0:03.12 systemd
                                              2 root      20   0       0      0      0 S   0.0   0.0   0:00.03 kthreadd
                                              3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
                                              4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
                                              5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 slub_flushwq
                                              6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 netns
                                              8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/0:0H-kblockd
                                             10 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_percpu_wq
                                             11 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tasks_rude_
                                             12 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tasks_trace
                                             13 root      20   0       0      0      0 S   0.0   0.0   0:02.50 ksoftirqd/0
                                             15 root      rt   0       0      0      0 S   0.0   0.0   0:00.09 migration/0
                                             16 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
                                             17 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
                                             18 root      rt   0       0      0      0 S   0.0   0.0   0:00.07 migration/1
                                             19 root      20   0       0      0      0 S   0.0   0.0   0:00.88 ksoftirqd/1
                                             21 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/1:0H-events_highpri
                                             22 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/2
                                             23 root      rt   0       0      0      0 S   0.0   0.0   0:00.06 migration/2
                                             24 root      20   0       0      0      0 S   0.0   0.0   0:00.85 ksoftirqd/2
                                             26 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/2:0H-kblockd
                                             27 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/3
                                             28 root      rt   0       0      0      0 S   0.0   0.0   0:00.06 migration/3
                                             29 root      20   0       0      0      0 S   0.0   0.0   0:00.79 ksoftirqd/3
                                             31 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/3:0H-kblockd
                                             32 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kdevtmpfs
                                             33 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 inet_frag_wq
                                             38 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kauditd
                                             39 root      20   0       0      0      0 S   0.0   0.0   0:00.01 khungtaskd
