  4. Deconz-Gui
    5.5k
Deconz-Gui
53 Beiträge 5 Kommentatoren 7.5k Aufrufe 3 Beobachtet
  • G Offline
    Gabe
    leider habe ich das gleiche Problem mit Deconz-gui, auch bei mir startet die nicht.
    Folgende Befehle habe ich bereits ausgeführt:
    sudo systemctl stop deconz
    sudo systemctl disable deconz
    sudo systemctl enable deconz-gui
    sudo systemctl start deconz-gui
    bei systemctl status deconz deconz-gui
    ● deconz.service - deCONZ: ZigBee gateway -- REST API
         Loaded: loaded (/lib/systemd/system/deconz.service; disabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Fri 2023-03-03 10:22:04 CET; 6min ago
       Main PID: 16590 (code=exited, status=143)
            CPU: 3.083s
    Mar 03 10:21:33 raspberrypi deCONZ[16590]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
    Mar 03 10:21:33 raspberrypi deCONZ[16590]: libpng warning: iCCP: known incorrect sRGB profile
    Mar 03 10:21:34 raspberrypi deCONZ[16590]: This plugin does not support propagateSizeHints()
    Mar 03 10:21:36 raspberrypi deCONZ[16590]: This plugin does not support propagateSizeHints()
    Mar 03 10:22:02 raspberrypi systemd[1]: Stopping deCONZ: ZigBee gateway -- REST API...
    Mar 03 10:22:04 raspberrypi systemd[1]: deconz.service: Main process exited, code=exited, status=143/n/a
    Mar 03 10:22:04 raspberrypi systemd[1]: deconz.service: Failed with result 'exit-code'.
    Mar 03 10:22:04 raspberrypi systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
    Mar 03 10:22:04 raspberrypi systemd[1]: deconz.service: Consumed 3.083s CPU time.
    ● deconz-gui.service - deCONZ: ZigBee gateway -- GUI/REST API
         Loaded: loaded (/lib/systemd/system/deconz-gui.service; enabled; vendor preset: enabled)
         Active: activating (auto-restart) (Result: signal) since Fri 2023-03-03 10:28:19 CET; 5s ago
        Process: 2500 ExecStart=/usr/bin/deCONZ --http-port=80 (code=killed, signal=ABRT)
       Main PID: 2500 (code=killed, signal=ABRT)
            CPU: 82ms
    HomoranH Thomas BraunT FabioF 3 Antworten Letzte Antwort
    • G Gabe
              CPU: 3.083s
              CPU: 82ms
      @gabe sagte in Deconz-Gui:
      wie wer oder was?
      • G Gabe
                CPU: 3.083s
                CPU: 82ms
        @gabe
        sudo apt update
        apt policy deconz
        sagt?
        G 2 Antworten Letzte Antwort
          @gabe
          sudo apt update
          apt policy deconz
          sagt?
          Gabe
          @thomas-braun hier die Infos
          pi@raspberrypi:~ $ sudo apt update
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://phoscon.de/apt/deconz bullseye InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
          Reading package lists... Done
          All packages are up to date.
          pi@raspberrypi:~ $ apt policy deconz
          deconz:
            Installed: 2.20.01-raspbian-buster-stable
            Candidate: 2.20.01-raspbian-buster-stable
            Version table:
           *** 2.20.01-raspbian-buster-stable 500
                  500 http://phoscon.de/apt/deconz bullseye/main armhf Packages
          pi@raspberrypi:~ $
          • G Gabe
            deconz:
              Version table:
            pi@raspberrypi:~ $
            @gabe
            Hast du denn einen X-Server laufen?
            iob diag
            sagt?
            haselchenH G 2 Antworten Letzte Antwort
              @gabe
              iob diag
              sagt?
              haselchenH Offline
              haselchenH Offline
              haselchen
              Gibs da eventuell Krach wegen Buster und Bullseye?
              • haselchenH haselchen
                @haselchen sagte in Deconz-Gui:
                Nein, die bei deconz sind nur zu faul die Pakete ordentlich zu benennen (bzw. zu versionieren).
                  @gabe
                  iob diag
                  sagt?
                  Gabe
                  @thomas-braun brauchst du die gesamte Ausgabe oder nur Teil?
                  • G Gabe
                    @gabe
                    Wie du willst. Bei voller Ausgabe kann man über die anderen Einstellungen aber auch nochmal drüber schauen.
                    G 1 Antwort Letzte Antwort
                      @gabe
                      Gabe
                      schrieb am zuletzt editiert von Gabe
                      @thomas-braun passt das so?
                      Skript v.2023-01-02
                      *** BASE SYSTEM ***
                      Model           : Raspberry Pi 4 Model B Rev 1.2
                      Architecture:   armv7l
                      Docker:         false
                      Virtualization: none
                      Distributor ID: Raspbian
                      Description:    Raspbian GNU/Linux 11 (bullseye)
                      Release:        11
                      Codename:       bullseye
                      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                      NAME="Raspbian GNU/Linux"
                      VERSION_ID="11"
                      VERSION="11 (bullseye)"
                      VERSION_CODENAME=bullseye
                      ID=raspbian
                      ID_LIKE=debian
                      HOME_URL="http://www.raspbian.org/"
                      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                      Systemuptime and Load:
                       19:54:30 up  9:44,  1 user,  load average: 1.20, 0.97, 0.80
                      CPU threads: 4
                      *** Time and Time Zones ***
                      Fri Mar  3 18:54:30 UTC 2023
                      Fri Mar  3 19:54:30 CET 2023
                      CET +0100
                      Europe/Berlin
                      *** User and Groups ***
                      pi
                      /home/pi
                      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                      *** X-Server-Setup ***
                      X-Server:       true
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        1.9G        814M         45M        1.1G        2.1G
                      Swap:            99M          0B         99M
                      Total:          3.9G        1.9G        914M
                               3838 M total memory
                               1946 M used memory
                                496 M active memory
                               2337 M inactive memory
                                814 M free memory
                                135 M buffer memory
                                942 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      *** FILESYSTEM ***
                      /dev/root      ext4       59G  8.5G   48G  16% /
                      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                      tmpfs          tmpfs     1.9G  1.1M  1.9G   1% /dev/shm
                      tmpfs          tmpfs     768M  1.1M  767M   1% /run
                      /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
                      tmpfs          tmpfs     384M   16K  384M   1% /run/user/999
                      tmpfs          tmpfs     384M   24K  384M   1% /run/user/112
                      tmpfs          tmpfs     384M   24K  384M   1% /run/user/1000
                      Messages in dmesg:
                      [Fri Mar  3 10:10:30 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:A6:63:F0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ff26f57-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                      [Fri Mar  3 10:10:31 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Fri Mar  3 10:10:31 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Fri Mar  3 10:10:34 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                      TARGET  SOURCE         FSTYPE OPTIONS
                      /       /dev/mmcblk0p2 ext4   rw,noatime
                      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                      /var:
                      2.6G    /var/
                      2.0G    /var/log
                      1.9G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
                      411M    /var/cache
                      /opt/iobroker/backups:
                      77M     /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      538M    /opt/iobroker/iobroker-data/
                      255M    /opt/iobroker/iobroker-data/files
                      198M    /opt/iobroker/iobroker-data/backup-objects
                      51M     /opt/iobroker/iobroker-data/files/javascript.admin
                      42M     /opt/iobroker/iobroker-data/files/devices.admin
                      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
                      27M     /opt/iobroker/iobroker-data/states.jsonl
                      27M     /opt/iobroker/iobroker-data/objects.jsonl
                      27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
                      8.6M    /opt/iobroker/iobroker-data/objects.json.migrated
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v16.19.1
                      /usr/bin/node           v16.19.1
                      /usr/bin/npm            8.19.3
                      /usr/bin/npx            8.19.3
                      nodejs:
                        Installed: 16.19.1-deb-1nodesource1
                        Candidate: 16.19.1-deb-1nodesource1
                        Version table:
                       *** 16.19.1-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                           12.22.12~dfsg-1~deb11u3 500
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Core adapters versions
                      js-controller:  4.0.24
                      admin:          6.3.5
                      javascript:     6.1.4
                      Adapters from github:   1
                      Adapter State
                      + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
                        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                      + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 8090
                        system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                      + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
                        system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              - disabled
                      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
                      + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
                        system.adapter.material.0               : material              : raspberrypi                              -  enabled
                      + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                      + system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
                      + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
                      + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
                      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
                      + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                      + system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
                        system.adapter.roomba.0                 : roomba                : raspberrypi                              -  enabled
                      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                      + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
                      + system.adapter.sma-em.0                 : sma-em                : raspberrypi                              -  enabled
                        system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
                      + system.adapter.tapo.0                   : tapo                  : raspberrypi                              -  enabled
                      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
                        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
                        system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
                        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              -  enabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                        system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
                        system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled
                      + system.adapter.zwave2.0                 : zwave2                : raspberrypi                              -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Installed ioBroker-Instances
                      Used repository: stable
                      Adapter    "alarm"        : 3.3.9    , installed 3.3.9
                      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                      Adapter    "backitup"     : 2.5.12   , installed 2.5.12
                      Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
                      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                      Adapter    "devices"      : 1.1.2    , installed 1.1.2
                      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                      Adapter    "email"        : 1.1.4    , installed 1.1.4
                      Adapter    "fahrplan"     : 1.2.2    , installed 1.2.2
                      Adapter    "fb-checkpresence": 1.1.25, installed 1.1.25
                      Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
                      Adapter    "history"      : 2.2.4    , installed 2.2.4
                      Adapter    "info"         : 1.9.19   , installed 1.9.19
                      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                      Adapter    "material"     : 1.1.2    , installed 1.1.2
                      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                      Adapter    "netatmo"      : 2.0.5    , installed 3.1.0
                      Adapter    "nina"         : 0.0.25   , installed 0.0.25
                      Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                      Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                      Adapter    "roomba"       : 1.1.4    , installed 1.1.4
                      Adapter    "shuttercontrol": 1.4.18  , installed 1.4.18
                      Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
                      Adapter    "tapo"         : 0.0.8    , installed 0.0.8
                      Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
                      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                      Adapter    "worx"         : 2.0.3    , installed 2.0.3
                      Adapter    "zigbee2mqtt"  : 2.7.3    , installed 2.7.3
                      Adapter    "zwave2"       : 3.0.3    , installed 3.0.3
                      Objects and States
                      Objects:        8447
                      States:         7701
                      Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
                      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                      Hit:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Pending Updates: 2
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       19591      1364/node-red
                      tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      1000       477726     5538/deCONZ
                      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       478317     5538/deCONZ
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15421      595/cupsd
                      tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        16534      841/pihole-FTL
                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          14763      767/lighttpd
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14565      611/sshd: /usr/sbin
                      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        16520      841/pihole-FTL
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15591      597/iobroker.js-con
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15897      597/iobroker.js-con
                      tcp6       0      0 :::3389                 :::*                    LISTEN      113        14645      626/xrdp
                      tcp6       0      0 ::1:3350                :::*                    LISTEN      0          14573      609/xrdp-sesman
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25898      3147/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17760      935/io.admin.0
                      tcp6       0      0 :::1950                 :::*                    LISTEN      1001       18022      1364/node-red
                      tcp6       0      0 :::80                   :::*                    LISTEN      0          14764      767/lighttpd
                      tcp6       0      0 ::1:4711                :::*                    LISTEN      999        14858      841/pihole-FTL
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15420      595/cupsd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          14567      611/sshd: /usr/sbin
                      tcp6       0      0 :::53                   :::*                    LISTEN      999        16522      841/pihole-FTL
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12659      358/avahi-daemon: r
                      udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       23492      3336/io.sma-em.0
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       478380     5538/deCONZ
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       451436     30037/io.deconz.0
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       451433     30037/io.deconz.0
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       18024      1364/node-red
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       18023      1364/node-red
                      udp        0      0 0.0.0.0:52123           0.0.0.0:*                           108        12661      358/avahi-daemon: r
                      udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        16519      841/pihole-FTL
                      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       21427      2380/io.radar2.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15433      722/dhcpcd
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          9005       645/cups-browsed
                      udp6       0      0 :::1194                 :::*                                0          13107      725/openvpn
                      udp6       0      0 :::5353                 :::*                                108        12660      358/avahi-daemon: r
                      udp6       0      0 :::1900                 :::*                                1001       451437     30037/io.deconz.0
                      udp6       0      0 :::1900                 :::*                                1001       451435     30037/io.deconz.0
                      udp6       0      0 :::1900                 :::*                                1001       451434     30037/io.deconz.0
                      udp6       0      0 :::50645                :::*                                108        12662      358/avahi-daemon: r
                      udp6       0      0 :::546                  :::*                                0          15450      722/dhcpcd
                      udp6       0      0 :::53                   :::*                                999        16521      841/pihole-FTL
                      • G Gabe
                        Skript v.2023-01-02
                        *** BASE SYSTEM ***
                        Docker:         false
                        Release:        11
                        Codename:       bullseye
                        VERSION_ID="11"
                        ID=raspbian
                        ID_LIKE=debian
                        CPU threads: 4
                        CET +0100
                        Europe/Berlin
                        pi
                        /home/pi
                        X-Server:       true
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M          0B         99M
                                 3838 M total memory
                                 1946 M used memory
                                  496 M active memory
                                  814 M free memory
                                  135 M buffer memory
                                  942 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        *** FILESYSTEM ***
                        Messages in dmesg:
                        /var:
                        2.6G    /var/
                        2.0G    /var/log
                        411M    /var/cache
                        /usr/bin/npm            8.19.3
                        /usr/bin/npx            8.19.3
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.3.5
                        javascript:     6.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        8447
                        States:         7701
                        Pending Updates: 2
                        @gabe
                        Ich würde die 64bit Version ohne Desktop nehmen.
                        Und Updates für das OS einspielen.
                          @gabe
                          Gabe
                          @thomas-braun magst du mir kurz sagen wie das geht?
                          Ich brauche einmal die deconz-gui um etwas auszulesen.
                          Bekomme ich das hin?
                          • Thomas BraunT Online
                            Wie was geht?
                            • G Offline
                              Gabe
                              @thomas-braun ich meinte auf die 64 Version zu gehen oder geht das nur über Komplettimage?
                              Bei dem OS komme ich auch nicht weiter, mit den Standardbefehlen gibt es kein Update.
                              Hast du auch noch eine Idee wegen dem deconz-Gui?
                              Danke für deine Hilfe!!!
                              • G Gabe
                                @gabe
                                64bit erfordert eine Neuinstallation.
                                Update mit den Debian-Standardbefehlen
                                sudo apt update
                                sudo apt full-upgrade
                                  @gabe
                                  sudo apt update
                                  apt policy deconz
                                  sagt?
                                  Gabe
                                  pi@raspberrypi:~ $ sudo apt full-upgrade
                                  Calculating upgrade... Done
                                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                  • G Gabe
                                    Gabe
                                    @Thomas-Braun hast du evtl noch eine Idee wie ich die gui gestartet bekomme?
                                    • G Gabe
                                      Am besten gar nicht.
                                      • G Gabe
                                                CPU: 3.083s
                                                CPU: 82ms
                                        FabioF Offline
                                        FabioF Offline
                                        Fabio
                                        @gabe wende dich doch mal an den Support von Dresden Elektronik https://phoscon.de/de/support hast du überhaupt deconz installiert und wenn ja wie und für welche Version sprich für welches Gerät. Hast du hier mal geschaut https://phoscon.de/de/conbee2/install
                                        Iobroker:
                                        • Matter over Thread Hilfe
                                        • FabioF Fabio
                                          Gabe
                                          @fa-bio ja alles installiert und funktioniert ja auch soweit. Nur die blöde GUI bekomme ich nicht zum laufen...
                                          FabioF 1 Antwort Letzte Antwort
