  4. Test Adapter LG ThinQ
    6.7k
950 Beiträge 72 Kommentatoren 415.5k Aufrufe 69 Beobachtet
  • L Lucky_ESA
    @lars0815 Bitte ein issues HIER und dein Debug Log dort posten. Ich benötige immer den Inhalt vom DP modelJsonUri damit ich das implementieren kann.
    Gruß//Lucky
    Lars0815
    #194
    @lucky_esa
    Auch mit Version 1.3 folgendes Problem:
    2022-12-04 20:14:53.138 - info: lg-thinq.0 (5400) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-12-04 20:14:53.412 - info: lg-thinq.0 (5400) starting. Version 0.1.3 (non-npm: TA2k/ioBroker.lg-thinq#c1c688b5321605dcab49f244ebdf0f707fffad0a) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v16.18.0, js-controller: 4.0.23
    2022-12-04 20:14:53.497 - info: smartmeter.0 (7177) Received 7 values, 3 updated
    2022-12-04 20:14:54.900 - info: lg-thinq.0 (5400) Login successful
    2022-12-04 20:14:55.784 - info: lg-thinq.0 (5400) Found: 1 devices
    2022-12-04 20:14:56.094 - info: lg-thinq.0 (5400) createAirRemoteStates: Cannot found ControlDevice
    2022-12-04 20:14:56.362 - error: lg-thinq.0 (5400) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-12-04 20:14:56.363 - error: lg-thinq.0 (5400) unhandled promise rejection: Cannot read properties of undefined (reading '0')
    2022-12-04 20:14:56.364 - error: lg-thinq.0 (5400) TypeError: Cannot read properties of undefined (reading '0')
    at LgThinq.getDeviceModelInfo (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:684:44)
    at async LgThinq.onReady (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:154:57)
    2022-12-04 20:14:56.365 - error: lg-thinq.0 (5400) Cannot read properties of undefined (reading '0')
    2022-12-04 20:14:56.371 - info: lg-thinq.0 (5400) terminating
    2022-12-04 20:14:56.373 - warn: lg-thinq.0 (5400) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-12-04 20:14:57.116 - error: host.rpi4 instance system.adapter.lg-thinq.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    • L Lars0815
      @lucky_esa
      tombox
      #195
      @lars0815 kannst du mal den adapter in debug laufen lassen und den content nach
      Get Device Model Info
      posten
      • L Offline
        Lucky_ESA
        schrieb am zuletzt editiert von Lucky_ESA
        #196
        @lucky_esa sagte in Test Adapter LG ThinQ v0.0.1:
        modelJsonUri
        Wie bereits von mir beschrieben benötige ich den Inhalt vom Datenpunkt modelJsonUri. Du hast wahrscheinlich ein thinq1 Geräte was auf dem GIT nicht gefixt ist.
        Edit1: Issue auf GIT erstellt..Danke..
        Gruß//Lucky
        L 1 Antwort Letzte Antwort
        • L Lucky_ESA
          modelJsonUri
          Gruß//Lucky
          Lars0815
          #197
          @lucky_esa Es hat aber bis zum letzten Update wunderbar funktioniert. :man-shrugging:
          • L Lars0815
            Lucky_ESA
            #198
            @lars0815 sagte in Test Adapter LG ThinQ v0.0.1:
            Ja, aber wie oben zu sehen, haben wir ein device 401 thinq2 hinzugefügt und du hast 401 thinq1. Das verursacht den Fehler.
            Du kannst vom GIT laden, diese Version sollte wieder funktionieren.
            Gruß//Lucky
            • G Offline
              g.pitzer
              #199
              Ich bin soeben auf diesen Thread gestossen da ich zwei Klima Splitgeräte habe und diese steuern möchte. Leider habe ich auch thing1 Geräte welche nur gelesen und nicht gesteuert werden können.
              Meine Frage: Wird daran noch gearbeitet? Kann man das irgendwie unterstützen?
              Andere Frage welche nicht zum Thema passt, aber ich versuchs trotzdem: macht es Sinn mit der Klimaanlage bei einer PV mit Überschuss zu heizen und damit die Ölheizung zu entlassten?
              Danke und lg
              • G g.pitzer
                Danke und lg
                Lucky_ESA
                #200
                @g-pitzer Bist du sicher das du nichts steuern kannst? Es sollte ein Ordner "remote" vorhanden sein. Wenn dieser fehlt wird dein Account benötigt.
                Deine zweite Frage kann ich dir leider nicht beantworten.
                Gruß//Lucky
                • L Lucky_ESA
                  auf dem GIT liegt nun ein Update für thinq2 Nutzer für die Geräte 101, 201 und 202.
                  Diese 3 Geräte werden nun voll unterstützt. Achtung! Die Version beinhaltet einen Datenpunkt der später wieder entfernt wird.
                  Wer testet muss dann später beim Wechsel auf latest oder stable seine Instanz löschen oder den Datenpunkt manuell löschen.
                  lg-thinq.0.xxx.remote.sendJSON
                  Hier eine Beschreibung wie ihr die Version installieren könnt.
                  Nun zu den neuen Funktionen.
                  Kühlschrank:
                  lg-thinq.0.xxx.deviceType = 101
                  lg-thinq.0.xxx.platformType = thinq2
                  MQTT Verbindung - Wer nur thinq2 Geräte hat kann nun sein Intervall auf 60 Minuten ändern
                  lg-thinq.0.xxx.remote.Statistic.command Statistik auswählen
                  lg-thinq.0.xxx.remote.Statistic.startDate 2022.11.15 eintragen
                  lg-thinq.0.xxx.remote.Statistic.endDate 2022.11.15 eintragen
                  lg-thinq.0.xxx.remote.Statistic.period täglich auswählen
                  Wenn alle 4 Datenpunkte ausgewählt sind dann:
                  lg-thinq.0.xxx.remote.Statistic.sendRequest auf true setzen
                  Leider bekommt ihr eine Fehlermeldung (undefined (reading 'replace')). Muss ich noch fixen.
                  Es kommt nun die Statistik in lg-thinq.0.xxx.remote.Statistic.jsonResult gespeichert. end und start muss immer auseinander liegen, wie ihr period auswählt. Bei stündlich muss auch noch die Zeit angegeben werden. Ihr könnt das Format mal testen...
                  Waschmaschine:
                  lg-thinq.0.xxx.deviceType = 201
                  lg-thinq.0.xxx.remote.Favorite: Funktioniert nur wenn ein Favorit in der APP ausgewählt wurde und wenn die Maschine eingeschaltet ist.
                  lg-thinq.0.xxx.remote.LastCourse: Die letzte 10 Programme auswählbar.
                  lg-thinq.0.xxx.remote.WMDownload_Select: Auswahl aller verfügbaren Programme (STD=Standard/DL=Downloadprogramme)
                  Wenn einer der 3 Datenpunkte gefüllt wird, wird das ausgewählt Programm in den Ordner Course ausgewählt. Hier könnt ihr dann noch Anpassunge vornehmen.
                  Danach muss der Datenpunkt lg-thinq.0.xxx.remote.WMDownload aus true/false gesetzt werden. Das Programm wird nun auf die Waschmaschine übertragen und im Display angezeigt (Waschmaschine muss an sein).
                  Danach könnt ihr mit lg-thinq.0.xxx.remote.WMStart die Waschmaschine starten.
                  Die Statistik ist wie beim Kühlschrank wobei es die Auswahl command nicht gibt.
                  Trockner:
                  lg-thinq.0.xxx.deviceType = 202
                  Leider gibt es hier einen Unterschied zur Waschnaschine.
                  Das Standard Programm wird nicht beim drücken von WMDownload zum Trockner übertragen sondern erst wenn ihr start drückt. Also einen der 3 Datenpunkte auswählen, dann den Ordner Course anpassen und danach WMDownload auf true/false setzen. Zum starten dann WMStart auf true/false setzen.
                  Value für den Datenpunkt sendJSON kommen bei Bugs von mir bzw. werde das dann genauer erklären.
                  Wenn ihr Problem habt dann wie oben beschrieben statt GIT -> NPM auswählen.
                  Werde diese Beitrag wahrscheinlich noch öfter editieren...Den Rest können wir dann in diesem Thread besprechen.
                  Nun viel Spaß beim testen.
                  Edit1: Wenn ihr die Datenpunkte mit Blocklys triggert macht bitte zwischen dem Setzen 2 Sekunden Pause.
                  Edit2: Bilder hinzugefügt
                  Edit3: Noch was zu MQTT Connection. Ihr bekommt nun aktuelle Daten wenn sich ein Zustand ändert. Schön nun beim Kühlschrank das öffnen/schließen sofort zu erkennen. Bei der Waschmaschine kann man lg-thinq.0.xxx.snapshot.washerDryer.state auf END triggern und beim Trockner lg-thinq.0.xxx.snapshot.washerDryer.processState auf END triggern. Beim Trockner wird der Datenpunkt lg-thinq.0.xxx.snapshot.washerDryer.remainTimeMinute erst 30 Sekunden später auf 0 gesetzt. Daher ist dieser DB nicht zum triggern zu gebrauchen aber bei der Waschmaschine funktioniert diese + lg-thinq.0.xxx.snapshot.washerDryer.remainTimeHour == 0.
                  Gruß//Lucky
                  shellyrulestheworld
                  schrieb am zuletzt editiert von shellyrulestheworld
                  #201
                  @lucky_esa said in Test Adapter LG ThinQ v0.0.1:
                  Hallöchen,
                  vielen Dank erst mal für die tolle Arbeit. Gerade die WAMA erfolgreich gestartet.
                  Habe aber noch 2 Fragen:
                  1. Wer nur thinq2 Geräte hat kann nun sein Intervall auf 60 Minuten ändern
                    --> ist damit das Intervall im Adapter gemeint? Ich habe da aktuell 1 Minute drin.
                  2. wie pausiere ich den Waschgang richtig? Möchte bei PV Überschuss starten bzw. stoppen (pausieren)
                    Und wie lange kann ich pausieren, bis ich die WAMA wieder am Gerät einschalten muss? Inkl. Fernstart aktivieren?
                  Nutzt diese "Pause"-Funktion schon jemand in einem Blockly / Script?
                  • S shellyrulestheworld
                    Hallöchen,
                    Lucky_ESA
                    #202
                    @peterschatz
                    Zu 1: Lass auf 1 Minute stehen. Habe noch Probleme mit der MQTT Verbindung. Habe das bereits gefixt und es läuft bei mir 5 Wochen fehlerfrei. Es wird bald ein Update kommen.
                    Zu 2: Für Pause gibt es lg-thinq.0.deviceID.remote.WMStop aber das habe ich noch nie getestet. Versuche es einfach mal...True für Pause und erneut True für weiter. Ja, Fernstart muss manuell aktiviert sein.
                    Gruß//Lucky
                    JackDanielJ 1 Antwort Letzte Antwort
                    • L Lucky_ESA
                      Kühlschrank:
                      Waschmaschine:
                      Trockner:
                      Gruß//Lucky
                      sudete
                      #203
                      Hallo und vielen Dank für diesen super Lg ThinQ Adapter!
                      Meine Klimaanlage funktioniert prima mit dem Adapter...nachdem der Adapter nun auch Thinq2-201 Geräte voll unterstützen soll,
                      habe ich den Adapter mit meinem Signature-Waschtrockner probiert. Leider funktioniert die Remote Steuerung nur bedingt bzw. garnicht.
                      Folgende Prozedure habe ich getestet:
                      1.lg-thinq.0.xxx.remote.WMDownload_Select -> z.B.: EASYCARE_CS-STD
                      2.lg-thinq.0.xxx.remote.WMDownload -> ca 2s auf true
                      3.lg-thinq.0.xxx.remote.WMStart -> ca 2s auf true
                      dann geht
                      lg-thinq.0.xxx.remote.WMDownload_Select auf NOT_SELECTED
                      und ich bekomme eine Warning vom Adapter
                      Log Meldung: lg-thinq.0 2023-02-23 11:16:06.943 warn Datapoint WMDownload_Select is empty!
                      Der Waschtrockner schaltet aus.
                      hier noch ein paar Datenpunkt-Infos:
                      lg-thinq.0.xxx.remote.Favorite -> false
                      lg-thinq.0.xxx.remote.LastCourse -> NOT_SELECTED(0)
                      lg-thinq.0.xxx.langPackModelUri -> https://objectcontent.lgthinq.com/e3faf059-253d-4fd4-8678-2a152427b355?hdnts=exp=1689396157~hmac=35abf699a63466d6efa493dda438e93a5f39b882974b79f031d5a62300a9970c
                      lg-thinq.0.xxx.modelJsonUri -> https://objectcontent.lgthinq.com/4df5ecde-bf98-49d2-a562-4037df401c4e?hdnts=exp=1691553592~hmac=d711e49cb7702f9f49b5d09bd443e98f2099c83078b36703c453d3e51aa2f4a0
                      lg-thinq.0.xxx.deviceType -> 201
                      lg-thinq.0.xxx.platformType -> thinq2
                      Hat jemand eine Idee?
                      • L Lucky_ESA
                        @peterschatz
                        Gruß//Lucky
                        JackDanielJ Offline
                        JackDanielJ Offline
                        JackDaniel
                        #204
                        hust, mal nachgefragt wann "bald" eigentlich ist :)
                        Carpe diem
                        L 2 Antworten Letzte Antwort
                        • JackDanielJ JackDaniel
                          Lucky_ESA
                          #205
                          @jackdaniel Mach ich vielleicht heute noch
                          @sudete Hier habe ich leider ein Problem. Meine Annahme war, dass das Model 201 eine Waschmaschine ist Du hast aber eine Kombi und daher passt das alles nicht. Jetzt fehlt mir die Idee wie ich festellen kann, ob es eine WA oder Kombi ist. Wahrscheinlich müsste uns auch @tombox helfen da ich nur vermuten kann welche Werte an das Kombi-Gerät gesendet werden....Auwaia...
                          L T 2 Antworten Letzte Antwort
                          • L Lucky_ESA
                            Lucky_ESA
                            #206
                            @sudete Hier habe ich leider ein Problem. Meine Annahme war, dass das Model 201 eine Waschmaschine ist Du hast aber eine Kombi und daher passt das alles nicht. Jetzt fehlt mir die Idee wie ich festellen kann, ob es eine WA oder Kombi ist. Wahrscheinlich müsste uns auch @tombox helfen da ich nur vermuten kann welche Werte an das Kombi-Gerät gesendet werden....Auwaia...Kannst du mal bitte auf debug stellen und mir das File zusenden github@luckyskills.de
                            • L Lucky_ESA
                              tombox
                              #207
                              @JackDaniel @lucky_esa oder mal ein debug log via pn zusenden da sind auch alle infos drin
                                Lucky_ESA
                                #208
                                @jackdaniel Habe es jetzt auf`m GIT
                                @sudete Wie von tombox und mir beschrieben benötigen wir einen debuglog. Vielleicht finde ich dort eine Info womit ich erkennen kann, ob 201 WM oder 201 Kombi.
                                • L Lucky_ESA
                                  sudete
                                  #209
                                  @lucky_esa Ich habe mal eine Log Datei erstellt..ich hoffe ihr könnt damit etwas anfangen.LG_log_sent.txt
                                  • S sudete
                                    Lucky_ESA
                                    #210
                                    @sudete Habe jetzt auf dem GIT deine Fehlermeldungen korrigiert. Am Wochenende versuche ich zu erraten was an die Cloud übergeben werden muss. Habe aber schon eine Vermutung allerdings gibt es 4 Möglichkeiten. Wenn es nicht funktioniert musst du uns als Mitglied in der APP aufnehmen. Dann musst du hoffen, dass @tombox mal Zeit hat.
                                    Funktioniert alles mit deiner Klimaanlage?
                                    Du hast da eine super Waschmaschine...Kann die auch Bügeln und Fensterputzen?
                                    Gruß//Lucky
                                    • S sudete
                                      Lucky_ESA
                                      #211
                                      @sudete Bitte deine Waschmaschine einschalten und Fernzugriff aktivieren. Dann mal in den Datenpunkt
                                      lg-thinq.0.<nummerderwaschmaschine>.remote.sendJSON folgendes eintragen:
                                         "ctrlKey": "WMDownload",
                                         "command": "Set",
                                         "dataSetList": {
                                             "washerDryer": {
                                         		"courseDownloadType": "COURSEDATA",
                                         		"courseDownloadDataLength": 30,
                                         		"courseMainGplusBest": "BABYCARE_CS",
                                         		"smartCourseMainGplusBest": "BABY_CARE",
                                         		"autoDetergent": "AUTO_DETERGENT_OFF",
                                         		"gplusBestWash": "GPLUS_BEST_WASH_NO_SELECT",
                                         		"steam": "STEAM_OFF",
                                         		"downloadSlotNumber": 0,
                                         		"categoryNumber": 0,
                                         		"steamSoftener": "STEAMSOFTENER_OFF",
                                         		"soilWash": "SOILWASH_NORMAL",
                                         		"temp": "TEMP_60",
                                         		"rinse": "RINSE_NORMAL",
                                         		"spin": "SPIN_1000",
                                         		"dryLevel": "NO_DRYLEVEL",
                                         		"preWash": "PREWASH_ON",
                                         		"medicRinse": "MEDICRINSE_ON",
                                         		"proofing": "PROOFING_OFF",
                                         		"creaseCare": "CREASECARE_OFF",
                                         		"turboWash": "TURBOWASH_OFF",
                                         		"softener": "SOFTENER_OFF",
                                         		"detergent": "DETERGENT_OFF",
                                         		"initialBit": "INITIAL_BIT_OFF",
                                         		"childLock": "CHILDLOCK_OFF",
                                         		"remoteStart": "REMOTE_START_OFF",
                                         		"softenerRemaining": "SOFTENER_REMAING_NO",
                                         		"detergentRemaining": "DETERGENT_REMAINING_NO",
                                         		"detergentBox": "DETERGENT_BOX_OFF",
                                         		"miniPairing": "MINI_PAIRING_OFF",
                                         		"reserveTimeMinute": 0,
                                         		"stainCare": "BLOOD",
                                         		"courseType": "SmartCourse"
                                      Was passiert dann?
                                      Werden die Daten in deine Waschmaschine übernommen oder geht die WM auf END.
                                      Wenn die WM auf End geht dann neu einschalten und Fernzugriff aktivieren.
                                      Nach beiden Fällen dann bitte das eingeben:
                                         "ctrlKey": "WMStart",
                                         "command": "Set",
                                         "dataSetList": {
                                             "washerDryer": {
                                         		"temp": "TEMP_60",
                                      Was passiert?
                                      Gruß//Lucky
                                      • L Lucky_ESA
                                        Gruß//Lucky
                                        sudete
                                        #212
                                        @lucky_esa Vielen Dank erstmal für deine Mühen!
                                        Die Klimaanlage funktioniert prima...keine Probleme beim Einstellen von Betriebsarten, Gebläsestärke, Zirkulierrichtungen sowie Temperaturen. Alles kann über IoBroker gesteuert werden. Erst gab es Probleme bei der Io-Broker Programmierung wie alles implementiert werden muss...aber wenn man das verstanden hat, klappt es auch.
                                        Ja, mit der Waschmaschine bin ich bislang sehr Zufrieden...für das Bügeln gibt es das Programm "Knitterfrei" ;-) , hat ja bereits schon jede Waschmaschine :-)...und fürs Fensterputzen warte ich noch auf ein Programm-Update von LG sollte dann auch fuktionieren😀
                                        Jetzt fehlt halt noch eine IoBroker Implementierung, um die Waschmaschine über die Sonnenstrahlung zu schalten.
                                        Gruß Uwe
                                        • L Lucky_ESA
                                             "command": "Set",
                                             "dataSetList": {
                                                 "washerDryer": {
                                             		"temp": "TEMP_60",
                                          Was passiert dann?
                                             "command": "Set",
                                             "dataSetList": {
                                                 "washerDryer": {
                                             		"temp": "TEMP_60",
                                          Was passiert?
                                          Gruß//Lucky
                                          sudete
                                          #213
                                          @lucky_esa Ich habe das Senden über sendJSON probiert, doch leider ohne Erfolg.
                                          Im ersten Fall, reagiert die Waschmischine gar nicht, opitisch jedenfalls...es wird kein neues Programm bzw. das "Baby_Care" Programm eingestellt. Hier die Debug-Info: sendjson.log
                                          Im zweiten Fall startet die Maschine zwar den Waschgang, allerdings mit dem Initialprogramm "Koch-/Buntwäsche" und nicht mit "Baby-Care". Auch hier dei Debug Info: sendjson2.log
                                          Gruß Uwe
