  4. [gelöst] Brauche Hilfe beim NSPanel mit Tasmota
    5.5k
nspanel mqtt sonoff
104 Beiträge 5 Kommentatoren 14.6k Aufrufe 4 Beobachtet
  • ArmilarA Armilar
    @armilar
    Irgendwelche Fehler im Log? Das Script versucht bereits an das Panel zu senden... Falls noch nichts angezeigt werden sollte außer "waiting for content", stimmt die Kommunikation MQTT zwischen Adapter und Tasmota noch nicht.
    GregorSG Offline
    GregorSG Offline
    GregorS
    @armilar
    Habe den Port jetzt mal auf 1886 geändert.
    mqtt.1
    	2023-02-16 20:53:56.627	info	Client [NSPanel_01] publishOnSubscribe send all known states
    mqtt.1
    	2023-02-16 20:53:56.626	info	Client [NSPanel_01] publishOnSubscribe send all known states
    mqtt.1
    	2023-02-16 20:53:56.625	info	Client [NSPanel_01] publishOnSubscribe send all known states
    mqtt.1
    	2023-02-16 20:53:56.426	info	Client [NSPanel_01] subscribes on "cmnd/NSPanel_01_fb/#" with regex /^mqtt\.1\.cmnd\.NSPanel_01_fb(\..*)?/
    mqtt.1
    	2023-02-16 20:53:56.426	info	Client [NSPanel_01] subscribes on "cmnd/NSPanel_01_fb/#" with regex /^cmnd\.NSPanel_01_fb(\..*)?/
    mqtt.1
    	2023-02-16 20:53:56.426	info	Client [NSPanel_01] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt\.1\.SmartHome\.tasmotas\.cmnd(\..*)?/
    mqtt.1
    	2023-02-16 20:53:56.426	info	Client [NSPanel_01] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd(\..*)?/
    mqtt.1
    	2023-02-16 20:53:56.425	info	Client [NSPanel_01] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^mqtt\.1\.SmartHome\.NSPanel_1\.cmnd(\..*)?/
    mqtt.1
    	2023-02-16 20:53:56.425	info	Client [NSPanel_01] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^SmartHome\.NSPanel_1\.cmnd(\..*)?/
    mqtt.1
    	2023-02-16 20:53:56.369	info	Client [NSPanel_01] reconnected. Old secret 1676577213300_2907. New secret 1676577236366_5097
    mqtt.1
    	2023-02-16 20:53:33.578	info	Client [NSPanel_01] publishOnSubscribe send all known states
    mqtt.1
    	2023-02-16 20:53:33.577	info	Client [NSPanel_01] publishOnSubscribe send all known states
    mqtt.1
    	2023-02-16 20:53:33.575	info	Client [NSPanel_01] publishOnSubscribe send all known states
    mqtt.1
    	2023-02-16 20:53:33.376	info	Client [NSPanel_01] subscribes on "cmnd/NSPanel_01_fb/#" with regex /^mqtt\.1\.cmnd\.NSPanel_01_fb(\..*)?/
    mqtt.1
    	2023-02-16 20:53:33.376	info	Client [NSPanel_01] subscribes on "cmnd/NSPanel_01_fb/#" with regex /^cmnd\.NSPanel_01_fb(\..*)?/
    mqtt.1
    	2023-02-16 20:53:33.376	info	Client [NSPanel_01] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt\.1\.SmartHome\.tasmotas\.cmnd(\..*)?/
    mqtt.1
    	2023-02-16 20:53:33.375	info	Client [NSPanel_01] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd(\..*)?/
    mqtt.1
    	2023-02-16 20:53:33.375	info	Client [NSPanel_01] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^mqtt\.1\.SmartHome\.NSPanel_1\.cmnd(\..*)?/
    mqtt.1
    	2023-02-16 20:53:33.374	info	Client [NSPanel_01] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^SmartHome\.NSPanel_1\.cmnd(\..*)?/
    mqtt.1
    	2023-02-16 20:53:33.303	info	Client [NSPanel_01] connected with secret 1676577213300_2907
    mqtt.1
    	2023-02-16 20:53:32.506	info	Starting MQTT-WebSocket authenticated server on 0.0.0.0:1887
    mqtt.1
    	2023-02-16 20:53:32.506	info	Starting MQTT authenticated server on 0.0.0.0:1886
    Keine Fehler im Log
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    • GregorSG GregorS
      @armilar
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      mqtt.1
      Keine Fehler im Log
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      @gregors
      okay jetzt mal in der Tasmota-Console:
      Backlog UpdateDriverVersion https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be; Restart 1
      dann sollte das Panel rebooten
      danach
      FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.9.4.tft
      ArmilarA GregorSG 2 Antworten Letzte Antwort
      • ArmilarA Armilar
        @gregors
        danach
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        @armilar
        Wie sehen die Config Parameter bei dir aus?
        export const config = <Config> {
            panelRecvTopic: 'mqtt.1.SmartHome.NSPanel_1.tele.RESULT',       // Bitte anpassen
            panelSendTopic: 'mqtt.1.SmartHome.NSPanel_1.cmnd.CustomSend',   // Bitte anpassen
        GregorSG 1 Antwort Letzte Antwort
        • ArmilarA Armilar
          @gregors
          danach
          GregorSG Offline
          GregorSG Offline
          GregorS
          @armilar
          Habe beide Befehle nacheinander ausgeführt, Panel hat neu gebootet und das flashen wurde auch ausgeführt.
          21:01:43.911 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2023-02-16T21:01:43","Uptime":"0T00:01:40","UptimeSec":100,"Heap":152,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":240},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"GS-Net","BSSId":"CC:CE:1E:AD:6B:A8","Channel":10,"Mode":"11n","RSSI":100,"Signal":-43,"LinkCount":1,"Downtime":"0T00:00:04"}}
          21:01:43.957 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2023-02-16T21:01:43","ANALOG":{"Temperature1":19.8},"ESP32":{"Temperature":48.1},"TempUnit":"C"}
          21:01:48.685 MQT: SmartHome/NSPanel_1/tele/RESULT = {"CustomRecv":"event,startup,49,eu"}
          • GregorSG GregorS
            @armilar
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            @gregors
            Sende mal die Config Paramater aus dem Post darüber.
            • ArmilarA Armilar
              @armilar
              GregorSG Offline
              GregorSG Offline
              GregorS
              @armilar
              export const config: Config = {
              Hatte ich lt. dem Video angepasst
              • ArmilarA Armilar
                @gregors
                GregorSG Offline
                GregorSG Offline
                GregorS
                @armilar
                Welche Config Parameter meinst du?
                • GregorSG GregorS
                  @armilar
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  @gregors
                  okay, das Panel hat einen Pfad mit Datenpunkte in 0_userdata angelegt. Den mal löschen. Dann das TypeScript nochmal starten...
                  komplett löschen
                  • GregorSG GregorS
                    @armilar
                    ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    @gregors
                    die
                    Die aus dem Script aus deinem Post davor
                    • ArmilarA Armilar
                      @gregors
                      komplett löschen
                      GregorSG Offline
                      GregorSG Offline
                      GregorS
                      @armilar
                      Die Datenpunkte hat das Script neu angelegt.
                      Aber die Struktur ist jetzt anders.
                      Hier die alte Struktur
                      ArmilarA 3 Antworten Letzte Antwort
                      • GregorSG GregorS
                        @armilar
                        ArmilarA Offline
                        ArmilarA Offline
                        Armilar
                        @gregors
                        Das was du alte Struktur nennst ist der Screenshot aus den MQTT Objekten, nicht 0_userdata
                        • ArmilarA Armilar
                          @gregors
                          GregorSG Offline
                          GregorSG Offline
                          GregorS
                          @armilar
                          Jup, hab ich gerade auch gesehen 😬
                          • GregorSG GregorS
                            @armilar
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            @gregors
                            Wie sehen denn die tele Datenpunkte im mqtt.1. aus?
                            EDIT: Du hast da aber keinen Mosquitto oder eine andere Fehlerquelle dazwischen, oder?
                            Port 1886 jetzt auch in Tasmota?
                            • ArmilarA Armilar
                              @gregors
                              GregorSG Offline
                              GregorSG Offline
                              GregorS
                              schrieb am zuletzt editiert von GregorS
                              @armilar
                              Info1
                              {"Info1":{"Module":"NSPanel","Version":"12.3.1.3(tasmota32-SONOFF_NSPANEL_DE)","FallbackTopic":"cmnd/NSPanel_01_fb/","GroupTopic":"SmartHome/tasmotas/cmnd/"}}
                              Info2
                              {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanel-1-3720","IPAddress":"192.168.10.130","IP6Global":"","IP6Local":"fe80::c6dd:57ff:fee7:ee88"}}
                              Info3
                              {"Info3":{"RestartReason":"Software reset CPU","BootCount":53}}
                              Result
                              State
                              {"Time":"2023-02-16T21:22:53","Uptime":"0T00:22:50","UptimeSec":1370,"Heap":151,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":240},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"GS-Net","BSSId":"CC:CE:1E:AD:6B:A8","Channel":10,"Mode":"11n","RSSI":100,"Signal":-44,"LinkCount":1,"Downtime":"0T00:00:04"}}
                              Nein, alles dirket. NSPanel -> ioBroker
                              NSPanel hat jetzt ebenfalls 1886 in den mqtt-Einstellungen
                              • GregorSG GregorS
                                @armilar
                                Info1
                                Info2
                                Info3
                                Result
                                State
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                @gregors
                                Die Empfangsrichtung ist perfekt. Verstehe im Moment nur nicht, warum der CustomSend da nichts sendet. Das Script befeuert den ja schon mit Daten
                                Gib mal einfach nur folgendes in die Tasmota-Console
                                CustomSend time~21:30
                                • ArmilarA Armilar
                                  @gregors
                                  GregorSG Offline
                                  GregorSG Offline
                                  GregorS
                                  @armilar said in Brauche Hilfe beim NSPanel mit Tasmota:
                                  21:30:09.186 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                  21:30:12.958 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2023-02-16T21:30:12","Uptime":"0T00:01:28","UptimeSec":88,"Heap":145,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":595,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":239},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"GS-Net","BSSId":"CC:CE:1E:AD:6B:A8","Channel":10,"Mode":"11n","RSSI":100,"Signal":-45,"LinkCount":1,"Downtime":"0T00:00:03"}}
                                  21:30:13.004 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2023-02-16T21:30:12","ANALOG":{"Temperature1":20.4},"ESP32":{"Temperature":49.2},"TempUnit":"C"}
                                  21:30:14.770 MQT: SmartHome/NSPanel_1/tele/RESULT = {"CustomRecv":"event,startup,49,eu"}
                                  21:30:20.770 MQT: SmartHome/NSPanel_1/tele/RESULT = {"CustomRecv":"event,startup,49,eu"}
                                  21:30:22.959 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2023-02-16T21:30:22","Uptime":"0T00:01:38","UptimeSec":98,"Heap":147,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":634,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":240},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"GS-Net","BSSId":"CC:CE:1E:AD:6B:A8","Channel":10,"Mode":"11n","RSSI":100,"Signal":-44,"LinkCount":1,"Downtime":"0T00:00:03"}}
                                  21:30:22.999 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2023-02-16T21:30:22","ANALOG":{"Temperature1":20.4},"ESP32":{"Temperature":49.8},"TempUnit":"C"}
                                  21:30:26.671 MQT: SmartHome/NSPanel_1/tele/RESULT = {"CustomRecv":"event,startup,49,eu"}
                                  21:30:32.672 MQT: SmartHome/NSPanel_1/tele/RESULT = {"CustomRecv":"event,startup,49,eu"}
                                  21:30:32.958 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2023-02-16T21:30:32","Uptime":"0T00:01:48","UptimeSec":108,"Heap":147,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":670,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":240},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"GS-Net","BSSId":"CC:CE:1E:AD:6B:A8","Channel":10,"Mode":"11n","RSSI":100,"Signal":-43,"LinkCount":1,"Downtime":"0T00:00:03"}}
                                  21:30:33.003 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2023-02-16T21:30:32","ANALOG":{"Temperature1":20.4},"ESP32":{"Temperature":49.8},"TempUnit":"C"}
                                  • GregorSG GregorS
                                    ArmilarA Offline
                                    ArmilarA Offline
                                    Armilar
                                    @gregors
                                    und das Ding dreht sich immer noch?
                                    • ArmilarA Armilar
                                      @gregors
                                      GregorSG Offline
                                      GregorSG Offline
                                      GregorS
                                      @armilar
                                      Hat bald einen Drehwurm.
                                      Keine Änderung
                                      • GregorSG GregorS
                                        @armilar
                                        Keine Änderung
                                        ArmilarA Offline
                                        ArmilarA Offline
                                        Armilar
                                        @gregors
                                        ioBroker mal durchgestartet?
                                        • ArmilarA Armilar
                                          @gregors
                                          GregorSG Offline
                                          GregorSG Offline
                                          GregorS
                                          @armilar
                                          iobroker neu gestartet, NSPanel Kaltstart
                                          Und es dreht sich immer noch 😕
