  4. [Neuer Adapter] radar-trap
255 Beiträge 27 Kommentatoren 72.1k Aufrufe 22 Beobachtet
  • O Oli
    @carsten04
    Fehlermeldungen aus der Instanz
    websocket.js:124 WebSocket connection to 'ws://192.168.2.120:3040/socket.io/?EIO=3&transport=websocket' failed:
    Pc.doOpen @ websocket.js:124
    Kf.open @ transport.js:84
    cn.open @ socket.js:250
    cn @ socket.js:122
    cn @ socket.js:28
    Pn.open.Pn.connect @ manager.js:226
    (anonym) @ manager.js:544
    cn @ socket.js:122
    cn @ socket.js:28
    browser-layer.js:92          GET https://api.mapbox.com/geocoding/v5/mapbox.places/xxxxxxxxxxxxxxxxxxxxxxxxxxxxx.json?language=de&types=address%2Cpoi&limit=1&access_token=XXXXXXXXXXXXXXXXXXXXXXXXXXXXAvM61g 401 (Unauthorized)
    (anonym) @ browser-layer.js:92
    zje @ browser-layer.js:38
    (anonym) @ browser-layer.js:116
    Promise.then (async)
    LVt @ browser-layer.js:114
    Hy.send @ mapi-request.js:160
    (anonym) @ RouteGeocoderField.tsx:62
    S2t @ react-dom.production.min.js:262
    jn.unstable_runWithPriority @ scheduler.production.min.js:18
    i_ @ react-dom.production.min.js:122
    My @ react-dom.production.min.js:261
    IK @ react-dom.production.min.js:243
    (anonym) @ react-dom.production.min.js:123
    cEe @ react-dom.production.min.js:123
    jf @ react-dom.production.min.js:122
    x2t @ react-dom.production.min.js:244
    GK @ react-dom.production.min.js:292
    HK @ react-dom.production.min.js:49
    QRt @ react-dom.production.min.js:50
    tEe @ react-dom.production.min.js:105
    QK @ react-dom.production.min.js:75
    JK @ react-dom.production.min.js:74
    ESe @ react-dom.production.min.js:292
    gkt @ react-dom.production.min.js:73
    index_m.html:1 Uncaught (in promise) RVt {message: 'Not Authorized - Invalid Token', type: 'HttpError', statusCode: 401, request: Hy, body: {…}}
    (anonym) @ RouteGeocoderField.tsx:63
    carsten04C Offline
    carsten04C Offline
    carsten04
    @oli Das hilft mir schon mal weiter. Danke Dir.
    O 1 Antwort Letzte Antwort
    • carsten04C carsten04
      O Offline
      O Offline
      Oli
      @carsten04
      gerne
      Oliver
      carsten04C 1 Antwort Letzte Antwort
      • O Oli
        @carsten04
        gerne
        carsten04C Offline
        carsten04C Offline
        carsten04
        schrieb am zuletzt editiert von carsten04
        @oli Hinweis: Dein Token ist definitiv ungültig. Das müsstest Du mal checken. Der Rest könnten Folgefehler seien. Am Besten Du erstellst Dir ein neues Token und nutzt nicht den Default public token. Wenn der Token korrekt ist, kannst Du auf jeden Fall im Tab KARTEN schon einmal eine Karte ohne Route sehen.
        • O Offline
          O Offline
          oxident
          Also bei mir tritt das VIS-Problem ja auch auf, nutze aber weder Docker noch Proxy. Die Routenerstellung funktioniert jedoch und der Feathers-Port ist verfügbar.
          • O oxident
            carsten04C Offline
            carsten04C Offline
            carsten04
            @oxident Du siehst dann im Admin unter Karten auch die eingegebenen Routen und die Hindernisse, richtig?
              O Offline
              O Offline
              oxident
              @carsten04 Ja, soweit alles ok!
              • O oxident
                carsten04C Offline
                carsten04C Offline
                carsten04
                @oxident Kannst Du mal bitte bei offener Dev-Konsole die VIS-Runtime mit F5 aktualisieren und vorher ein map-Widget auf die view ziehen und die Ausgabe (also nach Aktualisierung mit F5) dann hier posten.
                  O Offline
                  O Offline
                  Oli
                  @carsten04
                  es wird immer kurioser, Routen kann ich jetzt anlegen, allerdings nur mit folgender Web Adapter Einstellungen
                  Mit allen anderen Einstellungen funktioniert es nicht!!!!!
                  Dann bekomme ich aber folgende Fehlermeldungen im VIS Editor
                  VM2282:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
                     at JSON.parse (<anonymous>)
                     at getTranslation (info.js:13:47)
                  getTranslation @ info.js:13
                  await in getTranslation (async)
                  (anonym) @ info.js:6
                  jquery-1.11.2.min.js:4          GET http://192.168.2.120:8082/vis/adapter/rssfeed/words.js 404 (Not Found)
                  send @ jquery-1.11.2.min.js:4
                  ajax @ jquery-1.11.2.min.js:4
                  m.<computed> @ jquery-1.11.2.min.js:4
                  (anonym) @ rssfeed.js:15
                  index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=OOy4utq 404 (Not Found)
                  i.create @ index.js:83
                  i @ index.js:83
                  o.request @ index.js:83
                  o.doPoll @ index.js:83
                  r.poll @ index.js:83
                  r.doOpen @ index.js:83
                  r.open @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  r.open.r.connect @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  init @ conn.js:266
                  main @ vis.js:3649
                  (anonym) @ vis.js:3935
                  j @ jquery-1.11.2.min.js:2
                  fireWith @ jquery-1.11.2.min.js:2
                  ready @ jquery-1.11.2.min.js:2
                  J @ jquery-1.11.2.min.js:2
                  index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=OOy4xWa 404 (Not Found)
                  i @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  (anonym) @ conn.js:158
                  setInterval (async)
                  reconnect @ conn.js:156
                  (anonym) @ conn.js:363
                  r.emit @ index.js:83
                  r.emitAll @ index.js:83
                  (anonym) @ index.js:83
                  r.onError @ index.js:83
                  i.onError @ index.js:83
                  setTimeout (async)
                  hasXDR.e.onreadystatechange @ index.js:83
                  XMLHttpRequest.send (async)
                  i @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  init @ conn.js:266
                  main @ vis.js:3649
                  index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=OOy4zyr 404 (Not Found)
                  i @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  setInterval (async)
                  setTimeout (async)
                  i @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  init @ conn.js:266
                  main @ vis.js:3649
                  index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=OOy50P5 404 (Not Found)
                  i @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  setInterval (async)
                  setTimeout (async)
                  i @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  r @ index.js:83
                  init @ conn.js:266
                  main @ vis.js:3649
                  Mit dieser Web Adapter Einstellung, kann ich keine Routen speichern und bekomme unten angehängte Fehlermeldungen
                  VM106:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
                  vis-editor.css:1          GET http://192.168.2.120:8082/vis/icon/dimmer.png 404 (Not Found)
                  visEditInspect.js:2276 Uncaught TypeError: Cannot read properties of undefined (reading 'widgets')
                     at HTMLDivElement.<anonymous> (visEditInspect.js:2276:46)
                     at Function.each (jquery-1.11.2.min.js:2:2975)
                     at m.fn.init.each (jquery-1.11.2.min.js:2:835)
                     at Object.inspectWidgets (visEditInspect.js:2269:49)
                     at vis.js:3630:29
                     at r.<anonymous> (conn.js:936:45)
                     at r.onack (index.js:83:1)
                     at r.onpacket (index.js:83:1)
                     at r.<anonymous> (index.js:83:1)
                     at r.emit (index.js:83:1)
                     at r.ondecoded (index.js:83:1)
                     at a.<anonymous> (index.js:83:1)
                     at a.add (index.js:83:1)
                     at r.ondata (index.js:83:1)
                     at r.onPacket (index.js:83:1)
                     at r.onData (index.js:83:1)
                     at ws.onmessage (index.js:83:1)
                  (anonym) @ visEditInspect.js:2276
                  each @ jquery-1.11.2.min.js:2
                  inspectWidgets @ visEditInspect.js:2269
                  (anonym) @ vis.js:3630
                  (anonym) @ conn.js:936
                  r.onack @ index.js:83
                  r.onpacket @ index.js:83
                  r.ondecoded @ index.js:83
                  a.add @ index.js:83
                  r.ondata @ index.js:83
                  r.onPacket @ index.js:83
                  r.onData @ index.js:83
                  ws.onmessage @ index.js:83
                  Oliver
                  • O Oli
                    @carsten04
                    i @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    init @ conn.js:266
                    main @ vis.js:3649
                    i @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    setInterval (async)
                    setTimeout (async)
                    i @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    init @ conn.js:266
                    main @ vis.js:3649
                    i @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    setInterval (async)
                    setTimeout (async)
                    i @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    init @ conn.js:266
                    main @ vis.js:3649
                    i @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    setInterval (async)
                    setTimeout (async)
                    i @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    init @ conn.js:266
                    main @ vis.js:3649
                       at vis.js:3630:29
                    a.add @ index.js:83
                    carsten04C Offline
                    carsten04C Offline
                    carsten04
                    @oli Ich kümmere mich morgen darum, hab aber jetzt eine Idee woran es liegen könnte. Dein Token war ungültig, richtig?
                      O Offline
                      O Offline
                      Oli
                      @carsten04
                      Ja, habe mir einen neuen geholt
                      Oliver
                      • O Oli
                        @carsten04
                        carsten04C Offline
                        carsten04C Offline
                        carsten04
                        @oli @oxident Es gibt eine aktualisierte v1.0 auf GitHub. Bitte noch einmal neu installieren und vorher die Instanz und den Adapter sauber löschen. Ich habe an der socket-Konfiguration für den Adapter noch ein paar Änderungen vorgenommen und hoffe, dass es auch mit der VIS v1.4.15 jetzt läuft.
                        O O 2 Antworten Letzte Antwort
                          O Offline
                          O Offline
                          Oli
                          @carsten04
                          erstmal vielen Dank für deine Arbeit, die du hier investierst.
                          Mit der neuen Version kann ich Routen anlegen, der Verbindungsfehler in der VIS ist weg, allerdings wir mir im Widget nichts angezeigt.
                          Fehlermeldungen aus der Konsole:
                          VM4404:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
                          radar-trap2.js:174 Uncaught TypeError: io is not a function
                              at radar-trap2.js:174:15
                              at SocketClient.findAnswer (socket.io.js:294:20)
                              at socket.onmessage (socket.io.js:202:22)
                          (anonym) @ radar-trap2.js:174
                          SocketClient.findAnswer @ socket.io.js:294
                          socket.onmessage @ socket.io.js:202
                          radar-trap2.js:803 Uncaught (in promise) TypeError: Cannot read properties of null (reading 'get')
                              at Object.initAsync (radar-trap2.js:803:20)
                              at radar-trap2.js:776:42
                              at sentryWrapped (helpers.ts:87:17)
                          initAsync @ radar-trap2.js:803
                          (anonym) @ radar-trap2.js:776
                          sentryWrapped @ helpers.ts:87
                          Oliver
                            O Offline
                            O Offline
                            oxident
                            @carsten04 Sorry, bei mir sieht's leider ganz anders aus. Mit der neuen Version (nur installiert, keine Instanz angelegt) startet VIS überhaupt nicht mehr.
                            Habe dazu ein Issue angelegt...
                            https://github.com/Steiger04/ioBroker.radar-trap2/issues/1
                            • O oxident
                              O Offline
                              O Offline
                              Oli
                              @oxident
                              welche Einstellungen hast du im Web Adapter?
                              Oliver
                              • O Oli
                                @oxident
                                O Offline
                                O Offline
                                oxident
                                @oli Eigentlich ganz normal:
                                Version ist 5.4.3
                                • O oxident
                                  Version ist 5.4.3
                                  O Offline
                                  O Offline
                                  Oli
                                  @oxident
                                  versuche es mal, wenn bei "Reine Web-Sockets (iobroker.ws) verwenden" ein Haken drin ist, so funktioniert es bei mir
                                  Oliver
                                  • O Oli
                                    @oxident
                                    O Offline
                                    O Offline
                                    oxident
                                    schrieb am zuletzt editiert von oxident
                                    @oli Hmm, dann klappt leider bei mir der VIS-Editor nicht mehr (speichert nicht mehr) ... ist'ne andere Geschichte wofür ich extra eine zweite Web-Instanz aufgesetzt habe.
                                    Vermutlich muss ich diese Baustelle dann erstmal klären bevor ich Deinen (wirklich tollen!) Adapter weiter testen kann. Aber danke für Deine Hilfestellung ;-)
                                    • O oxident
                                      O Offline
                                      O Offline
                                      Oli
                                      @oxident
                                      ist nicht mein Adapter, sondern der von @carsten04 ;-)
                                      Oliver
                                      • O Oli
                                        @oxident
                                        O Offline
                                        O Offline
                                        oxident
                                        @oli Hoppla, natürlich. Trotzdem danke...
                                        • O oxident
                                          carsten04C Offline
                                          carsten04C Offline
                                          carsten04
                                          #66
                                          @oli Hast Du es auch mal ohne Haken bei ws mit der aktuellen Version versucht (also wirklich nichts angehakt im web-Adapter)?
                                          Die Fehler in Deinem Log bis Zeile 11 haben nichts mit meinem Adapter zu tun. Da ist noch was anderes nicht in Ordnung. Einmal musst Du den rssfeed-Adapter installiert haben und in der VIS kann bei den Widgets nicht word.js gefunden werden und an irgend einer anderen Stelle wirft er bei getTranslation einen Fehler. Das kommt auch von irgendwelchen VIS-Widgets die Du noch installiert hast.
