  4. [Neuer Adapter] radar-trap
255 Beiträge 27 Kommentatoren 72.1k Aufrufe 22 Beobachtet
  • carsten04C carsten04
    @oli Mhm, das ist alles sehr merkwürdig. Hast Du den feathers-Port eventuell schon anderweitig vergeben? Kannst Du einmal bei geöffneter dev-Konsole die Instanz neu starten und schauen, ob da irgendetwas kommt?
    O Offline
    O Offline
    Oli
    schrieb am zuletzt editiert von Oli
    @carsten04
    Fehlermeldungen aus der Instanz
    websocket.js:124 WebSocket connection to 'ws://192.168.2.120:3040/socket.io/?EIO=3&transport=websocket' failed:
    Pc.doOpen @ websocket.js:124
    Kf.open @ transport.js:84
    cn.open @ socket.js:250
    cn @ socket.js:122
    cn @ socket.js:28
    Pn.open.Pn.connect @ manager.js:226
    (anonym) @ manager.js:544
    cn @ socket.js:122
    cn @ socket.js:28
    browser-layer.js:92          GET https://api.mapbox.com/geocoding/v5/mapbox.places/xxxxxxxxxxxxxxxxxxxxxxxxxxxxx.json?language=de&types=address%2Cpoi&limit=1&access_token=XXXXXXXXXXXXXXXXXXXXXXXXXXXXAvM61g 401 (Unauthorized)
    (anonym) @ browser-layer.js:92
    zje @ browser-layer.js:38
    (anonym) @ browser-layer.js:116
    Promise.then (async)
    LVt @ browser-layer.js:114
    Hy.send @ mapi-request.js:160
    (anonym) @ RouteGeocoderField.tsx:62
    S2t @ react-dom.production.min.js:262
    jn.unstable_runWithPriority @ scheduler.production.min.js:18
    i_ @ react-dom.production.min.js:122
    My @ react-dom.production.min.js:261
    IK @ react-dom.production.min.js:243
    (anonym) @ react-dom.production.min.js:123
    cEe @ react-dom.production.min.js:123
    jf @ react-dom.production.min.js:122
    x2t @ react-dom.production.min.js:244
    GK @ react-dom.production.min.js:292
    HK @ react-dom.production.min.js:49
    QRt @ react-dom.production.min.js:50
    tEe @ react-dom.production.min.js:105
    QK @ react-dom.production.min.js:75
    JK @ react-dom.production.min.js:74
    ESe @ react-dom.production.min.js:292
    gkt @ react-dom.production.min.js:73
    index_m.html:1 Uncaught (in promise) RVt {message: 'Not Authorized - Invalid Token', type: 'HttpError', statusCode: 401, request: Hy, body: {…}}
    (anonym) @ RouteGeocoderField.tsx:63
    Oliver
    carsten04C 1 Antwort Letzte Antwort
    • O Oli
      @carsten04
      cn @ socket.js:122
      cn @ socket.js:28
      cn @ socket.js:122
      cn @ socket.js:28
      carsten04C Offline
      carsten04C Offline
      carsten04
      @oli Das hilft mir schon mal weiter. Danke Dir.
      O 1 Antwort Letzte Antwort
        O Offline
        O Offline
        Oli
        @carsten04
        gerne
        Oliver
        • O Oli
          @carsten04
          gerne
          carsten04C Offline
          carsten04C Offline
          carsten04
          schrieb am zuletzt editiert von carsten04
          @oli Hinweis: Dein Token ist definitiv ungültig. Das müsstest Du mal checken. Der Rest könnten Folgefehler seien. Am Besten Du erstellst Dir ein neues Token und nutzt nicht den Default public token. Wenn der Token korrekt ist, kannst Du auf jeden Fall im Tab KARTEN schon einmal eine Karte ohne Route sehen.
          • O Offline
            O Offline
            oxident
            Also bei mir tritt das VIS-Problem ja auch auf, nutze aber weder Docker noch Proxy. Die Routenerstellung funktioniert jedoch und der Feathers-Port ist verfügbar.
            • O oxident
              carsten04C Offline
              carsten04C Offline
              carsten04
              @oxident Du siehst dann im Admin unter Karten auch die eingegebenen Routen und die Hindernisse, richtig?
                O Offline
                O Offline
                oxident
                @carsten04 Ja, soweit alles ok!
                • O oxident
                  carsten04C Offline
                  carsten04C Offline
                  carsten04
                  @oxident Kannst Du mal bitte bei offener Dev-Konsole die VIS-Runtime mit F5 aktualisieren und vorher ein map-Widget auf die view ziehen und die Ausgabe (also nach Aktualisierung mit F5) dann hier posten.
                    O Offline
                    O Offline
                    Oli
                    @carsten04
                    es wird immer kurioser, Routen kann ich jetzt anlegen, allerdings nur mit folgender Web Adapter Einstellungen
                    Mit allen anderen Einstellungen funktioniert es nicht!!!!!
                    Dann bekomme ich aber folgende Fehlermeldungen im VIS Editor
                    VM2282:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
                       at JSON.parse (<anonymous>)
                       at getTranslation (info.js:13:47)
                    getTranslation @ info.js:13
                    await in getTranslation (async)
                    (anonym) @ info.js:6
                    jquery-1.11.2.min.js:4          GET http://192.168.2.120:8082/vis/adapter/rssfeed/words.js 404 (Not Found)
                    send @ jquery-1.11.2.min.js:4
                    ajax @ jquery-1.11.2.min.js:4
                    m.<computed> @ jquery-1.11.2.min.js:4
                    (anonym) @ rssfeed.js:15
                    index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=OOy4utq 404 (Not Found)
                    i.create @ index.js:83
                    i @ index.js:83
                    o.request @ index.js:83
                    o.doPoll @ index.js:83
                    r.poll @ index.js:83
                    r.doOpen @ index.js:83
                    r.open @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r.open.r.connect @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    init @ conn.js:266
                    main @ vis.js:3649
                    (anonym) @ vis.js:3935
                    j @ jquery-1.11.2.min.js:2
                    fireWith @ jquery-1.11.2.min.js:2
                    ready @ jquery-1.11.2.min.js:2
                    J @ jquery-1.11.2.min.js:2
                    index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=OOy4xWa 404 (Not Found)
                    i @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    (anonym) @ conn.js:158
                    setInterval (async)
                    reconnect @ conn.js:156
                    (anonym) @ conn.js:363
                    r.emit @ index.js:83
                    r.emitAll @ index.js:83
                    (anonym) @ index.js:83
                    r.onError @ index.js:83
                    i.onError @ index.js:83
                    setTimeout (async)
                    hasXDR.e.onreadystatechange @ index.js:83
                    XMLHttpRequest.send (async)
                    i @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    init @ conn.js:266
                    main @ vis.js:3649
                    index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=OOy4zyr 404 (Not Found)
                    i @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    setInterval (async)
                    setTimeout (async)
                    i @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    init @ conn.js:266
                    main @ vis.js:3649
                    index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=OOy50P5 404 (Not Found)
                    i @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    setInterval (async)
                    setTimeout (async)
                    i @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    r @ index.js:83
                    init @ conn.js:266
                    main @ vis.js:3649
                    Mit dieser Web Adapter Einstellung, kann ich keine Routen speichern und bekomme unten angehängte Fehlermeldungen
                    VM106:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
                    vis-editor.css:1          GET http://192.168.2.120:8082/vis/icon/dimmer.png 404 (Not Found)
                    visEditInspect.js:2276 Uncaught TypeError: Cannot read properties of undefined (reading 'widgets')
                       at HTMLDivElement.<anonymous> (visEditInspect.js:2276:46)
                       at Function.each (jquery-1.11.2.min.js:2:2975)
                       at m.fn.init.each (jquery-1.11.2.min.js:2:835)
                       at Object.inspectWidgets (visEditInspect.js:2269:49)
                       at vis.js:3630:29
                       at r.<anonymous> (conn.js:936:45)
                       at r.onack (index.js:83:1)
                       at r.onpacket (index.js:83:1)
                       at r.<anonymous> (index.js:83:1)
                       at r.emit (index.js:83:1)
                       at r.ondecoded (index.js:83:1)
                       at a.<anonymous> (index.js:83:1)
                       at a.add (index.js:83:1)
                       at r.ondata (index.js:83:1)
                       at r.onPacket (index.js:83:1)
                       at r.onData (index.js:83:1)
                       at ws.onmessage (index.js:83:1)
                    (anonym) @ visEditInspect.js:2276
                    each @ jquery-1.11.2.min.js:2
                    inspectWidgets @ visEditInspect.js:2269
                    (anonym) @ vis.js:3630
                    (anonym) @ conn.js:936
                    r.onack @ index.js:83
                    r.onpacket @ index.js:83
                    r.ondecoded @ index.js:83
                    a.add @ index.js:83
                    r.ondata @ index.js:83
                    r.onPacket @ index.js:83
                    r.onData @ index.js:83
                    ws.onmessage @ index.js:83
                    Oliver
                    • O Oli
                      @carsten04
                      i @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      init @ conn.js:266
                      main @ vis.js:3649
                      i @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      setInterval (async)
                      setTimeout (async)
                      i @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      init @ conn.js:266
                      main @ vis.js:3649
                      i @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      setInterval (async)
                      setTimeout (async)
                      i @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      init @ conn.js:266
                      main @ vis.js:3649
                      i @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      setInterval (async)
                      setTimeout (async)
                      i @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      r @ index.js:83
                      init @ conn.js:266
                      main @ vis.js:3649
                         at vis.js:3630:29
                      a.add @ index.js:83
                      carsten04C Offline
                      carsten04C Offline
                      carsten04
                      @oli Ich kümmere mich morgen darum, hab aber jetzt eine Idee woran es liegen könnte. Dein Token war ungültig, richtig?
                        O Offline
                        O Offline
                        Oli
                        @carsten04
                        Ja, habe mir einen neuen geholt
                        Oliver
                        • O Oli
                          @carsten04
                          carsten04C Offline
                          carsten04C Offline
                          carsten04
                          @oli @oxident Es gibt eine aktualisierte v1.0 auf GitHub. Bitte noch einmal neu installieren und vorher die Instanz und den Adapter sauber löschen. Ich habe an der socket-Konfiguration für den Adapter noch ein paar Änderungen vorgenommen und hoffe, dass es auch mit der VIS v1.4.15 jetzt läuft.
                          O O 2 Antworten Letzte Antwort
                            O Offline
                            O Offline
                            Oli
                            @carsten04
                            erstmal vielen Dank für deine Arbeit, die du hier investierst.
                            Mit der neuen Version kann ich Routen anlegen, der Verbindungsfehler in der VIS ist weg, allerdings wir mir im Widget nichts angezeigt.
                            Fehlermeldungen aus der Konsole:
                            VM4404:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
                            radar-trap2.js:174 Uncaught TypeError: io is not a function
                                at radar-trap2.js:174:15
                                at SocketClient.findAnswer (socket.io.js:294:20)
                                at socket.onmessage (socket.io.js:202:22)
                            (anonym) @ radar-trap2.js:174
                            SocketClient.findAnswer @ socket.io.js:294
                            socket.onmessage @ socket.io.js:202
                            radar-trap2.js:803 Uncaught (in promise) TypeError: Cannot read properties of null (reading 'get')
                                at Object.initAsync (radar-trap2.js:803:20)
                                at radar-trap2.js:776:42
                                at sentryWrapped (helpers.ts:87:17)
                            initAsync @ radar-trap2.js:803
                            (anonym) @ radar-trap2.js:776
                            sentryWrapped @ helpers.ts:87
                            Oliver
                              O Offline
                              O Offline
                              oxident
                              @carsten04 Sorry, bei mir sieht's leider ganz anders aus. Mit der neuen Version (nur installiert, keine Instanz angelegt) startet VIS überhaupt nicht mehr.
                              Habe dazu ein Issue angelegt...
                              https://github.com/Steiger04/ioBroker.radar-trap2/issues/1
                              • O oxident
                                O Offline
                                O Offline
                                Oli
                                @oxident
                                welche Einstellungen hast du im Web Adapter?
                                Oliver
                                • O Oli
                                  @oxident
                                  O Offline
                                  O Offline
                                  oxident
                                  @oli Eigentlich ganz normal:
                                  Version ist 5.4.3
                                  • O oxident
                                    Version ist 5.4.3
                                    O Offline
                                    O Offline
                                    Oli
                                    @oxident
                                    versuche es mal, wenn bei "Reine Web-Sockets (iobroker.ws) verwenden" ein Haken drin ist, so funktioniert es bei mir
                                    Oliver
                                    • O Oli
                                      @oxident
                                      O Offline
                                      O Offline
                                      oxident
                                      schrieb am zuletzt editiert von oxident
                                      @oli Hmm, dann klappt leider bei mir der VIS-Editor nicht mehr (speichert nicht mehr) ... ist'ne andere Geschichte wofür ich extra eine zweite Web-Instanz aufgesetzt habe.
                                      Vermutlich muss ich diese Baustelle dann erstmal klären bevor ich Deinen (wirklich tollen!) Adapter weiter testen kann. Aber danke für Deine Hilfestellung ;-)
                                      • O oxident
                                        O Offline
                                        O Offline
                                        Oli
                                        @oxident
                                        ist nicht mein Adapter, sondern der von @carsten04 ;-)
                                        Oliver
                                        • O Oli
                                          @oxident
                                          O Offline
                                          O Offline
                                          oxident
                                          @oli Hoppla, natürlich. Trotzdem danke...
