  4. Raspberry Pi3+ SSD + SWAP
    5.4k
47 Beiträge 11 Kommentatoren 7.8k Aufrufe 8 Beobachtet
  • F Offline
    Foradh 0
    @thomas-braun sagte in Raspberry Pi3+ SSD + SWAP:
    iob diag
    Hi Thomas, anbei das Ergebnis
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
    Architecture:   aarch64
    Docker:         false
    Virtualization: none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     12:34:52 up 28 min,  1 user,  load average: 5.50, 7.64, 4.17
    CPU threads: 4
    *** Time and Time Zones ***
    Mon Feb  6 11:34:52 UTC 2023
    Mon Feb  6 12:34:52 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            909M        774M         39M        1.0M         95M         79M
    Swap:             0B          0B          0B
    Total:          909M        774M         39M
              909 M total memory
              775 M used memory
               37 M active memory
              753 M inactive memory
               39 M free memory
                7 M buffer memory
               87 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4      220G  8.0G  203G   4% /
    devtmpfs       devtmpfs  325M     0  325M   0% /dev
    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
    tmpfs          tmpfs     182M  1.1M  181M   1% /run
    /dev/sda1      vfat      255M   31M  225M  12% /boot
    tmpfs          tmpfs      91M   16K   91M   1% /run/user/1000
    Messages in dmesg:
    [Mon Feb  6 12:05:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0rootwait quiet splash plymouth.ignore-serial-consoles
    [Mon Feb  6 12:06:00 2023] EXT4-fs (sda2): INFO: recovery required on readonly f
    [Mon Feb  6 12:06:00 2023] EXT4-fs (sda2): write access will be enabled during r
    [Mon Feb  6 12:06:01 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Mon Feb  6 12:06:01 2023] EXT4-fs (sda2): 1 orphan inode deleted
    [Mon Feb  6 12:06:01 2023] EXT4-fs (sda2): recovery complete
    [Mon Feb  6 12:06:01 2023] EXT4-fs (sda2): mounted filesystem with ordered data
    [Mon Feb  6 12:06:01 2023] VFS: Mounted root (ext4 filesystem) readonly on devic
    [Mon Feb  6 12:06:04 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode:
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharse
    /var:
    3.3G    /var/
    2.1G    /var/log
    1.8G    /var/log/journal/277251c066b54e14abe3a8dd6d0d19d4
    406M    /var/lib
    /opt/iobroker/backups:
    375M    /opt/iobroker/backups/
    4.0K    /opt/iobroker/backups/influxDB_2023_01_27-12_11_58_backupiobroker
    /opt/iobroker/iobroker-data:
    205M    /opt/iobroker/iobroker-data/
    111M    /opt/iobroker/iobroker-data/files
    60M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    30M     /opt/iobroker/iobroker-data/objects.jsonl
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n
    5.1M    /opt/iobroker/iobroker-data/states.jsonl
    4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.0
    /usr/bin/node           v16.19.0
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
     *** 16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://security.debian.org/debian-security bullseye-security/main ar
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : RPI
      system.adapter.backitup.0               : backitup              : RPI
      system.adapter.daswetter.0              : daswetter             : RPI
      system.adapter.discovery.0              : discovery             : RPI
    + system.adapter.ebus.0                   : ebus                  : RPI
    + system.adapter.fronius.0                : fronius               : RPI
    + system.adapter.influxdb.0               : influxdb              : RPI
      system.adapter.info.0                   : info                  : RPI
    + system.adapter.iqontrol.0               : iqontrol              : RPI
    + system.adapter.javascript.0             : javascript            : RPI
      system.adapter.pvforecast.0             : pvforecast            : RPI
    + system.adapter.rpi2.0                   : rpi2                  : RPI
    + system.adapter.web.0                    : web                   : RPI
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.5.10   , installed 2.5.10
    Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
    Adapter    "ebus"         : 3.0.7    , installed 3.0.7
    Adapter    "fronius"      : 1.1.3    , installed 1.1.3
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "pvforecast"   : 2.3.0    , installed 2.5.1
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Objects and States
    Objects:        1600
    States:         1387
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:8 https://repo.ebusd.eu/apt/default/bullseye bullseye InRelease
    Reading package lists... Done
    • F Foradh 0
      iob diag
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Docker:         false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      CET +0100
      Europe/Berlin
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:             0B          0B          0B
                909 M total memory
                775 M used memory
                 37 M active memory
                 39 M free memory
                  7 M buffer memory
                 87 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      Messages in dmesg:
      /var:
      3.3G    /var/
      2.1G    /var/log
      406M    /var/lib
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        1600
      States:         1387
      @foradh-0
      Warum hast du denn bei dem mageren 1GB Arbeitsspeicher auch noch den SWAP ausgeschaltet?
      Das kann nicht funktionieren.
      L 1 Antwort Letzte Antwort
        @foradh-0
        Luxi
        @thomas-braun steht im ersten Post....
        • F Foradh 0
          Guten Abend zusammen,
          ich habe leider aktuell ein kleines Problem mit meinem iobroker System mit dem ich auf eine SSD umgezogen bin.
          System:
          Raspberry Pi 3 B+ mit bullseye
          iobroker mit ein paar Adaptern + Grafana
          Wie gesagt, bin ich mit diesem System von einer SD Karte auf eine SSD mit USB Adapter umgezogen.
          Hierbei musste ich feststellen, dass das System nach dem Umzug sich beim booten immer wieder aufgehängt hat. Nach etwas Überprüfung stelle ich fest, dass wenn ich die SWAP Funktion deaktiviere alles wieder ganz normal läuft. Da der Rpi 3 leider nur mit 1GB RAM daherkommt, kann ich ohne SWAP einen Adapter nicht nutzen, da sonst zu wenig RAM zur Verfügung steht.
          Nun zu meiner Frage...muss ich beim Umzug auf eine SSD evtl. etwas zusätzlich für die SWAP datei eingstellen?
          Ich weiß, das Thema passt eigentlich nicht ganz hier her, aber ich habe bisher so tolle Erfahrungen mit dem Forum gemacht und dachte ich propiere hier mal mein Glück.
          Vielen Dank
          Foradh
          Luxi
          @foradh-0
          In der Konstellation hatte ich auch immer wieder Probleme, wobei ich das Netzteil nicht als Problem wahrnahm.
          Besser funktionieren die USB-Sticks auf SSD-Basis z.B. SanDisk Extreme PRO.
          Aktuell funktioniert das auch super mit dem Raspi-PoE-Hat.
          Hattest du neu installiert und ein Restore gemacht oder alles per dd verschoben?
          LG
          Luxi
          F 1 Antwort Letzte Antwort
          • F Foradh 0
            System:
            Vielen Dank
            Foradh
            @foradh-0 sagte in Raspberry Pi3+ SSD + SWAP:
            Naja, dann würde ich mir dringend anschauen was da falsch läuft. Bei 1GB RAM würde ich Swap auch auf Minimum 1GB setzen, eher 1,5.
            • F Foradh 0
              System:
              Vielen Dank
              Foradh
              BananaJoeB Offline
              BananaJoeB Offline
              BananaJoe
              @foradh-0 ich hoffe diese Anleitung funktioniert noch:
              https://znil.net/index.php?title=Raspbian_-_Swap_File_verschieben_und_vergrößern
              Sieh zu das das Swapfile dann auf der SSD liegt ... liegt die aber schon, oder?
              Aber als Partition?
              • F Offline
                Foradh 0
                Vielen dank für euren Input. Ich hatte zuvor auf der SD Karte die Swap auf 1GB gestellt und das hat auch wunderbar funktioniert. Nur eben seit der Umstellung nicht mehr.
                @BananaJoe
                ich habe den Pfad bei /var/swap belassen. Da nur noch die SSD angeschlossen ist sollte das auch auf der SSD als Datei abgelegt sein.
                Als Partition hab ich das ganze nicht laufen
                • L Luxi
                  @foradh-0
                  LG
                  Luxi
                  Foradh 0
                  @luxi
                  Ich habe das System per Win23 disk imager von SD gesichert und auf die SSD zurückgespielt.
                  Dann mit raspi-config die Partition erweitert
                  • F Foradh 0
                    @luxi
                    Luxi
                    @foradh-0
                    da könnte der Hund begraben sein.
                    Dann können dir hier vielleicht die Linux-Profis helfen.
                    Ich hatte deswegen damals einfach iobroker neu installiert und aus dem Backup wiederhergestellt.
                    Bei Grafana geht das ähnlich.
                    LG
                    Luxi
                    • madingM Online
                      madingM Online
                      mading
                      Setze auch einen rpi4 mit ssd ein. Hatte eine USB Verlängerung verwendet, die einen Wackel hatte. Direkt eingesteckt __> läuft problemlos
                      • madingM mading
                        Foradh 0
                        @mading
                        Das kann ich in meinem Fall eigentlich auch ausschließen. Es läuft ja tatsächlich stabil wenn ich Swap deaktiviere. Die Probleme treten nur mit aktiviertem Swap auf
                        • F Foradh 0
                          @mading
                          also bei vielen Schreibzugriffen.
                          klingt fast nach USB3
                            Foradh 0
                            Meinst du ein bekanntes Problem mit USB3?
                            Es wird folgende Hardware verwendet.
                            SSD = Kingston A400 240GB
                            StarTech 2.5″ SATA adapter USB 3.0
                            • F Offline
                              Foradh 0
                              Ich habe mein Problem nun mit dem Tool Zram umgehen können.
                              Mit Zram kann man einen Teil des Arbeitsspeicher als Swap nutzen und den Inhalt darin komprimieren.
                              Ich habe 25% (227MB) für Zram reserviert und mit dem Faktor 3 komprimiert, dadurch erhalte ich 682MB Swap auf dem Arbeitsspeicher.
                              sudo cat /proc/swaps
                              Filename                                Type            Size            Used            Priority
                              /dev/zram0                              partition       698592          353024          75
                              free -h
                              Mem:           909Mi       694Mi        55Mi       0.0Ki       160Mi       160Mi
                              Swap:          682Mi       344Mi       337Mi
                              Nun kann ich wieder alle Adapter nutzen und der RPI läuft stabil.
                              Mich würde natürlich trotzdem interessieren warum der Swap auf der SSD nicht funktioniert.
                              Y 1 Antwort Letzte Antwort
                              • F Foradh 0
                                free -h
                                Y Offline
                                Y Offline
                                Ychsel
                                Danke an alle hier im Forum, die sich mit so wertvollen Beiträgen beteiligen. Ich habe auch ein SWAP Problem mit meinem 1GB Pi3 nach Installation mit Influx und Grafana gehabt und bin hierdurch zur Gewissheit gekommen, dass ich die Swap größe anpassen muss. Jetzt funktioniert es. Als nächstes kommt dann der SSD USB stick... Danke
                                • Y Ychsel
                                  @ychsel sagte in Raspberry Pi3+ SSD + SWAP:
                                  so ein Quatsch!
                                  der SWAP ist ein Notfall Auffangbehälter und sollte bei einer vernünftigen Installation gar nicht genutzt werden.
                                    kimukao
                                    @homoran Bin über diesen Beitrag gestolpert, da ich in letzter Zeit vermehrt Performance-Probleme bei meinem Pi4 4GB feststelle, auf dem iobroker (40 Adapter, 100 Skripte), Grafana, influxdb und deconz laufen. Nicht alle Skripte werden vollständig ausgeführt, es kommt bei der Ausführung zu unterschiedlich langen Wartezeiten, auch derr Zugriff auf die Konsole ist lahm. Gebootet wird von einer schnellen SSD Festplatte (Samsung), auf der auch die ganze Installation ist. Ich würde mich als Endanwender bezeichnen und habe keine Ahnung von Linux. In der "Hosts" Übersicht der Konsole sehe ich selten CPU Werte von unter 40%, manchmal sind es 80% oder sogar 100%. Der Swap Wert liegt gerade bei 47Mi, war eben aber auch schonmal bei 99Mi.
                                    pi@raspberrypi:~ $ free -h
                                                  gesamt       benutzt     frei      gemns.  Puffer/Cache verfügbar
                                    Speicher:      3,7Gi       2,7Gi       178Mi       0,0Ki       863Mi       1,2Gi
                                    Swap:           99Mi        47Mi        52Mi
                                    Hat jemand eine Idee, wo ich einen Fehler in der Installation gemacht haben könnte? Oder kommt der Pi einfach an seine Grenzen, sodass ich über stärkere Hardware nachdenken sollte? Ich habe noch nicht probiert, einen USB Hub mit eigenem Netzteil für die SSD zwischenzuschalten. Müsste ich erst besorgen. Wäre das evtl. ein Lösungsansatz? Vielen Dank im Voraus!
                                    Thomas BraunT HomoranH ? 3 Antworten Letzte Antwort
                                    • K kimukao
                                      @kimukao sagte in Raspberry Pi3+ SSD + SWAP:
                                      Gib uns mal die Ausgabe von
                                      iob diag
                                      Dann kann man vielleicht mehr sagen.
                                      • K kimukao
                                        wenn Grenzen, dann RAM. Aber da sind noch 1.2GB verfügbar.
                                        der Überlauf in den SWAP muss wohl kurzfristig gewesen sein.
                                        Als erstes käme mir da ein (zu) großes Backup in den Sinn.
                                          iob diag
                                          kimukao
                                          @thomas-braun said in Raspberry Pi3+ SSD + SWAP:
                                          iob diag
                                          		     v.2023-04-02
                                          Operatingsystem: 	Raspbian GNU/Linux 11 (bullseye)
                                          Kernel: 		5.15.84-v7l+
                                          Installation: 		Native
                                          Timezone: 		Europe/Berlin (CEST, +0200)
                                          User-ID: 		1000
                                          X-Server: 		false
                                          Boot Target: 		graphical.target
                                          Pending OS-Updates: 	29
                                          Pending iob updates: 	5
                                          Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.1
                                          			/usr/bin/node 		v16.19.1
                                          			/usr/bin/npm 		8.19.3
                                          			/usr/local/bin/npx 		8.5.0
                                          Recommended versions are nodejs 18.x.y and npm 9.x.y
                                          MEMORY:
                                          Mem:            3.8G        2.9G        236M        0.0K        731M        1.0G
                                          Swap:            99M         99M        0.0K
                                          Total:          3.9G        3.0G        236M
                                          Active iob-Instances: 	39
                                          Active repo(s): beta
                                          ioBroker Core: 		js-controller 		4.0.24
                                          			admin 			6.4.3
                                          ioBroker Status: 	iobroker is running on this host.
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects: 		47396
                                          States: 		30285
                                          Size of iob-Database:
                                          51M	/opt/iobroker/iobroker-data/objects.jsonl
                                          9.4M	/opt/iobroker/iobroker-data/objects.json.migrated
                                          9.4M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                                          59M	/opt/iobroker/iobroker-data/states.jsonl
                                          2.4M	/opt/iobroker/iobroker-data/states.json.migrated
                                          2.4M	/opt/iobroker/iobroker-data/states.json.bak.migrated
                                          0	/opt/iobroker/iobroker-data/states.json.broken
