  4. Test Tesla-Motors v2.0.x
    6.3k
1.0k Beiträge 112 Kommentatoren 402.9k Aufrufe 101 Beobachtet
    marlan99
    #622
    Mit der aktuellen Version des Adapters von V1.3.1 erhalte ich immer Meldungen von falschem Datentyp.
    Zum Beispiel:
    tesla-motors.0
    2022-12-28 10:28:53.686	info	State value to set for "tesla-motors.0.5YJSA7E25HF205349.vehicle_state.media_info.now_playing_source" has to be type "string" but received type "number"
    tesla-motors.0
    2022-12-28 09:24:52.852	info	State value to set for "tesla-motors.0.LRW3E7EL8NC605350.vehicle_state.media_info.now_playing_source" has to be type "string" but received type "number"
    tesla-motors.0
    2022-12-28 09:22:53.011	info	State value to set for "tesla-motors.0.LRW3E7EL8NC605350.vehicle_state.media_info.now_playing_source" has to be type "string" but received type "number"
    tesla-motors.0
    2022-12-28 09:20:53.848	info	State value to set for "tesla-motors.0.LRW3E7EL8NC605350.vehicle_state.media_info.now_playing_source" has to be type "string" but received type "number"
    Könnte man dies in einem update bitte anpassen?
    • M marlan99
      Zum Beispiel:
      tesla-motors.0
      tesla-motors.0
      tesla-motors.0
      tesla-motors.0
      #623
      @marlan99 sagte in Test Tesla-Motors v1.0.0:
      Hast du die Datenpunkte mal gelöscht und neu einlesen lassen?
      Wenn das nicht funktioniert, am besten ein Issue drüben auf github da lassen.
        marlan99
        #624
        @thomas-braun danke für den Tipp. Habe ich gemacht, nur lautet die Fehlermeldung nun umgekehrt :
        tesla-motors.0
        2022-12-29 09:41:30.498	info	State value to set for "tesla-motors.0.5YJSA7E25HF205349.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
        tesla-motors.0
        2022-12-29 09:23:30.536	info	State value to set for "tesla-motors.0.5YJSA7E25HF205349.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
        tesla-motors.0
        2022-12-29 09:05:30.446	info	State value to set for "tesla-motors.0.5YJSA7E25HF205349.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
        tesla-motors.0
        2022-12-29 08:47:30.378	info	State value to set for "tesla-motors.0.5YJSA7E25HF205349.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
        tesla-motors.0
        2022-12-29 08:45:30.456	info	State value to set for "tesla-motors.0.5YJSA7E25HF205349.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
        Ich werde auf github ein Issue dazu erfassen
          Darius 0
          #625
          zunächst vielen Dank für den Adapter - funktioniert top!
          Allerdings bräuchte ich bei der Charge_History einen Denkanstoß. Wie kann ich all die Datenpunkte sinnvoll visualisieren? Betreibe den Adapter mit der Version 1.3.1. -
          Wie habt ihr sowas realisiert? Für jegliche Hilfe bin ich dankbar.
          Gruss
          Darius
            Sandmanyz
            #626
            Warum hat das Setzen des Datenpunktes "set_charging_amps-charging_amps" bei mir keine Auswirkungen? Hat Jemand eine Idee?
            Mache ich es, während des Ladevorgangs, manuell in der Tesla App, gehts direkt. D.h., das Auto wird geladen und ich kann in der App direkt die Ampere ändern. Die Änderung greift dann auch sofort. Quasi ohne den Ladevorgang kurz zu unterbrechen.
            Das Ändern in der App hat irgendwie auch keine Auswirkungen auf den Datenpunkt. Sprich, er wird nicht aktualisiert.
            J T 2 Antworten Letzte Antwort
            • S Sandmanyz
              JoergH
              #627
              @Sandmanyz
              Klingt nicht so, als hätte der Adapter überhaupt eine Verbindung zu Deinem Tesla...
              • S Sandmanyz
                tombox
                #628
                @sandmanyz Wichtig das sie die befehle unbestätigt gesendet werden und im log schauen was die Rückmeldung ist
                • T tombox
                  JoergH
                  #629
                  @tombox sagte in Test Tesla-Motors v1.0.0:
                  Allerdings müsste er in jedem Fall die Änderung durch die App in seinen Objekten sehen...
                  • J JoergH
                    @Sandmanyz
                    Sandmanyz
                    schrieb am zuletzt editiert von Sandmanyz
                    #630
                    @joergh
                    Der Adapter hat eine Verbindung. Es werden alle Datenpunkte korrekt angezeigt.
                    EDIT: Dir gilt natürlich auch mein Dank! 👍
                    @tombox
                    Oh, unbestätigt....das habe ich vorhin nicht getestet weil ich es nicht wusste:man-facepalming: . Unbestätigt funktioniert es 😁. Danke für den Tipp👍
                    Wie kann ich aus Blockly heraus den Datenpunkt unbestätigt ändern?
                    • S Sandmanyz
                      @joergh
                      @tombox
                      JoergH
                      #631
                      @sandmanyz sagte in Test Tesla-Motors v1.0.0:
                      Statt "Aktualisieren" musst Du einfach "Steuere" nehmen
                      • J JoergH
                        Sandmanyz
                        #632
                        @joergh
                        Ich danke dir, funktioniert 👍
                        @tombox
                        Im Log erscheinen jetzt immer mal wieder die folgenden Meldungen. Ich würde sagen, dass es mit dem setzen (steuern) des Datenpunktes "tesla-motors.0.LRWxxxxxxxxxx.remote.set_charging_amps-charging_amps" zu tun hat.
                        Mache ich was falsch oder könnte es am Adapter liegen?
                        tesla-motors.0
                        	2023-02-07 11:28:41.223	error	Error: socket hang up
                        tesla-motors.0
                        	2023-02-07 11:28:41.223	error	https://owner-api.teslamotors.com/api/1/vehicles/818527008737282/vehicle_data
                        tesla-motors.0
                        	2023-02-07 11:28:41.222	error	General error
                        paul pP 1 Antwort Letzte Antwort
                        • S Sandmanyz
                          @joergh
                          @tombox
                          tesla-motors.0
                          tesla-motors.0
                          tesla-motors.0
                          paul pP Offline
                          paul pP Offline
                          paul p
                          #633
                          Der Adapter läuft seit Mitte Dezember problemlos, allerdings bekomme ich seit heute Morgen folgenden Fehler:
                          Ich habe "nur" eine Powerwall, also kann es nicht an den DP oben beschrieben liegen.
                          tesla-motors.0 15379 2023-02-07 09:55:23.451 error Error: socket hang up
                          tesla-motors.0 15379 2023-02-07 09:55:23.450 error https://owner-api.teslamotors.com/api/1/energy_sites/140439652631/site_info
                          tesla-motors.0 15379 2023-02-07 09:55:23.450 error General error
                          tesla-motors.0 15379 2023-02-07 10:00:14.226 error Error: socket hang up
                          tesla-motors.0 15379 2023-02-07 10:00:14.226 error https://owner-api.teslamotors.com/api/1/energy_sites/140439652631/calendar_history?kind=self_consumption&start_date=2016-01-01T00%3A00%3A00%2B01%3A00&period=lifetime&time_zone=Europe%2FBerlin&end_date=2023-02-07T09:59:14.026Z
                          tesla-motors.0 15379 2023-02-07 10:00:14.226 error General error
                          Adapter ist Ver. 1.3.2
                          Auth Link habe ich schon neu generiert.
                            marlan99
                            schrieb am zuletzt editiert von marlan99
                            #634
                            @paul-p said in Test Tesla-Motors v1.0.0:
                            Diese Meldungen habe ich soeben auch entdeckt, nachdem ich hier davon geleseb habe.
                            Habe die Instanz mal neu gestartet.
                            Die Fehlermeldung erscheint ca. alle 20 Minuten.
                            Das Abfrageintervall ist bei mir bei 2 Minuten (120 Sekunden)
                            Adapter Version 1.3.2 seit einem Tag
                            Edit: Fehlermeldung kommt auch nach dem restart der Instanz weiterhin
                            • M marlan99
                              MatthiaB
                              #635
                              werden mit dem Adapter auch die "Trip-Daten" abgeholt? Irgendwie kann ich dazu nichts finden.
                                DrBoom
                                #636
                                Hallo Zusammen,
                                gibt es eine Möglichkeit den Sentry Mode zu deaktivieren? Über remote > set_sentry_mode lässt er sich aktivieren, aber nicht wieder deaktivieren.
                                Ich möchte den Sentry Modus nur nachts aktivieren, wenn mein Auto in der Einfahrt parkt und morgens wieder deaktivieren damit nicht jeder der am Auto vorbeiläuft (Postbote, etc.) eine Aufnahme auslöst.
                                Danke im Voraus!
                                LG Sebastian
                                • D DrBoom
                                  Hallo Zusammen,
                                  Danke im Voraus!
                                  LG Sebastian
                                  tombox
                                  #637
                                  @drboom Mit false müsste er sich deaktivieren
                                  • T tombox
                                    DrBoom
                                    #638
                                    @tombox nein, leider nicht. Ist ein Button der nur mit true getriggert werden kann. Bei false passiert nichts, habe es über ein Script getestet.
                                    peterk34P 1 Antwort Letzte Antwort
                                    • D DrBoom
                                      peterk34P Offline
                                      peterk34P Offline
                                      peterk34
                                      #639
                                      @drboom hab soeben ein script dazu gemacht - funktioniert anstandslos ... true aktiviert, false deaktiviert
                                      • peterk34P peterk34
                                        DrBoom
                                        schrieb am zuletzt editiert von DrBoom
                                        #640
                                        @peterk34 habe den Fehler gefunden. Im Blockly Script hatte ich "aktualisiere" gewählt um den Sentry Mode zu steuern - damit hat es nicht geklappt. Mit "steuere" funktioniert es tatsächlich auch bei mir anstandslos. Danke! :)
                                        • P Offline
                                          ple
                                          #641
                                          Moin zusammen,
                                          habe nun meinen Tesla und einen Mennekes Wallbox, die wurde zu Zeiten der Förderung eingebaut bei der Sanierung.
                                          Naja, jetzt ist es ja so, dass die Wallbox keine Phasenumschaltung kann.
                                          Ich habe zwar eine 40,5kwp Anlage (Huawei per Modbus an iobroker), aber in den Übergangszeiten sind selbst 4,5kw zu viel ab und zu.
                                          Meine Frage, wie kann man am besten eine Phasenumschaltung machen? Ich dachte erst an eine neue Wallbox, aber kann vielleicht der Tesla selber die Umschaltung machen und mit weniger laden?
                                          Ich stell mir gerade die Frage, warum ich überhaupt ne Wallbox dann bräuchte, wenn ich den PV Überschuss auch am Tesla direkt machen könnte.
                                          Intel Nuc + Proxmox
