  4. Test Tesla-Motors v2.0.x
    6.3k
1.0k Beiträge 112 Kommentatoren 402.9k Aufrufe 101 Beobachtet
  • H hoaloha
    Ich habe jetzt mal über die Konsole versucht "alle" Instanzen zu löschen.
    Leider keine Änderung.
    tombox
    #614
    @hoaloha Was ist denn der derzeitige Fehler nach Adapter start und installation via GitHub?
    H 1 Antwort Letzte Antwort
    • T tombox
      hoaloha
      #615
      host.iobroker
      2022-12-16 21:31:41.855	error	instance system.adapter.tesla-motors.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2022-12-16 21:31:41.855	error	Caught by controller[0]: }
      host.iobroker
      2022-12-16 21:31:41.855	error	Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
      host.iobroker
      2022-12-16 21:31:41.854	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/axios-cookiejar-support/lib/index.js:8:40) {
      host.iobroker
      2022-12-16 21:31:41.854	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
      host.iobroker
      2022-12-16 21:31:41.854	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1057:19)
      host.iobroker
      2022-12-16 21:31:41.854	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:833:27)
      host.iobroker
      2022-12-16 21:31:41.854	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:971:27)
      host.iobroker
      2022-12-16 21:31:41.854	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:562:31)
      host.iobroker
      2022-12-16 21:31:41.854	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:522:36)
      host.iobroker
      2022-12-16 21:31:41.854	error	Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:649:3)
      host.iobroker
      2022-12-16 21:31:41.854	error	Caught by controller[0]: at throwExportsNotFound (node:internal/modules/esm/resolve:365:9)
      host.iobroker
      2022-12-16 21:31:41.853	error	Caught by controller[0]: at new NodeError (node:internal/errors:387:5)
      host.iobroker
      2022-12-16 21:31:41.853	error	Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './lib/defaults' is not defined by "exports" in /opt/iobroker/node_modules/axios/package.json
      host.iobroker
      2022-12-16 21:31:41.853	error	Caught by controller[0]: ^
      host.iobroker
      2022-12-16 21:31:41.853	error	Caught by controller[0]: throw e;
      host.iobroker
      2022-12-16 21:31:41.852	error	Caught by controller[0]: node:internal/modules/cjs/loader:528
      Intel NUC mit Proxmox
      • H Offline
        hoaloha
        schrieb am zuletzt editiert von hoaloha
        #616
        Es scheint gelöst. Ich habe nach der erneuten Github installation über den Expertenmodus die Instanznummer auf 10 gesetzt. Jetzt ist alles grün. Also durch das Backup scheinen irgendwo Fragmente die 0 bzw. 1 zu blockieren.
        • H hoaloha
          JoergH
          #617
          @tombox
          Teilweise stelle ich fest, dass ich einen sehr hohen Stromverbrauch bei abgestelltem Fahrzeug habe. Nun frage ich mich woran das liegt und habe schon versucht die Abfragen der Daten zu reduzieren, in der Annahme, dass das Fahrzeug evtl. nicht in den Schlafmodus geht, wenn man die Daten regelmäßig abfragt. Ist das so? Und wenn ja, bei allen Daten?
          Evtl. liegt es auch einfach an der Kameraüberwachung, aber bei bis zu 5% (LR Batterie) pro Tag ist das schon echt ein Thema...
          M HumidorH 2 Antworten Letzte Antwort
          • J JoergH
            @tombox
            marlan99
            #618
            @joergh wenn du den sentry mode aktiviert hast, ist dieser Stromverbrauch normal.
            Ich kann bei mir, bei beiden Fahrzeugen, keinen Mehrverbrauch durch diesen Adapter feststellen.
            • J JoergH
              @tombox
              HumidorH Offline
              HumidorH Offline
              Humidor
              #619
              @joergh 5% da hast du verm. den Wächtermodus aktiv (zu Hause kann man den abschalten), dann ist es uU normal
              ich habe mit dem Adapter aufgehört, da unser Tesla gar nicht mehr in den Schlaf ging
              ev. wäre das heute aber schon wieder, war damals auch ein Thema vom Account selbst.
              BG
              • M marlan99
                JoergH
                #620
                @marlan99 sagte in Test Tesla-Motors v1.0.0:
                Ok, danke. Wahnsinn was die paar Kameras an Strom ziehen...
                  Sandmanyz
                  #621
                  Ich ging davon aus, dass tesla-motors.0.XXXXXXXXXXXXXX.charge_history.total_charged.value (geladene kWh) der Gesamtwert ist. Nun habe ich gesehen, dass der Wert nur die letzten 31 Tage beinhaltet. Für den Gesamtwert finde ich keinen Datenpunkt. Gibt es dafür einen Datenpunkt bzw. kann er eingefügt werden?
                    marlan99
                    #622
                    Mit der aktuellen Version des Adapters von V1.3.1 erhalte ich immer Meldungen von falschem Datentyp.
                    Zum Beispiel:
                    tesla-motors.0
                    2022-12-28 10:28:53.686	info	State value to set for "tesla-motors.0.5YJSA7E25HF205349.vehicle_state.media_info.now_playing_source" has to be type "string" but received type "number"
                    tesla-motors.0
                    2022-12-28 09:24:52.852	info	State value to set for "tesla-motors.0.LRW3E7EL8NC605350.vehicle_state.media_info.now_playing_source" has to be type "string" but received type "number"
                    tesla-motors.0
                    2022-12-28 09:22:53.011	info	State value to set for "tesla-motors.0.LRW3E7EL8NC605350.vehicle_state.media_info.now_playing_source" has to be type "string" but received type "number"
                    tesla-motors.0
                    2022-12-28 09:20:53.848	info	State value to set for "tesla-motors.0.LRW3E7EL8NC605350.vehicle_state.media_info.now_playing_source" has to be type "string" but received type "number"
                    Könnte man dies in einem update bitte anpassen?
                    • M marlan99
                      Zum Beispiel:
                      tesla-motors.0
                      tesla-motors.0
                      tesla-motors.0
                      tesla-motors.0
                      #623
                      Hast du die Datenpunkte mal gelöscht und neu einlesen lassen?
                      Wenn das nicht funktioniert, am besten ein Issue drüben auf github da lassen.
                        marlan99
                        #624
                        @thomas-braun danke für den Tipp. Habe ich gemacht, nur lautet die Fehlermeldung nun umgekehrt :
                        tesla-motors.0
                        2022-12-29 09:41:30.498	info	State value to set for "tesla-motors.0.5YJSA7E25HF205349.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
                        tesla-motors.0
                        2022-12-29 09:23:30.536	info	State value to set for "tesla-motors.0.5YJSA7E25HF205349.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
                        tesla-motors.0
                        2022-12-29 09:05:30.446	info	State value to set for "tesla-motors.0.5YJSA7E25HF205349.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
                        tesla-motors.0
                        2022-12-29 08:47:30.378	info	State value to set for "tesla-motors.0.5YJSA7E25HF205349.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
                        tesla-motors.0
                        2022-12-29 08:45:30.456	info	State value to set for "tesla-motors.0.5YJSA7E25HF205349.vehicle_state.media_info.now_playing_source" has to be type "number" but received type "string"
                        Ich werde auf github ein Issue dazu erfassen
                          Darius 0
                          #625
                          zunächst vielen Dank für den Adapter - funktioniert top!
                          Allerdings bräuchte ich bei der Charge_History einen Denkanstoß. Wie kann ich all die Datenpunkte sinnvoll visualisieren? Betreibe den Adapter mit der Version 1.3.1. -
                          Wie habt ihr sowas realisiert? Für jegliche Hilfe bin ich dankbar.
                          Gruss
                          Darius
                            Sandmanyz
                            #626
                            Warum hat das Setzen des Datenpunktes "set_charging_amps-charging_amps" bei mir keine Auswirkungen? Hat Jemand eine Idee?
                            Mache ich es, während des Ladevorgangs, manuell in der Tesla App, gehts direkt. D.h., das Auto wird geladen und ich kann in der App direkt die Ampere ändern. Die Änderung greift dann auch sofort. Quasi ohne den Ladevorgang kurz zu unterbrechen.
                            Das Ändern in der App hat irgendwie auch keine Auswirkungen auf den Datenpunkt. Sprich, er wird nicht aktualisiert.
                            J T 2 Antworten Letzte Antwort
                            • S Sandmanyz
                              JoergH
                              #627
                              @Sandmanyz
                              Klingt nicht so, als hätte der Adapter überhaupt eine Verbindung zu Deinem Tesla...
                              • S Sandmanyz
                                tombox
                                #628
                                @sandmanyz Wichtig das sie die befehle unbestätigt gesendet werden und im log schauen was die Rückmeldung ist
                                • T tombox
                                  JoergH
                                  #629
                                  @tombox sagte in Test Tesla-Motors v1.0.0:
                                  Allerdings müsste er in jedem Fall die Änderung durch die App in seinen Objekten sehen...
                                  • J JoergH
                                    @Sandmanyz
                                    Sandmanyz
                                    schrieb am zuletzt editiert von Sandmanyz
                                    #630
                                    @joergh
                                    Der Adapter hat eine Verbindung. Es werden alle Datenpunkte korrekt angezeigt.
                                    EDIT: Dir gilt natürlich auch mein Dank! 👍
                                    @tombox
                                    Oh, unbestätigt....das habe ich vorhin nicht getestet weil ich es nicht wusste:man-facepalming: . Unbestätigt funktioniert es 😁. Danke für den Tipp👍
                                    Wie kann ich aus Blockly heraus den Datenpunkt unbestätigt ändern?
                                    • S Sandmanyz
                                      @joergh
                                      @tombox
                                      JoergH
                                      #631
                                      @sandmanyz sagte in Test Tesla-Motors v1.0.0:
                                      Statt "Aktualisieren" musst Du einfach "Steuere" nehmen
                                      • J JoergH
                                        Sandmanyz
                                        #632
                                        @joergh
                                        Ich danke dir, funktioniert 👍
                                        @tombox
                                        Im Log erscheinen jetzt immer mal wieder die folgenden Meldungen. Ich würde sagen, dass es mit dem setzen (steuern) des Datenpunktes "tesla-motors.0.LRWxxxxxxxxxx.remote.set_charging_amps-charging_amps" zu tun hat.
                                        Mache ich was falsch oder könnte es am Adapter liegen?
                                        tesla-motors.0
                                        	2023-02-07 11:28:41.223	error	Error: socket hang up
                                        tesla-motors.0
                                        	2023-02-07 11:28:41.223	error	https://owner-api.teslamotors.com/api/1/vehicles/818527008737282/vehicle_data
                                        tesla-motors.0
                                        	2023-02-07 11:28:41.222	error	General error
                                        paul pP 1 Antwort Letzte Antwort
                                        • S Sandmanyz
                                          @joergh
                                          @tombox
                                          tesla-motors.0
                                          tesla-motors.0
                                          tesla-motors.0
                                          paul pP Offline
                                          paul pP Offline
                                          paul p
                                          #633
                                          Der Adapter läuft seit Mitte Dezember problemlos, allerdings bekomme ich seit heute Morgen folgenden Fehler:
                                          Ich habe "nur" eine Powerwall, also kann es nicht an den DP oben beschrieben liegen.
                                          tesla-motors.0 15379 2023-02-07 09:55:23.451 error Error: socket hang up
                                          tesla-motors.0 15379 2023-02-07 09:55:23.450 error https://owner-api.teslamotors.com/api/1/energy_sites/140439652631/site_info
                                          tesla-motors.0 15379 2023-02-07 09:55:23.450 error General error
                                          tesla-motors.0 15379 2023-02-07 10:00:14.226 error Error: socket hang up
                                          tesla-motors.0 15379 2023-02-07 10:00:14.226 error https://owner-api.teslamotors.com/api/1/energy_sites/140439652631/calendar_history?kind=self_consumption&start_date=2016-01-01T00%3A00%3A00%2B01%3A00&period=lifetime&time_zone=Europe%2FBerlin&end_date=2023-02-07T09:59:14.026Z
                                          tesla-motors.0 15379 2023-02-07 10:00:14.226 error General error
                                          Adapter ist Ver. 1.3.2
                                          Auth Link habe ich schon neu generiert.
