  4. Adapter "smartmeter"
    6.6k
3.6k Beiträge 281 Kommentatoren 3.0m Aufrufe 162 Beobachtet
  • T Thomas P 0
    @apollon77
    Hallo Apollon,
    2023-02-04 19:45:51.562  - info: host.zaehlerpi stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2023-02-04 19:45:51.574  - info: smartmeter.0 (3434) Got terminate signal TERMINATE_YOURSELF
    2023-02-04 19:45:51.578  - debug: smartmeter.0 (3434) STOP
    2023-02-04 19:45:51.580  - debug: smartmeter.0 (3434) CLEAR MESSAGE TIMEOUT TIMER
    2023-02-04 19:45:51.582  - info: smartmeter.0 (3434) terminating
    2023-02-04 19:45:51.585  - debug: smartmeter.0 (3434) Plugin sentry destroyed
    2023-02-04 19:45:51.586  - info: smartmeter.0 (3434) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-02-04 19:45:51.613  - info: host.zaehlerpi stopInstance system.adapter.smartmeter.0 send kill signal
    2023-02-04 19:45:52.177  - info: host.zaehlerpi instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-02-04 19:45:54.674  - info: host.zaehlerpi instance system.adapter.smartmeter.0 started with pid 5793
    2023-02-04 19:45:58.307  - debug: smartmeter.0 (5793) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-02-04 19:45:58.446  - debug: smartmeter.0 (5793) Objects client ready ... initialize now
    2023-02-04 19:45:58.454  - debug: smartmeter.0 (5793) Objects create System PubSub Client
    2023-02-04 19:45:58.459  - debug: smartmeter.0 (5793) Objects create User PubSub Client
    2023-02-04 19:45:58.550  - debug: smartmeter.0 (5793) Objects client initialize lua scripts
    2023-02-04 19:45:58.577  - debug: smartmeter.0 (5793) Objects connected to redis: 127.0.0.1:9001
    2023-02-04 19:45:58.628  - debug: smartmeter.0 (5793) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-02-04 19:45:58.649  - debug: smartmeter.0 (5793) States create System PubSub Client
    2023-02-04 19:45:58.654  - debug: smartmeter.0 (5793) States create User PubSub Client
    2023-02-04 19:45:58.681  - debug: smartmeter.0 (5793) States connected to redis: 127.0.0.1:9000
    2023-02-04 19:45:58.744  - debug: smartmeter.0 (5793) Plugin sentry Initialize Plugin (enabled=true)
    2023-02-04 19:45:59.335  - info: smartmeter.0 (5793) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.19.0, js-controller: 4.0.24
    2023-02-04 19:45:59.403  - debug: smartmeter.0 (5793) SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialRequestResponseTransport","requestInterval":"300","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0041-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":null,"protocolD0WakeupCharacters":0,"protocolD0DeviceAddress":"66002067","obisFallbackMedium":1}
    2023-02-04 19:45:59.411  - debug: smartmeter.0 (5793) CREATE SERIALPORT: 300 7 1 even
    2023-02-04 19:45:59.431  - debug: smartmeter.0 (5793) SERIALPORT OPEN
    2023-02-04 19:45:59.470  - debug: smartmeter.0 (5793) SERIALPORT RESET BAUDRATE TO 300
    2023-02-04 19:45:59.479  - debug: smartmeter.0 (5793) INITIAL MESSAGES TO SEND: 2
    2023-02-04 19:45:59.482  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
    2023-02-04 19:45:59.484  - debug: smartmeter.0 (5793) TO SEND 2:
    2023-02-04 19:45:59.485  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
    2023-02-04 19:45:59.487  - debug: smartmeter.0 (5793) TO SEND 1: /?66002067!
    2023-02-04 19:45:59.519  - debug: smartmeter.0 (5793) connected set to false
    2023-02-04 19:45:59.896  - debug: smartmeter.0 (5793) DONE SEND 1
    2023-02-04 19:45:59.958  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:45:59.963  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:45:59.964  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/" -> null
    2023-02-04 19:45:59.988  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:45:59.990  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:45:59.992  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/B" -> null
    2023-02-04 19:46:00.022  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.024  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.025  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BY" -> null
    2023-02-04 19:46:00.055  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.057  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.058  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL" -> null
    2023-02-04 19:46:00.089  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.091  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.093  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6" -> null
    2023-02-04 19:46:00.122  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.124  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.126  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<" -> null
    2023-02-04 19:46:00.150  - debug: smartmeter.0 (5793) DONE SEND 0
    2023-02-04 19:46:00.154  - debug: smartmeter.0 (5793) SET MESSAGE TIMEOUT TIMER2: 120000
    2023-02-04 19:46:00.177  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.179  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.181  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1" -> null
    2023-02-04 19:46:00.192  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.194  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.195  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>" -> null
    2023-02-04 19:46:00.222  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.224  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.225  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>B" -> null
    2023-02-04 19:46:00.256  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.257  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.258  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BY" -> null
    2023-02-04 19:46:00.288  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.289  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.290  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL" -> null
    2023-02-04 19:46:00.322  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.323  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.324  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-" -> null
    2023-02-04 19:46:00.355  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.356  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.357  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-C" -> null
    2023-02-04 19:46:00.388  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.390  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.391  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CR" -> null
    2023-02-04 19:46:00.423  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.424  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.425  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH" -> null
    2023-02-04 19:46:00.455  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.456  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.457  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-" -> null
    2023-02-04 19:46:00.489  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.490  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.491  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-B" -> null
    2023-02-04 19:46:00.521  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.523  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.524  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BT" -> null
    2023-02-04 19:46:00.556  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.558  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.559  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK" -> null
    2023-02-04 19:46:00.588  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.589  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.590  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK3" -> null
    2023-02-04 19:46:00.622  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.623  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.624  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK30" -> null
    2023-02-04 19:46:00.654  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.657  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.658  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK30-" -> null
    2023-02-04 19:46:00.688  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.690  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.691  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK30-R" -> null
    2023-02-04 19:46:00.722  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.723  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.725  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK30-R1" -> null
    2023-02-04 19:46:00.755  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.756  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.757  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK30-R1\r" -> null
    2023-02-04 19:46:00.789  - debug: smartmeter.0 (5793) NEW DATA
    2023-02-04 19:46:00.790  - debug: smartmeter.0 (5793) CURRENT PROCESS STEP 2 IN CHECKMESSAGE
    2023-02-04 19:46:00.791  - debug: smartmeter.0 (5793) MATCH-RESULT SIGNON: "/BYL6<1>BYL-CRH-BTK30-R1\r\n" -> null
    2023-02-04 19:48:00.159  - debug: smartmeter.0 (5793) MESSAGE TIMEOUT TRIGGERED
    2023-02-04 19:48:00.162  - debug: smartmeter.0 (5793) Error: No or too long answer from Serial Device after last request.
    2023-02-04 19:48:00.167  - warn: smartmeter.0 (5793) No or too long answer from Serial Device after last request.
    2023-02-04 19:48:00.169  - debug: smartmeter.0 (5793) Error: No or too long answer from Serial Device after last request.
    2023-02-04 19:48:00.170  - debug: smartmeter.0 (5793) Transport Reset!! Restart = true
    2023-02-04 19:48:00.173  - debug: smartmeter.0 (5793) STOP
    2023-02-04 19:48:00.174  - debug: smartmeter.0 (5793) CLEAR MESSAGE TIMEOUT TIMER
    2023-02-04 19:48:00.190  - debug: smartmeter.0 (5793) SERIALPORT CLOSE
    2023-02-04 19:48:00.192  - debug: smartmeter.0 (5793) SERIALPORT REMOVE LISTENERS
    2023-02-04 19:48:00.198  - debug: smartmeter.0 (5793) CURRENT SIGNON MESSAGE COUNTER 1 OF 1
    2023-02-04 19:48:00.200  - debug: smartmeter.0 (5793) DELETE rest of data (0) because new Message start with a new Request Message
    2023-02-04 19:48:00.201  - debug: smartmeter.0 (5793) SCHEDULE NEXT RUN IN 300000s
    Das ist ein ganzer Abfragezyklus. Ich habe den Adapter eu gestartet, um die Abfrage auszulösen.
    MfG
    Thomas Pfaffinger
    #3203
    @thomas-p-0 warum ist bei Modus override ein C drin? Der Grund ist aktuell das er die signon Nachricht nicht erkennt. Daher geht’s nicht weiter. Mein Tipp liegt an den < Bzw >. Muss schauen was die specs sagen aber solche Zeichen wären mir an sich neu. Dann müsste ich das einbauen. Wenn die Kinderbibel Bett sind schaue ich mal.
    Edit aaahhhhhhh tja die signon ist zu lang formal … um ein Zeichen zu lang.
    https://github.com/Apollon77/smartmeter-obis/blob/master/lib/protocols/D0Protocol.js Hier zeile 9 das 4,22 heißt „nach dem / kommen vor dem Zeilenende 4 bis 22 Zeichen“. Dein Zähler senden …. Trommelwirbel …. 23 (wenn ich mich nicht verzählt hab) kannst das file mal suchen und nen 23 reinschreiben anstelle der 22. wenn’s dann weitergeht ist’s das. Dann bitte github issue Anlegen. Muss ich wohl das Limit ändern. Hachja. Standards und die Hersteller …
    • apollon77A apollon77
      Thomas P 0
      schrieb am zuletzt editiert von Thomas P 0
      #3204
      @apollon77 said in Adapter "smartmeter":
      D0Protocol.js
      Guten Morgen Appollon,
      ja das war es. Jetzt funktioniert es. Vielen Dank. Kann man dir irgendwie ein Dankeschön zukommen lassen?
      In meinen Spec stehen übrigens 32 Zeichen. Welche ist denn nun richtig? :)
      iec62056-21_en
      Und ja, das ist der Grund, warum ich in der IT arbeite. Ein Zeichen und schon geht es
      MfG
      Thomas Pfaffinger
      P.S.: Issue ist angelegt. Ich hoffe, das ich das richtig gemacht habe. Ist mein erster
      apollon77A 2 Antworten Letzte Antwort
      • T Thomas P 0
        D0Protocol.js
        iec62056-21_en
        MfG
        Thomas Pfaffinger
        #3205
        @thomas-p-0 na dann lese ich mal deine specs ;-)) vllt gabs ein Update.
        Zum „zukommen lassen“ ist Link in meinem footer hier im Forum Oder auch im github bei den Adaptern Seite und oben unter „Sponsor“ als begriff. Danke.
        • T Thomas P 0
          D0Protocol.js
          iec62056-21_en
          MfG
          Thomas Pfaffinger
          #3206
          @thomas-p-0 ich gehe davon aus das mit der Änderung bei dir erstmal alles tut? Oder geht noch irgendetwas nicht?
            Thomas P 0
            #3207
            @apollon77
            Allo Apollon,
            nein, soweit alles perfekt.
            MfG
            Thomas Pfaffinger
            • T Thomas P 0
              @apollon77
              Allo Apollon,
              MfG
              Thomas Pfaffinger
              #3208
              @thomas-p-0 Ok, dann Todo liste :-)
                mirko3107
                #3209
                ich habe in meinem Zählerschrank einen "Sagemcom Smarty BZ-Plus" verbaut, einen Zweirichtungszähler.
                Aus diesem hatte ich gehofft, die Werte für den aktuellen Verbauch sowie für die einzelnen Phasen per D0
                auslesen zu können.
                Hab einen USB-IR-Lesekopf an einem Raspberry und einer kleinen Iobroker-Installation als Slave.
                Mein erster Erfolg war ein Auslesen per SML, aber da kam nur der aktuelle Verbrauch und ein paar Zählerstände.
                Hab dann D0 versucht, da spuckt er mir aber nur Zählerstände aus für jeden Monat des vergangenen Jahres,
                keine aktuellen Verbräuche.
                Hat noch jemand diesen Zähler erfolgreich auslesen können?
                Handbuch1
                Handbuch2
                Meine Settings:
                Mirko
                HomoranH wendy2702W 2 Antworten Letzte Antwort
                • M mirko3107
                  auslesen zu können.
                  Handbuch1
                  Handbuch2
                  Meine Settings:
                  Mirko
                  #3210
                  @mirko3107 sagte in Adapter "smartmeter":
                  das ist dann der richtige Weg gewesen.
                  Meht gibt es meistens nicht.
                  • M mirko3107
                    auslesen zu können.
                    Handbuch1
                    Handbuch2
                    Meine Settings:
                    Mirko
                    wendy2702W Online
                    wendy2702W Online
                    #3211
                    @mirko3107 Im Handbuch 1 Seite 16/17 steht doch genau welche Daten man mit welchem Protokoll abfragen kann.
                    Mehr geht halt nicht.
                      mirko3107
                      #3212
                      Wenn ich im Handbuch2 auf Seite 77 lese, hatte ich mir mehr Werte erhofft, aber wenn nicht mehr kommt, nutzt
                      mir das alles nix.
                      wendy2702W HomoranH 2 Antworten Letzte Antwort
                      • M mirko3107
                        mir das alles nix.
                        wendy2702W Online
                        wendy2702W Online
                        #3213
                        @mirko3107 Hast du PIN, Passwort 1 oder 2 ?
                        Ist das eine Handbuch vom Versorger und das andere vom Hersteller?
                        Nicht alles was der Hersteller theoretisch kann wird auch vom Versorger „gekauft“ bzw. An den Endkunden weitergegeben. Bist hier nicht der erste der so etwas hat.
                        Welche Werte benötigst du denn?
                        • M mirko3107
                          mir das alles nix.
                          #3214
                          was kommt denn?
                          kann alles und nichts bedeuten.
                            mirko3107
                            schrieb am zuletzt editiert von mirko3107
                            #3215
                            PIN hatte ich bekommen, hab die Abfrage deaktiviert.
                            Mir geht es um den aktuellen Gesamtverbrauch und die Verbräuche auf L1, L2, L3, mehr nicht.
                            Im Iobroker seh ich jede Menge Zählerstände, aber keine Momentanverbräuche. Pro Abfrage kommen laut
                            Log 137Werte.
                            • wendy2702W wendy2702
                              mirko3107
                              #3216
                              @wendy2702 sagte in Adapter "smartmeter":
                              das sind welche die im Netz verfügbar sind, wenn man nach der Gerätebezeichnung googelt.
                              • M mirko3107
                                Log 137Werte.
                                #3217
                                hast du auch INF auf on gestellt?
                                Log 137Werte.
                                dann besteht Hoffnung, dass du einen spendablen Versorger hast.
                                klapp mal die Ordner auf
                                  mirko3107
                                  #3218
                                  Inf ist auf On.
                                  • M mirko3107
                                    Inf ist auf On.
                                    wendy2702W Online
                                    wendy2702W Online
                                    #3219
                                    @mirko3107 Wenn jetzt bei den 173 Werten die Verbräuche der einzelnen Phasen fehlen wird es wohl keine Möglichkeit geben. Sollte Strom und Spannung (die ist eigentlich relativ klar) angezeigt werden muss man rechnen.
                                    • M mirko3107
                                      Inf ist auf On.
                                      #3220
                                      @mirko3107 hast du eine Wert für 1-0:16_7_0__255 ?
                                        mirko3107
                                        #3221
                                        jetzt mit D0-Ausgabe nicht. Da sind nur Zählerstände dabei, kein einzelner Momentanverbrauch.
                                        Ich glaub, dieser Wert kam bei SML-Ausgabe mit, sollte der Gesamtverbrauch sein, oder?
                                        Kann nur grad nicht umschalten, bin nicht zu Hause.
                                        • M mirko3107
                                          #3222
                                          vergiss D0
                                          zeig mal was SML bringt wenn du kannst
