  5. Alexa erzählt etwas anderes als sie soll
81 Beiträge 8 Kommentatoren 4.2k Aufrufe 5 Beobachtet
    @flori
    Schau hier rein:
    Flori
    Ich schicke jetzt mal alles was vorher kommt bevor die 100000 gleichen meldungen kommen und dann noch mal was danach kommt.```
    2023-01-28 16:57:23.851 - info: admin.0 (243242) ==> Connected system.user.admin from ::ffff:192.168.178.69
    2023-01-28 16:57:30.657 - info: javascript.0 (243299) Start javascript script.js.Alarmanlage.Alarmanlage_Neu_Neu
    2023-01-28 16:57:30.679 - info: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_Neu_Neu: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-28 16:57:36.859 - info: javascript.0 (243299) Stop script script.js.Alarmanlage.Alarmanlage_Neu_Neu
    2023-01-28 16:57:46.118 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:57:46.119 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:57:46.119 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
    2023-01-28 16:57:46.150 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:57:46.151 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:57:46.152 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
    2023-01-28 16:57:46.200 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:57:46.201 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:57:46.201 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
    2023-01-28 16:57:46.235 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:57:46.236 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:57:46.236 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
    2023-01-28 16:58:03.341 - info: javascript.0 (243299) Stop script script.js.Alarmanlage.Alarmanlage_Neu
    2023-01-28 16:58:04.413 - info: javascript.0 (243299) Start javascript script.js.Alarmanlage.Alarmanlage_Neu_Neu
    2023-01-28 16:58:04.419 - info: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_Neu_Neu: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-28 16:58:14.758 - info: tuya.0 (243444) 02654020840d8e804331: Error on Reconnect (5): connection timed out
    2023-01-28 16:58:23.837 - error: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_Neu_Neu: 1
    2023-01-28 16:58:24.541 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_Neu_Neu: setForeignState(id=alexa2.0.Echo-Devices.G090U5078437090J.Commands.speak, state={"val":"Alarmanlage wurde in den Zu Hause Modus geschaltet","ack":false,"ts":1674921504541,"q":0,"from":"system.adapter.javascript.0","lc":1674921504541,"c":"script.js.Alarmanlage.Alarmanlage_Neu_Neu"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
    2023-01-28 16:58:38.619 - info: admin.0 (243242) <== Disconnect system.user.admin from ::ffff:192.168.178.69 javascript
    2023-01-28 16:58:53.553 - error: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_Neu_Neu: 3
    2023-01-28 16:58:54.262 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_Neu_Neu: setForeignState(id=alexa2.0.Echo-Devices.G090U5078437090J.Commands.speak, state={"val":"Alarmanlage wurde ausgeschaltet","ack":false,"ts":1674921534262,"q":0,"from":"system.adapter.javascript.0","lc":1674921534262,"c":"script.js.Alarmanlage.Alarmanlage_Neu_Neu"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
    2023-01-28 16:58:55.545 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
    2023-01-28 16:58:55.546 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
    2023-01-28 16:58:55.547 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
    und danach
    2023-01-28 16:58:57.788 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
    2023-01-28 16:58:57.789 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
    2023-01-28 16:58:57.790 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
    2023-01-28 16:58:57.791 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
    2023-01-28 16:58:57.792 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
    2023-01-28 16:58:57.793 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
    2023-01-28 16:59:29.764 - info: admin.0 (243242) ==> Connected system.user.admin from ::ffff:192.168.178.69
    2023-01-28 16:59:46.126 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:59:46.127 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:59:46.128 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
    2023-01-28 16:59:46.184 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:59:46.199 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:59:46.200 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
    2023-01-28 16:59:46.245 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:59:46.246 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:59:46.258 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
    2023-01-28 16:59:46.351 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:59:46.352 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 16:59:46.353 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:00:40.369 - info: tuya.0 (243444) 02654020840d8e804331: Connect locally to device
    2023-01-28 17:00:40.369 - info: tuya.0 (243444) 02654020840d8e804331 Init with IP=192.168.178.46, Key=113417dd7dee128e, Version=3.3
    2023-01-28 17:01:47.170 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:01:47.171 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:01:47.172 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:01:47.217 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:01:47.220 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:01:47.221 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:01:47.264 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:01:47.265 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:01:47.305 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:01:47.331 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:01:47.337 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:01:47.370 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:02:01.017 - info: tuya.0 (243444) 02654020840d8e804331: Error on Reconnect (4): connection timed out
    2023-01-28 17:02:35.355 - info: tuya.0 (243444) 02654020840d8e804331: Connect locally to device
    2023-01-28 17:02:35.355 - info: tuya.0 (243444) 02654020840d8e804331 Init with IP=192.168.178.46, Key=113417dd7dee128e, Version=3.3
    2023-01-28 17:03:46.115 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:03:46.116 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:03:46.117 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:03:46.142 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:03:46.143 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:03:46.144 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:03:46.175 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:03:46.176 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:03:46.177 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:03:46.207 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:03:46.208 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:03:46.209 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:05:24.514 - info: tuya.0 (243444) 02654020840d8e804331: Error on Reconnect (5): connection timed out
    2023-01-28 17:05:45.937 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:05:45.939 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:05:45.943 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:05:45.985 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:05:45.986 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:05:45.987 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:05:46.062 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:05:46.063 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:05:46.064 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:05:46.130 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:05:46.131 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:05:46.132 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:07:11.671 - info: tuya.0 (243444) 02654020840d8e804331: Error on Reconnect (1): connection timed out
    2023-01-28 17:07:46.066 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:07:46.067 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:07:46.068 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:07:46.118 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:07:46.119 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:07:46.119 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:07:46.155 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:07:46.156 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:07:46.157 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:07:46.217 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:07:46.218 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:07:46.219 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:08:10.273 - info: admin.0 (243242) <== Disconnect system.user.admin from ::ffff:192.168.178.69 javascript
    2023-01-28 17:09:46.181 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:09:46.182 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:09:46.183 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:09:46.216 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:09:46.217 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:09:46.218 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:09:46.269 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:09:46.270 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:09:46.271 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:09:46.295 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:09:46.296 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:09:46.298 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:10:29.143 - info: tuya.0 (243444) 02654020840d8e804331: Error on Reconnect (4): connection timed out
    2023-01-28 17:11:30.099 - info: tuya.0 (243444) 02654020840d8e804331: Connect locally to device
    2023-01-28 17:11:30.100 - info: tuya.0 (243444) 02654020840d8e804331 Init with IP=192.168.178.46, Key=113417dd7dee128e, Version=3.3
    2023-01-28 17:11:45.919 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:11:45.920 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:11:45.921 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:11:45.948 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:11:45.949 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:11:45.950 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:11:45.977 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:11:45.978 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:11:45.979 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:11:46.017 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:11:46.018 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:11:46.019 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:12:17.437 - info: tuya.0 (243444) 02654020840d8e804331: Error on Reconnect (1): connection timed out
    2023-01-28 17:13:18.224 - info: admin.0 (243242) ==> Connected system.user.admin from ::ffff:192.168.178.69
    2023-01-28 17:13:46.175 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:13:46.175 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:13:46.176 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:13:46.207 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:13:46.208 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:13:46.209 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:13:46.272 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:13:46.273 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:13:46.273 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:13:46.299 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:13:46.300 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:13:46.301 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:15:46.176 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:15:46.177 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:15:46.178 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:15:46.218 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:15:46.220 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:15:46.221 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:15:46.264 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:15:46.265 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:15:46.269 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:15:46.362 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:15:46.363 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:15:46.364 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:16:58.772 - info: tuya.0 (243444) 02654020840d8e804331: Error on Reconnect (2): connection timed out
    2023-01-28 17:17:18.904 - info: admin.0 (243242) <== Disconnect system.user.admin from ::ffff:192.168.178.69 javascript
    2023-01-28 17:17:33.775 - info: tuya.0 (243444) 02654020840d8e804331: Error on Reconnect (4): connection timed out
    2023-01-28 17:17:46.664 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:17:46.665 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:17:46.666 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:17:46.710 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:17:46.711 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:17:46.712 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:17:46.774 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:17:46.776 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:17:46.777 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:17:46.874 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:17:46.875 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:17:46.876 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:18:50.204 - info: tuya.0 (243444) 02654020840d8e804331: Connect locally to device
    2023-01-28 17:18:50.205 - info: tuya.0 (243444) 02654020840d8e804331 Init with IP=192.168.178.46, Key=113417dd7dee128e, Version=3.3
    2023-01-28 17:19:46.151 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:19:46.152 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:19:46.152 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:19:46.191 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:19:46.192 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:19:46.193 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:19:46.219 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:19:46.219 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:19:46.262 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:19:46.324 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:19:46.325 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:19:46.326 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:21:46.151 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:21:46.152 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:21:46.153 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:21:46.181 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:21:46.181 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:21:46.197 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:21:46.254 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:21:46.255 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:21:46.256 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:21:46.322 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:21:46.323 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:21:46.324 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:22:50.129 - info: tuya.0 (243444) 02654020840d8e804331: Connect locally to device
    2023-01-28 17:22:50.130 - info: tuya.0 (243444) 02654020840d8e804331 Init with IP=192.168.178.46, Key=113417dd7dee128e, Version=3.3
    2023-01-28 17:23:46.093 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:23:46.094 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:23:46.095 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:23:46.143 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:23:46.144 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:23:46.146 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:23:46.196 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:23:46.197 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:23:46.198 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:23:46.228 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:23:46.228 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
    2023-01-28 17:23:46.229 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
    2023-01-28 17:24:38.357 - info: tuya.0 (243444) 02654020840d8e804331: Error on Reconnect (2): connection timed out
    • F Flori
      So ich habe es jetzt so gemacht da kommt aber dann das ich kürzer schreiben soll es sind mehr als 100000 Zeichen enthalten. ;)
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @flori wie wäre es mal wenn Du bitte dieses Skript deaktivierst und ein neues erstellst in dem NUR dieser Block drin steht ?!
      Also den Trigger natürlich durch dieses master_mode ersetzen.
      Dann mal triggern und NUR diese Werte aus dem LOG hier posten !
      Alles andere macht hier wenig Sinn da Du sicher irgendwo noch etwas anderes am Laufen hast was auf diesen Trigger Einfluss hat..
      Aber dazu fehlt mir leider die hellseherische Kraft.
      Lehrling seit 1975 !!!
      F 2 Antworten Letzte Antwort
        @flori
        Schau hier rein:
        Flori
        Das danch scheint geklappt zu haben. Jetzt versuche ich nochmal das davor
          @flori
          Schau hier rein:
          Flori
          Ich habe eben die Debug Meldungen als Error ausgeben lassen das ich sie besser heraus lesen kann.
          • F Flori
            #66
            @flori
            Liegt da irgendwas an skripten in 'global'?
            F 1 Antwort Letzte Antwort
              @flori
              Flori
              #67
              Nein so wie ich das sehe ist der blaue Ordner leer wenn du diesen meinst.
              • F Flori
                #68
                @flori
                Nein, ich meine das Verzeichnis 'global'. Sieht man nur im Experten-Modus.
                  @flori
                  Flori
                  #69
                  Nein absolut leer
                  • DJMarc75D DJMarc75
                    Flori
                    #70
                    @djmarc75
                    So jetzt noch einmal mit genau deinem Programm. Erst das davor vor den 100000 gleichen Einträgen
                    2023-01-28 18:02:31.211 - info: admin.0 (243242) ==> Connected system.user.admin from ::ffff:192.168.178.69
                    2023-01-28 18:02:40.393 - info: admin.0 (243242) <== Disconnect system.user.admin from ::ffff:192.168.178.69 javascript
                    2023-01-28 18:03:01.808 - info: admin.0 (243242) ==> Connected system.user.admin from ::ffff:192.168.178.69
                    2023-01-28 18:03:28.880 - info: javascript.0 (243299) script.js.Alarmanlage.Neu_für_DJ: 1
                    2023-01-28 18:03:31.019 - info: admin.0 (243242) <== Disconnect system.user.admin from ::ffff:192.168.178.69 javascript
                    2023-01-28 18:03:49.503 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
                    2023-01-28 18:03:49.504 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
                    2023-01-28 18:03:49.505 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
                    2023-01-28 18:03:49.549 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
                    2023-01-28 18:03:49.551 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
                    2023-01-28 18:03:49.553 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
                    2023-01-28 18:03:49.628 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
                    2023-01-28 18:03:49.629 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
                    2023-01-28 18:03:49.629 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
                    2023-01-28 18:03:49.669 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
                    2023-01-28 18:03:49.670 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
                    2023-01-28 18:03:49.685 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
                    2023-01-28 18:03:29.471 - info: javascript.0 (243299) script.js.Alarmanlage.Neu_für_DJ: 3
                    2023-01-28 18:03:59.464 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                    2023-01-28 18:03:59.465 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                    2023-01-28 18:03:59.466 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                    2023-01-28 18:03:59.467 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                    2023-01-28 18:03:59.468 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                    2023-01-28 18:03:59.469 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                    • F Flori
                      @djmarc75
                      #71
                      @flori sagte in Alexa erzählt etwas anderes als sie soll:
                      Poste doch mal das Skript
                        Flori
                        #72
                        @djmarc75
                        Und noch einmal das danach. Mit den unzähligen Ansagen. Das berühmte Sätzchen kommt übrigens auch wieder auch ohne Sprachaktivierung. ;)
                        2023-01-28 18:04:06.149 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                        2023-01-28 18:04:06.150 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                        2023-01-28 18:04:06.152 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                        2023-01-28 18:04:06.154 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                        2023-01-28 18:04:06.169 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                        2023-01-28 18:04:06.171 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                        2023-01-28 18:04:06.172 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                        2023-01-28 18:04:06.562 - info: admin.0 (243242) ==> Connected system.user.admin from ::ffff:192.168.178.69
                        2023-01-28 18:04:11.149 - info: tuya.0 (243444) 02654020840d8e804331: Error on Reconnect (5): connection timed out
                        2023-01-28 18:04:48.208 - info: admin.0 (243242) <== Disconnect system.user.admin from ::ffff:192.168.178.69 javascript
                        2023-01-28 18:04:23.541 - info: javascript.0 (243299) script.js.Alarmanlage.Neu_für_DJ: 1
                        • F Flori
                          @djmarc75
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          #73
                          ja Du brauchst das nicht in jedem zweiten Beitrag unnötig hier posten, das nervt und ist nicht hilfreich.
                          Mach doch einfach mal was man Dir sagt wie z.B.
                          @thomas-braun sagte in Alexa erzählt etwas anderes als sie soll:
                            Flori
                            #74
                            Dieses Skript läuft aber im Moment überhaupt nicht weil da noch die Sachen mit drinne sind die ich dann bei den neuen Script komplett heraus genommen habe. Sprich Trigger in Trigger so wie das mit der Zeit.
                            DJMarc75D paul53P Thomas BraunT 3 Antworten Letzte Antwort
                            • F Flori
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              #75
                              den Adapter neu starten.
                              • F Flori
                                #76
                                @flori sagte: Dieses Skript läuft aber im Moment überhaupt nicht
                                Es werden offenbar noch gepufferte Ereignisse ausgeführt. Starte ioBroker neu oder Reboot.
                                • F Flori
                                  #77
                                  Hast du den ioBroker bzw. besser den ganzen Rechner mal neugestartet? Das hängt vermutlich noch was im Cache.
                                    Flori
                                    #78
                                    Mache ich mal alles, Rechner neu hochfahren und Raspi4 neu hochfahren.
                                      Flori
                                      #79
                                      Also den Rechner schalte ich ja zweischenzeitlich eh immer aus, aber der IObroker und Raspi Neustart scheinen etwas gebracht zu haben. Zumindest sagt sie die angegeben Texte nur noch einmal und der berühmte Satz sind bisher auch ausgeblieben.
                                      Na dann erst einmal vielen Dank für Eure Gedult mit mir und vielen Lieben Dank für Eure Hilfe.
                                      Hoffe einmal das es so bleibt. Wenn es wieder auftritt versuche ich es gleich einmal mit einem Raspi Neustart.
                                      Es war mir eben unerklärlich wo sie das jedes mal hergeholt hat. Ist ja nicht mein erstes Blockly was ich geschrieben habe. Vielen lieben Dank an Euch ALLE ;) ;)
                                      • F Flori
                                        #80
                                        @flori sagte: Wenn es wieder auftritt
                                        Wenn keine Trigger im Trigger und keine Endlosschleifen programmiert werden, sollte es nicht wieder auftreten.
                                          Flori
                                          #81
                                          Ja manchmal sieht man eben den Wald vor lauter Bäumen nicht.
                                          Jeden sage ich ob Freund oder Frau wenn etwas mit dem Handy zum Beispiel nicht stimmt.
                                          Mal ausschalten und neu Starten und dann mal schauen, aber selber komme ich nicht mal auf die Idee den Raspi einmal neu zu starten. Das hätte mir wahrscheinlich einige Stunden erspart.
                                          Vielen Lieben Dank Euch allen. ;) ;) ;)
