  3. Off Topic
  4. InfluxDB
  5. [Gelöst] InfluxDB Upgrade error
Geplant Angeheftet Gesperrt Verschoben InfluxDB
errorinfluxupgrade
54 Beiträge 9 Kommentatoren 17.6k Aufrufe 10 Beobachtet
  • R Rushmed
    @Thomas-Braun Hallo,
    bin jetzt auch über das Influxrepoproblem gestolpert.
    Hab im anderen Fred deine Anleitung gefunden.
    Kann ich die jetzt direkt übenehmen?
    Auch diese Zeile:
    sudo apt-key del 05CE 1508 5FC0 9D18 E99E  FB22 684A 14CF 2582 E0C5
    Die /etc/apt/sources.list.d/influxdata.list existiert bei mir nicht, ich habe:
    Ist da influxdb.list gemeint?
    Hier noch mein LOG beim Update:
    pi@Smartazamba:~ $ iobroker stop && sudo apt update && sudo apt full-upgrade --yes && sudo reboot
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
    Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
    Ign:4 https://repos.influxdata.com/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Get:6 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
    Err:7 https://repos.influxdata.com/debian bullseye Release
      404  Not Found [IP: 13.224.189.2 443]
    Get:8 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [311 kB]
    Err:6 https://packages.grafana.com/oss/deb stable InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [302 kB]
    Get:10 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
    Reading package lists... Done
    E: The repository 'https://repos.influxdata.com/debian bullseye Release' no longer has a Release file.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will        be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified        because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    pi@Smartazamba:~ $ ^C
    pi@Smartazamba:~ $ cat /etc/apt/sources.list.d/influxdb.list
    deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian bullseye stable
    pi@Smartazamba:~ $ apt-key list | grep influx | wc -l
    Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
    @rushmed
    Ich glaube da ist was anderes im Busch. Das Repository hängt bei mir auch in den Seilen. Hatte aber noch keine Zeit mir das genauer anzuschauen.
    R 1 Antwort Letzte Antwort
      @rushmed
      Rushmed
      @thomas-braun @thomas-braun Ok, als sollte ich deine Anleitung lieber nicht probieren?
      • R Rushmed
        @rushmed sagte in [Gelöst] InfluxDB Upgrade error:
        Moin,
        habe gerade auf den offiziellen Seiten, dieses gefunden
        Linux Package Signing Key Rotation
        All signed InfluxData Linux packages have been resigned with an updated key. If using Linux, you may need to update your package configuration to continue to download and verify InfluxData software packages.
        For more information, see the Linux Package Signing Key Rotation blog post.
        Auf der Seite steht auch wie man das wohl wieder gerade zieht, dem Blog post folgen . ;)
        InfluxDB
        Bernd
        Edit
        Die server zum Abfragen des Keys scheinen ein Problem zu haben.
        404 Not Found
            Code: NoSuchKey
            Message: The specified key does not exist.
            Key: index.html
            RequestId: A83EH4N357J8FS56
            HostId: rY32TvnfiL+lAZxL/OaRzX5reFs6R4ORaEN6L6FtqO1ndkv29+EIkdMQDGOFn7DjHV6phMr1m/k=
          Moin,
          InfluxDB
          Bernd
          Edit
          404 Not Found
              Code: NoSuchKey
              Key: index.html
          Rushmed
          @dp20eic Bist du danach vorgegangen?
          • R Rushmed
            @rushmed
            Moin,
            ja, aber es wird nicht der key geladen, da die Server Zicken :(
            Sprich, der Befehl kann nichts holen
            wget -q https://repos.influxdata.com/influxdata-archive_compat.key
            Dann kommt halt, als Konsequenz,
            gpg: can't open './influxdata-archive_compat.key': No such file or directory
            Also auf die fünf Buchstaben setzen und warten, bis die das repariert haben :)
            Bernd
              @rushmed
              Moin,
              Bernd
              Rushmed
              @dp20eic Oke, ich gedulde mich.
              • R Rushmed
                @rushmed
                Moin,
                die Störung auf dem Repo. Server(n) scheint behoben zu sein, alle die InfluxDB auf Debian nutzen und von der Änderung des Keys betroffen sind, können anhand der Beschreibung auf New-Key Ihre Installation grade ziehen und aktualisieren.
                Bernd
                LatziL 1 Antwort Letzte Antwort
                  @rushmed
                  Moin,
                  Bernd
                  LatziL Online
                  LatziL Online
                  Latzi
                  @dp20eic
                  irgendwie funktioniert´s bei mir nicht, mit der Fehlermeldung beim sudo apt update kann ich nichts anfangen.
                  Indfluxdb2 läuft in einem Proxmox LXC
                  latzi@influxDB:~$ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                  latzi@influxDB:~$ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
                  pub   rsa4096 2023-01-18 [SC] [expires: 2026-01-17]
                        9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
                  uid                      InfluxData Package Signing Key <support@influxdata.com>
                  latzi@influxDB:~$ cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                  latzi@influxDB:~$ echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                  latzi@influxDB:~$ sudo rm -f /etc/apt/trusted.gpg.d/influxdb.gpg
                  latzi@influxDB:~$ sudo apt update
                  Hit:1 http://security.debian.org bullseye-security InRelease
                  Hit:2 http://ftp.debian.org/debian bullseye InRelease
                  Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                  Hit:4 https://repos.influxdata.com/debian stable InRelease
                  Get:5 https://repos.influxdata.com/debian bullseye InRelease [7022 B]
                  Err:5 https://repos.influxdata.com/debian bullseye InRelease
                    The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  Fetched 7022 B in 0s (15.8 kB/s)
                  All packages are up to date.
                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  W: Some index files failed to download. They have been ignored, or old ones used instead.
                  latzi@influxDB:~$
                  Thomas BraunT ? 2 Antworten Letzte Antwort
                  • LatziL Latzi
                    @dp20eic
                    latzi@influxDB:~$
                    @latzi sagte in [Gelöst] InfluxDB Upgrade error:
                    Der öffentliche Schlüssel D8FF8E1F7DF8B07E wurde nicht richtig reingeladen bei dir.
                      LatziL Online
                      LatziL Online
                      Latzi
                      okay, wie bekomm ich den rein? Ich hab die obigen statements schon mehrmals durchlaufen lassen - ändert leider nichts.
                      Hast du einen Tipp für mich?
                      • LatziL Latzi
                        Bin im Moment nicht am Rechner.
                          LatziL Online
                          LatziL Online
                          Latzi
                          ;-) kein Problem - eilt gar nicht - ich bin dir für deine Unterstützung sehr dankbar!
                          • LatziL Latzi
                            @dp20eic
                            latzi@influxDB:~$
                            @latzi
                            Moin,
                            kenne Deine Installation nicht, bei mir ging es genau so. Ich brauchte nur nichts löschen, da das File /etc/apt/trusted.gpg.d/influxdb.gpg nicht gab.
                            Hast Du unten weiter gelesen?
                            The above specifies paths to files and configuration from the most recent documentation. Users who use a different file than /etc/apt/sources.list.d/influxdata.list need to update the file to use signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg. Similarly, users who installed the old key in a different location than /etc/apt/trusted.gpg.d/influxdb.gpg need to use that location to remove the old key.
                            Meine Source.list sieht so aus
                            [dp20eic@influxDB ~]$ ls -la /etc/apt//sources.list.d/
                            total 14
                            drwxr-xr-x 2 root root   4 Jan 27 11:06 .
                            drwxr-xr-x 8 root root  11 Aug  9  2021 ..
                            -rw-r--r-- 1 root root 117 Jan 27 09:49 influxdata.list
                            -rw-r--r-- 1 root root  59 May  8  2022 non-free.list
                            Die dazugehörige trusted.gpg.d
                            [dp20eic@influxDB ~]$ ls -la /etc/apt/trusted.gpg.d/
                            total 110
                            drwxr-xr-x 2 root root   12 Jan 27 09:47 .
                            -rw-r--r-- 1 root root 8700 Feb 25  2021 debian-archive-bullseye-automatic.gpg
                            -rw-r--r-- 1 root root 8709 Feb 25  2021 debian-archive-bullseye-security-automatic.gpg
                            -rw-r--r-- 1 root root 2453 Feb 25  2021 debian-archive-bullseye-stable.gpg
                            -rw-r--r-- 1 root root 8132 Feb 25  2021 debian-archive-buster-automatic.gpg
                            -rw-r--r-- 1 root root 8141 Feb 25  2021 debian-archive-buster-security-automatic.gpg
                            -rw-r--r-- 1 root root 2332 Feb 25  2021 debian-archive-buster-stable.gpg
                            -rw-r--r-- 1 root root 7443 Feb 25  2021 debian-archive-stretch-automatic.gpg
                            -rw-r--r-- 1 root root 7452 Feb 25  2021 debian-archive-stretch-security-automatic.gpg
                            -rw-r--r-- 1 root root 2263 Feb 25  2021 debian-archive-stretch-stable.gpg
                            -rw-r--r-- 1 root root 1185 Jan 27 09:48 influxdata-archive_compat.gpg
                            Buster und stretch muss ich mal schauen, die kann ich glaube ich entfernen, muss mal bei Debian nachlesen, aktuell stören sie mich aber nicht.
                            Bernd
                              @latzi
                              Moin,
                              total 14
                              total 110
                              Bernd
                              LatziL Online
                              LatziL Online
                              Latzi
                              @dp20eic
                              schaut bei mir so aus:
                              latzi@influxDB:~$ ls -la /etc/apt//sources.list.d/
                              total 16
                              drwxr-xr-x 2 root root 4096 Jan 27 11:10 .
                              drwxr-xr-x 8 root root 4096 Aug 16  2021 ..
                              -rw-r--r-- 1 root root  117 Jan 27 11:01 influxdata.list
                              -rw-r--r-- 1 root root  101 Jan 27 11:10 influxdb.list
                              latzi@influxDB:~$
                              latzi@influxDB:~$ ls -la /etc/apt/trusted.gpg.d/
                              total 80
                              drwxr-xr-x 2 root root 4096 Jan 27 08:25 .
                              -rw-r--r-- 1 root root 1185 Jan 27 11:00 influxdata-archive_compat.gpg
                              latzi@influxDB:~$
                              • LatziL Latzi
                                @dp20eic
                                total 16
                                latzi@influxDB:~$
                                total 80
                                latzi@influxDB:~$
                                Moin,
                                Du hast da noch zwei Sorces für Influx, siehe
                                total 16
                                Wenn Du apt-get update ausführst, dann bekommst Du den Fehler
                                Schau mal was in den einzelnen Source-Listen steht
                                [dp20eic@influxDB ~]$ cat /etc/apt/sources.list.d/influxdata.list
                                Und dann verschiebe mal die die nicht mehr benötigte Datei influxdb.list nach /tmp und mach mal ein update
                                # sudo mv /etc/apt/sources.list.d/influxdb.list /tmp
                                # sudo apt-get update
                                Bernd
                                  Moin,
                                  total 16
                                  Bernd
                                  LatziL Online
                                  LatziL Online
                                  Latzi
                                  @dp20eic
                                  das ist der Inhalt der beiden:
                                  latzi@influxDB:~$ cat /etc/apt/sources.list.d/influxdata.list
                                  latzi@influxDB:~$ cat /etc/apt/sources.list.d/influxdb.list
                                  deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/debian bullseye stable
                                  latzi@influxDB:~$
                                  wenn ich die influxdb.list verschiebe schaut das apt update so aus:
                                  latzi@influxDB:/$ sudo apt update
                                  Get:1 http://security.debian.org bullseye-security InRelease [48.4 kB]
                                  Fetched 48.4 kB in 0s (116 kB/s)
                                  latzi@influxDB:/$
                                  Ich würde mal behaupten es passt (zumindest ist der Fehler weg), vielen herzlichen Dank! 👍 👏
                                  • LatziL Latzi
                                    @dp20eic
                                    latzi@influxDB:~$
                                    latzi@influxDB:/$
                                    @latzi
                                    Moin,
                                    wichtig ist, dass Du die zusammenhänge erkennst, zwischen dem Fehler von oben und der Lösung ;)
                                    Und/oder auch erkennst was Du da mit dem Update des Keys gemacht hast.
                                    Der Fehler von oben hing nur noch mit der alten Liste zusammen, einem
                                    # sudo apt-get upgrade
                                    hätte das nicht gestört, glaube ich :), wäre halt nur immer eine Fehlermeldung, die man nicht haben möchte.
                                    Bernd
                                    • R Offline
                                      Rushmed
                                      schrieb am zuletzt editiert von Rushmed
                                      Was hat denn das zu bedeuten?
                                      pi@Smartazamba:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                      pi@Smartazamba:~ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
                                      gpg: directory '/home/pi/.gnupg' created
                                      gpg: keybox '/home/pi/.gnupg/pubring.kbx' created
                                      -bash: pub: command not found
                                      -bash: 9D53: command not found
                                      -bash: syntax error near unexpected token `newline'
                                      EDIT: Hat doch geklappt.
                                      Meister MopperM R 2 Antworten Letzte Antwort
                                      • R Rushmed
                                        Meister MopperM Online
                                        Meister Mopper
                                        Sehr gut Männer,
                                        das Problem hat mich den ganzen Tag beschäftigt. Jetzt ist es keines mehr! 👍
                                        Proxmox und HA ...
                                        • C Offline
                                          cbrocker
                                          @dp20eic sagte
                                          kennst Du dich mit der InfluxDB Abfragesprache influxQL gut aus und Flux ist häh wasn das, dann bleib lieber bei der 1.8 Version und fang heute schon mal an Dich mit Flux zu beschäftigen
                                          Wenn Du gerade erst beginnst, dann kannst Du auch gleich mit V2.x weitermachen, vorher natürlich gut einlesen, wegen Datenmigration 1.8 -> 2.x und wie immer Backups nicht vergessen
                                          Hey dp20eic,
                                          hast du selber mal InfluxDB Daten von 1.8.x auf 2.6 migriert?
                                          Proxmox Cluster mit ioBroker, Wireguard, HomeAssistant (Testsystem), paperlessNGX, MariaDB, PiHole, Grafana, InfluxDB, 1 x BKW 600 Wp, 2 x BKW 400 Wp, 2 x SolarFlow 800 Pro mit 11,52 kWh Akku und 3,48 kWp, OpenDTU, AhoyDTU, HmIP, Shellys, AVM LAN/WLAN
