  3. Einsteigerfragen
  4. Fehlermeldungen bei Backup auf NAS [gelöst]
    5.5k
27 Beiträge 5 Kommentatoren 1.5k Aufrufe 4 Beobachtet
    @peter666666
    Ja, dann kann man das besser lesen, daraus zitieren usw.
    Peter666666
    schrieb am zuletzt editiert von Peter666666
    Also so? Oder die restlichen Sachen rauslöschen?
    2023-01-24 12:44:57.248 - error: host.e73f64821262 Invalid request getRepository. "callback" or "from" is null
    2023-01-24 12:45:00.060 - info: host.e73f64821262 instance system.adapter.daswetter.0 started with pid 22228
    2023-01-24 12:45:01.280 - info: daswetter.0 (22228) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.23
    2023-01-24 12:45:09.592 - info: daswetter.0 (22228) still wrong data structure from server received! repaired...
    2023-01-24 12:45:11.841 - info: daswetter.0 (22228) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-01-24 12:45:12.348 - info: daswetter.0 (22228) cleaned everything up...
    2023-01-24 12:45:12.369 - info: host.e73f64821262 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-24 12:48:19.854 - info: cloud.1 (849) User accessed from cloud: K-kYA9Klo_WrLGffATFY
    2023-01-24 12:49:18.372 - info: cloud.1 (849) User disconnected from cloud: K-kYA9Klo_WrLGffATFY
    2023-01-24 12:49:20.259 - info: cloud.1 (849) User accessed from cloud: xw-RPZCn509e9VYiATF7
    2023-01-24 12:49:53.606 - info: host.e73f64821262 stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-01-24 12:49:53.610 - info: backitup.0 (21654) Got terminate signal TERMINATE_YOURSELF
    2023-01-24 12:49:53.612 - info: backitup.0 (21654) cleaned everything up...
    2023-01-24 12:49:53.613 - info: backitup.0 (21654) terminating
    2023-01-24 12:49:53.613 - info: backitup.0 (21654) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-24 12:49:53.649 - info: host.e73f64821262 stopInstance system.adapter.backitup.0 send kill signal
    2023-01-24 12:49:54.160 - info: host.e73f64821262 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-24 12:49:56.751 - info: host.e73f64821262 instance system.adapter.backitup.0 started with pid 22504
    2023-01-24 12:49:58.043 - info: backitup.0 (22504) starting. Version 2.5.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.0, js-controller: 4.0.23
    2023-01-24 12:49:58.171 - info: backitup.0 (22504) [iobroker] backup was activated at 02:40 every 1 day(s)
    2023-01-24 12:49:58.664 - error: backitup.0 (22504) Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
    Unable to apply new capability set.
    2023-01-24 12:50:09.166 - info: host.e73f64821262 stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-01-24 12:50:09.170 - info: backitup.0 (22504) Got terminate signal TERMINATE_YOURSELF
    2023-01-24 12:50:09.171 - info: backitup.0 (22504) cleaned everything up...
    2023-01-24 12:50:09.171 - info: backitup.0 (22504) terminating
    2023-01-24 12:50:09.172 - info: backitup.0 (22504) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-24 12:50:09.209 - info: host.e73f64821262 stopInstance system.adapter.backitup.0 send kill signal
    2023-01-24 12:50:09.714 - info: host.e73f64821262 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-24 12:50:12.253 - info: host.e73f64821262 instance system.adapter.backitup.0 started with pid 22540
    2023-01-24 12:50:13.411 - info: backitup.0 (22540) starting. Version 2.5.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.0, js-controller: 4.0.23
    2023-01-24 12:50:13.473 - info: backitup.0 (22540) [iobroker] backup was activated at 02:40 every 1 day(s)
    2023-01-24 12:50:13.867 - error: backitup.0 (22540) Error: Command failed: mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
    2023-01-24 12:50:24.620 - error: backitup.0 (22540) [iobroker/mount] [undefined Error: Command failed: mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
    2023-01-24 12:50:24.620 - error: backitup.0 (22540) [iobroker/mount] Unable to apply new capability set.
    2023-01-24 12:50:24.621 - error: backitup.0 (22540) [iobroker/mount] Error: Command failed: mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
    2023-01-24 12:50:24.621 - error: backitup.0 (22540) [iobroker/mount] Unable to apply new capability set.
    2023-01-24 12:50:24.622 - error: backitup.0 (22540) [iobroker] Error: Command failed: mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
    2023-01-24 12:51:12.196 - info: cloud.1 (849) User disconnected from cloud: xw-RPZCn509e9VYiATF7
    2023-01-24 12:51:25.737 - info: cloud.1 (849) User accessed from cloud: 3gwKk0kJePfRo1C5ATHI
    2023-01-24 12:52:41.430 - warn: cloud.1 (849) User disconnected from cloud: 0 3gwKk0kJePfRo1C5ATHI
    2023-01-24 12:52:41.431 - info: cloud.1 (849) User disconnected from cloud:
    2023-01-24 12:57:39.273 - info: cloud.1 (849) received all objects
    2023-01-24 12:59:04.419 - info: admin.0 (530) Request actual repository...
    2023-01-24 12:59:04.732 - info: host.e73f64821262 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-01-24 12:59:05.842 - info: admin.0 (530) Repository received successfully.
    2023-01-24 13:00:00.069 - info: host.e73f64821262 instance system.adapter.daswetter.0 started with pid 23095
    2023-01-24 13:00:01.223 - info: daswetter.0 (23095) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.23
    2023-01-24 13:00:02.051 - error: cloud.1 (849) Cannot request admin pages:
    Cannot GET /socket.io/
    2023-01-24 13:00:03.487 - error: cloud.1 (849) Cannot request admin pages:
    2023-01-24 13:00:04.095 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 started with pid 23110
    2023-01-24 13:00:05.305 - error: cloud.1 (849) Cannot request admin pages:
    2023-01-24 13:00:06.086 - info: fuelpricemonitor.0 (23110) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v16.19.0, js-controller: 4.0.23
    2023-01-24 13:00:06.110 - info: fuelpricemonitor.0 (23110) Started with JSON-Explorer version 0.1.10
    2023-01-24 13:00:10.404 - error: cloud.1 (849) Cannot request admin pages:
    2023-01-24 13:00:13.461 - info: fuelpricemonitor.0 (23110) Terminated (NO_ERROR): Without reason
    2023-01-24 13:00:13.969 - info: fuelpricemonitor.0 (23110) cleaned everything up...
    2023-01-24 13:00:13.985 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
    2023-01-24 13:00:15.310 - info: daswetter.0 (23095) still wrong data structure from server received! repaired...
    2023-01-24 13:00:17.533 - info: daswetter.0 (23095) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-01-24 13:00:18.045 - info: daswetter.0 (23095) cleaned everything up...
    2023-01-24 13:00:18.064 - info: host.e73f64821262 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-24 13:00:19.559 - info: cloud.1 (849) User accessed from cloud: AZEXg8FpqhnWdZqAATLo
    2023-01-24 13:00:22.020 - info: cloud.1 (849) User disconnected from cloud: AZEXg8FpqhnWdZqAATLo
    2023-01-24 13:05:55.389 - info: cloud.1 (849) User accessed from cloud: MMm1qIvpysIQNsBUATOq
    2023-01-24 13:13:17.305 - info: cloud.1 (849) User disconnected from cloud: MMm1qIvpysIQNsBUATOq
    2023-01-24 13:13:17.311 - info: cloud.1 (849) User disconnected from cloud: NokHvXGAjLO20NjTATC_
    2023-01-24 13:15:00.057 - info: host.e73f64821262 instance system.adapter.daswetter.0 started with pid 23905
    2023-01-24 13:15:01.192 - info: daswetter.0 (23905) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.23
    2023-01-24 13:15:09.230 - info: daswetter.0 (23905) still wrong data structure from server received! repaired...
    2023-01-24 13:15:11.432 - info: daswetter.0 (23905) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-01-24 13:15:11.940 - info: daswetter.0 (23905) cleaned everything up...
    2023-01-24 13:15:11.960 - info: host.e73f64821262 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-24 13:20:00.095 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 started with pid 24180
    2023-01-24 13:20:01.317 - info: fuelpricemonitor.0 (24180) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v16.19.0, js-controller: 4.0.23
    2023-01-24 13:20:01.337 - info: fuelpricemonitor.0 (24180) Started with JSON-Explorer version 0.1.10
    2023-01-24 13:20:06.683 - info: fuelpricemonitor.0 (24180) Terminated (NO_ERROR): Without reason
    2023-01-24 13:20:07.191 - info: fuelpricemonitor.0 (24180) cleaned everything up...
    2023-01-24 13:20:07.209 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
    2023-01-24 13:22:21.568 - info: cloud.1 (849) User accessed from cloud: taDOa7y5WAhUpOs1ATVS
    2023-01-24 13:23:29.644 - info: cloud.1 (849) User disconnected from cloud: taDOa7y5WAhUpOs1ATVS
    2023-01-24 13:30:00.059 - info: host.e73f64821262 instance system.adapter.daswetter.0 started with pid 24711
    2023-01-24 13:30:01.243 - info: daswetter.0 (24711) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.23
    2023-01-24 13:30:07.530 - error: daswetter.0 (24711) exception in HourlyForecast [AxiosError: Request failed with status code 502]
    2023-01-24 13:30:07.653 - error: daswetter.0 (24711) exception in getForecastDataHourlyJSON [AxiosError: Request failed with status code 502]
    2023-01-24 13:30:07.654 - info: daswetter.0 (24711) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-01-24 13:30:08.162 - info: daswetter.0 (24711) cleaned everything up...
    2023-01-24 13:30:08.175 - info: host.e73f64821262 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-24 13:39:36.607 - info: cloud.1 (849) User accessed from cloud: K6va0EGI5Fmv9Yk3ATcP
    2023-01-24 13:39:45.764 - info: cloud.1 (849) User accessed from cloud: qbIfXHpE25svn3RPATcc
    2023-01-24 13:39:59.789 - info: host.e73f64821262 stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-01-24 13:39:59.794 - info: backitup.0 (22540) Got terminate signal TERMINATE_YOURSELF
    2023-01-24 13:39:59.795 - info: backitup.0 (22540) cleaned everything up...
    2023-01-24 13:39:59.795 - info: backitup.0 (22540) terminating
    2023-01-24 13:39:59.796 - info: backitup.0 (22540) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-24 13:39:59.835 - info: host.e73f64821262 stopInstance system.adapter.backitup.0 send kill signal
    2023-01-24 13:40:00.063 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 started with pid 25259
    2023-01-24 13:40:00.340 - info: host.e73f64821262 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-24 13:40:01.497 - info: fuelpricemonitor.0 (25259) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v16.19.0, js-controller: 4.0.23
    2023-01-24 13:40:01.519 - info: fuelpricemonitor.0 (25259) Started with JSON-Explorer version 0.1.10
    2023-01-24 13:40:03.420 - info: host.e73f64821262 instance system.adapter.backitup.0 started with pid 25274
    2023-01-24 13:40:06.392 - info: backitup.0 (25274) starting. Version 2.5.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.0, js-controller: 4.0.23
    2023-01-24 13:40:06.453 - info: backitup.0 (25274) [iobroker] backup was activated at 02:40 every 1 day(s)
    2023-01-24 13:40:06.993 - error: backitup.0 (25274) Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
    2023-01-24 13:40:07.591 - info: fuelpricemonitor.0 (25259) Terminated (NO_ERROR): Without reason
    2023-01-24 13:40:08.099 - info: fuelpricemonitor.0 (25259) cleaned everything up...
    2023-01-24 13:40:08.117 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
    2023-01-24 13:40:23.585 - error: backitup.0 (25274) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
    2023-01-24 13:40:23.586 - error: backitup.0 (25274) [iobroker/mount] Unable to apply new capability set.
    2023-01-24 13:40:23.586 - error: backitup.0 (25274) [iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
    2023-01-24 13:40:23.587 - error: backitup.0 (25274) [iobroker] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
    2023-01-24 13:40:54.515 - info: cloud.1 (849) User disconnected from cloud: qbIfXHpE25svn3RPATcc
    2023-01-24 13:45:00.060 - info: host.e73f64821262 instance system.adapter.daswetter.0 started with pid 25574
    2023-01-24 13:45:01.221 - info: daswetter.0 (25574) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.23
    2023-01-24 13:45:03.863 - info: cloud.1 (849) User disconnected from cloud: K6va0EGI5Fmv9Yk3ATcP
    2023-01-24 13:45:11.202 - info: daswetter.0 (25574) still wrong data structure from server received! repaired...
    2023-01-24 13:45:13.381 - info: daswetter.0 (25574) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-01-24 13:45:13.890 - info: daswetter.0 (25574) cleaned everything up...
    2023-01-24 13:45:13.905 - info: host.e73f64821262 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-24 13:59:47.962 - info: cloud.1 (849) User accessed from cloud: NS-F1bJvpGrmox7cATlj
    LG Peter
    Intel NUC i5 / 16GB RAM / 512GB SSD
    Synology DS220+ 10GB RAM / 8TB
    • P Peter666666
      CodierknechtC Offline
      Codierknecht
      @peter666666
      Nein - damit:
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      P 1 Antwort Letzte Antwort
      • Thomas BraunT Online
        @peter666666
        ioBroker im Container, ohne Privileged Mode?
        • CodierknechtC Codierknecht
          @peter666666
          Nein - damit:
          Peter666666
          @codierknecht erledigt :) - dachte das ist nur für Skript einfügen.
          LG Peter
            @peter666666
            Peter666666
            @thomas-braun was ist Privileged Mode?
            LG Peter
            • P Peter666666
              @peter666666
              Eine Konfiguratiosoption für einen Container.
              P GlasfaserG 2 Antworten Letzte Antwort
                @peter666666
                Peter666666
                @thomas-braun puhh -wo sehe ich das? Habe es lt. Anleitung https://mariushosting.com/how-to-install-iobroker-on-your-synology-nas/ gemacht.
                LG Peter
                • P Peter666666
                  @peter666666
                  Bei Containern bin ich raus.
                  • GlasfaserG Offline
                    GlasfaserG Offline
                    @peter666666 sagte in Fehlermeldungen bei Backup auf NAS:
                    https://forum.iobroker.net/topic/44092/gelöst-backitup-unable-to-apply-new-capability-set
                    In der Syn Docker Oberfläche , Docker iobroker stoppen " Bearbeiten " Privileged anhaken .
                    CodierknechtC P 2 Antworten Letzte Antwort
                      @peter666666
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @Peter666666
                      Große Frage , nutzt du auf deiner Synology den Benutzer " Admin " !?
                      • GlasfaserG Glasfaser
                        Codierknecht
                        @glasfaser sagte in Fehlermeldungen bei Backup auf NAS:
                        In DSM 6 hieß das noch "Container mit hoher Priorität ausführen"
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @codierknecht sagte in Fehlermeldungen bei Backup auf NAS:
                          Ist auch gleich geblieben ... bei DSM 7 ..
                          binn halt das Wort "Privileged " gewohnt ,
                          ... es kann auch auch sein das er Portainer nutzt ... dort ist es "Privileged Mode"
                            @Peter666666
                            Peter666666
                            @glasfaser Nein nutze ich nicht. Warum?
                            LG Peter
                              Peter666666
                              @glasfaser Habe ich gemacht (mit hoher Prio ausführen - root). Leider kommen wieder Fehlermeldungen:
                              2023-01-24 17:38:51.311 - info: admin.0 (148) ==> Connected system.user.admin from ::ffff:172.17.0.1
                              2023-01-24 17:38:59.746 - info: admin.0 (148) <== Disconnect system.user.admin from ::ffff:172.17.0.1
                              2023-01-24 17:39:02.751 - info: admin.0 (148) ==> Connected system.user.admin from ::ffff:172.17.0.1
                              2023-01-24 17:39:32.451 - error: backitup.0 (320) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
                              2023-01-24 17:39:32.452 - error: backitup.0 (320) [iobroker/mount] mount error(13): Permission denied
                              2023-01-24 17:39:32.452 - error: backitup.0 (320) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                              2023-01-24 17:39:32.452 - error: backitup.0 (320) [iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
                              2023-01-24 17:39:32.453 - error: backitup.0 (320) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                              2023-01-24 17:39:32.453 - error: backitup.0 (320) [iobroker] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
                              2023-01-24 17:39:56.571 - info: admin.0 (148) <== Disconnect system.user.admin from ::ffff:172.17.0.1
                              2023-01-24 17:40:00.055 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 started with pid 643
                              2023-01-24 17:40:01.279 - info: fuelpricemonitor.0 (643) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v16.19.0, js-controller: 4.0.23
                              2023-01-24 17:40:01.302 - info: fuelpricemonitor.0 (643) Started with JSON-Explorer version 0.1.10
                              2023-01-24 17:40:07.364 - info: fuelpricemonitor.0 (643) Terminated (NO_ERROR): Without reason
                              2023-01-24 17:40:07.871 - info: fuelpricemonitor.0 (643) cleaned everything up...
                              2023-01-24 17:40:07.886 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
                              LG Peter
                              • P Peter666666
                                Hallo Leute,
                                Ich würde gerne das ioBroker Backup auf mein NAS sichern. Habe dazu am NAS einen eigenen Benutzer angelegt mit den Schreib und Leserechten in den Backup Ordner. Im Backup Adapter wurde Benutzer und PW vom NAS Benutzer eingetragen. Wenn ich das Backup jetzt manuell anstoße kommen einige Fehlermeldungen:
                                Log:
                                Einstellung im NAS & Adapter:
                                In der Hilfe steht was von CIFS Mount....was ist das?
                                2023-01-24 13_07_40-ioBroker.backitup Wiki Deutsch · simatec_ioBroker.backitup Wiki · GitHub.png
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Sorry habe nicht den ganzen Beitrag gelesen , aber
                                du hast eine Syn Nas , auf der ist im Docker ioBroker und du möchtest das Backup auslagern ...
                                auf die selbe Syn Nas ....
                                Ist unlogisch , denn warum gehts du über CIFS bzw. so einen UMWEG !
                                Mounte den Backup Ordner von deiner Nas in den Einstellungen vom ioBroker Docker .
                                  Peter666666
                                  @glasfaser das hört sich einfacher an. Blöde Frage :) Wie Mounte ich den Ordner?
                                  LG Peter
                                  • P Peter666666
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Naja ... bin ja nicht so... in der Suche ...
                                    https://forum.iobroker.net/post/896365
                                      Peter666666
                                      @glasfaser vielen Dank!!! Hab nur mehr zwei Fehler drinnen bzgl. History.
                                      2023-01-24 18:15:24.628 - info: admin.0 (139) ==> Connected system.user.admin from ::ffff:172.17.0.1
                                      2023-01-24 18:15:46.168 - error: backitup.0 (324) [iobroker/historyDB] Backitup cannot found source "undefined" for compress!
                                      2023-01-24 18:15:46.169 - error: backitup.0 (324) [iobroker] Backitup cannot found source "undefined" for compress!
                                      2023-01-24 18:16:30.124 - info: admin.0 (139) <== Disconnect system.user.admin from ::ffff:172.17.0.1
                                      LG Peter
                                      • P Peter666666
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @peter666666
                                        https://forum.iobroker.net/topic/61217/gelöst-backitup-cannot-found-source-undefined-for-compress
                                          @peter666666
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          @glasfaser
                                          Die Suche muss @Peter666666 noch lernen ;-)
                                          Danke.
