  2. English
  3. Off Topic
  4. Problem with updating Debian with grafana...
    apollon77A
23 Beiträge 8 Kommentatoren 12.3k Aufrufe 8 Beobachtet
  • C
    C
    cainam
    Hello
    I am running on a virtual machine (LTX) under proxmox a debian buster with grafana and influxdb.
    As i want update influxdb i have to first update debian to bullseye.
    I can update with this instruction to debian 11
    sudo apt full-upgrade
    sudo apt autoremove
    sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list
    sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list.d/*.list
    sudo sed -i 's#/debian-security bullseye/updates# bullseye-security#g' /etc/apt/sources.list
    export LC_ALL=C
    sudo apt update
    sudo apt upgrade
    sudo apt autoremove
    sudo systemctl reboot
    but after this i cant start grafana anymore - i tried to uninstall install it, also to uninstall before updating then installing it... now chance, and looks like this:
    root@datenTest:~# sudo systemctl status grafana-server
    * grafana-server.service - Grafana instance
         Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Mon 2023-01-23 21:50:05 CET; 4s ago
           Docs: http://docs.grafana.org
        Process: 653 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/g>
       Main PID: 653 (code=exited, status=226/NAMESPACE)
            CPU: 28ms
    Jan 23 21:50:05 datenTest systemd[1]: grafana-server.service: Main process exited, code=exited, statu>
    Jan 23 21:50:05 datenTest systemd[1]: grafana-server.service: Failed with result 'exit-code'.
    Jan 23 21:50:05 datenTest systemd[1]: grafana-server.service: Scheduled restart job, restart counter >
    Jan 23 21:50:05 datenTest systemd[1]: Stopped Grafana instance.
    Jan 23 21:50:05 datenTest systemd[1]: grafana-server.service: Start request repeated too quickly.
    Jan 23 21:50:05 datenTest systemd[1]: Failed to start Grafana instance.
    Thanks for help
    Thomas BraunT OliverIOO ? 3 Antworten Letzte Antwort
    • C cainam
      Hello
      sudo apt autoremove
      export LC_ALL=C
      sudo apt update
      sudo apt upgrade
      sudo apt autoremove
              CPU: 28ms
      Thanks for help
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      @cainam
      Nicht als root herumkaspern.
      sudo apt update
      apt policy grafana
      sagt?
      • C
        C
        cainam
        Ich habe nur ein root usr und habe immer alles über den gemacht… was heisst ich soll das Update Debian ohne sudo machen oder Grafana install ohne sudo oder wie meinst du?
        • C cainam
          Thomas BraunT
          Thomas BraunT
          @cainam sagte in Problem with updating Debian with grafana...:
          Ist halt falsch.
          Leg dir einen Standard-User an und rumpel mit dem durch das System.
          Offenbar bist du ja alles andere als sattelfest in der Kommandozeile. Sonst würdest du nicht so'n Quatsch eingeben. Umso wichtiger ist es, so einen Quark nicht gleich mit root-Rechten reinzuklatschen.
          Du sollst die Ausgabe zu
          sudo apt update
          apt policy grafana
          posten. Und das ganze halt nicht als root machen.
          C 1 Antwort Letzte Antwort
          • C cainam
            Hello
            sudo apt autoremove
            export LC_ALL=C
            sudo apt update
            sudo apt upgrade
            sudo apt autoremove
                    CPU: 28ms
            Thanks for help
            OliverIOO
            OliverIOO
            OliverIO
            LTX
            what is LTX? Did you mean LXC=Linux containers?
            maybe you mix the terms.
            do you use a virtual machine or do you use a LXC container?
            these are different modes in proxmox
            normaly with containers, you dont update the operatiing system, you only change the container definition and in this container definition is bound to an dedicated Operating system. the container definition has volumes/mounts there the application data is saved. all other data (logs etc) are volatile and remains inside the container. if the container is recreated/redefined these data are lost.
            if you use a container as a replacement for a virtual machine, then you do it wrong
            @Thomas-braun in containern wird meist immer nur mit root gearbeitet.
            wenn man die definition von jemanden übernimmt, dann hat man da nur bedingt Einfluss. Ob das best practice ist weiß ich nicht. Ich sehe, das einige große distributionen mittlerweile ihre container auch innen mit entsprechenden usern versehen hat.
            Meine Adapter und Widgets
            Links im Profil
            Thomas BraunT C 2 Antworten Letzte Antwort
            • OliverIOO OliverIO
              LTX
              Thomas BraunT
              Thomas BraunT
              @oliverio sagte in Problem with updating Debian with grafana...:
              Definitiv NICHT. Unix/Linux ist und war schon immer ein Multiuser-System.
              Und so sollte es auch verwendet werden. Der root ist eigentlich nur noch aus technischen Gründen hinter den Kulissen tätig.
              Per sudo wird der halt nur bei Bedarf kurzfristig auf den Plan gerufen.
                Ist halt falsch.
                sudo apt update
                apt policy grafana
                C
                C
                cainam
                @thomas-braun said in Problem with updating Debian with grafana...:
                sudo apt update apt policy grafana
                grafana:
                  Installed: 9.3.2
                  Candidate: 9.3.2
                  Version table:
                 *** 9.3.2 100
                     9.2.3 500
                        500 https://packages.grafana.com/oss/deb stable/main amd64 Packages
                     9.2.2 500
                     9.2.1 500
                     9.2.0 500
                     9.1.8 500
                     9.1.7 500
                     9.1.6 500
                     9.1.5 500
                     9.1.4 500
                     9.1.3 500
                     9.1.2 500
                     9.1.1 500
                     9.1.0 500
                     9.0.9 500
                     9.0.8 500
                     9.0.7 500
                     9.0.6 500
                     9.0.5 500
                     9.0.4 500
                     9.0.3 500
                     9.0.2 500
                     9.0.1 500
                     9.0.0 500
                     8.5.14 500
                     8.5.13 500
                     8.5.12 500
                     8.5.10 500
                     8.5.9 500
                     8.5.6 500
                     8.5.5 500
                     8.5.4 500
                     8.5.3 500
                     8.5.2 500
                     8.5.1 500
                     8.5.0 500
                     8.4.11 500
                     8.4.10 500
                     8.4.7 500
                     8.4.6 500
                     8.4.5 500
                     8.4.4 500
                     8.4.3 500
                     8.4.2 500
                     8.4.1 500
                     8.4.0 500
                     8.3.11 500
                     8.3.10 500
                     8.3.7 500
                     8.3.6 500
                     8.3.5 500
                     8.3.4 500
                     8.3.3 500
                     8.3.2 500
                     8.3.1 500
                     8.3.0 500
                     8.2.7 500
                     8.2.6 500
                     8.2.5 500
                     8.2.4 500
                     8.2.3 500
                     8.2.2 500
                     8.2.1 500
                     8.2.0 500
                     8.1.8 500
                     8.1.7 500
                     8.1.6 500
                     8.1.5 500
                     8.1.4 500
                     8.1.3 500
                     8.1.2 500
                     8.1.1 500
                     8.1.0 500
                     8.0.7 500
                     8.0.6 500
                     8.0.5 500
                     8.0.4 500
                     8.0.3 500
                     8.0.2 500
                     8.0.1 500
                     8.0.0 500
                     7.5.16 500
                     7.5.15 500
                     7.5.13 500
                     7.5.12 500
                     7.5.11 500
                     7.5.10 500
                     7.5.9 500
                     7.5.8 500
                     7.5.7 500
                     7.5.6 500
                     7.5.5 500
                     7.5.4 500
                     7.5.3 500
                     7.5.2 500
                     7.5.1 500
                     7.5.0 500
                     7.4.5 500
                     7.4.3 500
                     7.4.2 500
                     7.4.1 500
                     7.4.0 500
                     7.3.10 500
                     7.3.7 500
                     7.3.6 500
                     7.3.5 500
                     7.3.4 500
                     7.3.3 500
                     7.3.2 500
                     7.3.1 500
                     7.3.0 500
                     7.2.2 500
                     7.2.1 500
                     7.2.0 500
                     7.1.5 500
                     7.1.4 500
                     7.1.3 500
                     7.1.2 500
                     7.1.1 500
                     7.1.0 500
                     7.0.6 500
                     7.0.5 500
                     7.0.4 500
                     7.0.3 500
                     7.0.2 500
                     7.0.1 500
                     7.0.0 500
                        500 https://packages.grafana.com/enterprise/deb stable/main amd64 Packages
                     6.7.6 500
                     6.7.5 500
                     6.7.4 500
                     6.7.3 500
                     6.7.2 500
                     6.7.1 500
                     6.7.0 500
                     6.6.2 500
                     6.6.1 500
                     6.6.0 500
                     6.5.3 500
                     6.5.2 500
                     6.5.1 500
                     6.5.0 500
                     6.4.5 500
                     6.4.4 500
                     6.4.3 500
                     6.4.2 500
                     6.4.1 500
                     6.4.0 500
                     6.3.7 500
                     6.3.6 500
                     6.3.5 500
                     6.3.4 500
                     6.3.3 500
                     6.3.2 500
                     6.3.1 500
                     6.3.0 500
                     6.2.5 500
                     6.2.4 500
                     6.2.3 500
                     6.2.2 500
                     6.2.1 500
                     6.2.0 500
                     6.1.6 500
                     6.1.5 500
                     6.1.4 500
                     6.1.3 500
                     6.1.2 500
                     6.1.1 500
                     6.1.0 500
                     6.0.2 500
                     6.0.1 500
                     6.0.0 500
                     5.4.5 500
                     5.4.4 500
                     5.4.3 500
                     5.4.2 500
                     5.4.1 500
                     5.4.0 500
                     5.3.4 500
                     5.3.3 500
                     5.3.2 500
                     5.3.1 500
                     5.3.0 500
                     5.2.5 500
                     5.2.4 500
                     5.2.3 500
                     5.2.2 500
                     5.2.1 500
                     5.2.0 500
                     5.1.5 500
                     5.1.4 500
                     5.1.3 500
                     5.1.2 500
                     5.1.1 500
                     5.1.0 500
                     5.0.4 500
                     5.0.3 500
                     5.0.2 500
                     5.0.1 500
                     5.0.0 500
                     4.6.5 500
                     4.6.4 500
                     4.6.3 500
                     4.6.2 500
                     4.6.1 500
                     4.6.0 500
                     4.5.2 500
                     4.5.1 500
                     4.5.0 500
                     4.4.3 500
                     4.4.2 500
                     4.4.1 500
                     4.4.0-pre1 500
                     4.4.0 500
                     4.3.2 500
                     4.3.1 500
                     4.3.0 500
                     4.2.0 500
                     4.1.2-1486989747 500
                     4.1.1-1484211277 500
                     4.1.0-1484127817 500
                     4.0.2-1481203731 500
                     4.0.1-1480694114 500
                     3.1.1-1470047149 500
                     3.1.0-1468321182 500
                     3.0.4-1464167696 500
                     2.6.0 500
                  LTX
                  C
                  C
                  cainam
                  @oliverio said in Problem with updating Debian with grafana...:
                  Sorry... yes lxc - Container over Proxmox
                  I use the container to operate influx and grafana. but the container runs still with buster... so to upgrade influx i also have to update the debian...
                  • C cainam
                    Thomas BraunT
                    Thomas BraunT
                    @cainam
                    Vom Update des Container OS abgesehen stimmt da dann auch irgendwas mit dem grafana-Repo nicht. Vermutlich die Sache mit dem neuen Key.
                      @cainam
                      C
                      C
                      cainam
                      und was mach ich jetzt? bin nun nicht mehr mit root drin...
                      • C cainam
                        Thomas BraunT
                        Thomas BraunT
                        @cainam
                        Bei Containern bin ich raus. Mir zu kompliziert.
                          @cainam
                          C
                          C
                          cainam
                          naja ist ja einfach ein linux auf einer virtuellen maschine...
                          • C cainam
                            Thomas BraunT
                            Thomas BraunT
                            Naja, nein...
                              Naja, nein...
                              C
                              C
                              cainam
                              aber eben... ging alles tiptop bis zum update
                              • C cainam
                                Thomas BraunT
                                Thomas BraunT
                                @cainam
                                Muss sich jemand anders anschauen. Mit Containern hab ich nix am Hut.
                                • Marc BergM
                                  Marc BergM
                                  Marc Berg
                                  @cainam
                                  So wie ich das verstehe, lässt Du influxdb und grafana in EINEM Container laufen und musst Dich jetzt um die Updates kümmern.
                                  Was ich aber NICHT verstehe ist, warum Du nicht für grafana+influxdb jeweils eigene Container nutzt. Das ist doch gerade der Charme der Docker-Umgebungen.
                                  Einmal neues Image deployed, Update fertig. Läuft nicht? Rollback zur vorherigen Version.
                                  • Marc BergM Marc Berg
                                    @cainam
                                    OliverIOO
                                    OliverIOO
                                    OliverIO
                                    @marc-berg
                                    weil er den unterschied zwischen vm und container nicht verstanden hat.
                                    er hat einen der vordefinierten system container genommen, aufgerufen und dort dann rein installiert
                                    https://pve.proxmox.com/wiki/Linux_Container siehe Kapitel Container Images
                                    Er verwendet den Container als virtuelle maschine und das finde ich problematisch.
                                    eigentlich wäre ihm nur zu raten
                                    1. er erzeugt unter proxmox eine virtuelle maschine und installiert dort alles neu, so wie er es gewohnt ist
                                    2. er beschäftigt sich mit container und richtet für jeden service einen eigenen container ein
                                    aber ich glaube 1) wäre besser für ihn
                                    Links im Profil
                                      @marc-berg
                                      C
                                      C
                                      cainam
                                      schrieb am zuletzt editiert von cainam
                                      @oliverio
                                      Situation ist wie folgt, ich benutze Proxmox
                                      Darin brauche ich zB für iobroker oder auch für mein Conbee eine Virtuelle Maschine. dann nutze ich für die daten ein lxc container (da schneller und schlanker). in diesem container habe ich influxdb und grafana installiert was gut ging... dann habe ich noch andere lxc container für andere applikationen..
                                      wieso nicht zwei (1 x influxdb und 1x grafana) - gute frage, grundsätzlich ging es mir darum das ganze nicht zuuuu komplizert zu machen und ich nicht jedesmall 7 containers und vms updaten/pflegen muss. zudem sind meine resourcen beschränkt auf dem computer
                                      Wenn ich nun ein neuen container mache, darin debian 11, grafana und influxdb installiere geht das tip top.. doch das ist keine gewünschte lösung, da ich dann jrgendwie die daten von influx übertragen muss und b eine längere offlinezeit hätte...
                                      p.s. für docker, welchen ich va. als test brauche habe ich auch einen eigenen container laufen
                                      OliverIOO ? 2 Antworten Letzte Antwort
                                      • C cainam
                                        Hello
                                        sudo apt autoremove
                                        export LC_ALL=C
                                        sudo apt update
                                        sudo apt upgrade
                                        sudo apt autoremove
                                                CPU: 28ms
                                        Thanks for help
                                        An @OliverIO u. @Marc-Berg und @cainam
                                        ich denke, das hier etwas falsch verstanden wird, sich @cainam falsch ausgedrückt hat.
                                        Ich interpretiere das mal so:
                                        PC == Proxmox OS
                                        -- LXC Container
                                        -- Grafana und InfluxDB
                                        Oder meinst Du @cainam wirklich:
                                        PC == Virtuelle Maschine (VMWare, oder ähnliches)
                                        - in der VM dann Proxmox
                                        - in Proxmox dann ein LXC Container
                                        im Container dann Grafana u. InfluxDB
                                        Für mich ist LXC - Container != Docker - Container
                                        @cainam löse mal deine verunglückte Beschreibung auf, da Du ja siehst das wir damit nicht zurande kommen ;)
                                        Bernd
                                        Uups da war @cainam schneller :)
                                        • C cainam
                                          @oliverio
                                          OliverIOO
                                          OliverIOO
                                          OliverIO
                                          dann würde ich das als docker container laufen lassen.
                                          ich dachte eigentlich das es für lxc auch so ein hub gibt, wo man beliebige definitionen herunterladen kann, aber scheint wohl aktuell noch nicht so zu sein.
                                          im docker-hub findest du für grafana, influx und wie du sicherlich auch weißt für viele andere installationen, wirklich einfach einzurichtende outOfTheBox-Lösungen.
                                          ein update einer lösung findet einfach nur über den tausch/download einer neuen containerdefinition statt und ist in vielen fällen in wenigen minuten erledigt. um ein OS musst du dich da nicht kümmern
                                          Wie eine Virtualisierung in einer Virtualisierung läuft und ob es da noch Probleme geben kann, weiß ich nicht.
                                          Links im Profil
                                          84.0k
