  4. BackitUp NAS Error Speedport Smart 4
    5.5k
91 Beiträge 4 Kommentatoren 10.8k Aufrufe 3 Beobachtet
  • N noidea
    user@iobroker:/$ sudo dmesg -T | tail -n 20
    [Sun Jan 22 19:57:12 2023] CIFS: VFS: cifs_mount failed w/return code = -6
    [Sun Jan 22 19:57:12 2023] CIFS: Attempting to mount \\192.168.2.1\SanDisk-USBExtremePro
    [Sun Jan 22 19:57:12 2023] CIFS: VFS: cifs_mount failed w/return code = -112
    [Sun Jan 22 20:08:09 2023] Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    [Sun Jan 22 20:08:09 2023] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    [Sun Jan 22 20:08:09 2023] CIFS: Attempting to mount \\192.168.2.1\SanDisk-USBExtremePro
    [Sun Jan 22 20:08:09 2023] CIFS: Status code returned 0xc000006d NT_STATUS_LOGON_FAILURE
    [Sun Jan 22 20:08:09 2023] CIFS: VFS: \\192.168.2.1 Send error in SessSetup = -13
    [Sun Jan 22 20:08:09 2023] CIFS: VFS: cifs_mount failed w/return code = -13
    [Sun Jan 22 20:10:33 2023] Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    [Sun Jan 22 20:10:33 2023] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    [Sun Jan 22 20:10:33 2023] CIFS: Attempting to mount \\192.168.2.1\SanDisk-USBExtremePro
    [Sun Jan 22 20:10:33 2023] CIFS: VFS: cifs_mount failed w/return code = -6
    [Sun Jan 22 20:10:33 2023] CIFS: Attempting to mount \\192.168.2.1\SANDISK-USBEXTREMEPRO
    user@iobroker:/$
    #73
    @noidea sagte in BackitUp NAS Error Speedport Smart 4:
    sudo apt update
    apt policy cifs-utils
    N 2 Antworten Letzte Antwort
    • N noidea
      user@iobroker:/$
      #74
      Attempting to mount \192.168.2.1\SanDisk-USBExtremePro
      heisst der share nicht anders?
      siehe unzitierbaren Screenshot
        sudo apt update
        N Offline
        N Offline
        noidea
        #75
        Ich werde das morgen nach der Arbeit machen, weil ich gerade böse Blicke ernte und den Haussegen wahren muss 😥
        Ich werde dann morgen direkt das Nachreichen.
        Aber ich wollte mich auf jeden Fall schonmal Bedanken für die ganze Mühe,die Du/Ihr euch gebt und vor allem nicht die Geduld zu verlieren. Ich kann mir vorstellen wir frustrierend es manchmal sein kann.
        Also: Vielen vielen Dank,einen schönen Abend noch an alle und hoffentlich bis morgen
        • N noidea
          #76
          @noidea
          Notiz für mich:
             RETURN CODES
             mount has the following return codes (the bits can be ORed):
             0      success
             1      incorrect invocation or permissions
             2      system error (out of memory, cannot fork, no more loop devices)
             4      internal mount bug
             8      user interrupt
             16     problems writing or locking /etc/mtab
             32     mount failure
             64     some mount succeeded
          • N noidea
            #77
            @noidea
            Klopf mal den Server ab:
            nmap -p445 --script smb-protocols 192.168.2.1
            nmap -p139 --script smb-protocols 192.168.2.1
            nmap ggf. nachinstallieren.
              sudo apt update
              N Offline
              N Offline
              noidea
              schrieb am zuletzt editiert von noidea
              #78
              Hallo Zusammen,
              ich habe mal Eure Sachen abgearbeitet:
              @thomas-braun sagte in BackitUp NAS Error Speedport Smart 4:
              sudo apt update
              Das habe ich jetzt mal gemacht:
              user@iobroker:/$ apt policy cifs-utils
              cifs-utils:
                Installed: 2:6.14-1ubuntu0.1
                Candidate: 2:6.14-1ubuntu0.1
                Version table:
               *** 2:6.14-1ubuntu0.1 500
                      500 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
                      500 http://archive.ubuntu.com/ubuntu jammy-security/main amd64 Packages
                   2:6.14-1build1 500
                      500 http://archive.ubuntu.com/ubuntu jammy/main amd64 Packages
              user@iobroker:/$
              @homoran sagte in BackitUp NAS Error Speedport Smart 4:
              Meinst du das, weil der Backup Speedport Eintrag fehlt?
              @noidea
              user@iobroker:/$ nmap -p445 --script smb-protocols 192.168.2.1
              Starting Nmap 7.80 ( https://nmap.org ) at 2023-01-23 17:06 CET
              Nmap scan report for speedport.ip (192.168.2.1)
              Host is up (0.00054s latency).
              PORT    STATE SERVICE
              445/tcp open  microsoft-ds
              Host script results:
              | smb-protocols:
              |   dialects:
              |_    NT LM 0.12 (SMBv1) [dangerous, but default]
              Nmap done: 1 IP address (1 host up) scanned in 0.51 seconds
              user@iobroker:/$
              user@iobroker:/$ nmap -p139 --script smb-protocols 192.168.2.1
              Starting Nmap 7.80 ( https://nmap.org ) at 2023-01-23 17:07 CET
              Host is up (0.00064s latency).
              PORT    STATE SERVICE
              139/tcp open  netbios-ssn
              | smb-protocols:
              |   dialects:
              user@iobroker:/$
              • N noidea
                Hallo Zusammen,
                sudo apt update
                cifs-utils:
                  Version table:
                     2:6.14-1build1 500
                user@iobroker:/$
                @noidea
                PORT    STATE SERVICE
                | smb-protocols:
                |   dialects:
                user@iobroker:/$
                PORT    STATE SERVICE
                | smb-protocols:
                |   dialects:
                user@iobroker:/$
                #79
                @noidea
                Das Mist-Ding spricht ja wirklich nur SMBv1.
                Wäre für mich ein Grund das Ding zurückzusenden.
                Stell deinen user mal in dessen /home:
                cd ~
                N 1 Antwort Letzte Antwort
                  @noidea
                  cd ~
                  N Offline
                  N Offline
                  noidea
                  #80
                  Ja das ist echt enttäuschent....
                  Und dann den Befehl nochmal in home ausführen?
                  • N noidea
                    #81
                    @noidea
                    Nein, nur den user aus / rausbewegen, da hat der nix zu suchen.
                      @noidea
                      N Offline
                      N Offline
                      noidea
                      #82
                      user@iobroker:/$ cd ~
                      user@iobroker:~$
                      Du meinst so, ja?
                      • N noidea
                        user@iobroker:~$
                        Du meinst so, ja?
                        #83
                        @noidea Ja...
                          @noidea Ja...
                          N Offline
                          N Offline
                          noidea
                          #84
                          Aber selbst wenn der Router nur SMB1 kann, müsste mein System doch trotzdem drauf zugreifen können,oder?
                          E 1 Antwort Letzte Antwort
                          • N noidea
                            Einstein67
                            #85
                            @noidea said in BackitUp NAS Error Speedport Smart 4:
                            Mit Handy, Notebook, etc. funktioniert der Zugriff?
                            • E Einstein67
                              N Offline
                              N Offline
                              noidea
                              #86
                              @einstein67
                              Habe ich ehrlich gesagt noch gar nicht ausprobiert, weil ich auch gar nicht weiß wie.
                              Ich versuche mal rauszufinden, wie das z.B. über den Rechner geht
                              • N noidea
                                @einstein67
                                Einstein67
                                #87
                                @noidea Explorer öffnen und auf Netzwerk klicken.
                                Dann werden alle SMB-Shares angezeigt, und der USB-Stick sollte sich nach Passworteingabe öffnen lassen.
                                • E Einstein67
                                  N Offline
                                  N Offline
                                  noidea
                                  #88
                                  @einstein67
                                  Interessanterweise hat es beim ersten Mal funktioniert, d.h. ich konnte auf den Ordner zugreifen. Dann habe ich mal versucht eine pdf-Datei reinzukopieren und seitdem kommt diese Fehlermeldung.
                                  • N noidea
                                    @einstein67
                                    Einstein67
                                    #89
                                    @noidea E/A Fehler ist nicht gut.
                                    Ist der USB-Stick OK und für den Smart4 richtig formatiert?
                                    • E Einstein67
                                      N Offline
                                      N Offline
                                      noidea
                                      #90
                                      @einstein67
                                      Laut der Beschreibung ja. Man kann exFAT und NTFS. Formatiert ist er mit exFAT
                                      • N noidea
                                        @einstein67
                                        N Offline
                                        N Offline
                                        noidea
                                        #91
                                        @noidea
                                        Hab jetzt einfach mal ganz blöd auf NTFS umgestellt, aber das hat natürlich nichts gebracht:
                                        Started iobroker ...
                                        [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.2.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"WORKGROUP","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/SanDisk-USBExtremePro/Backup/Speedport","dirMinimal":"sharename/backupDir","user":"speedport","pass":"****","ignoreErrors":false}
                                        [DEBUG] [mount] - noserverino option: false
                                        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups"
                                        [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
                                        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups"
                                        [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups
                                        mount error: Server abruptly closed the connection.
                                        This can happen if the server does not support the SMB version you are trying to use.
                                        The default SMB version recently changed from SMB1 to SMB2.1 and above. Try mounting with vers=1.0.
                                        mount error(112): Host is down
                                        Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                        [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups
                                        Ich kann aber jetzt über den Rechner auf den Ordner zugreifen und dort auch neue Ordner erstellen, allerdings seid ich auf NTFS umgestellt habe, kommt keine Passwortabfrage mehr.
                                        Ich habe nochmal versucht über die Konsole zu mounten:
                                        user@iobroker:/opt/iobroker/backups$ sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/SanDisk-USBExtremePro/Backup/speedport /opt/iobroker/backups
                                        Retrying with upper case share name
                                        mount error(6): No such device or address
                                        Jetzt kommt diese Fehlermeldung, wobei der Pfad richtig angegeben ist.
                                        Wenn ich das Passwort mal deaktivieren möchte, muss ich dann einfach
                                        weglassen?
                                        Ich hatte das mal probiert, aber dann kam diese Meldung:
                                        user@iobroker:/opt/iobroker/backups$ sudo mount -t cifs -o domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/SanDisk-USBExtremePro/Backup/speedport /opt/iobroker/backups
                                        Password for root@//192.168.2.1/SanDisk-USBExtremePro/Backup/speedport:
                                        Da wollte er ein Passwort haben, das nicht mehr gesetzt ist.
                                        Also bleibt die Frage, warum kann ich mit dem Rechner drauf zugreifen, aber nicht über IOBROKER?
                                        Hat noch jemand eine Idee? Ansonsten bleibt mir nur die Möglichkeit, das Backup "nur" über Google Drive machen zu können. Es fuchst mich zwar, aber was will man machen....
