  4. BackitUp NAS Error Speedport Smart 4
    5.5k
91 Beiträge 4 Kommentatoren 10.8k Aufrufe 3 Beobachtet
    @noidea
    sudo dmesg -T | tail -n 20
    N Offline
    N Offline
    noidea
    #72
    user@iobroker:/$ sudo dmesg -T | tail -n 20
    [Sun Jan 22 19:57:12 2023] CIFS: VFS: cifs_mount failed w/return code = -6
    [Sun Jan 22 19:57:12 2023] CIFS: Attempting to mount \\192.168.2.1\SanDisk-USBExtremePro
    [Sun Jan 22 19:57:12 2023] CIFS: VFS: cifs_mount failed w/return code = -112
    [Sun Jan 22 20:08:09 2023] Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    [Sun Jan 22 20:08:09 2023] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    [Sun Jan 22 20:08:09 2023] CIFS: Attempting to mount \\192.168.2.1\SanDisk-USBExtremePro
    [Sun Jan 22 20:08:09 2023] CIFS: Status code returned 0xc000006d NT_STATUS_LOGON_FAILURE
    [Sun Jan 22 20:08:09 2023] CIFS: VFS: \\192.168.2.1 Send error in SessSetup = -13
    [Sun Jan 22 20:08:09 2023] CIFS: VFS: cifs_mount failed w/return code = -13
    [Sun Jan 22 20:10:33 2023] Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    [Sun Jan 22 20:10:33 2023] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    [Sun Jan 22 20:10:33 2023] CIFS: Attempting to mount \\192.168.2.1\SanDisk-USBExtremePro
    [Sun Jan 22 20:10:33 2023] CIFS: VFS: cifs_mount failed w/return code = -6
    [Sun Jan 22 20:10:33 2023] CIFS: Attempting to mount \\192.168.2.1\SANDISK-USBEXTREMEPRO
    user@iobroker:/$
    • N noidea
      user@iobroker:/$
      #73
      @noidea sagte in BackitUp NAS Error Speedport Smart 4:
      sudo apt update
      apt policy cifs-utils
      N 2 Antworten Letzte Antwort
      • N noidea
        user@iobroker:/$
        #74
        Attempting to mount \192.168.2.1\SanDisk-USBExtremePro
        heisst der share nicht anders?
        siehe unzitierbaren Screenshot
          sudo apt update
          N Offline
          N Offline
          noidea
          #75
          Ich werde das morgen nach der Arbeit machen, weil ich gerade böse Blicke ernte und den Haussegen wahren muss 😥
          Ich werde dann morgen direkt das Nachreichen.
          Aber ich wollte mich auf jeden Fall schonmal Bedanken für die ganze Mühe,die Du/Ihr euch gebt und vor allem nicht die Geduld zu verlieren. Ich kann mir vorstellen wir frustrierend es manchmal sein kann.
          Also: Vielen vielen Dank,einen schönen Abend noch an alle und hoffentlich bis morgen
          • N noidea
            #76
            @noidea
            Notiz für mich:
               RETURN CODES
               mount has the following return codes (the bits can be ORed):
               0      success
               1      incorrect invocation or permissions
               2      system error (out of memory, cannot fork, no more loop devices)
               4      internal mount bug
               8      user interrupt
               16     problems writing or locking /etc/mtab
               32     mount failure
               64     some mount succeeded
            • N noidea
              #77
              @noidea
              Klopf mal den Server ab:
              nmap -p445 --script smb-protocols 192.168.2.1
              nmap -p139 --script smb-protocols 192.168.2.1
              nmap ggf. nachinstallieren.
                sudo apt update
                N Offline
                N Offline
                noidea
                schrieb am zuletzt editiert von noidea
                #78
                Hallo Zusammen,
                ich habe mal Eure Sachen abgearbeitet:
                @thomas-braun sagte in BackitUp NAS Error Speedport Smart 4:
                sudo apt update
                Das habe ich jetzt mal gemacht:
                user@iobroker:/$ apt policy cifs-utils
                cifs-utils:
                  Installed: 2:6.14-1ubuntu0.1
                  Candidate: 2:6.14-1ubuntu0.1
                  Version table:
                 *** 2:6.14-1ubuntu0.1 500
                        500 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
                        500 http://archive.ubuntu.com/ubuntu jammy-security/main amd64 Packages
                     2:6.14-1build1 500
                        500 http://archive.ubuntu.com/ubuntu jammy/main amd64 Packages
                user@iobroker:/$
                @homoran sagte in BackitUp NAS Error Speedport Smart 4:
                Meinst du das, weil der Backup Speedport Eintrag fehlt?
                @noidea
                user@iobroker:/$ nmap -p445 --script smb-protocols 192.168.2.1
                Starting Nmap 7.80 ( https://nmap.org ) at 2023-01-23 17:06 CET
                Nmap scan report for speedport.ip (192.168.2.1)
                Host is up (0.00054s latency).
                PORT    STATE SERVICE
                445/tcp open  microsoft-ds
                Host script results:
                | smb-protocols:
                |   dialects:
                |_    NT LM 0.12 (SMBv1) [dangerous, but default]
                Nmap done: 1 IP address (1 host up) scanned in 0.51 seconds
                user@iobroker:/$
                user@iobroker:/$ nmap -p139 --script smb-protocols 192.168.2.1
                Starting Nmap 7.80 ( https://nmap.org ) at 2023-01-23 17:07 CET
                Host is up (0.00064s latency).
                PORT    STATE SERVICE
                139/tcp open  netbios-ssn
                | smb-protocols:
                |   dialects:
                user@iobroker:/$
                • N noidea
                  Hallo Zusammen,
                  sudo apt update
                  cifs-utils:
                    Version table:
                       2:6.14-1build1 500
                  user@iobroker:/$
                  @noidea
                  PORT    STATE SERVICE
                  | smb-protocols:
                  |   dialects:
                  user@iobroker:/$
                  PORT    STATE SERVICE
                  | smb-protocols:
                  |   dialects:
                  user@iobroker:/$
                  #79
                  @noidea
                  Das Mist-Ding spricht ja wirklich nur SMBv1.
                  Wäre für mich ein Grund das Ding zurückzusenden.
                  Stell deinen user mal in dessen /home:
                  cd ~
                  N 1 Antwort Letzte Antwort
                    @noidea
                    cd ~
                    N Offline
                    N Offline
                    noidea
                    #80
                    Ja das ist echt enttäuschent....
                    Und dann den Befehl nochmal in home ausführen?
                    • N noidea
                      #81
                      @noidea
                      Nein, nur den user aus / rausbewegen, da hat der nix zu suchen.
                        @noidea
                        N Offline
                        N Offline
                        noidea
                        #82
                        user@iobroker:/$ cd ~
                        user@iobroker:~$
                        Du meinst so, ja?
                        • N noidea
                          user@iobroker:~$
                          Du meinst so, ja?
                          #83
                          @noidea Ja...
                            @noidea Ja...
                            N Offline
                            N Offline
                            noidea
                            #84
                            Aber selbst wenn der Router nur SMB1 kann, müsste mein System doch trotzdem drauf zugreifen können,oder?
                            E 1 Antwort Letzte Antwort
                            • N noidea
                              Einstein67
                              #85
                              @noidea said in BackitUp NAS Error Speedport Smart 4:
                              Mit Handy, Notebook, etc. funktioniert der Zugriff?
                              • E Einstein67
                                N Offline
                                N Offline
                                noidea
                                #86
                                @einstein67
                                Habe ich ehrlich gesagt noch gar nicht ausprobiert, weil ich auch gar nicht weiß wie.
                                Ich versuche mal rauszufinden, wie das z.B. über den Rechner geht
                                • N noidea
                                  @einstein67
                                  Einstein67
                                  #87
                                  @noidea Explorer öffnen und auf Netzwerk klicken.
                                  Dann werden alle SMB-Shares angezeigt, und der USB-Stick sollte sich nach Passworteingabe öffnen lassen.
                                  • E Einstein67
                                    N Offline
                                    N Offline
                                    noidea
                                    #88
                                    @einstein67
                                    Interessanterweise hat es beim ersten Mal funktioniert, d.h. ich konnte auf den Ordner zugreifen. Dann habe ich mal versucht eine pdf-Datei reinzukopieren und seitdem kommt diese Fehlermeldung.
                                    • N noidea
                                      @einstein67
                                      Einstein67
                                      #89
                                      @noidea E/A Fehler ist nicht gut.
                                      Ist der USB-Stick OK und für den Smart4 richtig formatiert?
                                      • E Einstein67
                                        N Offline
                                        N Offline
                                        noidea
                                        #90
                                        @einstein67
                                        Laut der Beschreibung ja. Man kann exFAT und NTFS. Formatiert ist er mit exFAT
                                        • N noidea
                                          @einstein67
                                          N Offline
                                          N Offline
                                          noidea
                                          #91
                                          @noidea
                                          Hab jetzt einfach mal ganz blöd auf NTFS umgestellt, aber das hat natürlich nichts gebracht:
                                          Started iobroker ...
                                          [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.2.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"WORKGROUP","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/SanDisk-USBExtremePro/Backup/Speedport","dirMinimal":"sharename/backupDir","user":"speedport","pass":"****","ignoreErrors":false}
                                          [DEBUG] [mount] - noserverino option: false
                                          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups"
                                          [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
                                          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups"
                                          [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups
                                          mount error: Server abruptly closed the connection.
                                          This can happen if the server does not support the SMB version you are trying to use.
                                          The default SMB version recently changed from SMB1 to SMB2.1 and above. Try mounting with vers=1.0.
                                          mount error(112): Host is down
                                          Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                          [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups
                                          Ich kann aber jetzt über den Rechner auf den Ordner zugreifen und dort auch neue Ordner erstellen, allerdings seid ich auf NTFS umgestellt habe, kommt keine Passwortabfrage mehr.
                                          Ich habe nochmal versucht über die Konsole zu mounten:
                                          user@iobroker:/opt/iobroker/backups$ sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/SanDisk-USBExtremePro/Backup/speedport /opt/iobroker/backups
                                          Retrying with upper case share name
                                          mount error(6): No such device or address
                                          Jetzt kommt diese Fehlermeldung, wobei der Pfad richtig angegeben ist.
                                          Wenn ich das Passwort mal deaktivieren möchte, muss ich dann einfach
                                          weglassen?
                                          Ich hatte das mal probiert, aber dann kam diese Meldung:
                                          user@iobroker:/opt/iobroker/backups$ sudo mount -t cifs -o domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/SanDisk-USBExtremePro/Backup/speedport /opt/iobroker/backups
                                          Password for root@//192.168.2.1/SanDisk-USBExtremePro/Backup/speedport:
                                          Da wollte er ein Passwort haben, das nicht mehr gesetzt ist.
                                          Also bleibt die Frage, warum kann ich mit dem Rechner drauf zugreifen, aber nicht über IOBROKER?
                                          Hat noch jemand eine Idee? Ansonsten bleibt mir nur die Möglichkeit, das Backup "nur" über Google Drive machen zu können. Es fuchst mich zwar, aber was will man machen....
