  3. Entwicklung
  4. Ecovacs Deebot Adapter: Status und Feedback
deebotecovacsecovacs-deebotecovacs-deebot adaptersaugrobotervacuum
580 Beiträge 37 Kommentatoren 242.9k Aufrufe 32 Beobachtet
  • J jm3west
    Das kommt wenn ich in der iOS App speichern klicke ....
     warn  got payload for unknown command 'onSimpleARMapSet': {"type":"ar","speechVer":"2.0","mid":"732490256","msid":"1863920572","subsets":[{"name":"Esszimmer1","mssid":"1","subtype":"2","totalCount":0},{"name":"","mssid":"2","subtype":"1","totalCount":0},{"name":"Küche1","mssid":"3","subtype":"5","totalCount":0},{"name":"Schlafzimmer1","mssid":"6","subtype":"3","totalCount":0},{"name":"Flur1","mssid":"8","subtype":"12","totalCount":0},{"name":"Badezimmer2","mssid":"7","subtype":"6","totalCount":0}]}
     MQTT  iot/atr/onMapSet_V2/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
     MQTT  onMapSet_V2
     payload
    { type: 'ar', mid: '732490256' }
     result  MapSpotAreas: {"mapID":"732490256","mapSpotAreas":[]}
     MQTT  iot/atr/onSched_V2/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
     MQTT  onSched_V2
     payload  {"header":{"pri":1,"tzm":60,"ts":"1674320951992","ver":"0.0.1","fwVer":"2.3.9","hwVer":"0.1.1","wkVer":"0.1.54"},"body":{}}
     warn  received error event with code '-2' and message 'resultData.repeat.split is not a function'
     event  Error resultData.repeat.split is not a function
     MQTT  iot/atr/onNextSched/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
     MQTT  onNextSched
     payload
     warn  got payload for unknown command 'onNextSched': []
     MQTT  iot/atr/onFwBuryPoint-areasInfo/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
     MQTT  onFwBuryPoint-areasInfo
     payload  {"header":{"pri":1,"tzm":60,"ts":"1674320952016","ver":"0.0.1","fwVer":"2.3.9","hwVer":"0.1.1","wkVer":"0.1.54"},"body":{"gid":"G1674320951960","index":"0000001094","ts":"1674320951960","mid":732490256,"areas":[{"id":1,"name":"Esszimmer1","type":2,"priority":0,"waterLevel":0,"fanLevel":1,"cleanCnt":1},{"id":2,"name":"","type":1,"priority":0,"waterLevel":1,"fanLevel":0,"cleanCnt":1},{"id":3,"name":"Küche1","type":5,"priority":0,"waterLevel":1,"fanLevel":0,"cleanCnt":1},{"id":6,"name":"Schlafzimmer1","type":3,"priority":0,"waterLevel":1,"fanLevel":0,"cleanCnt":1},{"id":8,"name":"Flur1","type":12,"priority":0,"waterLevel":1,"fanLevel":0,"cleanCnt":1},{"id":7,"name":"Badezimmer2","type":6,"priority":0,"waterLevel":1,"fanLevel":0,"cleanCnt":1}]}}
     warn  got payload for unknown command 'onFwBuryPoint-areasInfo': "{\"header\":{\"pri\":1,\"tzm\":60,\"ts\":\"1674320952016\",\"ver\":\"0.0.1\",\"fwVer\":\"2.3.9\",\"hwVer\":\"0.1.1\",\"wkVer\":\"0.1.54\"},\"body\":{\"gid\":\"G1674320951960\",\"index\":\"0000001094\",\"ts\":\"1674320951960\",\"mid\":732490256,\"areas\":[{\"id\":1,\"name\":\"Esszimmer1\",\"type\":2,\"priority\":0,\"waterLevel\":0,\"fanLevel\":1,\"cleanCnt\":1},{\"id\":2,\"name\":\"\",\"type\":1,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":1},{\"id\":3,\"name\":\"Küche1\",\"type\":5,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":1},{\"id\":6,\"name\":\"Schlafzimmer1\",\"type\":3,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":1},{\"id\":8,\"name\":\"Flur1\",\"type\":12,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":1},{\"id\":7,\"name\":\"Badezimmer2\",\"type\":6,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":1}]}}"
     MQTT  iot/atr/onNextVideoSched/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
     MQTT  onNextVideoSched
     payload
     warn  got payload for unknown command 'onNextVideoSched': []
    mrbungle64M
    mrbungle64M
    mrbungle64
    schrieb am zuletzt editiert von mrbungle64
    #170
    @jm3west
    Ok, ich schaue mir das nachher mal genauer an.
    Bitte deaktiviere aber schon mal in den Adapter-Einstellungen unter "Erweitert" "Experimental" folgende Funktionen:
    • Option zur separaten Steuerung der Reinigungsstärke für die einzelnen Bereiche
    • Option zur separaten Steuerung der Wasserzufuhr-Stärke für die einzelnen Bereiche
    Die sind eher für ältere Modelle gedacht, welche diese Möglichkeiten gar nicht (nativ) per Ecovacs Home App haben.
    J 2 Antworten Letzte Antwort
    • mrbungle64M mrbungle64
      @jm3west
      J
      J
      jm3west
      #171
      @mrbungle64 darf ich mich nun Debugger nennen? 🕶
      mrbungle64M 1 Antwort Letzte Antwort
      • J jm3west
        mrbungle64M
        mrbungle64M
        mrbungle64
        #172
        @jm3west sagte in Ecovacs Deebot Adapter: Status und Feedback:
        Ja, hast du gut gemacht 👍
          @jm3west
          J
          J
          jm3west
          #173
          @mrbungle64 sagte in Ecovacs Deebot Adapter: Status und Feedback:
          Bitte deaktiviere aber schon mal in den Adapter-Einstellungen unter "Erweitert" folgende Funktionen:
          Du wolltest mich testen. Gelle?
          Diese Optionen sind in Experimental
          • J jm3west
            mrbungle64M
            mrbungle64M
            mrbungle64
            #174
            Hehe, nein. Ich habe mich nur vertan ;)
              J
              J
              jm3west
              #175
              @mrbungle64 macht mir voll Spass.
              Wenn ich nur was programmieren könnte. Schade
              • J jm3west
                mrbungle64M
                mrbungle64M
                mrbungle64
                #176
                Dann habe ich doch direkt noch eine Frage ;)
                Hast du die Einstellung für den Wischmodus bei einem Bereich eingestellt oder global?
                Falls das für einen Bereich war dann mach das bitte noch mal global.
                Der Name vom Event onCustomAreaMode deutet nämlich eher darauf hin, dass das für einen speziellen Bereich war.
                  J
                  J
                  jm3west
                  #177
                  Es gibt ja bei den Reinigungseinstellungen Standard (Global) und Anpassen (Jedes Zimmer individuell)
                  Da habe ich die Änderungen in Anpassen (Jedes Zimmer individuell) gemacht.
                  J mrbungle64M 2 Antworten Letzte Antwort
                  • J jm3west
                    J
                    J
                    jm3west
                    #178
                    @jm3west Den Wischmodus gibt es in der App nur Global
                    • J jm3west
                      mrbungle64M
                      mrbungle64M
                      mrbungle64
                      #179
                      Ja genau, das hatte ich vermutet.
                      Ich bräuchte das aber erst mal global, weil bei den Reinigungseinstellungen noch einige andere Sachen behandelt werden. Das käme dann später mal dran...
                      Könntest du das dann also noch mal mit der globalen Einstellung debuggen? :)
                      • J jm3west
                        mrbungle64M
                        mrbungle64M
                        mrbungle64
                        #180
                        Ich bräuchte die Ausgabe wenn du diesen Wert (global) änderst.
                          J
                          J
                          jm3west
                          #181
                          Können wir das auf morgen vertagen.
                          Chefin hat zum Abendbrot zitiert. Du weist sicherlich was heißt 👖
                          • J jm3west
                            mrbungle64M
                            mrbungle64M
                            mrbungle64
                            #182
                            Alles klar, dann machen wir morgen weiter ;)
                            • J
                              J
                              jm3west
                              schrieb am zuletzt editiert von jm3west
                              #183
                              Moin,
                              da der Debugger, wie gestern schon erwähnt, arg zäh war. Habe ich mal ein reboot der VM von IOB gemacht und siehe da jetzt werden die Änderungen on the fly ausgegeben.
                              So habe ich mich mal ein wenig durch die iOS App geklickt.
                              Da kam einiges an Warmeldungen.
                              Wischmodus 0=Statndard, 1=Tief
                              Standard/Anpassen
                              warn  got payload for unknown command 'onCustomAreaMode': {"sweepMode":1}
                              Ecken-Tiefenreinigung Wert enable=1 (an), enable=0 (aus)
                              warn  got payload for unknown command 'onBorderSpin': {"enable":1,"type":1}
                              Reinigungseinstellungen > Anpassen > Bevorzugter Bereich
                              warn  got payload for unknown command 'onFwBuryPoint-areasInfo': "{\"header\":{\"pri\":1,\"tzm\":60,\"ts\":\"1674371159359\",\"ver\":\"0.0.1\",\"fwVer\":\"2.3.9\",\"hwVer\":\"0.1.1\",\"wkVer\":\"0.1.54\"},\"body\":{\"gid\":\"G1674371159297\",\"index\":\"0000001229\",\"ts\":\"1674371159298\",\"mid\":732490256,\"areas\":[{\"id\":1,\"name\":\"Esszimmer1\",\"type\":2,\"priority\":0,\"waterLevel\":1,\"fanLevel\":1,\"cleanCnt\":2},{\"id\":2,\"name\":\"\",\"type\":1,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":1},{\"id\":3,\"name\":\"Küche1\",\"type\":5,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":1},{\"id\":6,\"name\":\"Schlafzimmer1\",\"type\":3,\"priority\":0,\"waterLevel\":2,\"fanLevel\":1,\"cleanCnt\":2},{\"id\":8,\"name\":\"Flur1\",\"type\":12,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":1},{\"id\":7,\"name\":\"Badezimmer2\",\"type\":6,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":1}]}}"
                              warn  got payload for unknown command 'onFwBuryPoint-bd_mapinfo': "{\"header\":{\"pri\":1,\"tzm\":60,\"ts\":\"1674371159490\",\"ver\":\"0.0.1\",\"fwVer\":\"2.3.9\",\"hwVer\":\"0.1.1\",\"wkVer\":\"0.1.54\"},\"body\":{\"gid\":\"G1674371159448\",\"index\":\"0000001230\",\"ts\":\"1674371159448\",\"mapinfos\":[{\"mapid\":0,\"name\":\"\",\"savemapType\":0,\"isActive\":0,\"isRecentMap\":0,\"cleanCount\":0,\"priority\":0},{\"mapid\":732490256,\"name\":\"OG Loft\",\"savemapType\":1,\"isActive\":1,\"isRecentMap\":1,\"cleanCount\":2,\"priority\":26},{\"mapid\":0,\"name\":\"\",\"savemapType\":2,\"isActive\":0,\"isRecentMap\":0,\"cleanCount\":0,\"priority\":0},{\"mapid\":0,\"name\":\"\",\"savemapType\":3,\"isActive\":0,\"isRecentMap\":0,\"cleanCount\":0,\"priority\":0}]}}"
                              • J
                                J
                                jm3west
                                #184
                                ... noch was gefunden
                                Reinigungseinstellungen > Stamdard/Anpassen > Nur wischen
                                warn  Unhandled Evt code: '1141'
                                warn  got payload for unknown command 'onSweepMode': {"type":0}
                                • J jm3west
                                  mrbungle64M
                                  mrbungle64M
                                  mrbungle64
                                  #185
                                  @jm3west
                                  Alles klar, danke schon mal für die Infos 👍 Ich schaue mir das später genauer an.
                                  Falls du noch was findest kannst du das gerne noch posten :)
                                  • J jm3west
                                    Moin,
                                    Standard/Anpassen
                                    mrbungle64M
                                    mrbungle64M
                                    mrbungle64
                                    #186
                                    Ist die Einstellung für "Ecken-Tiefenreinigung" global?
                                    Was gibt es da für Optionen ("type")?
                                    Was kann man unter "Reinigungseinstellungen > Anpassen > Bevorzugter Bereich" einstellen?
                                    Ich habe diese Einstellungsmöglichkeiten nicht bei meinen Geräten ;)
                                    • J jm3west
                                      mrbungle64M
                                      mrbungle64M
                                      mrbungle64
                                      #187
                                      Wenn "Nur wischen" aktiviert ist, wäre dann der "type" = 1?
                                      Könntest du zusätzlich von den Einstellungen, welche zu den verschiedenen Wischmodi gehören, mal Screenshots machen?
                                      Und bei der "Ecken-Tiefenreinigung" ist mir noch nicht so ganz klar, ob das auch eine Einstellung für's Wischen oder Saugen ist ...
                                        J
                                        J
                                        jm3west
                                        #188
                                        Korrekt
                                          J
                                          J
                                          jm3west
                                          #189
                                          Sowohl als auch
                                          Auch "Nur wischen" Global und Anpassen (Bereich)
                                          83.8k
