  4. Test Adapter Philips-TV v0.2.x
    6.7k
philipsphilips tv
550 Beiträge 84 Kommentatoren 185.7k Aufrufe 48 Beobachtet
  • foxriver76F foxriver76
    @kuddel Ohne nachzuschauen, mal probiert ob es evtl. API v5 ist?
    Kuddel
    #451
    @foxriver76 bei V5 wird der Adapter leider auch nicht grün
    philips-tv.0		2022-11-17 10:32:09.439	debug	The TV seems to be turned off
    philips-tv.0		2022-11-17 10:32:04.146	info	Starting with ip "192.168.4.8" (API v5 - Jointspace)
    philips-tv.0		2022-11-17 10:32:04.135	info	starting. Version 0.5.2 (non-npm: AlCalzone/ioBroker.philips-tv#9e26469ed1578d03847fe168f5cc22bc4b064305) in /opt/iobroker/node_modules/iobroker.philips-tv, node: v16.18.0, js-controller: 4.0.23
    host.ioBroker-MASTER	2022-11-17 10:32:03.183	info	instance system.adapter.philips-tv.0 started with pid 78464
    • S senger1985
      @foxriver76
      Could not poll API: {"statusCode":404,"body":"<html>\n<head>\n <title>Status page</title>\n</head>\n<body style=\"font-family: sans-serif;\">\n<p style=\"font-size: 1.2em;font-weight: bold;margin: 1em 0px;\">Not Found</p>\n<p>The server has not found anything matching the request URI</p>\n<p>You can get technical details <a href=\"http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html#sec10.4.5\">here</a>.<br>\nPlease continue your visit at our <a href=\"/\">home page</a>.\n</p>\n</body>\n</html>\n","headers":{"date":"Thu, 17 Nov 2022 09:29:11 GMT","accept-ranges":"bytes","server":"Restlet-Framework/2.3.12","content-length":"439","content-type":"text/html; charset=UTF-8"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.35:1925","port":"1925","hostname":"192.168.178.35","hash":null,"search":null,"query":null,"pathname":"/1/audio/volume","path":"/1/audio/volume","href":"http://192.168.178.35:1925/1/audio/volume"},"method":"GET","headers":{}}}
      kannst du was, mit der Fehlermeldung anfangen?
      Der 65OLED804/12 ist über Lan angeschlossen.
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      #452
      @senger1985 Also der OLED804 hat auf jeden Fall die v6 API mit Android. Da liegt es wenn an Netzwerk o. ä.
      Der TV ist anpingbar vom ioBroker aus?
      Videotutorials & mehr
      S 3 Antworten Letzte Antwort
        senger1985
        #453
        @foxriver76 beim ersten Starten und Einrichtungsversuch, ja.
        Danach blieb der Adapter, aber gelb.
        Danach nicht mehr.
        Der TV war an und auch auch "TV schauen" eingestellt.
          senger1985
          #454
          @foxriver76 ich bekomme auch einen "ESOCKETTIMEDOUT"
          • K Kuddel
            heute kam mein neuer 70PUS7906/12
            Jetzt komme ich mit dem Adapter nicht weiter:
            Adapter-Einstellungen
            Fehler
            Log
            philips-tv.0	2022-11-15 16:45:01.710	warn	Please authenticate via the adapter configuration page
            philips-tv.0	2022-11-15 16:45:01.709	info	Starting with ip "192.168.4.8" (API v6 - Android)
            philips-tv.0	2022-11-15 16:45:01.688	info	starting. Version 0.5.2 (non-npm: AlCalzone/ioBroker.philips-tv#9e26469ed1578d03847fe168f5cc22bc4b064305) in /opt/iobroker/node_modules/iobroker.philips-tv, node: v16.18.0, js-controller: 4.0.23
            jmeister79J Offline
            jmeister79J Offline
            jmeister79
            #455
            @kuddel sagte in Test Adapter Philips-TV v0.2.x:
            Fehler
            Log
            Ich schließe mich dem an.
            Na auch beim Single's day zugeschlagen?
            Habe auch den 70" und kriege Connection refused.
            K 2 Antworten Letzte Antwort
            • jmeister79J jmeister79
              Fehler
              Log
              Kuddel
              #456
              Ich will mit diesem Adapter eigentlich erst einmal nur das Ambilight passend zur Tageszeit an- bzw. ausschalten.
              Gibt es da evtl. auch eine Alternative zu diesem Adapter?
                senger1985
                #457
                @foxriver76 frag mich bitte nicht, was ich jetzt anders gemacht habe, aber ich habe gerade(aus Langeweile) erneut versucht, meinen OLED804, mit dem Adapter zu verbinden und siehe da, es geht.
                Der Adapter ist grün und lässt sich mit dem Adapter steuern.
                Aber eine Frage habe ich.
                Wenn ich jetzt mit "launchApp" z. B. "Disney+" starte und den TV danach ausschalte, kann ich "Disney+" nicht erneut auswählen, da der DP noch mit dem Wert "Disney+" gefüllt ist.
                Gibt es da irgendeinen Trick?
                  Fehler
                  Log
                  Kuddel
                  #458
                  @jmeister79 hast du deinen TV schon anbinden können?
                  Ich leider immer noch nicht
                  • K Kuddel
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    #459
                    @kuddel Mal den TV anmachen, sicher stellen, dass er im Netzwerk ist und https://ip-des-tvs:1926/6/system vom Rechner aufrufen.
                    K foxriver76F 2 Antworten Letzte Antwort
                      Kuddel
                      #460
                      @foxriver76 die IP vom TV ist pingbar. Die URL kann aber leider nicht gefunden werden
                      • K Kuddel
                        foxriver76F Offline
                        foxriver76F Offline
                        foxriver76
                        schrieb am zuletzt editiert von foxriver76
                        #461
                        @kuddel Unabhängig davon, gibt es das bei dir? https://www.amazon.de/Philips-Television-Smart-TV-Sprachsteuerung/dp/B07JFSPV73
                        Soweit ich gelesen habe haben sie bei dem Modell auch Ambilight + Hue wegrationalisiert, nicht dass sie die API da auch weggelassen haben. 💩
                        UNTERSTÜTZTE MODELLE
                        Bei Philips Smart TV-Modellen, die diesen Skill unterstützen, finden Sie die "Amazon Alexa"-Client-App auf dem Startbildschirm. Sie müssen die App nicht manuell installieren. Vergewissern Sie sich, dass Ihr Fernsehgerät mit dem Internet verbunden ist und die neueste Softwareversion installiert ist. Sollte sich die App nicht auf dem Startbildschirm befinden, unterstützt Ihr Fernsehgerät diesen Skill noch nicht. Beispielsweise: "Wohnzimmer-Fernseher", "Fernseher", "Medienraum-Fernseher" usw.
                          Kuddel
                          #462
                          @foxriver76 bei meinem TV läuft die Sprachsteuerung über Google Assistent
                          jmeister79J 1 Antwort Letzte Antwort
                          • K Kuddel
                            jmeister79J Offline
                            jmeister79J Offline
                            jmeister79
                            #463
                            @kuddel leider bin ich kixh jixht weiter.
                            Anpingbar isser glaub ich aber ich krieg bei allen versuchen n Connection refused.
                              Kuddel
                              #464
                              @jmeister79 da ich einen Logitech Harmony Hub im Eisatz habe, werde ich erst einmal darüber das Ambilight schalten.
                              Tastenfolge Ambilight, Select, Exit
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                #465
                                https://ip-des-tvs:1926/5/system wäre noch möglich, sonst ist meine Vermutung, dass der TV keine der bekannten APIs unterstützt
                                  Kuddel
                                  #466
                                  @foxriver76 funzt leider auch nicht. Hmm sehr schade. Ich dachte eigentlich, dass ich mit einem Philips Android TV nicht falsch machen kann
                                  • K Kuddel
                                    foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    #467
                                    @kuddel Ansonsten mach mal von einem Linux Rechner z. B. deinem iob Host:
                                    nmap -p- ip-des-tvs
                                      nmap -p- ip-des-tvs
                                      Kuddel
                                      schrieb am zuletzt editiert von Kuddel
                                      #468
                                      @foxriver76 wenn es um die offenen Ports vom TV geht
                                      Nmap scan report for Phillips-70 (192.168.4.8)
                                      Host is up (0.0054s latency).
                                      Not shown: 65524 closed ports
                                      PORT      STATE SERVICE
                                      6466/tcp  open  unknown
                                      6467/tcp  open  unknown
                                      8008/tcp  open  http
                                      8009/tcp  open  ajp13
                                      8443/tcp  open  https-alt
                                      9000/tcp  open  cslistener
                                      10101/tcp open  ezmeeting-2
                                      35641/tcp open  unknown
                                      44691/tcp open  unknown
                                      56789/tcp open  unknown
                                      56790/tcp open  unknown
                                      • K Kuddel
                                        PORT      STATE SERVICE
                                        8008/tcp  open  http
                                        8009/tcp  open  ajp13
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        #469
                                        @kuddel Ja, da fehlen die beiden Ports für die API 1925/1926. In den TV Einstellungen gibts da vermutlich auch nix?
                                        So schaut es bei mir aus:
                                        PORT      STATE SERVICE
                                        1925/tcp  open  discovery-port
                                        1926/tcp  open  egs
                                        8008/tcp  open  http
                                        8009/tcp  open  ajp13
                                        9080/tcp  open  glrpc
                                        36177/tcp open  unknown
                                        45235/tcp open  unknown
                                        49153/tcp open  unknown
                                        50727/tcp open  unknown
                                          PORT      STATE SERVICE
                                          1926/tcp  open  egs
                                          8008/tcp  open  http
                                          8009/tcp  open  ajp13
                                          9080/tcp  open  glrpc
                                          Kuddel
                                          #470
                                          @foxriver76 in den Einstellungen habe ich nichts gefunden.
                                          Die Anleitungen zum aktivieren von JointSpace funzen leider auch nicht, da ich über einen VU+ Reciver schaue und nicht direkt über den TV.
                                          Wenn ich also auf TV wechsle und 5646877223 eingeben, kommt immer nur was von wegen "Sender suchen"
